# # ChangeLog for scripts-ada/missing in rtems # # Generated by Trac 1.2.1.dev0 # 04/25/24 17:38:46 Wed, 26 Jan 2000 19:56:54 GMT Joel Sherrill [64ab2e9] * scripts-ada/Makefile.am (added) * scripts-ada/README (added) * scripts-ada/TODO (added) * scripts-ada/binutils/Makefile.am (added) * scripts-ada/binutils/binutils.spec.in (added) * scripts-ada/buildall.in (added) * scripts-ada/configure.in (added) * scripts-ada/gdb/Makefile.am (added) * scripts-ada/gdb/gdb.spec.in (added) * scripts-ada/gnatnewlib/Makefile.am (added) * scripts-ada/gnatnewlib/gnatnewlib.spec.in (added) * scripts-ada/install-sh (added) * scripts-ada/missing (added) * scripts-ada/mkbinutilspec.in (added) * scripts-ada/mkbspspec.in (added) * scripts-ada/mkgdbspec.in (added) * scripts-ada/mkgnatnewlibspec.in (added) * scripts-ada/mkinstalldirs (added) * scripts-ada/mkrpms (added) * scripts-ada/mkspec (added) * scripts-ada/setup (added) * scripts-ada/setup.def (added) First cut at adding RPM scripts for building GNAT/RTEMS RPMs.
