# # ChangeLog for scripts/gccnewlib/Makefile.am in rtems # # Generated by Trac 1.2.1.dev0 # 03/19/24 02:29:31 Thu, 21 Oct 1999 15:59:54 GMT Joel Sherrill [43e7d103] * scripts/Makefile.am (modified) * scripts/binutils/Makefile.am (modified) * scripts/binutils/Makefile.in (modified) * scripts/binutils/binutils.spec.in (modified) * scripts/buildall.in (modified) * scripts/configure.in (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gccnewlib/Makefile.in (modified) * scripts/gccnewlib/gccnewlib.spec.in (modified) * scripts/gdb/Makefile.am (modified) * scripts/gdb/Makefile.in (modified) * scripts/gdb/gdb.spec.in (modified) * scripts/mkbinutils_subpackage_version (modified) * scripts/mkbinutilspec.in (modified) * scripts/mkbspspec.in (modified) * scripts/mkgccnewlibspec.in (modified) * scripts/mkgdbspec.in (modified) * scripts/rtems/Makefile.am (modified) * scripts/setup (modified) Changes from Ralf with script-19991021-0. He fixed the %files issue ... Wed, 20 Oct 1999 15:29:12 GMT Joel Sherrill [10629f7] * scripts/Makefile.am (added) * scripts/Makefile.in (added) * scripts/TODO (modified) * scripts/aclocal.m4 (added) * scripts/binutils/Makefile.am (added) * scripts/binutils/Makefile.in (added) * scripts/binutils/binutils.spec.in (added) * scripts/buildall (modified) * scripts/configure (added) * scripts/configure.in (added) * scripts/gccnewlib.spec.in (modified) * scripts/gccnewlib/Makefile.am (added) * scripts/gccnewlib/Makefile.in (added) * scripts/gccnewlib/gccnewlib.spec.in (added) * scripts/gdb.spec.in (modified) * scripts/install-sh (added) * scripts/missing (added) * scripts/mkbinutilspec (modified) * scripts/mkbinutilspec.in (added) * scripts/mkgccnewlibspec (modified) * scripts/mkgccnewlibspec.in (added) * scripts/mkgdbspec (modified) * scripts/mkinstalldirs (added) * scripts/mkspec (modified) * scripts/rtems.spec.in (modified) * scripts/setup (added) * scripts/setup.cache (added) * scripts/setup.def (added) New version from Ralf.
