# # ChangeLog for scripts/mkbspspec.in in rtems # # Generated by Trac 1.2.1.dev0 # 04/24/24 12:06:26 Tue, 25 Jan 2000 19:47:32 GMT Joel Sherrill [5eac93c7] * scripts/binutils/binutils.spec.in (modified) * scripts/buildall.in (modified) * scripts/gdb/gdb.spec.in (modified) * scripts/mkbinutilspec.in (modified) * scripts/mkbspspec.in (modified) * scripts/mkgccnewlibspec.in (modified) * scripts/mkgdbspec.in (modified) * scripts/mkgnatnewlibspec.in (modified) Now binutils, gcc, and gdb build into a "base" package that is shared ... Sun, 23 Jan 2000 19:20:02 GMT Joel Sherrill [0c602f0] * scripts/binutils/binutils.spec.in (modified) * scripts/configure.in (modified) * scripts/gccnewlib/gccnewlib.spec.in (modified) * scripts/gccnewlib/gccnewlib_c_only.spec.in (modified) * scripts/gdb/gdb.spec.in (modified) * scripts/gnatnewlib/gnatnewlib.spec.in (modified) * scripts/mkbinutilspec.in (modified) * scripts/mkbspspec.in (modified) * scripts/mkgccnewlibspec.in (modified) * scripts/mkgdbspec.in (modified) * scripts/mkgnatnewlibspec.in (modified) Patch from David Fiddes which adds basic ... Mon, 22 Nov 1999 14:30:41 GMT Joel Sherrill [b41a0d1] * scripts/configure.in (modified) * scripts/mkbspspec.in (modified) * scripts/rtems/rtems.spec.in (modified) * scripts/setup (modified) * scripts/setup.def (modified) RTEMS RPM basically working. Thu, 21 Oct 1999 17:22:02 GMT Joel Sherrill [7063e223] * scripts/Makefile.in (modified) * scripts/binutils/Makefile.in (modified) * scripts/binutils/binutils.spec.in (modified) * scripts/configure (modified) * scripts/configure.in (modified) * scripts/gccnewlib/Makefile.in (modified) * scripts/gdb/Makefile.in (modified) * scripts/gdb/gdb.spec.in (modified) * scripts/mkbinutilspec.in (modified) * scripts/mkbspspec.in (modified) * scripts/mkgccnewlibspec.in (modified) * scripts/mkgdbspec.in (modified) * scripts/rtems/rtems.spec.in (modified) * scripts/setup (modified) Made the RTEMS version get substituted properly even though it is ... Thu, 21 Oct 1999 15:59:54 GMT Joel Sherrill [43e7d103] * scripts/Makefile.am (modified) * scripts/binutils/Makefile.am (modified) * scripts/binutils/Makefile.in (modified) * scripts/binutils/binutils.spec.in (modified) * scripts/buildall.in (modified) * scripts/configure.in (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gccnewlib/Makefile.in (modified) * scripts/gccnewlib/gccnewlib.spec.in (modified) * scripts/gdb/Makefile.am (modified) * scripts/gdb/Makefile.in (modified) * scripts/gdb/gdb.spec.in (modified) * scripts/mkbinutils_subpackage_version (modified) * scripts/mkbinutilspec.in (modified) * scripts/mkbspspec.in (modified) * scripts/mkgccnewlibspec.in (modified) * scripts/mkgdbspec.in (modified) * scripts/rtems/Makefile.am (modified) * scripts/setup (modified) Changes from Ralf with script-19991021-0. He fixed the %files issue ... Wed, 20 Oct 1999 19:54:36 GMT Joel Sherrill [0f242f5f] * scripts/mkbspspec.in (moved) * scripts/rtems.spec.in (deleted) Moving things to an rtems subdirectory like the other tools.
