source: rtems/make
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @0e3c0096   08/05/98 15:44:09 Joel Sherrill changed load address 4.104.114.84.95
(edit) @8c6e195   08/01/98 14:41:45 Joel Sherrill Patch from David Fiddes <D.J.Fiddes@…> to make ASFLAGS include … 4.104.114.84.95
(edit) @032c100   07/30/98 15:56:59 Joel Sherrill Added HAS_RTC and enabled KA9Q. 4.104.114.84.95
(edit) @30cde042   07/28/98 16:50:14 Joel Sherrill Added missing parts of patch from Ralf Corsepius <corsepiu@…>. 4.104.114.84.95
(edit) @db29826d   07/25/98 16:20:57 Joel Sherrill Switching console interrupts on and off as we test. 4.104.114.84.95
(edit) @dbab462   07/24/98 16:09:51 Joel Sherrill Patch from Eric Valette <valette@…> and Emmanuel Raguet … 4.104.114.84.95
(edit) @dbaf51a   07/23/98 22:13:10 Joel Sherrill Patch from Emmanuel Raguet <raguet@…>: Here is a patch … 4.104.114.84.95
(edit) @f95d2b53   07/17/98 15:49:12 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>. Comments: * … 4.104.114.84.95
(edit) @9305e52   07/17/98 15:18:08 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>. Changes to … 4.104.114.84.95
(edit) @25e3f9a   07/15/98 13:59:36 Joel Sherrill Switched CONSOLE_USE_INTERRUPTS to "1" so console would use … 4.104.114.84.95
(edit) @5b8c1b7   07/11/98 14:23:53 Joel Sherrill Yet another EXEEXT patch. This one is from Ralf Corsepius … 4.104.114.84.95
(edit) @cc8a388a   07/10/98 14:13:59 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>. Comments: > … 4.104.114.84.95
(edit) @d7d51376   07/09/98 18:52:07 Joel Sherrill Now strip elf executables so they are much smaller and quicker to read … 4.104.114.84.95
(edit) @132f194   07/01/98 22:03:20 Joel Sherrill Initial submission of gen68340 BSP (should run on a 68349) from … 4.104.114.84.95
(edit) @4f0fc115   06/29/98 17:52:43 Joel Sherrill Correction from Aleksey Romanov <qqi@…> to finish off his … 4.104.114.84.95
(edit) @5d18fb0   06/27/98 18:51:49 Joel Sherrill PC386 BSP enhancements from Aleksey Romanov (Quality Quorum … 4.104.114.84.95
(edit) @98100d2   06/27/98 17:09:47 Joel Sherrill Monstrous patch from Ralf Corsepius <corsepiu@…>. I have … 4.104.114.84.95
(edit) @43b78f15   06/25/98 16:21:07 Joel Sherrill Added definition of RTEMSmcpu32p per patch from Robin Kirkham. 4.104.114.84.95
(edit) @8ed1f8d0   06/18/98 19:05:08 Joel Sherrill New file from Dario Alcocer <alcocer@…>. 4.104.114.84.95
(edit) @e5727f39   06/13/98 10:05:15 Joel Sherrill Added PPC_USE_DATA_CACHE. 4.104.114.84.95
(edit) @9456087   06/09/98 14:21:21 Joel Sherrill Added rule for .cxx and .cpp per suggestion from Geoffroy Montel … 4.104.114.84.95
(edit) @1ce50e0   06/03/98 18:40:21 Joel Sherrill Changed spacing 4.104.114.84.95
(edit) @3ac59666   06/03/98 18:40:10 Joel Sherrill Changed BSP name to posix. 4.104.114.84.95
(edit) @b938d3d4   06/03/98 18:39:53 Joel Sherrill Changed ppc to PowerPC in comments. 4.104.114.84.95
(edit) @dc104a4   05/30/98 11:46:21 Joel Sherrill Updated to current source and removed warnings. 4.104.114.84.95
(edit) @9c559acc   05/30/98 10:17:57 Joel Sherrill New file -- from rtems-LM-980406 based on a 12/97 RTEMS snapshot. 4.104.114.84.95
(edit) @27291bcc   05/27/98 22:07:40 Joel Sherrill Changed invocation of bin2boot to match gcc 2.8 rule. 4.104.114.84.95
(edit) @c2c9c7e   05/27/98 19:26:09 Joel Sherrill Added names for C++ compilers. 4.104.114.84.95
(edit) @cdf6fcbc   05/22/98 12:30:19 Joel Sherrill Now uses BSP specific configure variables and compiles for i486 and m68k. 4.104.114.84.95
(edit) @6fa1289   05/22/98 12:29:13 Joel Sherrill Renamed bare BSP specific options to make the dependency obvious. 4.104.114.84.95
(edit) @bd5e4f3b   05/21/98 18:26:58 Joel Sherrill Added bare bsp from Chris Johns <cjohns@…>. 4.104.114.84.95
(edit) @1e9c9d4   05/21/98 16:41:56 Joel Sherrill Per patch from Ralf Corsepius removed redundant lines. 4.104.114.84.95
(edit) @dd84f12   05/21/98 16:41:40 Joel Sherrill Removed undesirable space in TARGET_ARCH assignment line. Cleaned up … 4.104.114.84.95
(edit) @d494eeb4   05/21/98 16:40:46 Joel Sherrill Per patch from Ralf Corsepius UNIX ports always needs C++ for … 4.104.114.84.95
(edit) @17a8d603   05/20/98 17:02:29 Joel Sherrill Some patches in place from Brian Stevens which help the Solaris port … 4.104.114.84.95
(edit) @7aa10b0   05/20/98 17:01:39 Joel Sherrill Copied gcc 2.7.2 style make-exe rule to gcc 2.8 conditional. This … 4.104.114.84.95
(edit) @5dd4212   05/20/98 17:01:04 Joel Sherrill Changed CPP rule per patch from Ralf Corsepius. 4.104.114.84.95
(edit) @ca0bafa7   05/18/98 16:40:13 Joel Sherrill Added much stuff formerly in multiple compiler files. 4.104.114.84.95
(edit) @0500c342   05/18/98 16:39:49 Joel Sherrill Added conditional around TARGET_ARCH to prevent accidental overrides. 4.104.114.84.95
(edit) @7ebfa93   05/18/98 16:39:21 Joel Sherrill Switched to using shared gcc-target-default.cfg. 4.104.114.84.95
(edit) @6ee6abb   05/18/98 16:38:38 Joel Sherrill Added C++ rule. Added CROSS_TARGET conditionals so unix port can … 4.104.114.84.95
(edit) @60fa630   05/18/98 16:37:50 Joel Sherrill Added RTEMS_CROSS_TARGET. 4.104.114.84.95
(edit) @7123d3b   05/04/98 13:19:29 Joel Sherrill Modified objcopy to remove extra sections. Modified gcc 2.8 style … 4.104.114.84.95
(edit) @3d4e5906   04/30/98 16:45:55 Joel Sherrill Changed default target architecture name 4.104.114.84.95
(edit) @5f92a6a3   04/30/98 16:45:08 Joel Sherrill Modified objcopy invocation to ignore more sections. 4.104.114.84.95
(edit) @96d56b3   04/27/98 18:42:04 Joel Sherrill Update from Pedro Romano <pmcnr@…>. 4.104.114.84.95
(edit) @0e70f605   04/27/98 14:21:55 Joel Sherrill Fixes from Ralf Corsepius: * Posix BSP configuration: Moved some … 4.104.114.84.95
(edit) @c1dc8228   04/27/98 14:21:04 Joel Sherrill Removed forced enable of POSIX API. Now follow configuration flag. 4.104.114.84.95
(edit) @21c1513   04/27/98 14:20:25 Joel Sherrill Fixed bad CVS Id string. Removed unnecessary definition of "ED". 4.104.114.84.95
(edit) @b3d3a34e   04/15/98 15:10:47 Joel Sherrill Stack checker now enabled via initial set of user extensions. This … 4.104.114.84.95
(edit) @4381e50   04/14/98 22:44:49 Joel Sherrill Ralf Corsepius suggested a way to get rid of UNIX compiler files and … 4.104.114.84.95
(edit) @2758c9f2   04/14/98 22:13:05 Joel Sherrill Ralf Corsepius suggested a way to get rid of UNIX compiler files and … 4.104.114.84.95
(edit) @1504f71e   04/14/98 21:33:20 Joel Sherrill Stack checker on 4.104.114.84.95
(edit) @92e15e0   04/14/98 21:32:56 Joel Sherrill Updates from PPC refresh 4.104.114.84.95
(edit) @b0562e74   04/14/98 19:54:38 Joel Sherrill new file 4.104.114.84.95
(edit) @092940bd   04/06/98 17:09:44 Joel Sherrill Purged references to STACK_CHECKER_REPORT_USAGE 4.104.114.84.95
(edit) @1ea9c3f   04/06/98 16:33:48 Joel Sherrill Purged references to STACK_CHECKER_REPORT_USAGE 4.104.114.84.95
(edit) @a5cb673   04/06/98 16:26:53 Joel Sherrill Reordered CFLAGS definition so CFLAGS_DEFAULT is before … 4.104.114.84.95
(edit) @9d07e59d   04/06/98 15:55:37 Joel Sherrill Changed CPU model to mcpu32. 4.104.114.84.95
(edit) @5fafa0e   04/03/98 18:46:16 Joel Sherrill Added test so the build procedure would stop if a directory did not … 4.104.114.84.95
(edit) @55258b4   03/31/98 16:52:32 Joel Sherrill Fixed CUSTOM_FILES rule so it properly picked up files included from … 4.104.114.84.95
(edit) @c5fcc75e   03/30/98 14:05:03 Joel Sherrill Made the POSIX API option follow the configure line. 4.104.114.84.95
(edit) @26580ff   03/30/98 14:04:44 Joel Sherrill Made the HAS_POSIX_API follow the configure line option. 4.104.114.84.95
(edit) @de0d005   03/30/98 14:04:20 Joel Sherrill Made the C++ option follow the configure option. 4.104.114.84.95
(edit) @cbf2f54   03/30/98 14:03:59 Joel Sherrill Made HAS_POSIX_API have a "no" definition when it is not enabled. 4.104.114.84.95
(edit) @83997e2f   03/30/98 14:03:34 Joel Sherrill Made C++ follow the configure option. 4.104.114.84.95
(edit) @e6c92eef   03/24/98 18:44:40 Joel Sherrill Changed RTEMS cpu to hppa1.1. 4.104.114.84.95
(edit) @526ebe8   03/24/98 18:44:25 Joel Sherrill Added rule to transform hppa1.1 to hppa1_1 since hppa1.1 is not a … 4.104.114.84.95
(edit) @3ec7bfc   03/24/98 16:24:39 Joel Sherrill Rename hppa1_1 to hppa1.1 and switched to using XXX macros for the … 4.104.114.84.95
(edit) @e4829a05   03/23/98 22:54:55 Joel Sherrill renamed ppc to powerpc 4.104.114.84.95
(edit) @61bbe543   03/23/98 18:35:07 Joel Sherrill Update from Eric Norum: Here are some patches to the gen68360 … 4.104.114.84.95
(edit) @db4aaf8   03/20/98 17:39:56 Joel Sherrill Patch from Eric Norum <eric@…>: I've included a … 4.104.114.84.95
(edit) @f8b27df9   03/20/98 17:20:45 Joel Sherrill New port from Ralf Corsepius <corsepiu@…>. 4.104.114.84.95
(edit) @aa24c61   03/20/98 16:30:51 Joel Sherrill Fixed MANAGERS_NOT_WANTED. 4.104.114.84.95
(edit) @d2865dce   03/16/98 13:52:11 Joel Sherrill Fix from Chris Johns for inconsistent invocation of make. 4.104.114.84.95
(edit) @96c73ab   02/19/98 23:02:16 Joel Sherrill Patch from Eric Norum: While trying to work through this problem I … 4.104.114.84.95
(edit) @7324989   02/18/98 20:30:53 Joel Sherrill Went back to polled console. 4.104.114.84.95
(edit) @5d1ea96   02/17/98 20:42:10 Joel Sherrill added -Wno-unused to debug flags 4.104.114.84.95
(edit) @ac61209b   02/17/98 19:16:18 Joel Sherrill Added unused warning per discussion on rtems-snapshots list. 4.104.114.84.95
(edit) @e81ef51   02/17/98 14:12:01 Joel Sherrill Patch from Ralf Corsepius <corsepiu@…>: Yep, I have a … 4.104.114.84.95
(edit) @aa8a8c72   02/17/98 14:09:30 Joel Sherrill Patch from Ralf Corsepius <corsepiu@@faw.uni-ulm.de>: Yep, I have a … 4.104.114.84.95
(edit) @a858910   02/11/98 22:13:46 Joel Sherrill Incorporated Ralf Corsepius' idea for new -q flags to properly support … 4.104.114.84.95
(edit) @e44e678   02/04/98 15:47:44 Joel Sherrill Cleaned up the definition of CONSOLE_USE_POLLED and CONSOLE_USE_INTERRUPTS. 4.104.114.84.95
(edit) @594a413   02/02/98 16:55:57 Joel Sherrill Fixed so installed Makefile structure work. 4.104.114.84.95
(edit) @5c3511e   01/30/98 21:49:51 Joel Sherrill Big patch form Ralf Corsepius described in this email: Here is the … 4.104.114.84.95
(edit) @1333181   01/27/98 14:14:20 Joel Sherrill not submitted 4.104.114.84.95
(edit) @2936b425   01/23/98 17:45:05 Joel Sherrill Solaris port updates from Chris Johns 4.104.114.84.95
(add) @bffb938   01/20/98 19:30:30 Joel Sherrill Removed PROJECT_HOME and CONFIG_DIR variables. 4.104.114.84.95
