# # ChangeLog for scripts/gccnewlib/gccnewlib.add in rtems # # Generated by Trac 1.2.1.dev0 # 04/23/24 15:33:28 Sun, 28 May 2000 18:14:55 GMT Joel Sherrill [63cf252f] * scripts/Makefile.am (modified) * scripts/binutils/Makefile.am (modified) * scripts/binutils/base-binutils.add (modified) * scripts/binutils/binutils.add (modified) * scripts/binutils/binutils.spec.in (deleted) * scripts/binutils/target-binutils.add (modified) * scripts/config.guess (deleted) * scripts/config.sub (deleted) * scripts/gccnewlib/Makefile.am (modified) * scripts/gccnewlib/README (added) * scripts/gccnewlib/base-chill.add (modified) * scripts/gccnewlib/base-g77.add (modified) * scripts/gccnewlib/base-gcc.add (modified) * scripts/gccnewlib/base-gcj.add (modified) * scripts/gccnewlib/gccnewlib.add (modified) * scripts/gccnewlib/gccnewlib.spec.in (deleted) * scripts/gccnewlib/gccnewlib_c_only.spec.in (deleted) * scripts/gccnewlib/target-chill.add (modified) * scripts/gccnewlib/target-g77.add (modified) * scripts/gccnewlib/target-gcc.add (modified) * scripts/gccnewlib/target-gcj.add (modified) * scripts/gccnewlib/target-objc.add (modified) * scripts/gdb/Makefile.am (modified) * scripts/gdb/base-gdb.add (modified) * scripts/gdb/gdb.add (modified) * scripts/gdb/gdb.spec.in (deleted) * scripts/gdb/target-gdb.add (modified) * scripts/install-sh (deleted) * scripts/missing (deleted) Patch rtems-rc-4.5.0-21.diff from Ralf Corsepius [22095e22] * scripts/binutils/base-binutils.add (added) * scripts/binutils/binutils.add (added) * scripts/binutils/target-binutils.add (added) * scripts/gccnewlib/base-chill.add (added) * scripts/gccnewlib/base-g77.add (added) * scripts/gccnewlib/base-gcc.add (added) * scripts/gccnewlib/base-gcj.add (added) * scripts/gccnewlib/gccnewlib.add (added) * scripts/gccnewlib/target-chill.add (added) * scripts/gccnewlib/target-g77.add (added) * scripts/gccnewlib/target-gcc.add (added) * scripts/gccnewlib/target-gcj.add (added) * scripts/gccnewlib/target-objc.add (added) * scripts/gdb/base-gdb.add (added) * scripts/gdb/gdb.add (added) * scripts/gdb/target-gdb.add (added) This commit was manufactured by cvs2svn to create branch ...
