Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/scripts/ChangeLog
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @4e445522   01/28/04 21:45:51 Joel Sherrill 2004-01-28 RTEMS * buildall.in, buildalltar.in, … 4.104.114.84.95
(edit) @e85312d   01/28/04 21:19:49 Joel Sherrill 2004-01-28 RTEMS * configure.ac: Enable OS versioning by default for … 4.104.114.84.95
(edit) @f5d3cf6   01/13/04 12:51:00 Ralf Corsepius 2004-01-13 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @a1f0115d   01/12/04 06:03:17 Ralf Corsepius 2004-01-12 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @daec7a9   01/08/04 16:49:25 Joel Sherrill 2004-01-08 Joel Sherrill <joel@…> * setup.def: Update … 4.104.114.84.95
(edit) @282180cc   01/07/04 20:35:07 Joel Sherrill 2004-01-07 Joel Sherrill <joel@…> * buildall.in, … 4.104.114.84.95
(edit) @587d22de   12/16/03 13:53:52 Joel Sherrill 2003-12-16 Joel Sherrill <joel@…> * setup.def: Update … 4.104.114.84.95
(edit) @810720b6   12/12/03 03:28:02 Ralf Corsepius 2003-12-12 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @eec8e59e   12/11/03 16:12:23 Ralf Corsepius 2003-12-11 Ralf Corsepius <corsepiu@…> * Makefile.am: … 4.104.114.84.95
(edit) @61f41e2   11/17/03 12:52:01 Ralf Corsepius 2003-11-17 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @3c8fa15   10/30/03 09:29:19 Ralf Corsepius 2003-10-30 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @c83a419a   10/23/03 10:03:00 Ralf Corsepius 2003-10-23 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @4be8e00   10/22/03 19:57:43 Ralf Corsepius 2003-10-22 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @d61e9c0f   10/22/03 17:25:00 Joel Sherrill 2003-10-22 Joel Sherrill <joel@…> * configure.ac, … 4.104.114.84.95
(edit) @06e70cd   10/07/03 08:53:29 Ralf Corsepius 2003-10-07 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @869ffd9b   10/07/03 08:48:42 Ralf Corsepius 2003-10-07 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @923ecb6   09/26/03 21:48:56 Joel Sherrill 2003-09-26 Joel Sherrill <joel@…> * buildall.in, … 4.104.114.84.95
(edit) @2783df0   09/24/03 08:06:56 Ralf Corsepius 2003-09-24 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @937d881   09/18/03 07:36:48 Ralf Corsepius 2003-09-18 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @cdf5ff65   09/04/03 14:39:05 Ralf Corsepius 2003-09-04 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @dbb13bf   09/04/03 14:35:59 Ralf Corsepius 2003-09-04 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @f8f365a6   09/04/03 13:35:27 Ralf Corsepius 2003-09-04 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @087a6c86   09/02/03 16:41:50 Ralf Corsepius 2003-09-02 Ralf Corsepius <corsepiu@…> * Makefile.am, … 4.104.114.84.95
(edit) @ae674781   08/24/03 04:41:10 Ralf Corsepius 2003-08-23 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @5c47f47   08/22/03 10:31:12 Ralf Corsepius 2003-08-22 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @7dcc3fe   08/11/03 14:20:43 Ralf Corsepius 2003-08-11 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @a753ab2   07/13/03 16:16:27 Ralf Corsepius 2003-07-13 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @e1f8bf05   06/04/03 15:07:00 Ralf Corsepius 2003-06-04 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @be36fee0   06/02/03 16:49:33 Joel Sherrill 2003-06-02 Joel Sherrill <joel@…> * setup.def: Updated for … 4.104.114.84.95
(edit) @caebcb5b   05/07/03 18:07:29 Joel Sherrill 2003-05-07 Joel Sherrill <joel@…> * setup.def: Update to … 4.104.114.84.95
(edit) @888fc8e2   04/18/03 12:56:22 Joel Sherrill 2003-04-18 Joel Sherrill <joel@…> * setup.def: Update to … 4.104.114.84.95
(edit) @69b742e   03/11/03 12:40:35 Ralf Corsepius Merger from rtems-4-6-branch. 4.104.114.84.95
(edit) @a696c7a   02/26/03 18:05:17 Joel Sherrill 2003-02-26 RTEMS * setup.def: Updated gdb revision to -2 so arm will … 4.104.114.84.95
(edit) @ccd81b60   02/11/03 11:47:49 Ralf Corsepius 2003-02-11 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @9b5c258   02/11/03 11:11:33 Ralf Corsepius 2003-02-11 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @de819f6e   02/10/03 16:32:27 Joel Sherrill 2003-02-10 Joel Sherrill <joel@…> * gdb/gdb.add, … 4.104.114.84.95
(edit) @553e297   02/07/03 05:16:41 Ralf Corsepius 2003-02-07 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @7da8c10   01/31/03 16:02:21 Ralf Corsepius 2003-01-31 Ralf Corsepius <corsepiu@…> * README.cdn-X: … 4.104.114.84.95
(edit) @36f18e07   01/31/03 07:32:21 Ralf Corsepius 2003-01-31 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @ab591073   01/31/03 07:29:27 Ralf Corsepius 2003-01-31 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @59292fe9   01/31/03 06:22:09 Ralf Corsepius 2003-01-31 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @9c8ee7b   01/31/03 05:32:20 Ralf Corsepius 2003-01-31 Ralf Corsepius <corsepiu@…> * gdb/gdb.add: … 4.104.114.84.95
(edit) @491b8b2e   01/31/03 05:21:08 Ralf Corsepius 2003-01-31 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @6044dd2f   01/31/03 05:10:02 Ralf Corsepius 2003-01-31 Ralf Corsepius <corsepiu@…> * Makefile.am: … 4.104.114.84.95
(edit) @0ac55c0   01/31/03 04:58:01 Ralf Corsepius 2003-01-31 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @b5b0433e   01/31/03 04:46:44 Ralf Corsepius 2003-01-31 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @d413a66   01/30/03 10:26:45 Ralf Corsepius 2003-01-30 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @b601e1a   01/30/03 10:21:40 Ralf Corsepius 2003-01-30 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @00b8107   01/29/03 14:07:35 Ralf Corsepius 2003-01-29 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @c86d8e7f   01/29/03 14:06:02 Ralf Corsepius 2003-01-29 Ralf Corsepius <corsepiu@…> * ChangeLog?: Fix … 4.104.114.84.95
(edit) @9b0bb5a4   01/28/03 15:39:35 Ralf Corsepius 2003-01-28 Ralf Corsepius <corsepiu@…> * gccnewlib.add: … 4.104.114.84.95
(edit) @986eab46   01/28/03 06:19:20 Ralf Corsepius 2003-01-28 Ralf Corsepius <corsepiu@…> * ChangeLog?: … 4.104.114.84.95
(edit) @d5dd9b9   01/28/03 06:17:15 Ralf Corsepius 2003-01-28 Ralf Corsepius <corsepiu@…> * setup.def: … 4.104.114.84.95
(edit) @180a2ebd   01/27/03 16:38:54 Joel Sherrill 2003-01-27 RTEMS * buildalltar.in, setup.def: Tool update including … 4.104.114.84.95
(edit) @2eb3fdaa   01/26/03 08:20:30 Ralf Corsepius 2003-01-26 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @2dae735f   01/26/03 08:13:55 Ralf Corsepius 2003-01-26 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @0d1ce40   12/17/02 00:01:28 Joel Sherrill 2002-12-16 Joel Sherrill <joel@…> * setup.def: Updated gcc … 4.104.114.84.95
(edit) @09e391d   12/07/02 12:59:43 Ralf Corsepius 2002-12-07 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @07bf9f9d   12/06/02 13:51:35 Joel Sherrill 2002-12-06 Joel Sherrill <joel@…> * ChangeLog?: Removed … 4.104.114.84.95
(edit) @4f7ee21   12/06/02 13:51:15 Joel Sherrill 2002-12-06 Joel Sherrill <joel@…> * setup.def: Updated … 4.104.114.84.95
(edit) @e09c5c59   12/06/02 13:51:12 Joel Sherrill 2002-12-06 Joel Sherrill <joel@…> * setup.def: Updated … 4.104.114.84.95
(edit) @2e332a9   12/02/02 19:17:27 Joel Sherrill 2002-12-02 Joel Sherrill <joel@…> * setup.def, … 4.104.114.84.95
(edit) @472f35a   11/29/02 21:18:29 Joel Sherrill 2002-11-29 Joel Sherrill <joel@…> * setup.def: Updated to … 4.104.114.84.95
(edit) @f7e1564   11/28/02 21:12:23 Joel Sherrill 2002-11-28 Joel Sherrill <joel@…> * setup.def: Updated to … 4.104.114.84.95
(edit) @d35b77f   11/25/02 15:24:05 Ralf Corsepius 2002-11-25 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @e4eb1be   11/22/02 18:15:43 Ralf Corsepius 2002-11-22 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @b04b5ca7   11/15/02 13:24:03 Ralf Corsepius 2002-11-15 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @39f76ad   11/13/02 18:00:10 Joel Sherrill 2002-11-13 Joel Sherrill <joel@…> * setup.def: Switched to … 4.104.114.84.95
(edit) @45162744   11/11/02 21:37:37 Joel Sherrill 2002-11-11 Joel Sherrill <joel@…> * setup.def, … 4.104.114.84.95
(edit) @60ac65d   10/29/02 16:53:14 Ralf Corsepius 2002-10-29 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @d08b8eb8   10/25/02 14:56:47 Ralf Corsepius 2002-10-25 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @d21091b   10/25/02 14:52:25 Ralf Corsepius 2002-10-25 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @17a11842   10/24/02 22:34:37 Joel Sherrill 2002-10-24 Joel Sherrill <joel@…> * setup.def: Update gcc … 4.104.114.84.95
(edit) @8730f45   10/21/02 12:19:27 Ralf Corsepius 2002-10-21 Ralf Corsepius <corsepiu@…> * .cvsignore: … 4.104.114.84.95
(edit) @99e797a5   09/14/02 20:10:21 Joel Sherrill 2002-09-14 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @3e1526f0   08/21/02 18:50:04 Joel Sherrill 2002-08-21 Joel Sherrill <joel@…> * setup.def, … 4.104.114.84.95
(edit) @fa42a76b   08/19/02 06:28:42 Ralf Corsepius 2002-08-19 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @3549ab0   08/16/02 01:53:11 Joel Sherrill 2002-08-15 Joel Sherrill <joel@…> * setup.def: New gcc 3.1 … 4.104.114.84.95
(edit) @682c7502   08/15/02 23:12:04 Ralf Corsepius 2002-08-15 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @0215848   08/13/02 14:51:15 Ralf Corsepius 2002-08-13 Ralf Corsepius <corsepiu@…> * ChangeLog?: Fix … 4.104.114.84.95
(edit) @513afacb   08/13/02 14:01:03 Ralf Corsepius 2002-08-13 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @0e2bfb8   08/12/02 13:21:46 Ralf Corsepius 2002-08-12 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @a81b432   08/12/02 10:27:46 Ralf Corsepius 2002-08-12 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @4aba88a1   08/12/02 10:11:44 Ralf Corsepius 2002-08-12 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @343d4ff   08/09/02 14:35:39 Ralf Corsepius 2002-08-09 Ralf Corsepius <corsepiu@…> * setup.def: … 4.104.114.84.95
(edit) @52270c07   08/08/02 16:49:20 Joel Sherrill 2002-08-08 Joel Sherrill <joel@…> * setup.def, … 4.104.114.84.95
(edit) @74f15b60   08/06/02 19:18:10 Joel Sherrill 2002-08-06 Joel Sherrill <joel@…> * setup.def: Updating … 4.104.114.84.95
(edit) @f326d12   07/31/02 00:22:06 Joel Sherrill 2002-07-30 Joel Sherrill <joel@…> * setup.def: Updated to … 4.104.114.84.95
(edit) @084879d   07/30/02 15:18:59 Ralf Corsepius 2002-07-30 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @3d36fe3d   07/29/02 07:55:49 Ralf Corsepius 2002-07-29 Ralf Corsepius <corsepiu@…> * configure.ac: … 4.104.114.84.95
(edit) @620c972   07/29/02 07:40:53 Ralf Corsepius 2002-07-29 Ralf Corsepius <corsepiu@…> * ChangeLog?: Fix … 4.104.114.84.95
(edit) @3ad7f69d   07/22/02 09:57:30 Ralf Corsepius 2002-07-22 Joel Sherrill <joel@…> * binutils/Makefile.am: … 4.104.114.84.95
(edit) @8b1d3bf   07/19/02 16:29:06 Joel Sherrill 2002-07-19 Joel Sherrill <joel@…> * setup.def: Updated … 4.104.114.84.95
(edit) @33d1719   07/01/02 22:09:56 Joel Sherrill 2002-07-01 Joel Sherrill <joel@…> * setup.def: Update gcc3 … 4.104.114.84.95
(edit) @6d4210c1   06/27/02 02:30:21 Ralf Corsepius 2002-06-27 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @c93fb2af   06/14/02 17:33:04 Joel Sherrill 2002-06-14 Joel Sherrill <joel@…> * mkgdbspec.in, … 4.104.114.84.95
(edit) @72503c6   05/29/02 16:55:09 Joel Sherrill 2001-05-29 Joel Sherrill <joel@…> * setup.def: Updated to … 4.104.114.84.95
(edit) @6e9746a2   05/15/02 16:38:16 Joel Sherrill 2002-06-15 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @383e974   04/18/02 13:07:59 Joel Sherrill 2002-04-20 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @3f60b2aa   04/16/02 23:43:23 Joel Sherrill 2001-04-16 Joel Sherrill <joel@…> * .cvsignore: Added … 4.104.114.84.95
