# # ChangeLog for scripts/mkgccnewlibspec.in in rtems # # Generated by Trac 1.2.1.dev0 # 04/19/24 11:15:34 Tue, 25 Jan 2000 19:47:32 GMT Joel Sherrill [5eac93c7] * scripts/binutils/binutils.spec.in (modified) * scripts/buildall.in (modified) * scripts/gdb/gdb.spec.in (modified) * scripts/mkbinutilspec.in (modified) * scripts/mkbspspec.in (modified) * scripts/mkgccnewlibspec.in (modified) * scripts/mkgdbspec.in (modified) * scripts/mkgnatnewlibspec.in (modified) Now binutils, gcc, and gdb build into a "base" package that is shared ... Sun, 23 Jan 2000 19:20:02 GMT Joel Sherrill [0c602f0] * scripts/binutils/binutils.spec.in (modified) * scripts/configure.in (modified) * scripts/gccnewlib/gccnewlib.spec.in (modified) * scripts/gccnewlib/gccnewlib_c_only.spec.in (modified) * scripts/gdb/gdb.spec.in (modified) * scripts/gnatnewlib/gnatnewlib.spec.in (modified) * scripts/mkbinutilspec.in (modified) * scripts/mkbspspec.in (modified) * scripts/mkgccnewlibspec.in (modified) * scripts/mkgdbspec.in (modified) * scripts/mkgnatnewlibspec.in (modified) Patch from David Fiddes which adds basic ... Thu, 18 Nov 1999 20:37:29 GMT Joel Sherrill [97d7eaf8] * scripts/mkgccnewlibspec.in (modified) Added ";;" to correct syntactical error. Thu, 04 Nov 1999 18:05:09 GMT Joel Sherrill [f817b02] * c/src/exec/rtems/include/rtems.h (modified) * c/src/exec/sapi/include/rtems/config.h (modified) * c/src/exec/score/cpu/mips/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/cpu.h (modified) * c/src/lib/libbsp/mips/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mcp750/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/clock/Makefile.in (added) * c/src/lib/libbsp/powerpc/mcp750/clock/c_clock.c (added) * c/src/lib/libbsp/powerpc/mcp750/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/clock/Makefile.in (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/clock/c_clock.c (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/clock/clock.c (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/semaphore/semaphore.c (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.in (modified) * c/src/lib/libcpu/mips/clock/ckinit.c (modified) * c/src/lib/libcpu/mips/timer/timer.c (modified) * c/src/lib/libcpu/mips64orion/clock/ckinit.c (modified) * c/src/lib/libcpu/mips64orion/include/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/mpc505/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/wrapup/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc821/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/mpc821/vectors/align_h.S (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/mpc860/vectors/align_h.S (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console.c (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console.c.polled (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/ictrl.c (modified) * c/src/lib/libcpu/powerpc/ppc403/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/timer.c (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/align_h.S (modified) * c/src/lib/libcpu/sh/sh7032/clock/ckinit.c (modified) * c/src/lib/libcpu/sh/sh7032/console/console.c (modified) * c/src/lib/libcpu/sh/sh7032/include/sci.h (modified) * c/src/lib/libcpu/sh/sh7032/timer/timer.c (modified) * c/src/tests/psxtests/psxstat/main.c (modified) * c/src/tests/samples/minimum/init.c (modified) * cpukit/rtems/include/rtems.h (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/score/cpu/mips/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips64orion/rtems/score/cpu.h (modified) * scripts/Makefile.am (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gnatnewlib/gnatnewlib.spec.in (modified) * scripts/mkgccnewlibspec.in (modified) * testsuites/psxtests/psxstat/main.c (modified) * testsuites/samples/minimum/init.c (modified) The files in libcpu should not be directly dependent on any BSP. In ... Thu, 21 Oct 1999 17:22:02 GMT Joel Sherrill [7063e223] * scripts/Makefile.in (modified) * scripts/binutils/Makefile.in (modified) * scripts/binutils/binutils.spec.in (modified) * scripts/configure (modified) * scripts/configure.in (modified) * scripts/gccnewlib/Makefile.in (modified) * scripts/gdb/Makefile.in (modified) * scripts/gdb/gdb.spec.in (modified) * scripts/mkbinutilspec.in (modified) * scripts/mkbspspec.in (modified) * scripts/mkgccnewlibspec.in (modified) * scripts/mkgdbspec.in (modified) * scripts/rtems/rtems.spec.in (modified) * scripts/setup (modified) Made the RTEMS version get substituted properly even though it is ... Thu, 21 Oct 1999 15:59:54 GMT Joel Sherrill [43e7d103] * scripts/Makefile.am (modified) * scripts/binutils/Makefile.am (modified) * scripts/binutils/Makefile.in (modified) * scripts/binutils/binutils.spec.in (modified) * scripts/buildall.in (modified) * scripts/configure.in (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gccnewlib/Makefile.in (modified) * scripts/gccnewlib/gccnewlib.spec.in (modified) * scripts/gdb/Makefile.am (modified) * scripts/gdb/Makefile.in (modified) * scripts/gdb/gdb.spec.in (modified) * scripts/mkbinutils_subpackage_version (modified) * scripts/mkbinutilspec.in (modified) * scripts/mkbspspec.in (modified) * scripts/mkgccnewlibspec.in (modified) * scripts/mkgdbspec.in (modified) * scripts/rtems/Makefile.am (modified) * scripts/setup (modified) Changes from Ralf with script-19991021-0. He fixed the %files issue ... Wed, 20 Oct 1999 19:59:01 GMT Joel Sherrill [431c35d] * scripts/Makefile.am (modified) * scripts/Makefile.in (modified) * scripts/TODO (modified) * scripts/binutils/binutils.spec.in (modified) * scripts/buildall (deleted) * scripts/configure (modified) * scripts/configure.in (modified) * scripts/gccnewlib/gccnewlib.spec.in (modified) * scripts/gdb/gdb.spec.in (modified) * scripts/mkbinutils_subpackage_version (modified) * scripts/mkbinutilspec.in (modified) * scripts/mkgccnewlibspec.in (modified) * scripts/mkgdbspec.in (modified) Miscellaneous improvements and cleanups committed so I can merge ... Wed, 20 Oct 1999 15:29:12 GMT Joel Sherrill [10629f7] * scripts/Makefile.am (added) * scripts/Makefile.in (added) * scripts/TODO (modified) * scripts/aclocal.m4 (added) * scripts/binutils/Makefile.am (added) * scripts/binutils/Makefile.in (added) * scripts/binutils/binutils.spec.in (added) * scripts/buildall (modified) * scripts/configure (added) * scripts/configure.in (added) * scripts/gccnewlib.spec.in (modified) * scripts/gccnewlib/Makefile.am (added) * scripts/gccnewlib/Makefile.in (added) * scripts/gccnewlib/gccnewlib.spec.in (added) * scripts/gdb.spec.in (modified) * scripts/install-sh (added) * scripts/missing (added) * scripts/mkbinutilspec (modified) * scripts/mkbinutilspec.in (added) * scripts/mkgccnewlibspec (modified) * scripts/mkgccnewlibspec.in (added) * scripts/mkgdbspec (modified) * scripts/mkinstalldirs (added) * scripts/mkspec (modified) * scripts/rtems.spec.in (modified) * scripts/setup (added) * scripts/setup.cache (added) * scripts/setup.def (added) New version from Ralf.
