# # ChangeLog for scripts/ChangeLog in rtems # # Generated by Trac 1.2.1.dev0 # 05/16/24 22:06:31 Thu, 28 Nov 2002 21:12:23 GMT Joel Sherrill [f7e1564] * scripts/ChangeLog (modified) * scripts/gcc3newlib/gccnewlib.add (modified) * scripts/setup.def (modified) 2002-11-28 Joel Sherrill * ... Mon, 25 Nov 2002 15:24:05 GMT Ralf Corsepius [d35b77f] * scripts/ChangeLog (modified) * scripts/gcc3newlib/gccnewlib.add (modified) 2002-11-25 Ralf Corsepius * ... Fri, 22 Nov 2002 18:15:43 GMT Ralf Corsepius [e4eb1be] * scripts/ChangeLog (modified) * scripts/binutils/base-binutils.add (modified) * scripts/binutils/binutils.add (modified) * scripts/binutils/target-binutils.add (modified) 2002-11-22 Ralf Corsepius * ... Fri, 15 Nov 2002 13:24:03 GMT Ralf Corsepius [b04b5ca7] * scripts/ChangeLog (modified) * scripts/autotools/autoconf-rtems.spec.in (modified) 2002-11-15 Ralf Corsepius * ... Wed, 13 Nov 2002 18:00:10 GMT Joel Sherrill [39f76ad] * scripts/ChangeLog (modified) * scripts/binutils/Makefile.am (modified) * scripts/setup.def (modified) 2002-11-13 Joel Sherrill * ... Mon, 11 Nov 2002 21:37:37 GMT Joel Sherrill [45162744] * scripts/ChangeLog (modified) * scripts/gcc3newlib/gccnewlib.add (modified) * scripts/setup.def (modified) 2002-11-11 Joel Sherrill * ... Tue, 29 Oct 2002 16:53:14 GMT Ralf Corsepius [60ac65d] * scripts/ChangeLog (modified) * scripts/binutils/binutils.add (modified) * scripts/gcc3newlib/base-gcc.add (modified) * scripts/gcc3newlib/base-gcj.add (modified) * scripts/gcc3newlib/gccnewlib.add (modified) 2002-10-29 Ralf Corsepius * ... Fri, 25 Oct 2002 14:56:47 GMT Ralf Corsepius [d08b8eb8] * scripts/ChangeLog (modified) * scripts/autotools/automake-rtems.spec.in (modified) 2002-10-25 Ralf Corsepius * ... Fri, 25 Oct 2002 14:52:25 GMT Ralf Corsepius [d21091b] * scripts/ChangeLog (modified) * scripts/Makefile.am (modified) * scripts/autotools/autoconf-rtems.spec.in (moved) * scripts/autotools/automake-rtems.spec.in (modified) * scripts/configure.ac (modified) * scripts/gcc3newlib/Makefile.am (modified) 2002-10-25 Joel Sherrill * ... Thu, 24 Oct 2002 22:34:37 GMT Joel Sherrill [17a11842] * scripts/ChangeLog (modified) * scripts/gcc3newlib/gccnewlib.add (modified) * scripts/setup.def (modified) 2002-10-24 Joel Sherrill * ... Mon, 21 Oct 2002 12:19:27 GMT Ralf Corsepius [8730f45] * .cvsignore (modified) * ChangeLog (modified) * c/make/.cvsignore (modified) * c/make/ChangeLog (modified) * c/src/ada-tests/.cvsignore (modified) * c/src/ada-tests/ChangeLog (modified) * c/src/lib/.cvsignore (modified) * c/src/lib/ChangeLog (modified) * c/src/lib/libbsp/.cvsignore (modified) * c/src/lib/libbsp/ChangeLog (modified) * c/src/lib/libbsp/a29k/.cvsignore (modified) * c/src/lib/libbsp/a29k/ChangeLog (modified) * c/src/lib/libbsp/a29k/portsw/.cvsignore (modified) * c/src/lib/libbsp/a29k/portsw/ChangeLog (modified) * c/src/lib/libbsp/arm/.cvsignore (modified) * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/.cvsignore (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/ChangeLog (modified) * c/src/lib/libbsp/arm/armulator/.cvsignore (modified) * c/src/lib/libbsp/arm/armulator/ChangeLog (modified) * c/src/lib/libbsp/arm/vegaplus/.cvsignore (modified) * c/src/lib/libbsp/arm/vegaplus/ChangeLog (modified) * c/src/lib/libbsp/bare/.cvsignore (modified) * c/src/lib/libbsp/bare/ChangeLog (modified) * c/src/lib/libbsp/c4x/.cvsignore (modified) * c/src/lib/libbsp/c4x/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/.cvsignore (modified) * c/src/lib/libbsp/c4x/c4xsim/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/.cvsignore (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/ChangeLog (modified) * c/src/lib/libbsp/h8300/.cvsignore (modified) * c/src/lib/libbsp/h8300/ChangeLog (modified) * c/src/lib/libbsp/h8300/h8sim/.cvsignore (modified) * c/src/lib/libbsp/h8300/h8sim/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/.cvsignore (modified) * c/src/lib/libbsp/hppa1.1/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/simhppa/.cvsignore (modified) * c/src/lib/libbsp/hppa1.1/simhppa/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/.cvsignore (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/.cvsignore (modified) * c/src/lib/libbsp/i386/ChangeLog (modified) * c/src/lib/libbsp/i386/i386ex/.cvsignore (modified) * c/src/lib/libbsp/i386/i386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/.cvsignore (modified) * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/tools/.cvsignore (modified) * c/src/lib/libbsp/i386/pc386/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/.cvsignore (modified) * c/src/lib/libbsp/i386/ts_386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/.cvsignore (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ChangeLog (modified) * c/src/lib/libbsp/i960/.cvsignore (modified) * c/src/lib/libbsp/i960/ChangeLog (modified) * c/src/lib/libbsp/i960/cvme961/.cvsignore (modified) * c/src/lib/libbsp/i960/cvme961/ChangeLog (modified) * c/src/lib/libbsp/i960/i960sim/.cvsignore (modified) * c/src/lib/libbsp/i960/i960sim/ChangeLog (modified) * c/src/lib/libbsp/i960/rxgen960/.cvsignore (modified) * c/src/lib/libbsp/i960/rxgen960/ChangeLog (modified) * c/src/lib/libbsp/m68k/.cvsignore (modified) * c/src/lib/libbsp/m68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/dmv152/.cvsignore (modified) * c/src/lib/libbsp/m68k/dmv152/ChangeLog (modified) * c/src/lib/libbsp/m68k/efi332/.cvsignore (modified) * c/src/lib/libbsp/m68k/efi332/ChangeLog (modified) * c/src/lib/libbsp/m68k/efi68k/.cvsignore (modified) * c/src/lib/libbsp/m68k/efi68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68302/.cvsignore (modified) * c/src/lib/libbsp/m68k/gen68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68340/.cvsignore (modified) * c/src/lib/libbsp/m68k/gen68340/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68360/.cvsignore (modified) * c/src/lib/libbsp/m68k/gen68360/ChangeLog (modified) * c/src/lib/libbsp/m68k/idp/.cvsignore (modified) * c/src/lib/libbsp/m68k/idp/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/.cvsignore (modified) * c/src/lib/libbsp/m68k/mcf5206elite/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/.cvsignore (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mrm332/.cvsignore (modified) * c/src/lib/libbsp/m68k/mrm332/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme136/.cvsignore (modified) * c/src/lib/libbsp/m68k/mvme136/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147/.cvsignore (modified) * c/src/lib/libbsp/m68k/mvme147/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147s/.cvsignore (modified) * c/src/lib/libbsp/m68k/mvme147s/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/.cvsignore (modified) * c/src/lib/libbsp/m68k/mvme162/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/tools/.cvsignore (modified) * c/src/lib/libbsp/m68k/mvme162/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme167/.cvsignore (modified) * c/src/lib/libbsp/m68k/mvme167/ChangeLog (modified) * c/src/lib/libbsp/m68k/ods68302/.cvsignore (modified) * c/src/lib/libbsp/m68k/ods68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/sim68000/.cvsignore (modified) * c/src/lib/libbsp/m68k/sim68000/ChangeLog (modified) * c/src/lib/libbsp/mips/.cvsignore (modified) * c/src/lib/libbsp/mips/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/.cvsignore (modified) * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/.cvsignore (modified) * c/src/lib/libbsp/mips/jmr3904/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/tools/.cvsignore (modified) * c/src/lib/libbsp/mips/jmr3904/tools/ChangeLog (modified) * c/src/lib/libbsp/mips/p4000/.cvsignore (modified) * c/src/lib/libbsp/mips/p4000/ChangeLog (modified) * c/src/lib/libbsp/mips64orion/.cvsignore (modified) * c/src/lib/libbsp/mips64orion/ChangeLog (modified) * c/src/lib/libbsp/mips64orion/p4000/.cvsignore (modified) * c/src/lib/libbsp/mips64orion/p4000/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/.cvsignore (modified) * c/src/lib/libbsp/no_cpu/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/no_bsp/.cvsignore (modified) * c/src/lib/libbsp/no_cpu/no_bsp/ChangeLog (modified) * c/src/lib/libbsp/or32/.cvsignore (modified) * c/src/lib/libbsp/or32/ChangeLog (modified) * c/src/lib/libbsp/or32/orp/.cvsignore (modified) * c/src/lib/libbsp/or32/orp/ChangeLog (modified) * c/src/lib/libbsp/powerpc/.cvsignore (modified) * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/dmv177/.cvsignore (modified) * c/src/lib/libbsp/powerpc/dmv177/ChangeLog (modified) * c/src/lib/libbsp/powerpc/eth_comm/.cvsignore (modified) * c/src/lib/libbsp/powerpc/eth_comm/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen405/.cvsignore (modified) * c/src/lib/libbsp/powerpc/gen405/ChangeLog (modified) * c/src/lib/libbsp/powerpc/helas403/.cvsignore (modified) * c/src/lib/libbsp/powerpc/helas403/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mbx8xx/.cvsignore (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/.cvsignore (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/.cvsignore (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/.cvsignore (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/.cvsignore (modified) * c/src/lib/libbsp/powerpc/psim/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/tools/.cvsignore (modified) * c/src/lib/libbsp/powerpc/psim/tools/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/.cvsignore (modified) * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/.cvsignore (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/ChangeLog (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/.cvsignore (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/ChangeLog (modified) * c/src/lib/libbsp/sh/.cvsignore (modified) * c/src/lib/libbsp/sh/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh1/.cvsignore (modified) * c/src/lib/libbsp/sh/gensh1/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh2/.cvsignore (modified) * c/src/lib/libbsp/sh/gensh2/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh4/.cvsignore (modified) * c/src/lib/libbsp/sh/gensh4/ChangeLog (modified) * c/src/lib/libbsp/sh/shsim/.cvsignore (modified) * c/src/lib/libbsp/sh/shsim/ChangeLog (modified) * c/src/lib/libbsp/sh/simsh4/.cvsignore (modified) * c/src/lib/libbsp/sh/simsh4/ChangeLog (modified) * c/src/lib/libbsp/sparc/.cvsignore (modified) * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/.cvsignore (modified) * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/tools/.cvsignore (modified) * c/src/lib/libbsp/sparc/erc32/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon/.cvsignore (modified) * c/src/lib/libbsp/sparc/leon/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon/tools/.cvsignore (modified) * c/src/lib/libbsp/sparc/leon/tools/ChangeLog (modified) * c/src/lib/libbsp/unix/.cvsignore (modified) * c/src/lib/libbsp/unix/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/.cvsignore (modified) * c/src/lib/libbsp/unix/posix/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/tools/.cvsignore (modified) * c/src/lib/libbsp/unix/posix/tools/ChangeLog (modified) * c/src/lib/libcpu/.cvsignore (modified) * c/src/lib/libcpu/ChangeLog (modified) * c/src/lib/libcpu/a29k/.cvsignore (modified) * c/src/lib/libcpu/a29k/ChangeLog (modified) * c/src/lib/libcpu/hppa1.1/.cvsignore (modified) * c/src/lib/libcpu/hppa1.1/ChangeLog (modified) * c/src/lib/libcpu/i386/.cvsignore (modified) * c/src/lib/libcpu/i386/ChangeLog (modified) * c/src/lib/libcpu/i960/.cvsignore (modified) * c/src/lib/libcpu/i960/ChangeLog (modified) * c/src/lib/libcpu/m68k/.cvsignore (modified) * c/src/lib/libcpu/m68k/ChangeLog (modified) * c/src/lib/libcpu/m68k/mcf5206/.cvsignore (modified) * c/src/lib/libcpu/m68k/mcf5206/ChangeLog (modified) * c/src/lib/libcpu/mips/.cvsignore (modified) * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips64orion/.cvsignore (modified) * c/src/lib/libcpu/mips64orion/ChangeLog (modified) * c/src/lib/libcpu/powerpc/.cvsignore (modified) * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/new-exceptions/ChangeLog (modified) * c/src/lib/libcpu/powerpc/old-exceptions/ChangeLog (modified) * c/src/lib/libcpu/sh/.cvsignore (modified) * c/src/lib/libcpu/sh/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7032/.cvsignore (modified) * c/src/lib/libcpu/sh/sh7032/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7045/.cvsignore (modified) * c/src/lib/libcpu/sh/sh7045/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7750/.cvsignore (modified) * c/src/lib/libcpu/sh/sh7750/ChangeLog (modified) * c/src/lib/libcpu/sparc/.cvsignore (modified) * c/src/lib/libcpu/sparc/ChangeLog (modified) * c/src/libchip/.cvsignore (modified) * c/src/libchip/ChangeLog (modified) * c/src/libmisc/.cvsignore (modified) * c/src/libmisc/ChangeLog (modified) * c/src/libnetworking/.cvsignore (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/librdbg/.cvsignore (modified) * c/src/librdbg/ChangeLog (modified) * c/src/librtems++/.cvsignore (modified) * c/src/librtems++/ChangeLog (modified) * c/src/make/.cvsignore (modified) * c/src/make/ChangeLog (modified) * c/src/tests/.cvsignore (modified) * c/src/tests/ChangeLog (modified) * c/src/tests/itrontests/.cvsignore (modified) * c/src/tests/itrontests/ChangeLog (modified) * c/src/tests/libtests/.cvsignore (modified) * c/src/tests/libtests/ChangeLog (modified) * c/src/tests/mptests/.cvsignore (modified) * c/src/tests/mptests/ChangeLog (modified) * c/src/tests/psxtests/.cvsignore (modified) * c/src/tests/psxtests/ChangeLog (modified) * c/src/tests/samples/.cvsignore (modified) * c/src/tests/samples/ChangeLog (modified) * c/src/tests/sptests/.cvsignore (modified) * c/src/tests/sptests/ChangeLog (modified) * c/src/tests/support/.cvsignore (modified) * c/src/tests/support/ChangeLog (modified) * c/src/tests/tmitrontests/.cvsignore (modified) * c/src/tests/tmitrontests/ChangeLog (modified) * c/src/tests/tmtests/.cvsignore (modified) * c/src/tests/tmtests/ChangeLog (modified) * c/src/tests/tools/.cvsignore (modified) * c/src/tests/tools/ChangeLog (modified) * c/src/tests/tools/generic/.cvsignore (modified) * c/src/tests/tools/generic/ChangeLog (modified) * contrib/cygwin/.cvsignore (modified) * contrib/cygwin/ChangeLog (modified) * contrib/solaris/.cvsignore (modified) * contrib/solaris/ChangeLog (modified) * cpukit/libmisc/.cvsignore (modified) * cpukit/libmisc/ChangeLog (modified) * doc/.cvsignore (modified) * doc/ChangeLog (modified) * doc/tools/.cvsignore (modified) * doc/tools/ChangeLog (modified) * scripts/.cvsignore (modified) * scripts/ChangeLog (modified) * testsuites/.cvsignore (modified) * testsuites/ChangeLog (modified) * testsuites/itrontests/.cvsignore (modified) * testsuites/itrontests/ChangeLog (modified) * testsuites/libtests/.cvsignore (modified) * testsuites/libtests/ChangeLog (modified) * testsuites/mptests/.cvsignore (modified) * testsuites/mptests/ChangeLog (modified) * testsuites/psxtests/.cvsignore (modified) * testsuites/psxtests/ChangeLog (modified) * testsuites/samples/.cvsignore (modified) * testsuites/samples/ChangeLog (modified) * testsuites/sptests/.cvsignore (modified) * testsuites/sptests/ChangeLog (modified) * testsuites/support/.cvsignore (modified) * testsuites/support/ChangeLog (modified) * testsuites/tmitrontests/.cvsignore (modified) * testsuites/tmitrontests/ChangeLog (modified) * testsuites/tmtests/.cvsignore (modified) * testsuites/tmtests/ChangeLog (modified) * testsuites/tools/.cvsignore (modified) * testsuites/tools/ChangeLog (modified) * testsuites/tools/generic/.cvsignore (modified) * testsuites/tools/generic/ChangeLog (modified) 2002-10-21 Ralf Corsepius * ... Sat, 14 Sep 2002 20:10:21 GMT Joel Sherrill [99e797a5] * scripts/ChangeLog (modified) * scripts/gcc3newlib/base-gcj.add (modified) * scripts/gcc3newlib/gccnewlib.add (modified) * scripts/gcc3newlib/target-gcj.add (modified) 2002-09-14 Joel Sherrill * ... Wed, 21 Aug 2002 18:50:04 GMT Joel Sherrill [3e1526f0] * scripts/ChangeLog (modified) * scripts/gcc3newlib/gccnewlib.add (modified) * scripts/setup.def (modified) 2002-08-21 Joel Sherrill * ... Mon, 19 Aug 2002 06:28:42 GMT Ralf Corsepius [fa42a76b] * scripts/ChangeLog (modified) * scripts/gcc3newlib/gccnewlib.add (modified) 2002-08-19 Ralf Corsepius * ... Fri, 16 Aug 2002 01:53:11 GMT Joel Sherrill [3549ab0] * scripts/ChangeLog (modified) * scripts/gcc3newlib/gccnewlib.add (modified) * scripts/setup.def (modified) 2002-08-15 Joel Sherrill * ... Thu, 15 Aug 2002 23:12:04 GMT Ralf Corsepius [682c7502] * scripts/ChangeLog (modified) * scripts/gcc3newlib/Makefile.am (modified) * scripts/gcc3newlib/gccnewlib.add (modified) * scripts/gcc3newlib/target-c++.add (modified) 2002-08-15 Ralf Corsepius * ... Tue, 13 Aug 2002 14:51:15 GMT Ralf Corsepius [0215848] * scripts/ChangeLog (modified) 2002-08-13 Ralf Corsepius * ... Tue, 13 Aug 2002 14:01:03 GMT Ralf Corsepius [513afacb] * scripts/ChangeLog (modified) * scripts/gcc3newlib/Makefile.am (modified) * scripts/gcc3newlib/base-gnat.add (modified) * scripts/gcc3newlib/gccnewlib.add (modified) * scripts/gcc3newlib/target-gnat.add (modified) 2002-08-13 Ralf Corsepius * ... Mon, 12 Aug 2002 13:21:46 GMT Ralf Corsepius [0e2bfb8] * scripts/ChangeLog (modified) * scripts/gcc3newlib/base-gnat.add (modified) 2002-08-12 Ralf Corsepius * ... Mon, 12 Aug 2002 10:27:46 GMT Ralf Corsepius [a81b432] * scripts/ChangeLog (modified) * scripts/gcc3newlib/.cvsignore (modified) 2002-08-12 Ralf Corsepius * ... Mon, 12 Aug 2002 10:11:44 GMT Ralf Corsepius [4aba88a1] * scripts/ChangeLog (modified) * scripts/configure.ac (modified) * scripts/gcc3newlib/Makefile.am (modified) * scripts/gcc3newlib/base-g77.add (modified) * scripts/gcc3newlib/base-gcj.add (modified) * scripts/gcc3newlib/base-gnat.add (added) * scripts/gcc3newlib/gccnewlib.add (modified) * scripts/gcc3newlib/mkspec.in (moved) * scripts/gcc3newlib/target-c++.add (modified) * scripts/gcc3newlib/target-g77.add (modified) * scripts/gcc3newlib/target-gcj.add (modified) * scripts/gcc3newlib/target-gnat.add (added) * scripts/gcc3newlib/target-objc.add (modified) 2002-08-12 Ralf Corsepius * ... Fri, 09 Aug 2002 14:35:39 GMT Ralf Corsepius [343d4ff] * scripts/ChangeLog (modified) * scripts/gcc3newlib/gccnewlib.add (modified) * scripts/setup.def (modified) 2002-08-09 Ralf Corsepius * ... Thu, 08 Aug 2002 16:49:20 GMT Joel Sherrill [52270c07] * cpukit/ChangeLog (modified) * cpukit/aclocal/version.m4 (modified) * scripts/ChangeLog (modified) * scripts/binutils/base-binutils.add (modified) * scripts/binutils/target-binutils.add (modified) * scripts/setup.def (modified) 2002-08-08 Joel Sherrill * ... Tue, 06 Aug 2002 19:18:10 GMT Joel Sherrill [74f15b60] * scripts/ChangeLog (modified) * scripts/setup.def (modified) 2002-08-06 Joel Sherrill * ... Wed, 31 Jul 2002 00:22:06 GMT Joel Sherrill [f326d12] * scripts/ChangeLog (modified) * scripts/setup.def (modified) 2002-07-30 Joel Sherrill * ... Tue, 30 Jul 2002 15:18:59 GMT Ralf Corsepius [084879d] * scripts/ChangeLog (modified) * scripts/autotools/automake-rtems.spec.in (modified) * scripts/cpukit/.cvsignore (modified) 2002-07-30 Ralf Corsepius * ... Mon, 29 Jul 2002 07:55:49 GMT Ralf Corsepius [3d36fe3d] * scripts/ChangeLog (modified) * scripts/configure.ac (modified) * scripts/cpukit/mkspec.in (modified) * scripts/mkbinutilspec.in (modified) * scripts/mkbspspec.in (modified) 2002-07-29 Ralf Corsepius * ... Mon, 29 Jul 2002 07:40:53 GMT Ralf Corsepius [620c972] * scripts/ChangeLog (modified) * scripts/Makefile.am (modified) * scripts/configure.ac (modified) * scripts/cpukit/.cvsignore (added) * scripts/cpukit/Makefile.am (added) * scripts/cpukit/mkspec.in (added) * scripts/cpukit/rtems-cpukit.spec.in (added) * scripts/mkgcc3newlibspec.in (modified) * scripts/mkgccnewlibspec.in (modified) * scripts/mkgdbspec.in (modified) * scripts/setup.def (modified) 2002-07-29 Ralf Corsepius * ... Mon, 22 Jul 2002 09:57:30 GMT Ralf Corsepius [3ad7f69d] * scripts/ChangeLog (modified) * scripts/binutils/Makefile.am (modified) 2002-07-22 Joel Sherrill * ... Fri, 19 Jul 2002 16:29:06 GMT Joel Sherrill [8b1d3bf] * scripts/ChangeLog (modified) * scripts/setup.def (modified) 2002-07-19 Joel Sherrill * ... Mon, 01 Jul 2002 22:09:56 GMT Joel Sherrill [33d1719] * scripts/ChangeLog (modified) * scripts/setup.def (modified) 2002-07-01 Joel Sherrill * ... Thu, 27 Jun 2002 02:30:21 GMT Ralf Corsepius [6d4210c1] * scripts/ChangeLog (modified) * scripts/autotools/automake-rtems.spec.in (modified) 2002-06-27 Ralf Corsepius * ... Fri, 14 Jun 2002 17:33:04 GMT Joel Sherrill [c93fb2af] * scripts/ChangeLog (modified) * scripts/gcc3newlib/gccnewlib.add (modified) * scripts/gdb/gdb.add (modified) * scripts/mkgdbspec.in (modified) * scripts/setup.def (modified) 2002-06-14 Joel Sherrill * ... Wed, 29 May 2002 16:55:09 GMT Joel Sherrill [72503c6] * scripts/ChangeLog (modified) * scripts/rtems/Makefile.am (modified) * scripts/setup.def (modified) 2001-05-29 Joel Sherrill * ... Wed, 15 May 2002 16:38:16 GMT Joel Sherrill [6e9746a2] * scripts/ChangeLog (modified) * scripts/gcc3newlib/Makefile.am (modified) * scripts/gcc3newlib/base-g77.add (modified) * scripts/gcc3newlib/base-gcc.add (modified) * scripts/gcc3newlib/gccnewlib.add (modified) * scripts/gcc3newlib/target-c++.add (added) * scripts/gcc3newlib/target-gcc.add (modified) * scripts/mkgcc3newlibspec.in (modified) 2002-06-15 Ralf Corsepius * ... Thu, 18 Apr 2002 13:07:59 GMT Joel Sherrill [383e974] * scripts/ChangeLog (modified) * scripts/gcc3newlib/gccnewlib.add (modified) 2002-04-20 Ralf Corsepius * ... Tue, 16 Apr 2002 23:43:23 GMT Joel Sherrill [3f60b2aa] * scripts/.cvsignore (modified) * scripts/ChangeLog (modified) * scripts/binutils/Makefile.am (modified) * scripts/gcc3newlib/gccnewlib.add (modified) * scripts/gdb/Makefile.am (modified) * scripts/rtems/Makefile.am (modified) * scripts/setup.def (modified) 2001-04-16 Joel Sherrill * ... Tue, 16 Apr 2002 18:33:23 GMT Joel Sherrill [1daced6] * scripts/ChangeLog (modified) * scripts/autotools/automake-rtems.spec.in (modified) 2002-04-14 Ralf Corsepius * ... Mon, 08 Apr 2002 18:29:24 GMT Joel Sherrill [df2b589] * scripts/ChangeLog (modified) * scripts/mkbinutilspec.in (modified) 2002-04-06 Ralf Corsepius * ... Thu, 04 Apr 2002 18:22:45 GMT Joel Sherrill [55f4d3d4] * scripts/ChangeLog (modified) * scripts/gcc3newlib/gccnewlib.add (modified) 2002-04-04 Ralf Corsepius * ... Thu, 04 Apr 2002 18:20:38 GMT Joel Sherrill [0d211e81] * scripts/ChangeLog (modified) * scripts/gcc3newlib/gccnewlib.spec.in (deleted) 2002-04-04 Ralf Corsepius * ... Wed, 03 Apr 2002 17:58:26 GMT Joel Sherrill [df1f734] * scripts/ChangeLog (modified) * scripts/binutils/binutils.add (modified) * scripts/binutils/target-binutils.add (modified) * scripts/gcc3newlib/base-gcc.add (modified) * scripts/gcc3newlib/gccnewlib.add (modified) * scripts/gcc3newlib/gccnewlib_c_only.spec.in (modified) * scripts/mkbinutilspec.in (modified) * scripts/mkgcc3newlibspec.in (modified) * scripts/setup (modified) * scripts/setup.def (modified) 2002-04-03 Ralf Corsepius * ... Tue, 02 Apr 2002 23:48:02 GMT Joel Sherrill [349a01cc] * scripts/ChangeLog (modified) * scripts/buildall.in (modified) 2001-04-02 Joel Sherrill * ... Fri, 29 Mar 2002 14:16:43 GMT Joel Sherrill [d3c2a04] * scripts/.cvsignore (modified) * scripts/ChangeLog (modified) 2001-03-29 Joel Sherrill * ... Fri, 29 Mar 2002 14:15:34 GMT Joel Sherrill [ff47e5b] * scripts/ChangeLog (modified) * scripts/gcc3newlib/.cvsignore (added) * scripts/setup.def (modified) 2001-03-29 Joel Sherrill * ... Thu, 28 Mar 2002 18:17:40 GMT Joel Sherrill [afe5cac] * scripts/ChangeLog (modified) * scripts/Makefile.am (modified) * scripts/configure.ac (modified) * scripts/gcc3newlib/HISTORY (added) * scripts/gcc3newlib/Makefile.am (added) * scripts/gcc3newlib/README (added) * scripts/gcc3newlib/base-g77.add (added) * scripts/gcc3newlib/base-gcc.add (added) * scripts/gcc3newlib/base-gcj.add (added) * scripts/gcc3newlib/gccnewlib.add (added) * scripts/gcc3newlib/gccnewlib.spec.in (added) * scripts/gcc3newlib/gccnewlib_c_only.spec.in (added) * scripts/gcc3newlib/target-g77.add (added) * scripts/gcc3newlib/target-gcc.add (added) * scripts/gcc3newlib/target-gcj.add (added) * scripts/gcc3newlib/target-objc.add (added) * scripts/mkgcc3newlibspec.in (added) * scripts/mkspec (modified) * scripts/setup (modified) * scripts/setup.def (modified) 2001-03-28 Joel Sherrill * Per PR64 ... Thu, 28 Mar 2002 18:13:06 GMT Joel Sherrill [c2778fa] * scripts/ChangeLog (modified) * scripts/binutils/binutils.add (modified) 2001-03-28 Joel Sherrill * ... Thu, 28 Mar 2002 00:54:33 GMT Joel Sherrill [d7c8239] * scripts/ChangeLog (modified) * scripts/Makefile.am (modified) * scripts/autotools/Makefile.am (modified) * scripts/binutils/Makefile.am (modified) * scripts/configure.ac (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gdb/Makefile.am (modified) * scripts/rtems/Makefile.am (modified) 2002-03-27 Ralf Corsepius * ... Wed, 20 Mar 2002 14:17:17 GMT Joel Sherrill [353dbe95] * scripts/ChangeLog (modified) * scripts/binutils/binutils.add (modified) * scripts/configure.ac (modified) * scripts/setup.def (modified) 2002-03-06 Ralf Corsepius * ... Wed, 27 Feb 2002 21:56:41 GMT Joel Sherrill [0694dbab] * scripts/ChangeLog (modified) * scripts/configure.ac (modified) 2001-02-27 Joel Sherrill * ... Tue, 05 Feb 2002 21:08:15 GMT Joel Sherrill [4b3af7a4] * scripts/ChangeLog (modified) * scripts/gccnewlib/base-chill.add (modified) * scripts/gccnewlib/base-g77.add (modified) * scripts/gccnewlib/base-gcc.add (modified) * scripts/gccnewlib/base-gcj.add (modified) * scripts/gccnewlib/gccnewlib.add (modified) * scripts/gccnewlib/target-chill.add (modified) * scripts/gccnewlib/target-g77.add (modified) * scripts/gccnewlib/target-gcc.add (modified) * scripts/gccnewlib/target-gcj.add (modified) * scripts/gccnewlib/target-objc.add (modified) * scripts/mkbinutilspec.in (modified) * scripts/mkgccnewlibspec.in (modified) 2002-01-29 Ralf Corsepius * ... Wed, 30 Jan 2002 14:31:41 GMT Joel Sherrill [2d14fce] * scripts/ChangeLog (modified) * scripts/buildall.in (modified) 2001-01-30 Joel Sherrill * ... Thu, 24 Jan 2002 14:18:41 GMT Joel Sherrill [49d0704] * scripts/ChangeLog (modified) * scripts/README (modified) 2001-01-24 Joel Sherrill * README: ... Thu, 24 Jan 2002 14:14:31 GMT Joel Sherrill [b96a7b1] * scripts/ChangeLog (modified) * scripts/binutils/base-binutils.add (modified) * scripts/binutils/binutils.add (modified) * scripts/binutils/target-binutils.add (modified) * scripts/configure.ac (modified) 2002-01-23 Ralf Corsepius * ... Tue, 22 Jan 2002 18:00:08 GMT Joel Sherrill [2cfb2387] * scripts/ChangeLog (modified) * scripts/binutils/binutils.add (modified) 2002-01-22 Ralf Corsepius * ... Tue, 22 Jan 2002 15:38:43 GMT Joel Sherrill [08f224b] * scripts/ChangeLog (modified) * scripts/buildalltar.in (modified) 2001-01-22 Joel Sherrill * ... Thu, 15 Nov 2001 16:51:20 GMT Joel Sherrill [96a2a02] * scripts/ChangeLog (modified) * scripts/configure.ac (modified) 2001-11-15 Ralf Corsepius * ... Tue, 16 Oct 2001 13:16:53 GMT Joel Sherrill [7b2368b] * scripts/ChangeLog (modified) * scripts/gdb/Makefile.am (modified) * scripts/setup.def (modified) 2001-10-16 Joel Sherrill * ... Mon, 15 Oct 2001 17:49:35 GMT Joel Sherrill [64cc4bb5] * scripts/ChangeLog (modified) * scripts/autotools/automake-rtems.spec (modified) * scripts/configure.ac (modified) * scripts/mkbinutilspec.in (modified) * scripts/mkbspspec.in (modified) * scripts/mkgccnewlibspec.in (modified) * scripts/mkgdbspec.in (modified) 2001-10-15 Ralf Corsepius * ... Thu, 11 Oct 2001 19:36:23 GMT Joel Sherrill [df25c998] * c/src/.cvsignore (modified) * c/src/ChangeLog (modified) * c/src/exec/libcsupport/.cvsignore (modified) * c/src/exec/libfs/.cvsignore (modified) * c/src/exec/libfs/ChangeLog (modified) * c/src/exec/libnetworking/.cvsignore (modified) * c/src/exec/libnetworking/ChangeLog (modified) * c/src/exec/librpc/.cvsignore (modified) * c/src/exec/librpc/ChangeLog (modified) * c/src/exec/score/cpu/powerpc/.cvsignore (modified) * c/src/exec/score/cpu/powerpc/ChangeLog (modified) * c/src/exec/score/cpu/sh/.cvsignore (modified) * c/src/exec/score/cpu/sh/ChangeLog (modified) * c/src/exec/score/cpu/sparc/.cvsignore (modified) * c/src/exec/score/cpu/sparc/ChangeLog (modified) * c/src/exec/score/cpu/unix/.cvsignore (modified) * c/src/exec/score/cpu/unix/ChangeLog (modified) * c/src/lib/.cvsignore (modified) * c/src/lib/ChangeLog (modified) * c/src/lib/libbsp/.cvsignore (modified) * c/src/lib/libbsp/ChangeLog (modified) * c/src/lib/libbsp/a29k/.cvsignore (modified) * c/src/lib/libbsp/a29k/ChangeLog (modified) * c/src/lib/libbsp/a29k/portsw/.cvsignore (modified) * c/src/lib/libbsp/a29k/portsw/ChangeLog (modified) * c/src/lib/libbsp/arm/.cvsignore (modified) * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/.cvsignore (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/ChangeLog (modified) * c/src/lib/libbsp/arm/armulator/.cvsignore (modified) * c/src/lib/libbsp/arm/armulator/ChangeLog (modified) * c/src/lib/libbsp/arm/vegaplus/.cvsignore (modified) * c/src/lib/libbsp/arm/vegaplus/ChangeLog (modified) * c/src/lib/libbsp/bare/.cvsignore (modified) * c/src/lib/libbsp/bare/ChangeLog (modified) * c/src/lib/libbsp/c4x/.cvsignore (modified) * c/src/lib/libbsp/c4x/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/.cvsignore (modified) * c/src/lib/libbsp/c4x/c4xsim/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/.cvsignore (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/ChangeLog (modified) * c/src/lib/libbsp/h8300/.cvsignore (modified) * c/src/lib/libbsp/h8300/ChangeLog (modified) * c/src/lib/libbsp/h8300/h8sim/.cvsignore (modified) * c/src/lib/libbsp/h8300/h8sim/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/.cvsignore (modified) * c/src/lib/libbsp/hppa1.1/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/simhppa/.cvsignore (modified) * c/src/lib/libbsp/hppa1.1/simhppa/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/.cvsignore (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/.cvsignore (modified) * c/src/lib/libbsp/i386/ChangeLog (modified) * c/src/lib/libbsp/i386/i386ex/.cvsignore (modified) * c/src/lib/libbsp/i386/i386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/.cvsignore (modified) * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/tools/.cvsignore (modified) * c/src/lib/libbsp/i386/pc386/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/.cvsignore (modified) * c/src/lib/libbsp/i386/ts_386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/.cvsignore (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ChangeLog (modified) * c/src/lib/libbsp/i960/.cvsignore (modified) * c/src/lib/libbsp/i960/ChangeLog (modified) * c/src/lib/libbsp/i960/cvme961/.cvsignore (modified) * c/src/lib/libbsp/i960/cvme961/ChangeLog (modified) * c/src/lib/libbsp/i960/i960sim/.cvsignore (modified) * c/src/lib/libbsp/i960/i960sim/ChangeLog (modified) * c/src/lib/libbsp/i960/rxgen960/.cvsignore (modified) * c/src/lib/libbsp/i960/rxgen960/ChangeLog (modified) * c/src/lib/libbsp/m68k/.cvsignore (modified) * c/src/lib/libbsp/m68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/dmv152/.cvsignore (modified) * c/src/lib/libbsp/m68k/dmv152/ChangeLog (modified) * c/src/lib/libbsp/m68k/efi332/.cvsignore (modified) * c/src/lib/libbsp/m68k/efi332/ChangeLog (modified) * c/src/lib/libbsp/m68k/efi68k/.cvsignore (modified) * c/src/lib/libbsp/m68k/efi68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68302/.cvsignore (modified) * c/src/lib/libbsp/m68k/gen68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68340/.cvsignore (modified) * c/src/lib/libbsp/m68k/gen68340/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68360/.cvsignore (modified) * c/src/lib/libbsp/m68k/gen68360/ChangeLog (modified) * c/src/lib/libbsp/m68k/idp/.cvsignore (modified) * c/src/lib/libbsp/m68k/idp/ChangeLog (modified) * c/src/lib/libbsp/m68k/mrm332/.cvsignore (modified) * c/src/lib/libbsp/m68k/mrm332/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme136/.cvsignore (modified) * c/src/lib/libbsp/m68k/mvme136/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147/.cvsignore (modified) * c/src/lib/libbsp/m68k/mvme147/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147s/.cvsignore (modified) * c/src/lib/libbsp/m68k/mvme147s/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/.cvsignore (modified) * c/src/lib/libbsp/m68k/mvme162/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/tools/.cvsignore (modified) * c/src/lib/libbsp/m68k/mvme162/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme167/.cvsignore (modified) * c/src/lib/libbsp/m68k/mvme167/ChangeLog (modified) * c/src/lib/libbsp/m68k/ods68302/.cvsignore (modified) * c/src/lib/libbsp/m68k/ods68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/sim68000/.cvsignore (modified) * c/src/lib/libbsp/m68k/sim68000/ChangeLog (modified) * c/src/lib/libbsp/mips/.cvsignore (modified) * c/src/lib/libbsp/mips/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/.cvsignore (modified) * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/.cvsignore (modified) * c/src/lib/libbsp/mips/jmr3904/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/tools/.cvsignore (modified) * c/src/lib/libbsp/mips/jmr3904/tools/ChangeLog (modified) * c/src/lib/libbsp/mips/p4000/.cvsignore (modified) * c/src/lib/libbsp/mips/p4000/ChangeLog (modified) * c/src/lib/libbsp/mips64orion/.cvsignore (modified) * c/src/lib/libbsp/mips64orion/ChangeLog (modified) * c/src/lib/libbsp/mips64orion/p4000/.cvsignore (modified) * c/src/lib/libbsp/mips64orion/p4000/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/.cvsignore (modified) * c/src/lib/libbsp/no_cpu/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/no_bsp/.cvsignore (modified) * c/src/lib/libbsp/no_cpu/no_bsp/ChangeLog (modified) * c/src/lib/libbsp/powerpc/.cvsignore (modified) * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/dmv177/.cvsignore (modified) * c/src/lib/libbsp/powerpc/dmv177/ChangeLog (modified) * c/src/lib/libbsp/powerpc/eth_comm/.cvsignore (modified) * c/src/lib/libbsp/powerpc/eth_comm/ChangeLog (modified) * c/src/lib/libbsp/powerpc/helas403/.cvsignore (modified) * c/src/lib/libbsp/powerpc/helas403/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mbx8xx/.cvsignore (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/.cvsignore (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/papyrus/.cvsignore (modified) * c/src/lib/libbsp/powerpc/papyrus/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/.cvsignore (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/.cvsignore (modified) * c/src/lib/libbsp/powerpc/psim/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/tools/.cvsignore (modified) * c/src/lib/libbsp/powerpc/psim/tools/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/.cvsignore (modified) * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/sh/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh1/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh2/ChangeLog (modified) * c/src/lib/libbsp/sh/shsim/ChangeLog (modified) * c/src/lib/libbsp/sparc/.cvsignore (modified) * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/.cvsignore (modified) * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/tools/.cvsignore (modified) * c/src/lib/libbsp/sparc/erc32/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon/.cvsignore (modified) * c/src/lib/libbsp/sparc/leon/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon/tools/.cvsignore (modified) * c/src/lib/libbsp/sparc/leon/tools/ChangeLog (modified) * c/src/lib/libbsp/unix/.cvsignore (modified) * c/src/lib/libbsp/unix/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/.cvsignore (modified) * c/src/lib/libbsp/unix/posix/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/tools/.cvsignore (modified) * c/src/lib/libbsp/unix/posix/tools/ChangeLog (modified) * c/src/lib/libcpu/.cvsignore (modified) * c/src/lib/libcpu/ChangeLog (modified) * c/src/lib/libcpu/a29k/.cvsignore (modified) * c/src/lib/libcpu/a29k/ChangeLog (modified) * c/src/lib/libcpu/hppa1.1/.cvsignore (modified) * c/src/lib/libcpu/hppa1.1/ChangeLog (modified) * c/src/lib/libcpu/i386/.cvsignore (modified) * c/src/lib/libcpu/i386/ChangeLog (modified) * c/src/lib/libcpu/i960/.cvsignore (modified) * c/src/lib/libcpu/i960/ChangeLog (modified) * c/src/lib/libcpu/m68k/.cvsignore (modified) * c/src/lib/libcpu/m68k/ChangeLog (modified) * c/src/lib/libcpu/mips/.cvsignore (modified) * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips64orion/.cvsignore (modified) * c/src/lib/libcpu/mips64orion/ChangeLog (modified) * c/src/lib/libcpu/powerpc/.cvsignore (modified) * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/sh/.cvsignore (modified) * c/src/lib/libcpu/sh/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7032/.cvsignore (modified) * c/src/lib/libcpu/sh/sh7032/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7045/.cvsignore (modified) * c/src/lib/libcpu/sh/sh7045/ChangeLog (modified) * c/src/lib/libcpu/sparc/.cvsignore (modified) * c/src/lib/libcpu/sparc/ChangeLog (modified) * c/src/libchip/.cvsignore (modified) * c/src/libchip/ChangeLog (modified) * c/src/libfs/.cvsignore (modified) * c/src/libfs/ChangeLog (modified) * c/src/libmisc/.cvsignore (modified) * c/src/libmisc/ChangeLog (modified) * c/src/libnetworking/.cvsignore (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/librdbg/.cvsignore (modified) * c/src/librdbg/ChangeLog (modified) * c/src/librpc/.cvsignore (modified) * c/src/librpc/ChangeLog (modified) * c/src/librtems++/.cvsignore (modified) * c/src/librtems++/ChangeLog (modified) * c/src/make/.cvsignore (modified) * c/src/make/ChangeLog (modified) * c/src/tests/.cvsignore (modified) * c/src/tests/ChangeLog (modified) * c/src/tests/itrontests/.cvsignore (modified) * c/src/tests/itrontests/ChangeLog (modified) * c/src/tests/libtests/.cvsignore (modified) * c/src/tests/libtests/ChangeLog (modified) * c/src/tests/mptests/.cvsignore (modified) * c/src/tests/mptests/ChangeLog (modified) * c/src/tests/psxtests/.cvsignore (modified) * c/src/tests/psxtests/ChangeLog (modified) * c/src/tests/samples/.cvsignore (modified) * c/src/tests/samples/ChangeLog (modified) * c/src/tests/sptests/.cvsignore (modified) * c/src/tests/sptests/ChangeLog (modified) * c/src/tests/support/.cvsignore (modified) * c/src/tests/support/ChangeLog (modified) * c/src/tests/tmitrontests/.cvsignore (modified) * c/src/tests/tmitrontests/ChangeLog (modified) * c/src/tests/tmtests/.cvsignore (modified) * c/src/tests/tmtests/ChangeLog (modified) * c/src/tests/tools/.cvsignore (modified) * c/src/tests/tools/ChangeLog (modified) * c/src/tests/tools/generic/.cvsignore (modified) * c/src/tests/tools/generic/ChangeLog (modified) * c/src/wrapup/.cvsignore (modified) * c/src/wrapup/ChangeLog (modified) * contrib/cygwin/.cvsignore (modified) * contrib/cygwin/ChangeLog (modified) * cpukit/libcsupport/.cvsignore (modified) * cpukit/libfs/.cvsignore (modified) * cpukit/libfs/ChangeLog (modified) * cpukit/libmisc/.cvsignore (modified) * cpukit/libmisc/ChangeLog (modified) * cpukit/libnetworking/.cvsignore (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/librpc/.cvsignore (modified) * cpukit/librpc/ChangeLog (modified) * cpukit/score/cpu/powerpc/.cvsignore (modified) * cpukit/score/cpu/powerpc/ChangeLog (modified) * cpukit/score/cpu/sh/.cvsignore (modified) * cpukit/score/cpu/sh/ChangeLog (modified) * cpukit/score/cpu/sparc/.cvsignore (modified) * cpukit/score/cpu/sparc/ChangeLog (modified) * cpukit/score/cpu/unix/.cvsignore (modified) * cpukit/score/cpu/unix/ChangeLog (modified) * scripts-ada/.cvsignore (modified) * scripts-ada/ChangeLog (modified) * scripts/.cvsignore (modified) * scripts/ChangeLog (modified) * testsuites/.cvsignore (modified) * testsuites/ChangeLog (modified) * testsuites/itrontests/.cvsignore (modified) * testsuites/itrontests/ChangeLog (modified) * testsuites/libtests/.cvsignore (modified) * testsuites/libtests/ChangeLog (modified) * testsuites/mptests/.cvsignore (modified) * testsuites/mptests/ChangeLog (modified) * testsuites/psxtests/.cvsignore (modified) * testsuites/psxtests/ChangeLog (modified) * testsuites/samples/.cvsignore (modified) * testsuites/samples/ChangeLog (modified) * testsuites/sptests/.cvsignore (modified) * testsuites/sptests/ChangeLog (modified) * testsuites/support/.cvsignore (modified) * testsuites/support/ChangeLog (modified) * testsuites/tmitrontests/.cvsignore (modified) * testsuites/tmitrontests/ChangeLog (modified) * testsuites/tmtests/.cvsignore (modified) * testsuites/tmtests/ChangeLog (modified) * testsuites/tools/.cvsignore (modified) * testsuites/tools/ChangeLog (modified) * testsuites/tools/generic/.cvsignore (modified) * testsuites/tools/generic/ChangeLog (modified) * tools/build/.cvsignore (modified) * tools/build/ChangeLog (modified) * tools/cpu/.cvsignore (modified) * tools/cpu/ChangeLog (modified) * tools/cpu/generic/.cvsignore (modified) * tools/cpu/generic/ChangeLog (modified) * tools/cpu/hppa1.1/.cvsignore (modified) * tools/cpu/hppa1.1/ChangeLog (modified) * tools/cpu/sh/.cvsignore (modified) * tools/cpu/sh/ChangeLog (modified) * tools/cpu/unix/.cvsignore (modified) * tools/cpu/unix/ChangeLog (modified) * tools/update/.cvsignore (modified) * tools/update/ChangeLog (modified) 2001-10-11 Ralf Corsepius * ... Mon, 24 Sep 2001 18:30:27 GMT Joel Sherrill [0671af6] * scripts/ChangeLog (modified) * scripts/binutils/Makefile.am (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gdb/Makefile.am (modified) 2001-09-22 Ralf Corsepius * ... Thu, 13 Sep 2001 16:37:03 GMT Joel Sherrill [1cd0db4] * scripts/ChangeLog (modified) * scripts/gccnewlib/base-gcc.add (modified) * scripts/gccnewlib/gccnewlib.add (modified) * scripts/gccnewlib/target-gcc.add (modified) * scripts/setup.def (modified) 2001-09-13 Joel Sherrill * ... Thu, 13 Sep 2001 13:35:35 GMT Joel Sherrill [a8bd1de] * scripts/ChangeLog (modified) * scripts/gccnewlib/base-gcc.add (modified) * scripts/gccnewlib/gccnewlib.add (modified) * scripts/gccnewlib/target-gcc.add (modified) * scripts/mkgccnewlibspec.in (modified) * scripts/setup.def (modified) 2001-09-13 Joel Sherrill * ... Thu, 13 Sep 2001 13:13:20 GMT Joel Sherrill [34094cc3] * scripts/ChangeLog (modified) * scripts/autotools/.cvsignore (added) 2001-09-13 Joel Sherrill * ... Thu, 06 Sep 2001 18:38:31 GMT Joel Sherrill [a792b78] * scripts/ChangeLog (modified) * scripts/Makefile.am (modified) * scripts/autotools/Makefile.am (added) * scripts/autotools/autoconf-rtems.spec (added) * scripts/autotools/automake-rtems.spec (added) * scripts/configure.in (modified) 2001-07-19 Ralf Corsepius * ... Thu, 30 Aug 2001 13:36:26 GMT Joel Sherrill [4331c3d] * scripts/.cvsignore (modified) * scripts/ChangeLog (modified) 2001-08-30 Joel Sherrill * ... Thu, 30 Aug 2001 13:33:32 GMT Joel Sherrill [302b76d] * scripts/ChangeLog (modified) * scripts/Makefile.am (modified) * scripts/buildalltar.in (added) * scripts/configure.in (modified) 2001-08-30 Joel Sherrill * ... Fri, 10 Aug 2001 17:12:12 GMT Joel Sherrill [b471c035] * scripts/ChangeLog (modified) * scripts/mkgdbspec.in (modified) * scripts/setup.def (modified) 2001-08-10 Joel Sherrill * ... Tue, 03 Jul 2001 17:01:56 GMT Joel Sherrill [6c5e3215] * scripts/ChangeLog (modified) * scripts/binutils/binutils.add (modified) * scripts/gccnewlib/gccnewlib.add (modified) * scripts/setup.def (modified) 2001-07-03 Joel Sherrill * ... Thu, 24 May 2001 19:58:35 GMT Joel Sherrill [01ec6c0] * scripts/ChangeLog (modified) * scripts/configure.in (modified) * scripts/gccnewlib/base-gcc.add (modified) * scripts/gccnewlib/gccnewlib.add (modified) * scripts/gccnewlib/target-gcc.add (modified) 2001-05-15 Ralf Corsepius * ... Mon, 16 Apr 2001 20:33:56 GMT Joel Sherrill [4ff04390] * scripts/ChangeLog (modified) * scripts/setup.def (modified) 2001-04-16 Joel Sherrill * ... Wed, 11 Apr 2001 13:51:18 GMT Joel Sherrill [365d16cf] * scripts/ChangeLog (modified) * scripts/binutils/Makefile.am (modified) * scripts/binutils/binutils.add (modified) 2001-04-11 Joel Sherrill * ... Mon, 19 Mar 2001 13:09:35 GMT Joel Sherrill [9a4d549] * scripts/ChangeLog (modified) * scripts/setup.def (modified) 2001-03-19 Joel Sherrill * ... Wed, 14 Mar 2001 19:43:57 GMT Joel Sherrill [b9a7287e] * scripts/ChangeLog (modified) * scripts/gdb/Makefile.am (modified) * scripts/mkgdbspec.in (modified) 2001-03-14 Joel Sherrill * ... Wed, 03 Jan 2001 16:50:24 GMT Joel Sherrill [409f7d1] * scripts/ChangeLog (modified) * scripts/binutils/HISTORY (modified) * scripts/gccnewlib/HISTORY (modified) * scripts/setup.def (modified) 2001-01-03 Joel Sherrill * ... Thu, 16 Nov 2000 13:54:18 GMT Joel Sherrill [ee6d205] * scripts/ChangeLog (modified) * scripts/gccnewlib/gccnewlib.add (modified) 2000-11-13 Ralf Corsepius * ... Thu, 09 Nov 2000 16:51:47 GMT Joel Sherrill [bd914b46] * scripts/ChangeLog (modified) * scripts/configure.in (modified) 2000-11-05 Ralf Corsepius * ... Tue, 31 Oct 2000 16:44:11 GMT Joel Sherrill [06f2f75] * scripts/ChangeLog (modified) * scripts/binutils/Makefile.am (modified) * scripts/buildall.in (modified) * scripts/gccnewlib/HISTORY (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gdb/Makefile.am (modified) * scripts/mkgdbspec.in (modified) * scripts/setup.def (modified) 2000-10-30 Joel Sherrill * ... Thu, 26 Oct 2000 13:00:02 GMT Joel Sherrill [b507814] * scripts/ChangeLog (modified) * scripts/configure.in (modified) 2000-10-26 Ralf Corsepius * ... Wed, 18 Oct 2000 16:42:13 GMT Joel Sherrill [467ed56f] * scripts/ChangeLog (modified) * scripts/setup.def (modified) 2000-10-18 Joel Sherrill * ... Wed, 30 Aug 2000 08:23:28 GMT Joel Sherrill [99b8e8c] * scripts/ChangeLog (modified) * scripts/gccnewlib/HISTORY (modified) * scripts/setup.def (modified) 2000-08-30 Joel Sherrill * ... Thu, 10 Aug 2000 13:24:00 GMT Joel Sherrill [e94ad1fe] * ChangeLog (added) * c/ChangeLog (added) * c/make/ChangeLog (added) * c/src/ChangeLog (added) * c/src/exec/ChangeLog (added) * c/src/exec/itron/ChangeLog (added) * c/src/exec/libnetworking/ChangeLog (added) * c/src/exec/librpc/ChangeLog (added) * c/src/exec/posix/ChangeLog (added) * c/src/exec/rtems/ChangeLog (added) * c/src/exec/sapi/ChangeLog (added) * c/src/exec/score/ChangeLog (added) * c/src/exec/score/cpu/a29k/ChangeLog (added) * c/src/exec/score/cpu/arm/ChangeLog (added) * c/src/exec/score/cpu/c4x/ChangeLog (added) * c/src/exec/score/cpu/h8300/ChangeLog (added) * c/src/exec/score/cpu/hppa1.1/ChangeLog (added) * c/src/exec/score/cpu/i386/ChangeLog (added) * c/src/exec/score/cpu/i960/ChangeLog (added) * c/src/exec/score/cpu/m68k/ChangeLog (added) * c/src/exec/score/cpu/mips/ChangeLog (added) * c/src/exec/score/cpu/mips64orion/ChangeLog (added) * c/src/exec/score/cpu/no_cpu/ChangeLog (added) * c/src/exec/score/cpu/powerpc/ChangeLog (added) * c/src/exec/score/cpu/sh/ChangeLog (added) * c/src/exec/score/cpu/sparc/ChangeLog (added) * c/src/exec/score/cpu/unix/ChangeLog (added) * c/src/lib/ChangeLog (added) * c/src/lib/libbsp/ChangeLog (added) * c/src/lib/libbsp/a29k/ChangeLog (added) * c/src/lib/libbsp/a29k/portsw/ChangeLog (added) * c/src/lib/libbsp/arm/ChangeLog (added) * c/src/lib/libbsp/arm/arm_bare_bsp/ChangeLog (added) * c/src/lib/libbsp/arm/armulator/ChangeLog (added) * c/src/lib/libbsp/arm/shared/ChangeLog (added) * c/src/lib/libbsp/bare/ChangeLog (added) * c/src/lib/libbsp/c4x/ChangeLog (added) * c/src/lib/libbsp/c4x/c4xsim/ChangeLog (added) * c/src/lib/libbsp/c4x/c4xsim/tools/ChangeLog (added) * c/src/lib/libbsp/c4x/shared/ChangeLog (added) * c/src/lib/libbsp/h8300/ChangeLog (added) * c/src/lib/libbsp/h8300/h8sim/ChangeLog (added) * c/src/lib/libbsp/hppa1.1/ChangeLog (added) * c/src/lib/libbsp/hppa1.1/simhppa/ChangeLog (added) * c/src/lib/libbsp/hppa1.1/simhppa/tools/ChangeLog (added) * c/src/lib/libbsp/i386/ChangeLog (added) * c/src/lib/libbsp/i386/i386ex/ChangeLog (added) * c/src/lib/libbsp/i386/pc386/ChangeLog (added) * c/src/lib/libbsp/i386/pc386/tools/ChangeLog (added) * c/src/lib/libbsp/i386/shared/ChangeLog (added) * c/src/lib/libbsp/i386/ts_386ex/ChangeLog (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ChangeLog (added) * c/src/lib/libbsp/i960/ChangeLog (added) * c/src/lib/libbsp/i960/cvme961/ChangeLog (added) * c/src/lib/libbsp/i960/i960sim/ChangeLog (added) * c/src/lib/libbsp/i960/rxgen960/ChangeLog (added) * c/src/lib/libbsp/m68k/ChangeLog (added) * c/src/lib/libbsp/m68k/dmv152/ChangeLog (added) * c/src/lib/libbsp/m68k/efi332/ChangeLog (added) * c/src/lib/libbsp/m68k/efi68k/ChangeLog (added) * c/src/lib/libbsp/m68k/gen68302/ChangeLog (added) * c/src/lib/libbsp/m68k/gen68340/ChangeLog (added) * c/src/lib/libbsp/m68k/gen68360/ChangeLog (added) * c/src/lib/libbsp/m68k/idp/ChangeLog (added) * c/src/lib/libbsp/m68k/mvme136/ChangeLog (added) * c/src/lib/libbsp/m68k/mvme147/ChangeLog (added) * c/src/lib/libbsp/m68k/mvme147s/ChangeLog (added) * c/src/lib/libbsp/m68k/mvme162/ChangeLog (added) * c/src/lib/libbsp/m68k/mvme162/tools/ChangeLog (added) * c/src/lib/libbsp/m68k/mvme167/ChangeLog (added) * c/src/lib/libbsp/m68k/ods68302/ChangeLog (added) * c/src/lib/libbsp/m68k/shared/ChangeLog (added) * c/src/lib/libbsp/m68k/sim68000/ChangeLog (added) * c/src/lib/libbsp/mips/ChangeLog (added) * c/src/lib/libbsp/mips/p4000/ChangeLog (added) * c/src/lib/libbsp/mips64orion/ChangeLog (added) * c/src/lib/libbsp/mips64orion/p4000/ChangeLog (added) * c/src/lib/libbsp/no_cpu/ChangeLog (added) * c/src/lib/libbsp/no_cpu/no_bsp/ChangeLog (added) * c/src/lib/libbsp/powerpc/ChangeLog (added) * c/src/lib/libbsp/powerpc/dmv177/ChangeLog (added) * c/src/lib/libbsp/powerpc/eth_comm/ChangeLog (added) * c/src/lib/libbsp/powerpc/helas403/ChangeLog (added) * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (added) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (added) * c/src/lib/libbsp/powerpc/papyrus/ChangeLog (added) * c/src/lib/libbsp/powerpc/ppcn_60x/ChangeLog (added) * c/src/lib/libbsp/powerpc/psim/ChangeLog (added) * c/src/lib/libbsp/powerpc/psim/tools/ChangeLog (added) * c/src/lib/libbsp/powerpc/score603e/ChangeLog (added) * c/src/lib/libbsp/powerpc/shared/ChangeLog (added) * c/src/lib/libbsp/sh/ChangeLog (added) * c/src/lib/libbsp/sh/gensh1/ChangeLog (added) * c/src/lib/libbsp/sh/gensh2/ChangeLog (added) * c/src/lib/libbsp/sh/shared/ChangeLog (added) * c/src/lib/libbsp/shared/ChangeLog (added) * c/src/lib/libbsp/sparc/ChangeLog (added) * c/src/lib/libbsp/sparc/erc32/ChangeLog (added) * c/src/lib/libbsp/sparc/erc32/tools/ChangeLog (added) * c/src/lib/libbsp/unix/ChangeLog (added) * c/src/lib/libbsp/unix/posix/ChangeLog (added) * c/src/lib/libbsp/unix/posix/tools/ChangeLog (added) * c/src/lib/libcpu/ChangeLog (added) * c/src/lib/libcpu/a29k/ChangeLog (added) * c/src/lib/libcpu/hppa1.1/ChangeLog (added) * c/src/lib/libcpu/i386/ChangeLog (added) * c/src/lib/libcpu/i960/ChangeLog (added) * c/src/lib/libcpu/m68k/ChangeLog (added) * c/src/lib/libcpu/mips/ChangeLog (added) * c/src/lib/libcpu/mips64orion/ChangeLog (added) * c/src/lib/libcpu/powerpc/ChangeLog (added) * c/src/lib/libcpu/sh/ChangeLog (added) * c/src/lib/libcpu/sh/sh7032/ChangeLog (added) * c/src/lib/libcpu/sh/sh7045/ChangeLog (added) * c/src/lib/libcpu/sparc/ChangeLog (added) * c/src/libchip/ChangeLog (added) * c/src/libmisc/ChangeLog (added) * c/src/libnetworking/ChangeLog (added) * c/src/librdbg/ChangeLog (added) * c/src/librpc/ChangeLog (added) * c/src/librtems++/ChangeLog (added) * c/src/make/ChangeLog (added) * c/src/tests/ChangeLog (added) * c/src/tests/itrontests/ChangeLog (added) * c/src/tests/libtests/ChangeLog (added) * c/src/tests/mptests/ChangeLog (added) * c/src/tests/psxtests/ChangeLog (added) * c/src/tests/samples/ChangeLog (added) * c/src/tests/sptests/ChangeLog (added) * c/src/tests/support/ChangeLog (added) * c/src/tests/tmitrontests/ChangeLog (added) * c/src/tests/tmtests/ChangeLog (added) * c/src/tests/tools/ChangeLog (added) * c/src/tests/tools/generic/ChangeLog (added) * cpukit/ChangeLog (added) * cpukit/itron/ChangeLog (added) * cpukit/libmisc/ChangeLog (added) * cpukit/libnetworking/ChangeLog (added) * cpukit/librpc/ChangeLog (added) * cpukit/posix/ChangeLog (added) * cpukit/rtems/ChangeLog (added) * cpukit/sapi/ChangeLog (added) * cpukit/score/ChangeLog (added) * cpukit/score/cpu/a29k/ChangeLog (added) * cpukit/score/cpu/arm/ChangeLog (added) * cpukit/score/cpu/c4x/ChangeLog (added) * cpukit/score/cpu/h8300/ChangeLog (added) * cpukit/score/cpu/hppa1.1/ChangeLog (added) * cpukit/score/cpu/i386/ChangeLog (added) * cpukit/score/cpu/i960/ChangeLog (added) * cpukit/score/cpu/m68k/ChangeLog (added) * cpukit/score/cpu/mips/ChangeLog (added) * cpukit/score/cpu/mips64orion/ChangeLog (added) * cpukit/score/cpu/no_cpu/ChangeLog (added) * cpukit/score/cpu/powerpc/ChangeLog (added) * cpukit/score/cpu/sh/ChangeLog (added) * cpukit/score/cpu/sparc/ChangeLog (added) * cpukit/score/cpu/unix/ChangeLog (added) * scripts-ada/ChangeLog (added) * scripts/ChangeLog (added) * testsuites/ChangeLog (added) * testsuites/itrontests/ChangeLog (added) * testsuites/libtests/ChangeLog (added) * testsuites/mptests/ChangeLog (added) * testsuites/psxtests/ChangeLog (added) * testsuites/samples/ChangeLog (added) * testsuites/sptests/ChangeLog (added) * testsuites/support/ChangeLog (added) * testsuites/tmitrontests/ChangeLog (added) * testsuites/tmtests/ChangeLog (added) * testsuites/tools/ChangeLog (added) * testsuites/tools/generic/ChangeLog (added) * tools/build/ChangeLog (added) * tools/cpu/ChangeLog (added) * tools/cpu/generic/ChangeLog (added) * tools/cpu/hppa1.1/ChangeLog (added) * tools/cpu/sh/ChangeLog (added) * tools/cpu/unix/ChangeLog (added) * tools/update/ChangeLog (added) Adding ChangeLogs.
