source: rtems/make
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @93f79c0f   05/08/01 22:59:25 Joel Sherrill 2001-05-07 Ralf Corsepius <corsepiu@…> * leaf.cfg: … 4.104.114.84.95
(edit) @65e6b542   04/26/01 16:41:44 Joel Sherrill 2001-04-26 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @d96374f   04/11/01 14:06:05 Joel Sherrill 2001-04-11 Eric Valette <valette@…> * … 4.104.114.84.95
(edit) @8d2eb8c   04/11/01 13:49:47 Joel Sherrill 2001-04-11 Joel Sherrill <joel@…> * custom/default.cfg: … 4.104.114.84.95
(edit) @969de1f3   04/06/01 16:00:54 Joel Sherrill 2001-03-30 Eric Valette <valette@…> * … 4.104.114.84.95
(edit) @1a792e47   03/14/01 17:25:20 Joel Sherrill 2001-03-14 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @48ad47cc   03/01/01 20:46:21 Joel Sherrill 2001-02-22 Ralf Corsepius <corsepiu@…> * configure.in: … 4.104.114.84.95
(edit) @85371f7   02/21/01 14:20:01 Joel Sherrill 2001-02-20 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @e5bc1968   02/12/01 14:52:50 Joel Sherrill 2001-02-07 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @1db8d62f   02/05/01 18:21:18 Joel Sherrill 2001-02-03 Ralf Corsepius <corsepiu@…> * lib.cfg: … 4.104.114.84.95
(edit) @227ae749   01/22/01 14:03:44 Joel Sherrill 2001-01-22 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @96e34e0   01/09/01 13:51:09 Joel Sherrill 2001-01-09 Joel Sherrill <joel@…> * custom/pc386.cfg … 4.104.114.84.95
(edit) @f8b891d   01/08/01 18:14:01 Joel Sherrill 2001-01-08 Joel Sherrill <joel@…> * custom/p4000.cfg, … 4.104.114.84.95
(edit) @e8ad374a   01/05/01 13:36:58 Joel Sherrill 2001-01-05 Joel Sherrill <joel@…> * custom/gensh1.cfg: … 4.104.114.84.95
(edit) @fdfa5b9   01/03/01 18:46:31 Joel Sherrill 2001-01-03 Emmanuel Raguet <raguet@…> * custom/mcp750.cfg … 4.104.114.84.95
(edit) @c2bbfb52   01/03/01 17:53:45 Joel Sherrill 2001-01-03 Joel Sherrill <joel@…> * custom/psim.cfg: … 4.104.114.84.95
(edit) @80cc928   01/03/01 16:47:16 Joel Sherrill 2001-01-03 Joel Sherrill <joel@…> * custom/sim68000.cfg: … 4.104.114.84.95
(edit) @cec6bb0   12/14/00 14:23:10 Joel Sherrill 2000-12-14 Emmanuel Raguet <raguet@…> * … 4.104.114.84.95
(edit) @dfa6d4b7   12/06/00 15:48:04 Joel Sherrill 2000-12-06 Joel Sherrill <joel@…> * custom/vegaplus.cfg: … 4.104.114.84.95
(edit) @3fddd25c   12/01/00 19:25:10 Joel Sherrill 2000-12-01 Joel Sherrill <joel@…> * custom/jmr3904.cfg: … 4.104.114.84.95
(edit) @c061304   11/30/00 14:38:18 Joel Sherrill 2000-11-30 Joel Sherrill <joel@…> * custom/jmr3904.cfg: … 4.104.114.84.95
(edit) @e066afe8   11/27/00 17:04:00 Joel Sherrill 2000-11-27 Joel Sherrill <joel@…> * custom/jmr3904.cfg: … 4.104.114.84.95
(edit) @1c69af9b   11/27/00 16:02:50 Joel Sherrill 2000-11-27 Joel Sherrill <joel@…> * custom/shsim.cfg: New … 4.104.114.84.95
(edit) @511374e4   11/25/00 20:06:11 Joel Sherrill 2000-11-25 Joel Sherrill <joel@…> * custom/pc386.cfg: … 4.104.114.84.95
(edit) @732d4db   11/25/00 18:45:13 Joel Sherrill 2000-11-25 Joel Sherrill <joel@…> * custom/Makefile.am: … 4.104.114.84.95
(edit) @8c47d509   11/15/00 21:48:40 Joel Sherrill 2000-11-13 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @cd0324cf   11/13/00 22:48:24 Joel Sherrill 2000-11-13 Jiri Gaisler <jgais@…> * … 4.104.114.84.95
(edit) @b2e4f3a8   11/10/00 14:24:36 Joel Sherrill 2000-11-10 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @2b0714f3   10/27/00 14:33:19 Joel Sherrill 2000-10-27 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @c801aba   10/25/00 16:53:51 Joel Sherrill 2000-10-24 Joel Sherrill <joel@…> * custom/p4600.cfg, … 4.104.114.84.95
(edit) @3a410c5   10/18/00 13:05:10 Joel Sherrill 2000-10-18 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @3db37a7c   09/13/00 19:39:00 Joel Sherrill 2000-09-13 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @fb7e6dcf   09/13/00 13:45:41 Joel Sherrill 2000-09-13 Emmanuel Raguet <raguet@…> * vegaplus BSP … 4.104.114.84.95
(edit) @2094513   09/12/00 20:56:54 Joel Sherrill 2000-09-12 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @5174271   09/12/00 12:51:01 Joel Sherrill 2000-09-12 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @9fbf213   09/12/00 12:48:05 Joel Sherrill 2000-09-12 Joel Sherrill <joel@…> * custom/mvme167.cfg … 4.104.114.84.95
(edit) @0905e0f   09/12/00 12:39:07 Joel Sherrill 2000-09-12 Joel Sherrill <joel@…> * custom/mbx860_005b.cfg … 4.104.114.84.95
(edit) @e0457c6b   09/06/00 13:27:31 Joel Sherrill 2000-09-05 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @c698e7b8   09/01/00 07:06:46 Joel Sherrill 2000-08-31 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @ef386359   08/29/00 14:52:33 Joel Sherrill 2000-08-29 Joel Sherrill <joel.sherrill@…> * … 4.104.114.84.95
(edit) @6fe4d043   08/25/00 17:29:00 Joel Sherrill 2000-08-17 Ralf Corsepius <corsepiu@…> * … 4.104.114.84.95
(edit) @060d538   08/25/00 17:24:11 Joel Sherrill 2000-08-11 Charles-Antoine Gauthier <charles.gauthier@…> * … 4.104.114.84.95
(edit) @b24a093   08/25/00 17:22:07 Joel Sherrill 2000-08-25 Joel Sherrill <joel.sherrill@…> * ChangeLog?: … 4.104.114.84.95
(edit) @b96ca51   08/11/00 19:24:30 Joel Sherrill 2000-08-04 Charles-Antoine Gauthier <charles.gauthier@…> * … 4.104.114.84.95
(edit) @380b5227   08/10/00 16:25:46 Joel Sherrill 2000-08-10 Charles-Antoine Gauthier <charles.gauthier@…> * … 4.104.114.84.95
(edit) @f1aa400   08/10/00 16:15:43 Joel Sherrill New file. 4.104.114.84.95
(edit) @f3d9df08   08/02/00 16:28:34 Joel Sherrill Executables are now in binary format for download using network. 4.104.114.84.95
(edit) @6baa664   08/01/00 20:51:50 Joel Sherrill Produce Srecords. 4.104.114.84.95
(edit) @b812f84   08/01/00 20:01:14 Joel Sherrill Added sim68000 BSP for the BSVC simulator. This BSP includes the … 4.104.114.84.95
(edit) @8725d7c   08/01/00 14:21:40 Joel Sherrill Patch rtems-rc-20000731-2-cvs.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @caf88699   07/31/00 18:29:37 Joel Sherrill New bsp for simulator in gdb. Does not work yet. 4.104.114.84.95
(edit) @93d31be   07/27/00 17:44:11 Joel Sherrill Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @08330bf   07/27/00 01:04:11 Joel Sherrill Port of RTEMS to the ARM processor family by Eric Valette … 4.104.114.84.95
(edit) @db9ae70   07/26/00 21:15:27 Joel Sherrill Patch from Charles-Antoine Gauthier <charles.gauthier@…> that … 4.104.114.84.95
(edit) @ca7858bb   07/26/00 19:28:11 Joel Sherrill Port of RTEMS to the Texas Instruments C3x/C4x DSP families including … 4.104.114.84.95
(edit) @b8a30d07   07/13/00 15:05:38 Joel Sherrill Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @ce39123   07/13/00 14:53:41 Joel Sherrill Removed NDEBUG as a per BSP option. 4.104.114.84.95
(edit) @bfc86bcb   07/12/00 19:28:27 Joel Sherrill Removed references to stack checker defines since it is dynamically … 4.104.114.84.95
(edit) @ea56a072   07/12/00 19:27:02 Joel Sherrill Removed stupid reference to NO_TABLE_MOVE in comment block. 4.104.114.84.95
(edit) @39607984   07/12/00 19:23:14 Joel Sherrill Patch rtems-rc-20000712-1-cvs.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @4159370   07/11/00 21:16:53 Joel Sherrill Reworked score/cpu/sparc so it can be safely compiled multilib. All … 4.104.114.84.95
(edit) @bc85fd5a   07/11/00 19:31:04 Joel Sherrill Reworked score/cpu/i960 so it can be safely compiled multilib. All … 4.104.114.84.95
(edit) @9e52b29   07/11/00 15:26:40 Joel Sherrill Patch rtems-rc-20000711-2-cvs.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @270e3cc   07/11/00 14:56:04 Joel Sherrill Patch rtems-rc-20000711-1-cvs.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @d74fdb5   07/07/00 16:46:52 Joel Sherrill Patch from James Housley <jim@…> to let the Makefiles … 4.104.114.84.95
(edit) @168ba07   07/06/00 20:36:48 Joel Sherrill Patch from Eric Valette <valette@…> and Yacine El Kolli … 4.104.114.84.95
(edit) @501d312   07/06/00 20:07:34 Joel Sherrill Added baseline for h8 simulator BSP to support the simulator in gdb 5.0 4.104.114.84.95
(edit) @80e24f1f   06/15/00 22:22:00 Joel Sherrill rxgen960 compiles and links. 4.104.114.84.95
(edit) @a4228693   06/15/00 13:20:48 Joel Sherrill Added multigen generated bare BSP configuration files. 4.104.114.84.95
(edit) @bb47a3b   06/14/00 15:46:14 Joel Sherrill Changed to standard make-exe type rule. 4.104.114.84.95
(edit) @b31839e7   06/14/00 15:45:57 Joel Sherrill Moved PPC_VECTOR_FILE_BASE to targopts.h 4.104.114.84.95
(edit) @41ab6966   06/12/00 20:06:59 Joel Sherrill Patch from John Cotton <john.cotton@…>, Charles-Antoine Gauthier … 4.104.114.84.95
(edit) @8ef3818   06/12/00 19:57:02 Joel Sherrill Patch from John Cotton <john.cotton@…>, Charles-Antoine Gauthier … 4.104.114.84.95
(edit) @68c498f4   06/12/00 16:34:46 Joel Sherrill Added i960sim BSP which (ignoring the 3 instructions not supported by … 4.104.114.84.95
(edit) @df49c60   06/12/00 15:00:15 Joel Sherrill Merged from 4.5.0-beta3a 4.104.114.84.95
(edit) @bf85b19   04/13/00 14:37:14 Joel Sherrill Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @4ace694   04/05/00 19:37:03 Joel Sherrill Cleanup patch from Ralf Corsepius. 4.104.114.84.95
(edit) @58b28eb   04/05/00 13:09:56 Joel Sherrill New file. Should support Cygwin as unix simulator port. 4.104.114.84.95
(edit) @8eacefcc   02/29/00 16:35:45 Joel Sherrill BSP now compiles and links with CAVSL board information. This … 4.104.114.84.95
(edit) @61ba9763   02/22/00 18:39:52 Joel Sherrill New port of RTEMS to TI C3x and C4x. 4.104.114.84.95
(edit) @1249edfa   02/11/00 14:12:03 Joel Sherrill Fixed typos introduced in last modification. Spotted by Erwin Rol … 4.104.114.84.95
(edit) @70810dc   02/08/00 22:33:25 Joel Sherrill Patches rtems-rc-20000204-0.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @ee3c9e5   02/08/00 14:00:45 Joel Sherrill Removed references to INSTALL_VARIANT. 4.104.114.84.95
(edit) @399432fa   02/02/00 15:26:41 Joel Sherrill Patch rtems-rc-20000118-6.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @4c46630   01/31/00 15:15:10 Joel Sherrill Patch rtems-rc-20000118-1.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @0261887   01/31/00 14:46:23 Joel Sherrill Modifications from Ralf to be more like other custom files. There is … 4.104.114.84.95
(edit) @318f591   01/27/00 14:37:17 Joel Sherrill Added after report from Quality Quorum <qqi@…> that … 4.104.114.84.95
(edit) @1e194112   01/12/00 16:08:57 Joel Sherrill Called symbol table ".nm" not .num like every other BSP. 4.104.114.84.95
(edit) @6d3ab0f   01/10/00 20:56:35 Joel Sherrill Added pc486 and pc586 as aliases of pc386 with proper cpu flags. 4.104.114.84.95
(edit) @aa1d76e   01/10/00 18:56:10 Joel Sherrill Missed cleanup from Ralf Corsepius. 4.104.114.84.95
(edit) @f9b48de   01/10/00 18:07:51 Joel Sherrill Removed reference to Radstone PPCN. 4.104.114.84.95
(edit) @2352726   01/10/00 18:07:15 Joel Sherrill Fixed comment. 4.104.114.84.95
(edit) @d273d78a   01/07/00 20:51:56 Joel Sherrill Renaming mcp750 to motorola_shared since that is the basis for both … 4.104.114.84.95
(edit) @0ff37e68   01/07/00 14:47:02 Joel Sherrill Patch rtems-rc-20000104-0.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @8b91282   12/21/99 14:27:52 Joel Sherrill Patch rtems-rc-19991203-5.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @1d5039f   12/13/99 20:30:53 Joel Sherrill * empty log message * 4.104.114.84.95
(edit) @acc25ee   12/02/99 14:31:19 Joel Sherrill Merged of mcp750 and mvme2307 BSP by Eric Valette … 4.104.114.84.95
(edit) @7dd4054   12/01/99 14:27:58 Joel Sherrill Patch rtems-rc-19991123-rc-1.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @96344c8   11/30/99 13:49:04 Joel Sherrill Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius … 4.104.114.84.95
(edit) @49da88c   11/23/99 15:53:09 Joel Sherrill Patch rtems-rc-19991117-16.diff from Ralf Corsepius … 4.104.114.84.95
