# # ChangeLog for make/custom in rtems # # Generated by Trac 1.2.1.dev0 # 05/06/24 12:30:16 Wed, 13 Sep 2000 13:45:41 GMT Joel Sherrill [fb7e6dcf] * make/ChangeLog (modified) * make/custom/vegaplus.cfg (added) 2000-09-13 Emmanuel Raguet * ... Tue, 12 Sep 2000 20:56:54 GMT Joel Sherrill [2094513] * make/ChangeLog (modified) * make/custom/erc32.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gen68340.cfg (modified) * make/custom/gen68360.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/ods68302.cfg (modified) 2000-09-12 Ralf Corsepius * ... Tue, 12 Sep 2000 12:51:01 GMT Joel Sherrill [5174271] * make/ChangeLog (modified) * make/custom/gensh2.cfg (modified) 2000-09-12 Ralf Corsepius * ... Tue, 12 Sep 2000 12:48:05 GMT Joel Sherrill [9fbf213] * make/ChangeLog (modified) * make/custom/mvme167.cfg (modified) 2000-09-12 Joel Sherrill * ... Tue, 12 Sep 2000 12:39:07 GMT Joel Sherrill [0905e0f] * make/ChangeLog (modified) * make/custom/mbx860_005b.cfg (modified) 2000-09-12 Joel Sherrill * ... Wed, 06 Sep 2000 13:27:31 GMT Joel Sherrill [e0457c6b] * make/ChangeLog (modified) * make/custom/arm_bare_bsp.cfg (modified) 2000-09-05 Ralf Corsepius * ... Fri, 01 Sep 2000 07:06:46 GMT Joel Sherrill [c698e7b8] * make/ChangeLog (modified) * make/custom/gensh1.cfg (modified) * make/custom/gensh2.cfg (modified) * make/custom/simcpu32.cfg (modified) 2000-08-31 Ralf Corsepius * ... Tue, 29 Aug 2000 14:52:33 GMT Joel Sherrill [ef386359] * make/ChangeLog (modified) * make/custom/armulator.cfg (modified) 2000-08-29 Joel Sherrill * ... Fri, 25 Aug 2000 17:29:00 GMT Joel Sherrill [6fe4d043] * make/ChangeLog (modified) * make/custom/i386ex.cfg (modified) * make/custom/pc486.cfg (modified) * make/custom/pc586.cfg (modified) * make/custom/pc686.cfg (modified) * make/custom/pck6.cfg (added) 2000-08-17 Ralf Corsepius * ... Fri, 25 Aug 2000 17:24:11 GMT Joel Sherrill [060d538] * make/ChangeLog (modified) * make/custom/mbx8xx.cfg (modified) 2000-08-11 Charles-Antoine Gauthier ... Fri, 11 Aug 2000 19:24:30 GMT Joel Sherrill [b96ca51] * make/ChangeLog (modified) * make/custom/mvme167.cfg (modified) 2000-08-04 Charles-Antoine Gauthier ... Thu, 10 Aug 2000 16:25:46 GMT Joel Sherrill [380b5227] * make/ChangeLog (modified) * make/custom/mbx8xx.cfg (modified) 2000-08-10 Charles-Antoine Gauthier ... Wed, 02 Aug 2000 16:28:34 GMT Joel Sherrill [f3d9df08] * make/custom/mvme162.cfg (modified) Executables are now in binary format for download using network. Tue, 01 Aug 2000 20:51:50 GMT Joel Sherrill [6baa664] * make/custom/sim68000.cfg (modified) Produce Srecords. Tue, 01 Aug 2000 20:01:14 GMT Joel Sherrill [b812f84] * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) * c/ACKNOWLEDGEMENTS (modified) * c/TESTED (modified) * c/src/lib/libbsp/m68k/shared/bspspuriousinit.c (added) * c/src/lib/libbsp/m68k/shared/m68000spurious.c (added) * c/src/lib/libbsp/m68k/sim68000/.cvsignore (added) * c/src/lib/libbsp/m68k/sim68000/Makefile.am (added) * c/src/lib/libbsp/m68k/sim68000/README (added) * c/src/lib/libbsp/m68k/sim68000/bsp_specs (added) * c/src/lib/libbsp/m68k/sim68000/clock/.cvsignore (added) * c/src/lib/libbsp/m68k/sim68000/clock/Makefile.am (added) * c/src/lib/libbsp/m68k/sim68000/clock/clockdrv.c (added) * c/src/lib/libbsp/m68k/sim68000/configure.in (added) * c/src/lib/libbsp/m68k/sim68000/console/.cvsignore (added) * c/src/lib/libbsp/m68k/sim68000/console/Makefile.am (added) * c/src/lib/libbsp/m68k/sim68000/console/conscfg.c (added) * c/src/lib/libbsp/m68k/sim68000/include/.cvsignore (added) * c/src/lib/libbsp/m68k/sim68000/include/Makefile.am (added) * c/src/lib/libbsp/m68k/sim68000/include/bsp.h (added) * c/src/lib/libbsp/m68k/sim68000/sim68000.setup (added) * c/src/lib/libbsp/m68k/sim68000/start/.cvsignore (added) * c/src/lib/libbsp/m68k/sim68000/start/Makefile.am (added) * c/src/lib/libbsp/m68k/sim68000/start/start.S (added) * c/src/lib/libbsp/m68k/sim68000/startup/.cvsignore (added) * c/src/lib/libbsp/m68k/sim68000/startup/Makefile.am (added) * c/src/lib/libbsp/m68k/sim68000/startup/bspstart.c (added) * c/src/lib/libbsp/m68k/sim68000/startup/linkcmds (added) * c/src/lib/libbsp/m68k/sim68000/startup/spurious_assistant.c (added) * c/src/lib/libbsp/m68k/sim68000/wrapup/.cvsignore (added) * c/src/lib/libbsp/m68k/sim68000/wrapup/Makefile.am (added) * make/custom/sim68000.cfg (added) * make/custom/simcpu32.cfg (added) Added sim68000 BSP for the BSVC simulator. This BSP includes the ... Tue, 01 Aug 2000 14:21:40 GMT Joel Sherrill [8725d7c] * make/custom/dmv152.cfg (modified) * make/custom/dmv177.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mcp750.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/mvme2307.cfg (modified) * make/custom/ts_386ex.cfg (modified) Patch rtems-rc-20000731-2-cvs.diff from Ralf Corsepius [caf88699] * c/src/lib/libbsp/arm/armulator/Makefile.am (added) * c/src/lib/libbsp/arm/armulator/bsp_specs (added) * c/src/lib/libbsp/arm/armulator/clock/.cvsignore (added) * c/src/lib/libbsp/arm/armulator/clock/Makefile.am (added) * c/src/lib/libbsp/arm/armulator/clock/clockdrv.c (added) * c/src/lib/libbsp/arm/armulator/configure.in (added) * c/src/lib/libbsp/arm/armulator/console/.cvsignore (added) * c/src/lib/libbsp/arm/armulator/console/Makefile.am (added) * c/src/lib/libbsp/arm/armulator/console/console-io.c (added) * c/src/lib/libbsp/arm/armulator/console/mon-syscalls.S (added) * c/src/lib/libbsp/arm/armulator/include/.cvsignore (added) * c/src/lib/libbsp/arm/armulator/include/Makefile.am (added) * c/src/lib/libbsp/arm/armulator/include/bsp.h (added) * c/src/lib/libbsp/arm/armulator/start/Makefile.am (added) * c/src/lib/libbsp/arm/armulator/start/start.S (added) * c/src/lib/libbsp/arm/armulator/startup/.cvsignore (added) * c/src/lib/libbsp/arm/armulator/startup/Makefile.am (added) * c/src/lib/libbsp/arm/armulator/startup/bspstart.c (added) * c/src/lib/libbsp/arm/armulator/startup/libcfunc.c (added) * c/src/lib/libbsp/arm/armulator/startup/linkcmds (added) * c/src/lib/libbsp/arm/armulator/startup/swi.h (added) * c/src/lib/libbsp/arm/armulator/startup/syscalls.c (added) * c/src/lib/libbsp/arm/armulator/startup/trap.S (added) * c/src/lib/libbsp/arm/armulator/wrapup/.cvsignore (added) * c/src/lib/libbsp/arm/armulator/wrapup/Makefile.am (added) * make/custom/armulator.cfg (added) New bsp for simulator in gdb. Does not work yet. Thu, 27 Jul 2000 17:44:11 GMT Joel Sherrill [93d31be] * make/custom/arm_bare_bsp.cfg (modified) * make/custom/c4xsim.cfg (modified) Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius [08330bf] * c/ACKNOWLEDGEMENTS (modified) * c/src/exec/score/cpu/arm/.cvsignore (added) * c/src/exec/score/cpu/arm/Makefile.am (added) * c/src/exec/score/cpu/arm/asm.h (added) * c/src/exec/score/cpu/arm/configure.in (added) * c/src/exec/score/cpu/arm/cpu.c (added) * c/src/exec/score/cpu/arm/cpu_asm.S (added) * c/src/exec/score/cpu/arm/rtems/.cvsignore (added) * c/src/exec/score/cpu/arm/rtems/Makefile.am (added) * c/src/exec/score/cpu/arm/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/arm/rtems/score/Makefile.am (added) * c/src/exec/score/cpu/arm/rtems/score/arm.h (added) * c/src/exec/score/cpu/arm/rtems/score/armtypes.h (added) * c/src/exec/score/cpu/arm/rtems/score/cpu.h (added) * c/src/exec/score/cpu/arm/rtems/score/cpu_asm.h (added) * c/src/exec/score/cpu/arm/rtems/score/types.h (added) * c/src/lib/libbsp/arm/.cvsignore (added) * c/src/lib/libbsp/arm/Makefile.am (added) * c/src/lib/libbsp/arm/arm_bare_bsp/.cvsignore (added) * c/src/lib/libbsp/arm/arm_bare_bsp/Makefile.am (added) * c/src/lib/libbsp/arm/arm_bare_bsp/bsp_specs (added) * c/src/lib/libbsp/arm/arm_bare_bsp/configure.in (added) * c/src/lib/libbsp/arm/arm_bare_bsp/console/.cvsignore (added) * c/src/lib/libbsp/arm/arm_bare_bsp/console/Makefile.am (added) * c/src/lib/libbsp/arm/arm_bare_bsp/include/.cvsignore (added) * c/src/lib/libbsp/arm/arm_bare_bsp/include/Makefile.am (added) * c/src/lib/libbsp/arm/arm_bare_bsp/include/bsp.h (added) * c/src/lib/libbsp/arm/arm_bare_bsp/include/registers.h (added) * c/src/lib/libbsp/arm/arm_bare_bsp/irq/.cvsignore (added) * c/src/lib/libbsp/arm/arm_bare_bsp/irq/Makefile.am (added) * c/src/lib/libbsp/arm/arm_bare_bsp/irq/bsp_irq_asm.S (added) * c/src/lib/libbsp/arm/arm_bare_bsp/irq/bsp_irq_init.c (added) * c/src/lib/libbsp/arm/arm_bare_bsp/irq/irq.c (added) * c/src/lib/libbsp/arm/arm_bare_bsp/irq/irq.h (added) * c/src/lib/libbsp/arm/arm_bare_bsp/start/.cvsignore (added) * c/src/lib/libbsp/arm/arm_bare_bsp/start/Makefile.am (added) * c/src/lib/libbsp/arm/arm_bare_bsp/start/start.S (added) * c/src/lib/libbsp/arm/arm_bare_bsp/startup/.cvsignore (added) * c/src/lib/libbsp/arm/arm_bare_bsp/startup/Makefile.am (added) * c/src/lib/libbsp/arm/arm_bare_bsp/startup/bspstart.c (added) * c/src/lib/libbsp/arm/arm_bare_bsp/startup/exit.c (added) * c/src/lib/libbsp/arm/arm_bare_bsp/startup/linkcmds (added) * c/src/lib/libbsp/arm/arm_bare_bsp/wrapup/.cvsignore (added) * c/src/lib/libbsp/arm/arm_bare_bsp/wrapup/Makefile.am (added) * c/src/lib/libbsp/arm/configure.in (added) * c/src/lib/libbsp/arm/shared/.cvsignore (added) * c/src/lib/libbsp/arm/shared/Makefile.am (added) * c/src/lib/libbsp/arm/shared/comm/.cvsignore (added) * c/src/lib/libbsp/arm/shared/comm/Makefile.am (added) * c/src/lib/libbsp/arm/shared/comm/console.c (added) * c/src/lib/libbsp/arm/shared/comm/uart.c (added) * c/src/lib/libbsp/arm/shared/comm/uart.h (added) * c/src/lib/libbsp/arm/shared/io/.cvsignore (added) * c/src/lib/libbsp/arm/shared/io/Makefile.am (added) * c/src/lib/libbsp/arm/shared/io/bspio.h (added) * c/src/lib/libbsp/arm/shared/io/printk.c (added) * c/src/lib/libbsp/arm/shared/irq/.cvsignore (added) * c/src/lib/libbsp/arm/shared/irq/Makefile.am (added) * c/src/lib/libbsp/arm/shared/irq/irq_asm.S (added) * c/src/lib/libbsp/arm/shared/irq/irq_init.c (added) * cpukit/score/cpu/arm/.cvsignore (added) * cpukit/score/cpu/arm/Makefile.am (added) * cpukit/score/cpu/arm/asm.h (added) * cpukit/score/cpu/arm/cpu.c (added) * cpukit/score/cpu/arm/cpu_asm.S (added) * cpukit/score/cpu/arm/rtems/.cvsignore (added) * cpukit/score/cpu/arm/rtems/asm.h (added) * cpukit/score/cpu/arm/rtems/score/.cvsignore (added) * cpukit/score/cpu/arm/rtems/score/arm.h (added) * cpukit/score/cpu/arm/rtems/score/cpu.h (added) * cpukit/score/cpu/arm/rtems/score/cpu_asm.h (added) * cpukit/score/cpu/arm/rtems/score/types.h (added) * make/custom/arm_bare_bsp.cfg (added) * scripts/binutils/HISTORY (modified) * scripts/binutils/Makefile.am (modified) * scripts/buildall.in (modified) * scripts/gccnewlib/HISTORY (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gdb/Makefile.am (modified) * scripts/setup.def (modified) Port of RTEMS to the ARM processor family by Eric Valette ... Wed, 26 Jul 2000 21:15:27 GMT Joel Sherrill [db9ae70] * c/src/lib/libbsp/m68k/mvme167/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme167/network/network.c (modified) * c/src/lib/libbsp/m68k/mvme167/network/uti596.h (modified) * make/custom/mvme167.cfg (modified) Patch from Charles-Antoine Gauthier that ... Wed, 26 Jul 2000 19:28:11 GMT Joel Sherrill [ca7858bb] * c/src/lib/libbsp/c4x/c4xsim/tools/.cvsignore (modified) * c/src/lib/libbsp/c4x/c4xsim/wrapup/.cvsignore (added) * c/src/lib/libbsp/c4x/shared/.cvsignore (added) * c/src/lib/libbsp/shared/main.c (modified) * c/src/lib/libc/malloc.c (modified) * c/src/libmisc/monitor/mon-monitor.c (modified) * c/src/libnetworking/pppd/fsm.c (modified) * c/src/libnetworking/pppd/fsm.h (modified) * c/src/libnetworking/pppd/upap.c (modified) * c/src/librpc/Makefile.am (modified) * c/src/librpc/configure.in (modified) * c/src/tests/sptests/spsize/size.c (modified) * c/src/tests/tmtests/tm26/task1.c (modified) * c/src/wrapup/Makefile.am (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libmisc/monitor/mon-monitor.c (modified) * cpukit/librpc/Makefile.am (modified) * cpukit/pppd/fsm.c (modified) * cpukit/pppd/fsm.h (modified) * cpukit/pppd/upap.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadclose.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadloadenv.c (modified) * make/custom/c4xsim.cfg (modified) * testsuites/sptests/spsize/size.c (modified) * testsuites/tmtests/tm26/task1.c (modified) Port of RTEMS to the Texas Instruments C3x/C4x DSP families including ... Thu, 13 Jul 2000 15:05:38 GMT Joel Sherrill [b8a30d07] * Makefile.am (modified) * aclocal/check-itron.m4 (modified) * aclocal/check-multiprocessing.m4 (modified) * aclocal/check-posix.m4 (modified) * aclocal/rtems-debug.m4 (modified) * aclocal/rtems-test-no-pause.m4 (added) * c/src/exec/configure.in (modified) * c/src/exec/itron/configure.in (modified) * c/src/exec/posix/configure.in (modified) * c/src/exec/score/cpu/unix/configure.in (modified) * c/src/lib/configure.in (modified) * c/src/lib/libbsp/a29k/portsw/configure.in (modified) * c/src/lib/libbsp/configure.in (modified) * c/src/lib/libbsp/h8300/h8sim/configure.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/configure.in (modified) * c/src/lib/libbsp/i960/cvme961/configure.in (modified) * c/src/lib/libbsp/i960/i960sim/configure.in (modified) * c/src/lib/libbsp/i960/rxgen960/configure.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.in (modified) * c/src/lib/libbsp/powerpc/dmv177/configure.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/configure.in (modified) * c/src/lib/libbsp/powerpc/helas403/configure.in (modified) * c/src/lib/libbsp/powerpc/mbx8xx/configure.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.in (modified) * c/src/lib/libbsp/powerpc/papyrus/configure.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/configure.in (modified) * c/src/lib/libbsp/powerpc/psim/configure.in (modified) * c/src/lib/libbsp/unix/posix/configure.in (modified) * c/src/libmisc/configure.in (modified) * c/src/tests/configure.in (modified) * c/src/tests/itrontests/configure.in (modified) * c/src/tests/itrontests/itrontests.am (modified) * c/src/tests/libtests/configure.in (modified) * c/src/tests/libtests/libtests.am (modified) * c/src/tests/mptests/configure.in (modified) * c/src/tests/mptests/mp01/node1/Makefile.am (modified) * c/src/tests/mptests/mp01/node2/Makefile.am (modified) * c/src/tests/mptests/mp02/node1/Makefile.am (modified) * c/src/tests/mptests/mp02/node2/Makefile.am (modified) * c/src/tests/mptests/mp03/node1/Makefile.am (modified) * c/src/tests/mptests/mp03/node2/Makefile.am (modified) * c/src/tests/mptests/mp04/node1/Makefile.am (modified) * c/src/tests/mptests/mp04/node2/Makefile.am (modified) * c/src/tests/mptests/mp05/node1/Makefile.am (modified) * c/src/tests/mptests/mp05/node2/Makefile.am (modified) * c/src/tests/mptests/mp06/node1/Makefile.am (modified) * c/src/tests/mptests/mp06/node2/Makefile.am (modified) * c/src/tests/mptests/mp07/node1/Makefile.am (modified) * c/src/tests/mptests/mp07/node2/Makefile.am (modified) * c/src/tests/mptests/mp08/node1/Makefile.am (modified) * c/src/tests/mptests/mp08/node2/Makefile.am (modified) * c/src/tests/mptests/mp09/node1/Makefile.am (modified) * c/src/tests/mptests/mp09/node2/Makefile.am (modified) * c/src/tests/mptests/mp10/node1/Makefile.am (modified) * c/src/tests/mptests/mp10/node2/Makefile.am (modified) * c/src/tests/mptests/mp11/node1/Makefile.am (modified) * c/src/tests/mptests/mp11/node2/Makefile.am (modified) * c/src/tests/mptests/mp12/node1/Makefile.am (modified) * c/src/tests/mptests/mp12/node2/Makefile.am (modified) * c/src/tests/mptests/mp13/node1/Makefile.am (modified) * c/src/tests/mptests/mp13/node2/Makefile.am (modified) * c/src/tests/mptests/mp14/node1/Makefile.am (modified) * c/src/tests/mptests/mp14/node2/Makefile.am (modified) * c/src/tests/mptests/mptests.am (modified) * c/src/tests/psxtests/configure.in (modified) * c/src/tests/psxtests/psxtests.am (modified) * c/src/tests/samples/base_mp/node1/Makefile.am (modified) * c/src/tests/samples/base_mp/node2/Makefile.am (modified) * c/src/tests/samples/configure.in (modified) * c/src/tests/samples/sample.am (modified) * c/src/tests/sptests/configure.in (modified) * c/src/tests/sptests/sptests.am (modified) * c/src/tests/support/configure.in (modified) * c/src/tests/tmitrontests/configure.in (modified) * c/src/tests/tmitrontests/tmitrontests.am (modified) * c/src/tests/tmtests/configure.in (modified) * c/src/tests/tmtests/tmtests.am (modified) * make/custom/Cygwin-posix.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/bare.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/dmv177.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/eth_comm.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gen68340.cfg (modified) * make/custom/gen68360.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/gensh2.cfg (modified) * make/custom/h8sim.cfg (modified) * make/custom/helas403.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/i960sim.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mbx860_005b.cfg (modified) * make/custom/mbx8xx.cfg (modified) * make/custom/mcp750.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/mvme167.cfg (modified) * make/custom/mvme2307.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/pc386.cfg (modified) * make/custom/portsw.cfg (modified) * make/custom/ppcn_60x.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/rxgen960.cfg (modified) * make/custom/score603e.cfg (modified) * make/custom/simhppa.cfg (modified) * make/custom/ts_386ex.cfg (modified) * testsuites/itrontests/itrontests.am (modified) * testsuites/libtests/libtests.am (modified) * testsuites/mptests/mp01/node1/Makefile.am (modified) * testsuites/mptests/mp01/node2/Makefile.am (modified) * testsuites/mptests/mp02/node1/Makefile.am (modified) * testsuites/mptests/mp02/node2/Makefile.am (modified) * testsuites/mptests/mp03/node1/Makefile.am (modified) * testsuites/mptests/mp03/node2/Makefile.am (modified) * testsuites/mptests/mp04/node1/Makefile.am (modified) * testsuites/mptests/mp04/node2/Makefile.am (modified) * testsuites/mptests/mp05/node1/Makefile.am (modified) * testsuites/mptests/mp05/node2/Makefile.am (modified) * testsuites/mptests/mp06/node1/Makefile.am (modified) * testsuites/mptests/mp06/node2/Makefile.am (modified) * testsuites/mptests/mp07/node1/Makefile.am (modified) * testsuites/mptests/mp07/node2/Makefile.am (modified) * testsuites/mptests/mp08/node1/Makefile.am (modified) * testsuites/mptests/mp08/node2/Makefile.am (modified) * testsuites/mptests/mp09/node1/Makefile.am (modified) * testsuites/mptests/mp09/node2/Makefile.am (modified) * testsuites/mptests/mp10/node1/Makefile.am (modified) * testsuites/mptests/mp10/node2/Makefile.am (modified) * testsuites/mptests/mp11/node1/Makefile.am (modified) * testsuites/mptests/mp11/node2/Makefile.am (modified) * testsuites/mptests/mp12/node1/Makefile.am (modified) * testsuites/mptests/mp12/node2/Makefile.am (modified) * testsuites/mptests/mp13/node1/Makefile.am (modified) * testsuites/mptests/mp13/node2/Makefile.am (modified) * testsuites/mptests/mp14/node1/Makefile.am (modified) * testsuites/mptests/mp14/node2/Makefile.am (modified) * testsuites/mptests/mptests.am (modified) * testsuites/psxtests/psxtests.am (modified) * testsuites/samples/base_mp/node1/Makefile.am (modified) * testsuites/samples/base_mp/node2/Makefile.am (modified) * testsuites/samples/sample.am (modified) * testsuites/sptests/sptests.am (modified) * testsuites/tmitrontests/tmitrontests.am (modified) * testsuites/tmtests/tmtests.am (modified) Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius [ce39123] * make/custom/Cygwin-posix.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/bare.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/dmv177.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/eth_comm.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gen68340.cfg (modified) * make/custom/gen68360.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/gensh2.cfg (modified) * make/custom/h8sim.cfg (modified) * make/custom/helas403.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/i960sim.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mbx860_005b.cfg (modified) * make/custom/mbx8xx.cfg (modified) * make/custom/mcp750.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/mvme167.cfg (modified) * make/custom/mvme2307.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/pc386.cfg (modified) * make/custom/portsw.cfg (modified) * make/custom/ppcn_60x.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/rxgen960.cfg (modified) * make/custom/score603e.cfg (modified) * make/custom/simhppa.cfg (modified) * make/custom/ts_386ex.cfg (modified) Removed NDEBUG as a per BSP option. Wed, 12 Jul 2000 19:28:27 GMT Joel Sherrill [bfc86bcb] * make/custom/mbx860_005b.cfg (modified) * make/custom/mbx8xx.cfg (modified) Removed references to stack checker defines since it is dynamically ... Wed, 12 Jul 2000 19:27:02 GMT Joel Sherrill [ea56a072] * make/custom/Cygwin-posix.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/rxgen960.cfg (modified) Removed stupid reference to NO_TABLE_MOVE in comment block. Wed, 12 Jul 2000 19:23:14 GMT Joel Sherrill [39607984] * aclocal/rtems-debug.m4 (added) * c/src/exec/configure.in (modified) * configure.in (modified) * make/custom/Cygwin-posix.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/bare.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/dmv177.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/eth_comm.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gen68340.cfg (modified) * make/custom/gen68360.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/gensh2.cfg (modified) * make/custom/h8sim.cfg (modified) * make/custom/helas403.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/i960sim.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mbx860_005b.cfg (modified) * make/custom/mbx8xx.cfg (modified) * make/custom/mcp750.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/mvme167.cfg (modified) * make/custom/mvme2307.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/pc386.cfg (modified) * make/custom/portsw.cfg (modified) * make/custom/ppcn_60x.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/rxgen960.cfg (modified) * make/custom/score603e.cfg (modified) * make/custom/simhppa.cfg (modified) * make/custom/ts_386ex.cfg (modified) Patch rtems-rc-20000712-1-cvs.diff from Ralf Corsepius [4159370] * c/src/exec/score/cpu/i960/rtems/score/i960.h (modified) * c/src/exec/score/cpu/sparc/Makefile.am (modified) * c/src/exec/score/cpu/sparc/asm.h (modified) * c/src/exec/score/cpu/sparc/cpu.c (modified) * c/src/exec/score/cpu/sparc/cpu_asm.S (modified) * c/src/exec/score/cpu/sparc/erc32.h (deleted) * c/src/exec/score/cpu/sparc/rtems.S (modified) * c/src/exec/score/cpu/sparc/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/sparc/rtems/score/sparc.h (modified) * c/src/exec/score/cpu/sparc/rtems/score/sparctypes.h (modified) * c/src/exec/score/cpu/sparc/rtems/score/types.h (modified) * c/src/exec/score/include/rtems/system.h (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/erc32/start/start.S (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspstart.c (modified) * c/src/lib/libcpu/i960/include/Makefile.am (modified) * c/src/lib/libcpu/sparc/Makefile.am (modified) * c/src/lib/libcpu/sparc/configure.in (modified) * cpukit/score/cpu/i960/rtems/score/i960.h (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/asm.h (modified) * cpukit/score/cpu/sparc/cpu.c (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) * cpukit/score/cpu/sparc/rtems/asm.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) * cpukit/score/cpu/sparc/rtems/score/types.h (modified) * cpukit/score/include/rtems/system.h (modified) * make/custom/p4600.cfg (modified) Reworked score/cpu/sparc so it can be safely compiled multilib. All ... Tue, 11 Jul 2000 19:31:04 GMT Joel Sherrill [bc85fd5a] * c/src/exec/score/cpu/i960/Makefile.am (modified) * c/src/exec/score/cpu/i960/cpu.c (modified) * c/src/exec/score/cpu/i960/cpu_asm.S (modified) * c/src/exec/score/cpu/i960/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/i960/rtems/score/i960.h (modified) * c/src/lib/libbsp/i960/cvme961/include/bsp.h (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i960/i960sim/include/bsp.h (modified) * c/src/lib/libbsp/i960/i960sim/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/i960sim/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/clock/ckinit.c (modified) * c/src/lib/libbsp/i960/rxgen960/include/bsp.h (modified) * c/src/lib/libbsp/i960/rxgen960/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/cntrltbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/rom_cntrltbl.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/rom_ibr.c (modified) * c/src/lib/libbsp/i960/rxgen960/timer/timer.c (modified) * c/src/lib/libbsp/i960/rxgen960/wrapup/Makefile.am (modified) * c/src/lib/libcpu/i960/Makefile.am (added) * c/src/lib/libcpu/i960/configure.in (added) * c/src/lib/libcpu/i960/i960ca/Makefile.am (added) * c/src/lib/libcpu/i960/i960ca/cpu_install_intr_stack.c (added) * c/src/lib/libcpu/i960/i960ca/cpu_install_raw_isr.c (added) * c/src/lib/libcpu/i960/i960ka/Makefile.am (added) * c/src/lib/libcpu/i960/i960ka/cpu_install_intr_stack.c (added) * c/src/lib/libcpu/i960/i960ka/cpu_install_raw_isr.c (added) * c/src/lib/libcpu/i960/i960rp/Makefile.am (added) * c/src/lib/libcpu/i960/i960rp/cpu_install_intr_stack.c (added) * c/src/lib/libcpu/i960/i960rp/cpu_install_raw_isr.c (added) * c/src/lib/libcpu/i960/include/Makefile.am (added) * c/src/lib/libcpu/i960/include/i960CA.h (added) * c/src/lib/libcpu/i960/include/i960HA.h (added) * c/src/lib/libcpu/i960/include/i960JX_RP_common.h (added) * c/src/lib/libcpu/i960/include/i960KA.h (added) * c/src/lib/libcpu/i960/include/i960RP.h (moved) * c/src/lib/libcpu/i960/shared/soft_reset_asm.S (added) * cpukit/score/cpu/i960/Makefile.am (modified) * cpukit/score/cpu/i960/cpu.c (modified) * cpukit/score/cpu/i960/cpu_asm.S (modified) * cpukit/score/cpu/i960/rtems/score/cpu.h (modified) * cpukit/score/cpu/i960/rtems/score/i960.h (modified) * make/custom/i960sim.cfg (modified) * make/custom/rxgen960.cfg (modified) Reworked score/cpu/i960 so it can be safely compiled multilib. All ... Tue, 11 Jul 2000 15:26:40 GMT Joel Sherrill [9e52b29] * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) Patch rtems-rc-20000711-2-cvs.diff from Ralf Corsepius [270e3cc] * c/src/exec/score/cpu/i960/asm.h (modified) * c/src/exec/score/cpu/m68k/asm.h (modified) * c/src/exec/score/cpu/no_cpu/asm.h (modified) * c/src/exec/score/cpu/sh/asm.h (modified) * c/src/exec/score/include/rtems/system.h (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.am (modified) * cpukit/score/cpu/i960/asm.h (modified) * cpukit/score/cpu/m68k/asm.h (modified) * cpukit/score/cpu/m68k/rtems/asm.h (modified) * cpukit/score/cpu/no_cpu/asm.h (modified) * cpukit/score/cpu/no_cpu/rtems/asm.h (modified) * cpukit/score/cpu/sh/asm.h (modified) * cpukit/score/cpu/sh/rtems/asm.h (modified) * cpukit/score/include/rtems/system.h (modified) * make/custom/dmv152.cfg (modified) * make/custom/mvme167.cfg (modified) Patch rtems-rc-20000711-1-cvs.diff from Ralf Corsepius [168ba07] * c/src/exec/sapi/include/confdefs.h (modified) * c/src/lib/libbsp/powerpc/mbx8xx/startup/imbx8xx.c (modified) * c/src/lib/libbsp/powerpc/mbx8xx/startup/mmutlbtab.c (modified) * cpukit/sapi/include/confdefs.h (modified) * make/custom/mbx860_005b.cfg (added) * make/custom/mbx8xx.cfg (modified) Patch from Eric Valette and Yacine El Kolli ... Thu, 06 Jul 2000 20:07:34 GMT Joel Sherrill [501d312] * c/src/lib/libbsp/h8300/Makefile.am (added) * c/src/lib/libbsp/h8300/configure.in (added) * c/src/lib/libbsp/h8300/h8sim/Makefile.am (added) * c/src/lib/libbsp/h8300/h8sim/bsp_specs (added) * c/src/lib/libbsp/h8300/h8sim/configure.in (added) * c/src/lib/libbsp/h8300/h8sim/console/.cvsignore (added) * c/src/lib/libbsp/h8300/h8sim/console/Makefile.am (added) * c/src/lib/libbsp/h8300/h8sim/console/console-io.c (added) * c/src/lib/libbsp/h8300/h8sim/include/.cvsignore (added) * c/src/lib/libbsp/h8300/h8sim/include/Makefile.am (added) * c/src/lib/libbsp/h8300/h8sim/include/bsp.h (added) * c/src/lib/libbsp/h8300/h8sim/start/.cvsignore (added) * c/src/lib/libbsp/h8300/h8sim/start/Makefile.am (added) * c/src/lib/libbsp/h8300/h8sim/start/start.S (added) * c/src/lib/libbsp/h8300/h8sim/startup/.cvsignore (added) * c/src/lib/libbsp/h8300/h8sim/startup/Makefile.am (added) * c/src/lib/libbsp/h8300/h8sim/startup/__main.c (added) * c/src/lib/libbsp/h8300/h8sim/startup/bspstart.c (added) * c/src/lib/libbsp/h8300/h8sim/startup/linkcmds (added) * c/src/lib/libbsp/h8300/h8sim/wrapup/.cvsignore (added) * c/src/lib/libbsp/h8300/h8sim/wrapup/Makefile.am (added) * make/custom/h8sim.cfg (added) Added baseline for h8 simulator BSP to support the simulator in gdb 5.0 Thu, 15 Jun 2000 22:22:00 GMT Joel Sherrill [80e24f1f] * c/src/lib/libbsp/i960/rxgen960/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/bsp_specs (modified) * c/src/lib/libbsp/i960/rxgen960/configure.in (modified) * c/src/lib/libbsp/i960/rxgen960/start/Makefile.am (added) * c/src/lib/libbsp/i960/rxgen960/start/rxgen_romld.S (moved) * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/startup/exit.c (modified) * c/src/lib/libbsp/i960/rxgen960/startup/kkprintf.c (modified) * make/custom/rxgen960.cfg (modified) rxgen960 compiles and links. Thu, 15 Jun 2000 13:20:48 GMT Joel Sherrill [a4228693] * make/custom/.cvsignore (modified) Added multigen generated bare BSP configuration files. Wed, 14 Jun 2000 15:46:14 GMT Joel Sherrill [bb47a3b] * make/custom/mbx8xx.cfg (modified) Changed to standard make-exe type rule. Wed, 14 Jun 2000 15:45:57 GMT Joel Sherrill [b31839e7] * make/custom/eth_comm.cfg (modified) Moved PPC_VECTOR_FILE_BASE to targopts.h Mon, 12 Jun 2000 20:06:59 GMT Joel Sherrill [41ab6966] * c/src/tests/libffi/Makefile.am (added) * c/src/tests/libffi/configure.in (added) * c/src/tests/libffi/ffitest/Makefile.am (added) * c/src/tests/libffi/ffitest/ffitest.c (added) * c/src/tests/libffi/ffitest/init.c (added) * c/src/tests/libffi/ffitest/system.h (added) * c/src/tests/libffi/libffi.am (added) * c/src/tests/sptests/threaditerate/Makefile.am (added) * c/src/tests/sptests/threaditerate/init.c (added) * c/src/tests/sptests/threaditerate/itrontask.c (added) * c/src/tests/sptests/threaditerate/pthread.c (added) * c/src/tests/sptests/threaditerate/rtemstask.c (added) * c/src/tests/sptests/threaditerate/system.h (added) * c/src/tests/sptests/threaditerate/threadinfo.c (added) * c/src/tests/sptests/threaditerate/threaditerate.scn (added) * make/custom/mbx821_001.cfg (added) * make/custom/mbx860_002.cfg (added) * make/custom/mbx8xx.cfg (added) Patch from John Cotton , Charles-Antoine Gauthier ... Mon, 12 Jun 2000 19:57:02 GMT Joel Sherrill [8ef3818] * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) * c/src/exec/libcsupport/include/sys/termios.h (modified) * c/src/exec/libcsupport/src/malloc.c (modified) * c/src/exec/libcsupport/src/termios.c (modified) * c/src/exec/posix/src/waitpid.c (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/include/rtems/rtems/cache.h (added) * c/src/exec/rtems/src/Makefile.am (modified) * c/src/exec/rtems/src/cache.c (added) * c/src/exec/score/cpu/i386/rtems/score/i386.h (modified) * c/src/exec/score/cpu/m68k/rtems/score/m68k.h (modified) * c/src/exec/score/cpu/powerpc/asm.h (modified) * c/src/exec/score/cpu/powerpc/old_exception_processing/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/old_exception_processing/cpu.c (modified) * c/src/exec/score/cpu/powerpc/old_exception_processing/cpu.h (modified) * c/src/exec/score/cpu/powerpc/rtems/score/ppc.h (modified) * c/src/exec/score/cpu/powerpc/shared/asm.h (modified) * c/src/exec/score/cpu/powerpc/shared/ppc.h (modified) * c/src/exec/score/include/rtems/score/object.h (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/src/Makefile.am (modified) * c/src/exec/score/src/objectlocaliterate.c (added) * c/src/exec/score/src/threadlocaliterate.c (added) * c/src/lib/include/sys/termios.h (modified) * c/src/lib/libbsp/m68k/gen68360/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme167/README (modified) * c/src/lib/libbsp/m68k/mvme167/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme167/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme167/network/network.c (modified) * c/src/lib/libbsp/m68k/mvme167/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme167/startup/page_table.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/canbus.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/console.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/network.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/cpuinit.c (added) * c/src/lib/libbsp/powerpc/eth_comm/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/mmutlbtab.c (added) * c/src/lib/libbsp/powerpc/mbx8xx/Makefile.am (added) * c/src/lib/libbsp/powerpc/mbx8xx/README (added) * c/src/lib/libbsp/powerpc/mbx8xx/bsp_specs (added) * c/src/lib/libbsp/powerpc/mbx8xx/configure.in (added) * c/src/lib/libbsp/powerpc/mbx8xx/console/Makefile.am (added) * c/src/lib/libbsp/powerpc/mbx8xx/console/console.c (added) * c/src/lib/libbsp/powerpc/mbx8xx/include/Makefile.am (added) * c/src/lib/libbsp/powerpc/mbx8xx/include/bsp.h (added) * c/src/lib/libbsp/powerpc/mbx8xx/include/coverhd.h (added) * c/src/lib/libbsp/powerpc/mbx8xx/network/Makefile.am (added) * c/src/lib/libbsp/powerpc/mbx8xx/network/network.c (added) * c/src/lib/libbsp/powerpc/mbx8xx/startup/Makefile.am (added) * c/src/lib/libbsp/powerpc/mbx8xx/startup/bspstart.c (added) * c/src/lib/libbsp/powerpc/mbx8xx/startup/bspstart.c.nocache (added) * c/src/lib/libbsp/powerpc/mbx8xx/startup/imbx8xx.c (added) * c/src/lib/libbsp/powerpc/mbx8xx/startup/linkcmds (added) * c/src/lib/libbsp/powerpc/mbx8xx/startup/mmutlbtab.c (added) * c/src/lib/libbsp/powerpc/mbx8xx/startup/setvec.c (added) * c/src/lib/libbsp/powerpc/mbx8xx/startup/start.S (added) * c/src/lib/libbsp/powerpc/mbx8xx/times-mbx821 (added) * c/src/lib/libbsp/powerpc/mbx8xx/times-mbx860 (added) * c/src/lib/libbsp/powerpc/mbx8xx/wrapup/Makefile.am (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/Makefile.am (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/cpu.c (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/cpu.h (modified) * c/src/lib/libc/malloc.c (modified) * c/src/lib/libc/termios.c (modified) * c/src/lib/libcpu/i386/cpu.h (modified) * c/src/lib/libcpu/i386/page.c (modified) * c/src/lib/libcpu/powerpc/Makefile.am (modified) * c/src/lib/libcpu/powerpc/configure.in (modified) * c/src/lib/libcpu/powerpc/mpc8xx/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc8xx/README (added) * c/src/lib/libcpu/powerpc/mpc8xx/clock/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc8xx/clock/clock.c (added) * c/src/lib/libcpu/powerpc/mpc8xx/console-generic/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c (added) * c/src/lib/libcpu/powerpc/mpc8xx/cpm/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc8xx/cpm/cp.c (added) * c/src/lib/libcpu/powerpc/mpc8xx/cpm/dpram.c (added) * c/src/lib/libcpu/powerpc/mpc8xx/include/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc8xx/include/console.h (added) * c/src/lib/libcpu/powerpc/mpc8xx/include/cpm.h (added) * c/src/lib/libcpu/powerpc/mpc8xx/include/mmu.h (added) * c/src/lib/libcpu/powerpc/mpc8xx/include/mpc8xx.h (added) * c/src/lib/libcpu/powerpc/mpc8xx/mmu/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc8xx/mmu/mmu.c (added) * c/src/lib/libcpu/powerpc/mpc8xx/timer/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc8xx/timer/timer.c (added) * c/src/lib/libcpu/powerpc/mpc8xx/vectors/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc8xx/vectors/README (added) * c/src/lib/libcpu/powerpc/mpc8xx/vectors/align_h.S (added) * c/src/lib/libcpu/powerpc/mpc8xx/vectors/vectors.S (added) * c/src/lib/libcpu/powerpc/old-exceptions/cpu.c (modified) * c/src/lib/libcpu/powerpc/old_exception_processing/Makefile.am (modified) * c/src/lib/libcpu/powerpc/old_exception_processing/cpu.c (modified) * c/src/lib/libcpu/powerpc/old_exception_processing/cpu.h (modified) * c/src/lib/libcpu/powerpc/shared/cpu.h (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/tests/configure.in (modified) * c/src/tests/libtests/termios/init.c (modified) * c/src/tests/samples/cdtest/system.h (modified) * c/src/tests/sptests/Makefile.am (modified) * c/src/tests/sptests/configure.in (modified) * cpukit/libcsupport/include/sys/termios.h (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/posix/src/waitpid.c (modified) * cpukit/rtems/include/rtems/rtems/cache.h (added) * cpukit/rtems/src/Makefile.am (modified) * cpukit/score/cpu/i386/rtems/score/i386.h (modified) * cpukit/score/cpu/m68k/rtems/score/m68k.h (modified) * cpukit/score/cpu/powerpc/asm.h (modified) * cpukit/score/cpu/powerpc/rtems/asm.h (modified) * cpukit/score/cpu/powerpc/rtems/score/ppc.h (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/Makefile.am (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/eth_comm.cfg (modified) * make/custom/mvme167.cfg (modified) * make/leaf.cfg (modified) * testsuites/libtests/termios/init.c (modified) * testsuites/samples/cdtest/system.h (modified) * testsuites/sptests/Makefile.am (modified) Patch from John Cotton , Charles-Antoine Gauthier ... Mon, 12 Jun 2000 16:34:46 GMT Joel Sherrill [68c498f4] * c/src/lib/libbsp/i960/i960sim/Makefile.am (added) * c/src/lib/libbsp/i960/i960sim/bsp_specs (added) * c/src/lib/libbsp/i960/i960sim/configure.in (added) * c/src/lib/libbsp/i960/i960sim/console/.cvsignore (added) * c/src/lib/libbsp/i960/i960sim/console/Makefile.am (added) * c/src/lib/libbsp/i960/i960sim/console/console-io.c (added) * c/src/lib/libbsp/i960/i960sim/console/mon-syscalls.S (added) * c/src/lib/libbsp/i960/i960sim/include/.cvsignore (added) * c/src/lib/libbsp/i960/i960sim/include/Makefile.am (added) * c/src/lib/libbsp/i960/i960sim/include/bsp.h (added) * c/src/lib/libbsp/i960/i960sim/start/.cvsignore (added) * c/src/lib/libbsp/i960/i960sim/start/Makefile.am (added) * c/src/lib/libbsp/i960/i960sim/start/start.c (added) * c/src/lib/libbsp/i960/i960sim/startup/Makefile.am (added) * c/src/lib/libbsp/i960/i960sim/startup/bspstart.c (added) * c/src/lib/libbsp/i960/i960sim/startup/linkcmds (added) * c/src/lib/libbsp/i960/i960sim/wrapup/.cvsignore (added) * c/src/lib/libbsp/i960/i960sim/wrapup/Makefile.am (added) * make/custom/i960sim.cfg (added) Added i960sim BSP which (ignoring the 3 instructions not supported ... Mon, 12 Jun 2000 15:00:15 GMT Joel Sherrill [df49c60] * Makefile.am (modified) * VERSION (modified) * aclocal/canonical-host.m4 (modified) * aclocal/canonical-target-name.m4 (modified) * aclocal/check-multiprocessing.m4 (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/prog-cxx.m4 (modified) * aclocal/target.m4 (modified) * automake/host.am (added) * automake/local.am (modified) * automake/subdirs.am (modified) * bootstrap (modified) * c/Makefile.am (modified) * c/make/Makefile.am (modified) * c/src/Makefile.am (modified) * c/src/exec/itron/include/Makefile.am (modified) * c/src/exec/itron/include/itronsys/Makefile.am (modified) * c/src/exec/itron/include/rtems/itron/Makefile.am (modified) * c/src/exec/itron/inline/rtems/itron/Makefile.am (modified) * c/src/exec/itron/src/Makefile.am (modified) * c/src/exec/itron/src/cre_tsk.c (modified) * c/src/exec/itron/src/eventflags.c (modified) * c/src/exec/itron/src/fmempool.c (modified) * c/src/exec/itron/src/itronsem.c (modified) * c/src/exec/itron/src/mbox.c (modified) * c/src/exec/itron/src/msgbuffer.c (modified) * c/src/exec/itron/src/port.c (modified) * c/src/exec/itron/src/vmempool.c (modified) * c/src/exec/libcsupport/Makefile.am (modified) * c/src/exec/libcsupport/include/console.h (modified) * c/src/exec/libcsupport/include/rtems/error.h (modified) * c/src/exec/libcsupport/include/sys/termios.h (modified) * c/src/exec/libcsupport/src/Makefile.am (modified) * c/src/exec/libcsupport/src/gxx_wrappers.c (modified) * c/src/exec/libcsupport/src/libio.c (modified) * c/src/exec/libcsupport/src/malloc.c (modified) * c/src/exec/libcsupport/src/scandir.c (modified) * c/src/exec/libcsupport/src/termios.c (modified) * c/src/exec/libcsupport/src/termiosreserveresources.c (modified) * c/src/exec/libcsupport/src/unmount.c (modified) * c/src/exec/libfs/src/imfs/imfs.h (modified) * c/src/exec/libfs/src/imfs/imfs_creat.c (modified) * c/src/exec/libfs/src/imfs/imfs_directory.c (modified) * c/src/exec/libfs/src/imfs/imfs_stat.c (modified) * c/src/exec/libfs/src/imfs/imfs_utime.c (modified) * c/src/exec/libnetworking/Makefile.am (modified) * c/src/exec/libnetworking/arpa/Makefile.am (modified) * c/src/exec/libnetworking/kern/Makefile.am (modified) * c/src/exec/libnetworking/lib/Makefile.am (modified) * c/src/exec/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * c/src/exec/libnetworking/libc/Makefile.am (modified) * c/src/exec/libnetworking/machine/Makefile.am (modified) * c/src/exec/libnetworking/memory.h (modified) * c/src/exec/libnetworking/net/Makefile.am (modified) * c/src/exec/libnetworking/net/if_loop.c (modified) * c/src/exec/libnetworking/netinet/Makefile.am (modified) * c/src/exec/libnetworking/netinet/in.h (modified) * c/src/exec/libnetworking/nfs/Makefile.am (modified) * c/src/exec/libnetworking/rtems/Makefile.am (modified) * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/exec/libnetworking/sys/Makefile.am (modified) * c/src/exec/libnetworking/sys/un.h (modified) * c/src/exec/libnetworking/vm/Makefile.am (modified) * c/src/exec/libnetworking/wrapup/Makefile.am (modified) * c/src/exec/librpc/Makefile.am (modified) * c/src/exec/librpc/README_RTEMS (modified) * c/src/exec/librpc/include/Makefile.am (modified) * c/src/exec/librpc/include/rpc/Makefile.am (modified) * c/src/exec/librpc/include/rpc/auth.h (modified) * c/src/exec/librpc/include/rpc/auth_des.h (modified) * c/src/exec/librpc/include/rpc/auth_unix.h (modified) * c/src/exec/librpc/include/rpc/clnt.h (modified) * c/src/exec/librpc/include/rpc/des.h (modified) * c/src/exec/librpc/include/rpc/des_crypt.h (modified) * c/src/exec/librpc/include/rpc/pmap_clnt.h (modified) * c/src/exec/librpc/include/rpc/pmap_prot.h (modified) * c/src/exec/librpc/include/rpc/pmap_rmt.h (modified) * c/src/exec/librpc/include/rpc/rpc.h (modified) * c/src/exec/librpc/include/rpc/rpc_com.h (modified) * c/src/exec/librpc/include/rpc/rpc_msg.h (modified) * c/src/exec/librpc/include/rpc/svc.h (modified) * c/src/exec/librpc/include/rpc/svc_auth.h (modified) * c/src/exec/librpc/include/rpc/types.h (modified) * c/src/exec/librpc/include/rpc/xdr.h (modified) * c/src/exec/librpc/include/rpcsvc/.cvsignore (modified) * c/src/exec/librpc/include/rpcsvc/Makefile.am (modified) * c/src/exec/librpc/include/rpcsvc/bootparam_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/crypt.x (modified) * c/src/exec/librpc/include/rpcsvc/key_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/klm_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/mount.x (modified) * c/src/exec/librpc/include/rpcsvc/nfs_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/nis.x (modified) * c/src/exec/librpc/include/rpcsvc/nis_cache.x (modified) * c/src/exec/librpc/include/rpcsvc/nis_callback.x (modified) * c/src/exec/librpc/include/rpcsvc/nis_db.h (modified) * c/src/exec/librpc/include/rpcsvc/nis_object.x (modified) * c/src/exec/librpc/include/rpcsvc/nis_tags.h (modified) * c/src/exec/librpc/include/rpcsvc/nislib.h (modified) * c/src/exec/librpc/include/rpcsvc/nlm_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/pmap_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/rex.x (modified) * c/src/exec/librpc/include/rpcsvc/rnusers.x (modified) * c/src/exec/librpc/include/rpcsvc/rquota.x (modified) * c/src/exec/librpc/include/rpcsvc/rstat.x (modified) * c/src/exec/librpc/include/rpcsvc/rwall.x (modified) * c/src/exec/librpc/include/rpcsvc/sm_inter.x (modified) * c/src/exec/librpc/include/rpcsvc/spray.x (modified) * c/src/exec/librpc/include/rpcsvc/yp.x (modified) * c/src/exec/librpc/include/rpcsvc/yp_prot.h (modified) * c/src/exec/librpc/include/rpcsvc/ypclnt.h (modified) * c/src/exec/librpc/include/rpcsvc/yppasswd.x (modified) * c/src/exec/librpc/include/rpcsvc/ypupdate_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/ypxfrd.x (modified) * c/src/exec/librpc/src/Makefile.am (modified) * c/src/exec/librpc/src/rpc/DISCLAIMER (modified) * c/src/exec/librpc/src/rpc/Makefile.am (modified) * c/src/exec/librpc/src/rpc/PSD.doc/.cvsignore (modified) * c/src/exec/librpc/src/rpc/PSD.doc/Makefile.am (modified) * c/src/exec/librpc/src/rpc/PSD.doc/nfs.rfc.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/rpc.prog.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/rpc.rfc.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/rpcgen.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/xdr.nts.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/xdr.rfc.ms (modified) * c/src/exec/librpc/src/rpc/README (modified) * c/src/exec/librpc/src/rpc/auth_des.c (modified) * c/src/exec/librpc/src/rpc/auth_none.c (modified) * c/src/exec/librpc/src/rpc/auth_time.c (modified) * c/src/exec/librpc/src/rpc/auth_unix.c (modified) * c/src/exec/librpc/src/rpc/authdes_prot.c (modified) * c/src/exec/librpc/src/rpc/authunix_prot.c (modified) * c/src/exec/librpc/src/rpc/bindresvport.3 (modified) * c/src/exec/librpc/src/rpc/bindresvport.c (modified) * c/src/exec/librpc/src/rpc/clnt_generic.c (modified) * c/src/exec/librpc/src/rpc/clnt_perror.c (modified) * c/src/exec/librpc/src/rpc/clnt_raw.c (modified) * c/src/exec/librpc/src/rpc/clnt_simple.c (modified) * c/src/exec/librpc/src/rpc/clnt_tcp.c (modified) * c/src/exec/librpc/src/rpc/clnt_udp.c (modified) * c/src/exec/librpc/src/rpc/clnt_unix.c (modified) * c/src/exec/librpc/src/rpc/crypt_client.c (modified) * c/src/exec/librpc/src/rpc/des_crypt.3 (modified) * c/src/exec/librpc/src/rpc/des_crypt.c (modified) * c/src/exec/librpc/src/rpc/des_soft.c (modified) * c/src/exec/librpc/src/rpc/get_myaddress.c (modified) * c/src/exec/librpc/src/rpc/getpublickey.c (modified) * c/src/exec/librpc/src/rpc/getrpcent.3 (modified) * c/src/exec/librpc/src/rpc/getrpcent.c (modified) * c/src/exec/librpc/src/rpc/getrpcport.3 (modified) * c/src/exec/librpc/src/rpc/getrpcport.c (modified) * c/src/exec/librpc/src/rpc/key_call.c (modified) * c/src/exec/librpc/src/rpc/key_prot_xdr.c (modified) * c/src/exec/librpc/src/rpc/netname.c (modified) * c/src/exec/librpc/src/rpc/netnamer.c (modified) * c/src/exec/librpc/src/rpc/pmap_clnt.c (modified) * c/src/exec/librpc/src/rpc/pmap_getmaps.c (modified) * c/src/exec/librpc/src/rpc/pmap_getport.c (modified) * c/src/exec/librpc/src/rpc/pmap_prot.c (modified) * c/src/exec/librpc/src/rpc/pmap_prot2.c (modified) * c/src/exec/librpc/src/rpc/pmap_rmt.c (modified) * c/src/exec/librpc/src/rpc/publickey.3 (modified) * c/src/exec/librpc/src/rpc/publickey.5 (modified) * c/src/exec/librpc/src/rpc/rpc.3 (modified) * c/src/exec/librpc/src/rpc/rpc.5 (modified) * c/src/exec/librpc/src/rpc/rpc_callmsg.c (modified) * c/src/exec/librpc/src/rpc/rpc_commondata.c (modified) * c/src/exec/librpc/src/rpc/rpc_dtablesize.c (modified) * c/src/exec/librpc/src/rpc/rpc_prot.c (modified) * c/src/exec/librpc/src/rpc/rpc_secure.3 (modified) * c/src/exec/librpc/src/rpc/rpcdname.c (modified) * c/src/exec/librpc/src/rpc/rstat.1 (modified) * c/src/exec/librpc/src/rpc/rstat_svc.8 (modified) * c/src/exec/librpc/src/rpc/rtems_portmapper.c (modified) * c/src/exec/librpc/src/rpc/rtems_rpc.c (modified) * c/src/exec/librpc/src/rpc/rtime.3 (modified) * c/src/exec/librpc/src/rpc/rtime.c (modified) * c/src/exec/librpc/src/rpc/svc.c (modified) * c/src/exec/librpc/src/rpc/svc_auth.c (modified) * c/src/exec/librpc/src/rpc/svc_auth_des.c (modified) * c/src/exec/librpc/src/rpc/svc_auth_unix.c (modified) * c/src/exec/librpc/src/rpc/svc_raw.c (modified) * c/src/exec/librpc/src/rpc/svc_run.c (modified) * c/src/exec/librpc/src/rpc/svc_simple.c (modified) * c/src/exec/librpc/src/rpc/svc_tcp.c (modified) * c/src/exec/librpc/src/rpc/svc_udp.c (modified) * c/src/exec/librpc/src/rpc/svc_unix.c (modified) * c/src/exec/librpc/src/xdr/Makefile.am (modified) * c/src/exec/librpc/src/xdr/xdr.3 (modified) * c/src/exec/librpc/src/xdr/xdr.c (modified) * c/src/exec/librpc/src/xdr/xdr_array.c (modified) * c/src/exec/librpc/src/xdr/xdr_float.c (modified) * c/src/exec/librpc/src/xdr/xdr_mem.c (modified) * c/src/exec/librpc/src/xdr/xdr_rec.c (modified) * c/src/exec/librpc/src/xdr/xdr_reference.c (modified) * c/src/exec/librpc/src/xdr/xdr_sizeof.c (modified) * c/src/exec/librpc/src/xdr/xdr_stdio.c (modified) * c/src/exec/posix/include/Makefile.am (modified) * c/src/exec/posix/include/pthread.h (deleted) * c/src/exec/posix/include/rtems/posix/Makefile.am (modified) * c/src/exec/posix/include/sys/Makefile.am (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.am (modified) * c/src/exec/posix/inline/rtems/posix/cond.inl (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.am (modified) * c/src/exec/posix/optman/Makefile.am (modified) * c/src/exec/posix/src/Makefile.am (modified) * c/src/exec/posix/src/mqueuecreatesupp.c (modified) * c/src/exec/posix/src/mqueuedeletesupp.c (modified) * c/src/exec/posix/src/mqueueunlink.c (modified) * c/src/exec/posix/src/pthread.c (modified) * c/src/exec/posix/src/pthreadcreate.c (modified) * c/src/exec/posix/src/sigtimedwait.c (modified) * c/src/exec/posix/src/waitpid.c (modified) * c/src/exec/rtems/include/Makefile.am (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/include/rtems/rtems/rtemsapi.h (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/optman/Makefile.am (modified) * c/src/exec/rtems/optman/no-mp.c (modified) * c/src/exec/rtems/src/Makefile.am (modified) * c/src/exec/rtems/src/semdelete.c (modified) * c/src/exec/rtems/src/tasks.c (modified) * c/src/exec/rtems/src/taskvariableadd.c (modified) * c/src/exec/rtems/src/taskvariabledelete.c (modified) * c/src/exec/rtems/src/taskvariableget.c (modified) * c/src/exec/sapi/include/Makefile.am (modified) * c/src/exec/sapi/include/confdefs.h (modified) * c/src/exec/sapi/include/rtems/Makefile.am (modified) * c/src/exec/sapi/include/rtems/README (modified) * c/src/exec/sapi/inline/rtems/Makefile.am (modified) * c/src/exec/sapi/macros/rtems/Makefile.am (modified) * c/src/exec/sapi/optman/Makefile.am (modified) * c/src/exec/sapi/src/Makefile.am (modified) * c/src/exec/score/cpu/a29k/Makefile.am (modified) * c/src/exec/score/cpu/a29k/rtems/Makefile.am (modified) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/a29k/rtems/score/a29k.h (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/hppa.h (modified) * c/src/exec/score/cpu/i386/Makefile.am (modified) * c/src/exec/score/cpu/i386/rtems/Makefile.am (modified) * c/src/exec/score/cpu/i386/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/i386/rtems/score/i386.h (modified) * c/src/exec/score/cpu/i960/Makefile.am (modified) * c/src/exec/score/cpu/i960/rtems/Makefile.am (modified) * c/src/exec/score/cpu/i960/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/i960/rtems/score/i960.h (modified) * c/src/exec/score/cpu/m68k/Makefile.am (modified) * c/src/exec/score/cpu/m68k/qsm.h (modified) * c/src/exec/score/cpu/m68k/rtems/Makefile.am (modified) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/m68k/rtems/score/m68k.h (modified) * c/src/exec/score/cpu/m68k/sim.h (modified) * c/src/exec/score/cpu/mips/Makefile.am (modified) * c/src/exec/score/cpu/mips/rtems/Makefile.am (modified) * c/src/exec/score/cpu/mips/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/mips/rtems/score/mips.h (modified) * c/src/exec/score/cpu/mips/rtems/score/mips64orion.h (modified) * c/src/exec/score/cpu/mips64orion/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/mips64orion.h (modified) * c/src/exec/score/cpu/no_cpu/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/cpu.c (modified) * c/src/exec/score/cpu/no_cpu/cpu_asm.c (modified) * c/src/exec/score/cpu/no_cpu/rtems.c (modified) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/no_cpu.h (modified) * c/src/exec/score/cpu/powerpc/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/new_exception_processing/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/old_exception_processing/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/old_exception_processing/irq_stub.S (modified) * c/src/exec/score/cpu/powerpc/rtems/score/ppc.h (modified) * c/src/exec/score/cpu/powerpc/shared/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/shared/ppc.h (modified) * c/src/exec/score/cpu/sh/Makefile.am (modified) * c/src/exec/score/cpu/sh/rtems/Makefile.am (modified) * c/src/exec/score/cpu/sh/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/sh/rtems/score/sh.h (modified) * c/src/exec/score/cpu/sparc/Makefile.am (modified) * c/src/exec/score/cpu/sparc/rtems/Makefile.am (modified) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/sparc/rtems/score/sparc.h (modified) * c/src/exec/score/cpu/unix/Makefile.am (modified) * c/src/exec/score/cpu/unix/cpu.c (modified) * c/src/exec/score/cpu/unix/rtems/Makefile.am (modified) * c/src/exec/score/cpu/unix/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/unix/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/unix/rtems/score/unix.h (modified) * c/src/exec/score/include/rtems/Makefile.am (modified) * c/src/exec/score/include/rtems/score/Makefile.am (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/include/rtems/system.h (modified) * c/src/exec/score/inline/rtems/score/Makefile.am (modified) * c/src/exec/score/macros/rtems/score/Makefile.am (modified) * c/src/exec/score/macros/rtems/score/address.inl (modified) * c/src/exec/score/src/Makefile.am (modified) * c/src/exec/score/src/objectcopynamestring.c (modified) * c/src/exec/wrapup/itron/Makefile.am (modified) * c/src/exec/wrapup/posix/Makefile.am (modified) * c/src/exec/wrapup/rtems/Makefile.am (modified) * c/src/lib/Makefile.am (modified) * c/src/lib/configure.in (modified) * c/src/lib/include/Makefile.am (modified) * c/src/lib/include/console.h (modified) * c/src/lib/include/motorola/Makefile.am (modified) * c/src/lib/include/rtems/error.h (modified) * c/src/lib/include/sys/Makefile.am (modified) * c/src/lib/include/sys/termios.h (modified) * c/src/lib/include/zilog/Makefile.am (modified) * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/a29k/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/include/bsp.h (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/startup/bspstart.c (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.am (modified) * c/src/lib/libbsp/bare/Makefile.am (modified) * c/src/lib/libbsp/bare/bsp_specs (modified) * c/src/lib/libbsp/bare/include/Makefile.am (modified) * c/src/lib/libbsp/bare/include/bsp.h (modified) * c/src/lib/libbsp/hppa1.1/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/bsp.h (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/console/console.c (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/include/bsp.h (modified) * c/src/lib/libbsp/i386/i386ex/network/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/start/start.S (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/3c509/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/HOWTO (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/ne2000/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/start/start16.S (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/wd8003/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/comm/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/io/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/irq/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/pci/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/console/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/console/console.c (modified) * c/src/lib/libbsp/i386/ts_386ex/include/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/include/bsp.h (modified) * c/src/lib/libbsp/i386/ts_386ex/network/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/start/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/start/start.S (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/ts_386ex/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_ada/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_ada/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_c/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_c/system.h (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/adasockets/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/listener/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/listener/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/tcprelay/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/tcprelay/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i960/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/include/bsp.h (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/bsp_specs (modified) * c/src/lib/libbsp/i960/rxgen960/clock/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/console/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/include/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/include/bsp.h (modified) * c/src/lib/libbsp/i960/rxgen960/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/rxgen960/timer/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/console/console.c (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/include/bsp.h (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/README (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/include/bsp.h (modified) * c/src/lib/libbsp/m68k/efi332/misc/dotests (modified) * c/src/lib/libbsp/m68k/efi332/misc/gdbinit68 (modified) * c/src/lib/libbsp/m68k/efi332/misc/interr.c (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/start/start.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/except_vect_332_ROM.S (modified) * c/src/lib/libbsp/m68k/efi332/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/efi332/startup/linkcmds_ROM (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/include/bsp.h (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68340/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/console/consolereserveresources.c (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/network/network.c (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/start/start.S (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/init68360.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.bootp (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.prom (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/include/bsp.h (modified) * c/src/lib/libbsp/m68k/idp/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme162/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/README (modified) * c/src/lib/libbsp/m68k/mvme167/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/configure.in (modified) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/console/console-recording.c (modified) * c/src/lib/libbsp/m68k/mvme167/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme167/network/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/network/network.c (modified) * c/src/lib/libbsp/m68k/mvme167/network/uti596.h (modified) * c/src/lib/libbsp/m68k/mvme167/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme167/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme167/startup/page_table.c (modified) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/shared/m68kpretaskinghook.c (modified) * c/src/lib/libbsp/m68k/shared/start.S (modified) * c/src/lib/libbsp/mips/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/console/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/include/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/include/bsp.h (modified) * c/src/lib/libbsp/mips/p4000/liblnk/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/start/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/startup/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/p4000/wrapup/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/include/bsp.h (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/bsp_specs (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/bsp_specs (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/start.S (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bsp_specs (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/motorola/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/bsp_specs (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/console.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/bsp_specs (modified) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/console/console.c (modified) * c/src/lib/libbsp/powerpc/psim/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/tools/runtest (modified) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/bsp_specs (modified) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/console/consolereserveresources.c (modified) * c/src/lib/libbsp/powerpc/score603e/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/misc.c (modified) * c/src/lib/libbsp/powerpc/shared/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/console/console.c (modified) * c/src/lib/libbsp/powerpc/shared/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/shared/irq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq_asm.S (modified) * c/src/lib/libbsp/powerpc/shared/motorola/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/openpic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/residual/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/start/start.S (modified) * c/src/lib/libbsp/powerpc/shared/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/shared/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/Makefile.am (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/Makefile.am (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/irq_stub.S (modified) * c/src/lib/libbsp/sh/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/bsp_specs (modified) * c/src/lib/libbsp/sh/gensh1/console/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/include/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/startup/bspstart.c (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/README (modified) * c/src/lib/libbsp/sh/gensh2/bsp_specs (modified) * c/src/lib/libbsp/sh/gensh2/console/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/include/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh2/scitab/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/start/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/start/start.S (modified) * c/src/lib/libbsp/sh/gensh2/startup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/startup/bspstart.c (modified) * c/src/lib/libbsp/sh/gensh2/startup/hw_init.c (modified) * c/src/lib/libbsp/sh/gensh2/wrapup/Makefile.am (modified) * c/src/lib/libbsp/sh/shared/Makefile.am (modified) * c/src/lib/libbsp/shared/console.c (modified) * c/src/lib/libbsp/shmdr/Makefile.am (modified) * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/console/consolereserveresources.c (modified) * c/src/lib/libbsp/sparc/erc32/gnatsupp/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/linkcmds (modified) * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/tools/runtest.in (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.am (modified) * c/src/lib/libbsp/unix/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/configure.in (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/include/bsp.h (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/startup/bspstart.c (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.am (modified) * c/src/lib/libc/Makefile.am (modified) * c/src/lib/libc/error.h (modified) * c/src/lib/libc/gxx_wrappers.c (modified) * c/src/lib/libc/imfs.h (modified) * c/src/lib/libc/imfs_creat.c (modified) * c/src/lib/libc/imfs_directory.c (modified) * c/src/lib/libc/imfs_stat.c (modified) * c/src/lib/libc/imfs_utime.c (modified) * c/src/lib/libc/libio.c (modified) * c/src/lib/libc/malloc.c (modified) * c/src/lib/libc/scandir.c (modified) * c/src/lib/libc/termios.c (modified) * c/src/lib/libc/termiosreserveresources.c (modified) * c/src/lib/libc/unmount.c (modified) * c/src/lib/libcpu/Makefile.am (modified) * c/src/lib/libcpu/a29k/Makefile.am (modified) * c/src/lib/libcpu/a29k/clock/Makefile.am (modified) * c/src/lib/libcpu/a29k/timer/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.am (modified) * c/src/lib/libcpu/i386/Makefile.am (modified) * c/src/lib/libcpu/m68k/Makefile.am (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.am (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.am (modified) * c/src/lib/libcpu/mips/Makefile.am (modified) * c/src/lib/libcpu/mips/clock/Makefile.am (modified) * c/src/lib/libcpu/mips/timer/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/wrapup/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc821/include/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/include/mpc860.h (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/new_exception_processing/Makefile.am (modified) * c/src/lib/libcpu/powerpc/old-exceptions/irq_stub.S (modified) * c/src/lib/libcpu/powerpc/old_exception_processing/Makefile.am (modified) * c/src/lib/libcpu/powerpc/old_exception_processing/irq_stub.S (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console.c (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/shared/Makefile.am (modified) * c/src/lib/libcpu/powerpc/wrapup/Makefile.am (modified) * c/src/lib/libcpu/sh/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/delay/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/sci/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/clock/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/include/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/null/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/sci/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/sci/sci.c (modified) * c/src/lib/libcpu/sh/sh7045/timer/Makefile.am (modified) * c/src/lib/libcpu/sparc/Makefile.am (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.am (modified) * c/src/lib/libcpu/sparc/syscall/Makefile.am (modified) * c/src/libchip/network/Makefile.am (modified) * c/src/libchip/network/README.dec21140 (modified) * c/src/libchip/network/dec21140.c (modified) * c/src/libchip/rtc/Makefile.am (modified) * c/src/libchip/serial/Makefile.am (modified) * c/src/libchip/serial/README.ns16550 (modified) * c/src/libchip/serial/STATUS (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550_p.h (modified) * c/src/libfs/src/imfs/imfs.h (modified) * c/src/libfs/src/imfs/imfs_creat.c (modified) * c/src/libfs/src/imfs/imfs_directory.c (modified) * c/src/libfs/src/imfs/imfs_stat.c (modified) * c/src/libfs/src/imfs/imfs_utime.c (modified) * c/src/libmisc/cpuuse/Makefile.am (modified) * c/src/libmisc/dummy/Makefile.am (modified) * c/src/libmisc/dummy/dummy.c (modified) * c/src/libmisc/dumpbuf/Makefile.am (modified) * c/src/libmisc/monitor/Makefile.am (modified) * c/src/libmisc/monitor/mon-server.c (modified) * c/src/libmisc/rtmonuse/Makefile.am (modified) * c/src/libmisc/stackchk/Makefile.am (modified) * c/src/libmisc/stackchk/internal.h (modified) * c/src/libmisc/untar/Makefile.am (modified) * c/src/libmisc/wrapup/Makefile.am (modified) * c/src/libnetworking/Makefile.am (modified) * c/src/libnetworking/arpa/Makefile.am (modified) * c/src/libnetworking/include/Makefile.am (modified) * c/src/libnetworking/kern/Makefile.am (modified) * c/src/libnetworking/lib/Makefile.am (modified) * c/src/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * c/src/libnetworking/libc/Makefile.am (modified) * c/src/libnetworking/machine/Makefile.am (modified) * c/src/libnetworking/memory.h (modified) * c/src/libnetworking/net/Makefile.am (modified) * c/src/libnetworking/net/if_loop.c (modified) * c/src/libnetworking/netinet/Makefile.am (modified) * c/src/libnetworking/netinet/in.h (modified) * c/src/libnetworking/nfs/Makefile.am (modified) * c/src/libnetworking/pppd/Makefile.am (modified) * c/src/libnetworking/pppd/options.c (modified) * c/src/libnetworking/pppd/pppd.h (modified) * c/src/libnetworking/pppd/rtems-ppp.c (modified) * c/src/libnetworking/rtems/Makefile.am (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * c/src/libnetworking/rtems_servers/Makefile.am (modified) * c/src/libnetworking/rtems_servers/ftpd.c (modified) * c/src/libnetworking/rtems_webserver/Makefile.am (modified) * c/src/libnetworking/rtems_webserver/balloc.c (modified) * c/src/libnetworking/rtems_webserver/ejlex.c (modified) * c/src/libnetworking/rtems_webserver/handler.c (modified) * c/src/libnetworking/rtems_webserver/uemf.c (modified) * c/src/libnetworking/rtems_webserver/uemf.h (modified) * c/src/libnetworking/rtems_webserver/webs.c (modified) * c/src/libnetworking/sys/Makefile.am (modified) * c/src/libnetworking/sys/un.h (modified) * c/src/libnetworking/vm/Makefile.am (modified) * c/src/libnetworking/wrapup/Makefile.am (modified) * c/src/librdbg/include/rdbg/Makefile.am (modified) * c/src/librdbg/include/rdbg/i386/Makefile.am (modified) * c/src/librdbg/include/rdbg/powerpc/Makefile.am (modified) * c/src/librdbg/src/Makefile.am (modified) * c/src/librdbg/src/i386/Makefile.am (modified) * c/src/librdbg/src/i386/any/Makefile.am (modified) * c/src/librdbg/src/powerpc/Makefile.am (modified) * c/src/librdbg/src/powerpc/mcp750/Makefile.am (modified) * c/src/librdbg/src/powerpc/new_exception_processing/Makefile.am (modified) * c/src/librpc/Makefile.am (modified) * c/src/librpc/README_RTEMS (modified) * c/src/librpc/configure.in (modified) * c/src/librpc/include/Makefile.am (modified) * c/src/librpc/include/rpc/Makefile.am (modified) * c/src/librpc/include/rpc/auth.h (modified) * c/src/librpc/include/rpc/auth_des.h (modified) * c/src/librpc/include/rpc/auth_unix.h (modified) * c/src/librpc/include/rpc/clnt.h (modified) * c/src/librpc/include/rpc/des.h (modified) * c/src/librpc/include/rpc/des_crypt.h (modified) * c/src/librpc/include/rpc/pmap_clnt.h (modified) * c/src/librpc/include/rpc/pmap_prot.h (modified) * c/src/librpc/include/rpc/pmap_rmt.h (modified) * c/src/librpc/include/rpc/rpc.h (modified) * c/src/librpc/include/rpc/rpc_com.h (modified) * c/src/librpc/include/rpc/rpc_msg.h (modified) * c/src/librpc/include/rpc/svc.h (modified) * c/src/librpc/include/rpc/svc_auth.h (modified) * c/src/librpc/include/rpc/types.h (modified) * c/src/librpc/include/rpc/xdr.h (modified) * c/src/librpc/include/rpcsvc/.cvsignore (modified) * c/src/librpc/include/rpcsvc/Makefile.am (modified) * c/src/librpc/include/rpcsvc/bootparam_prot.x (modified) * c/src/librpc/include/rpcsvc/crypt.x (modified) * c/src/librpc/include/rpcsvc/key_prot.x (modified) * c/src/librpc/include/rpcsvc/klm_prot.x (modified) * c/src/librpc/include/rpcsvc/mount.x (modified) * c/src/librpc/include/rpcsvc/nfs_prot.x (modified) * c/src/librpc/include/rpcsvc/nis.x (modified) * c/src/librpc/include/rpcsvc/nis_cache.x (modified) * c/src/librpc/include/rpcsvc/nis_callback.x (modified) * c/src/librpc/include/rpcsvc/nis_db.h (modified) * c/src/librpc/include/rpcsvc/nis_object.x (modified) * c/src/librpc/include/rpcsvc/nis_tags.h (modified) * c/src/librpc/include/rpcsvc/nislib.h (modified) * c/src/librpc/include/rpcsvc/nlm_prot.x (modified) * c/src/librpc/include/rpcsvc/pmap_prot.x (modified) * c/src/librpc/include/rpcsvc/rex.x (modified) * c/src/librpc/include/rpcsvc/rnusers.x (modified) * c/src/librpc/include/rpcsvc/rquota.x (modified) * c/src/librpc/include/rpcsvc/rstat.x (modified) * c/src/librpc/include/rpcsvc/rwall.x (modified) * c/src/librpc/include/rpcsvc/sm_inter.x (modified) * c/src/librpc/include/rpcsvc/spray.x (modified) * c/src/librpc/include/rpcsvc/yp.x (modified) * c/src/librpc/include/rpcsvc/yp_prot.h (modified) * c/src/librpc/include/rpcsvc/ypclnt.h (modified) * c/src/librpc/include/rpcsvc/yppasswd.x (modified) * c/src/librpc/include/rpcsvc/ypupdate_prot.x (modified) * c/src/librpc/include/rpcsvc/ypxfrd.x (modified) * c/src/librpc/src/Makefile.am (modified) * c/src/librpc/src/rpc/DISCLAIMER (modified) * c/src/librpc/src/rpc/Makefile.am (modified) * c/src/librpc/src/rpc/PSD.doc/.cvsignore (modified) * c/src/librpc/src/rpc/PSD.doc/Makefile.am (modified) * c/src/librpc/src/rpc/PSD.doc/nfs.rfc.ms (modified) * c/src/librpc/src/rpc/PSD.doc/rpc.prog.ms (modified) * c/src/librpc/src/rpc/PSD.doc/rpc.rfc.ms (modified) * c/src/librpc/src/rpc/PSD.doc/rpcgen.ms (modified) * c/src/librpc/src/rpc/PSD.doc/xdr.nts.ms (modified) * c/src/librpc/src/rpc/PSD.doc/xdr.rfc.ms (modified) * c/src/librpc/src/rpc/README (modified) * c/src/librpc/src/rpc/auth_des.c (modified) * c/src/librpc/src/rpc/auth_none.c (modified) * c/src/librpc/src/rpc/auth_time.c (modified) * c/src/librpc/src/rpc/auth_unix.c (modified) * c/src/librpc/src/rpc/authdes_prot.c (modified) * c/src/librpc/src/rpc/authunix_prot.c (modified) * c/src/librpc/src/rpc/bindresvport.3 (modified) * c/src/librpc/src/rpc/bindresvport.c (modified) * c/src/librpc/src/rpc/clnt_generic.c (modified) * c/src/librpc/src/rpc/clnt_perror.c (modified) * c/src/librpc/src/rpc/clnt_raw.c (modified) * c/src/librpc/src/rpc/clnt_simple.c (modified) * c/src/librpc/src/rpc/clnt_tcp.c (modified) * c/src/librpc/src/rpc/clnt_udp.c (modified) * c/src/librpc/src/rpc/clnt_unix.c (modified) * c/src/librpc/src/rpc/crypt_client.c (modified) * c/src/librpc/src/rpc/des_crypt.3 (modified) * c/src/librpc/src/rpc/des_crypt.c (modified) * c/src/librpc/src/rpc/des_soft.c (modified) * c/src/librpc/src/rpc/get_myaddress.c (modified) * c/src/librpc/src/rpc/getpublickey.c (modified) * c/src/librpc/src/rpc/getrpcent.3 (modified) * c/src/librpc/src/rpc/getrpcent.c (modified) * c/src/librpc/src/rpc/getrpcport.3 (modified) * c/src/librpc/src/rpc/getrpcport.c (modified) * c/src/librpc/src/rpc/key_call.c (modified) * c/src/librpc/src/rpc/key_prot_xdr.c (modified) * c/src/librpc/src/rpc/netname.c (modified) * c/src/librpc/src/rpc/netnamer.c (modified) * c/src/librpc/src/rpc/pmap_clnt.c (modified) * c/src/librpc/src/rpc/pmap_getmaps.c (modified) * c/src/librpc/src/rpc/pmap_getport.c (modified) * c/src/librpc/src/rpc/pmap_prot.c (modified) * c/src/librpc/src/rpc/pmap_prot2.c (modified) * c/src/librpc/src/rpc/pmap_rmt.c (modified) * c/src/librpc/src/rpc/publickey.3 (modified) * c/src/librpc/src/rpc/publickey.5 (modified) * c/src/librpc/src/rpc/rpc.3 (modified) * c/src/librpc/src/rpc/rpc.5 (modified) * c/src/librpc/src/rpc/rpc_callmsg.c (modified) * c/src/librpc/src/rpc/rpc_commondata.c (modified) * c/src/librpc/src/rpc/rpc_dtablesize.c (modified) * c/src/librpc/src/rpc/rpc_prot.c (modified) * c/src/librpc/src/rpc/rpc_secure.3 (modified) * c/src/librpc/src/rpc/rpcdname.c (modified) * c/src/librpc/src/rpc/rstat.1 (modified) * c/src/librpc/src/rpc/rstat_svc.8 (modified) * c/src/librpc/src/rpc/rtems_portmapper.c (modified) * c/src/librpc/src/rpc/rtems_rpc.c (modified) * c/src/librpc/src/rpc/rtime.3 (modified) * c/src/librpc/src/rpc/rtime.c (modified) * c/src/librpc/src/rpc/svc.c (modified) * c/src/librpc/src/rpc/svc_auth.c (modified) * c/src/librpc/src/rpc/svc_auth_des.c (modified) * c/src/librpc/src/rpc/svc_auth_unix.c (modified) * c/src/librpc/src/rpc/svc_raw.c (modified) * c/src/librpc/src/rpc/svc_run.c (modified) * c/src/librpc/src/rpc/svc_simple.c (modified) * c/src/librpc/src/rpc/svc_tcp.c (modified) * c/src/librpc/src/rpc/svc_udp.c (modified) * c/src/librpc/src/rpc/svc_unix.c (modified) * c/src/librpc/src/rpc_callmsg.c (deleted) * c/src/librpc/src/rpc_prot.c (deleted) * c/src/librpc/src/svc.c (deleted) * c/src/librpc/src/svc_auth.c (deleted) * c/src/librpc/src/svc_udp.c (deleted) * c/src/librpc/src/xdr.c (deleted) * c/src/librpc/src/xdr/Makefile.am (modified) * c/src/librpc/src/xdr/xdr.3 (modified) * c/src/librpc/src/xdr/xdr.c (modified) * c/src/librpc/src/xdr/xdr_array.c (modified) * c/src/librpc/src/xdr/xdr_float.c (modified) * c/src/librpc/src/xdr/xdr_mem.c (modified) * c/src/librpc/src/xdr/xdr_rec.c (modified) * c/src/librpc/src/xdr/xdr_reference.c (modified) * c/src/librpc/src/xdr/xdr_sizeof.c (modified) * c/src/librpc/src/xdr/xdr_stdio.c (modified) * c/src/librpc/src/xdr_array.c (deleted) * c/src/librpc/src/xdr_mem.c (deleted) * c/src/librtems++/include/rtems++/Makefile.am (modified) * c/src/librtems++/src/Makefile.am (modified) * c/src/make/Makefile.am (modified) * c/src/make/README (modified) * c/src/make/compilers/Makefile.am (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/configure.in (modified) * c/src/make/custom/Makefile.am (modified) * c/src/make/host.cfg.in (modified) * c/src/make/leaf.cfg (modified) * c/src/make/main.cfg.in (modified) * c/src/optman/rtems/Makefile.am (modified) * c/src/optman/rtems/no-mp.c (modified) * c/src/optman/sapi/Makefile.am (modified) * c/src/tests/itrontests/itronhello/Makefile.am (modified) * c/src/tests/itrontests/itronhello/system.h (modified) * c/src/tests/itrontests/itronmbf01/Makefile.am (modified) * c/src/tests/itrontests/itronmbf01/system.h (modified) * c/src/tests/itrontests/itronmbox01/Makefile.am (modified) * c/src/tests/itrontests/itronmbox01/itronmbox01.scn (modified) * c/src/tests/itrontests/itronmbox01/system.h (modified) * c/src/tests/itrontests/itronsem01/Makefile.am (modified) * c/src/tests/itrontests/itronsem01/init.c (modified) * c/src/tests/itrontests/itronsem01/system.h (modified) * c/src/tests/itrontests/itrontask01/Makefile.am (modified) * c/src/tests/itrontests/itrontask01/system.h (modified) * c/src/tests/itrontests/itrontask02/Makefile.am (modified) * c/src/tests/itrontests/itrontask02/system.h (modified) * c/src/tests/itrontests/itrontask03/Makefile.am (modified) * c/src/tests/itrontests/itrontask03/system.h (modified) * c/src/tests/itrontests/itrontask04/Makefile.am (modified) * c/src/tests/itrontests/itrontask04/system.h (modified) * c/src/tests/itrontests/itrontime01/Makefile.am (modified) * c/src/tests/itrontests/itrontime01/itrontime01.scn (modified) * c/src/tests/itrontests/itrontime01/system.h (modified) * c/src/tests/libtests/cpuuse/Makefile.am (modified) * c/src/tests/libtests/cpuuse/cpuuse.scn (modified) * c/src/tests/libtests/cpuuse/system.h (modified) * c/src/tests/libtests/cpuuse/task2.c (modified) * c/src/tests/libtests/cpuuse/tswitch.c (modified) * c/src/tests/libtests/malloctest/Makefile.am (modified) * c/src/tests/libtests/malloctest/malloctest.scn (modified) * c/src/tests/libtests/malloctest/system.h (modified) * c/src/tests/libtests/monitor/Makefile.am (modified) * c/src/tests/libtests/monitor/system.h (modified) * c/src/tests/libtests/putenvtest/Makefile.am (modified) * c/src/tests/libtests/putenvtest/init.c (modified) * c/src/tests/libtests/rtems++/Makefile.am (modified) * c/src/tests/libtests/rtems++/System.h (modified) * c/src/tests/libtests/rtmonuse/Makefile.am (modified) * c/src/tests/libtests/rtmonuse/system.h (modified) * c/src/tests/libtests/stackchk/Makefile.am (modified) * c/src/tests/libtests/stackchk/system.h (modified) * c/src/tests/libtests/termios/Makefile.am (modified) * c/src/tests/libtests/termios/README (modified) * c/src/tests/libtests/termios/init.c (modified) * c/src/tests/mptests/mp01/node1/Makefile.am (modified) * c/src/tests/mptests/mp01/node2/Makefile.am (modified) * c/src/tests/mptests/mp01/system.h (modified) * c/src/tests/mptests/mp02/node1/Makefile.am (modified) * c/src/tests/mptests/mp02/node2/Makefile.am (modified) * c/src/tests/mptests/mp02/system.h (modified) * c/src/tests/mptests/mp03/node1/Makefile.am (modified) * c/src/tests/mptests/mp03/node2/Makefile.am (modified) * c/src/tests/mptests/mp03/system.h (modified) * c/src/tests/mptests/mp04/node1/Makefile.am (modified) * c/src/tests/mptests/mp04/node2/Makefile.am (modified) * c/src/tests/mptests/mp04/system.h (modified) * c/src/tests/mptests/mp05/node1/Makefile.am (modified) * c/src/tests/mptests/mp05/node2/Makefile.am (modified) * c/src/tests/mptests/mp05/system.h (modified) * c/src/tests/mptests/mp06/node1/Makefile.am (modified) * c/src/tests/mptests/mp06/node2/Makefile.am (modified) * c/src/tests/mptests/mp06/system.h (modified) * c/src/tests/mptests/mp07/node1/Makefile.am (modified) * c/src/tests/mptests/mp07/node2/Makefile.am (modified) * c/src/tests/mptests/mp07/system.h (modified) * c/src/tests/mptests/mp08/node1/Makefile.am (modified) * c/src/tests/mptests/mp08/node2/Makefile.am (modified) * c/src/tests/mptests/mp08/system.h (modified) * c/src/tests/mptests/mp09/node1/Makefile.am (modified) * c/src/tests/mptests/mp09/node2/Makefile.am (modified) * c/src/tests/mptests/mp09/system.h (modified) * c/src/tests/mptests/mp10/node1/Makefile.am (modified) * c/src/tests/mptests/mp10/node2/Makefile.am (modified) * c/src/tests/mptests/mp10/system.h (modified) * c/src/tests/mptests/mp11/node1/Makefile.am (modified) * c/src/tests/mptests/mp11/node2/Makefile.am (modified) * c/src/tests/mptests/mp11/system.h (modified) * c/src/tests/mptests/mp12/node1/Makefile.am (modified) * c/src/tests/mptests/mp12/node2/Makefile.am (modified) * c/src/tests/mptests/mp12/system.h (modified) * c/src/tests/mptests/mp13/node1/Makefile.am (modified) * c/src/tests/mptests/mp13/node2/Makefile.am (modified) * c/src/tests/mptests/mp13/system.h (modified) * c/src/tests/mptests/mp14/Makefile.am (modified) * c/src/tests/mptests/mp14/node1/Makefile.am (modified) * c/src/tests/mptests/mp14/node2/Makefile.am (modified) * c/src/tests/mptests/mp14/system.h (modified) * c/src/tests/psxtests/Makefile.am (modified) * c/src/tests/psxtests/psx01/Makefile.am (modified) * c/src/tests/psxtests/psx01/psx01.scn (modified) * c/src/tests/psxtests/psx01/system.h (modified) * c/src/tests/psxtests/psx02/Makefile.am (modified) * c/src/tests/psxtests/psx02/system.h (modified) * c/src/tests/psxtests/psx03/Makefile.am (modified) * c/src/tests/psxtests/psx03/system.h (modified) * c/src/tests/psxtests/psx04/Makefile.am (modified) * c/src/tests/psxtests/psx04/system.h (modified) * c/src/tests/psxtests/psx05/Makefile.am (modified) * c/src/tests/psxtests/psx05/system.h (modified) * c/src/tests/psxtests/psx06/Makefile.am (modified) * c/src/tests/psxtests/psx06/system.h (modified) * c/src/tests/psxtests/psx07/Makefile.am (modified) * c/src/tests/psxtests/psx07/system.h (modified) * c/src/tests/psxtests/psx08/Makefile.am (modified) * c/src/tests/psxtests/psx08/system.h (modified) * c/src/tests/psxtests/psx09/Makefile.am (modified) * c/src/tests/psxtests/psx09/system.h (modified) * c/src/tests/psxtests/psx10/Makefile.am (modified) * c/src/tests/psxtests/psx10/system.h (modified) * c/src/tests/psxtests/psx11/Makefile.am (modified) * c/src/tests/psxtests/psx11/system.h (modified) * c/src/tests/psxtests/psx12/Makefile.am (modified) * c/src/tests/psxtests/psx12/system.h (modified) * c/src/tests/psxtests/psx13/Makefile.am (modified) * c/src/tests/psxtests/psx13/main.c (modified) * c/src/tests/psxtests/psxcancel/Makefile.am (modified) * c/src/tests/psxtests/psxcancel/system.h (modified) * c/src/tests/psxtests/psxfile01/Makefile.am (modified) * c/src/tests/psxtests/psxfile01/main.c (modified) * c/src/tests/psxtests/psxfile01/psxfile01.scn (modified) * c/src/tests/psxtests/psxfile01/test.c (modified) * c/src/tests/psxtests/psxhdrs/Makefile.am (modified) * c/src/tests/psxtests/psxmount/Makefile.am (modified) * c/src/tests/psxtests/psxmount/main.c (modified) * c/src/tests/psxtests/psxmsgq01/Makefile.am (modified) * c/src/tests/psxtests/psxmsgq01/system.h (modified) * c/src/tests/psxtests/psxreaddir/Makefile.am (modified) * c/src/tests/psxtests/psxreaddir/main.c (modified) * c/src/tests/psxtests/psxsem01/Makefile.am (modified) * c/src/tests/psxtests/psxsem01/system.h (modified) * c/src/tests/psxtests/psxstat/Makefile.am (modified) * c/src/tests/psxtests/psxstat/main.c (modified) * c/src/tests/psxtests/psxstat/test.c (modified) * c/src/tests/psxtests/psxtime/Makefile.am (modified) * c/src/tests/psxtests/psxtime/main.c (modified) * c/src/tests/psxtests/psxtimer/Makefile.am (modified) * c/src/tests/psxtests/psxtimer/system.h (modified) * c/src/tests/samples/Makefile.am (modified) * c/src/tests/samples/base_mp/apptask.c (modified) * c/src/tests/samples/base_mp/init.c (modified) * c/src/tests/samples/base_mp/system.h (modified) * c/src/tests/samples/base_sp/apptask.c (modified) * c/src/tests/samples/base_sp/init.c (modified) * c/src/tests/samples/base_sp/system.h (modified) * c/src/tests/samples/cdtest/Makefile.am (modified) * c/src/tests/samples/cdtest/init.c (modified) * c/src/tests/samples/cdtest/system.h (modified) * c/src/tests/samples/hello/Makefile.am (modified) * c/src/tests/samples/hello/init.c (modified) * c/src/tests/samples/hello/system.h (modified) * c/src/tests/samples/minimum/Makefile.am (modified) * c/src/tests/samples/minimum/init.c (modified) * c/src/tests/samples/paranoia/Makefile.am (modified) * c/src/tests/samples/paranoia/init.c (modified) * c/src/tests/samples/paranoia/system.h (modified) * c/src/tests/samples/ticker/Makefile.am (modified) * c/src/tests/samples/ticker/init.c (modified) * c/src/tests/samples/ticker/system.h (modified) * c/src/tests/samples/ticker/tasks.c (modified) * c/src/tests/samples/unlimited/Makefile.am (modified) * c/src/tests/samples/unlimited/init.c (modified) * c/src/tests/samples/unlimited/system.h (modified) * c/src/tests/sptests/sp01/Makefile.am (modified) * c/src/tests/sptests/sp01/system.h (modified) * c/src/tests/sptests/sp02/Makefile.am (modified) * c/src/tests/sptests/sp02/system.h (modified) * c/src/tests/sptests/sp03/Makefile.am (modified) * c/src/tests/sptests/sp03/system.h (modified) * c/src/tests/sptests/sp04/Makefile.am (modified) * c/src/tests/sptests/sp04/system.h (modified) * c/src/tests/sptests/sp04/tswitch.c (modified) * c/src/tests/sptests/sp05/Makefile.am (modified) * c/src/tests/sptests/sp05/system.h (modified) * c/src/tests/sptests/sp06/Makefile.am (modified) * c/src/tests/sptests/sp06/system.h (modified) * c/src/tests/sptests/sp07/Makefile.am (modified) * c/src/tests/sptests/sp07/system.h (modified) * c/src/tests/sptests/sp08/Makefile.am (modified) * c/src/tests/sptests/sp08/system.h (modified) * c/src/tests/sptests/sp09/Makefile.am (modified) * c/src/tests/sptests/sp09/screen07.c (modified) * c/src/tests/sptests/sp09/screen08.c (modified) * c/src/tests/sptests/sp09/system.h (modified) * c/src/tests/sptests/sp11/Makefile.am (modified) * c/src/tests/sptests/sp11/system.h (modified) * c/src/tests/sptests/sp12/Makefile.am (modified) * c/src/tests/sptests/sp12/system.h (modified) * c/src/tests/sptests/sp13/Makefile.am (modified) * c/src/tests/sptests/sp13/fillbuff.c (modified) * c/src/tests/sptests/sp13/init.c (modified) * c/src/tests/sptests/sp13/putbuff.c (modified) * c/src/tests/sptests/sp13/system.h (modified) * c/src/tests/sptests/sp13/task1.c (modified) * c/src/tests/sptests/sp13/task2.c (modified) * c/src/tests/sptests/sp14/Makefile.am (modified) * c/src/tests/sptests/sp14/system.h (modified) * c/src/tests/sptests/sp15/Makefile.am (modified) * c/src/tests/sptests/sp15/system.h (modified) * c/src/tests/sptests/sp16/Makefile.am (modified) * c/src/tests/sptests/sp16/system.h (modified) * c/src/tests/sptests/sp17/Makefile.am (modified) * c/src/tests/sptests/sp17/system.h (modified) * c/src/tests/sptests/sp19/Makefile.am (modified) * c/src/tests/sptests/sp19/system.h (modified) * c/src/tests/sptests/sp20/Makefile.am (modified) * c/src/tests/sptests/sp20/system.h (modified) * c/src/tests/sptests/sp21/Makefile.am (modified) * c/src/tests/sptests/sp21/system.h (modified) * c/src/tests/sptests/sp22/Makefile.am (modified) * c/src/tests/sptests/sp22/system.h (modified) * c/src/tests/sptests/sp23/Makefile.am (modified) * c/src/tests/sptests/sp23/system.h (modified) * c/src/tests/sptests/sp24/Makefile.am (modified) * c/src/tests/sptests/sp24/system.h (modified) * c/src/tests/sptests/sp25/Makefile.am (modified) * c/src/tests/sptests/sp25/sp25.scn (modified) * c/src/tests/sptests/sp25/system.h (modified) * c/src/tests/sptests/sp26/Makefile.am (modified) * c/src/tests/sptests/sp26/system.h (modified) * c/src/tests/sptests/sp27/Makefile.am (modified) * c/src/tests/sptests/sp27/init.c (modified) * c/src/tests/sptests/sp28/Makefile.am (modified) * c/src/tests/sptests/sp28/init.c (modified) * c/src/tests/sptests/sp29/Makefile.am (modified) * c/src/tests/sptests/sp29/init.c (modified) * c/src/tests/sptests/spfatal/Makefile.am (modified) * c/src/tests/sptests/spfatal/system.h (modified) * c/src/tests/sptests/spsize/Makefile.am (modified) * c/src/tests/sptests/spsize/system.h (modified) * c/src/tests/support/include/Makefile.am (modified) * c/src/tests/support/stubdr/Makefile.am (modified) * c/src/tests/support/wrapup/Makefile.am (modified) * c/src/tests/tmitrontests/tmitronsem01/Makefile.am (modified) * c/src/tests/tmitrontests/tmitronsem01/system.h (modified) * c/src/tests/tmtests/Makefile.am (modified) * c/src/tests/tmtests/tm01/Makefile.am (modified) * c/src/tests/tmtests/tm01/system.h (modified) * c/src/tests/tmtests/tm02/Makefile.am (modified) * c/src/tests/tmtests/tm02/system.h (modified) * c/src/tests/tmtests/tm03/Makefile.am (modified) * c/src/tests/tmtests/tm03/system.h (modified) * c/src/tests/tmtests/tm04/Makefile.am (modified) * c/src/tests/tmtests/tm04/system.h (modified) * c/src/tests/tmtests/tm05/Makefile.am (modified) * c/src/tests/tmtests/tm05/system.h (modified) * c/src/tests/tmtests/tm06/Makefile.am (modified) * c/src/tests/tmtests/tm06/system.h (modified) * c/src/tests/tmtests/tm07/Makefile.am (modified) * c/src/tests/tmtests/tm07/system.h (modified) * c/src/tests/tmtests/tm08/Makefile.am (modified) * c/src/tests/tmtests/tm08/system.h (modified) * c/src/tests/tmtests/tm09/Makefile.am (modified) * c/src/tests/tmtests/tm09/system.h (modified) * c/src/tests/tmtests/tm09/task1.c (modified) * c/src/tests/tmtests/tm10/Makefile.am (modified) * c/src/tests/tmtests/tm10/system.h (modified) * c/src/tests/tmtests/tm11/Makefile.am (modified) * c/src/tests/tmtests/tm11/system.h (modified) * c/src/tests/tmtests/tm11/task1.c (modified) * c/src/tests/tmtests/tm12/Makefile.am (modified) * c/src/tests/tmtests/tm12/system.h (modified) * c/src/tests/tmtests/tm12/task1.c (modified) * c/src/tests/tmtests/tm13/Makefile.am (modified) * c/src/tests/tmtests/tm13/system.h (modified) * c/src/tests/tmtests/tm13/task1.c (modified) * c/src/tests/tmtests/tm14/Makefile.am (modified) * c/src/tests/tmtests/tm14/system.h (modified) * c/src/tests/tmtests/tm14/task1.c (modified) * c/src/tests/tmtests/tm15/Makefile.am (modified) * c/src/tests/tmtests/tm15/system.h (modified) * c/src/tests/tmtests/tm16/Makefile.am (modified) * c/src/tests/tmtests/tm16/system.h (modified) * c/src/tests/tmtests/tm17/Makefile.am (modified) * c/src/tests/tmtests/tm17/system.h (modified) * c/src/tests/tmtests/tm18/Makefile.am (modified) * c/src/tests/tmtests/tm18/system.h (modified) * c/src/tests/tmtests/tm19/Makefile.am (modified) * c/src/tests/tmtests/tm19/system.h (modified) * c/src/tests/tmtests/tm20/Makefile.am (modified) * c/src/tests/tmtests/tm20/system.h (modified) * c/src/tests/tmtests/tm21/Makefile.am (modified) * c/src/tests/tmtests/tm21/system.h (modified) * c/src/tests/tmtests/tm21/task1.c (modified) * c/src/tests/tmtests/tm22/Makefile.am (modified) * c/src/tests/tmtests/tm22/system.h (modified) * c/src/tests/tmtests/tm22/task1.c (modified) * c/src/tests/tmtests/tm23/Makefile.am (modified) * c/src/tests/tmtests/tm23/system.h (modified) * c/src/tests/tmtests/tm24/Makefile.am (modified) * c/src/tests/tmtests/tm24/system.h (modified) * c/src/tests/tmtests/tm25/Makefile.am (modified) * c/src/tests/tmtests/tm25/system.h (modified) * c/src/tests/tmtests/tm26/Makefile.am (modified) * c/src/tests/tmtests/tm26/system.h (modified) * c/src/tests/tmtests/tm27/Makefile.am (modified) * c/src/tests/tmtests/tm27/system.h (modified) * c/src/tests/tmtests/tm28/Makefile.am (modified) * c/src/tests/tmtests/tm28/system.h (modified) * c/src/tests/tmtests/tm29/Makefile.am (modified) * c/src/tests/tmtests/tm29/system.h (modified) * c/src/tests/tmtests/tmck/Makefile.am (modified) * c/src/tests/tmtests/tmck/system.h (modified) * c/src/tests/tmtests/tmoverhd/Makefile.am (modified) * c/src/tests/tmtests/tmoverhd/system.h (modified) * c/src/tests/tools/Makefile.am (modified) * c/src/tests/tools/generic/Makefile.am (modified) * c/src/wrapup/Makefile.am (modified) * configure.in (modified) * cpukit/ftpd/Makefile.am (modified) * cpukit/ftpd/ftpd.c (modified) * cpukit/httpd/Makefile.am (modified) * cpukit/httpd/balloc.c (modified) * cpukit/httpd/ejlex.c (modified) * cpukit/httpd/handler.c (modified) * cpukit/httpd/uemf.c (modified) * cpukit/httpd/uemf.h (modified) * cpukit/httpd/webs.c (modified) * cpukit/itron/include/Makefile.am (modified) * cpukit/itron/src/Makefile.am (modified) * cpukit/itron/src/cre_tsk.c (modified) * cpukit/itron/src/eventflags.c (modified) * cpukit/itron/src/fmempool.c (modified) * cpukit/itron/src/itronsem.c (modified) * cpukit/itron/src/mbox.c (modified) * cpukit/itron/src/msgbuffer.c (modified) * cpukit/itron/src/port.c (modified) * cpukit/itron/src/vmempool.c (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/console.h (modified) * cpukit/libcsupport/include/rtems/error.h (modified) * cpukit/libcsupport/include/sys/termios.h (modified) * cpukit/libcsupport/src/gxx_wrappers.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/scandir.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libcsupport/src/termiosreserveresources.c (modified) * cpukit/libcsupport/src/unmount.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_stat.c (modified) * cpukit/libfs/src/imfs/imfs_utime.c (modified) * cpukit/libmisc/cpuuse/Makefile.am (modified) * cpukit/libmisc/dummy/Makefile.am (modified) * cpukit/libmisc/dummy/dummy.c (modified) * cpukit/libmisc/dumpbuf/Makefile.am (modified) * cpukit/libmisc/monitor/Makefile.am (modified) * cpukit/libmisc/monitor/mon-server.c (modified) * cpukit/libmisc/rtmonuse/Makefile.am (modified) * cpukit/libmisc/stackchk/Makefile.am (modified) * cpukit/libmisc/stackchk/internal.h (modified) * cpukit/libmisc/untar/Makefile.am (modified) * cpukit/libmisc/wrapup/Makefile.am (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/arpa/Makefile.am (modified) * cpukit/libnetworking/kern/Makefile.am (modified) * cpukit/libnetworking/lib/Makefile.am (modified) * cpukit/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * cpukit/libnetworking/libc/Makefile.am (modified) * cpukit/libnetworking/machine/Makefile.am (modified) * cpukit/libnetworking/memory.h (modified) * cpukit/libnetworking/net/Makefile.am (modified) * cpukit/libnetworking/net/if_loop.c (modified) * cpukit/libnetworking/netinet/Makefile.am (modified) * cpukit/libnetworking/netinet/in.h (modified) * cpukit/libnetworking/nfs/Makefile.am (modified) * cpukit/libnetworking/rtems/Makefile.am (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libnetworking/sys/Makefile.am (modified) * cpukit/libnetworking/sys/un.h (modified) * cpukit/libnetworking/vm/Makefile.am (modified) * cpukit/libnetworking/wrapup/Makefile.am (modified) * cpukit/librpc/Makefile.am (modified) * cpukit/librpc/README_RTEMS (modified) * cpukit/librpc/include/Makefile.am (modified) * cpukit/librpc/include/rpc/Makefile.am (modified) * cpukit/librpc/include/rpc/auth.h (modified) * cpukit/librpc/include/rpc/auth_des.h (modified) * cpukit/librpc/include/rpc/auth_unix.h (modified) * cpukit/librpc/include/rpc/clnt.h (modified) * cpukit/librpc/include/rpc/des.h (modified) * cpukit/librpc/include/rpc/des_crypt.h (modified) * cpukit/librpc/include/rpc/pmap_clnt.h (modified) * cpukit/librpc/include/rpc/pmap_prot.h (modified) * cpukit/librpc/include/rpc/pmap_rmt.h (modified) * cpukit/librpc/include/rpc/rpc.h (modified) * cpukit/librpc/include/rpc/rpc_com.h (modified) * cpukit/librpc/include/rpc/rpc_msg.h (modified) * cpukit/librpc/include/rpc/svc.h (modified) * cpukit/librpc/include/rpc/svc_auth.h (modified) * cpukit/librpc/include/rpc/types.h (modified) * cpukit/librpc/include/rpc/xdr.h (modified) * cpukit/librpc/include/rpcsvc/.cvsignore (modified) * cpukit/librpc/include/rpcsvc/Makefile.am (modified) * cpukit/librpc/include/rpcsvc/bootparam_prot.x (modified) * cpukit/librpc/include/rpcsvc/crypt.x (modified) * cpukit/librpc/include/rpcsvc/key_prot.x (modified) * cpukit/librpc/include/rpcsvc/klm_prot.x (modified) * cpukit/librpc/include/rpcsvc/mount.x (modified) * cpukit/librpc/include/rpcsvc/nfs_prot.x (modified) * cpukit/librpc/include/rpcsvc/nis.x (modified) * cpukit/librpc/include/rpcsvc/nis_cache.x (modified) * cpukit/librpc/include/rpcsvc/nis_callback.x (modified) * cpukit/librpc/include/rpcsvc/nis_db.h (modified) * cpukit/librpc/include/rpcsvc/nis_object.x (modified) * cpukit/librpc/include/rpcsvc/nis_tags.h (modified) * cpukit/librpc/include/rpcsvc/nislib.h (modified) * cpukit/librpc/include/rpcsvc/nlm_prot.x (modified) * cpukit/librpc/include/rpcsvc/pmap_prot.x (modified) * cpukit/librpc/include/rpcsvc/rex.x (modified) * cpukit/librpc/include/rpcsvc/rnusers.x (modified) * cpukit/librpc/include/rpcsvc/rquota.x (modified) * cpukit/librpc/include/rpcsvc/rstat.x (modified) * cpukit/librpc/include/rpcsvc/rwall.x (modified) * cpukit/librpc/include/rpcsvc/sm_inter.x (modified) * cpukit/librpc/include/rpcsvc/spray.x (modified) * cpukit/librpc/include/rpcsvc/yp.x (modified) * cpukit/librpc/include/rpcsvc/yp_prot.h (modified) * cpukit/librpc/include/rpcsvc/ypclnt.h (modified) * cpukit/librpc/include/rpcsvc/yppasswd.x (modified) * cpukit/librpc/include/rpcsvc/ypupdate_prot.x (modified) * cpukit/librpc/include/rpcsvc/ypxfrd.x (modified) * cpukit/librpc/src/Makefile.am (modified) * cpukit/librpc/src/rpc/DISCLAIMER (modified) * cpukit/librpc/src/rpc/Makefile.am (modified) * cpukit/librpc/src/rpc/PSD.doc/.cvsignore (modified) * cpukit/librpc/src/rpc/PSD.doc/Makefile.am (modified) * cpukit/librpc/src/rpc/PSD.doc/nfs.rfc.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/rpc.prog.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/rpc.rfc.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/rpcgen.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/xdr.nts.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/xdr.rfc.ms (modified) * cpukit/librpc/src/rpc/README (modified) * cpukit/librpc/src/rpc/auth_des.c (modified) * cpukit/librpc/src/rpc/auth_none.c (modified) * cpukit/librpc/src/rpc/auth_time.c (modified) * cpukit/librpc/src/rpc/auth_unix.c (modified) * cpukit/librpc/src/rpc/authdes_prot.c (modified) * cpukit/librpc/src/rpc/authunix_prot.c (modified) * cpukit/librpc/src/rpc/bindresvport.3 (modified) * cpukit/librpc/src/rpc/bindresvport.c (modified) * cpukit/librpc/src/rpc/clnt_generic.c (modified) * cpukit/librpc/src/rpc/clnt_perror.c (modified) * cpukit/librpc/src/rpc/clnt_raw.c (modified) * cpukit/librpc/src/rpc/clnt_simple.c (modified) * cpukit/librpc/src/rpc/clnt_tcp.c (modified) * cpukit/librpc/src/rpc/clnt_udp.c (modified) * cpukit/librpc/src/rpc/clnt_unix.c (modified) * cpukit/librpc/src/rpc/crypt_client.c (modified) * cpukit/librpc/src/rpc/des_crypt.3 (modified) * cpukit/librpc/src/rpc/des_crypt.c (modified) * cpukit/librpc/src/rpc/des_soft.c (modified) * cpukit/librpc/src/rpc/get_myaddress.c (modified) * cpukit/librpc/src/rpc/getpublickey.c (modified) * cpukit/librpc/src/rpc/getrpcent.3 (modified) * cpukit/librpc/src/rpc/getrpcent.c (modified) * cpukit/librpc/src/rpc/getrpcport.3 (modified) * cpukit/librpc/src/rpc/getrpcport.c (modified) * cpukit/librpc/src/rpc/key_call.c (modified) * cpukit/librpc/src/rpc/key_prot_xdr.c (modified) * cpukit/librpc/src/rpc/netname.c (modified) * cpukit/librpc/src/rpc/netnamer.c (modified) * cpukit/librpc/src/rpc/pmap_clnt.c (modified) * cpukit/librpc/src/rpc/pmap_getmaps.c (modified) * cpukit/librpc/src/rpc/pmap_getport.c (modified) * cpukit/librpc/src/rpc/pmap_prot.c (modified) * cpukit/librpc/src/rpc/pmap_prot2.c (modified) * cpukit/librpc/src/rpc/pmap_rmt.c (modified) * cpukit/librpc/src/rpc/publickey.3 (modified) * cpukit/librpc/src/rpc/publickey.5 (modified) * cpukit/librpc/src/rpc/rpc.3 (modified) * cpukit/librpc/src/rpc/rpc.5 (modified) * cpukit/librpc/src/rpc/rpc_callmsg.c (modified) * cpukit/librpc/src/rpc/rpc_commondata.c (modified) * cpukit/librpc/src/rpc/rpc_dtablesize.c (modified) * cpukit/librpc/src/rpc/rpc_prot.c (modified) * cpukit/librpc/src/rpc/rpc_secure.3 (modified) * cpukit/librpc/src/rpc/rpcdname.c (modified) * cpukit/librpc/src/rpc/rstat.1 (modified) * cpukit/librpc/src/rpc/rstat_svc.8 (modified) * cpukit/librpc/src/rpc/rtems_portmapper.c (modified) * cpukit/librpc/src/rpc/rtems_rpc.c (modified) * cpukit/librpc/src/rpc/rtime.3 (modified) * cpukit/librpc/src/rpc/rtime.c (modified) * cpukit/librpc/src/rpc/svc.c (modified) * cpukit/librpc/src/rpc/svc_auth.c (modified) * cpukit/librpc/src/rpc/svc_auth_des.c (modified) * cpukit/librpc/src/rpc/svc_auth_unix.c (modified) * cpukit/librpc/src/rpc/svc_raw.c (modified) * cpukit/librpc/src/rpc/svc_run.c (modified) * cpukit/librpc/src/rpc/svc_simple.c (modified) * cpukit/librpc/src/rpc/svc_tcp.c (modified) * cpukit/librpc/src/rpc/svc_udp.c (modified) * cpukit/librpc/src/rpc/svc_unix.c (modified) * cpukit/librpc/src/xdr/Makefile.am (modified) * cpukit/librpc/src/xdr/xdr.3 (modified) * cpukit/librpc/src/xdr/xdr.c (modified) * cpukit/librpc/src/xdr/xdr_array.c (modified) * cpukit/librpc/src/xdr/xdr_float.c (modified) * cpukit/librpc/src/xdr/xdr_mem.c (modified) * cpukit/librpc/src/xdr/xdr_rec.c (modified) * cpukit/librpc/src/xdr/xdr_reference.c (modified) * cpukit/librpc/src/xdr/xdr_sizeof.c (modified) * cpukit/librpc/src/xdr/xdr_stdio.c (modified) * cpukit/posix/include/Makefile.am (modified) * cpukit/posix/inline/rtems/posix/cond.inl (modified) * cpukit/posix/src/Makefile.am (modified) * cpukit/posix/src/mqueuecreatesupp.c (modified) * cpukit/posix/src/mqueuedeletesupp.c (modified) * cpukit/posix/src/mqueueunlink.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) * cpukit/posix/src/waitpid.c (modified) * cpukit/pppd/Makefile.am (modified) * cpukit/pppd/options.c (modified) * cpukit/pppd/pppd.h (modified) * cpukit/rtems/include/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/rtemsapi.h (modified) * cpukit/rtems/src/Makefile.am (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/taskvariableadd.c (modified) * cpukit/rtems/src/taskvariabledelete.c (modified) * cpukit/rtems/src/taskvariableget.c (modified) * cpukit/sapi/include/Makefile.am (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/README (modified) * cpukit/sapi/src/Makefile.am (modified) * cpukit/score/cpu/a29k/Makefile.am (modified) * cpukit/score/cpu/a29k/rtems/score/a29k.h (modified) * cpukit/score/cpu/hppa1.1/Makefile.am (modified) * cpukit/score/cpu/hppa1.1/rtems/score/hppa.h (modified) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/i386/rtems/score/i386.h (modified) * cpukit/score/cpu/i960/Makefile.am (modified) * cpukit/score/cpu/i960/rtems/score/i960.h (modified) * cpukit/score/cpu/m68k/Makefile.am (modified) * cpukit/score/cpu/m68k/qsm.h (modified) * cpukit/score/cpu/m68k/rtems/m68k/qsm.h (modified) * cpukit/score/cpu/m68k/rtems/m68k/sim.h (modified) * cpukit/score/cpu/m68k/rtems/score/m68k.h (modified) * cpukit/score/cpu/m68k/sim.h (modified) * cpukit/score/cpu/mips/Makefile.am (modified) * cpukit/score/cpu/mips/rtems/score/mips.h (modified) * cpukit/score/cpu/mips64orion/Makefile.am (modified) * cpukit/score/cpu/mips64orion/rtems/score/mips64orion.h (modified) * cpukit/score/cpu/no_cpu/Makefile.am (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/no_cpu.h (modified) * cpukit/score/cpu/powerpc/Makefile.am (modified) * cpukit/score/cpu/powerpc/rtems/score/ppc.h (modified) * cpukit/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/sh/rtems/score/sh.h (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) * cpukit/score/cpu/unix/Makefile.am (modified) * cpukit/score/cpu/unix/cpu.c (modified) * cpukit/score/cpu/unix/rtems/score/cpu.h (modified) * cpukit/score/cpu/unix/rtems/score/unix.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/system.h (modified) * cpukit/score/macros/rtems/score/address.inl (modified) * cpukit/score/src/Makefile.am (modified) * cpukit/score/src/objectcopynamestring.c (modified) * make/Makefile.am (modified) * make/README (modified) * make/Templates/Makefile.am (modified) * make/Templates/Makefile.dir (modified) * make/Templates/Makefile.leaf (modified) * make/Templates/Makefile.lib (modified) * make/compilers/Makefile.am (modified) * make/compilers/gcc-no_bsp.cfg (modified) * make/compilers/gcc-portsw.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Makefile.am (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/dmv177.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/eth_comm.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gen68340.cfg (modified) * make/custom/gen68360.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/gensh2.cfg (modified) * make/custom/helas403.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mcp750.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/mvme167.cfg (modified) * make/custom/mvme2307.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/pc386.cfg (modified) * make/custom/ppcn_60x.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/rxgen960.cfg (modified) * make/custom/score603e.cfg (modified) * make/custom/simhppa.cfg (modified) * make/custom/ts_386ex.cfg (modified) * make/host.cfg.in (modified) * make/leaf.cfg (modified) * make/main.cfg (modified) * scripts-ada/.cvsignore (modified) * scripts-ada/Makefile.am (modified) * scripts-ada/binutils/.cvsignore (modified) * scripts-ada/binutils/Makefile.am (modified) * scripts-ada/binutils/binutils.spec.in (modified) * scripts-ada/buildall.in (modified) * scripts-ada/configure.in (modified) * scripts-ada/gdb/.cvsignore (modified) * scripts-ada/gdb/Makefile.am (modified) * scripts-ada/gdb/gdb.spec.in (modified) * scripts-ada/gnatnewlib/.cvsignore (modified) * scripts-ada/gnatnewlib/Makefile.am (modified) * scripts-ada/gnatnewlib/gnatnewlib.spec.in (modified) * scripts-ada/mkbinutilspec.in (modified) * scripts-ada/mkgdbspec.in (modified) * scripts-ada/mkgnatnewlibspec.in (modified) * scripts-ada/setup.def (modified) * scripts/Makefile.am (modified) * scripts/binutils/.cvsignore (modified) * scripts/binutils/Makefile.am (modified) * scripts/binutils/base-binutils.add (modified) * scripts/binutils/binutils.add (modified) * scripts/binutils/target-binutils.add (modified) * scripts/buildall.in (modified) * scripts/configure.in (modified) * scripts/gccnewlib/.cvsignore (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gccnewlib/README (added) * scripts/gccnewlib/base-chill.add (modified) * scripts/gccnewlib/base-g77.add (modified) * scripts/gccnewlib/base-gcc.add (modified) * scripts/gccnewlib/base-gcj.add (modified) * scripts/gccnewlib/gccnewlib.add (modified) * scripts/gccnewlib/target-chill.add (modified) * scripts/gccnewlib/target-g77.add (modified) * scripts/gccnewlib/target-gcc.add (modified) * scripts/gccnewlib/target-gcj.add (modified) * scripts/gccnewlib/target-objc.add (modified) * scripts/gdb/.cvsignore (modified) * scripts/gdb/Makefile.am (modified) * scripts/gdb/base-gdb.add (modified) * scripts/gdb/gdb.add (modified) * scripts/gdb/target-gdb.add (modified) * scripts/rtems/.cvsignore (modified) * scripts/rtems/Makefile.am (modified) * scripts/rtems/rtems.spec.in (modified) * scripts/setup.def (modified) * testsuites/itrontests/itronhello/Makefile.am (modified) * testsuites/itrontests/itronhello/system.h (modified) * testsuites/itrontests/itronmbf01/Makefile.am (modified) * testsuites/itrontests/itronmbf01/system.h (modified) * testsuites/itrontests/itronmbox01/Makefile.am (modified) * testsuites/itrontests/itronmbox01/itronmbox01.scn (modified) * testsuites/itrontests/itronmbox01/system.h (modified) * testsuites/itrontests/itronsem01/Makefile.am (modified) * testsuites/itrontests/itronsem01/init.c (modified) * testsuites/itrontests/itronsem01/system.h (modified) * testsuites/itrontests/itrontask01/Makefile.am (modified) * testsuites/itrontests/itrontask01/system.h (modified) * testsuites/itrontests/itrontask02/Makefile.am (modified) * testsuites/itrontests/itrontask02/system.h (modified) * testsuites/itrontests/itrontask03/Makefile.am (modified) * testsuites/itrontests/itrontask03/system.h (modified) * testsuites/itrontests/itrontask04/Makefile.am (modified) * testsuites/itrontests/itrontask04/system.h (modified) * testsuites/itrontests/itrontime01/Makefile.am (modified) * testsuites/itrontests/itrontime01/itrontime01.scn (modified) * testsuites/itrontests/itrontime01/system.h (modified) * testsuites/libtests/cpuuse/Makefile.am (modified) * testsuites/libtests/cpuuse/cpuuse.scn (modified) * testsuites/libtests/cpuuse/system.h (modified) * testsuites/libtests/cpuuse/task2.c (modified) * testsuites/libtests/cpuuse/tswitch.c (modified) * testsuites/libtests/malloctest/Makefile.am (modified) * testsuites/libtests/malloctest/malloctest.scn (modified) * testsuites/libtests/malloctest/system.h (modified) * testsuites/libtests/monitor/Makefile.am (modified) * testsuites/libtests/monitor/system.h (modified) * testsuites/libtests/putenvtest/Makefile.am (modified) * testsuites/libtests/putenvtest/init.c (modified) * testsuites/libtests/rtems++/Makefile.am (modified) * testsuites/libtests/rtems++/System.h (modified) * testsuites/libtests/rtmonuse/Makefile.am (modified) * testsuites/libtests/rtmonuse/system.h (modified) * testsuites/libtests/stackchk/Makefile.am (modified) * testsuites/libtests/stackchk/system.h (modified) * testsuites/libtests/termios/Makefile.am (modified) * testsuites/libtests/termios/README (modified) * testsuites/libtests/termios/init.c (modified) * testsuites/mptests/mp01/node1/Makefile.am (modified) * testsuites/mptests/mp01/node2/Makefile.am (modified) * testsuites/mptests/mp01/system.h (modified) * testsuites/mptests/mp02/node1/Makefile.am (modified) * testsuites/mptests/mp02/node2/Makefile.am (modified) * testsuites/mptests/mp02/system.h (modified) * testsuites/mptests/mp03/node1/Makefile.am (modified) * testsuites/mptests/mp03/node2/Makefile.am (modified) * testsuites/mptests/mp03/system.h (modified) * testsuites/mptests/mp04/node1/Makefile.am (modified) * testsuites/mptests/mp04/node2/Makefile.am (modified) * testsuites/mptests/mp04/system.h (modified) * testsuites/mptests/mp05/node1/Makefile.am (modified) * testsuites/mptests/mp05/node2/Makefile.am (modified) * testsuites/mptests/mp05/system.h (modified) * testsuites/mptests/mp06/node1/Makefile.am (modified) * testsuites/mptests/mp06/node2/Makefile.am (modified) * testsuites/mptests/mp06/system.h (modified) * testsuites/mptests/mp07/node1/Makefile.am (modified) * testsuites/mptests/mp07/node2/Makefile.am (modified) * testsuites/mptests/mp07/system.h (modified) * testsuites/mptests/mp08/node1/Makefile.am (modified) * testsuites/mptests/mp08/node2/Makefile.am (modified) * testsuites/mptests/mp08/system.h (modified) * testsuites/mptests/mp09/node1/Makefile.am (modified) * testsuites/mptests/mp09/node2/Makefile.am (modified) * testsuites/mptests/mp09/system.h (modified) * testsuites/mptests/mp10/node1/Makefile.am (modified) * testsuites/mptests/mp10/node2/Makefile.am (modified) * testsuites/mptests/mp10/system.h (modified) * testsuites/mptests/mp11/node1/Makefile.am (modified) * testsuites/mptests/mp11/node2/Makefile.am (modified) * testsuites/mptests/mp11/system.h (modified) * testsuites/mptests/mp12/node1/Makefile.am (modified) * testsuites/mptests/mp12/node2/Makefile.am (modified) * testsuites/mptests/mp12/system.h (modified) * testsuites/mptests/mp13/node1/Makefile.am (modified) * testsuites/mptests/mp13/node2/Makefile.am (modified) * testsuites/mptests/mp13/system.h (modified) * testsuites/mptests/mp14/Makefile.am (modified) * testsuites/mptests/mp14/node1/Makefile.am (modified) * testsuites/mptests/mp14/node2/Makefile.am (modified) * testsuites/mptests/mp14/system.h (modified) * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/psx01/Makefile.am (modified) * testsuites/psxtests/psx01/psx01.scn (modified) * testsuites/psxtests/psx01/system.h (modified) * testsuites/psxtests/psx02/Makefile.am (modified) * testsuites/psxtests/psx02/system.h (modified) * testsuites/psxtests/psx03/Makefile.am (modified) * testsuites/psxtests/psx03/system.h (modified) * testsuites/psxtests/psx04/Makefile.am (modified) * testsuites/psxtests/psx04/system.h (modified) * testsuites/psxtests/psx05/Makefile.am (modified) * testsuites/psxtests/psx05/system.h (modified) * testsuites/psxtests/psx06/Makefile.am (modified) * testsuites/psxtests/psx06/system.h (modified) * testsuites/psxtests/psx07/Makefile.am (modified) * testsuites/psxtests/psx07/system.h (modified) * testsuites/psxtests/psx08/Makefile.am (modified) * testsuites/psxtests/psx08/system.h (modified) * testsuites/psxtests/psx09/Makefile.am (modified) * testsuites/psxtests/psx09/system.h (modified) * testsuites/psxtests/psx10/Makefile.am (modified) * testsuites/psxtests/psx10/system.h (modified) * testsuites/psxtests/psx11/Makefile.am (modified) * testsuites/psxtests/psx11/system.h (modified) * testsuites/psxtests/psx12/Makefile.am (modified) * testsuites/psxtests/psx12/system.h (modified) * testsuites/psxtests/psx13/Makefile.am (modified) * testsuites/psxtests/psx13/main.c (modified) * testsuites/psxtests/psxcancel/Makefile.am (modified) * testsuites/psxtests/psxfile01/Makefile.am (modified) * testsuites/psxtests/psxfile01/main.c (modified) * testsuites/psxtests/psxfile01/psxfile01.scn (modified) * testsuites/psxtests/psxfile01/test.c (modified) * testsuites/psxtests/psxhdrs/Makefile.am (modified) * testsuites/psxtests/psxmount/Makefile.am (modified) * testsuites/psxtests/psxmount/main.c (modified) * testsuites/psxtests/psxmsgq01/Makefile.am (modified) * testsuites/psxtests/psxmsgq01/system.h (modified) * testsuites/psxtests/psxreaddir/Makefile.am (modified) * testsuites/psxtests/psxreaddir/main.c (modified) * testsuites/psxtests/psxsem01/Makefile.am (modified) * testsuites/psxtests/psxsem01/system.h (modified) * testsuites/psxtests/psxstat/Makefile.am (modified) * testsuites/psxtests/psxstat/main.c (modified) * testsuites/psxtests/psxstat/test.c (modified) * testsuites/psxtests/psxtime/Makefile.am (modified) * testsuites/psxtests/psxtime/main.c (modified) * testsuites/psxtests/psxtimer/Makefile.am (modified) * testsuites/psxtests/psxtimer/system.h (modified) * testsuites/samples/Makefile.am (modified) * testsuites/samples/base_mp/apptask.c (modified) * testsuites/samples/base_mp/init.c (modified) * testsuites/samples/base_mp/system.h (modified) * testsuites/samples/base_sp/apptask.c (modified) * testsuites/samples/base_sp/init.c (modified) * testsuites/samples/base_sp/system.h (modified) * testsuites/samples/cdtest/Makefile.am (modified) * testsuites/samples/cdtest/init.c (modified) * testsuites/samples/cdtest/system.h (modified) * testsuites/samples/hello/Makefile.am (modified) * testsuites/samples/hello/init.c (modified) * testsuites/samples/hello/system.h (modified) * testsuites/samples/minimum/Makefile.am (modified) * testsuites/samples/minimum/init.c (modified) * testsuites/samples/paranoia/Makefile.am (modified) * testsuites/samples/paranoia/init.c (modified) * testsuites/samples/paranoia/system.h (modified) * testsuites/samples/ticker/Makefile.am (modified) * testsuites/samples/ticker/init.c (modified) * testsuites/samples/ticker/system.h (modified) * testsuites/samples/ticker/tasks.c (modified) * testsuites/samples/unlimited/Makefile.am (modified) * testsuites/samples/unlimited/init.c (modified) * testsuites/samples/unlimited/system.h (modified) * testsuites/sptests/sp01/Makefile.am (modified) * testsuites/sptests/sp01/system.h (modified) * testsuites/sptests/sp02/Makefile.am (modified) * testsuites/sptests/sp02/system.h (modified) * testsuites/sptests/sp03/Makefile.am (modified) * testsuites/sptests/sp03/system.h (modified) * testsuites/sptests/sp04/Makefile.am (modified) * testsuites/sptests/sp04/system.h (modified) * testsuites/sptests/sp04/tswitch.c (modified) * testsuites/sptests/sp05/Makefile.am (modified) * testsuites/sptests/sp05/system.h (modified) * testsuites/sptests/sp06/Makefile.am (modified) * testsuites/sptests/sp06/system.h (modified) * testsuites/sptests/sp07/Makefile.am (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp08/Makefile.am (modified) * testsuites/sptests/sp08/system.h (modified) * testsuites/sptests/sp09/Makefile.am (modified) * testsuites/sptests/sp09/screen07.c (modified) * testsuites/sptests/sp09/screen08.c (modified) * testsuites/sptests/sp09/system.h (modified) * testsuites/sptests/sp11/Makefile.am (modified) * testsuites/sptests/sp11/system.h (modified) * testsuites/sptests/sp12/Makefile.am (modified) * testsuites/sptests/sp12/system.h (modified) * testsuites/sptests/sp13/Makefile.am (modified) * testsuites/sptests/sp13/fillbuff.c (modified) * testsuites/sptests/sp13/init.c (modified) * testsuites/sptests/sp13/putbuff.c (modified) * testsuites/sptests/sp13/system.h (modified) * testsuites/sptests/sp13/task1.c (modified) * testsuites/sptests/sp13/task2.c (modified) * testsuites/sptests/sp14/Makefile.am (modified) * testsuites/sptests/sp14/system.h (modified) * testsuites/sptests/sp15/Makefile.am (modified) * testsuites/sptests/sp15/system.h (modified) * testsuites/sptests/sp16/Makefile.am (modified) * testsuites/sptests/sp16/system.h (modified) * testsuites/sptests/sp17/Makefile.am (modified) * testsuites/sptests/sp17/system.h (modified) * testsuites/sptests/sp19/Makefile.am (modified) * testsuites/sptests/sp19/system.h (modified) * testsuites/sptests/sp20/Makefile.am (modified) * testsuites/sptests/sp20/system.h (modified) * testsuites/sptests/sp21/Makefile.am (modified) * testsuites/sptests/sp21/system.h (modified) * testsuites/sptests/sp22/Makefile.am (modified) * testsuites/sptests/sp22/system.h (modified) * testsuites/sptests/sp23/Makefile.am (modified) * testsuites/sptests/sp23/system.h (modified) * testsuites/sptests/sp24/Makefile.am (modified) * testsuites/sptests/sp24/system.h (modified) * testsuites/sptests/sp25/Makefile.am (modified) * testsuites/sptests/sp25/sp25.scn (modified) * testsuites/sptests/sp25/system.h (modified) * testsuites/sptests/sp26/Makefile.am (modified) * testsuites/sptests/sp26/system.h (modified) * testsuites/sptests/sp27/Makefile.am (modified) * testsuites/sptests/sp27/init.c (modified) * testsuites/sptests/sp28/Makefile.am (modified) * testsuites/sptests/sp28/init.c (modified) * testsuites/sptests/sp29/Makefile.am (modified) * testsuites/sptests/sp29/init.c (modified) * testsuites/sptests/spfatal/Makefile.am (modified) * testsuites/sptests/spfatal/system.h (modified) * testsuites/sptests/spsize/Makefile.am (modified) * testsuites/sptests/spsize/system.h (modified) * testsuites/tmitrontests/tmitronsem01/Makefile.am (modified) * testsuites/tmitrontests/tmitronsem01/system.h (modified) * testsuites/tmtests/Makefile.am (modified) * testsuites/tmtests/tm01/Makefile.am (modified) * testsuites/tmtests/tm01/system.h (modified) * testsuites/tmtests/tm02/Makefile.am (modified) * testsuites/tmtests/tm02/system.h (modified) * testsuites/tmtests/tm03/Makefile.am (modified) * testsuites/tmtests/tm03/system.h (modified) * testsuites/tmtests/tm04/Makefile.am (modified) * testsuites/tmtests/tm04/system.h (modified) * testsuites/tmtests/tm05/Makefile.am (modified) * testsuites/tmtests/tm05/system.h (modified) * testsuites/tmtests/tm06/Makefile.am (modified) * testsuites/tmtests/tm06/system.h (modified) * testsuites/tmtests/tm07/Makefile.am (modified) * testsuites/tmtests/tm07/system.h (modified) * testsuites/tmtests/tm08/Makefile.am (modified) * testsuites/tmtests/tm08/system.h (modified) * testsuites/tmtests/tm09/Makefile.am (modified) * testsuites/tmtests/tm09/system.h (modified) * testsuites/tmtests/tm09/task1.c (modified) * testsuites/tmtests/tm10/Makefile.am (modified) * testsuites/tmtests/tm10/system.h (modified) * testsuites/tmtests/tm11/Makefile.am (modified) * testsuites/tmtests/tm11/system.h (modified) * testsuites/tmtests/tm11/task1.c (modified) * testsuites/tmtests/tm12/Makefile.am (modified) * testsuites/tmtests/tm12/system.h (modified) * testsuites/tmtests/tm12/task1.c (modified) * testsuites/tmtests/tm13/Makefile.am (modified) * testsuites/tmtests/tm13/system.h (modified) * testsuites/tmtests/tm13/task1.c (modified) * testsuites/tmtests/tm14/Makefile.am (modified) * testsuites/tmtests/tm14/system.h (modified) * testsuites/tmtests/tm14/task1.c (modified) * testsuites/tmtests/tm15/Makefile.am (modified) * testsuites/tmtests/tm15/system.h (modified) * testsuites/tmtests/tm16/Makefile.am (modified) * testsuites/tmtests/tm16/system.h (modified) * testsuites/tmtests/tm17/Makefile.am (modified) * testsuites/tmtests/tm17/system.h (modified) * testsuites/tmtests/tm18/Makefile.am (modified) * testsuites/tmtests/tm18/system.h (modified) * testsuites/tmtests/tm19/Makefile.am (modified) * testsuites/tmtests/tm19/system.h (modified) * testsuites/tmtests/tm20/Makefile.am (modified) * testsuites/tmtests/tm20/system.h (modified) * testsuites/tmtests/tm21/Makefile.am (modified) * testsuites/tmtests/tm21/system.h (modified) * testsuites/tmtests/tm21/task1.c (modified) * testsuites/tmtests/tm22/Makefile.am (modified) * testsuites/tmtests/tm22/system.h (modified) * testsuites/tmtests/tm22/task1.c (modified) * testsuites/tmtests/tm23/Makefile.am (modified) * testsuites/tmtests/tm23/system.h (modified) * testsuites/tmtests/tm24/Makefile.am (modified) * testsuites/tmtests/tm24/system.h (modified) * testsuites/tmtests/tm25/Makefile.am (modified) * testsuites/tmtests/tm25/system.h (modified) * testsuites/tmtests/tm26/Makefile.am (modified) * testsuites/tmtests/tm26/system.h (modified) * testsuites/tmtests/tm27/Makefile.am (modified) * testsuites/tmtests/tm27/system.h (modified) * testsuites/tmtests/tm28/Makefile.am (modified) * testsuites/tmtests/tm28/system.h (modified) * testsuites/tmtests/tm29/Makefile.am (modified) * testsuites/tmtests/tm29/system.h (modified) * testsuites/tmtests/tmck/Makefile.am (modified) * testsuites/tmtests/tmck/system.h (modified) * testsuites/tmtests/tmoverhd/Makefile.am (modified) * testsuites/tmtests/tmoverhd/system.h (modified) * testsuites/tools/Makefile.am (modified) * testsuites/tools/generic/Makefile.am (modified) * tools/Makefile.am (modified) * tools/build/Makefile.am (modified) * tools/cpu/Makefile.am (modified) * tools/cpu/generic/Makefile.am (modified) * tools/cpu/generic/size_rtems.in (modified) * tools/cpu/hppa1.1/Makefile.am (modified) * tools/cpu/sh/Makefile.am (modified) * tools/cpu/sh/configure.in (modified) * tools/cpu/sh/shgen.c (modified) * tools/cpu/unix/Makefile.am (modified) * tools/cpu/unix/gensize.c (modified) * tools/update/Makefile.am (modified) * tools/update/acpolish (modified) * tools/update/ampolish (modified) * tools/update/cipolish (modified) * tools/update/rtems-polish.sh (modified) Merged from 4.5.0-beta3a Thu, 13 Apr 2000 14:37:14 GMT Joel Sherrill [bf85b19] * c/.cvsignore (added) * c/make/.cvsignore (added) * c/src/.cvsignore (added) * c/src/exec/itron/.cvsignore (added) * c/src/exec/itron/include/.cvsignore (added) * c/src/exec/itron/include/itronsys/.cvsignore (added) * c/src/exec/itron/include/rtems/.cvsignore (added) * c/src/exec/itron/include/rtems/itron/.cvsignore (added) * c/src/exec/itron/inline/.cvsignore (added) * c/src/exec/itron/inline/rtems/.cvsignore (added) * c/src/exec/itron/inline/rtems/itron/.cvsignore (added) * c/src/exec/itron/src/.cvsignore (added) * c/src/exec/libcsupport/.cvsignore (added) * c/src/exec/libnetworking/.cvsignore (added) * c/src/exec/libnetworking/arpa/.cvsignore (added) * c/src/exec/libnetworking/kern/.cvsignore (added) * c/src/exec/libnetworking/lib/.cvsignore (added) * c/src/exec/libnetworking/libc/.cvsignore (added) * c/src/exec/libnetworking/machine/.cvsignore (added) * c/src/exec/libnetworking/net/.cvsignore (added) * c/src/exec/libnetworking/netinet/.cvsignore (added) * c/src/exec/libnetworking/nfs/.cvsignore (added) * c/src/exec/libnetworking/rtems/.cvsignore (added) * c/src/exec/libnetworking/sys/.cvsignore (added) * c/src/exec/libnetworking/vm/.cvsignore (added) * c/src/exec/libnetworking/wrapup/.cvsignore (added) * c/src/exec/librpc/.cvsignore (added) * c/src/exec/librpc/include/.cvsignore (added) * c/src/exec/librpc/include/rpc/.cvsignore (added) * c/src/exec/librpc/src/.cvsignore (added) * c/src/exec/posix/.cvsignore (added) * c/src/exec/posix/include/.cvsignore (added) * c/src/exec/posix/include/rtems/.cvsignore (added) * c/src/exec/posix/include/rtems/posix/.cvsignore (added) * c/src/exec/posix/include/sys/.cvsignore (added) * c/src/exec/posix/inline/.cvsignore (added) * c/src/exec/posix/inline/rtems/.cvsignore (added) * c/src/exec/posix/inline/rtems/posix/.cvsignore (added) * c/src/exec/posix/macros/.cvsignore (added) * c/src/exec/posix/macros/rtems/.cvsignore (added) * c/src/exec/posix/macros/rtems/posix/.cvsignore (added) * c/src/exec/posix/optman/.cvsignore (added) * c/src/exec/posix/src/.cvsignore (added) * c/src/exec/rtems/.cvsignore (added) * c/src/exec/rtems/include/.cvsignore (added) * c/src/exec/rtems/include/rtems/.cvsignore (added) * c/src/exec/rtems/include/rtems/rtems/.cvsignore (added) * c/src/exec/rtems/inline/.cvsignore (added) * c/src/exec/rtems/inline/rtems/.cvsignore (added) * c/src/exec/rtems/inline/rtems/rtems/.cvsignore (added) * c/src/exec/rtems/macros/.cvsignore (added) * c/src/exec/rtems/macros/rtems/.cvsignore (added) * c/src/exec/rtems/macros/rtems/rtems/.cvsignore (added) * c/src/exec/rtems/optman/.cvsignore (added) * c/src/exec/rtems/src/.cvsignore (added) * c/src/exec/sapi/.cvsignore (added) * c/src/exec/sapi/include/.cvsignore (added) * c/src/exec/sapi/include/rtems/.cvsignore (added) * c/src/exec/sapi/inline/.cvsignore (added) * c/src/exec/sapi/inline/rtems/.cvsignore (added) * c/src/exec/sapi/macros/.cvsignore (added) * c/src/exec/sapi/macros/rtems/.cvsignore (added) * c/src/exec/sapi/optman/.cvsignore (added) * c/src/exec/sapi/src/.cvsignore (added) * c/src/exec/score/cpu/a29k/.cvsignore (added) * c/src/exec/score/cpu/a29k/rtems/.cvsignore (added) * c/src/exec/score/cpu/a29k/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/hppa1.1/.cvsignore (added) * c/src/exec/score/cpu/hppa1.1/rtems/.cvsignore (added) * c/src/exec/score/cpu/hppa1.1/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/i386/.cvsignore (added) * c/src/exec/score/cpu/i386/rtems/.cvsignore (added) * c/src/exec/score/cpu/i386/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/i960/.cvsignore (added) * c/src/exec/score/cpu/i960/rtems/.cvsignore (added) * c/src/exec/score/cpu/i960/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/m68k/.cvsignore (added) * c/src/exec/score/cpu/m68k/rtems/.cvsignore (added) * c/src/exec/score/cpu/m68k/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/mips/.cvsignore (added) * c/src/exec/score/cpu/mips/rtems/.cvsignore (added) * c/src/exec/score/cpu/mips/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/mips64orion/.cvsignore (added) * c/src/exec/score/cpu/mips64orion/rtems/.cvsignore (added) * c/src/exec/score/cpu/mips64orion/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/no_cpu/.cvsignore (added) * c/src/exec/score/cpu/no_cpu/rtems/.cvsignore (added) * c/src/exec/score/cpu/no_cpu/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/powerpc/new_exception_processing/.cvsignore (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/.cvsignore (added) * c/src/exec/score/cpu/powerpc/shared/.cvsignore (added) * c/src/lib/.cvsignore (added) * c/src/lib/libbsp/.cvsignore (added) * c/src/lib/libbsp/powerpc/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/motorola/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/openpic/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/pci/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/residual/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/start/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/startup/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/vectors/.cvsignore (added) * c/src/lib/libbsp/powerpc/support/new_exception_processing/.cvsignore (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/.cvsignore (added) * c/src/lib/libbsp/sh/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/console/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/include/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/scitab/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/start/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/startup/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/wrapup/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/console/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/include/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/scitab/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/start/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/startup/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/wrapup/.cvsignore (added) * c/src/lib/libbsp/sh/shared/.cvsignore (added) * c/src/lib/libbsp/shmdr/.cvsignore (added) * c/src/lib/libbsp/sparc/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/clock/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/console/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/gnatsupp/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/include/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/start/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/startup/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/timer/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/tools/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/wrapup/.cvsignore (added) * c/src/lib/libbsp/unix/.cvsignore (added) * c/src/lib/libbsp/unix/posix/.cvsignore (added) * c/src/lib/libbsp/unix/posix/clock/.cvsignore (added) * c/src/lib/libbsp/unix/posix/console/.cvsignore (added) * c/src/lib/libbsp/unix/posix/include/.cvsignore (added) * c/src/lib/libbsp/unix/posix/shmsupp/.cvsignore (added) * c/src/lib/libbsp/unix/posix/startup/.cvsignore (added) * c/src/lib/libbsp/unix/posix/timer/.cvsignore (added) * c/src/lib/libbsp/unix/posix/tools/.cvsignore (added) * c/src/lib/libbsp/unix/posix/wrapup/.cvsignore (added) * c/src/lib/libc/.cvsignore (added) * c/src/lib/libcpu/.cvsignore (added) * c/src/lib/libcpu/a29k/.cvsignore (added) * c/src/lib/libcpu/a29k/clock/.cvsignore (added) * c/src/lib/libcpu/a29k/timer/.cvsignore (added) * c/src/lib/libcpu/hppa1.1/.cvsignore (added) * c/src/lib/libcpu/hppa1.1/clock/.cvsignore (added) * c/src/lib/libcpu/hppa1.1/include/.cvsignore (added) * c/src/lib/libcpu/hppa1.1/milli/.cvsignore (added) * c/src/lib/libcpu/hppa1.1/semaphore/.cvsignore (added) * c/src/lib/libcpu/hppa1.1/timer/.cvsignore (added) * c/src/lib/libcpu/i386/.cvsignore (added) * c/src/lib/libcpu/m68k/.cvsignore (added) * c/src/lib/libcpu/m68k/m68040/.cvsignore (added) * c/src/lib/libcpu/m68k/m68040/fpsp/.cvsignore (added) * c/src/lib/libcpu/mips/.cvsignore (added) * c/src/lib/libcpu/mips/clock/.cvsignore (added) * c/src/lib/libcpu/mips/timer/.cvsignore (added) * c/src/lib/libcpu/mips64orion/.cvsignore (added) * c/src/lib/libcpu/mips64orion/clock/.cvsignore (added) * c/src/lib/libcpu/mips64orion/timer/.cvsignore (added) * c/src/lib/libcpu/powerpc/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc505/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc505/timer/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc505/vectors/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc6xx/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc6xx/clock/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc6xx/timer/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc6xx/wrapup/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc821/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc821/clock/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc821/console-generic/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc821/include/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc821/timer/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc821/vectors/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc860/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc860/clock/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc860/console-generic/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc860/include/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc860/timer/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc860/vectors/.cvsignore (added) * c/src/lib/libcpu/powerpc/new_exception_processing/.cvsignore (added) * c/src/lib/libcpu/powerpc/old_exception_processing/.cvsignore (added) * c/src/lib/libcpu/powerpc/ppc403/.cvsignore (added) * c/src/lib/libcpu/powerpc/ppc403/clock/.cvsignore (added) * c/src/lib/libcpu/powerpc/ppc403/console/.cvsignore (added) * c/src/lib/libcpu/powerpc/ppc403/ictrl/.cvsignore (added) * c/src/lib/libcpu/powerpc/ppc403/timer/.cvsignore (added) * c/src/lib/libcpu/powerpc/ppc403/vectors/.cvsignore (added) * c/src/lib/libcpu/powerpc/shared/.cvsignore (added) * c/src/lib/libcpu/powerpc/wrapup/.cvsignore (added) * c/src/lib/libcpu/sh/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/clock/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/delay/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/include/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/null/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/sci/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/timer/.cvsignore (added) * c/src/lib/libcpu/sh/sh7045/.cvsignore (added) * c/src/lib/libcpu/sh/sh7045/clock/.cvsignore (added) * c/src/lib/libcpu/sh/sh7045/include/.cvsignore (added) * c/src/lib/libcpu/sh/sh7045/null/.cvsignore (added) * c/src/lib/libcpu/sh/sh7045/sci/.cvsignore (added) * c/src/lib/libcpu/sh/sh7045/timer/.cvsignore (added) * c/src/lib/libcpu/sparc/.cvsignore (added) * c/src/lib/libcpu/sparc/reg_win/.cvsignore (added) * c/src/lib/libcpu/sparc/syscall/.cvsignore (added) * c/src/libchip/.cvsignore (added) * c/src/libchip/network/.cvsignore (added) * c/src/libchip/rtc/.cvsignore (added) * c/src/libchip/serial/.cvsignore (added) * c/src/libchip/shmdr/.cvsignore (added) * c/src/libmisc/.cvsignore (added) * c/src/libmisc/cpuuse/.cvsignore (added) * c/src/libmisc/dummy/.cvsignore (added) * c/src/libmisc/dumpbuf/.cvsignore (added) * c/src/libmisc/monitor/.cvsignore (added) * c/src/libmisc/rtmonuse/.cvsignore (added) * c/src/libmisc/stackchk/.cvsignore (added) * c/src/libmisc/untar/.cvsignore (added) * c/src/libmisc/wrapup/.cvsignore (added) * c/src/libnetworking/.cvsignore (added) * c/src/libnetworking/arpa/.cvsignore (added) * c/src/libnetworking/include/.cvsignore (added) * c/src/libnetworking/kern/.cvsignore (added) * c/src/libnetworking/lib/.cvsignore (added) * c/src/libnetworking/libc/.cvsignore (added) * c/src/libnetworking/machine/.cvsignore (added) * c/src/libnetworking/net/.cvsignore (added) * c/src/libnetworking/netinet/.cvsignore (added) * c/src/libnetworking/nfs/.cvsignore (added) * c/src/libnetworking/pppd/.cvsignore (added) * c/src/libnetworking/rtems/.cvsignore (added) * c/src/libnetworking/rtems_servers/.cvsignore (added) * c/src/libnetworking/rtems_webserver/.cvsignore (added) * c/src/libnetworking/sys/.cvsignore (added) * c/src/libnetworking/vm/.cvsignore (added) * c/src/libnetworking/wrapup/.cvsignore (added) * c/src/librdbg/.cvsignore (added) * c/src/librdbg/include/.cvsignore (added) * c/src/librdbg/include/rdbg/.cvsignore (added) * c/src/librdbg/include/rdbg/i386/.cvsignore (added) * c/src/librdbg/include/rdbg/powerpc/.cvsignore (added) * c/src/librdbg/src/.cvsignore (added) * c/src/librdbg/src/i386/.cvsignore (added) * c/src/librdbg/src/i386/any/.cvsignore (added) * c/src/librdbg/src/powerpc/.cvsignore (added) * c/src/librdbg/src/powerpc/mcp750/.cvsignore (added) * c/src/librdbg/src/powerpc/new_exception_processing/.cvsignore (added) * c/src/librpc/.cvsignore (added) * c/src/librpc/include/.cvsignore (added) * c/src/librpc/include/rpc/.cvsignore (added) * c/src/librpc/src/.cvsignore (added) * c/src/librtems++/.cvsignore (added) * c/src/librtems++/include/.cvsignore (added) * c/src/librtems++/include/rtems++/.cvsignore (added) * c/src/librtems++/src/.cvsignore (added) * c/src/make/.cvsignore (added) * c/src/make/compilers/.cvsignore (added) * c/src/make/custom/.cvsignore (added) * c/src/tests/.cvsignore (added) * c/src/tests/itrontests/.cvsignore (added) * c/src/tests/itrontests/itronhello/.cvsignore (added) * c/src/tests/itrontests/itronmbf01/.cvsignore (added) * c/src/tests/itrontests/itronmbox01/.cvsignore (added) * c/src/tests/itrontests/itronsem01/.cvsignore (added) * c/src/tests/itrontests/itrontask01/.cvsignore (added) * c/src/tests/itrontests/itrontask02/.cvsignore (added) * c/src/tests/itrontests/itrontask03/.cvsignore (added) * c/src/tests/itrontests/itrontask04/.cvsignore (added) * c/src/tests/itrontests/itrontime01/.cvsignore (added) * c/src/tests/libtests/.cvsignore (added) * c/src/tests/libtests/cpuuse/.cvsignore (added) * c/src/tests/libtests/malloctest/.cvsignore (added) * c/src/tests/libtests/monitor/.cvsignore (added) * c/src/tests/libtests/putenvtest/.cvsignore (added) * c/src/tests/libtests/rtems++/.cvsignore (added) * c/src/tests/libtests/rtmonuse/.cvsignore (added) * c/src/tests/libtests/stackchk/.cvsignore (added) * c/src/tests/libtests/termios/.cvsignore (added) * c/src/tests/mptests/.cvsignore (added) * c/src/tests/mptests/mp01/.cvsignore (added) * c/src/tests/mptests/mp01/node1/.cvsignore (added) * c/src/tests/mptests/mp01/node2/.cvsignore (added) * c/src/tests/mptests/mp02/.cvsignore (added) * c/src/tests/mptests/mp02/node1/.cvsignore (added) * c/src/tests/mptests/mp02/node2/.cvsignore (added) * c/src/tests/mptests/mp03/.cvsignore (added) * c/src/tests/mptests/mp03/node1/.cvsignore (added) * c/src/tests/mptests/mp03/node2/.cvsignore (added) * c/src/tests/mptests/mp04/.cvsignore (added) * c/src/tests/mptests/mp04/node1/.cvsignore (added) * c/src/tests/mptests/mp04/node2/.cvsignore (added) * c/src/tests/mptests/mp05/.cvsignore (added) * c/src/tests/mptests/mp05/node1/.cvsignore (added) * c/src/tests/mptests/mp05/node2/.cvsignore (added) * c/src/tests/mptests/mp06/.cvsignore (added) * c/src/tests/mptests/mp06/node1/.cvsignore (added) * c/src/tests/mptests/mp06/node2/.cvsignore (added) * c/src/tests/mptests/mp07/.cvsignore (added) * c/src/tests/mptests/mp07/node1/.cvsignore (added) * c/src/tests/mptests/mp07/node2/.cvsignore (added) * c/src/tests/mptests/mp08/.cvsignore (added) * c/src/tests/mptests/mp08/node1/.cvsignore (added) * c/src/tests/mptests/mp08/node2/.cvsignore (added) * c/src/tests/mptests/mp09/.cvsignore (added) * c/src/tests/mptests/mp09/node1/.cvsignore (added) * c/src/tests/mptests/mp09/node2/.cvsignore (added) * c/src/tests/mptests/mp10/.cvsignore (added) * c/src/tests/mptests/mp10/node1/.cvsignore (added) * c/src/tests/mptests/mp10/node2/.cvsignore (added) * c/src/tests/mptests/mp11/.cvsignore (added) * c/src/tests/mptests/mp11/node1/.cvsignore (added) * c/src/tests/mptests/mp11/node2/.cvsignore (added) * c/src/tests/mptests/mp12/.cvsignore (added) * c/src/tests/mptests/mp12/node1/.cvsignore (added) * c/src/tests/mptests/mp12/node2/.cvsignore (added) * c/src/tests/mptests/mp13/.cvsignore (added) * c/src/tests/mptests/mp13/node1/.cvsignore (added) * c/src/tests/mptests/mp13/node2/.cvsignore (added) * c/src/tests/mptests/mp14/.cvsignore (added) * c/src/tests/mptests/mp14/node1/.cvsignore (added) * c/src/tests/mptests/mp14/node2/.cvsignore (added) * c/src/tests/psxtests/.cvsignore (added) * c/src/tests/psxtests/include/.cvsignore (added) * c/src/tests/psxtests/psx01/.cvsignore (added) * c/src/tests/psxtests/psx02/.cvsignore (added) * c/src/tests/psxtests/psx03/.cvsignore (added) * c/src/tests/psxtests/psx04/.cvsignore (added) * c/src/tests/psxtests/psx05/.cvsignore (added) * c/src/tests/psxtests/psx06/.cvsignore (added) * c/src/tests/psxtests/psx07/.cvsignore (added) * c/src/tests/psxtests/psx08/.cvsignore (added) * c/src/tests/psxtests/psx09/.cvsignore (added) * c/src/tests/psxtests/psx10/.cvsignore (added) * c/src/tests/psxtests/psx11/.cvsignore (added) * c/src/tests/psxtests/psx12/.cvsignore (added) * c/src/tests/psxtests/psx13/.cvsignore (added) * c/src/tests/psxtests/psxcancel/.cvsignore (added) * c/src/tests/psxtests/psxfile01/.cvsignore (added) * c/src/tests/psxtests/psxhdrs/.cvsignore (added) * c/src/tests/psxtests/psxmount/.cvsignore (added) * c/src/tests/psxtests/psxmsgq01/.cvsignore (added) * c/src/tests/psxtests/psxreaddir/.cvsignore (added) * c/src/tests/psxtests/psxsem01/.cvsignore (added) * c/src/tests/psxtests/psxstat/.cvsignore (added) * c/src/tests/psxtests/psxtime/.cvsignore (added) * c/src/tests/psxtests/psxtimer/.cvsignore (added) * c/src/tests/samples/.cvsignore (added) * c/src/tests/samples/base_mp/.cvsignore (added) * c/src/tests/samples/base_mp/node1/.cvsignore (added) * c/src/tests/samples/base_mp/node2/.cvsignore (added) * c/src/tests/samples/base_sp/.cvsignore (added) * c/src/tests/samples/cdtest/.cvsignore (added) * c/src/tests/samples/hello/.cvsignore (added) * c/src/tests/samples/minimum/.cvsignore (added) * c/src/tests/samples/paranoia/.cvsignore (added) * c/src/tests/samples/ticker/.cvsignore (added) * c/src/tests/samples/unlimited/.cvsignore (added) * c/src/tests/sptests/.cvsignore (added) * c/src/tests/sptests/sp01/.cvsignore (added) * c/src/tests/sptests/sp02/.cvsignore (added) * c/src/tests/sptests/sp03/.cvsignore (added) * c/src/tests/sptests/sp04/.cvsignore (added) * c/src/tests/sptests/sp05/.cvsignore (added) * c/src/tests/sptests/sp06/.cvsignore (added) * c/src/tests/sptests/sp07/.cvsignore (added) * c/src/tests/sptests/sp08/.cvsignore (added) * c/src/tests/sptests/sp09/.cvsignore (added) * c/src/tests/sptests/sp11/.cvsignore (added) * c/src/tests/sptests/sp12/.cvsignore (added) * c/src/tests/sptests/sp13/.cvsignore (added) * c/src/tests/sptests/sp14/.cvsignore (added) * c/src/tests/sptests/sp15/.cvsignore (added) * c/src/tests/sptests/sp16/.cvsignore (added) * c/src/tests/sptests/sp17/.cvsignore (added) * c/src/tests/sptests/sp19/.cvsignore (added) * c/src/tests/sptests/sp20/.cvsignore (added) * c/src/tests/sptests/sp21/.cvsignore (added) * c/src/tests/sptests/sp22/.cvsignore (added) * c/src/tests/sptests/sp23/.cvsignore (added) * c/src/tests/sptests/sp24/.cvsignore (added) * c/src/tests/sptests/sp25/.cvsignore (added) * c/src/tests/sptests/sp26/.cvsignore (added) * c/src/tests/sptests/sp27/.cvsignore (added) * c/src/tests/sptests/sp28/.cvsignore (added) * c/src/tests/sptests/sp29/.cvsignore (added) * c/src/tests/sptests/spfatal/.cvsignore (added) * c/src/tests/sptests/spsize/.cvsignore (added) * c/src/tests/support/.cvsignore (added) * c/src/tests/support/include/.cvsignore (added) * c/src/tests/support/stubdr/.cvsignore (added) * c/src/tests/support/wrapup/.cvsignore (added) * c/src/tests/tmitrontests/.cvsignore (added) * c/src/tests/tmitrontests/include/.cvsignore (added) * c/src/tests/tmitrontests/tmitronsem01/.cvsignore (added) * c/src/tests/tmtests/.cvsignore (added) * c/src/tests/tmtests/include/.cvsignore (added) * c/src/tests/tmtests/tm01/.cvsignore (added) * c/src/tests/tmtests/tm02/.cvsignore (added) * c/src/tests/tmtests/tm03/.cvsignore (added) * c/src/tests/tmtests/tm04/.cvsignore (added) * c/src/tests/tmtests/tm05/.cvsignore (added) * c/src/tests/tmtests/tm06/.cvsignore (added) * c/src/tests/tmtests/tm07/.cvsignore (added) * c/src/tests/tmtests/tm08/.cvsignore (added) * c/src/tests/tmtests/tm09/.cvsignore (added) * c/src/tests/tmtests/tm10/.cvsignore (added) * c/src/tests/tmtests/tm11/.cvsignore (added) * c/src/tests/tmtests/tm12/.cvsignore (added) * c/src/tests/tmtests/tm13/.cvsignore (added) * c/src/tests/tmtests/tm14/.cvsignore (added) * c/src/tests/tmtests/tm15/.cvsignore (added) * c/src/tests/tmtests/tm16/.cvsignore (added) * c/src/tests/tmtests/tm17/.cvsignore (added) * c/src/tests/tmtests/tm18/.cvsignore (added) * c/src/tests/tmtests/tm19/.cvsignore (added) * c/src/tests/tmtests/tm20/.cvsignore (added) * c/src/tests/tmtests/tm21/.cvsignore (added) * c/src/tests/tmtests/tm22/.cvsignore (added) * c/src/tests/tmtests/tm23/.cvsignore (added) * c/src/tests/tmtests/tm24/.cvsignore (added) * c/src/tests/tmtests/tm25/.cvsignore (added) * c/src/tests/tmtests/tm26/.cvsignore (added) * c/src/tests/tmtests/tm27/.cvsignore (added) * c/src/tests/tmtests/tm28/.cvsignore (added) * c/src/tests/tmtests/tm29/.cvsignore (added) * c/src/tests/tmtests/tmck/.cvsignore (added) * c/src/tests/tmtests/tmoverhd/.cvsignore (added) * c/src/tests/tools/.cvsignore (added) * c/src/tests/tools/generic/.cvsignore (added) * c/src/wrapup/.cvsignore (added) * cpukit/httpd/.cvsignore (added) * cpukit/itron/.cvsignore (added) * cpukit/itron/include/.cvsignore (added) * cpukit/itron/include/itronsys/.cvsignore (added) * cpukit/itron/include/rtems/.cvsignore (added) * cpukit/itron/include/rtems/itron/.cvsignore (added) * cpukit/itron/inline/.cvsignore (added) * cpukit/itron/inline/rtems/.cvsignore (added) * cpukit/itron/inline/rtems/itron/.cvsignore (added) * cpukit/itron/src/.cvsignore (added) * cpukit/libcsupport/.cvsignore (added) * cpukit/libmisc/.cvsignore (added) * cpukit/libmisc/cpuuse/.cvsignore (added) * cpukit/libmisc/dummy/.cvsignore (added) * cpukit/libmisc/dumpbuf/.cvsignore (added) * cpukit/libmisc/monitor/.cvsignore (added) * cpukit/libmisc/rtmonuse/.cvsignore (added) * cpukit/libmisc/stackchk/.cvsignore (added) * cpukit/libmisc/untar/.cvsignore (added) * cpukit/libmisc/wrapup/.cvsignore (added) * cpukit/libnetworking/.cvsignore (added) * cpukit/libnetworking/arpa/.cvsignore (added) * cpukit/libnetworking/kern/.cvsignore (added) * cpukit/libnetworking/lib/.cvsignore (added) * cpukit/libnetworking/libc/.cvsignore (added) * cpukit/libnetworking/machine/.cvsignore (added) * cpukit/libnetworking/net/.cvsignore (added) * cpukit/libnetworking/netinet/.cvsignore (added) * cpukit/libnetworking/nfs/.cvsignore (added) * cpukit/libnetworking/rtems/.cvsignore (added) * cpukit/libnetworking/sys/.cvsignore (added) * cpukit/libnetworking/vm/.cvsignore (added) * cpukit/libnetworking/wrapup/.cvsignore (added) * cpukit/librpc/.cvsignore (added) * cpukit/librpc/include/.cvsignore (added) * cpukit/librpc/include/rpc/.cvsignore (added) * cpukit/librpc/src/.cvsignore (added) * cpukit/posix/.cvsignore (added) * cpukit/posix/include/.cvsignore (added) * cpukit/posix/include/rtems/.cvsignore (added) * cpukit/posix/include/rtems/posix/.cvsignore (added) * cpukit/posix/inline/.cvsignore (added) * cpukit/posix/inline/rtems/.cvsignore (added) * cpukit/posix/inline/rtems/posix/.cvsignore (added) * cpukit/posix/macros/.cvsignore (added) * cpukit/posix/macros/rtems/.cvsignore (added) * cpukit/posix/macros/rtems/posix/.cvsignore (added) * cpukit/posix/src/.cvsignore (added) * cpukit/rtems/.cvsignore (added) * cpukit/rtems/include/.cvsignore (added) * cpukit/rtems/include/rtems/.cvsignore (added) * cpukit/rtems/include/rtems/rtems/.cvsignore (added) * cpukit/rtems/inline/.cvsignore (added) * cpukit/rtems/inline/rtems/.cvsignore (added) * cpukit/rtems/inline/rtems/rtems/.cvsignore (added) * cpukit/rtems/macros/.cvsignore (added) * cpukit/rtems/macros/rtems/.cvsignore (added) * cpukit/rtems/macros/rtems/rtems/.cvsignore (added) * cpukit/rtems/src/.cvsignore (added) * cpukit/sapi/.cvsignore (added) * cpukit/sapi/include/.cvsignore (added) * cpukit/sapi/include/rtems/.cvsignore (added) * cpukit/sapi/inline/.cvsignore (added) * cpukit/sapi/inline/rtems/.cvsignore (added) * cpukit/sapi/macros/.cvsignore (added) * cpukit/sapi/macros/rtems/.cvsignore (added) * cpukit/sapi/src/.cvsignore (added) * cpukit/score/cpu/a29k/.cvsignore (added) * cpukit/score/cpu/a29k/rtems/.cvsignore (added) * cpukit/score/cpu/a29k/rtems/score/.cvsignore (added) * cpukit/score/cpu/hppa1.1/.cvsignore (added) * cpukit/score/cpu/hppa1.1/rtems/.cvsignore (added) * cpukit/score/cpu/hppa1.1/rtems/score/.cvsignore (added) * cpukit/score/cpu/i386/.cvsignore (added) * cpukit/score/cpu/i386/rtems/.cvsignore (added) * cpukit/score/cpu/i386/rtems/score/.cvsignore (added) * cpukit/score/cpu/i960/.cvsignore (added) * cpukit/score/cpu/i960/rtems/.cvsignore (added) * cpukit/score/cpu/i960/rtems/score/.cvsignore (added) * cpukit/score/cpu/m68k/.cvsignore (added) * cpukit/score/cpu/m68k/rtems/.cvsignore (added) * cpukit/score/cpu/m68k/rtems/score/.cvsignore (added) * cpukit/score/cpu/mips/.cvsignore (added) * cpukit/score/cpu/mips/rtems/.cvsignore (added) * cpukit/score/cpu/mips/rtems/score/.cvsignore (added) * cpukit/score/cpu/mips64orion/.cvsignore (added) * cpukit/score/cpu/mips64orion/rtems/.cvsignore (added) * cpukit/score/cpu/mips64orion/rtems/score/.cvsignore (added) * cpukit/score/cpu/no_cpu/.cvsignore (added) * cpukit/score/cpu/no_cpu/rtems/.cvsignore (added) * cpukit/score/cpu/no_cpu/rtems/score/.cvsignore (added) * doc/.cvsignore (added) * make/.cvsignore (added) * make/Templates/.cvsignore (added) * make/compilers/.cvsignore (added) * make/custom/.cvsignore (added) * scripts-ada/.cvsignore (added) * scripts-ada/binutils/.cvsignore (added) * scripts-ada/gdb/.cvsignore (added) * scripts-ada/gnatnewlib/.cvsignore (added) * scripts/.cvsignore (added) * scripts/binutils/.cvsignore (added) * scripts/gccnewlib/.cvsignore (added) * scripts/gdb/.cvsignore (added) * scripts/rtems/.cvsignore (added) * testsuites/.cvsignore (added) * testsuites/itrontests/.cvsignore (added) * testsuites/itrontests/itronhello/.cvsignore (added) * testsuites/itrontests/itronmbf01/.cvsignore (added) * testsuites/itrontests/itronmbox01/.cvsignore (added) * testsuites/itrontests/itronsem01/.cvsignore (added) * testsuites/itrontests/itrontask01/.cvsignore (added) * testsuites/itrontests/itrontask02/.cvsignore (added) * testsuites/itrontests/itrontask03/.cvsignore (added) * testsuites/itrontests/itrontask04/.cvsignore (added) * testsuites/itrontests/itrontime01/.cvsignore (added) * testsuites/libtests/.cvsignore (added) * testsuites/libtests/cpuuse/.cvsignore (added) * testsuites/libtests/malloctest/.cvsignore (added) * testsuites/libtests/monitor/.cvsignore (added) * testsuites/libtests/putenvtest/.cvsignore (added) * testsuites/libtests/rtems++/.cvsignore (added) * testsuites/libtests/rtmonuse/.cvsignore (added) * testsuites/libtests/stackchk/.cvsignore (added) * testsuites/libtests/termios/.cvsignore (added) * testsuites/mptests/.cvsignore (added) * testsuites/mptests/mp01/.cvsignore (added) * testsuites/mptests/mp01/node1/.cvsignore (added) * testsuites/mptests/mp01/node2/.cvsignore (added) * testsuites/mptests/mp02/.cvsignore (added) * testsuites/mptests/mp02/node1/.cvsignore (added) * testsuites/mptests/mp02/node2/.cvsignore (added) * testsuites/mptests/mp03/.cvsignore (added) * testsuites/mptests/mp03/node1/.cvsignore (added) * testsuites/mptests/mp03/node2/.cvsignore (added) * testsuites/mptests/mp04/.cvsignore (added) * testsuites/mptests/mp04/node1/.cvsignore (added) * testsuites/mptests/mp04/node2/.cvsignore (added) * testsuites/mptests/mp05/.cvsignore (added) * testsuites/mptests/mp05/node1/.cvsignore (added) * testsuites/mptests/mp05/node2/.cvsignore (added) * testsuites/mptests/mp06/.cvsignore (added) * testsuites/mptests/mp06/node1/.cvsignore (added) * testsuites/mptests/mp06/node2/.cvsignore (added) * testsuites/mptests/mp07/.cvsignore (added) * testsuites/mptests/mp07/node1/.cvsignore (added) * testsuites/mptests/mp07/node2/.cvsignore (added) * testsuites/mptests/mp08/.cvsignore (added) * testsuites/mptests/mp08/node1/.cvsignore (added) * testsuites/mptests/mp08/node2/.cvsignore (added) * testsuites/mptests/mp09/.cvsignore (added) * testsuites/mptests/mp09/node1/.cvsignore (added) * testsuites/mptests/mp09/node2/.cvsignore (added) * testsuites/mptests/mp10/.cvsignore (added) * testsuites/mptests/mp10/node1/.cvsignore (added) * testsuites/mptests/mp10/node2/.cvsignore (added) * testsuites/mptests/mp11/.cvsignore (added) * testsuites/mptests/mp11/node1/.cvsignore (added) * testsuites/mptests/mp11/node2/.cvsignore (added) * testsuites/mptests/mp12/.cvsignore (added) * testsuites/mptests/mp12/node1/.cvsignore (added) * testsuites/mptests/mp12/node2/.cvsignore (added) * testsuites/mptests/mp13/.cvsignore (added) * testsuites/mptests/mp13/node1/.cvsignore (added) * testsuites/mptests/mp13/node2/.cvsignore (added) * testsuites/mptests/mp14/.cvsignore (added) * testsuites/mptests/mp14/node1/.cvsignore (added) * testsuites/mptests/mp14/node2/.cvsignore (added) * testsuites/psxtests/.cvsignore (added) * testsuites/psxtests/include/.cvsignore (added) * testsuites/psxtests/psx01/.cvsignore (added) * testsuites/psxtests/psx02/.cvsignore (added) * testsuites/psxtests/psx03/.cvsignore (added) * testsuites/psxtests/psx04/.cvsignore (added) * testsuites/psxtests/psx05/.cvsignore (added) * testsuites/psxtests/psx06/.cvsignore (added) * testsuites/psxtests/psx07/.cvsignore (added) * testsuites/psxtests/psx08/.cvsignore (added) * testsuites/psxtests/psx09/.cvsignore (added) * testsuites/psxtests/psx10/.cvsignore (added) * testsuites/psxtests/psx11/.cvsignore (added) * testsuites/psxtests/psx12/.cvsignore (added) * testsuites/psxtests/psx13/.cvsignore (added) * testsuites/psxtests/psxcancel/.cvsignore (added) * testsuites/psxtests/psxfile01/.cvsignore (added) * testsuites/psxtests/psxhdrs/.cvsignore (added) * testsuites/psxtests/psxmount/.cvsignore (added) * testsuites/psxtests/psxmsgq01/.cvsignore (added) * testsuites/psxtests/psxreaddir/.cvsignore (added) * testsuites/psxtests/psxsem01/.cvsignore (added) * testsuites/psxtests/psxstat/.cvsignore (added) * testsuites/psxtests/psxtime/.cvsignore (added) * testsuites/psxtests/psxtimer/.cvsignore (added) * testsuites/samples/.cvsignore (added) * testsuites/samples/base_mp/.cvsignore (added) * testsuites/samples/base_mp/node1/.cvsignore (added) * testsuites/samples/base_mp/node2/.cvsignore (added) * testsuites/samples/base_sp/.cvsignore (added) * testsuites/samples/cdtest/.cvsignore (added) * testsuites/samples/hello/.cvsignore (added) * testsuites/samples/minimum/.cvsignore (added) * testsuites/samples/paranoia/.cvsignore (added) * testsuites/samples/ticker/.cvsignore (added) * testsuites/samples/unlimited/.cvsignore (added) * testsuites/sptests/.cvsignore (added) * testsuites/sptests/sp01/.cvsignore (added) * testsuites/sptests/sp02/.cvsignore (added) * testsuites/sptests/sp03/.cvsignore (added) * testsuites/sptests/sp04/.cvsignore (added) * testsuites/sptests/sp05/.cvsignore (added) * testsuites/sptests/sp06/.cvsignore (added) * testsuites/sptests/sp07/.cvsignore (added) * testsuites/sptests/sp08/.cvsignore (added) * testsuites/sptests/sp09/.cvsignore (added) * testsuites/sptests/sp11/.cvsignore (added) * testsuites/sptests/sp12/.cvsignore (added) * testsuites/sptests/sp13/.cvsignore (added) * testsuites/sptests/sp14/.cvsignore (added) * testsuites/sptests/sp15/.cvsignore (added) * testsuites/sptests/sp16/.cvsignore (added) * testsuites/sptests/sp17/.cvsignore (added) * testsuites/sptests/sp19/.cvsignore (added) * testsuites/sptests/sp20/.cvsignore (added) * testsuites/sptests/sp21/.cvsignore (added) * testsuites/sptests/sp22/.cvsignore (added) * testsuites/sptests/sp23/.cvsignore (added) * testsuites/sptests/sp24/.cvsignore (added) * testsuites/sptests/sp25/.cvsignore (added) * testsuites/sptests/sp26/.cvsignore (added) * testsuites/sptests/sp27/.cvsignore (added) * testsuites/sptests/sp28/.cvsignore (added) * testsuites/sptests/sp29/.cvsignore (added) * testsuites/sptests/spfatal/.cvsignore (added) * testsuites/sptests/spsize/.cvsignore (added) * testsuites/support/.cvsignore (added) * testsuites/support/include/.cvsignore (added) * testsuites/tmitrontests/.cvsignore (added) * testsuites/tmitrontests/include/.cvsignore (added) * testsuites/tmitrontests/tmitronsem01/.cvsignore (added) * testsuites/tmtests/.cvsignore (added) * testsuites/tmtests/include/.cvsignore (added) * testsuites/tmtests/tm01/.cvsignore (added) * testsuites/tmtests/tm02/.cvsignore (added) * testsuites/tmtests/tm03/.cvsignore (added) * testsuites/tmtests/tm04/.cvsignore (added) * testsuites/tmtests/tm05/.cvsignore (added) * testsuites/tmtests/tm06/.cvsignore (added) * testsuites/tmtests/tm07/.cvsignore (added) * testsuites/tmtests/tm08/.cvsignore (added) * testsuites/tmtests/tm09/.cvsignore (added) * testsuites/tmtests/tm10/.cvsignore (added) * testsuites/tmtests/tm11/.cvsignore (added) * testsuites/tmtests/tm12/.cvsignore (added) * testsuites/tmtests/tm13/.cvsignore (added) * testsuites/tmtests/tm14/.cvsignore (added) * testsuites/tmtests/tm15/.cvsignore (added) * testsuites/tmtests/tm16/.cvsignore (added) * testsuites/tmtests/tm17/.cvsignore (added) * testsuites/tmtests/tm18/.cvsignore (added) * testsuites/tmtests/tm19/.cvsignore (added) * testsuites/tmtests/tm20/.cvsignore (added) * testsuites/tmtests/tm21/.cvsignore (added) * testsuites/tmtests/tm22/.cvsignore (added) * testsuites/tmtests/tm23/.cvsignore (added) * testsuites/tmtests/tm24/.cvsignore (added) * testsuites/tmtests/tm25/.cvsignore (added) * testsuites/tmtests/tm26/.cvsignore (added) * testsuites/tmtests/tm27/.cvsignore (added) * testsuites/tmtests/tm28/.cvsignore (added) * testsuites/tmtests/tm29/.cvsignore (added) * testsuites/tmtests/tmck/.cvsignore (added) * testsuites/tmtests/tmoverhd/.cvsignore (added) * testsuites/tools/.cvsignore (added) * testsuites/tools/generic/.cvsignore (added) * tools/.cvsignore (added) * tools/build/.cvsignore (added) * tools/cpu/.cvsignore (added) * tools/cpu/generic/.cvsignore (added) * tools/cpu/hppa1.1/.cvsignore (added) * tools/cpu/sh/.cvsignore (added) * tools/cpu/unix/.cvsignore (added) * tools/update/.cvsignore (added) Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius [4ace694] * make/custom/Cygwin-posix.cfg (modified) Cleanup patch from Ralf Corsepius. Wed, 05 Apr 2000 13:09:56 GMT Joel Sherrill [58b28eb] * make/custom/Cygwin-posix.cfg (added) New file. Should support Cygwin as unix simulator port. Tue, 29 Feb 2000 16:35:45 GMT Joel Sherrill [8eacefcc] * c/src/exec/score/cpu/c4x/rtems/score/c4x.h (modified) * c/src/lib/libbsp/c4x/c4xsim/README (modified) * c/src/lib/libbsp/c4x/c4xsim/include/Makefile.am (modified) * c/src/lib/libbsp/c4x/shared/bspspuriousinit.c (modified) * cpukit/score/cpu/c4x/rtems/score/c4x.h (modified) * make/custom/c3xsim.cfg (modified) * make/custom/c4xsim.cfg (modified) BSP now compiles and links with CAVSL board information. This ... Tue, 22 Feb 2000 18:39:52 GMT Joel Sherrill [61ba9763] * c/src/exec/score/cpu/c4x/Makefile.am (added) * c/src/exec/score/cpu/c4x/asm.h (added) * c/src/exec/score/cpu/c4x/c4xio.h (added) * c/src/exec/score/cpu/c4x/configure.in (added) * c/src/exec/score/cpu/c4x/cpu.c (added) * c/src/exec/score/cpu/c4x/cpu_asm.S (added) * c/src/exec/score/cpu/c4x/irq.c (added) * c/src/exec/score/cpu/c4x/rtems.c (added) * c/src/exec/score/cpu/c4x/rtems/Makefile.am (added) * c/src/exec/score/cpu/c4x/rtems/score/Makefile.am (added) * c/src/exec/score/cpu/c4x/rtems/score/c4x.h (added) * c/src/exec/score/cpu/c4x/rtems/score/c4xtypes.h (added) * c/src/exec/score/cpu/c4x/rtems/score/cpu.h (added) * c/src/exec/score/cpu/c4x/rtems/score/cpu_asm.h (added) * c/src/exec/score/cpu/c4x/rtems/score/types.h (added) * c/src/lib/libbsp/c4x/Makefile.am (added) * c/src/lib/libbsp/c4x/c4xsim/Makefile.am (added) * c/src/lib/libbsp/c4x/c4xsim/README (added) * c/src/lib/libbsp/c4x/c4xsim/bsp_specs (added) * c/src/lib/libbsp/c4x/c4xsim/clock/Makefile.am (added) * c/src/lib/libbsp/c4x/c4xsim/clock/clock.c (added) * c/src/lib/libbsp/c4x/c4xsim/configure.in (added) * c/src/lib/libbsp/c4x/c4xsim/console/Makefile.am (added) * c/src/lib/libbsp/c4x/c4xsim/console/console.c (added) * c/src/lib/libbsp/c4x/c4xsim/console/consolereserveresources.c (added) * c/src/lib/libbsp/c4x/c4xsim/console/debugio.c (added) * c/src/lib/libbsp/c4x/c4xsim/console/simio.c (added) * c/src/lib/libbsp/c4x/c4xsim/include/Makefile.am (added) * c/src/lib/libbsp/c4x/c4xsim/include/bsp.h (added) * c/src/lib/libbsp/c4x/c4xsim/include/simio.h (added) * c/src/lib/libbsp/c4x/c4xsim/start/Makefile.am (added) * c/src/lib/libbsp/c4x/c4xsim/start/start.S (added) * c/src/lib/libbsp/c4x/c4xsim/startup/Makefile.am (added) * c/src/lib/libbsp/c4x/c4xsim/startup/bspstart.c (added) * c/src/lib/libbsp/c4x/c4xsim/startup/linkcmds (added) * c/src/lib/libbsp/c4x/c4xsim/startup/spurious.c (added) * c/src/lib/libbsp/c4x/c4xsim/timer/Makefile.am (added) * c/src/lib/libbsp/c4x/c4xsim/timer/timer.c (added) * c/src/lib/libbsp/c4x/c4xsim/tools/Makefile.am (added) * c/src/lib/libbsp/c4x/c4xsim/tools/configure.in (added) * c/src/lib/libbsp/c4x/c4xsim/tools/runtest.in (added) * c/src/lib/libbsp/c4x/c4xsim/wrapup/Makefile.am (added) * c/src/lib/libbsp/c4x/configure.in (added) * c/src/lib/libbsp/c4x/shared/Makefile.am (added) * c/src/lib/libbsp/c4x/shared/bspspuriousinit.c (added) * c/src/lib/libbsp/c4x/shared/c3xspurious.c (added) * c/src/lib/libbsp/c4x/shared/c4xspurious.c (added) * cpukit/score/cpu/c4x/Makefile.am (added) * cpukit/score/cpu/c4x/asm.h (added) * cpukit/score/cpu/c4x/c4xio.h (added) * cpukit/score/cpu/c4x/cpu.c (added) * cpukit/score/cpu/c4x/cpu_asm.S (added) * cpukit/score/cpu/c4x/irq.c (added) * cpukit/score/cpu/c4x/rtems/asm.h (added) * cpukit/score/cpu/c4x/rtems/score/c4x.h (added) * cpukit/score/cpu/c4x/rtems/score/cpu.h (added) * cpukit/score/cpu/c4x/rtems/score/cpu_asm.h (added) * cpukit/score/cpu/c4x/rtems/score/types.h (added) * cpukit/score/cpu/c4x/rtems/tic4x/c4xio.h (added) * make/custom/c3xsim.cfg (added) * make/custom/c4xsim.cfg (added) New port of RTEMS to TI C3x and C4x. Fri, 11 Feb 2000 14:12:03 GMT Joel Sherrill [1249edfa] * make/custom/pc386.cfg (modified) Fixed typos introduced in last modification. Spotted by Erwin Rol ... Tue, 08 Feb 2000 22:33:25 GMT Joel Sherrill [70810dc] * aclocal/canonicalize-tools.m4 (modified) * aclocal/gcc-pipe.m4 (modified) * aclocal/prog-cc.m4 (modified) * aclocal/prog-cxx.m4 (modified) * aclocal/project-root.m4 (modified) * c/configure.in (modified) * c/make/Makefile.am (modified) * c/make/configure.in (modified) * c/src/configure.in (modified) * c/src/exec/configure.in (modified) * c/src/exec/itron/configure.in (modified) * c/src/exec/itron/src/Makefile.am (modified) * c/src/exec/libcsupport/src/Makefile.am (modified) * c/src/exec/posix/configure.in (modified) * c/src/exec/posix/src/Makefile.am (modified) * c/src/exec/rtems/src/Makefile.am (modified) * c/src/exec/sapi/src/Makefile.am (modified) * c/src/exec/score/cpu/a29k/configure.in (modified) * c/src/exec/score/cpu/hppa1.1/configure.in (modified) * c/src/exec/score/cpu/i386/configure.in (modified) * c/src/exec/score/cpu/i960/configure.in (modified) * c/src/exec/score/cpu/m68k/configure.in (modified) * c/src/exec/score/cpu/mips/configure.in (modified) * c/src/exec/score/cpu/mips64orion/configure.in (modified) * c/src/exec/score/cpu/no_cpu/configure.in (modified) * c/src/exec/score/cpu/powerpc/configure.in (modified) * c/src/exec/score/cpu/sh/configure.in (modified) * c/src/exec/score/cpu/sparc/configure.in (modified) * c/src/exec/score/cpu/unix/configure.in (modified) * c/src/exec/score/src/Makefile.am (modified) * c/src/lib/configure.in (modified) * c/src/lib/libbsp/a29k/configure.in (modified) * c/src/lib/libbsp/a29k/portsw/configure.in (modified) * c/src/lib/libbsp/bare/configure.in (modified) * c/src/lib/libbsp/configure.in (modified) * c/src/lib/libbsp/hppa1.1/configure.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/configure.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure.in (modified) * c/src/lib/libbsp/i386/configure.in (modified) * c/src/lib/libbsp/i386/i386ex/configure.in (modified) * c/src/lib/libbsp/i386/pc386/configure.in (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.in (modified) * c/src/lib/libbsp/i386/ts_386ex/configure.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/configure.in (modified) * c/src/lib/libbsp/i960/configure.in (modified) * c/src/lib/libbsp/i960/cvme961/configure.in (modified) * c/src/lib/libbsp/i960/rxgen960/configure.in (modified) * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/configure.in (modified) * c/src/lib/libbsp/m68k/dmv152/configure.in (modified) * c/src/lib/libbsp/m68k/efi332/configure.in (modified) * c/src/lib/libbsp/m68k/efi68k/configure.in (modified) * c/src/lib/libbsp/m68k/gen68302/configure.in (modified) * c/src/lib/libbsp/m68k/gen68340/configure.in (modified) * c/src/lib/libbsp/m68k/gen68360/configure.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/configure.in (modified) * c/src/lib/libbsp/m68k/mvme136/configure.in (modified) * c/src/lib/libbsp/m68k/mvme147/configure.in (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.in (modified) * c/src/lib/libbsp/m68k/mvme162/configure.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.in (modified) * c/src/lib/libbsp/m68k/mvme167/configure.in (modified) * c/src/lib/libbsp/m68k/ods68302/configure.in (modified) * c/src/lib/libbsp/mips/configure.in (modified) * c/src/lib/libbsp/mips/p4000/configure.in (modified) * c/src/lib/libbsp/mips64orion/configure.in (modified) * c/src/lib/libbsp/mips64orion/p4000/configure.in (modified) * c/src/lib/libbsp/no_cpu/configure.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.in (modified) * c/src/lib/libbsp/powerpc/configure.in (modified) * c/src/lib/libbsp/powerpc/dmv177/configure.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/configure.in (modified) * c/src/lib/libbsp/powerpc/helas403/configure.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.in (modified) * c/src/lib/libbsp/powerpc/papyrus/configure.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/configure.in (modified) * c/src/lib/libbsp/powerpc/psim/configure.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure.in (modified) * c/src/lib/libbsp/powerpc/score603e/configure.in (modified) * c/src/lib/libbsp/sh/configure.in (modified) * c/src/lib/libbsp/sh/gensh1/configure.in (modified) * c/src/lib/libbsp/sh/gensh2/configure.in (modified) * c/src/lib/libbsp/sparc/configure.in (modified) * c/src/lib/libbsp/sparc/erc32/configure.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure.in (modified) * c/src/lib/libbsp/unix/configure.in (modified) * c/src/lib/libbsp/unix/posix/configure.in (modified) * c/src/lib/libbsp/unix/posix/tools/configure.in (modified) * c/src/lib/libc/Makefile.am (modified) * c/src/lib/libcpu/a29k/clock/Makefile.am (modified) * c/src/lib/libcpu/a29k/configure.in (modified) * c/src/lib/libcpu/a29k/timer/Makefile.am (modified) * c/src/lib/libcpu/configure.in (modified) * c/src/lib/libcpu/hppa1.1/configure.in (modified) * c/src/lib/libcpu/i386/configure.in (modified) * c/src/lib/libcpu/m68k/configure.in (modified) * c/src/lib/libcpu/mips/configure.in (modified) * c/src/lib/libcpu/mips64orion/configure.in (modified) * c/src/lib/libcpu/powerpc/configure.in (modified) * c/src/lib/libcpu/sh/configure.in (modified) * c/src/lib/libcpu/sparc/configure.in (modified) * c/src/libchip/configure.in (modified) * c/src/libchip/network/Makefile.am (modified) * c/src/libchip/rtc/Makefile.am (modified) * c/src/libchip/serial/Makefile.am (modified) * c/src/libmisc/configure.in (modified) * c/src/libmisc/cpuuse/Makefile.am (modified) * c/src/libmisc/monitor/Makefile.am (modified) * c/src/libmisc/rtmonuse/Makefile.am (modified) * c/src/libmisc/stackchk/Makefile.am (modified) * c/src/libmisc/untar/Makefile.am (modified) * c/src/libmisc/wrapup/Makefile.am (modified) * c/src/libnetworking/configure.in (modified) * c/src/librdbg/configure.in (modified) * c/src/librdbg/include/Makefile.am (modified) * c/src/librdbg/src/Makefile.am (modified) * c/src/librdbg/src/i386/Makefile.am (modified) * c/src/librdbg/src/powerpc/Makefile.am (modified) * c/src/librpc/configure.in (modified) * c/src/librtems++/configure.in (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/configure.in (modified) * c/src/make/lib.cfg (modified) * c/src/tests/configure.in (modified) * c/src/tests/itrontests/configure.in (modified) * c/src/tests/libtests/configure.in (modified) * c/src/tests/mptests/configure.in (modified) * c/src/tests/psxtests/configure.in (modified) * c/src/tests/samples/configure.in (modified) * c/src/tests/samples/hello/Makefile.am (modified) * c/src/tests/samples/ticker/Makefile.am (modified) * c/src/tests/sptests/configure.in (modified) * c/src/tests/support/configure.in (modified) * c/src/tests/tmitrontests/configure.in (modified) * c/src/tests/tmtests/configure.in (modified) * c/src/tests/tools/configure.in (modified) * c/src/tests/tools/generic/configure.in (modified) * configure.in (modified) * cpukit/itron/src/Makefile.am (modified) * cpukit/libmisc/cpuuse/Makefile.am (modified) * cpukit/libmisc/monitor/Makefile.am (modified) * cpukit/libmisc/rtmonuse/Makefile.am (modified) * cpukit/libmisc/stackchk/Makefile.am (modified) * cpukit/libmisc/untar/Makefile.am (modified) * cpukit/libmisc/wrapup/Makefile.am (modified) * cpukit/posix/src/Makefile.am (modified) * cpukit/rtems/src/Makefile.am (modified) * cpukit/sapi/src/Makefile.am (modified) * cpukit/score/src/Makefile.am (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/gen68360.cfg (modified) * make/lib.cfg (modified) * scripts-ada/configure.in (modified) * scripts/configure.in (modified) * testsuites/samples/hello/Makefile.am (modified) * testsuites/samples/ticker/Makefile.am (modified) * tools/build/configure.in (modified) * tools/cpu/configure.in (modified) * tools/cpu/generic/configure.in (modified) * tools/cpu/hppa1.1/configure.in (modified) * tools/cpu/sh/configure.in (modified) * tools/cpu/unix/configure.in (modified) * tools/update/cipolish (modified) * tools/update/configure.in (modified) Patches rtems-rc-20000204-0.diff from Ralf Corsepius [ee3c9e5] * make/custom/pc386.cfg (modified) Removed references to INSTALL_VARIANT. Wed, 02 Feb 2000 15:26:41 GMT Joel Sherrill [399432fa] * c/src/lib/libbsp/bsp.am (modified) * make/custom/mcp750.cfg (modified) Patch rtems-rc-20000118-6.diff from Ralf Corsepius [4c46630] * c/src/exec/configure.in (modified) * c/src/exec/itron/configure.in (modified) * c/src/exec/posix/configure.in (modified) * c/src/exec/score/cpu/a29k/configure.in (modified) * c/src/exec/score/cpu/hppa1.1/configure.in (modified) * c/src/exec/score/cpu/i386/configure.in (modified) * c/src/exec/score/cpu/i960/configure.in (modified) * c/src/exec/score/cpu/m68k/configure.in (modified) * c/src/exec/score/cpu/mips/configure.in (modified) * c/src/exec/score/cpu/mips64orion/configure.in (modified) * c/src/exec/score/cpu/no_cpu/configure.in (modified) * c/src/exec/score/cpu/powerpc/configure.in (modified) * c/src/exec/score/cpu/sh/configure.in (modified) * c/src/exec/score/cpu/sparc/configure.in (modified) * c/src/exec/score/cpu/unix/configure.in (modified) * c/src/lib/configure.in (modified) * c/src/lib/libbsp/a29k/configure.in (modified) * c/src/lib/libbsp/bare/Makefile.am (modified) * c/src/lib/libbsp/bare/configure.in (modified) * c/src/lib/libbsp/bare/include/Makefile.am (modified) * c/src/lib/libbsp/bare/wrapup/Makefile.in (deleted) * c/src/lib/libbsp/hppa1.1/configure.in (modified) * c/src/lib/libbsp/i386/configure.in (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.in (modified) * c/src/lib/libbsp/i960/configure.in (modified) * c/src/lib/libbsp/i960/cvme961/configure.in (modified) * c/src/lib/libbsp/i960/rxgen960/configure.in (modified) * c/src/lib/libbsp/m68k/configure.in (modified) * c/src/lib/libbsp/mips/configure.in (modified) * c/src/lib/libbsp/mips64orion/configure.in (modified) * c/src/lib/libbsp/no_cpu/configure.in (modified) * c/src/lib/libbsp/sh/configure.in (modified) * c/src/lib/libbsp/sparc/configure.in (modified) * c/src/lib/libbsp/unix/configure.in (modified) * c/src/lib/libcpu/a29k/clock/ckinit.c (modified) * c/src/lib/libcpu/a29k/clock/clock.h (modified) * c/src/lib/libcpu/a29k/timer/Makefile.am (modified) * c/src/lib/libcpu/a29k/timer/timer.c (modified) * c/src/lib/libcpu/a29k/timer/timerisr.c (modified) * c/src/librpc/configure.in (modified) * c/src/librtems++/configure.in (modified) * make/custom/dmv152.cfg (modified) * make/custom/gensh2.cfg (modified) * scripts-ada/Makefile.am (modified) * scripts-ada/binutils/Makefile.am (modified) * scripts-ada/gdb/Makefile.am (modified) * scripts/Makefile.am (modified) * scripts/binutils/Makefile.am (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gccnewlib/gccnewlib.spec.in (modified) * scripts/gdb/Makefile.am (modified) * scripts/rtems/Makefile.am (modified) Patch rtems-rc-20000118-1.diff from Ralf Corsepius [0261887] * make/custom/portsw.cfg (modified) Modifications from Ralf to be more like other custom files. There ... Thu, 27 Jan 2000 14:37:17 GMT Joel Sherrill [318f591] * c/src/exec/score/cpu/i386/rtems/score/i386.h (modified) * cpukit/score/cpu/i386/rtems/score/i386.h (modified) * make/custom/pc686.cfg (added) Added after report from Quality Quorum that ... Wed, 12 Jan 2000 16:08:57 GMT Joel Sherrill [1e194112] * make/custom/mvme167.cfg (modified) Called symbol table ".nm" not .num like every other BSP. Mon, 10 Jan 2000 20:56:35 GMT Joel Sherrill [6d3ab0f] * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) * make/custom/pc386.cfg (modified) * make/custom/pc486.cfg (added) * make/custom/pc586.cfg (added) Added pc486 and pc586 as aliases of pc386 with proper cpu flags. Mon, 10 Jan 2000 18:56:10 GMT Joel Sherrill [aa1d76e] * make/custom/cvme961.cfg (modified) * make/custom/rxgen960.cfg (modified) Missed cleanup from Ralf Corsepius. Mon, 10 Jan 2000 18:07:51 GMT Joel Sherrill [f9b48de] * make/custom/mcp750.cfg (modified) Removed reference to Radstone PPCN. Mon, 10 Jan 2000 18:07:15 GMT Joel Sherrill [2352726] * make/custom/mcp750.cfg (modified) Fixed comment. Fri, 07 Jan 2000 20:51:56 GMT Joel Sherrill [d273d78a] * aclocal/bsp-alias.m4 (modified) * make/custom/mcp750.cfg (modified) * make/custom/mvme2307.cfg (modified) Renaming mcp750 to motorola_shared since that is the basis for both ... Fri, 07 Jan 2000 14:47:02 GMT Joel Sherrill [0ff37e68] * aclocal/check-bsps.m4 (modified) * automake/lib.am (modified) * c/src/lib/libbsp/MERGE.PROCEDURE (modified) * c/src/lib/libbsp/Makefile.am.new (deleted) * c/src/lib/libcpu/powerpc/mpc6xx/Makefile.am (modified) * make/custom/gensh2.cfg (modified) * tools/update/rtems-polish.sh (modified) Patch rtems-rc-20000104-0.diff from Ralf Corsepius [8b91282] * c/src/exec/score/cpu/sh/rtems/score/iosh7045.h (modified) * c/src/lib/libbsp/sh/gensh2/startup/bspstart.c (modified) * c/src/lib/libbsp/sh/gensh2/startup/hw_init.c (modified) * c/src/lib/libcpu/sh/sh7045/include/io_types.h (modified) * c/src/lib/libcpu/sh/sh7045/include/iosh7045.h (modified) * c/src/lib/libcpu/sh/sh7045/include/sh7_pfc.h (modified) * c/src/lib/libcpu/sh/sh7045/sci/sci.c (modified) * make/custom/gensh2.cfg (modified) Patch rtems-rc-19991203-5.diff from Ralf Corsepius [1d5039f] * make/custom/gensh2.cfg (modified) *** empty log message *** Thu, 02 Dec 1999 14:31:19 GMT Joel Sherrill [acc25ee] * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/new_exception_processing/Makefile.in (added) * c/src/exec/score/cpu/powerpc/new_exception_processing/c_isr.inl (added) * c/src/exec/score/cpu/powerpc/new_exception_processing/cpu.c (added) * c/src/exec/score/cpu/powerpc/new_exception_processing/cpu.h (added) * c/src/exec/score/cpu/powerpc/new_exception_processing/cpu_asm.S (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/Makefile.in (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/README (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/TODO (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/c_isr.inl (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/cpu.c (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/cpu.h (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/cpu_asm.S (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/irq_stub.S (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/ppccache.c (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/rtems.S (added) * c/src/exec/score/cpu/powerpc/rtems/score/ppc.h (modified) * c/src/exec/score/cpu/powerpc/shared/ppc.h (modified) * c/src/exec/score/cpu/powerpc/wrap/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/bootloader/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/console/console.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/console/console_reserve_resources.c (deleted) * c/src/lib/libbsp/powerpc/mcp750/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/irq/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/openpic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/residual/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/console_reserve_resources.c (deleted) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/shared/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/bootloader/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/bootloader/README (added) * c/src/lib/libbsp/powerpc/shared/bootloader/bootldr.h (added) * c/src/lib/libbsp/powerpc/shared/bootloader/em86.c (added) * c/src/lib/libbsp/powerpc/shared/bootloader/em86real.S (added) * c/src/lib/libbsp/powerpc/shared/bootloader/exception.S (added) * c/src/lib/libbsp/powerpc/shared/bootloader/head.S (added) * c/src/lib/libbsp/powerpc/shared/bootloader/lib.c (added) * c/src/lib/libbsp/powerpc/shared/bootloader/misc.c (added) * c/src/lib/libbsp/powerpc/shared/bootloader/mm.c (added) * c/src/lib/libbsp/powerpc/shared/bootloader/pci.c (added) * c/src/lib/libbsp/powerpc/shared/bootloader/pci.h (added) * c/src/lib/libbsp/powerpc/shared/bootloader/ppcboot.lds (added) * c/src/lib/libbsp/powerpc/shared/bootloader/zlib.c (added) * c/src/lib/libbsp/powerpc/shared/bootloader/zlib.h (added) * c/src/lib/libbsp/powerpc/shared/clock/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/clock/p_clock.c (added) * c/src/lib/libbsp/powerpc/shared/console/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/console/console.c (moved) * c/src/lib/libbsp/powerpc/shared/console/consoleIo.h (added) * c/src/lib/libbsp/powerpc/shared/console/inch.c (added) * c/src/lib/libbsp/powerpc/shared/console/keyboard.h (added) * c/src/lib/libbsp/powerpc/shared/console/polled_io.c (added) * c/src/lib/libbsp/powerpc/shared/console/uart.c (added) * c/src/lib/libbsp/powerpc/shared/console/uart.h (added) * c/src/lib/libbsp/powerpc/shared/dec21140/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/dec21140/dec21140.c (added) * c/src/lib/libbsp/powerpc/shared/include/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/include/bsp.h (added) * c/src/lib/libbsp/powerpc/shared/include/nvram.h (added) * c/src/lib/libbsp/powerpc/shared/irq/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/irq/i8259.c (added) * c/src/lib/libbsp/powerpc/shared/irq/irq.c (added) * c/src/lib/libbsp/powerpc/shared/irq/irq.h (added) * c/src/lib/libbsp/powerpc/shared/irq/irq_asm.S (added) * c/src/lib/libbsp/powerpc/shared/irq/irq_init.c (added) * c/src/lib/libbsp/powerpc/shared/motorola/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/motorola/motorola.c (added) * c/src/lib/libbsp/powerpc/shared/motorola/motorola.h (added) * c/src/lib/libbsp/powerpc/shared/openpic/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/openpic/openpic.c (added) * c/src/lib/libbsp/powerpc/shared/openpic/openpic.h (added) * c/src/lib/libbsp/powerpc/shared/pci/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/pci/pci.c (added) * c/src/lib/libbsp/powerpc/shared/pci/pci.h (added) * c/src/lib/libbsp/powerpc/shared/residual/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/residual/pnp.h (added) * c/src/lib/libbsp/powerpc/shared/residual/residual.c (added) * c/src/lib/libbsp/powerpc/shared/residual/residual.h (added) * c/src/lib/libbsp/powerpc/shared/start/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/start/start.S (added) * c/src/lib/libbsp/powerpc/shared/startup/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/startup/bspstart.c (added) * c/src/lib/libbsp/powerpc/shared/startup/linkcmds (added) * c/src/lib/libbsp/powerpc/shared/vectors/Makefile.in (added) * c/src/lib/libbsp/powerpc/shared/vectors/vectors.S (added) * c/src/lib/libbsp/powerpc/shared/vectors/vectors.h (added) * c/src/lib/libbsp/powerpc/shared/vectors/vectors_init.c (added) * c/src/lib/libbsp/powerpc/support/new_exception_processing/c_isr.inl (added) * c/src/lib/libbsp/powerpc/support/new_exception_processing/cpu.c (added) * c/src/lib/libbsp/powerpc/support/new_exception_processing/cpu.h (added) * c/src/lib/libbsp/powerpc/support/new_exception_processing/cpu_asm.S (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/README (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/TODO (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/c_isr.inl (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/cpu.c (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/cpu.h (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/cpu_asm.S (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/irq_stub.S (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/ppccache.c (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/rtems.S (added) * c/src/lib/libcpu/powerpc/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc6xx/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc6xx/clock/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.c (added) * c/src/lib/libcpu/powerpc/mpc6xx/clock/c_clock.h (added) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/asm_utils.S (added) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/raw_exception.c (added) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/raw_exception.h (added) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/bat.c (added) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/bat.h (added) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/mmuAsm.S (added) * c/src/lib/libcpu/powerpc/mpc6xx/wrapup/Makefile.in (added) * c/src/lib/libcpu/powerpc/new-exceptions/cpu.c (added) * c/src/lib/libcpu/powerpc/new-exceptions/cpu_asm.S (added) * c/src/lib/libcpu/powerpc/new_exception_processing/Makefile.in (added) * c/src/lib/libcpu/powerpc/new_exception_processing/c_isr.inl (added) * c/src/lib/libcpu/powerpc/new_exception_processing/cpu.c (added) * c/src/lib/libcpu/powerpc/new_exception_processing/cpu.h (added) * c/src/lib/libcpu/powerpc/new_exception_processing/cpu_asm.S (added) * c/src/lib/libcpu/powerpc/old-exceptions/README (added) * c/src/lib/libcpu/powerpc/old-exceptions/TODO (added) * c/src/lib/libcpu/powerpc/old-exceptions/cpu.c (added) * c/src/lib/libcpu/powerpc/old-exceptions/cpu_asm.S (added) * c/src/lib/libcpu/powerpc/old-exceptions/irq_stub.S (added) * c/src/lib/libcpu/powerpc/old-exceptions/ppccache.c (added) * c/src/lib/libcpu/powerpc/old_exception_processing/Makefile.in (added) * c/src/lib/libcpu/powerpc/old_exception_processing/README (added) * c/src/lib/libcpu/powerpc/old_exception_processing/TODO (added) * c/src/lib/libcpu/powerpc/old_exception_processing/c_isr.inl (added) * c/src/lib/libcpu/powerpc/old_exception_processing/cpu.c (added) * c/src/lib/libcpu/powerpc/old_exception_processing/cpu.h (added) * c/src/lib/libcpu/powerpc/old_exception_processing/cpu_asm.S (added) * c/src/lib/libcpu/powerpc/old_exception_processing/irq_stub.S (added) * c/src/lib/libcpu/powerpc/old_exception_processing/ppccache.c (added) * c/src/lib/libcpu/powerpc/old_exception_processing/rtems.S (added) * c/src/lib/libcpu/powerpc/shared/Makefile.in (modified) * c/src/lib/libcpu/powerpc/shared/cpu.h (modified) * c/src/lib/libcpu/powerpc/wrapup/Makefile.in (modified) * cpukit/score/cpu/powerpc/rtems/score/ppc.h (modified) * make/custom/mcp750.cfg (modified) * make/custom/mvme2307.cfg (modified) Merged of mcp750 and mvme2307 BSP by Eric Valette ... Tue, 30 Nov 1999 13:49:04 GMT Joel Sherrill [96344c8] * Makefile.am (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-posix.m4 (modified) * make/custom/mcp750.cfg (modified) Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius [49da88c] * c/src/exec/rtems/include/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/optman/Makefile.am (modified) * c/src/exec/sapi/optman/Makefile.am (modified) * c/src/lib/libbsp/powerpc/mcp750/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.in (modified) * c/src/make/host.cfg.in (modified) * c/src/optman/rtems/Makefile.am (modified) * c/src/optman/sapi/Makefile.am (modified) * make/custom/gen68360.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/gensh2.cfg (modified) * make/host.cfg.in (modified) Patch rtems-rc-19991117-16.diff from Ralf Corsepius [9f4868c] * Makefile.am (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-networking.m4 (modified) * aclocal/enable-posix.m4 (modified) * c/src/exec/librpc/include/rpc/Makefile.am (modified) * c/src/libchip/network/Makefile.am (modified) * c/src/libchip/rtc/Makefile.am (modified) * c/src/libchip/serial/Makefile.am (modified) * c/src/libnetworking/include/Makefile.in (modified) * c/src/libnetworking/rtems_webserver/Makefile.in (modified) * c/src/libnetworking/wrapup/Makefile.in (modified) * c/src/librdbg/src/i386/Makefile.am (modified) * c/src/librdbg/src/i386/any/Makefile.in (modified) * c/src/librdbg/src/i386/pc386/Makefile.in (modified) * c/src/librpc/include/rpc/Makefile.am (modified) * c/src/librpc/src/Makefile.in (modified) * c/src/librtems++/src/Makefile.in (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/tests/psxtests/Makefile.am (modified) * c/src/tests/psxtests/configure.in (modified) * c/src/tests/support/stubdr/Makefile.in (modified) * c/src/wrapup/Makefile.in (modified) * cpukit/httpd/Makefile.in (modified) * cpukit/librpc/include/rpc/Makefile.am (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/pc386.cfg (modified) * testsuites/psxtests/Makefile.am (modified) * tools/update/acpolish (modified) * tools/update/ampolish (modified) Miscellaneous patches from Ralf Corsepius ... Mon, 22 Nov 1999 14:28:36 GMT Joel Sherrill [28cc172] * make/custom/dmv177.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/eth_comm.cfg (modified) * make/custom/gen68340.cfg (modified) * make/custom/gen68360.cfg (modified) * make/custom/mcp750.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/ppcn_60x.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/score603e.cfg (modified) Removed need for START_BASE. Mon, 22 Nov 1999 13:41:11 GMT Joel Sherrill [9608320] * aclocal/check-cpu.m4 (modified) * aclocal/check-multiprocessing.m4 (modified) * aclocal/check-networking.m4 (modified) * aclocal/check-posix.m4 (modified) * aclocal/enable-rtemsbsp.m4 (modified) * automake/local.am (modified) * c/src/Makefile.am (modified) * c/src/exec/configure.in (modified) * c/src/exec/itron/include/Makefile.am (modified) * c/src/exec/itron/include/itronsys/Makefile.am (modified) * c/src/exec/itron/include/rtems/itron/Makefile.am (modified) * c/src/exec/itron/inline/rtems/itron/Makefile.am (modified) * c/src/exec/librpc/include/rpc/Makefile.am (modified) * c/src/exec/posix/configure.in (modified) * c/src/exec/posix/include/Makefile.am (modified) * c/src/exec/posix/include/rtems/posix/Makefile.am (modified) * c/src/exec/posix/include/sys/Makefile.am (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.am (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.am (modified) * c/src/exec/rtems/include/Makefile.am (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.am (modified) * c/src/exec/sapi/include/Makefile.am (modified) * c/src/exec/sapi/include/rtems/Makefile.am (modified) * c/src/exec/sapi/inline/rtems/Makefile.am (modified) * c/src/exec/sapi/macros/rtems/Makefile.am (modified) * c/src/exec/score/cpu/Makefile.in (modified) * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/Makefile.in (modified) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/sh/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/Makefile.in (modified) * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/Makefile.in (modified) * c/src/exec/score/include/rtems/Makefile.am (modified) * c/src/exec/score/inline/rtems/score/Makefile.am (modified) * c/src/exec/score/macros/rtems/score/Makefile.am (modified) * c/src/lib/include/Makefile.am (modified) * c/src/lib/include/motorola/Makefile.am (modified) * c/src/lib/include/sys/Makefile.am (modified) * c/src/lib/include/zilog/Makefile.am (modified) * c/src/lib/libbsp/Makefile.in (modified) * c/src/lib/libbsp/a29k/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.in (modified) * c/src/lib/libbsp/bare/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (modified) * c/src/lib/libbsp/i386/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/Makefile.in (modified) * c/src/lib/libbsp/i960/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/Makefile.in (modified) * c/src/lib/libbsp/m68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.in (modified) * c/src/lib/libbsp/powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mvme2307/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.in (modified) * c/src/lib/libbsp/sh/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.in (modified) * c/src/lib/libbsp/sparc/Makefile.in (modified) * c/src/lib/libbsp/unix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/Makefile.in (modified) * c/src/lib/libcpu/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/Makefile.in (modified) * c/src/lib/libcpu/m68k/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/Makefile.in (modified) * c/src/lib/libcpu/powerpc/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc505/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.in (modified) * c/src/lib/libcpu/sh/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7045/Makefile.in (modified) * c/src/lib/libcpu/sparc/Makefile.in (modified) * c/src/libchip/network/Makefile.am (added) * c/src/libchip/network/Makefile.in (deleted) * c/src/libchip/rtc/Makefile.am (added) * c/src/libchip/rtc/Makefile.in (deleted) * c/src/libchip/serial/Makefile.am (added) * c/src/libchip/serial/Makefile.in (deleted) * c/src/libmisc/configure.in (modified) * c/src/libmisc/cpuuse/Makefile.am (added) * c/src/libmisc/cpuuse/Makefile.in (deleted) * c/src/libmisc/dummy/Makefile.am (added) * c/src/libmisc/dummy/Makefile.in (deleted) * c/src/libmisc/dumpbuf/Makefile.am (added) * c/src/libmisc/dumpbuf/Makefile.in (deleted) * c/src/libmisc/monitor/Makefile.am (added) * c/src/libmisc/monitor/Makefile.in (deleted) * c/src/libmisc/rtmonuse/Makefile.am (added) * c/src/libmisc/rtmonuse/Makefile.in (deleted) * c/src/libmisc/stackchk/Makefile.am (added) * c/src/libmisc/stackchk/Makefile.in (deleted) * c/src/libmisc/untar/Makefile.am (added) * c/src/libmisc/untar/Makefile.in (deleted) * c/src/libmisc/wrapup/Makefile.am (added) * c/src/libmisc/wrapup/Makefile.in (deleted) * c/src/librdbg/include/rdbg/Makefile.am (modified) * c/src/librdbg/include/rdbg/i386/Makefile.am (modified) * c/src/librdbg/include/rdbg/powerpc/Makefile.am (modified) * c/src/librpc/include/rpc/Makefile.am (modified) * c/src/librtems++/include/rtems++/Makefile.am (modified) * c/src/make/README (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/directory.cfg (modified) * c/src/make/lib.cfg (modified) * c/src/make/main.cfg.in (modified) * c/src/tests/mptests/mp01/Makefile.in (modified) * c/src/tests/mptests/mp02/Makefile.in (modified) * c/src/tests/mptests/mp03/Makefile.in (modified) * c/src/tests/mptests/mp04/Makefile.in (modified) * c/src/tests/mptests/mp05/Makefile.in (modified) * c/src/tests/mptests/mp06/Makefile.in (modified) * c/src/tests/mptests/mp07/Makefile.in (modified) * c/src/tests/mptests/mp08/Makefile.in (modified) * c/src/tests/mptests/mp09/Makefile.in (modified) * c/src/tests/mptests/mp10/Makefile.in (modified) * c/src/tests/mptests/mp11/Makefile.in (modified) * c/src/tests/mptests/mp12/Makefile.in (modified) * c/src/tests/mptests/mp13/Makefile.in (modified) * c/src/tests/mptests/mp14/Makefile.in (modified) * c/src/tests/psxtests/support/Makefile.in (modified) * c/src/tests/samples/base_mp/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.am (modified) * cpukit/itron/include/Makefile.am (modified) * cpukit/libmisc/cpuuse/Makefile.am (added) * cpukit/libmisc/dummy/Makefile.am (added) * cpukit/libmisc/dumpbuf/Makefile.am (added) * cpukit/libmisc/monitor/Makefile.am (added) * cpukit/libmisc/rtmonuse/Makefile.am (added) * cpukit/libmisc/stackchk/Makefile.am (added) * cpukit/libmisc/untar/Makefile.am (added) * cpukit/libmisc/wrapup/Makefile.am (added) * cpukit/librpc/include/rpc/Makefile.am (modified) * cpukit/posix/include/Makefile.am (modified) * cpukit/rtems/include/Makefile.am (modified) * cpukit/sapi/include/Makefile.am (modified) * make/README (modified) * make/Templates/Makefile.dir (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/erc32.cfg (modified) * make/directory.cfg (modified) * make/lib.cfg (modified) * make/main.cfg (modified) * testsuites/tools/generic/Makefile.am (modified) Patch rtems-rc-19991117-4.diff from Ralf Corsepius [4a238002] * c/configure.in (modified) * c/src/exec/score/cpu/sh/cpu.c (modified) * c/src/exec/score/cpu/sh/cpu_asm.c (modified) * c/src/exec/score/cpu/sh/cpu_isps.c (deleted) * c/src/exec/score/cpu/sh/ispsh7032.c (modified) * c/src/exec/score/cpu/sh/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/sh/rtems/score/cpu_isps.h (deleted) * c/src/exec/score/cpu/sh/rtems/score/iosh7030.h (deleted) * c/src/exec/score/cpu/sh/rtems/score/sh.h (modified) * c/src/exec/score/cpu/sh/wrap/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/README (modified) * c/src/lib/libbsp/sh/gensh1/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/startup/bspstart.c (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.in (added) * c/src/lib/libbsp/sh/gensh2/README (added) * c/src/lib/libbsp/sh/gensh2/bsp_specs (added) * c/src/lib/libbsp/sh/gensh2/console/Makefile.in (moved) * c/src/lib/libbsp/sh/gensh2/include/Makefile.in (added) * c/src/lib/libbsp/sh/gensh2/include/bsp.h (added) * c/src/lib/libbsp/sh/gensh2/include/coverhd.h (added) * c/src/lib/libbsp/sh/gensh2/scitab/Makefile.in (added) * c/src/lib/libbsp/sh/gensh2/start/Makefile.in (added) * c/src/lib/libbsp/sh/gensh2/start/start.S (added) * c/src/lib/libbsp/sh/gensh2/start/start.ram (added) * c/src/lib/libbsp/sh/gensh2/start/start.rom (added) * c/src/lib/libbsp/sh/gensh2/startup/Makefile.in (added) * c/src/lib/libbsp/sh/gensh2/startup/bspclean.c (added) * c/src/lib/libbsp/sh/gensh2/startup/bspstart.c (added) * c/src/lib/libbsp/sh/gensh2/startup/hw_init.c (added) * c/src/lib/libbsp/sh/gensh2/startup/linkcmds (added) * c/src/lib/libbsp/sh/gensh2/startup/linkcmds.ram (added) * c/src/lib/libbsp/sh/gensh2/startup/linkcmds.rom (added) * c/src/lib/libbsp/sh/gensh2/wrapup/Makefile.in (added) * c/src/lib/libcpu/sh/sh7032/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/clock/ckinit.c (modified) * c/src/lib/libcpu/sh/sh7032/console/console.c (deleted) * c/src/lib/libcpu/sh/sh7032/include/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/include/ioqueue.h (deleted) * c/src/lib/libcpu/sh/sh7032/include/sci.h (modified) * c/src/lib/libcpu/sh/sh7032/include/sh7_pfc.h (modified) * c/src/lib/libcpu/sh/sh7032/include/sh7_sci.h (modified) * c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7032/score/ispsh7032.c (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/timer/timer.c (modified) * c/src/lib/libcpu/sh/sh7045/Makefile.in (added) * c/src/lib/libcpu/sh/sh7045/clock/Makefile.in (added) * c/src/lib/libcpu/sh/sh7045/clock/ckinit.c (added) * c/src/lib/libcpu/sh/sh7045/include/Makefile.in (added) * c/src/lib/libcpu/sh/sh7045/include/io_types.h (added) * c/src/lib/libcpu/sh/sh7045/include/null.h (added) * c/src/lib/libcpu/sh/sh7045/include/sci.h (added) * c/src/lib/libcpu/sh/sh7045/include/sh7_pfc.h (added) * c/src/lib/libcpu/sh/sh7045/include/sh7_sci.h (added) * c/src/lib/libcpu/sh/sh7045/null/Makefile.in (added) * c/src/lib/libcpu/sh/sh7045/null/close.c (added) * c/src/lib/libcpu/sh/sh7045/null/cntrl.c (added) * c/src/lib/libcpu/sh/sh7045/null/init.c (added) * c/src/lib/libcpu/sh/sh7045/null/open.c (added) * c/src/lib/libcpu/sh/sh7045/null/read.c (added) * c/src/lib/libcpu/sh/sh7045/null/write.c (added) * c/src/lib/libcpu/sh/sh7045/sci/Makefile.in (added) * c/src/lib/libcpu/sh/sh7045/sci/sci.c (added) * c/src/lib/libcpu/sh/sh7045/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7045/timer/Makefile.in (added) * c/src/lib/libcpu/sh/sh7045/timer/timer.c (added) * cpukit/score/cpu/sh/cpu.c (modified) * cpukit/score/cpu/sh/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/rtems/score/sh.h (modified) * make/custom/gensh1.cfg (modified) * make/custom/gensh2.cfg (added) Patch from "John M. Mills" with subsequent cleanup ... Tue, 16 Nov 1999 15:48:11 GMT Joel Sherrill [d6c83529] * Makefile.am (modified) * bootstrap (moved) * c/Makefile.am (modified) * c/configure.in (modified) * c/make/Makefile.am (added) * c/make/configure.in (added) * c/make/target.cfg.in (moved) * c/src/make/Makefile.am (modified) * c/src/make/bsp.cfg.in (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/configure.in (modified) * c/src/make/custom/default.cfg.in (modified) * c/src/make/main.cfg.in (modified) * c/src/tests/samples/cdtest/Makefile.in (modified) * c/src/tests/samples/paranoia/Makefile.in (modified) * make/Makefile.am (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/bare.cfg (modified) * make/custom/default.cfg (modified) * make/custom/gen68360.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/ods68302.cfg (modified) * make/leaf.cfg (modified) * make/main.cfg (modified) Patch rtems-rc-19991105-1.diff.gz from Ralf Corsepius ... Fri, 05 Nov 1999 15:47:47 GMT Joel Sherrill [707f5c7] * make/custom/eth_comm.cfg (modified) * make/custom/gen68340.cfg (modified) * make/custom/mcp750.cfg (modified) * make/custom/score603e.cfg (modified) Eliminated references to stack checker related #defines. Mon, 01 Nov 1999 13:15:26 GMT Joel Sherrill [c61218e8] * make/custom/mvme2307.cfg (modified) Removed HAS_MP=no and commented out HAS_NETWORKING=no. Thu, 28 Oct 1999 16:01:41 GMT Joel Sherrill [7046cdd] * c/src/exec/score/cpu/sh/rtems/score/sh.h (modified) * c/src/lib/libbsp/sh/gensh1/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.in (modified) * cpukit/score/cpu/sh/rtems/score/sh.h (modified) * make/custom/gensh1.cfg (modified) Patch rtems-rc-19991011-3.diff from Ralf Corsepius. Wed, 27 Oct 1999 19:24:26 GMT Joel Sherrill [226ea52] * make/custom/rxgen960.cfg (modified) Updated to be more like cvme961.cfg. Wed, 27 Oct 1999 15:29:18 GMT Joel Sherrill [702c5f5] * c/ACKNOWLEDGEMENTS (modified) * c/src/exec/score/cpu/i960/cpu.c (modified) * c/src/exec/score/cpu/i960/i960RP.h (added) * c/src/exec/score/cpu/i960/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/i960/rtems/score/i960.h (modified) * c/src/exec/score/cpu/i960/wrap/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/Makefile.in (added) * c/src/lib/libbsp/i960/rxgen960/README (added) * c/src/lib/libbsp/i960/rxgen960/bsp_specs (added) * c/src/lib/libbsp/i960/rxgen960/clock/Makefile.in (added) * c/src/lib/libbsp/i960/rxgen960/clock/ckinit.c (added) * c/src/lib/libbsp/i960/rxgen960/console/Makefile.in (added) * c/src/lib/libbsp/i960/rxgen960/console/concntl.h (added) * c/src/lib/libbsp/i960/rxgen960/console/console.c (added) * c/src/lib/libbsp/i960/rxgen960/console/serial.c (added) * c/src/lib/libbsp/i960/rxgen960/console/serial.h (added) * c/src/lib/libbsp/i960/rxgen960/include/Makefile.in (added) * c/src/lib/libbsp/i960/rxgen960/include/bsp.h (added) * c/src/lib/libbsp/i960/rxgen960/include/coverhd.h (added) * c/src/lib/libbsp/i960/rxgen960/include/rxgen960_config.h (added) * c/src/lib/libbsp/i960/rxgen960/shmsupp/Makefile.in (added) * c/src/lib/libbsp/i960/rxgen960/shmsupp/addrconv.c (added) * c/src/lib/libbsp/i960/rxgen960/shmsupp/getcfg.c (added) * c/src/lib/libbsp/i960/rxgen960/shmsupp/lock.c (added) * c/src/lib/libbsp/i960/rxgen960/shmsupp/mpisr.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.in (added) * c/src/lib/libbsp/i960/rxgen960/startup/asmfault.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/asmfault.s (added) * c/src/lib/libbsp/i960/rxgen960/startup/asmstub.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/asmstub.s (added) * c/src/lib/libbsp/i960/rxgen960/startup/bspstart.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/cntrltbl.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/cntrltbl.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/dram.ld (added) * c/src/lib/libbsp/i960/rxgen960/startup/exit.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/fault.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/fault.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/faultret.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/flttbl.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/flttbl.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/frmstr.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/frmstr.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/i960.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/ihandler.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/ihandler.s (added) * c/src/lib/libbsp/i960/rxgen960/startup/intrtbl.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/intrtbl.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/kkprintf.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/linkcmds (added) * c/src/lib/libbsp/i960/rxgen960/startup/main.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/memchnl.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/nmi.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/nulsystbl.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/pmc901_memmap.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/prcb.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/prcb.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/rom.ld (added) * c/src/lib/libbsp/i960/rxgen960/startup/rom_cntrltbl.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/rom_ibr.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/rom_ibr.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/rom_prcb.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/rommon.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/rxgen_romld.s (added) * c/src/lib/libbsp/i960/rxgen960/startup/save_systbl.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/sctns.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/sctns.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/sctns.s (added) * c/src/lib/libbsp/i960/rxgen960/startup/setvec.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/systbl.c (added) * c/src/lib/libbsp/i960/rxgen960/startup/systbl.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/systbl.s (added) * c/src/lib/libbsp/i960/rxgen960/startup/time.h (added) * c/src/lib/libbsp/i960/rxgen960/startup/types.h (added) * c/src/lib/libbsp/i960/rxgen960/timer/Makefile.in (added) * c/src/lib/libbsp/i960/rxgen960/timer/timer.c (added) * c/src/lib/libbsp/i960/rxgen960/timer/timerisr.s (added) * c/src/lib/libbsp/i960/rxgen960/wrapup/Makefile.in (added) * cpukit/score/cpu/i960/cpu.c (modified) * cpukit/score/cpu/i960/rtems/score/cpu.h (modified) * cpukit/score/cpu/i960/rtems/score/i960.h (modified) * make/custom/rxgen960.cfg (added) The rxgen960 BSP and i960 RPM support was submitted by Mark Bronson ... Tue, 26 Oct 1999 14:22:55 GMT Joel Sherrill [65a60cd] * c/src/make/README (modified) * c/src/make/compilers/Makefile.am (modified) * c/src/make/compilers/gcc.cfg.in (deleted) * c/src/make/configure.in (modified) * make/README (modified) * make/compilers/Makefile.am (modified) * make/compilers/gcc.cfg.in (deleted) * make/custom/HPUX9-posix.cfg (modified) * make/custom/default.cfg (modified) * make/leaf.cfg (modified) Removed all references to HOST_ARCH including the file gcc.cfg.in. ... Mon, 25 Oct 1999 14:52:19 GMT Joel Sherrill [3eb75db3] * c/src/lib/libbsp/powerpc/mcp750/dec21140/dec21140.c (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/dec21140/dec21140.c (modified) * make/custom/mcp750.cfg (modified) tch from Eric Valette and Emmanuel Raguet ... Mon, 25 Oct 1999 14:14:36 GMT Joel Sherrill [43d3a8e] * make/custom/erc32.cfg (modified) Changed to use interrupt driven console. Mon, 11 Oct 1999 15:30:49 GMT Joel Sherrill [8ab8646] * make/custom/cvme961.cfg (modified) Switched to the C++ front end to gcc to link. This still did not work. Wed, 06 Oct 1999 18:09:11 GMT Joel Sherrill [b9fcbd0] * make/custom/mcp750.cfg (modified) Added $(LINK_LIBS) to linking gcc command so paranoia would link. Tue, 05 Oct 1999 19:22:15 GMT Joel Sherrill [2ccdc399] * make/custom/Makefile.am (modified) Removed targets and configurations that are no longer functional and ... Tue, 05 Oct 1999 18:39:56 GMT Joel Sherrill [977623b] * README.configure (modified) * c/src/make/README (modified) * make/README (modified) * make/custom/force386.cfg (deleted) * make/custom/go32.cfg (deleted) * make/custom/go32_p5.cfg (deleted) Removed targets and configurations that are no longer functional and ... Tue, 05 Oct 1999 14:05:30 GMT Joel Sherrill [17978a1] * c/src/lib/libbsp/powerpc/mvme2307/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mvme2307/boot/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mvme2307/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mvme2307/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mvme2307/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mvme2307/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mvme2307/nvram/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mvme2307/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mvme2307/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mvme2307/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mvme2307/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mvme2307/wrapup/Makefile.in (modified) * make/custom/Makefile.am (modified) Minor corrections to get mvme2307 to compile. Mon, 04 Oct 1999 20:41:28 GMT Joel Sherrill [19ca797] * c/src/lib/libbsp/powerpc/mvme2307/Makefile.in (added) * c/src/lib/libbsp/powerpc/mvme2307/NOTES (added) * c/src/lib/libbsp/powerpc/mvme2307/README (added) * c/src/lib/libbsp/powerpc/mvme2307/boot/Makefile.in (added) * c/src/lib/libbsp/powerpc/mvme2307/boot/start.S (added) * c/src/lib/libbsp/powerpc/mvme2307/bsp_specs (added) * c/src/lib/libbsp/powerpc/mvme2307/clock/Makefile.in (added) * c/src/lib/libbsp/powerpc/mvme2307/clock/ckinit.c (added) * c/src/lib/libbsp/powerpc/mvme2307/console/Makefile.in (added) * c/src/lib/libbsp/powerpc/mvme2307/console/console.c (added) * c/src/lib/libbsp/powerpc/mvme2307/console/printk.c (added) * c/src/lib/libbsp/powerpc/mvme2307/include/Makefile.in (added) * c/src/lib/libbsp/powerpc/mvme2307/include/bsp.h (added) * c/src/lib/libbsp/powerpc/mvme2307/include/coverhd.h (added) * c/src/lib/libbsp/powerpc/mvme2307/network/Makefile.in (added) * c/src/lib/libbsp/powerpc/mvme2307/network/network.c (added) * c/src/lib/libbsp/powerpc/mvme2307/nvram/Makefile.in (added) * c/src/lib/libbsp/powerpc/mvme2307/nvram/nvram.c (added) * c/src/lib/libbsp/powerpc/mvme2307/pci/Makefile.in (added) * c/src/lib/libbsp/powerpc/mvme2307/pci/NOTES (added) * c/src/lib/libbsp/powerpc/mvme2307/pci/interrupts.c (added) * c/src/lib/libbsp/powerpc/mvme2307/pci/isa_interrupts.c (added) * c/src/lib/libbsp/powerpc/mvme2307/pci/pci.c (added) * c/src/lib/libbsp/powerpc/mvme2307/shmsupp/Makefile.in (added) * c/src/lib/libbsp/powerpc/mvme2307/shmsupp/addrconv.c (added) * c/src/lib/libbsp/powerpc/mvme2307/shmsupp/getcfg.c (added) * c/src/lib/libbsp/powerpc/mvme2307/shmsupp/lock.c (added) * c/src/lib/libbsp/powerpc/mvme2307/shmsupp/mpisr.c (added) * c/src/lib/libbsp/powerpc/mvme2307/startup/Makefile.in (added) * c/src/lib/libbsp/powerpc/mvme2307/startup/bspclean.c (added) * c/src/lib/libbsp/powerpc/mvme2307/startup/bspstart.c (added) * c/src/lib/libbsp/powerpc/mvme2307/startup/linkcmds (added) * c/src/lib/libbsp/powerpc/mvme2307/startup/main.c (added) * c/src/lib/libbsp/powerpc/mvme2307/startup/setvec.c (added) * c/src/lib/libbsp/powerpc/mvme2307/timer/Makefile.in (added) * c/src/lib/libbsp/powerpc/mvme2307/timer/timer.c (added) * c/src/lib/libbsp/powerpc/mvme2307/times (added) * c/src/lib/libbsp/powerpc/mvme2307/wrapup/Makefile.in (added) * make/custom/mvme2307.cfg (added) Motorola MVME2307 BSP submitted by Jay Kulpinski ... Mon, 04 Oct 1999 19:15:14 GMT Joel Sherrill [811804fe] * Makefile.am (modified) * c/Makefile.am (modified) * c/src/Makefile.am (modified) * c/src/exec/Makefile.am (modified) * c/src/exec/libcsupport/Makefile.am (modified) * c/src/exec/libnetworking/Makefile.am (modified) * c/src/exec/librpc/include/rpc/Makefile.am (modified) * c/src/exec/posix/Makefile.am (modified) * c/src/exec/posix/include/Makefile.am (modified) * c/src/exec/posix/include/rtems/Makefile.am (modified) * c/src/exec/posix/include/rtems/posix/Makefile.am (modified) * c/src/exec/posix/include/sys/Makefile.am (modified) * c/src/exec/posix/inline/Makefile.am (modified) * c/src/exec/posix/inline/rtems/Makefile.am (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.am (modified) * c/src/exec/posix/macros/Makefile.am (modified) * c/src/exec/posix/macros/rtems/Makefile.am (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.am (modified) * c/src/exec/rtems/Makefile.am (modified) * c/src/exec/rtems/include/Makefile.am (modified) * c/src/exec/rtems/include/rtems/Makefile.am (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/inline/Makefile.am (modified) * c/src/exec/rtems/inline/rtems/Makefile.am (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/macros/Makefile.am (modified) * c/src/exec/rtems/macros/rtems/Makefile.am (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.am (modified) * c/src/exec/sapi/Makefile.am (modified) * c/src/exec/sapi/include/Makefile.am (modified) * c/src/exec/sapi/include/rtems/Makefile.am (modified) * c/src/exec/sapi/inline/Makefile.am (modified) * c/src/exec/sapi/inline/rtems/Makefile.am (modified) * c/src/exec/sapi/macros/Makefile.am (modified) * c/src/exec/sapi/macros/rtems/Makefile.am (modified) * c/src/exec/score/Makefile.am (modified) * c/src/exec/score/include/Makefile.am (modified) * c/src/exec/score/include/rtems/Makefile.am (modified) * c/src/exec/score/inline/Makefile.am (modified) * c/src/exec/score/inline/rtems/Makefile.am (modified) * c/src/exec/score/inline/rtems/score/Makefile.am (modified) * c/src/exec/score/macros/Makefile.am (modified) * c/src/exec/score/macros/rtems/Makefile.am (modified) * c/src/exec/score/macros/rtems/score/Makefile.am (modified) * c/src/exec/wrapup/Makefile.am (modified) * c/src/lib/Makefile.am (modified) * c/src/lib/include/motorola/Makefile.am (modified) * c/src/lib/include/rdbg/Makefile.am (modified) * c/src/lib/include/rdbg/i386/Makefile.am (modified) * c/src/lib/include/rdbg/powerpc/Makefile.am (modified) * c/src/lib/include/rpc/Makefile.am (modified) * c/src/lib/include/sys/Makefile.am (modified) * c/src/lib/include/zilog/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.am (modified) * c/src/lib/libchip/Makefile.am (modified) * c/src/lib/libmisc/Makefile.am (modified) * c/src/lib/start/Makefile.am (modified) * c/src/libchip/Makefile.am (modified) * c/src/libmisc/Makefile.am (modified) * c/src/libnetworking/Makefile.am (modified) * c/src/librdbg/include/rdbg/Makefile.am (modified) * c/src/librdbg/include/rdbg/i386/Makefile.am (modified) * c/src/librdbg/include/rdbg/powerpc/Makefile.am (modified) * c/src/librpc/include/rpc/Makefile.am (modified) * c/src/make/Makefile.am (modified) * c/src/make/compilers/Makefile.am (modified) * c/src/make/custom/Makefile.am (modified) * c/src/tests/Makefile.am (modified) * c/src/tests/libtests/Makefile.am (modified) * c/src/tests/mptests/Makefile.am (modified) * c/src/tests/psxtests/Makefile.am (modified) * c/src/tests/samples/Makefile.am (modified) * c/src/tests/sptests/Makefile.am (modified) * c/src/tests/support/Makefile.am (modified) * c/src/tests/support/include/Makefile.am (modified) * c/src/tests/tmtests/Makefile.am (modified) * c/src/tests/tmtests/include/Makefile.am (modified) * c/src/tests/tools/Makefile.am (modified) * c/src/tests/tools/generic/Makefile.am (modified) * cpukit/Makefile.am (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/librpc/include/rpc/Makefile.am (modified) * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/Makefile.am (modified) * cpukit/posix/inline/Makefile.am (modified) * cpukit/posix/macros/Makefile.am (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/Makefile.am (modified) * cpukit/rtems/inline/Makefile.am (modified) * cpukit/rtems/macros/Makefile.am (modified) * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/include/Makefile.am (modified) * cpukit/sapi/inline/Makefile.am (modified) * cpukit/sapi/macros/Makefile.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/Makefile.am (modified) * cpukit/score/inline/Makefile.am (modified) * cpukit/score/macros/Makefile.am (modified) * cpukit/wrapup/Makefile.am (modified) * make/Makefile.am (modified) * make/Templates/Makefile.am (modified) * make/compilers/Makefile.am (modified) * make/custom/Makefile.am (modified) * testsuites/Makefile.am (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/mptests/Makefile.am (modified) * testsuites/psxtests/Makefile.am (modified) * testsuites/samples/Makefile.am (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/support/Makefile.am (modified) * testsuites/tmtests/Makefile.am (modified) * testsuites/tmtests/include/Makefile.am (modified) * testsuites/tools/Makefile.am (modified) * testsuites/tools/generic/Makefile.am (modified) * tools/build/Makefile.am (modified) * tools/cpu/Makefile.am (modified) * tools/cpu/generic/Makefile.am (modified) * tools/cpu/hppa1.1/Makefile.am (modified) * tools/cpu/sh/Makefile.am (modified) * tools/cpu/unix/Makefile.am (modified) * tools/update/Makefile.am (modified) Patch from Ralf Corsepius to make fix bug ... Mon, 04 Oct 1999 17:33:23 GMT Joel Sherrill [4f021c0] * Makefile.in (deleted) * c/Makefile.in (deleted) * c/src/Makefile.in (deleted) * c/src/exec/Makefile.in (deleted) * c/src/exec/posix/Makefile.in (deleted) * c/src/exec/posix/include/Makefile.in (deleted) * c/src/exec/posix/include/rtems/Makefile.in (deleted) * c/src/exec/posix/include/rtems/posix/Makefile.in (deleted) * c/src/exec/posix/include/sys/Makefile.in (deleted) * c/src/exec/posix/inline/Makefile.in (deleted) * c/src/exec/posix/inline/rtems/Makefile.in (deleted) * c/src/exec/posix/inline/rtems/posix/Makefile.in (deleted) * c/src/exec/posix/macros/Makefile.in (deleted) * c/src/exec/posix/macros/rtems/Makefile.in (deleted) * c/src/exec/posix/macros/rtems/posix/Makefile.in (deleted) * c/src/exec/rtems/Makefile.in (deleted) * c/src/exec/rtems/include/Makefile.in (deleted) * c/src/exec/rtems/include/rtems/Makefile.in (deleted) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (deleted) * c/src/exec/rtems/inline/Makefile.in (deleted) * c/src/exec/rtems/inline/rtems/Makefile.in (deleted) * c/src/exec/rtems/inline/rtems/rtems/Makefile.in (deleted) * c/src/exec/rtems/macros/Makefile.in (deleted) * c/src/exec/rtems/macros/rtems/Makefile.in (deleted) * c/src/exec/rtems/macros/rtems/rtems/Makefile.in (deleted) * c/src/exec/sapi/Makefile.in (deleted) * c/src/exec/sapi/include/Makefile.in (deleted) * c/src/exec/sapi/include/rtems/Makefile.in (deleted) * c/src/exec/sapi/inline/Makefile.in (deleted) * c/src/exec/sapi/inline/rtems/Makefile.in (deleted) * c/src/exec/sapi/macros/Makefile.in (deleted) * c/src/exec/sapi/macros/rtems/Makefile.in (deleted) * c/src/exec/score/Makefile.in (deleted) * c/src/exec/score/include/Makefile.in (deleted) * c/src/exec/score/include/rtems/Makefile.in (deleted) * c/src/exec/score/inline/Makefile.in (deleted) * c/src/exec/score/inline/rtems/Makefile.in (deleted) * c/src/exec/score/inline/rtems/score/Makefile.in (deleted) * c/src/exec/score/macros/Makefile.in (deleted) * c/src/exec/score/macros/rtems/Makefile.in (deleted) * c/src/exec/score/macros/rtems/score/Makefile.in (deleted) * c/src/exec/wrapup/Makefile.in (deleted) * c/src/lib/Makefile.in (deleted) * c/src/lib/include/Makefile.in (deleted) * c/src/lib/include/motorola/Makefile.in (deleted) * c/src/lib/include/rdbg/Makefile.in (deleted) * c/src/lib/include/rdbg/i386/Makefile.in (deleted) * c/src/lib/include/rdbg/powerpc/Makefile.in (deleted) * c/src/lib/include/rpc/Makefile.in (deleted) * c/src/lib/include/sys/Makefile.in (deleted) * c/src/lib/include/zilog/Makefile.in (deleted) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (deleted) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (deleted) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.in (deleted) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/Makefile.in (deleted) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.in (deleted) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (deleted) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (deleted) * c/src/lib/libchip/Makefile.in (deleted) * c/src/lib/libmisc/Makefile.in (deleted) * c/src/lib/libnetworking/Makefile.in (deleted) * c/src/lib/start/Makefile.in (deleted) * c/src/libnetworking/Makefile.in (deleted) * c/src/librdbg/include/rdbg/Makefile.in (deleted) * c/src/librdbg/include/rdbg/i386/Makefile.in (deleted) * c/src/librdbg/include/rdbg/powerpc/Makefile.in (deleted) * c/src/librtems++/Makefile.in (deleted) * c/src/librtems++/include/Makefile.in (deleted) * c/src/librtems++/include/rtems++/Makefile.in (deleted) * c/src/make/Makefile.in (deleted) * c/src/make/compilers/Makefile.in (deleted) * c/src/make/custom/Makefile.in (deleted) * c/src/tests/Makefile.in (deleted) * c/src/tests/libtests/Makefile.in (deleted) * c/src/tests/mptests/Makefile.in (deleted) * c/src/tests/psxtests/Makefile.in (deleted) * c/src/tests/samples/Makefile.in (deleted) * c/src/tests/sptests/Makefile.in (deleted) * c/src/tests/support/Makefile.in (deleted) * c/src/tests/support/include/Makefile.in (deleted) * c/src/tests/tmtests/Makefile.in (deleted) * c/src/tests/tmtests/include/Makefile.in (deleted) * c/src/tests/tools/Makefile.in (deleted) * c/src/tests/tools/generic/Makefile.in (deleted) * doc/Makefile.in (deleted) * make/Makefile.in (deleted) * make/Templates/Makefile.in (deleted) * make/compilers/Makefile.in (deleted) * make/custom/Makefile.in (deleted) * tools/Makefile.in (deleted) * tools/build/Makefile.in (deleted) * tools/cpu/Makefile.in (deleted) * tools/cpu/generic/Makefile.in (deleted) * tools/cpu/sh/Makefile.in (deleted) * tools/cpu/unix/Makefile.in (deleted) * tools/update/Makefile.in (deleted) Removed Makefile.in generated from Makefile.am Mon, 04 Oct 1999 13:30:15 GMT Joel Sherrill [473b4e5] * Makefile.in (modified) * aclocal.m4 (modified) * c/Makefile.in (modified) * c/aclocal.m4 (modified) * c/configure (modified) * c/src/Makefile.in (modified) * c/src/aclocal.m4 (modified) * c/src/configure (modified) * c/src/exec/Makefile.in (modified) * c/src/exec/aclocal.m4 (modified) * c/src/exec/configure (modified) * c/src/exec/posix/Makefile.in (modified) * c/src/exec/posix/aclocal.m4 (modified) * c/src/exec/posix/configure (modified) * c/src/exec/posix/include/Makefile.in (modified) * c/src/exec/posix/include/rtems/Makefile.in (modified) * c/src/exec/posix/include/rtems/posix/Makefile.in (modified) * c/src/exec/posix/include/sys/Makefile.in (modified) * c/src/exec/posix/inline/Makefile.in (modified) * c/src/exec/posix/inline/rtems/Makefile.in (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.in (modified) * c/src/exec/posix/macros/Makefile.in (modified) * c/src/exec/posix/macros/rtems/Makefile.in (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.in (modified) * c/src/exec/rtems/Makefile.in (modified) * c/src/exec/rtems/include/Makefile.in (modified) * c/src/exec/rtems/include/rtems/Makefile.in (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/inline/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.in (modified) * c/src/exec/sapi/Makefile.in (modified) * c/src/exec/sapi/include/Makefile.in (modified) * c/src/exec/sapi/include/rtems/Makefile.in (modified) * c/src/exec/sapi/inline/Makefile.in (modified) * c/src/exec/sapi/inline/rtems/Makefile.in (modified) * c/src/exec/sapi/macros/Makefile.in (modified) * c/src/exec/sapi/macros/rtems/Makefile.in (modified) * c/src/exec/score/Makefile.in (modified) * c/src/exec/score/cpu/aclocal.m4 (modified) * c/src/exec/score/include/Makefile.in (modified) * c/src/exec/score/include/rtems/Makefile.in (modified) * c/src/exec/score/inline/Makefile.in (modified) * c/src/exec/score/inline/rtems/Makefile.in (modified) * c/src/exec/score/inline/rtems/score/Makefile.in (modified) * c/src/exec/score/macros/Makefile.in (modified) * c/src/exec/score/macros/rtems/Makefile.in (modified) * c/src/exec/score/macros/rtems/score/Makefile.in (modified) * c/src/exec/wrapup/Makefile.in (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/aclocal.m4 (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/include/motorola/Makefile.in (modified) * c/src/lib/include/rdbg/Makefile.in (modified) * c/src/lib/include/rdbg/i386/Makefile.in (modified) * c/src/lib/include/rdbg/powerpc/Makefile.in (modified) * c/src/lib/include/rpc/Makefile.in (modified) * c/src/lib/include/sys/Makefile.in (modified) * c/src/lib/include/zilog/Makefile.in (modified) * c/src/lib/libbsp/aclocal.m4 (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/aclocal.m4 (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/aclocal.m4 (modified) * c/src/lib/libbsp/i386/pc386/tools/configure (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/aclocal.m4 (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/configure (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/aclocal.m4 (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/aclocal.m4 (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/aclocal.m4 (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/aclocal.m4 (modified) * c/src/lib/libbsp/unix/posix/tools/configure (modified) * c/src/lib/libchip/Makefile.in (modified) * c/src/lib/libchip/aclocal.m4 (modified) * c/src/lib/libchip/configure (modified) * c/src/lib/libcpu/aclocal.m4 (modified) * c/src/lib/libmisc/Makefile.in (modified) * c/src/lib/libmisc/aclocal.m4 (modified) * c/src/lib/libmisc/configure (modified) * c/src/lib/libnetworking/Makefile.in (modified) * c/src/lib/libnetworking/aclocal.m4 (modified) * c/src/lib/libnetworking/configure (modified) * c/src/lib/librdbg/aclocal.m4 (modified) * c/src/lib/librdbg/configure (modified) * c/src/lib/librpc/aclocal.m4 (modified) * c/src/lib/start/Makefile.in (modified) * c/src/lib/start/a29k/aclocal.m4 (modified) * c/src/lib/start/i960/aclocal.m4 (modified) * c/src/lib/start/m68k/aclocal.m4 (modified) * c/src/lib/start/mips64orion/aclocal.m4 (modified) * c/src/lib/start/sh/aclocal.m4 (modified) * c/src/libnetworking/Makefile.in (modified) * c/src/libnetworking/aclocal.m4 (modified) * c/src/libnetworking/configure (modified) * c/src/librdbg/include/rdbg/Makefile.in (modified) * c/src/librdbg/include/rdbg/i386/Makefile.in (modified) * c/src/librdbg/include/rdbg/powerpc/Makefile.in (modified) * c/src/librdbg/src/aclocal.m4 (modified) * c/src/librdbg/src/configure (modified) * c/src/librtems++/Makefile.in (modified) * c/src/librtems++/aclocal.m4 (modified) * c/src/librtems++/configure (modified) * c/src/librtems++/include/Makefile.in (modified) * c/src/librtems++/include/rtems++/Makefile.in (modified) * c/src/make/Makefile.in (modified) * c/src/make/aclocal.m4 (modified) * c/src/make/compilers/Makefile.in (modified) * c/src/make/configure (modified) * c/src/make/custom/Makefile.in (modified) * c/src/tests/Makefile.in (modified) * c/src/tests/aclocal.m4 (modified) * c/src/tests/configure (modified) * c/src/tests/libtests/Makefile.in (modified) * c/src/tests/libtests/aclocal.m4 (modified) * c/src/tests/libtests/configure (modified) * c/src/tests/mptests/Makefile.in (modified) * c/src/tests/mptests/aclocal.m4 (modified) * c/src/tests/mptests/configure (modified) * c/src/tests/psxtests/Makefile.in (modified) * c/src/tests/psxtests/aclocal.m4 (modified) * c/src/tests/psxtests/configure (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/tests/samples/aclocal.m4 (modified) * c/src/tests/samples/configure (modified) * c/src/tests/sptests/Makefile.in (modified) * c/src/tests/sptests/aclocal.m4 (modified) * c/src/tests/sptests/configure (modified) * c/src/tests/support/Makefile.in (modified) * c/src/tests/support/aclocal.m4 (modified) * c/src/tests/support/configure (modified) * c/src/tests/support/include/Makefile.in (modified) * c/src/tests/tmtests/Makefile.in (modified) * c/src/tests/tmtests/aclocal.m4 (modified) * c/src/tests/tmtests/configure (modified) * c/src/tests/tmtests/include/Makefile.in (modified) * c/src/tests/tools/Makefile.in (modified) * c/src/tests/tools/aclocal.m4 (modified) * c/src/tests/tools/configure (modified) * c/src/tests/tools/generic/Makefile.in (modified) * c/src/tests/tools/generic/aclocal.m4 (modified) * c/src/tests/tools/generic/configure (modified) * configure (modified) * doc/Makefile.in (modified) * make/Makefile.in (modified) * make/Templates/Makefile.in (modified) * make/compilers/Makefile.in (modified) * make/custom/Makefile.in (modified) * tools/Makefile.in (modified) * tools/build/Makefile.in (modified) * tools/build/aclocal.m4 (modified) * tools/build/configure (modified) * tools/cpu/Makefile.in (modified) * tools/cpu/aclocal.m4 (modified) * tools/cpu/configure (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/generic/aclocal.m4 (modified) * tools/cpu/generic/configure (modified) * tools/cpu/hppa1.1/aclocal.m4 (modified) * tools/cpu/hppa1.1/configure (modified) * tools/cpu/sh/Makefile.in (modified) * tools/cpu/sh/aclocal.m4 (modified) * tools/cpu/sh/configure (modified) * tools/cpu/unix/Makefile.in (modified) * tools/cpu/unix/aclocal.m4 (modified) * tools/cpu/unix/configure (modified) * tools/update/Makefile.in (modified) * tools/update/aclocal.m4 (modified) * tools/update/configure (modified) Regenerated. Tue, 07 Sep 1999 13:45:03 GMT Joel Sherrill [e1d8abb] * Makefile.in (modified) * aclocal/check-cxx.m4 (modified) * automake/local.am (modified) * c/Makefile.in (modified) * c/src/Makefile.am (modified) * c/src/Makefile.in (modified) * c/src/aclocal.m4 (modified) * c/src/configure (modified) * c/src/configure.in (modified) * c/src/exec/Makefile.am (added) * c/src/exec/Makefile.in (modified) * c/src/exec/aclocal.m4 (modified) * c/src/exec/configure (modified) * c/src/exec/configure.in (modified) * c/src/exec/libcsupport/Makefile.am (added) * c/src/exec/libnetworking/Makefile.am (added) * c/src/exec/librpc/include/rpc/Makefile.am (added) * c/src/exec/posix/Makefile.am (added) * c/src/exec/posix/Makefile.in (modified) * c/src/exec/posix/configure.in (added) * c/src/exec/posix/include/Makefile.am (added) * c/src/exec/posix/include/Makefile.in (modified) * c/src/exec/posix/include/rtems/Makefile.am (added) * c/src/exec/posix/include/rtems/Makefile.in (modified) * c/src/exec/posix/include/rtems/posix/Makefile.am (added) * c/src/exec/posix/include/rtems/posix/Makefile.in (modified) * c/src/exec/posix/include/sys/Makefile.am (added) * c/src/exec/posix/include/sys/Makefile.in (modified) * c/src/exec/posix/inline/Makefile.am (added) * c/src/exec/posix/inline/Makefile.in (modified) * c/src/exec/posix/inline/rtems/Makefile.am (added) * c/src/exec/posix/inline/rtems/Makefile.in (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.am (added) * c/src/exec/posix/inline/rtems/posix/Makefile.in (modified) * c/src/exec/posix/macros/Makefile.am (added) * c/src/exec/posix/macros/Makefile.in (modified) * c/src/exec/posix/macros/rtems/Makefile.am (added) * c/src/exec/posix/macros/rtems/Makefile.in (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.am (added) * c/src/exec/posix/macros/rtems/posix/Makefile.in (modified) * c/src/exec/posix/optman/Makefile.in (modified) * c/src/exec/posix/src/Makefile.in (modified) * c/src/exec/rtems/Makefile.am (added) * c/src/exec/rtems/Makefile.in (modified) * c/src/exec/rtems/include/Makefile.am (added) * c/src/exec/rtems/include/Makefile.in (modified) * c/src/exec/rtems/include/rtems/Makefile.am (added) * c/src/exec/rtems/include/rtems/Makefile.in (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.am (added) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/inline/Makefile.am (added) * c/src/exec/rtems/inline/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/Makefile.am (added) * c/src/exec/rtems/inline/rtems/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.am (added) * c/src/exec/rtems/inline/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/Makefile.am (added) * c/src/exec/rtems/macros/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/Makefile.am (added) * c/src/exec/rtems/macros/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.am (added) * c/src/exec/rtems/macros/rtems/rtems/Makefile.in (modified) * c/src/exec/sapi/Makefile.am (added) * c/src/exec/sapi/Makefile.in (modified) * c/src/exec/sapi/include/Makefile.am (added) * c/src/exec/sapi/include/Makefile.in (modified) * c/src/exec/sapi/include/rtems/Makefile.am (added) * c/src/exec/sapi/include/rtems/Makefile.in (modified) * c/src/exec/sapi/inline/Makefile.am (added) * c/src/exec/sapi/inline/Makefile.in (modified) * c/src/exec/sapi/inline/rtems/Makefile.am (added) * c/src/exec/sapi/inline/rtems/Makefile.in (modified) * c/src/exec/sapi/macros/Makefile.am (added) * c/src/exec/sapi/macros/Makefile.in (modified) * c/src/exec/sapi/macros/rtems/Makefile.am (added) * c/src/exec/sapi/macros/rtems/Makefile.in (modified) * c/src/exec/score/Makefile.am (added) * c/src/exec/score/Makefile.in (modified) * c/src/exec/score/cpu/Makefile.in (modified) * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/a29k/wrap/Makefile.in (modified) * c/src/exec/score/cpu/configure.in (added) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/wrap/Makefile.in (modified) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/i386/wrap/Makefile.in (modified) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/i960/wrap/Makefile.in (modified) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/m68k/wrap/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/wrap/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/wrap/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/mpc750/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/other_cpu/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/shared/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/wrap/Makefile.in (modified) * c/src/exec/score/cpu/sh/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sh/wrap/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sparc/wrap/Makefile.in (modified) * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/unix/wrap/Makefile.in (modified) * c/src/exec/score/include/Makefile.am (added) * c/src/exec/score/include/Makefile.in (modified) * c/src/exec/score/include/rtems/Makefile.am (added) * c/src/exec/score/include/rtems/Makefile.in (modified) * c/src/exec/score/inline/Makefile.am (added) * c/src/exec/score/inline/Makefile.in (modified) * c/src/exec/score/inline/rtems/Makefile.am (added) * c/src/exec/score/inline/rtems/Makefile.in (modified) * c/src/exec/score/inline/rtems/score/Makefile.am (added) * c/src/exec/score/inline/rtems/score/Makefile.in (modified) * c/src/exec/score/macros/Makefile.am (added) * c/src/exec/score/macros/Makefile.in (modified) * c/src/exec/score/macros/rtems/Makefile.am (added) * c/src/exec/score/macros/rtems/Makefile.in (modified) * c/src/exec/score/macros/rtems/score/Makefile.am (added) * c/src/exec/score/macros/rtems/score/Makefile.in (modified) * c/src/exec/wrapup/Makefile.am (added) * c/src/exec/wrapup/Makefile.in (modified) * c/src/exec/wrapup/posix/Makefile.in (modified) * c/src/lib/Makefile.am (added) * c/src/lib/Makefile.in (modified) * c/src/lib/aclocal.m4 (modified) * c/src/lib/configure (modified) * c/src/lib/configure.in (modified) * c/src/lib/include/Makefile.am (added) * c/src/lib/include/Makefile.in (modified) * c/src/lib/include/motorola/Makefile.am (added) * c/src/lib/include/rdbg/Makefile.am (added) * c/src/lib/include/rdbg/i386/Makefile.am (added) * c/src/lib/include/rdbg/powerpc/Makefile.am (added) * c/src/lib/include/rpc/Makefile.am (added) * c/src/lib/include/sys/Makefile.am (added) * c/src/lib/include/zilog/Makefile.am (added) * c/src/lib/libbsp/Makefile.am.new (added) * c/src/lib/libbsp/Makefile.in (modified) * c/src/lib/libbsp/a29k/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.in (modified) * c/src/lib/libbsp/bare/Makefile.in (modified) * c/src/lib/libbsp/bare/include/Makefile.in (modified) * c/src/lib/libbsp/bare/wrapup/Makefile.in (modified) * c/src/lib/libbsp/configure.in (added) * c/src/lib/libbsp/hppa1.1/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/console/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/include/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/network/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/3c509/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/dec21140/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/ne2000/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wd8003/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/comm/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/io/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/irq/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/pci/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/include/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/network/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/start/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i960/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/bootloader/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/irq/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/openpic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/residual/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startsim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.in (modified) * c/src/lib/libbsp/sh/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/include/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.in (modified) * c/src/lib/libbsp/shmdr/Makefile.in (modified) * c/src/lib/libbsp/sparc/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/gnatsupp/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startsis/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/unix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.in (modified) * c/src/lib/libchip/Makefile.am (added) * c/src/lib/libchip/Makefile.in (modified) * c/src/lib/libchip/configure.in (added) * c/src/lib/libchip/network/Makefile.in (modified) * c/src/lib/libchip/rtc/Makefile.in (modified) * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/lib/libcpu/Makefile.in (modified) * c/src/lib/libcpu/configure.in (added) * c/src/lib/libcpu/hppa1.1/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/runway/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.in (modified) * c/src/lib/libcpu/i386/Makefile.in (modified) * c/src/lib/libcpu/i386/wrapup/Makefile.in (modified) * c/src/lib/libcpu/m68k/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/include/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc505/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc505/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc505/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/exceptions/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/mmu/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/wrapup/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/shared/Makefile.in (modified) * c/src/lib/libcpu/powerpc/wrapup/Makefile.in (modified) * c/src/lib/libcpu/sh/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/console/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.in (modified) * c/src/lib/libcpu/sparc/Makefile.in (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.in (modified) * c/src/lib/libcpu/sparc/syscall/Makefile.in (modified) * c/src/lib/libmisc/Makefile.am (added) * c/src/lib/libmisc/Makefile.in (modified) * c/src/lib/libmisc/assoc/Makefile.in (modified) * c/src/lib/libmisc/configure.in (added) * c/src/lib/libmisc/cpuuse/Makefile.in (modified) * c/src/lib/libmisc/dumpbuf/Makefile.in (modified) * c/src/lib/libmisc/error/Makefile.in (modified) * c/src/lib/libmisc/monitor/Makefile.in (modified) * c/src/lib/libmisc/rtmonuse/Makefile.in (modified) * c/src/lib/libmisc/stackchk/Makefile.in (modified) * c/src/lib/libmisc/untar/Makefile.in (modified) * c/src/lib/libmisc/wrapup/Makefile.in (modified) * c/src/lib/libnetworking/Makefile.am (added) * c/src/lib/libnetworking/Makefile.in (modified) * c/src/lib/libnetworking/configure.in (added) * c/src/lib/libnetworking/include/Makefile.in (modified) * c/src/lib/libnetworking/kern/Makefile.in (modified) * c/src/lib/libnetworking/lib/Makefile.in (modified) * c/src/lib/libnetworking/libc/Makefile.in (modified) * c/src/lib/libnetworking/net/Makefile.in (modified) * c/src/lib/libnetworking/netinet/Makefile.in (modified) * c/src/lib/libnetworking/nfs/Makefile.in (modified) * c/src/lib/libnetworking/rtems/Makefile.in (modified) * c/src/lib/libnetworking/rtems_servers/Makefile.in (modified) * c/src/lib/libnetworking/wrapup/Makefile.in (modified) * c/src/lib/librdbg/Makefile.in (modified) * c/src/lib/librdbg/configure.in (added) * c/src/lib/librdbg/i386/Makefile.in (modified) * c/src/lib/librdbg/i386/pc386/Makefile.in (modified) * c/src/lib/librdbg/powerpc/Makefile.in (modified) * c/src/lib/librdbg/powerpc/mcp750/Makefile.in (modified) * c/src/lib/librpc/Makefile.in (modified) * c/src/lib/librpc/configure.in (added) * c/src/lib/start/Makefile.am (added) * c/src/lib/start/Makefile.in (modified) * c/src/lib/start/a29k/Makefile.in (modified) * c/src/lib/start/a29k/configure.in (added) * c/src/lib/start/i960/Makefile.in (modified) * c/src/lib/start/i960/configure.in (added) * c/src/lib/start/m68k/Makefile.in (modified) * c/src/lib/start/m68k/configure.in (added) * c/src/lib/start/mips64orion/Makefile.in (modified) * c/src/lib/start/mips64orion/configure.in (added) * c/src/lib/start/sh/Makefile.in (modified) * c/src/lib/start/sh/configure.in (added) * c/src/libchip/Makefile.am (added) * c/src/libchip/configure.in (added) * c/src/libchip/network/Makefile.in (modified) * c/src/libchip/rtc/Makefile.in (modified) * c/src/libchip/serial/Makefile.in (modified) * c/src/libmisc/Makefile.am (added) * c/src/libmisc/assoc/Makefile.in (modified) * c/src/libmisc/configure.in (added) * c/src/libmisc/cpuuse/Makefile.in (modified) * c/src/libmisc/dumpbuf/Makefile.in (modified) * c/src/libmisc/error/Makefile.in (modified) * c/src/libmisc/monitor/Makefile.in (modified) * c/src/libmisc/rtmonuse/Makefile.in (modified) * c/src/libmisc/stackchk/Makefile.in (modified) * c/src/libmisc/untar/Makefile.in (modified) * c/src/libmisc/wrapup/Makefile.in (modified) * c/src/libnetworking/Makefile.am (added) * c/src/libnetworking/Makefile.in (modified) * c/src/libnetworking/configure.in (added) * c/src/libnetworking/include/Makefile.in (modified) * c/src/libnetworking/kern/Makefile.in (modified) * c/src/libnetworking/lib/Makefile.in (modified) * c/src/libnetworking/libc/Makefile.in (modified) * c/src/libnetworking/net/Makefile.in (modified) * c/src/libnetworking/netinet/Makefile.in (modified) * c/src/libnetworking/nfs/Makefile.in (modified) * c/src/libnetworking/rtems/Makefile.in (modified) * c/src/libnetworking/rtems_servers/Makefile.in (modified) * c/src/libnetworking/wrapup/Makefile.in (modified) * c/src/librdbg/include/rdbg/Makefile.am (added) * c/src/librdbg/include/rdbg/i386/Makefile.am (added) * c/src/librdbg/include/rdbg/powerpc/Makefile.am (added) * c/src/librdbg/src/Makefile.in (modified) * c/src/librdbg/src/configure.in (added) * c/src/librdbg/src/i386/Makefile.in (modified) * c/src/librdbg/src/i386/any/Makefile.in (modified) * c/src/librdbg/src/i386/pc386/Makefile.in (modified) * c/src/librdbg/src/powerpc/Makefile.in (modified) * c/src/librdbg/src/powerpc/mcp750/Makefile.in (modified) * c/src/librpc/include/rpc/Makefile.am (added) * c/src/librpc/src/Makefile.in (modified) * c/src/librtems++/Makefile.am (added) * c/src/librtems++/Makefile.in (added) * c/src/librtems++/aclocal.m4 (added) * c/src/librtems++/configure (added) * c/src/librtems++/configure.in (added) * c/src/librtems++/include/Makefile.am (added) * c/src/librtems++/include/Makefile.in (added) * c/src/librtems++/include/rtems++/Makefile.am (added) * c/src/librtems++/include/rtems++/Makefile.in (added) * c/src/make/Makefile.in (modified) * c/src/make/aclocal.m4 (modified) * c/src/make/compilers/Makefile.in (modified) * c/src/make/custom/Makefile.in (modified) * c/src/make/custom/default.cfg.in (modified) * c/src/tests/Makefile.in (modified) * c/src/tests/libtests/Makefile.in (modified) * c/src/tests/libtests/aclocal.m4 (modified) * c/src/tests/mptests/Makefile.in (modified) * c/src/tests/psxtests/Makefile.in (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/tests/samples/aclocal.m4 (modified) * c/src/tests/sptests/Makefile.in (modified) * c/src/tests/support/Makefile.in (modified) * c/src/tests/support/include/Makefile.in (modified) * c/src/tests/tmtests/Makefile.in (modified) * c/src/tests/tmtests/include/Makefile.in (modified) * c/src/tests/tools/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.in (modified) * cpukit/Makefile.am (added) * cpukit/libcsupport/Makefile.am (added) * cpukit/libmisc/Makefile.am (added) * cpukit/libnetworking/Makefile.am (added) * cpukit/librpc/include/rpc/Makefile.am (added) * cpukit/posix/Makefile.am (added) * cpukit/posix/include/Makefile.am (added) * cpukit/posix/inline/Makefile.am (added) * cpukit/posix/macros/Makefile.am (added) * cpukit/rtems/Makefile.am (added) * cpukit/rtems/include/Makefile.am (added) * cpukit/rtems/inline/Makefile.am (added) * cpukit/rtems/macros/Makefile.am (added) * cpukit/sapi/Makefile.am (added) * cpukit/sapi/include/Makefile.am (added) * cpukit/sapi/inline/Makefile.am (added) * cpukit/sapi/macros/Makefile.am (added) * cpukit/score/Makefile.am (added) * cpukit/score/include/Makefile.am (added) * cpukit/score/inline/Makefile.am (added) * cpukit/score/macros/Makefile.am (added) * cpukit/wrapup/Makefile.am (added) * doc/Makefile.in (modified) * make/Makefile.in (modified) * make/Templates/Makefile.in (modified) * make/compilers/Makefile.in (modified) * make/custom/Makefile.in (modified) * tools/Makefile.in (modified) * tools/build/Makefile.in (modified) * tools/build/configure (modified) * tools/build/configure.in (modified) * tools/cpu/Makefile.am (modified) * tools/cpu/Makefile.in (modified) * tools/cpu/configure (modified) * tools/cpu/configure.in (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/sh/Makefile.in (modified) * tools/cpu/unix/Makefile.in (modified) * tools/update/Makefile.in (modified) * tools/update/configure (modified) * tools/update/configure.in (modified) Applied patch rtems-rc-19990820-6.diff.gz from Ralf Corsepius ... Wed, 18 Aug 1999 16:49:52 GMT Joel Sherrill [6fc973e] * aclocal.m4 (modified) * aclocal/target.m4 (modified) * c/src/exec/libcsupport/src/malloc.c (modified) * c/src/lib/configure (modified) * c/src/lib/configure.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/startup/bspstart.c (modified) * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libc/malloc.c (modified) * c/src/lib/libmisc/monitor/mon-symbols.c (modified) * c/src/libmisc/monitor/mon-symbols.c (modified) * configure (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libmisc/monitor/mon-symbols.c (modified) * make/custom/Linux-posix.cfg (modified) Patch from Ralf Corsepius : Here is ... Thu, 12 Aug 1999 18:22:17 GMT Joel Sherrill [ea562ee9] * aclocal/sysv-ipc.m4 (modified) * c/src/exec/aclocal.m4 (modified) * c/src/exec/configure (modified) * c/src/exec/score/cpu/unix/cpu.c (modified) * c/src/exec/score/cpu/unix/wrap/Makefile.in (modified) * c/src/lib/aclocal.m4 (modified) * c/src/lib/configure (modified) * c/src/lib/configure.in (modified) * c/src/make/configure (modified) * c/src/make/configure.in (modified) * c/src/make/custom/Makefile.am (modified) * c/src/make/custom/Makefile.in (modified) * c/src/make/custom/default.cfg.in (modified) * cpukit/score/cpu/unix/cpu.c (modified) * make/custom/mcp750.cfg (modified) * make/custom/posix.cfg (modified) Patch from Ralf Corsepius : After ... Wed, 11 Aug 1999 23:58:16 GMT Joel Sherrill [8aefe83] * make/custom/ts_386ex.cfg (modified) Patch from Tony R. Ambardar : I'm attaching a ... Tue, 10 Aug 1999 16:41:44 GMT Joel Sherrill [981b99f] * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/mpc750/cpu.c (modified) * c/src/exec/score/cpu/powerpc/mpc750/cpu.h (modified) * c/src/lib/include/rdbg/i386/rdbg_f.h (modified) * c/src/lib/include/rdbg/i386/reg.h (modified) * c/src/lib/include/rdbg/powerpc/rdbg_f.h (added) * c/src/lib/include/rdbg/powerpc/reg.h (added) * c/src/lib/include/rdbg/rdbg.h (modified) * c/src/lib/include/rdbg/servrpc.h (modified) * c/src/lib/libbsp/powerpc/mcp750/dec21140/dec21140.c (modified) * c/src/lib/libbsp/powerpc/mcp750/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/mcp750/irq/i8259.c (modified) * c/src/lib/libbsp/powerpc/mcp750/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/mcp750/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/mcp750/irq/irq_asm.S (modified) * c/src/lib/libbsp/powerpc/mcp750/start/start.S (modified) * c/src/lib/libbsp/powerpc/mcp750/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/mcp750/vectors/vectors.S (modified) * c/src/lib/libbsp/powerpc/mcp750/vectors/vectors.h (modified) * c/src/lib/libbsp/powerpc/mcp750/vectors/vectors_init.c (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/dec21140/dec21140.c (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/i8259.c (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/irq.c (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/irq.h (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/irq_asm.S (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/start.S (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/vectors.S (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/vectors.h (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/vectors_init.c (modified) * c/src/lib/librdbg/_servtgt.c (modified) * c/src/lib/librdbg/awk.svc (modified) * c/src/lib/librdbg/excep.c (added) * c/src/lib/librdbg/i386/excep.c (modified) * c/src/lib/librdbg/i386/excep_f.c (added) * c/src/lib/librdbg/i386/pc386/Makefile.in (modified) * c/src/lib/librdbg/i386/pc386/remdeb_f.x (modified) * c/src/lib/librdbg/i386/rdbg_cpu_asm.S (modified) * c/src/lib/librdbg/i386/rdbg_f.c (modified) * c/src/lib/librdbg/powerpc/Makefile.in (added) * c/src/lib/librdbg/powerpc/excep_f.c (added) * c/src/lib/librdbg/powerpc/mcp750/Makefile.in (added) * c/src/lib/librdbg/powerpc/mcp750/remdeb_f.x (added) * c/src/lib/librdbg/powerpc/rdbg_cpu_asm.S (added) * c/src/lib/librdbg/powerpc/rdbg_f.c (added) * c/src/lib/librdbg/ptrace.c (modified) * c/src/lib/librdbg/rdbg.c (modified) * c/src/lib/librdbg/remdeb.x (modified) * c/src/lib/librdbg/servbkpt.c (modified) * c/src/lib/librdbg/servcon.c (modified) * c/src/lib/librdbg/servrpc.c (modified) * c/src/lib/librdbg/servtgt.c (modified) * c/src/lib/librdbg/servtsp.c (modified) * c/src/lib/librdbg/servutil.c (modified) * c/src/librdbg/include/rdbg/i386/rdbg_f.h (modified) * c/src/librdbg/include/rdbg/i386/reg.h (modified) * c/src/librdbg/include/rdbg/powerpc/rdbg_f.h (added) * c/src/librdbg/include/rdbg/powerpc/reg.h (added) * c/src/librdbg/include/rdbg/rdbg.h (modified) * c/src/librdbg/include/rdbg/servrpc.h (modified) * c/src/librdbg/src/_servtgt.c (modified) * c/src/librdbg/src/awk.svc (modified) * c/src/librdbg/src/excep.c (added) * c/src/librdbg/src/i386/any/Makefile.in (modified) * c/src/librdbg/src/i386/any/remdeb_f.x (modified) * c/src/librdbg/src/i386/excep.c (modified) * c/src/librdbg/src/i386/excep_f.c (added) * c/src/librdbg/src/i386/pc386/Makefile.in (modified) * c/src/librdbg/src/i386/pc386/remdeb_f.x (modified) * c/src/librdbg/src/i386/rdbg_cpu_asm.S (modified) * c/src/librdbg/src/i386/rdbg_f.c (modified) * c/src/librdbg/src/powerpc/Makefile.in (added) * c/src/librdbg/src/powerpc/excep_f.c (added) * c/src/librdbg/src/powerpc/mcp750/Makefile.in (added) * c/src/librdbg/src/powerpc/mcp750/remdeb_f.x (added) * c/src/librdbg/src/powerpc/new_exception_processing/remdeb_f.x (added) * c/src/librdbg/src/powerpc/rdbg_cpu_asm.S (added) * c/src/librdbg/src/powerpc/rdbg_f.c (added) * c/src/librdbg/src/ptrace.c (modified) * c/src/librdbg/src/rdbg.c (modified) * c/src/librdbg/src/remdeb.x (modified) * c/src/librdbg/src/servbkpt.c (modified) * c/src/librdbg/src/servcon.c (modified) * c/src/librdbg/src/servrpc.c (modified) * c/src/librdbg/src/servtgt.c (modified) * c/src/librdbg/src/servtsp.c (modified) * c/src/librdbg/src/servutil.c (modified) * make/custom/mcp750.cfg (modified) Patch from Eric Valette and Emmanuel Raguet ... Fri, 06 Aug 1999 17:55:25 GMT Joel Sherrill [3a8915e] * aclocal/check-multiprocessing.m4 (modified) * aclocal/check-rdbg.m4 (modified) * c/Makefile.am (modified) * c/src/exec/aclocal.m4 (modified) * c/src/exec/configure (modified) * c/src/exec/configure.in (modified) * c/src/lib/aclocal.m4 (modified) * c/src/lib/configure (modified) * c/src/lib/configure.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/libbsp/bare/include/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/bsp_specs (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.in (modified) * c/src/lib/libmisc/wrapup/Makefile.in (modified) * c/src/lib/start/sh/Makefile.in (modified) * c/src/libmisc/wrapup/Makefile.in (modified) * c/src/make/Makefile.am (modified) * c/src/make/Makefile.in (modified) * c/src/make/Makefile.inc.in (modified) * c/src/make/Templates/Makefile.in (modified) * c/src/make/aclocal.m4 (modified) * c/src/make/bsp.cfg.in (modified) * c/src/make/compilers/Makefile.in (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/configure (modified) * c/src/make/configure.in (modified) * c/src/make/custom/Makefile.in (modified) * c/src/make/custom/default.cfg.in (modified) * c/src/make/host.cfg.in (modified) * c/src/tests/Makefile.in (modified) * c/src/tests/aclocal.m4 (modified) * c/src/tests/configure (modified) * c/src/tests/configure.in (modified) * c/src/tests/libtests/Makefile.in (modified) * c/src/tests/libtests/cpuuse/Makefile.in (modified) * c/src/tests/libtests/malloctest/Makefile.in (modified) * c/src/tests/libtests/monitor/Makefile.in (modified) * c/src/tests/libtests/rtems++/Makefile.in (modified) * c/src/tests/libtests/rtmonuse/Makefile.in (modified) * c/src/tests/libtests/stackchk/Makefile.in (modified) * c/src/tests/libtests/termios/Makefile.in (modified) * c/src/tests/mptests/Makefile.in (modified) * c/src/tests/mptests/mp01/Makefile.in (modified) * c/src/tests/mptests/mp01/node1/Makefile.in (modified) * c/src/tests/mptests/mp01/node2/Makefile.in (modified) * c/src/tests/mptests/mp02/Makefile.in (modified) * c/src/tests/mptests/mp02/node1/Makefile.in (modified) * c/src/tests/mptests/mp02/node2/Makefile.in (modified) * c/src/tests/mptests/mp03/Makefile.in (modified) * c/src/tests/mptests/mp03/node1/Makefile.in (modified) * c/src/tests/mptests/mp03/node2/Makefile.in (modified) * c/src/tests/mptests/mp04/Makefile.in (modified) * c/src/tests/mptests/mp04/node1/Makefile.in (modified) * c/src/tests/mptests/mp04/node2/Makefile.in (modified) * c/src/tests/mptests/mp05/Makefile.in (modified) * c/src/tests/mptests/mp05/node1/Makefile.in (modified) * c/src/tests/mptests/mp05/node2/Makefile.in (modified) * c/src/tests/mptests/mp06/Makefile.in (modified) * c/src/tests/mptests/mp06/node1/Makefile.in (modified) * c/src/tests/mptests/mp06/node2/Makefile.in (modified) * c/src/tests/mptests/mp07/Makefile.in (modified) * c/src/tests/mptests/mp07/node1/Makefile.in (modified) * c/src/tests/mptests/mp07/node2/Makefile.in (modified) * c/src/tests/mptests/mp08/Makefile.in (modified) * c/src/tests/mptests/mp08/node1/Makefile.in (modified) * c/src/tests/mptests/mp08/node2/Makefile.in (modified) * c/src/tests/mptests/mp09/Makefile.in (modified) * c/src/tests/mptests/mp09/node1/Makefile.in (modified) * c/src/tests/mptests/mp09/node2/Makefile.in (modified) * c/src/tests/mptests/mp10/Makefile.in (modified) * c/src/tests/mptests/mp10/node1/Makefile.in (modified) * c/src/tests/mptests/mp10/node2/Makefile.in (modified) * c/src/tests/mptests/mp11/Makefile.in (modified) * c/src/tests/mptests/mp11/node1/Makefile.in (modified) * c/src/tests/mptests/mp11/node2/Makefile.in (modified) * c/src/tests/mptests/mp12/Makefile.in (modified) * c/src/tests/mptests/mp12/node1/Makefile.in (modified) * c/src/tests/mptests/mp12/node2/Makefile.in (modified) * c/src/tests/mptests/mp13/Makefile.in (modified) * c/src/tests/mptests/mp13/node1/Makefile.in (modified) * c/src/tests/mptests/mp13/node2/Makefile.in (modified) * c/src/tests/mptests/mp14/Makefile.in (modified) * c/src/tests/mptests/mp14/node1/Makefile.in (modified) * c/src/tests/mptests/mp14/node2/Makefile.in (modified) * c/src/tests/psxtests/Makefile.in (modified) * c/src/tests/psxtests/psx01/Makefile.in (modified) * c/src/tests/psxtests/psx02/Makefile.in (modified) * c/src/tests/psxtests/psx03/Makefile.in (modified) * c/src/tests/psxtests/psx04/Makefile.in (modified) * c/src/tests/psxtests/psx05/Makefile.in (modified) * c/src/tests/psxtests/psx06/Makefile.in (modified) * c/src/tests/psxtests/psx07/Makefile.in (modified) * c/src/tests/psxtests/psx08/Makefile.in (modified) * c/src/tests/psxtests/psx09/Makefile.in (modified) * c/src/tests/psxtests/psx10/Makefile.in (modified) * c/src/tests/psxtests/psx11/Makefile.in (modified) * c/src/tests/psxtests/psx12/Makefile.in (modified) * c/src/tests/psxtests/psx13/Makefile.in (modified) * c/src/tests/psxtests/psxfile01/Makefile.in (modified) * c/src/tests/psxtests/psxfile02/Makefile.in (modified) * c/src/tests/psxtests/psxhdrs/Makefile.in (modified) * c/src/tests/psxtests/psxmount/Makefile.in (modified) * c/src/tests/psxtests/psxreaddir/Makefile.in (modified) * c/src/tests/psxtests/psxstat/Makefile.in (modified) * c/src/tests/psxtests/psxtime/Makefile.in (modified) * c/src/tests/psxtests/psxtimer/Makefile.in (modified) * c/src/tests/psxtests/support/Makefile.in (modified) * c/src/tests/psxtests/support/include/Makefile.in (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/tests/samples/base_mp/Makefile.in (modified) * c/src/tests/samples/base_mp/node1/Makefile.in (modified) * c/src/tests/samples/base_mp/node2/Makefile.in (modified) * c/src/tests/samples/base_sp/Makefile.in (modified) * c/src/tests/samples/cdtest/Makefile.in (modified) * c/src/tests/samples/hello/Makefile.in (modified) * c/src/tests/samples/minimum/Makefile.in (modified) * c/src/tests/samples/paranoia/Makefile.in (modified) * c/src/tests/samples/ticker/Makefile.in (modified) * c/src/tests/samples/unlimited/Makefile.in (modified) * c/src/tests/sptests/Makefile.in (modified) * c/src/tests/sptests/sp01/Makefile.in (modified) * c/src/tests/sptests/sp02/Makefile.in (modified) * c/src/tests/sptests/sp03/Makefile.in (modified) * c/src/tests/sptests/sp04/Makefile.in (modified) * c/src/tests/sptests/sp05/Makefile.in (modified) * c/src/tests/sptests/sp06/Makefile.in (modified) * c/src/tests/sptests/sp07/Makefile.in (modified) * c/src/tests/sptests/sp08/Makefile.in (modified) * c/src/tests/sptests/sp09/Makefile.in (modified) * c/src/tests/sptests/sp11/Makefile.in (modified) * c/src/tests/sptests/sp12/Makefile.in (modified) * c/src/tests/sptests/sp13/Makefile.in (modified) * c/src/tests/sptests/sp14/Makefile.in (modified) * c/src/tests/sptests/sp15/Makefile.in (modified) * c/src/tests/sptests/sp16/Makefile.in (modified) * c/src/tests/sptests/sp17/Makefile.in (modified) * c/src/tests/sptests/sp19/Makefile.in (modified) * c/src/tests/sptests/sp20/Makefile.in (modified) * c/src/tests/sptests/sp21/Makefile.in (modified) * c/src/tests/sptests/sp22/Makefile.in (modified) * c/src/tests/sptests/sp23/Makefile.in (modified) * c/src/tests/sptests/sp24/Makefile.in (modified) * c/src/tests/sptests/sp25/Makefile.in (modified) * c/src/tests/sptests/spfatal/Makefile.in (modified) * c/src/tests/sptests/spsize/Makefile.in (modified) * c/src/tests/support/Makefile.in (modified) * c/src/tests/support/include/Makefile.in (modified) * c/src/tests/support/stubdr/Makefile.in (modified) * c/src/tests/support/wrapup/Makefile.in (modified) * c/src/tests/tmtests/Makefile.in (modified) * c/src/tests/tmtests/include/Makefile.in (modified) * c/src/tests/tmtests/tm01/Makefile.in (modified) * c/src/tests/tmtests/tm02/Makefile.in (modified) * c/src/tests/tmtests/tm03/Makefile.in (modified) * c/src/tests/tmtests/tm04/Makefile.in (modified) * c/src/tests/tmtests/tm05/Makefile.in (modified) * c/src/tests/tmtests/tm06/Makefile.in (modified) * c/src/tests/tmtests/tm07/Makefile.in (modified) * c/src/tests/tmtests/tm08/Makefile.in (modified) * c/src/tests/tmtests/tm09/Makefile.in (modified) * c/src/tests/tmtests/tm10/Makefile.in (modified) * c/src/tests/tmtests/tm11/Makefile.in (modified) * c/src/tests/tmtests/tm12/Makefile.in (modified) * c/src/tests/tmtests/tm13/Makefile.in (modified) * c/src/tests/tmtests/tm14/Makefile.in (modified) * c/src/tests/tmtests/tm15/Makefile.in (modified) * c/src/tests/tmtests/tm16/Makefile.in (modified) * c/src/tests/tmtests/tm17/Makefile.in (modified) * c/src/tests/tmtests/tm18/Makefile.in (modified) * c/src/tests/tmtests/tm19/Makefile.in (modified) * c/src/tests/tmtests/tm20/Makefile.in (modified) * c/src/tests/tmtests/tm21/Makefile.in (modified) * c/src/tests/tmtests/tm22/Makefile.in (modified) * c/src/tests/tmtests/tm23/Makefile.in (modified) * c/src/tests/tmtests/tm24/Makefile.in (modified) * c/src/tests/tmtests/tm25/Makefile.in (modified) * c/src/tests/tmtests/tm26/Makefile.in (modified) * c/src/tests/tmtests/tm27/Makefile.in (modified) * c/src/tests/tmtests/tm28/Makefile.in (modified) * c/src/tests/tmtests/tm29/Makefile.in (modified) * c/src/tests/tmtests/tmck/Makefile.in (modified) * c/src/tests/tmtests/tmoverhd/Makefile.in (modified) * c/src/tests/tools/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.am (modified) * c/src/tests/tools/generic/Makefile.in (modified) * make/Templates/Makefile.am (modified) * make/Templates/Makefile.in (modified) * make/Templates/Makefile.inc.in (deleted) * make/compilers/gcc-target-default.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/default.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/force386.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/go32.cfg (modified) * make/custom/helas403.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/mvme167.cfg (modified) * make/custom/no_bsp.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/portsw.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/score603e.cfg (modified) * make/custom/simhppa.cfg (modified) * make/host.cfg.in (modified) * make/leaf.cfg (modified) * testsuites/tools/generic/Makefile.am (modified) * tools/update/acpolish (modified) Patch rtems-rc-19990709-6-diff from Ralf Corsepius [1896a650] * aclocal/check-rdbg.m4 (modified) * c/src/exec/aclocal.m4 (modified) * c/src/exec/configure (modified) * c/src/exec/configure.in (modified) * c/src/exec/posix/include/rtems/posix/Makefile.in (modified) * c/src/exec/rtems/Makefile.in (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/sapi/include/rtems/Makefile.in (modified) * c/src/exec/score/Makefile.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/exec/score/inline/rtems/score/Makefile.in (modified) * c/src/exec/score/macros/rtems/score/Makefile.in (modified) * c/src/exec/score/src/Makefile.in (modified) * c/src/exec/wrapup/posix/Makefile.in (modified) * c/src/lib/aclocal.m4 (modified) * c/src/lib/configure (modified) * c/src/lib/configure.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/start/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/bootloader/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.in (modified) * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/exceptions/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/mmu/Makefile.in (modified) * c/src/lib/libmisc/monitor/Makefile.in (modified) * c/src/lib/libnetworking/include/Makefile.in (modified) * c/src/lib/librdbg/i386/pc386/Makefile.in (modified) * c/src/libchip/serial/Makefile.in (modified) * c/src/libmisc/monitor/Makefile.in (modified) * c/src/libnetworking/include/Makefile.in (modified) * c/src/librdbg/src/i386/any/Makefile.in (modified) * c/src/librdbg/src/i386/pc386/Makefile.in (modified) * c/src/make/Makefile.am (modified) * c/src/make/Makefile.in (modified) * c/src/make/Templates/Makefile.in (modified) * c/src/make/aclocal.m4 (modified) * c/src/make/bsp.cfg.in (added) * c/src/make/compilers/Makefile.in (modified) * c/src/make/configure (modified) * c/src/make/configure.in (modified) * c/src/make/custom/Makefile.am (modified) * c/src/make/custom/Makefile.in (modified) * c/src/make/custom/default.cfg.in (modified) * c/src/make/main.cfg.in (modified) * c/src/tests/aclocal.m4 (modified) * c/src/tests/configure (modified) * c/src/tests/configure.in (modified) * make/custom/default.cfg (modified) * make/custom/force386.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/pc386.cfg (modified) * make/custom/portsw.cfg (modified) * make/custom/ppcn_60x.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/ts_386ex.cfg (modified) * make/main.cfg (modified) * tools/build/configure (modified) * tools/update/acpolish (modified) Patch from Ralf Corsepius : The main ... Tue, 27 Jul 1999 15:20:36 GMT Joel Sherrill [c32555c] * make/custom/dmv177.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/psim.cfg (modified) Patch from Jay Kulpinski to correct ... Mon, 26 Jul 1999 21:26:44 GMT Joel Sherrill [29e68b75] * Makefile.am (modified) * Makefile.in (modified) * automake/local.am (modified) * automake/subdirs.am (modified) * c/Makefile.am (modified) * c/Makefile.in (modified) * c/src/Makefile.in (modified) * c/src/exec/Makefile.in (modified) * c/src/exec/sapi/include/rtems/Makefile.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure.in (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/bin2boot.c (modified) * c/src/lib/libbsp/i386/pc386/tools/binpatch.c (deleted) * c/src/lib/libbsp/i386/pc386/tools/configure (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (modified) * c/src/make/Makefile.in (modified) * c/src/make/README (modified) * c/src/make/Templates/Makefile.in (modified) * c/src/make/compilers/Makefile.in (modified) * c/src/make/custom/Makefile.in (modified) * c/src/make/directory.cfg (modified) * c/src/make/main.cfg.in (modified) * c/src/tests/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.in (modified) * doc/Makefile.in (modified) * make/Makefile.in (modified) * make/README (modified) * make/Templates/Makefile.in (modified) * make/compilers/Makefile.in (modified) * make/custom/Makefile.in (modified) * make/custom/ts_386ex.cfg (modified) * make/directory.cfg (modified) * make/leaf.cfg (modified) * make/main.cfg (modified) * tools/Makefile.in (modified) * tools/build/Makefile.am (modified) * tools/build/Makefile.in (modified) * tools/build/binpatch.c (modified) * tools/build/config.h.in (modified) * tools/build/configure (modified) * tools/build/configure.in (modified) * tools/cpu/Makefile.in (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/hppa1.1/configure (modified) * tools/cpu/hppa1.1/configure.in (modified) * tools/cpu/sh/Makefile.in (modified) * tools/cpu/sh/configure (modified) * tools/cpu/sh/configure.in (modified) * tools/cpu/unix/Makefile.in (modified) * tools/cpu/unix/configure (modified) * tools/cpu/unix/configure.in (modified) * tools/update/Makefile.in (modified) Patch from Ralf Corsepius : This patch ... Mon, 26 Jul 1999 20:20:22 GMT Joel Sherrill [eb299afc] * Makefile.am (added) * aclocal/bsp-alias.m4 (added) * aclocal/check-newlib.m4 (added) * aclocal/check-rdbg.m4 (added) * aclocal/enable-rtemsbsp.m4 (added) * aclocal/project-root.m4 (added) * aclocal/target.m4 (added) * c/Makefile.am (added) * c/aclocal.m4 (added) * c/configure (added) * c/configure.in (added) * c/src/Makefile.am (added) * c/src/aclocal.m4 (added) * c/src/configure (added) * c/src/configure.in (added) * c/src/exec/aclocal.m4 (added) * c/src/exec/configure (added) * c/src/exec/configure.in (added) * c/src/lib/aclocal.m4 (added) * c/src/lib/configure (added) * c/src/lib/configure.in (added) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.am (added) * c/src/lib/libbsp/i386/ts_386ex/tools/aclocal.m4 (added) * c/src/lib/libbsp/i386/ts_386ex/tools/configure (added) * c/src/lib/libbsp/i386/ts_386ex/tools/configure.in (added) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/Makefile.am (added) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/Makefile.in (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.am (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.in (added) * c/src/make/Makefile.am (added) * c/src/make/Makefile.in (added) * c/src/make/Makefile.inc.in (added) * c/src/make/Templates/Makefile.am (added) * c/src/make/Templates/Makefile.dir (added) * c/src/make/Templates/Makefile.in (added) * c/src/make/Templates/Makefile.leaf (added) * c/src/make/Templates/Makefile.lib (added) * c/src/make/aclocal.m4 (added) * c/src/make/compilers/Makefile.am (added) * c/src/make/compilers/Makefile.in (added) * c/src/make/compilers/gcc.cfg.in (added) * c/src/make/configure (added) * c/src/make/configure.in (added) * c/src/make/custom/Makefile.am (added) * c/src/make/custom/Makefile.in (added) * c/src/make/custom/default.cfg.in (added) * c/src/make/main.cfg.in (added) * c/src/make/target.cfg.in (added) * c/src/tests/aclocal.m4 (added) * c/src/tests/configure (added) * c/src/tests/configure.in (added) * make/Makefile.am (added) * make/Templates/Makefile.am (added) * make/Templates/Makefile.in (added) * make/compilers/Makefile.am (added) * make/compilers/Makefile.in (added) * make/custom/Makefile.am (added) * make/custom/Makefile.in (added) * tools/Makefile.am (added) * tools/Makefile.in (added) * tools/cpu/Makefile.am (added) * tools/cpu/aclocal.m4 (added) * tools/cpu/configure (added) * tools/cpu/configure.in (added) This is part of a major patch from Ralf Corsepius [6693a68] * Makefile.in (modified) * aclocal.m4 (modified) * aclocal/canonicalize-tools.m4 (modified) * aclocal/gcc-pipe.m4 (modified) * aclocal/prog-cc.m4 (modified) * aclocal/prog-cxx.m4 (modified) * aclocal/rtems-top.m4 (modified) * aclocal/sysv-ipc.m4 (modified) * aclocal/tool-paths.m4 (modified) * aclocal/tool-prefix.m4 (modified) * autogen (modified) * c/Makefile.in (modified) * c/src/Makefile.in (modified) * c/src/exec/Makefile.in (modified) * c/src/exec/posix/Makefile.in (modified) * c/src/exec/posix/include/Makefile.in (modified) * c/src/exec/posix/include/rtems/Makefile.in (modified) * c/src/exec/posix/include/rtems/posix/Makefile.in (modified) * c/src/exec/posix/include/sys/Makefile.in (modified) * c/src/exec/posix/include/wrap/Makefile.in (modified) * c/src/exec/posix/inline/Makefile.in (modified) * c/src/exec/posix/inline/rtems/Makefile.in (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.in (modified) * c/src/exec/posix/macros/Makefile.in (modified) * c/src/exec/posix/macros/rtems/Makefile.in (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.in (modified) * c/src/exec/posix/optman/Makefile.in (modified) * c/src/exec/posix/src/Makefile.in (modified) * c/src/exec/rtems/Makefile.in (modified) * c/src/exec/rtems/include/Makefile.in (modified) * c/src/exec/rtems/include/rtems/Makefile.in (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/include/wrap/Makefile.in (modified) * c/src/exec/rtems/inline/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/optman/Makefile.in (modified) * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/sapi/Makefile.in (modified) * c/src/exec/sapi/include/Makefile.in (modified) * c/src/exec/sapi/include/rtems/Makefile.in (modified) * c/src/exec/sapi/include/rtems/sptables.h.in (added) * c/src/exec/sapi/include/wrap/Makefile.in (modified) * c/src/exec/sapi/inline/Makefile.in (modified) * c/src/exec/sapi/inline/rtems/Makefile.in (modified) * c/src/exec/sapi/macros/Makefile.in (modified) * c/src/exec/sapi/macros/rtems/Makefile.in (modified) * c/src/exec/sapi/optman/Makefile.in (modified) * c/src/exec/sapi/src/Makefile.in (modified) * c/src/exec/score/Makefile.in (modified) * c/src/exec/score/cpu/Makefile.in (modified) * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/a29k/wrap/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/wrap/Makefile.in (modified) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/i386/wrap/Makefile.in (modified) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/i960/wrap/Makefile.in (modified) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/m68k/wrap/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/wrap/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/wrap/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/mpc750/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/other_cpu/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/shared/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/wrap/Makefile.in (modified) * c/src/exec/score/cpu/sh/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sh/wrap/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sparc/wrap/Makefile.in (modified) * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/unix/wrap/Makefile.in (modified) * c/src/exec/score/include/Makefile.in (modified) * c/src/exec/score/include/rtems/Makefile.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/exec/score/include/rtems/wrap/Makefile.in (modified) * c/src/exec/score/inline/Makefile.in (modified) * c/src/exec/score/inline/rtems/Makefile.in (modified) * c/src/exec/score/inline/rtems/score/Makefile.in (modified) * c/src/exec/score/macros/Makefile.in (modified) * c/src/exec/score/macros/rtems/Makefile.in (modified) * c/src/exec/score/macros/rtems/score/Makefile.in (modified) * c/src/exec/score/src/Makefile.in (modified) * c/src/exec/wrapup/Makefile.in (modified) * c/src/exec/wrapup/posix/Makefile.in (modified) * c/src/exec/wrapup/rtems/Makefile.in (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/libbsp/Makefile.in (modified) * c/src/lib/libbsp/a29k/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.in (modified) * c/src/lib/libbsp/bare/Makefile.in (modified) * c/src/lib/libbsp/bare/include/Makefile.in (modified) * c/src/lib/libbsp/bare/wrapup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/aclocal.m4 (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/console/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/include/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/network/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/3c509/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/dec21140/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/ne2000/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/aclocal.m4 (modified) * c/src/lib/libbsp/i386/pc386/tools/configure (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.in (modified) * c/src/lib/libbsp/i386/pc386/wd8003/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/comm/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/io/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/irq/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/pci/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/include/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/network/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/start/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile (deleted) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/README (added) * c/src/lib/libbsp/i386/ts_386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i960/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/aclocal.m4 (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.in (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/bootloader/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/irq/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/openpic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/residual/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startsim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/aclocal.m4 (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure.in (modified) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.in (modified) * c/src/lib/libbsp/sh/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/include/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.in (modified) * c/src/lib/libbsp/shmdr/Makefile.in (modified) * c/src/lib/libbsp/sparc/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/gnatsupp/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startsis/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/aclocal.m4 (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure.in (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/unix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/aclocal.m4 (modified) * c/src/lib/libbsp/unix/posix/tools/configure (modified) * c/src/lib/libbsp/unix/posix/tools/configure.in (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.in (modified) * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libchip/Makefile.in (modified) * c/src/lib/libchip/network/Makefile.in (modified) * c/src/lib/libchip/rtc/Makefile.in (modified) * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/lib/libcpu/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/runway/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.in (modified) * c/src/lib/libcpu/i386/Makefile.in (modified) * c/src/lib/libcpu/i386/wrapup/Makefile.in (modified) * c/src/lib/libcpu/m68k/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/include/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/exceptions/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/mmu/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/wrapup/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/shared/Makefile.in (modified) * c/src/lib/libcpu/powerpc/wrapup/Makefile.in (modified) * c/src/lib/libcpu/sh/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/console/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.in (modified) * c/src/lib/libcpu/sparc/Makefile.in (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.in (modified) * c/src/lib/libcpu/sparc/syscall/Makefile.in (modified) * c/src/lib/libmisc/Makefile.in (modified) * c/src/lib/libmisc/assoc/Makefile.in (modified) * c/src/lib/libmisc/cpuuse/Makefile.in (modified) * c/src/lib/libmisc/dumpbuf/Makefile.in (modified) * c/src/lib/libmisc/error/Makefile.in (modified) * c/src/lib/libmisc/monitor/Makefile.in (modified) * c/src/lib/libmisc/rtmonuse/Makefile.in (modified) * c/src/lib/libmisc/stackchk/Makefile.in (modified) * c/src/lib/libmisc/untar/Makefile.in (modified) * c/src/lib/libmisc/wrapup/Makefile.in (modified) * c/src/lib/libnetworking/Makefile.in (modified) * c/src/lib/libnetworking/include/Makefile.in (modified) * c/src/lib/libnetworking/kern/Makefile.in (modified) * c/src/lib/libnetworking/lib/Makefile.in (modified) * c/src/lib/libnetworking/libc/Makefile.in (modified) * c/src/lib/libnetworking/net/Makefile.in (modified) * c/src/lib/libnetworking/netinet/Makefile.in (modified) * c/src/lib/libnetworking/nfs/Makefile.in (modified) * c/src/lib/libnetworking/rtems/Makefile.in (modified) * c/src/lib/libnetworking/rtems_servers/Makefile.in (modified) * c/src/lib/libnetworking/wrapup/Makefile.in (modified) * c/src/lib/librdbg/Makefile.in (modified) * c/src/lib/librdbg/i386/Makefile.in (modified) * c/src/lib/librdbg/i386/pc386/Makefile.in (modified) * c/src/lib/librpc/Makefile.in (modified) * c/src/lib/librtems++/Makefile.in (modified) * c/src/lib/start/Makefile.in (modified) * c/src/lib/start/a29k/Makefile.in (modified) * c/src/lib/start/i960/Makefile.in (modified) * c/src/lib/start/m68k/Makefile.in (modified) * c/src/lib/start/mips64orion/Makefile.in (modified) * c/src/lib/start/sh/Makefile.in (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/libchip/network/Makefile.in (modified) * c/src/libchip/rtc/Makefile.in (modified) * c/src/libchip/serial/Makefile.in (modified) * c/src/libmisc/assoc/Makefile.in (modified) * c/src/libmisc/cpuuse/Makefile.in (modified) * c/src/libmisc/dumpbuf/Makefile.in (modified) * c/src/libmisc/error/Makefile.in (modified) * c/src/libmisc/monitor/Makefile.in (modified) * c/src/libmisc/rtmonuse/Makefile.in (modified) * c/src/libmisc/stackchk/Makefile.in (modified) * c/src/libmisc/untar/Makefile.in (modified) * c/src/libmisc/wrapup/Makefile.in (modified) * c/src/libnetworking/Makefile.in (modified) * c/src/libnetworking/include/Makefile.in (modified) * c/src/libnetworking/kern/Makefile.in (modified) * c/src/libnetworking/lib/Makefile.in (modified) * c/src/libnetworking/libc/Makefile.in (modified) * c/src/libnetworking/net/Makefile.in (modified) * c/src/libnetworking/netinet/Makefile.in (modified) * c/src/libnetworking/nfs/Makefile.in (modified) * c/src/libnetworking/rtems/Makefile.in (modified) * c/src/libnetworking/rtems_servers/Makefile.in (modified) * c/src/libnetworking/wrapup/Makefile.in (modified) * c/src/librdbg/src/Makefile.in (modified) * c/src/librdbg/src/i386/Makefile.in (modified) * c/src/librdbg/src/i386/any/Makefile.in (modified) * c/src/librdbg/src/i386/pc386/Makefile.in (modified) * c/src/librpc/src/Makefile.in (modified) * c/src/librtems++/src/Makefile.in (modified) * c/src/make/directory.cfg (modified) * c/src/make/host.cfg.in (modified) * c/src/tests/Makefile.in (modified) * c/src/tests/libtests/Makefile.in (modified) * c/src/tests/libtests/cpuuse/Makefile.in (modified) * c/src/tests/libtests/malloctest/Makefile.in (modified) * c/src/tests/libtests/monitor/Makefile.in (modified) * c/src/tests/libtests/rtems++/Makefile.in (modified) * c/src/tests/libtests/rtmonuse/Makefile.in (modified) * c/src/tests/libtests/stackchk/Makefile.in (modified) * c/src/tests/libtests/termios/Makefile.in (modified) * c/src/tests/mptests/Makefile.in (modified) * c/src/tests/mptests/mp01/Makefile.in (modified) * c/src/tests/mptests/mp01/node1/Makefile.in (modified) * c/src/tests/mptests/mp01/node2/Makefile.in (modified) * c/src/tests/mptests/mp02/Makefile.in (modified) * c/src/tests/mptests/mp02/node1/Makefile.in (modified) * c/src/tests/mptests/mp02/node2/Makefile.in (modified) * c/src/tests/mptests/mp03/Makefile.in (modified) * c/src/tests/mptests/mp03/node1/Makefile.in (modified) * c/src/tests/mptests/mp03/node2/Makefile.in (modified) * c/src/tests/mptests/mp04/Makefile.in (modified) * c/src/tests/mptests/mp04/node1/Makefile.in (modified) * c/src/tests/mptests/mp04/node2/Makefile.in (modified) * c/src/tests/mptests/mp05/Makefile.in (modified) * c/src/tests/mptests/mp05/node1/Makefile.in (modified) * c/src/tests/mptests/mp05/node2/Makefile.in (modified) * c/src/tests/mptests/mp06/Makefile.in (modified) * c/src/tests/mptests/mp06/node1/Makefile.in (modified) * c/src/tests/mptests/mp06/node2/Makefile.in (modified) * c/src/tests/mptests/mp07/Makefile.in (modified) * c/src/tests/mptests/mp07/node1/Makefile.in (modified) * c/src/tests/mptests/mp07/node2/Makefile.in (modified) * c/src/tests/mptests/mp08/Makefile.in (modified) * c/src/tests/mptests/mp08/node1/Makefile.in (modified) * c/src/tests/mptests/mp08/node2/Makefile.in (modified) * c/src/tests/mptests/mp09/Makefile.in (modified) * c/src/tests/mptests/mp09/node1/Makefile.in (modified) * c/src/tests/mptests/mp09/node2/Makefile.in (modified) * c/src/tests/mptests/mp10/Makefile.in (modified) * c/src/tests/mptests/mp10/node1/Makefile.in (modified) * c/src/tests/mptests/mp10/node2/Makefile.in (modified) * c/src/tests/mptests/mp11/Makefile.in (modified) * c/src/tests/mptests/mp11/node1/Makefile.in (modified) * c/src/tests/mptests/mp11/node2/Makefile.in (modified) * c/src/tests/mptests/mp12/Makefile.in (modified) * c/src/tests/mptests/mp12/node1/Makefile.in (modified) * c/src/tests/mptests/mp12/node2/Makefile.in (modified) * c/src/tests/mptests/mp13/Makefile.in (modified) * c/src/tests/mptests/mp13/node1/Makefile.in (modified) * c/src/tests/mptests/mp13/node2/Makefile.in (modified) * c/src/tests/mptests/mp14/Makefile.in (modified) * c/src/tests/mptests/mp14/node1/Makefile.in (modified) * c/src/tests/mptests/mp14/node2/Makefile.in (modified) * c/src/tests/psxtests/Makefile.in (modified) * c/src/tests/psxtests/psx01/Makefile.in (modified) * c/src/tests/psxtests/psx02/Makefile.in (modified) * c/src/tests/psxtests/psx03/Makefile.in (modified) * c/src/tests/psxtests/psx04/Makefile.in (modified) * c/src/tests/psxtests/psx05/Makefile.in (modified) * c/src/tests/psxtests/psx06/Makefile.in (modified) * c/src/tests/psxtests/psx07/Makefile.in (modified) * c/src/tests/psxtests/psx08/Makefile.in (modified) * c/src/tests/psxtests/psx09/Makefile.in (modified) * c/src/tests/psxtests/psx10/Makefile.in (modified) * c/src/tests/psxtests/psx11/Makefile.in (modified) * c/src/tests/psxtests/psx12/Makefile.in (modified) * c/src/tests/psxtests/psx13/Makefile.in (modified) * c/src/tests/psxtests/psxfile01/Makefile.in (modified) * c/src/tests/psxtests/psxfile02/Makefile.in (modified) * c/src/tests/psxtests/psxhdrs/Makefile.in (modified) * c/src/tests/psxtests/psxmount/Makefile.in (modified) * c/src/tests/psxtests/psxreaddir/Makefile.in (modified) * c/src/tests/psxtests/psxstat/Makefile.in (modified) * c/src/tests/psxtests/psxtime/Makefile.in (modified) * c/src/tests/psxtests/psxtimer/Makefile.in (modified) * c/src/tests/psxtests/support/Makefile.in (modified) * c/src/tests/psxtests/support/include/Makefile.in (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/tests/samples/base_mp/Makefile.in (modified) * c/src/tests/samples/base_mp/node1/Makefile.in (modified) * c/src/tests/samples/base_mp/node2/Makefile.in (modified) * c/src/tests/samples/base_sp/Makefile.in (modified) * c/src/tests/samples/cdtest/Makefile.in (modified) * c/src/tests/samples/hello/Makefile.in (modified) * c/src/tests/samples/minimum/Makefile.in (modified) * c/src/tests/samples/paranoia/Makefile.in (modified) * c/src/tests/samples/ticker/Makefile.in (modified) * c/src/tests/samples/unlimited/Makefile.in (modified) * c/src/tests/sptests/Makefile.in (modified) * c/src/tests/sptests/sp01/Makefile.in (modified) * c/src/tests/sptests/sp02/Makefile.in (modified) * c/src/tests/sptests/sp03/Makefile.in (modified) * c/src/tests/sptests/sp04/Makefile.in (modified) * c/src/tests/sptests/sp05/Makefile.in (modified) * c/src/tests/sptests/sp06/Makefile.in (modified) * c/src/tests/sptests/sp07/Makefile.in (modified) * c/src/tests/sptests/sp08/Makefile.in (modified) * c/src/tests/sptests/sp09/Makefile.in (modified) * c/src/tests/sptests/sp11/Makefile.in (modified) * c/src/tests/sptests/sp12/Makefile.in (modified) * c/src/tests/sptests/sp13/Makefile.in (modified) * c/src/tests/sptests/sp14/Makefile.in (modified) * c/src/tests/sptests/sp15/Makefile.in (modified) * c/src/tests/sptests/sp16/Makefile.in (modified) * c/src/tests/sptests/sp17/Makefile.in (modified) * c/src/tests/sptests/sp19/Makefile.in (modified) * c/src/tests/sptests/sp20/Makefile.in (modified) * c/src/tests/sptests/sp21/Makefile.in (modified) * c/src/tests/sptests/sp22/Makefile.in (modified) * c/src/tests/sptests/sp23/Makefile.in (modified) * c/src/tests/sptests/sp24/Makefile.in (modified) * c/src/tests/sptests/sp25/Makefile.in (modified) * c/src/tests/sptests/spfatal/Makefile.in (modified) * c/src/tests/sptests/spsize/Makefile.in (modified) * c/src/tests/support/Makefile.in (modified) * c/src/tests/support/include/Makefile.in (modified) * c/src/tests/support/stubdr/Makefile.in (modified) * c/src/tests/support/wrapup/Makefile.in (modified) * c/src/tests/tmtests/Makefile.in (modified) * c/src/tests/tmtests/include/Makefile.in (modified) * c/src/tests/tmtests/tm01/Makefile.in (modified) * c/src/tests/tmtests/tm02/Makefile.in (modified) * c/src/tests/tmtests/tm03/Makefile.in (modified) * c/src/tests/tmtests/tm04/Makefile.in (modified) * c/src/tests/tmtests/tm05/Makefile.in (modified) * c/src/tests/tmtests/tm06/Makefile.in (modified) * c/src/tests/tmtests/tm07/Makefile.in (modified) * c/src/tests/tmtests/tm08/Makefile.in (modified) * c/src/tests/tmtests/tm09/Makefile.in (modified) * c/src/tests/tmtests/tm10/Makefile.in (modified) * c/src/tests/tmtests/tm11/Makefile.in (modified) * c/src/tests/tmtests/tm12/Makefile.in (modified) * c/src/tests/tmtests/tm13/Makefile.in (modified) * c/src/tests/tmtests/tm14/Makefile.in (modified) * c/src/tests/tmtests/tm15/Makefile.in (modified) * c/src/tests/tmtests/tm16/Makefile.in (modified) * c/src/tests/tmtests/tm17/Makefile.in (modified) * c/src/tests/tmtests/tm18/Makefile.in (modified) * c/src/tests/tmtests/tm19/Makefile.in (modified) * c/src/tests/tmtests/tm20/Makefile.in (modified) * c/src/tests/tmtests/tm21/Makefile.in (modified) * c/src/tests/tmtests/tm22/Makefile.in (modified) * c/src/tests/tmtests/tm23/Makefile.in (modified) * c/src/tests/tmtests/tm24/Makefile.in (modified) * c/src/tests/tmtests/tm25/Makefile.in (modified) * c/src/tests/tmtests/tm26/Makefile.in (modified) * c/src/tests/tmtests/tm27/Makefile.in (modified) * c/src/tests/tmtests/tm28/Makefile.in (modified) * c/src/tests/tmtests/tm29/Makefile.in (modified) * c/src/tests/tmtests/tmck/Makefile.in (modified) * c/src/tests/tmtests/tmoverhd/Makefile.in (modified) * c/src/tests/tools/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.am (modified) * c/src/tests/tools/generic/Makefile.in (modified) * c/src/tests/tools/generic/aclocal.m4 (modified) * c/src/tests/tools/generic/configure (modified) * c/src/tests/tools/generic/configure.in (modified) * c/src/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) * cpukit/sapi/include/rtems/sptables.h.in (moved) * doc/Makefile.in (modified) * make/Makefile.in (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/default.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/no_bsp.cfg (modified) * make/custom/portsw.cfg (modified) * make/custom/posix.cfg (modified) * make/custom/simhppa.cfg (modified) * make/directory.cfg (modified) * make/host.cfg.in (modified) * make/leaf.cfg (modified) * make/main.cfg (modified) * make/target.cfg.in (modified) * testsuites/tools/generic/Makefile.am (modified) * tools/build/Makefile.am (modified) * tools/build/Makefile.in (modified) * tools/build/aclocal.m4 (modified) * tools/build/configure (modified) * tools/build/configure.in (modified) * tools/cpu/Makefile.in (modified) * tools/cpu/generic/Makefile.am (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/generic/aclocal.m4 (modified) * tools/cpu/generic/configure (modified) * tools/cpu/generic/configure.in (modified) * tools/cpu/generic/size_rtems.in (modified) * tools/cpu/hppa1.1/Makefile.am (modified) * tools/cpu/hppa1.1/aclocal.m4 (modified) * tools/cpu/hppa1.1/configure (modified) * tools/cpu/hppa1.1/configure.in (modified) * tools/cpu/sh/Makefile.am (modified) * tools/cpu/sh/Makefile.in (modified) * tools/cpu/sh/aclocal.m4 (modified) * tools/cpu/sh/configure (modified) * tools/cpu/sh/configure.in (modified) * tools/cpu/unix/Makefile.am (modified) * tools/cpu/unix/Makefile.in (modified) * tools/cpu/unix/aclocal.m4 (modified) * tools/cpu/unix/configure (modified) * tools/cpu/unix/configure.in (modified) * tools/update/Makefile.am (modified) * tools/update/Makefile.in (modified) * tools/update/aclocal.m4 (modified) * tools/update/acpolish (modified) * tools/update/ampolish (modified) * tools/update/configure (modified) * tools/update/configure.in (modified) * tools/update/rtems-polish.sh (modified) This is part of a major patch from Ralf Corsepius [b73e57b] * c/src/exec/score/cpu/sparc/asm.h (modified) * c/src/exec/score/cpu/sparc/cpu_asm.S (modified) * c/src/exec/score/cpu/sparc/erc32.h (modified) * c/src/exec/score/cpu/sparc/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/sparc/rtems/score/sparc.h (modified) * c/src/lib/libbsp/sparc/erc32/start/start.S (modified) * c/src/lib/libbsp/sparc/erc32/startsis/startsis.S (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspclean.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/linkcmds (modified) * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.in (modified) * c/src/lib/libcpu/sparc/Makefile.in (modified) * c/src/lib/libcpu/sparc/include/erc32.h (modified) * cpukit/score/cpu/sparc/asm.h (modified) * cpukit/score/cpu/sparc/cpu_asm.S (modified) * cpukit/score/cpu/sparc/rtems/asm.h (modified) * cpukit/score/cpu/sparc/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) * make/custom/erc32.cfg (modified) Patch from Jiri Gaisler : + interrupt ... Mon, 14 Jun 1999 18:33:39 GMT Joel Sherrill [3b38683] * make/custom/ts_386ex.cfg (modified) Patch from Ralf Corsepius : * Use ... Mon, 14 Jun 1999 18:33:38 GMT Joel Sherrill [b290da4c] * make/custom/score603e.cfg (modified) Patch from Ralf Corsepius : * RTEMS_CPU ...
