# # ChangeLog for make/custom in rtems # # Generated by Trac 1.2.1.dev0 # 04/20/24 02:48:18 Wed, 24 Feb 1999 14:39:24 GMT Joel Sherrill [d6f28200] * make/custom/pc386.cfg (modified) Added $(LIB_VARIANT) to start16.bin. Wed, 24 Feb 1999 14:39:03 GMT Joel Sherrill [98e8c7f2] * make/custom/cvme961.cfg (modified) Corrected spacing. Fri, 19 Feb 1999 00:22:33 GMT Joel Sherrill [9c448e1] * c/src/lib/libbsp/powerpc/score603e/Makefile.in (added) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.in (added) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.c (added) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/PCI.h (added) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/flash.c (added) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/universe.c (added) * c/src/lib/libbsp/powerpc/score603e/README (added) * c/src/lib/libbsp/powerpc/score603e/bsp_specs (added) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.in (added) * c/src/lib/libbsp/powerpc/score603e/clock/clock.c (added) * c/src/lib/libbsp/powerpc/score603e/console/85c30.c (added) * c/src/lib/libbsp/powerpc/score603e/console/85c30.h (added) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.in (added) * c/src/lib/libbsp/powerpc/score603e/console/console.c (added) * c/src/lib/libbsp/powerpc/score603e/console/consolebsp.h (added) * c/src/lib/libbsp/powerpc/score603e/console/tbl85c30.c (added) * c/src/lib/libbsp/powerpc/score603e/include/Makefile.in (added) * c/src/lib/libbsp/powerpc/score603e/include/bsp.h (added) * c/src/lib/libbsp/powerpc/score603e/include/chain.h (added) * c/src/lib/libbsp/powerpc/score603e/include/coverhd.h (added) * c/src/lib/libbsp/powerpc/score603e/include/gen1.h (added) * c/src/lib/libbsp/powerpc/score603e/include/gen2.h (added) * c/src/lib/libbsp/powerpc/score603e/include/tod.h (added) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.in (added) * c/src/lib/libbsp/powerpc/score603e/start/start.S (added) * c/src/lib/libbsp/powerpc/score603e/startup/82378zb.c (added) * c/src/lib/libbsp/powerpc/score603e/startup/FPGA.c (added) * c/src/lib/libbsp/powerpc/score603e/startup/Hwr_init.c (added) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.in (added) * c/src/lib/libbsp/powerpc/score603e/startup/bspclean.c (added) * c/src/lib/libbsp/powerpc/score603e/startup/bspstart.c (added) * c/src/lib/libbsp/powerpc/score603e/startup/genpvec.c (added) * c/src/lib/libbsp/powerpc/score603e/startup/linkcmds (added) * c/src/lib/libbsp/powerpc/score603e/startup/setvec.c (added) * c/src/lib/libbsp/powerpc/score603e/startup/spurious.c (added) * c/src/lib/libbsp/powerpc/score603e/startup/vmeintr.c (added) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.in (added) * c/src/lib/libbsp/powerpc/score603e/timer/timer.c (added) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.in (added) * c/src/lib/libbsp/powerpc/score603e/tod/tod.c (added) * c/src/lib/libbsp/powerpc/score603e/tod/tod_g1.c (added) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.in (added) * c/src/lib/libbsp/powerpc/score603e/vectors/vectors.S (added) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.in (added) * make/custom/score603e.cfg (added) BSP for Vista Score603e added. Thu, 18 Feb 1999 19:23:28 GMT Joel Sherrill [5d02459] * c/src/lib/libbsp/m68k/mvme167/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme167/README (added) * c/src/lib/libbsp/m68k/mvme167/bsp_specs (added) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme167/clock/ckinit.c (added) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme167/console/console.c (added) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme167/fatal/bspfatal.c (added) * c/src/lib/libbsp/m68k/mvme167/fatal/fatal.c (added) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme167/include/bsp.h (added) * c/src/lib/libbsp/m68k/mvme167/include/coverhd.h (added) * c/src/lib/libbsp/m68k/mvme167/include/fatal.h (added) * c/src/lib/libbsp/m68k/mvme167/include/page_table.h (added) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme167/startup/bspclean.c (added) * c/src/lib/libbsp/m68k/mvme167/startup/bspstart.c (added) * c/src/lib/libbsp/m68k/mvme167/startup/linkcmds (added) * c/src/lib/libbsp/m68k/mvme167/startup/page_table.c (added) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.in (added) * c/src/lib/libbsp/m68k/mvme167/timer/timer.c (added) * c/src/lib/libbsp/m68k/mvme167/timer/timerisr.s (added) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.in (added) * make/custom/mvme167.cfg (added) MVME167 BSP submitted by Charles Gauthier . Thu, 18 Feb 1999 17:55:49 GMT Joel Sherrill [a110b68] * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * make/compilers/gcc-no_bsp.cfg (modified) * make/compilers/gcc-portsw.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/ods68302.cfg (modified) Part of automake VI patch from Ralf Corsepius [011677f] * c/src/make/host.cfg.in (modified) * make/custom/dmv152.cfg (modified) * make/custom/dmv177.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/force386.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/pc386.cfg (modified) * make/custom/posix.cfg (modified) * make/custom/simhppa.cfg (modified) * make/host.cfg.in (modified) Part of automake VI Patch from Ralf Corsepius [0c04c377] * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.in (added) * c/src/lib/libbsp/powerpc/ppcn_60x/README (added) * c/src/lib/libbsp/powerpc/ppcn_60x/STATUS (added) * c/src/lib/libbsp/powerpc/ppcn_60x/bsp_specs (added) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.in (added) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/clock.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.in (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/console.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/console.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/i8042.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/i8042_p.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/i8042vga.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/i8042vga.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/ns16550.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/ns16550.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/ns16550_p.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/ns16550cfg.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/ns16550cfg.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/vga.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/vga_p.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/z85c30.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/z85c30.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/z85c30_p.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/z85c30cfg.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/console/z85c30cfg.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.in (added) * c/src/lib/libbsp/powerpc/ppcn_60x/include/bsp.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/include/chain.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/include/coverhd.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/include/extisrdrv.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/include/nvram.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/include/pci.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/include/tod.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.in (added) * c/src/lib/libbsp/powerpc/ppcn_60x/network/amd79c970.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/network/amd79c970.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.in (added) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/ds1385.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/mk48t18.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/nvram.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/prepnvr.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/stk11c68.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.in (added) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/pci.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.in (added) * c/src/lib/libbsp/powerpc/ppcn_60x/start/start.S (added) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.in (added) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/bspclean.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/bspstart.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/bsptrap.S (added) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/genpvec.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/linkcmds (added) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/rtems-ctor.cc (added) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/setvec.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/spurious.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/swap.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.in (added) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/timer.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.in (added) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/cmos.h (added) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/tod.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.in (added) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/universe.c (added) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.in (added) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/README (added) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/align_h.S (added) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/vectors.S (added) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.in (added) * make/custom/ppcn_60x.cfg (added) ./clock/Makefile.in,v ./clock/clock.c,v ./console/Makefile.in,v ... Wed, 17 Feb 1999 20:24:53 GMT Joel Sherrill [ee733965] * c/src/exec/score/cpu/powerpc/mpc860.h (added) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.in (added) * c/src/lib/libbsp/powerpc/eth_comm/README (added) * c/src/lib/libbsp/powerpc/eth_comm/bsp_specs (added) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.in (added) * c/src/lib/libbsp/powerpc/eth_comm/canbus/canbus.c (added) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.in (added) * c/src/lib/libbsp/powerpc/eth_comm/console/console.c (added) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.in (added) * c/src/lib/libbsp/powerpc/eth_comm/include/bsp.h (added) * c/src/lib/libbsp/powerpc/eth_comm/include/canbus.h (added) * c/src/lib/libbsp/powerpc/eth_comm/include/coverhd.h (added) * c/src/lib/libbsp/powerpc/eth_comm/include/info.h (added) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.in (added) * c/src/lib/libbsp/powerpc/eth_comm/network/README (added) * c/src/lib/libbsp/powerpc/eth_comm/network/network.c (added) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.in (added) * c/src/lib/libbsp/powerpc/eth_comm/start/start.S (added) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.in (added) * c/src/lib/libbsp/powerpc/eth_comm/startup/alloc860.c (added) * c/src/lib/libbsp/powerpc/eth_comm/startup/bspstart.c (added) * c/src/lib/libbsp/powerpc/eth_comm/startup/linkcmds (added) * c/src/lib/libbsp/powerpc/eth_comm/startup/mmu.c (added) * c/src/lib/libbsp/powerpc/eth_comm/startup/setvec.c (added) * c/src/lib/libbsp/powerpc/eth_comm/times (added) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc860/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc860/README (added) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc860/clock/clock.c (added) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc860/console-generic/console-generic.c (added) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc860/include/console.h (added) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc860/timer/timer.c (added) * c/src/lib/libcpu/powerpc/mpc860/vectors/Makefile.in (added) * c/src/lib/libcpu/powerpc/mpc860/vectors/README (added) * c/src/lib/libcpu/powerpc/mpc860/vectors/align_h.S (added) * c/src/lib/libcpu/powerpc/mpc860/vectors/vectors.S (added) * make/custom/eth_comm.cfg (added) Jay Monkman submitted the eth_comm BSP for a ... Fri, 05 Feb 1999 00:30:30 GMT Joel Sherrill [b5e4eb7] * make/custom/psim.cfg (modified) Commented out disable of building network code so it is built. You ... Fri, 05 Feb 1999 00:29:47 GMT Joel Sherrill [2caa006] * make/custom/dmv177.cfg (modified) Added instruction and data cache enable. Tue, 19 Jan 1999 20:24:56 GMT Joel Sherrill [6a14ae56] * make/custom/psim.cfg (modified) Added comments to indicate what options are required to take ... Thu, 03 Dec 1998 23:54:14 GMT Joel Sherrill [4721cf1] * c/Makefile.in (modified) * c/src/exec/librpc/include/rpc/auth.h (added) * c/src/exec/librpc/include/rpc/clnt.h (added) * c/src/exec/librpc/include/rpc/rpc.h (added) * c/src/exec/librpc/include/rpc/rpc_msg.h (added) * c/src/exec/librpc/include/rpc/svc.h (added) * c/src/exec/librpc/include/rpc/svc_auth.h (added) * c/src/exec/librpc/include/rpc/types.h (added) * c/src/exec/librpc/include/rpc/xdr.h (added) * c/src/exec/score/cpu/i386/cpu.h (modified) * c/src/exec/score/cpu/i386/cpu_asm.s (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/include/rdbg/i386/rdbg_f.h (added) * c/src/lib/include/rdbg/i386/reg.h (added) * c/src/lib/include/rdbg/rdbg.h (added) * c/src/lib/include/rdbg/servrpc.h (added) * c/src/lib/include/rpc/auth.h (added) * c/src/lib/include/rpc/clnt.h (added) * c/src/lib/include/rpc/rpc.h (added) * c/src/lib/include/rpc/rpc_msg.h (added) * c/src/lib/include/rpc/svc.h (added) * c/src/lib/include/rpc/svc_auth.h (added) * c/src/lib/include/rpc/types.h (added) * c/src/lib/include/rpc/xdr.h (added) * c/src/lib/librdbg/Makefile.in (added) * c/src/lib/librdbg/_servtgt.c (added) * c/src/lib/librdbg/awk.svc (added) * c/src/lib/librdbg/i386/excep.c (added) * c/src/lib/librdbg/i386/pc386/remdeb_f.x (added) * c/src/lib/librdbg/i386/rdbg_cpu_asm.s (added) * c/src/lib/librdbg/i386/rdbg_f.c (added) * c/src/lib/librdbg/ptrace.c (added) * c/src/lib/librdbg/rdbg.c (added) * c/src/lib/librdbg/remdeb.x (added) * c/src/lib/librdbg/servbkpt.c (added) * c/src/lib/librdbg/servcon.c (added) * c/src/lib/librdbg/servrpc.c (added) * c/src/lib/librdbg/servtgt.c (added) * c/src/lib/librdbg/servtsp.c (added) * c/src/lib/librdbg/servutil.c (added) * c/src/lib/librpc/Makefile.in (added) * c/src/lib/librpc/rpc_callmsg.c (added) * c/src/lib/librpc/rpc_prot.c (added) * c/src/lib/librpc/svc.c (added) * c/src/lib/librpc/svc_auth.c (added) * c/src/lib/librpc/svc_udp.c (added) * c/src/lib/librpc/xdr.c (added) * c/src/lib/librpc/xdr_array.c (added) * c/src/lib/librpc/xdr_mem.c (added) * c/src/lib/wrapup/Makefile.in (modified) * c/src/librdbg/include/rdbg/i386/rdbg_f.h (added) * c/src/librdbg/include/rdbg/i386/reg.h (added) * c/src/librdbg/include/rdbg/rdbg.h (added) * c/src/librdbg/include/rdbg/servrpc.h (added) * c/src/librdbg/src/Makefile.in (added) * c/src/librdbg/src/_servtgt.c (added) * c/src/librdbg/src/awk.svc (added) * c/src/librdbg/src/i386/any/remdeb_f.x (added) * c/src/librdbg/src/i386/excep.c (added) * c/src/librdbg/src/i386/pc386/remdeb_f.x (added) * c/src/librdbg/src/i386/rdbg_cpu_asm.s (added) * c/src/librdbg/src/i386/rdbg_f.c (added) * c/src/librdbg/src/ptrace.c (added) * c/src/librdbg/src/rdbg.c (added) * c/src/librdbg/src/remdeb.x (added) * c/src/librdbg/src/servbkpt.c (added) * c/src/librdbg/src/servcon.c (added) * c/src/librdbg/src/servrpc.c (added) * c/src/librdbg/src/servtgt.c (added) * c/src/librdbg/src/servtsp.c (added) * c/src/librdbg/src/servutil.c (added) * c/src/librpc/include/rpc/auth.h (added) * c/src/librpc/include/rpc/clnt.h (added) * c/src/librpc/include/rpc/rpc.h (added) * c/src/librpc/include/rpc/rpc_msg.h (added) * c/src/librpc/include/rpc/svc.h (added) * c/src/librpc/include/rpc/svc_auth.h (added) * c/src/librpc/include/rpc/types.h (added) * c/src/librpc/include/rpc/xdr.h (added) * c/src/librpc/src/Makefile.in (added) * c/src/librpc/src/rpc_callmsg.c (added) * c/src/librpc/src/rpc_prot.c (added) * c/src/librpc/src/svc.c (added) * c/src/librpc/src/svc_auth.c (added) * c/src/librpc/src/svc_udp.c (added) * c/src/librpc/src/xdr.c (added) * c/src/librpc/src/xdr_array.c (added) * c/src/librpc/src/xdr_mem.c (added) * c/src/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) * cpukit/librpc/include/rpc/auth.h (added) * cpukit/librpc/include/rpc/clnt.h (added) * cpukit/librpc/include/rpc/rpc.h (added) * cpukit/librpc/include/rpc/rpc_msg.h (added) * cpukit/librpc/include/rpc/svc.h (added) * cpukit/librpc/include/rpc/svc_auth.h (added) * cpukit/librpc/include/rpc/types.h (added) * cpukit/librpc/include/rpc/xdr.h (added) * make/custom/default.cfg (modified) * make/target.cfg.in (modified) Patch from Emmanuel Raguet to add remote debug ... Mon, 23 Nov 1998 17:38:09 GMT Joel Sherrill [97e2729d] * aclocal.m4 (modified) * c/src/exec/posix/headers/Makefile.in (modified) * c/src/exec/posix/headers/cond.h (modified) * c/src/exec/posix/headers/mqueue.h (modified) * c/src/exec/posix/headers/mutex.h (modified) * c/src/exec/posix/headers/pthread.h (modified) * c/src/exec/posix/headers/semaphore.h (modified) * c/src/exec/posix/include/rtems/posix/Makefile.in (modified) * c/src/exec/posix/include/rtems/posix/cond.h (modified) * c/src/exec/posix/include/rtems/posix/mqueue.h (modified) * c/src/exec/posix/include/rtems/posix/mutex.h (modified) * c/src/exec/posix/include/rtems/posix/pthread.h (modified) * c/src/exec/posix/include/rtems/posix/semaphore.h (modified) * c/src/exec/posix/src/cond.c (modified) * c/src/exec/posix/src/mutex.c (modified) * c/src/exec/rtems/headers/Makefile.in (modified) * c/src/exec/rtems/headers/event.h (modified) * c/src/exec/rtems/headers/message.h (modified) * c/src/exec/rtems/headers/part.h (modified) * c/src/exec/rtems/headers/region.h (modified) * c/src/exec/rtems/headers/rtems.h (modified) * c/src/exec/rtems/headers/sem.h (modified) * c/src/exec/rtems/headers/signal.h (modified) * c/src/exec/rtems/headers/tasks.h (modified) * c/src/exec/rtems/headers/types.h (modified) * c/src/exec/rtems/include/rtems.h (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/include/rtems/rtems/event.h (modified) * c/src/exec/rtems/include/rtems/rtems/message.h (modified) * c/src/exec/rtems/include/rtems/rtems/part.h (modified) * c/src/exec/rtems/include/rtems/rtems/region.h (modified) * c/src/exec/rtems/include/rtems/rtems/sem.h (modified) * c/src/exec/rtems/include/rtems/rtems/signal.h (modified) * c/src/exec/rtems/include/rtems/rtems/tasks.h (modified) * c/src/exec/rtems/include/rtems/rtems/types.h (modified) * c/src/exec/rtems/inline/attr.inl (modified) * c/src/exec/rtems/inline/rtems/rtems/attr.inl (modified) * c/src/exec/rtems/macros/attr.inl (modified) * c/src/exec/rtems/macros/rtems/rtems/attr.inl (modified) * c/src/exec/rtems/optman/Makefile.in (modified) * c/src/exec/rtems/optman/no-mp.c (modified) * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/rtems/src/dpmem.c (modified) * c/src/exec/rtems/src/event.c (modified) * c/src/exec/rtems/src/msg.c (modified) * c/src/exec/rtems/src/part.c (modified) * c/src/exec/rtems/src/ratemon.c (modified) * c/src/exec/rtems/src/region.c (modified) * c/src/exec/rtems/src/rtemstimer.c (modified) * c/src/exec/rtems/src/sem.c (modified) * c/src/exec/rtems/src/signal.c (modified) * c/src/exec/rtems/src/tasks.c (modified) * c/src/exec/rtems/src/timer.c (modified) * c/src/exec/sapi/headers/config.h (modified) * c/src/exec/sapi/headers/sptables.h (modified) * c/src/exec/sapi/include/rtems/config.h (modified) * c/src/exec/sapi/include/rtems/sptables.h (modified) * c/src/exec/sapi/src/exinit.c (modified) * c/src/exec/sapi/src/rtemsapi.c (modified) * c/src/exec/score/headers/Makefile.in (modified) * c/src/exec/score/headers/object.h (modified) * c/src/exec/score/headers/thread.h (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/exec/score/include/rtems/score/object.h (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/inline/Makefile.in (modified) * c/src/exec/score/inline/rtems/score/Makefile.in (modified) * c/src/exec/score/macros/Makefile.in (modified) * c/src/exec/score/macros/rtems/score/Makefile.in (modified) * c/src/exec/score/src/Makefile.in (modified) * c/src/exec/score/src/coremsg.c (modified) * c/src/exec/score/src/coremutex.c (modified) * c/src/exec/score/src/coresem.c (modified) * c/src/exec/score/src/mpci.c (modified) * c/src/exec/score/src/object.c (modified) * c/src/exec/score/src/thread.c (modified) * c/src/exec/score/src/threadq.c (modified) * c/src/exec/score/tools/generic/size_rtems.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/Makefile.in (modified) * c/src/lib/libmisc/monitor/Makefile.in (modified) * c/src/lib/libmisc/monitor/mon-object.c (modified) * c/src/lib/libmisc/monitor/monitor.h (modified) * c/src/libmisc/monitor/Makefile.in (modified) * c/src/libmisc/monitor/mon-object.c (modified) * c/src/libmisc/monitor/monitor.h (modified) * c/src/optman/rtems/no-mp.c (modified) * c/src/tests/sptests/spsize/size.c (modified) * configure (modified) * configure.in (modified) * cpukit/libmisc/monitor/mon-object.c (modified) * cpukit/libmisc/monitor/monitor.h (modified) * cpukit/posix/include/rtems/posix/cond.h (modified) * cpukit/posix/include/rtems/posix/mqueue.h (modified) * cpukit/posix/include/rtems/posix/mutex.h (modified) * cpukit/posix/include/rtems/posix/pthread.h (modified) * cpukit/posix/include/rtems/posix/semaphore.h (modified) * cpukit/posix/src/cond.c (modified) * cpukit/posix/src/mutex.c (modified) * cpukit/rtems/include/rtems.h (modified) * cpukit/rtems/include/rtems/rtems/event.h (modified) * cpukit/rtems/include/rtems/rtems/message.h (modified) * cpukit/rtems/include/rtems/rtems/part.h (modified) * cpukit/rtems/include/rtems/rtems/region.h (modified) * cpukit/rtems/include/rtems/rtems/sem.h (modified) * cpukit/rtems/include/rtems/rtems/signal.h (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/include/rtems/rtems/types.h (modified) * cpukit/rtems/inline/rtems/rtems/attr.inl (modified) * cpukit/rtems/macros/rtems/rtems/attr.inl (modified) * cpukit/rtems/src/dpmem.c (modified) * cpukit/rtems/src/event.c (modified) * cpukit/rtems/src/msg.c (modified) * cpukit/rtems/src/part.c (modified) * cpukit/rtems/src/ratemon.c (modified) * cpukit/rtems/src/region.c (modified) * cpukit/rtems/src/rtemstimer.c (modified) * cpukit/rtems/src/sem.c (modified) * cpukit/rtems/src/signal.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/sapi/src/exinit.c (modified) * cpukit/sapi/src/rtemsapi.c (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/coremsg.c (modified) * cpukit/score/src/coremutex.c (modified) * cpukit/score/src/coresem.c (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/object.c (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threadq.c (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/default.cfg (modified) * make/custom/dmv177.cfg (modified) * make/custom/force386.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147s.cfg (modified) * make/custom/no_bsp.cfg (modified) * make/custom/simhppa.cfg (modified) * make/leaf.cfg (modified) * make/target.cfg.in (modified) * testsuites/sptests/spsize/size.c (modified) * tools/cpu/generic/size_rtems.in (modified) Added --disable-multiprocessing flag and modified a lot of files to ... Mon, 23 Nov 1998 16:38:13 GMT Joel Sherrill [35e5ae64] * make/custom/i386ex.cfg (modified) Removed "HAS_NETWORKING=no". Thu, 19 Nov 1998 21:57:39 GMT Joel Sherrill [588b689] * make/custom/efi332.cfg (modified) Bug report from Peter Mueller : I use the ... Wed, 28 Oct 1998 19:17:16 GMT Joel Sherrill [692b9f7] * aclocal.m4 (modified) * aclocal/canonicalize-tools.m4 (modified) * c/Makefile.in (modified) * c/src/exec/libcsupport/include/sys/termios.h (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/sys/termios.h (modified) * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/lib/libchip/serial/ns16550.c (modified) * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/z85c30.c (modified) * c/src/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) * cpukit/libcsupport/include/sys/termios.h (modified) * make/custom/psim.cfg (modified) * make/target.cfg.in (modified) Merged Vista SCORE603e, Radstone PPCn_60x, and DY-4 DMV177 BSPs along ... Thu, 22 Oct 1998 18:16:25 GMT Joel Sherrill [6e0721a] * make/custom/i386ex.cfg (modified) Patch from Erik Ivanenko : Please ... Thu, 15 Oct 1998 19:19:35 GMT Joel Sherrill [fae18771] * make/custom/gen68340.cfg (modified) Removed unnecessary settings. Tue, 13 Oct 1998 15:03:27 GMT Joel Sherrill [714137ef] * c/src/exec/score/cpu/sh/cpu_isps.c (modified) * c/src/exec/score/cpu/sh/ispsh7032.c (modified) * c/src/lib/libcpu/sh/sh7032/score/ispsh7032.c (modified) * make/custom/gensh1.cfg (modified) Patch from Ralf Corsepius to correct minor ... Mon, 05 Oct 1998 13:53:16 GMT Joel Sherrill [09213ec3] * configure (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) Patch from Ralf Corsepius : As mentioned ... Thu, 01 Oct 1998 18:48:43 GMT Joel Sherrill [e125ad3] * make/custom/helas403.cfg (modified) Switched from HAS_KA9Q=no to HAS_NETWORKING=no. Thu, 01 Oct 1998 18:38:53 GMT Joel Sherrill [a0b7a07] * make/custom/gen68360.cfg (modified) Patch from Eric Norum : Here's a patch ... Wed, 30 Sep 1998 21:50:42 GMT Joel Sherrill [be4284d0] * c/src/lib/libbsp/powerpc/helas403/Makefile.in (added) * c/src/lib/libbsp/powerpc/helas403/README (added) * c/src/lib/libbsp/powerpc/helas403/bsp_specs (added) * c/src/lib/libbsp/powerpc/helas403/bsp_specs.dl (added) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.in (added) * c/src/lib/libbsp/powerpc/helas403/dlentry/dlentry.s (added) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.in (added) * c/src/lib/libbsp/powerpc/helas403/flashentry/flashentry.s (added) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.in (added) * c/src/lib/libbsp/powerpc/helas403/include/bsp.h (added) * c/src/lib/libbsp/powerpc/helas403/include/coverhd.h (added) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.in (added) * c/src/lib/libbsp/powerpc/helas403/startup/bspclean.c (added) * c/src/lib/libbsp/powerpc/helas403/startup/bspstart.c (added) * c/src/lib/libbsp/powerpc/helas403/startup/linkcmds (added) * c/src/lib/libbsp/powerpc/helas403/startup/linkcmds.dl (added) * c/src/lib/libbsp/powerpc/helas403/startup/setvec.c (added) * c/src/lib/libbsp/powerpc/helas403/times (added) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.in (added) * make/custom/helas403.cfg (added) BSP submitted by Thomas Doerfler : Finally I ... Wed, 30 Sep 1998 13:02:30 GMT Joel Sherrill [17408b90] * c/src/exec/score/cpu/m68k/cpu_asm.s (modified) * c/src/exec/score/cpu/m68k/m68k.h (modified) * make/custom/gen68360.cfg (modified) Patch from Eric Norum : I found that my ... Fri, 11 Sep 1998 23:35:09 GMT Joel Sherrill [bfcf4cb3] * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.c (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/sonic.h (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (modified) * c/src/lib/libchip/serial/mc68681.c (modified) * c/src/lib/libchip/serial/ns16550.c (modified) * c/src/lib/libchip/serial/z85c30.c (modified) * c/src/libchip/serial/mc68681.c (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/z85c30.c (modified) * make/custom/dmv177.cfg (modified) Updates to tree to make it build with all desired changes and the ... Fri, 21 Aug 1998 17:43:22 GMT Joel Sherrill [cce81a7] * configure (modified) * configure.in (modified) * make/Makefile.in (modified) * make/compilers/gcc.cfg.in (added) * make/custom/default.cfg (modified) A patch from Ralf Corsepius : Here is ... Thu, 20 Aug 1998 22:04:22 GMT Joel Sherrill [28e7d7fa] * c/Makefile.in (modified) * c/src/exec/libnetworking/arpa/inet.h (modified) * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/exec/score/cpu/i386/cpu.h (modified) * c/src/exec/score/headers/Makefile.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/libbsp/bare/README (modified) * c/src/lib/libbsp/bare/do-bare-bsp-build (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/network/network.c (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/README (modified) * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/libnetworking/arpa/inet.h (modified) * c/src/lib/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/libnetworking/arpa/inet.h (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) * cpukit/libnetworking/arpa/inet.h (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) * make/Templates/Makefile.inc.in (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/default.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/force386.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/go32.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/no_bsp.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/portsw.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/simhppa.cfg (modified) * make/target.cfg.in (modified) Patches from Eric Norum Thu, 20 Aug 1998 14:39:09 GMT Joel Sherrill [0280cb6] * c/Makefile.in (modified) * c/src/exec/score/cpu/i386/cpu.h (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/network.c (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/default.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/force386.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/go32.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/no_bsp.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/portsw.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/simhppa.cfg (modified) * make/target.cfg.in (modified) FreeBSD stack compiles for the first time (except libc/strsep.c) Wed, 19 Aug 1998 14:41:23 GMT Joel Sherrill [2d7d605] * aclocal.m4 (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/network/network.c (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/start/start.s (modified) * c/src/lib/libbsp/i386/pc386/timer/timer.c (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/io/bspIo.h (modified) * c/src/lib/libbsp/i386/shared/irq/irq_asm.s (modified) * configure (modified) * make/custom/pc386.cfg (modified) Patch from Aleksey : It fixes netboot build ... Wed, 19 Aug 1998 12:42:35 GMT Joel Sherrill [b93a1ab] * make/custom/pc386.cfg (modified) Cleaned up the ka9q definition. Wed, 05 Aug 1998 15:44:09 GMT Joel Sherrill [0e3c0096] * make/custom/pc386.cfg (modified) changed load address Thu, 30 Jul 1998 15:56:59 GMT Joel Sherrill [032c100] * make/custom/dmv177.cfg (modified) Added HAS_RTC and enabled KA9Q. Sat, 25 Jul 1998 16:20:57 GMT Joel Sherrill [db29826d] * make/custom/dmv177.cfg (modified) Switching console interrupts on and off as we test. Thu, 23 Jul 1998 22:13:10 GMT Joel Sherrill [dbaf51a] * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/wd80x3.h (added) * c/src/lib/libbsp/i386/pc386/network/Makefile.in (added) * c/src/lib/libbsp/i386/pc386/network/network.c (added) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/tests/samples/Makefile.in (modified) * make/custom/pc386.cfg (modified) Patch from Emmanuel Raguet : Here is a ... Fri, 17 Jul 1998 15:18:08 GMT Joel Sherrill [9305e52] * make/custom/gensh1.cfg (modified) Patch from Ralf Corsepius . Changes to ... Wed, 15 Jul 1998 13:59:36 GMT Joel Sherrill [25e3f9a] * make/custom/dmv177.cfg (modified) Switched CONSOLE_USE_INTERRUPTS to "1" so console would use ... Thu, 09 Jul 1998 18:52:07 GMT Joel Sherrill [d7d51376] * make/custom/dmv177.cfg (modified) Now strip elf executables so they are much smaller and quicker to ... Wed, 01 Jul 1998 22:03:20 GMT Joel Sherrill [132f194] * c/src/lib/libbsp/m68k/gen68340/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/README (added) * c/src/lib/libbsp/m68k/gen68340/bsp_specs (added) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/clock/ckinit.c (added) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/console/Modif_cpu_asm.s (added) * c/src/lib/libbsp/m68k/gen68340/console/console.c (added) * c/src/lib/libbsp/m68k/gen68340/console/m340uart.c (added) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/include/bsp.h (added) * c/src/lib/libbsp/m68k/gen68340/include/coverhd.h (added) * c/src/lib/libbsp/m68k/gen68340/include/m340timer.h (added) * c/src/lib/libbsp/m68k/gen68340/include/m340uart.h (added) * c/src/lib/libbsp/m68k/gen68340/include/m68340.h (added) * c/src/lib/libbsp/m68k/gen68340/include/m68340.inc (added) * c/src/lib/libbsp/m68k/gen68340/include/m68349.inc (added) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/start/start340.s (added) * c/src/lib/libbsp/m68k/gen68340/start340/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/start340/start340.s (added) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/startup/bspclean.c (added) * c/src/lib/libbsp/m68k/gen68340/startup/bspstart.c (added) * c/src/lib/libbsp/m68k/gen68340/startup/dumpanic.c (added) * c/src/lib/libbsp/m68k/gen68340/startup/init68340.c (added) * c/src/lib/libbsp/m68k/gen68340/startup/linkcmds (added) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.in (added) * c/src/lib/libbsp/m68k/gen68340/timer/timer.c (added) * make/custom/gen68340.cfg (added) Initial submission of gen68340 BSP (should run on a 68349) from ... Mon, 29 Jun 1998 17:52:43 GMT Joel Sherrill [4f0fc115] * make/custom/pc386.cfg (modified) Correction from Aleksey Romanov to finish off his ... Sat, 27 Jun 1998 18:51:49 GMT Joel Sherrill [5d18fb0] * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/bsp_specs (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/console/inch.c (modified) * c/src/lib/libbsp/i386/pc386/console/outch.c (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/start/start.s (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/exit.c (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.s (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/bin2boot.c (modified) * c/src/lib/libbsp/i386/pc386/tools/binpatch.c (added) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * make/custom/pc386.cfg (modified) * tools/build/binpatch.c (added) PC386 BSP enhancements from Aleksey Romanov (Quality Quorum ... Sat, 27 Jun 1998 17:09:47 GMT Joel Sherrill [98100d2] * Makefile.in (modified) * aclocal.m4 (modified) * aclocal/ar-s.m4 (added) * aclocal/canonicalize-tools.m4 (modified) * aclocal/cygwin.m4 (added) * aclocal/exeext.m4 (added) * aclocal/gcc-pipe.m4 (modified) * aclocal/gcc-specs.m4 (modified) * c/PROBLEMS (modified) * c/build-tools/scripts/Makefile.in (modified) * c/build-tools/src/Makefile.in (modified) * c/src/exec/score/tools/generic/size_rtems.in (modified) * c/src/lib/libbsp/i386/pc386/tools/bin2boot.c (modified) * c/src/lib/libbsp/m68k/idp/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme162/console/console.c (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/make/README (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/host.cfg.in (modified) * c/src/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) * make/README (modified) * make/compilers/gcc-no_bsp.cfg (modified) * make/compilers/gcc-portsw.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/bare.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/force386.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gen68360.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/go32.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/no_bsp.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/pc386.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/simhppa.cfg (modified) * make/host.cfg.in (modified) * make/target.cfg.in (modified) * tools/build/scripts/Makefile.in (modified) * tools/build/src/Makefile.in (modified) * tools/cpu/generic/size_rtems.in (modified) Monstrous patch from Ralf Corsepius . I ... Thu, 25 Jun 1998 16:21:07 GMT Joel Sherrill [43b78f15] * make/custom/gen68360.cfg (modified) Added definition of RTEMS__mcpu32p__ per patch from Robin Kirkham. Thu, 18 Jun 1998 19:05:08 GMT Joel Sherrill [8ed1f8d0] * make/custom/FreeBSD-posix.cfg (added) New file from Dario Alcocer . Sat, 13 Jun 1998 10:05:15 GMT Joel Sherrill [e5727f39] * make/custom/dmv177.cfg (modified) Added PPC_USE_DATA_CACHE. Wed, 03 Jun 1998 18:40:21 GMT Joel Sherrill [1ce50e0] * make/custom/erc32.cfg (modified) Changed spacing Wed, 03 Jun 1998 18:40:10 GMT Joel Sherrill [3ac59666] * make/custom/Solaris-posix.cfg (modified) Changed BSP name to posix. Wed, 03 Jun 1998 18:39:53 GMT Joel Sherrill [b938d3d4] * make/custom/papyrus.cfg (modified) * make/custom/psim.cfg (modified) Changed ppc to PowerPC in comments. Sat, 30 May 1998 11:46:21 GMT Joel Sherrill [dc104a4] * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/clock.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/console/console.c (modified) * c/src/lib/libbsp/powerpc/dmv177/console/duart.c (modified) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/dmv177/include/dmv170.h (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/start/start.s (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/genpvec.c (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/setvec.c (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/timer.c (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/tod.c (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (modified) * make/custom/dmv177.cfg (modified) Updated to current source and removed warnings. Sat, 30 May 1998 10:17:57 GMT Joel Sherrill [9c559acc] * make/custom/dmv177.cfg (added) New file -- from rtems-LM-980406 based on a 12/97 RTEMS snapshot. Wed, 27 May 1998 22:07:40 GMT Joel Sherrill [27291bcc] * make/custom/pc386.cfg (modified) Changed invocation of bin2boot to match gcc 2.8 rule. Fri, 22 May 1998 12:30:19 GMT Joel Sherrill [cdf6fcbc] * make/custom/bare.cfg (modified) Now uses BSP specific configure variables and compiles for i486 and m68k. Thu, 21 May 1998 18:26:58 GMT Joel Sherrill [bd5e4f3b] * c/src/lib/libbsp/Makefile.in (modified) * c/src/lib/libbsp/bare/Makefile.in (added) * c/src/lib/libbsp/bare/README (added) * c/src/lib/libbsp/bare/bsp_specs (added) * c/src/lib/libbsp/bare/include/Makefile.in (added) * c/src/lib/libbsp/bare/include/bsp.h (added) * c/src/lib/libbsp/bare/wrapup/Makefile.in (added) * configure (modified) * configure.in (modified) * make/custom/bare.cfg (added) * make/leaf.cfg (modified) * make/target.cfg.in (modified) Added bare bsp from Chris Johns . Thu, 21 May 1998 16:41:56 GMT Joel Sherrill [1e9c9d4] * make/custom/posix.cfg (modified) Per patch from Ralf Corsepius removed redundant lines. Thu, 21 May 1998 16:41:40 GMT Joel Sherrill [dd84f12] * make/custom/Solaris-posix.cfg (modified) Removed undesirable space in TARGET_ARCH assignment line. Cleaned ... Thu, 21 May 1998 16:40:46 GMT Joel Sherrill [d494eeb4] * make/custom/Linux-posix.cfg (modified) Per patch from Ralf Corsepius UNIX ports always needs C++ for rtems- ... Wed, 20 May 1998 17:02:29 GMT Joel Sherrill [17a8d603] * make/custom/Solaris-posix.cfg (modified) Some patches in place from Brian Stevens which help the Solaris port ... Wed, 20 May 1998 17:01:39 GMT Joel Sherrill [7aa10b0] * make/custom/Linux-posix.cfg (modified) Copied gcc 2.7.2 style make-exe rule to gcc 2.8 conditional. This ... Mon, 18 May 1998 16:40:13 GMT Joel Sherrill [ca0bafa7] * make/custom/posix.cfg (modified) Added much stuff formerly in multiple compiler files. Mon, 18 May 1998 16:39:49 GMT Joel Sherrill [0500c342] * make/custom/default.cfg (modified) Added conditional around TARGET_ARCH to prevent accidental overrides. Mon, 18 May 1998 16:39:21 GMT Joel Sherrill [7ebfa93] * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) Switched to using shared gcc-target-default.cfg. Mon, 04 May 1998 13:19:29 GMT Joel Sherrill [7123d3b] * make/custom/pc386.cfg (modified) Modified objcopy to remove extra sections. Modified gcc 2.8 style ... Thu, 30 Apr 1998 16:45:55 GMT Joel Sherrill [3d4e5906] * make/custom/go32.cfg (modified) Changed default target architecture name Thu, 30 Apr 1998 16:45:08 GMT Joel Sherrill [5f92a6a3] * make/custom/pc386.cfg (modified) Modified objcopy invocation to ignore more sections. Mon, 27 Apr 1998 18:42:04 GMT Joel Sherrill [96d56b3] * c/src/lib/libbsp/i386/pc386/HOWTO (modified) * c/src/lib/libbsp/i386/pc386/bsp_specs (modified) * c/src/lib/libbsp/i386/pc386/console/inch.c (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/start/start.s (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.s (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/bin2boot.c (deleted) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * make/custom/pc386.cfg (modified) Update from Pedro Romano . Mon, 27 Apr 1998 14:21:55 GMT Joel Sherrill [0e70f605] * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/posix.cfg (modified) Fixes from Ralf Corsepius: * Posix BSP configuration: Moved ... Mon, 27 Apr 1998 14:21:04 GMT Joel Sherrill [c1dc8228] * make/custom/gensh1.cfg (modified) Removed forced enable of POSIX API. Now follow configuration flag. Wed, 15 Apr 1998 15:10:47 GMT Joel Sherrill [b3d3a34e] * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/force386.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gen68360.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/go32.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/pc386.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/simhppa.cfg (modified) Stack checker now enabled via initial set of user extensions. This ... Tue, 14 Apr 1998 22:44:49 GMT Joel Sherrill [4381e50] * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/exec/score/cpu/unix/cpu.c (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.in (modified) * cpukit/score/cpu/unix/cpu.c (modified) * make/custom/Linux-posix.cfg (modified) Ralf Corsepius suggested a way to get rid of UNIX compiler files and ... Tue, 14 Apr 1998 22:13:05 GMT Joel Sherrill [2758c9f2] * configure (modified) * configure.in (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) Ralf Corsepius suggested a way to get rid of UNIX compiler files and ... Tue, 14 Apr 1998 21:33:20 GMT Joel Sherrill [1504f71e] * make/custom/psim.cfg (modified) Stack checker on Tue, 14 Apr 1998 21:32:56 GMT Joel Sherrill [92e15e0] * make/custom/papyrus.cfg (modified) Updates from PPC refresh Tue, 14 Apr 1998 19:54:38 GMT Joel Sherrill [b0562e74] * make/custom/psim.cfg (added) new file Mon, 06 Apr 1998 16:33:48 GMT Joel Sherrill [1ea9c3f] * make/custom/cvme961.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/force386.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gen68360.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/go32.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/pc386.cfg (modified) * make/custom/simhppa.cfg (modified) Purged references to STACK_CHECKER_REPORT_USAGE Mon, 06 Apr 1998 15:55:37 GMT Joel Sherrill [9d07e59d] * make/custom/gen68360.cfg (modified) Changed CPU model to mcpu32. Mon, 30 Mar 1998 14:05:03 GMT Joel Sherrill [c5fcc75e] * make/custom/portsw.cfg (modified) Made the POSIX API option follow the configure line. Mon, 30 Mar 1998 14:04:44 GMT Joel Sherrill [26580ff] * make/custom/no_bsp.cfg (modified) Made the HAS_POSIX_API follow the configure line option. Mon, 30 Mar 1998 14:04:20 GMT Joel Sherrill [de0d005] * make/custom/gensh1.cfg (modified) Made the C++ option follow the configure option. Mon, 30 Mar 1998 14:03:59 GMT Joel Sherrill [cbf2f54] * make/custom/default.cfg (modified) Made HAS_POSIX_API have a "no" definition when it is not enabled. Mon, 30 Mar 1998 14:03:34 GMT Joel Sherrill [83997e2f] * make/custom/HPUX9-posix.cfg (modified) Made C++ follow the configure option. Tue, 24 Mar 1998 18:44:40 GMT Joel Sherrill [e6c92eef] * make/custom/simhppa.cfg (modified) Changed RTEMS cpu to hppa1.1. Tue, 24 Mar 1998 16:24:39 GMT Joel Sherrill [3ec7bfc] * README.configure (modified) * c/src/exec/score/cpu/unix/cpu.c (modified) * c/src/exec/score/cpu/unix/cpu.h (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/m68k-stub.c (modified) * c/src/lib/libbsp/shmdr/shm.h (modified) * c/src/lib/libbsp/shmdr/shm_driver.h (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/clock.c (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/timer.c (modified) * c/src/lib/start/README (modified) * c/src/libchip/shmdr/shm_driver.h (modified) * c/src/tests/samples/cdtest/main.cc (modified) * c/src/tests/sptests/spsize/size.c (modified) * cpukit/score/cpu/unix/cpu.c (modified) * make/custom/simhppa.cfg (modified) * testsuites/samples/cdtest/main.cc (modified) * testsuites/sptests/spsize/size.c (modified) Rename hppa1_1 to hppa1.1 and switched to using __XXX__ macros for ... Mon, 23 Mar 1998 22:54:55 GMT Joel Sherrill [e4829a05] * c/src/exec/score/tools/generic/size_rtems.in (modified) * configure (modified) * configure.in (modified) * make/custom/papyrus.cfg (modified) * tools/cpu/generic/size_rtems.in (modified) renamed ppc to powerpc Mon, 23 Mar 1998 18:35:07 GMT Joel Sherrill [61bbe543] * make/custom/gen68360.cfg (modified) Update from Eric Norum: Here are some patches to the gen68360 ... Fri, 20 Mar 1998 17:39:56 GMT Joel Sherrill [db4aaf8] * make/custom/gen68360.cfg (modified) Patch from Eric Norum : I've included a ... Fri, 20 Mar 1998 17:20:45 GMT Joel Sherrill [f8b27df9] * c/src/lib/libbsp/sh/gensh1/start/Makefile.in (added) * c/src/lib/libbsp/sh/shared/setvec.c (added) * c/src/lib/libcpu/sh/Makefile.in (added) * c/src/lib/libcpu/sh/sh7032/Makefile.in (added) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.in (added) * c/src/lib/libcpu/sh/sh7032/clock/ckinit.c (added) * c/src/lib/libcpu/sh/sh7032/console/Makefile.in (added) * c/src/lib/libcpu/sh/sh7032/console/console.c (added) * c/src/lib/libcpu/sh/sh7032/include/Makefile.in (added) * c/src/lib/libcpu/sh/sh7032/include/ioqueue.h (added) * c/src/lib/libcpu/sh/sh7032/include/null.h (added) * c/src/lib/libcpu/sh/sh7032/include/sh7_pfc.h (added) * c/src/lib/libcpu/sh/sh7032/include/sh7_sci.h (added) * c/src/lib/libcpu/sh/sh7032/null/Makefile.in (added) * c/src/lib/libcpu/sh/sh7032/null/close.c (added) * c/src/lib/libcpu/sh/sh7032/null/cntrl.c (added) * c/src/lib/libcpu/sh/sh7032/null/init.c (added) * c/src/lib/libcpu/sh/sh7032/null/open.c (added) * c/src/lib/libcpu/sh/sh7032/null/read.c (added) * c/src/lib/libcpu/sh/sh7032/null/write.c (added) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.in (added) * c/src/lib/libcpu/sh/sh7032/timer/timer.c (added) * c/src/lib/start/sh/Makefile.in (added) * c/src/lib/start/sh/start.s (added) * make/custom/gensh1.cfg (added) New port from Ralf Corsepius . Thu, 19 Feb 1998 23:02:16 GMT Joel Sherrill [96c73ab] * c/src/lib/libbsp/m68k/gen68360/console/console.c (modified) * make/custom/gen68360.cfg (modified) Patch from Eric Norum: While trying to work through this problem ... Wed, 18 Feb 1998 20:30:53 GMT Joel Sherrill [7324989] * make/custom/erc32.cfg (modified) Went back to polled console. Wed, 04 Feb 1998 15:47:44 GMT Joel Sherrill [e44e678] * make/custom/erc32.cfg (modified) Cleaned up the definition of CONSOLE_USE_POLLED and ... Tue, 27 Jan 1998 14:14:20 GMT Joel Sherrill [1333181] * make/custom/gensh1.cfg (deleted) not submitted Fri, 23 Jan 1998 17:45:05 GMT Joel Sherrill [2936b425] * Makefile.in (modified) * c/build-tools/eolstrip.c (modified) * c/build-tools/packhex.c (modified) * c/build-tools/src/eolstrip.c (modified) * c/build-tools/src/packhex.c (modified) * c/src/exec/libcsupport/src/__gettod.c (modified) * c/src/exec/libcsupport/src/error.c (modified) * c/src/exec/score/cpu/unix/cpu.c (modified) * c/src/exec/wrapup/rtems/Makefile.in (modified) * c/src/lib/include/rtems++/rtemsInterrupt.h (modified) * c/src/lib/libbsp/unix/posix/timer/timer.c (modified) * c/src/lib/libc/__gettod.c (modified) * c/src/lib/libc/error.c (modified) * c/src/lib/libmisc/error/error.c (modified) * c/src/lib/libmisc/monitor/mon-symbols.c (modified) * c/src/lib/librtems++/rtemsMessageQueue.cc (modified) * c/src/lib/librtems++/rtemsSemaphore.cc (modified) * c/src/lib/librtems++/rtemsTask.cc (modified) * c/src/lib/librtems++/rtemsTimer.cc (modified) * c/src/libmisc/error/error.c (modified) * c/src/libmisc/monitor/mon-symbols.c (modified) * c/src/librtems++/include/rtems++/rtemsInterrupt.h (modified) * c/src/librtems++/src/rtemsMessageQueue.cc (modified) * c/src/librtems++/src/rtemsSemaphore.cc (modified) * c/src/librtems++/src/rtemsTask.cc (modified) * c/src/librtems++/src/rtemsTimer.cc (modified) * c/src/make/directory.cfg (modified) * c/src/tests/samples/cdtest/main.cc (modified) * c/src/tests/samples/paranoia/paranoia.c (modified) * cpukit/libcsupport/src/__gettod.c (modified) * cpukit/libcsupport/src/error.c (modified) * cpukit/libmisc/monitor/mon-symbols.c (modified) * cpukit/score/cpu/unix/cpu.c (modified) * make/custom/Solaris-posix.cfg (modified) * make/directory.cfg (modified) * testsuites/samples/cdtest/main.cc (modified) * testsuites/samples/paranoia/paranoia.c (modified) * tools/build/eolstrip.c (modified) * tools/build/packhex.c (modified) * tools/build/src/eolstrip.c (modified) * tools/build/src/packhex.c (modified) Solaris port updates from Chris Johns Tue, 20 Jan 1998 19:30:30 GMT Joel Sherrill [bffb938] * c/src/make/README (added) * c/src/make/compilers/gcc-target-default.cfg (added) * c/src/make/directory.cfg (added) * c/src/make/host.cfg.in (added) * c/src/make/lib.cfg (added) * make/Makefile.in (added) * make/README (added) * make/Templates/Makefile.dir (added) * make/Templates/Makefile.inc.in (added) * make/Templates/Makefile.leaf (added) * make/Templates/Makefile.lib (added) * make/compilers/gcc-no_bsp.cfg (added) * make/compilers/gcc-portsw.cfg (added) * make/compilers/gcc-target-default.cfg (added) * make/custom/HPUX9-posix.cfg (added) * make/custom/Linux-posix.cfg (added) * make/custom/Solaris-posix.cfg (added) * make/custom/cvme961.cfg (added) * make/custom/default.cfg (added) * make/custom/dmv152.cfg (added) * make/custom/efi332.cfg (added) * make/custom/efi68k.cfg (added) * make/custom/erc32.cfg (added) * make/custom/force386.cfg (added) * make/custom/gen68302.cfg (added) * make/custom/gen68360.cfg (added) * make/custom/gen68360_040.cfg (added) * make/custom/gensh1.cfg (added) * make/custom/go32.cfg (added) * make/custom/go32_p5.cfg (added) * make/custom/i386ex.cfg (added) * make/custom/idp.cfg (added) * make/custom/mvme136.cfg (added) * make/custom/mvme147.cfg (added) * make/custom/mvme147s.cfg (added) * make/custom/mvme162.cfg (added) * make/custom/mvme162lx.cfg (added) * make/custom/no_bsp.cfg (added) * make/custom/ods68302.cfg (added) * make/custom/p4000.cfg (added) * make/custom/p4600.cfg (added) * make/custom/p4650.cfg (added) * make/custom/papyrus.cfg (added) * make/custom/pc386.cfg (added) * make/custom/portsw.cfg (added) * make/custom/posix.cfg (added) * make/custom/simhppa.cfg (added) * make/directory.cfg (added) * make/host.cfg.in (added) * make/leaf.cfg (added) * make/lib.cfg (added) * make/main.cfg (added) * make/target.cfg.in (added) Removed PROJECT_HOME and CONFIG_DIR variables.
