# # ChangeLog for scripts/TODO in rtems # # Generated by Trac 1.2.1.dev0 # 04/25/24 05:01:03 Wed, 20 Oct 1999 19:59:01 GMT Joel Sherrill [431c35d] * scripts/Makefile.am (modified) * scripts/Makefile.in (modified) * scripts/TODO (modified) * scripts/binutils/binutils.spec.in (modified) * scripts/buildall (deleted) * scripts/configure (modified) * scripts/configure.in (modified) * scripts/gccnewlib/gccnewlib.spec.in (modified) * scripts/gdb/gdb.spec.in (modified) * scripts/mkbinutils_subpackage_version (modified) * scripts/mkbinutilspec.in (modified) * scripts/mkgccnewlibspec.in (modified) * scripts/mkgdbspec.in (modified) Miscellaneous improvements and cleanups committed so I can merge ... Wed, 20 Oct 1999 15:29:12 GMT Joel Sherrill [10629f7] * scripts/Makefile.am (added) * scripts/Makefile.in (added) * scripts/TODO (modified) * scripts/aclocal.m4 (added) * scripts/binutils/Makefile.am (added) * scripts/binutils/Makefile.in (added) * scripts/binutils/binutils.spec.in (added) * scripts/buildall (modified) * scripts/configure (added) * scripts/configure.in (added) * scripts/gccnewlib.spec.in (modified) * scripts/gccnewlib/Makefile.am (added) * scripts/gccnewlib/Makefile.in (added) * scripts/gccnewlib/gccnewlib.spec.in (added) * scripts/gdb.spec.in (modified) * scripts/install-sh (added) * scripts/missing (added) * scripts/mkbinutilspec (modified) * scripts/mkbinutilspec.in (added) * scripts/mkgccnewlibspec (modified) * scripts/mkgccnewlibspec.in (added) * scripts/mkgdbspec (modified) * scripts/mkinstalldirs (added) * scripts/mkspec (modified) * scripts/rtems.spec.in (modified) * scripts/setup (added) * scripts/setup.cache (added) * scripts/setup.def (added) New version from Ralf. Mon, 18 Oct 1999 19:10:03 GMT Joel Sherrill [8c5e54b] * scripts/README (modified) * scripts/TODO (added) * scripts/binutils.spec.in (added) * scripts/gccnewlib.spec.in (added) * scripts/gdb.spec.in (added) * scripts/mkbinutils_subpackage_version (added) * scripts/mkbinutilspec (added) * scripts/mkgccnewlibspec (added) * scripts/mkgdbspec (added) * scripts/mkspec (modified) * scripts/mktoolspec (modified) * scripts/toolchain.spec.in (modified) Working on being able to cut RPMs. It now appears that the process ...
