@cdf6fcbc
05/22/98 12:30:19 |
Joel Sherrill |
Now uses BSP specific configure variables and compiles for i486 and m68k.
4.104.114.84.95
@6fa1289
05/22/98 12:29:13 |
Joel Sherrill |
Renamed bare BSP specific options to make the dependency obvious.
4.104.114.84.95
@bd5e4f3b
05/21/98 18:26:58 |
Joel Sherrill |
Added bare bsp from Chris Johns <cjohns@…>.
4.104.114.84.95
@1e9c9d4
05/21/98 16:41:56 |
Joel Sherrill |
Per patch from Ralf Corsepius removed redundant lines.
4.104.114.84.95
@dd84f12
05/21/98 16:41:40 |
Joel Sherrill |
Removed undesirable space in TARGET_ARCH assignment line.
Cleaned up …
4.104.114.84.95
@d494eeb4
05/21/98 16:40:46 |
Joel Sherrill |
Per patch from Ralf Corsepius UNIX ports always needs C++ for …
4.104.114.84.95
@17a8d603
05/20/98 17:02:29 |
Joel Sherrill |
Some patches in place from Brian Stevens which help the Solaris port …
4.104.114.84.95
@7aa10b0
05/20/98 17:01:39 |
Joel Sherrill |
Copied gcc 2.7.2 style make-exe rule to gcc 2.8 conditional. This …
4.104.114.84.95
@5dd4212
05/20/98 17:01:04 |
Joel Sherrill |
Changed CPP rule per patch from Ralf Corsepius.
4.104.114.84.95
@ca0bafa7
05/18/98 16:40:13 |
Joel Sherrill |
Added much stuff formerly in multiple compiler files.
4.104.114.84.95
@0500c342
05/18/98 16:39:49 |
Joel Sherrill |
Added conditional around TARGET_ARCH to prevent accidental overrides.
4.104.114.84.95
@7ebfa93
05/18/98 16:39:21 |
Joel Sherrill |
Switched to using shared gcc-target-default.cfg.
4.104.114.84.95
@6ee6abb
05/18/98 16:38:38 |
Joel Sherrill |
Added C++ rule.
Added CROSS_TARGET conditionals so unix port can …
4.104.114.84.95
@60fa630
05/18/98 16:37:50 |
Joel Sherrill |
Added RTEMS_CROSS_TARGET.
4.104.114.84.95
@7123d3b
05/04/98 13:19:29 |
Joel Sherrill |
Modified objcopy to remove extra sections.
Modified gcc 2.8 style …
4.104.114.84.95
@3d4e5906
04/30/98 16:45:55 |
Joel Sherrill |
Changed default target architecture name
4.104.114.84.95
@5f92a6a3
04/30/98 16:45:08 |
Joel Sherrill |
Modified objcopy invocation to ignore more sections.
4.104.114.84.95
@96d56b3
04/27/98 18:42:04 |
Joel Sherrill |
Update from Pedro Romano <pmcnr@…>.
4.104.114.84.95
@0e70f605
04/27/98 14:21:55 |
Joel Sherrill |
Fixes from Ralf Corsepius:
* Posix BSP configuration: Moved some …
4.104.114.84.95
@c1dc8228
04/27/98 14:21:04 |
Joel Sherrill |
Removed forced enable of POSIX API. Now follow configuration flag.
4.104.114.84.95
@21c1513
04/27/98 14:20:25 |
Joel Sherrill |
Fixed bad CVS Id string.
Removed unnecessary definition of "ED".
4.104.114.84.95
@b3d3a34e
04/15/98 15:10:47 |
Joel Sherrill |
Stack checker now enabled via initial set of user extensions. This …
4.104.114.84.95
@4381e50
04/14/98 22:44:49 |
Joel Sherrill |
Ralf Corsepius suggested a way to get rid of UNIX compiler files and …
4.104.114.84.95
@2758c9f2
04/14/98 22:13:05 |
Joel Sherrill |
4.104.114.84.95
@1504f71e
04/14/98 21:33:20 |
Joel Sherrill |
Stack checker on
4.104.114.84.95
@92e15e0
04/14/98 21:32:56 |
Joel Sherrill |
Updates from PPC refresh
4.104.114.84.95
@b0562e74
04/14/98 19:54:38 |
Joel Sherrill |
new file
4.104.114.84.95
@092940bd
04/06/98 17:09:44 |
Joel Sherrill |
Purged references to STACK_CHECKER_REPORT_USAGE
4.104.114.84.95
@1ea9c3f
04/06/98 16:33:48 |
Joel Sherrill |
4.104.114.84.95
@a5cb673
04/06/98 16:26:53 |
Joel Sherrill |
Reordered CFLAGS definition so CFLAGS_DEFAULT is before …
4.104.114.84.95
@9d07e59d
04/06/98 15:55:37 |
Joel Sherrill |
Changed CPU model to mcpu32.
4.104.114.84.95
@5fafa0e
04/03/98 18:46:16 |
Joel Sherrill |
Added test so the build procedure would stop if a directory did not …
4.104.114.84.95
@55258b4
03/31/98 16:52:32 |
Joel Sherrill |
Fixed CUSTOM_FILES rule so it properly picked up files included from …
4.104.114.84.95
@c5fcc75e
03/30/98 14:05:03 |
Joel Sherrill |
Made the POSIX API option follow the configure line.
4.104.114.84.95
@26580ff
03/30/98 14:04:44 |
Joel Sherrill |
Made the HAS_POSIX_API follow the configure line option.
4.104.114.84.95
@de0d005
03/30/98 14:04:20 |
Joel Sherrill |
Made the C++ option follow the configure option.
4.104.114.84.95
@cbf2f54
03/30/98 14:03:59 |
Joel Sherrill |
Made HAS_POSIX_API have a "no" definition when it is not enabled.
4.104.114.84.95
@83997e2f
03/30/98 14:03:34 |
Joel Sherrill |
Made C++ follow the configure option.
4.104.114.84.95
@e6c92eef
03/24/98 18:44:40 |
Joel Sherrill |
Changed RTEMS cpu to hppa1.1.
4.104.114.84.95
@526ebe8
03/24/98 18:44:25 |
Joel Sherrill |
Added rule to transform hppa1.1 to hppa1_1 since hppa1.1 is not a …
4.104.114.84.95
@3ec7bfc
03/24/98 16:24:39 |
Joel Sherrill |
Rename hppa1_1 to hppa1.1 and switched to using XXX macros for
the …
4.104.114.84.95
@e4829a05
03/23/98 22:54:55 |
Joel Sherrill |
renamed ppc to powerpc
4.104.114.84.95
@61bbe543
03/23/98 18:35:07 |
Joel Sherrill |
Update from Eric Norum:
Here are some patches to the gen68360 …
4.104.114.84.95
@db4aaf8
03/20/98 17:39:56 |
Joel Sherrill |
Patch from Eric Norum <eric@…>:
I've included a …
4.104.114.84.95
@f8b27df9
03/20/98 17:20:45 |
Joel Sherrill |
New port from Ralf Corsepius <corsepiu@…>.
4.104.114.84.95
@aa24c61
03/20/98 16:30:51 |
Joel Sherrill |
Fixed MANAGERS_NOT_WANTED.
4.104.114.84.95
@d2865dce
03/16/98 13:52:11 |
Joel Sherrill |
Fix from Chris Johns for inconsistent invocation of make.
4.104.114.84.95
@96c73ab
02/19/98 23:02:16 |
Joel Sherrill |
Patch from Eric Norum:
While trying to work through this problem I …
4.104.114.84.95
@7324989
02/18/98 20:30:53 |
Joel Sherrill |
Went back to polled console.
4.104.114.84.95
@5d1ea96
02/17/98 20:42:10 |
Joel Sherrill |
added -Wno-unused to debug flags
4.104.114.84.95
@ac61209b
02/17/98 19:16:18 |
Joel Sherrill |
Added unused warning per discussion on rtems-snapshots list.
4.104.114.84.95
@e81ef51
02/17/98 14:12:01 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…>:
Yep, I have a …
4.104.114.84.95
@aa8a8c72
02/17/98 14:09:30 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@@faw.uni-ulm.de>:
Yep, I have a …
4.104.114.84.95
@a858910
02/11/98 22:13:46 |
Joel Sherrill |
Incorporated Ralf Corsepius' idea for new -q flags to properly support …
4.104.114.84.95
@e44e678
02/04/98 15:47:44 |
Joel Sherrill |
Cleaned up the definition of CONSOLE_USE_POLLED and CONSOLE_USE_INTERRUPTS.
4.104.114.84.95
@594a413
02/02/98 16:55:57 |
Joel Sherrill |
Fixed so installed Makefile structure work.
4.104.114.84.95
@5c3511e
01/30/98 21:49:51 |
Joel Sherrill |
Big patch form Ralf Corsepius described in this email:
Here is the …
4.104.114.84.95
@1333181
01/27/98 14:14:20 |
Joel Sherrill |
not submitted
4.104.114.84.95
@2936b425
01/23/98 17:45:05 |
Joel Sherrill |
Solaris port updates from Chris Johns
4.104.114.84.95
@bffb938
01/20/98 19:30:30 |
Joel Sherrill |
Removed PROJECT_HOME and CONFIG_DIR variables.
4.104.114.84.95
