# # ChangeLog for scripts/buildall.in in rtems # # Generated by Trac 1.2.1.dev0 # 04/24/24 14:48:16 Tue, 25 Jan 2000 19:47:32 GMT Joel Sherrill [5eac93c7] * scripts/binutils/binutils.spec.in (modified) * scripts/buildall.in (modified) * scripts/gdb/gdb.spec.in (modified) * scripts/mkbinutilspec.in (modified) * scripts/mkbspspec.in (modified) * scripts/mkgccnewlibspec.in (modified) * scripts/mkgdbspec.in (modified) * scripts/mkgnatnewlibspec.in (modified) Now binutils, gcc, and gdb build into a "base" package that is shared ... Fri, 14 Jan 2000 17:41:45 GMT Joel Sherrill [1cb2f89a] * scripts/buildall.in (modified) Updated list of targets to build. Tue, 02 Nov 1999 16:07:06 GMT Joel Sherrill [ee9d8d52] * scripts/buildall.in (modified) Clean up /opt/rtems in case junk is installed in the wrong place. ... Thu, 21 Oct 1999 15:59:54 GMT Joel Sherrill [43e7d103] * scripts/Makefile.am (modified) * scripts/binutils/Makefile.am (modified) * scripts/binutils/Makefile.in (modified) * scripts/binutils/binutils.spec.in (modified) * scripts/buildall.in (modified) * scripts/configure.in (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gccnewlib/Makefile.in (modified) * scripts/gccnewlib/gccnewlib.spec.in (modified) * scripts/gdb/Makefile.am (modified) * scripts/gdb/Makefile.in (modified) * scripts/gdb/gdb.spec.in (modified) * scripts/mkbinutils_subpackage_version (modified) * scripts/mkbinutilspec.in (modified) * scripts/mkbspspec.in (modified) * scripts/mkgccnewlibspec.in (modified) * scripts/mkgdbspec.in (modified) * scripts/rtems/Makefile.am (modified) * scripts/setup (modified) Changes from Ralf with script-19991021-0. He fixed the %files issue ... Thu, 21 Oct 1999 05:07:17 GMT Joel Sherrill [98e6eb8] * scripts/buildall.in (modified) * scripts/rtems/Makefile.am (modified) Shipping this all to Ralf. Wed, 20 Oct 1999 20:23:18 GMT Joel Sherrill [2f23359] * scripts/Makefile.am (modified) * scripts/Makefile.in (modified) * scripts/binutils/Makefile.in (modified) * scripts/buildall.in (modified) * scripts/configure (modified) * scripts/configure.in (modified) * scripts/gdb/Makefile.in (modified) Moved stuff to rtems subdirectory and made sure the system still ... Wed, 20 Oct 1999 19:51:57 GMT Joel Sherrill [d35e532b] * scripts/buildall.in (added) New file.
