# # ChangeLog for make/host.cfg.in in rtems # # Generated by Trac 1.2.1.dev0 # 04/25/24 06:07:50 Thu, 18 Feb 1999 17:54:03 GMT Joel Sherrill [011677f] * c/src/make/host.cfg.in (modified) * make/custom/dmv152.cfg (modified) * make/custom/dmv177.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/force386.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/pc386.cfg (modified) * make/custom/posix.cfg (modified) * make/custom/simhppa.cfg (modified) * make/host.cfg.in (modified) Part of automake VI Patch from Ralf Corsepius [06fa582] * aclocal.m4 (modified) * aclocal/sysv-ipc.m4 (modified) * c/Makefile.in (modified) * c/build-tools/os/msdos/Makefile.in (modified) * c/build-tools/scripts/Makefile.in (modified) * c/build-tools/src/Makefile.in (modified) * c/src/exec/score/tools/generic/Makefile.in (modified) * c/src/exec/score/tools/sh/Makefile.in (modified) * c/src/make/host.cfg.in (modified) * c/update-tools/Makefile.in (modified) * configure (modified) * make/host.cfg.in (modified) * tools/build/os/msdos/Makefile.in (modified) * tools/build/scripts/Makefile.in (modified) * tools/build/src/Makefile.in (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/sh/Makefile.in (modified) * tools/update/Makefile.in (modified) Patches from Ralf Corsepius and myself to ... Fri, 17 Jul 1998 15:49:12 GMT Joel Sherrill [f95d2b53] * c/build-tools/os/msdos/Makefile.in (modified) * c/build-tools/scripts/Makefile.in (modified) * c/build-tools/src/Makefile.in (modified) * c/src/exec/score/tools/generic/Makefile.in (modified) * c/src/exec/score/tools/hppa1.1/Makefile.in (modified) * c/src/exec/score/tools/unix/Makefile.in (modified) * c/src/make/host.cfg.in (modified) * c/update-tools/Makefile.in (modified) * configure.in (modified) * make/host.cfg.in (modified) * make/main.cfg (modified) * tools/build/os/msdos/Makefile.in (modified) * tools/build/scripts/Makefile.in (modified) * tools/build/src/Makefile.in (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/unix/Makefile.in (modified) * tools/update/Makefile.in (modified) Patch from Ralf Corsepius . Comments: ... Sat, 27 Jun 1998 17:09:47 GMT Joel Sherrill [98100d2] * Makefile.in (modified) * aclocal.m4 (modified) * aclocal/ar-s.m4 (added) * aclocal/canonicalize-tools.m4 (modified) * aclocal/cygwin.m4 (added) * aclocal/exeext.m4 (added) * aclocal/gcc-pipe.m4 (modified) * aclocal/gcc-specs.m4 (modified) * c/PROBLEMS (modified) * c/build-tools/scripts/Makefile.in (modified) * c/build-tools/src/Makefile.in (modified) * c/src/exec/score/tools/generic/size_rtems.in (modified) * c/src/lib/libbsp/i386/pc386/tools/bin2boot.c (modified) * c/src/lib/libbsp/m68k/idp/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme162/console/console.c (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/make/README (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/host.cfg.in (modified) * c/src/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) * make/README (modified) * make/compilers/gcc-no_bsp.cfg (modified) * make/compilers/gcc-portsw.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/bare.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/force386.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gen68360.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/go32.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/no_bsp.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/pc386.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/simhppa.cfg (modified) * make/host.cfg.in (modified) * make/target.cfg.in (modified) * tools/build/scripts/Makefile.in (modified) * tools/build/src/Makefile.in (modified) * tools/cpu/generic/size_rtems.in (modified) Monstrous patch from Ralf Corsepius . I ... Mon, 27 Apr 1998 14:20:25 GMT Joel Sherrill [21c1513] * c/src/make/host.cfg.in (modified) * make/host.cfg.in (modified) Fixed bad CVS Id string. Removed unnecessary definition of "ED". Tue, 20 Jan 1998 19:30:30 GMT Joel Sherrill [bffb938] * c/src/make/README (added) * c/src/make/compilers/gcc-target-default.cfg (added) * c/src/make/directory.cfg (added) * c/src/make/host.cfg.in (added) * c/src/make/lib.cfg (added) * make/Makefile.in (added) * make/README (added) * make/Templates/Makefile.dir (added) * make/Templates/Makefile.inc.in (added) * make/Templates/Makefile.leaf (added) * make/Templates/Makefile.lib (added) * make/compilers/gcc-no_bsp.cfg (added) * make/compilers/gcc-portsw.cfg (added) * make/compilers/gcc-target-default.cfg (added) * make/custom/HPUX9-posix.cfg (added) * make/custom/Linux-posix.cfg (added) * make/custom/Solaris-posix.cfg (added) * make/custom/cvme961.cfg (added) * make/custom/default.cfg (added) * make/custom/dmv152.cfg (added) * make/custom/efi332.cfg (added) * make/custom/efi68k.cfg (added) * make/custom/erc32.cfg (added) * make/custom/force386.cfg (added) * make/custom/gen68302.cfg (added) * make/custom/gen68360.cfg (added) * make/custom/gen68360_040.cfg (added) * make/custom/gensh1.cfg (added) * make/custom/go32.cfg (added) * make/custom/go32_p5.cfg (added) * make/custom/i386ex.cfg (added) * make/custom/idp.cfg (added) * make/custom/mvme136.cfg (added) * make/custom/mvme147.cfg (added) * make/custom/mvme147s.cfg (added) * make/custom/mvme162.cfg (added) * make/custom/mvme162lx.cfg (added) * make/custom/no_bsp.cfg (added) * make/custom/ods68302.cfg (added) * make/custom/p4000.cfg (added) * make/custom/p4600.cfg (added) * make/custom/p4650.cfg (added) * make/custom/papyrus.cfg (added) * make/custom/pc386.cfg (added) * make/custom/portsw.cfg (added) * make/custom/posix.cfg (added) * make/custom/simhppa.cfg (added) * make/directory.cfg (added) * make/host.cfg.in (added) * make/leaf.cfg (added) * make/lib.cfg (added) * make/main.cfg (added) * make/target.cfg.in (added) Removed PROJECT_HOME and CONFIG_DIR variables.
