# # ChangeLog for make/compilers in rtems # # Generated by Trac 1.2.1.dev0 # 04/25/24 10:35:24 Tue, 12 Nov 2002 09:28:51 GMT Ralf Corsepius [4d19fd5c] * make/ChangeLog (modified) * make/Makefile.am (modified) * make/README (deleted) * make/compilers/Makefile.am (deleted) * make/directory.cfg (deleted) * make/lib.cfg (deleted) 2002-11-12 Ralf Corsepius * ... Fri, 13 Sep 2002 13:39:52 GMT Joel Sherrill [ccf2cfd] * c/src/make/compilers/gcc-target-default.cfg (modified) * make/ChangeLog (modified) * make/compilers/gcc-target-default.cfg (modified) * make/main.cfg (modified) 2002-09-13 Joel Sherrill * Part of ... Thu, 28 Mar 2002 00:54:29 GMT Joel Sherrill [8b14331a] * make/ChangeLog (modified) * make/Makefile.am (modified) * make/Templates/Makefile.am (modified) * make/compilers/Makefile.am (modified) * make/custom/Makefile.am (modified) 2002-03-27 Ralf Corsepius * ... Tue, 22 Jan 2002 17:35:22 GMT Joel Sherrill [6703f877] * c/src/make/compilers/gcc-target-default.cfg (modified) * make/ChangeLog (modified) * make/compilers/gcc-target-default.cfg (modified) 2002-01-21 Ralf Corsepius * ... Sun, 06 Jan 2002 20:09:43 GMT Joel Sherrill [88f60e26] * c/src/make/compilers/gcc-target-default.cfg (modified) * make/ChangeLog (modified) * make/compilers/gcc-no_bsp.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/genmongoosev.cfg (modified) * make/custom/h8sim.cfg (modified) * make/custom/jmr3904.cfg (modified) 2002-02-05 Ralf Corsepius * ... Tue, 08 May 2001 22:59:25 GMT Joel Sherrill [93f79c0f] * c/src/make/compilers/gcc-target-default.cfg (modified) * make/ChangeLog (modified) * make/compilers/gcc-no_bsp.cfg (modified) * make/compilers/gcc-portsw.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/eth_comm.cfg (modified) * make/custom/sim68000.cfg (modified) * make/leaf.cfg (modified) 2001-05-07 Ralf Corsepius * ... Thu, 26 Apr 2001 16:41:44 GMT Joel Sherrill [65e6b542] * c/src/make/compilers/gcc-target-default.cfg (modified) * make/ChangeLog (modified) * make/compilers/gcc-no_bsp.cfg (modified) * make/compilers/gcc-portsw.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/posix.cfg (modified) * make/custom/simhppa.cfg (modified) 2001-04-26 Ralf Corsepius * ... Wed, 18 Oct 2000 13:05:10 GMT Joel Sherrill [3a410c5] * make/ChangeLog (modified) * make/compilers/gcc-portsw.cfg (modified) 2000-10-18 Joel Sherrill * ... Mon, 12 Jun 2000 19:57:02 GMT Joel Sherrill [8ef3818] * aclocal/bsp-alias.m4 (modified) * aclocal/check-bsps.m4 (modified) * c/src/exec/libcsupport/include/sys/termios.h (modified) * c/src/exec/libcsupport/src/malloc.c (modified) * c/src/exec/libcsupport/src/termios.c (modified) * c/src/exec/posix/src/waitpid.c (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/include/rtems/rtems/cache.h (added) * c/src/exec/rtems/src/Makefile.am (modified) * c/src/exec/rtems/src/cache.c (added) * c/src/exec/score/cpu/i386/rtems/score/i386.h (modified) * c/src/exec/score/cpu/m68k/rtems/score/m68k.h (modified) * c/src/exec/score/cpu/powerpc/asm.h (modified) * c/src/exec/score/cpu/powerpc/old_exception_processing/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/old_exception_processing/cpu.c (modified) * c/src/exec/score/cpu/powerpc/old_exception_processing/cpu.h (modified) * c/src/exec/score/cpu/powerpc/rtems/score/ppc.h (modified) * c/src/exec/score/cpu/powerpc/shared/asm.h (modified) * c/src/exec/score/cpu/powerpc/shared/ppc.h (modified) * c/src/exec/score/include/rtems/score/object.h (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/src/Makefile.am (modified) * c/src/exec/score/src/objectlocaliterate.c (added) * c/src/exec/score/src/threadlocaliterate.c (added) * c/src/lib/include/sys/termios.h (modified) * c/src/lib/libbsp/m68k/gen68360/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme167/README (modified) * c/src/lib/libbsp/m68k/mvme167/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme167/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme167/network/network.c (modified) * c/src/lib/libbsp/m68k/mvme167/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme167/startup/page_table.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/canbus.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/console.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/network.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/cpuinit.c (added) * c/src/lib/libbsp/powerpc/eth_comm/startup/linkcmds (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/mmutlbtab.c (added) * c/src/lib/libbsp/powerpc/mbx8xx/Makefile.am (added) * c/src/lib/libbsp/powerpc/mbx8xx/README (added) * c/src/lib/libbsp/powerpc/mbx8xx/bsp_specs (added) * c/src/lib/libbsp/powerpc/mbx8xx/configure.in (added) * c/src/lib/libbsp/powerpc/mbx8xx/console/Makefile.am (added) * c/src/lib/libbsp/powerpc/mbx8xx/console/console.c (added) * c/src/lib/libbsp/powerpc/mbx8xx/include/Makefile.am (added) * c/src/lib/libbsp/powerpc/mbx8xx/include/bsp.h (added) * c/src/lib/libbsp/powerpc/mbx8xx/include/coverhd.h (added) * c/src/lib/libbsp/powerpc/mbx8xx/network/Makefile.am (added) * c/src/lib/libbsp/powerpc/mbx8xx/network/network.c (added) * c/src/lib/libbsp/powerpc/mbx8xx/startup/Makefile.am (added) * c/src/lib/libbsp/powerpc/mbx8xx/startup/bspstart.c (added) * c/src/lib/libbsp/powerpc/mbx8xx/startup/bspstart.c.nocache (added) * c/src/lib/libbsp/powerpc/mbx8xx/startup/imbx8xx.c (added) * c/src/lib/libbsp/powerpc/mbx8xx/startup/linkcmds (added) * c/src/lib/libbsp/powerpc/mbx8xx/startup/mmutlbtab.c (added) * c/src/lib/libbsp/powerpc/mbx8xx/startup/setvec.c (added) * c/src/lib/libbsp/powerpc/mbx8xx/startup/start.S (added) * c/src/lib/libbsp/powerpc/mbx8xx/times-mbx821 (added) * c/src/lib/libbsp/powerpc/mbx8xx/times-mbx860 (added) * c/src/lib/libbsp/powerpc/mbx8xx/wrapup/Makefile.am (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/Makefile.am (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/cpu.c (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/cpu.h (modified) * c/src/lib/libc/malloc.c (modified) * c/src/lib/libc/termios.c (modified) * c/src/lib/libcpu/i386/cpu.h (modified) * c/src/lib/libcpu/i386/page.c (modified) * c/src/lib/libcpu/powerpc/Makefile.am (modified) * c/src/lib/libcpu/powerpc/configure.in (modified) * c/src/lib/libcpu/powerpc/mpc8xx/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc8xx/README (added) * c/src/lib/libcpu/powerpc/mpc8xx/clock/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc8xx/clock/clock.c (added) * c/src/lib/libcpu/powerpc/mpc8xx/console-generic/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc8xx/console-generic/console-generic.c (added) * c/src/lib/libcpu/powerpc/mpc8xx/cpm/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc8xx/cpm/cp.c (added) * c/src/lib/libcpu/powerpc/mpc8xx/cpm/dpram.c (added) * c/src/lib/libcpu/powerpc/mpc8xx/include/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc8xx/include/console.h (added) * c/src/lib/libcpu/powerpc/mpc8xx/include/cpm.h (added) * c/src/lib/libcpu/powerpc/mpc8xx/include/mmu.h (added) * c/src/lib/libcpu/powerpc/mpc8xx/include/mpc8xx.h (added) * c/src/lib/libcpu/powerpc/mpc8xx/mmu/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc8xx/mmu/mmu.c (added) * c/src/lib/libcpu/powerpc/mpc8xx/timer/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc8xx/timer/timer.c (added) * c/src/lib/libcpu/powerpc/mpc8xx/vectors/Makefile.am (added) * c/src/lib/libcpu/powerpc/mpc8xx/vectors/README (added) * c/src/lib/libcpu/powerpc/mpc8xx/vectors/align_h.S (added) * c/src/lib/libcpu/powerpc/mpc8xx/vectors/vectors.S (added) * c/src/lib/libcpu/powerpc/old-exceptions/cpu.c (modified) * c/src/lib/libcpu/powerpc/old_exception_processing/Makefile.am (modified) * c/src/lib/libcpu/powerpc/old_exception_processing/cpu.c (modified) * c/src/lib/libcpu/powerpc/old_exception_processing/cpu.h (modified) * c/src/lib/libcpu/powerpc/shared/cpu.h (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/tests/configure.in (modified) * c/src/tests/libtests/termios/init.c (modified) * c/src/tests/samples/cdtest/system.h (modified) * c/src/tests/sptests/Makefile.am (modified) * c/src/tests/sptests/configure.in (modified) * cpukit/libcsupport/include/sys/termios.h (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/posix/src/waitpid.c (modified) * cpukit/rtems/include/rtems/rtems/cache.h (added) * cpukit/rtems/src/Makefile.am (modified) * cpukit/score/cpu/i386/rtems/score/i386.h (modified) * cpukit/score/cpu/m68k/rtems/score/m68k.h (modified) * cpukit/score/cpu/powerpc/asm.h (modified) * cpukit/score/cpu/powerpc/rtems/asm.h (modified) * cpukit/score/cpu/powerpc/rtems/score/ppc.h (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/Makefile.am (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/eth_comm.cfg (modified) * make/custom/mvme167.cfg (modified) * make/leaf.cfg (modified) * testsuites/libtests/termios/init.c (modified) * testsuites/samples/cdtest/system.h (modified) * testsuites/sptests/Makefile.am (modified) Patch from John Cotton , Charles-Antoine Gauthier ... Mon, 12 Jun 2000 15:00:15 GMT Joel Sherrill [df49c60] * Makefile.am (modified) * VERSION (modified) * aclocal/canonical-host.m4 (modified) * aclocal/canonical-target-name.m4 (modified) * aclocal/check-multiprocessing.m4 (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-posix.m4 (modified) * aclocal/prog-cxx.m4 (modified) * aclocal/target.m4 (modified) * automake/host.am (added) * automake/local.am (modified) * automake/subdirs.am (modified) * bootstrap (modified) * c/Makefile.am (modified) * c/make/Makefile.am (modified) * c/src/Makefile.am (modified) * c/src/exec/itron/include/Makefile.am (modified) * c/src/exec/itron/include/itronsys/Makefile.am (modified) * c/src/exec/itron/include/rtems/itron/Makefile.am (modified) * c/src/exec/itron/inline/rtems/itron/Makefile.am (modified) * c/src/exec/itron/src/Makefile.am (modified) * c/src/exec/itron/src/cre_tsk.c (modified) * c/src/exec/itron/src/eventflags.c (modified) * c/src/exec/itron/src/fmempool.c (modified) * c/src/exec/itron/src/itronsem.c (modified) * c/src/exec/itron/src/mbox.c (modified) * c/src/exec/itron/src/msgbuffer.c (modified) * c/src/exec/itron/src/port.c (modified) * c/src/exec/itron/src/vmempool.c (modified) * c/src/exec/libcsupport/Makefile.am (modified) * c/src/exec/libcsupport/include/console.h (modified) * c/src/exec/libcsupport/include/rtems/error.h (modified) * c/src/exec/libcsupport/include/sys/termios.h (modified) * c/src/exec/libcsupport/src/Makefile.am (modified) * c/src/exec/libcsupport/src/gxx_wrappers.c (modified) * c/src/exec/libcsupport/src/libio.c (modified) * c/src/exec/libcsupport/src/malloc.c (modified) * c/src/exec/libcsupport/src/scandir.c (modified) * c/src/exec/libcsupport/src/termios.c (modified) * c/src/exec/libcsupport/src/termiosreserveresources.c (modified) * c/src/exec/libcsupport/src/unmount.c (modified) * c/src/exec/libfs/src/imfs/imfs.h (modified) * c/src/exec/libfs/src/imfs/imfs_creat.c (modified) * c/src/exec/libfs/src/imfs/imfs_directory.c (modified) * c/src/exec/libfs/src/imfs/imfs_stat.c (modified) * c/src/exec/libfs/src/imfs/imfs_utime.c (modified) * c/src/exec/libnetworking/Makefile.am (modified) * c/src/exec/libnetworking/arpa/Makefile.am (modified) * c/src/exec/libnetworking/kern/Makefile.am (modified) * c/src/exec/libnetworking/lib/Makefile.am (modified) * c/src/exec/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * c/src/exec/libnetworking/libc/Makefile.am (modified) * c/src/exec/libnetworking/machine/Makefile.am (modified) * c/src/exec/libnetworking/memory.h (modified) * c/src/exec/libnetworking/net/Makefile.am (modified) * c/src/exec/libnetworking/net/if_loop.c (modified) * c/src/exec/libnetworking/netinet/Makefile.am (modified) * c/src/exec/libnetworking/netinet/in.h (modified) * c/src/exec/libnetworking/nfs/Makefile.am (modified) * c/src/exec/libnetworking/rtems/Makefile.am (modified) * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/exec/libnetworking/sys/Makefile.am (modified) * c/src/exec/libnetworking/sys/un.h (modified) * c/src/exec/libnetworking/vm/Makefile.am (modified) * c/src/exec/libnetworking/wrapup/Makefile.am (modified) * c/src/exec/librpc/Makefile.am (modified) * c/src/exec/librpc/README_RTEMS (modified) * c/src/exec/librpc/include/Makefile.am (modified) * c/src/exec/librpc/include/rpc/Makefile.am (modified) * c/src/exec/librpc/include/rpc/auth.h (modified) * c/src/exec/librpc/include/rpc/auth_des.h (modified) * c/src/exec/librpc/include/rpc/auth_unix.h (modified) * c/src/exec/librpc/include/rpc/clnt.h (modified) * c/src/exec/librpc/include/rpc/des.h (modified) * c/src/exec/librpc/include/rpc/des_crypt.h (modified) * c/src/exec/librpc/include/rpc/pmap_clnt.h (modified) * c/src/exec/librpc/include/rpc/pmap_prot.h (modified) * c/src/exec/librpc/include/rpc/pmap_rmt.h (modified) * c/src/exec/librpc/include/rpc/rpc.h (modified) * c/src/exec/librpc/include/rpc/rpc_com.h (modified) * c/src/exec/librpc/include/rpc/rpc_msg.h (modified) * c/src/exec/librpc/include/rpc/svc.h (modified) * c/src/exec/librpc/include/rpc/svc_auth.h (modified) * c/src/exec/librpc/include/rpc/types.h (modified) * c/src/exec/librpc/include/rpc/xdr.h (modified) * c/src/exec/librpc/include/rpcsvc/.cvsignore (modified) * c/src/exec/librpc/include/rpcsvc/Makefile.am (modified) * c/src/exec/librpc/include/rpcsvc/bootparam_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/crypt.x (modified) * c/src/exec/librpc/include/rpcsvc/key_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/klm_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/mount.x (modified) * c/src/exec/librpc/include/rpcsvc/nfs_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/nis.x (modified) * c/src/exec/librpc/include/rpcsvc/nis_cache.x (modified) * c/src/exec/librpc/include/rpcsvc/nis_callback.x (modified) * c/src/exec/librpc/include/rpcsvc/nis_db.h (modified) * c/src/exec/librpc/include/rpcsvc/nis_object.x (modified) * c/src/exec/librpc/include/rpcsvc/nis_tags.h (modified) * c/src/exec/librpc/include/rpcsvc/nislib.h (modified) * c/src/exec/librpc/include/rpcsvc/nlm_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/pmap_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/rex.x (modified) * c/src/exec/librpc/include/rpcsvc/rnusers.x (modified) * c/src/exec/librpc/include/rpcsvc/rquota.x (modified) * c/src/exec/librpc/include/rpcsvc/rstat.x (modified) * c/src/exec/librpc/include/rpcsvc/rwall.x (modified) * c/src/exec/librpc/include/rpcsvc/sm_inter.x (modified) * c/src/exec/librpc/include/rpcsvc/spray.x (modified) * c/src/exec/librpc/include/rpcsvc/yp.x (modified) * c/src/exec/librpc/include/rpcsvc/yp_prot.h (modified) * c/src/exec/librpc/include/rpcsvc/ypclnt.h (modified) * c/src/exec/librpc/include/rpcsvc/yppasswd.x (modified) * c/src/exec/librpc/include/rpcsvc/ypupdate_prot.x (modified) * c/src/exec/librpc/include/rpcsvc/ypxfrd.x (modified) * c/src/exec/librpc/src/Makefile.am (modified) * c/src/exec/librpc/src/rpc/DISCLAIMER (modified) * c/src/exec/librpc/src/rpc/Makefile.am (modified) * c/src/exec/librpc/src/rpc/PSD.doc/.cvsignore (modified) * c/src/exec/librpc/src/rpc/PSD.doc/Makefile.am (modified) * c/src/exec/librpc/src/rpc/PSD.doc/nfs.rfc.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/rpc.prog.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/rpc.rfc.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/rpcgen.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/xdr.nts.ms (modified) * c/src/exec/librpc/src/rpc/PSD.doc/xdr.rfc.ms (modified) * c/src/exec/librpc/src/rpc/README (modified) * c/src/exec/librpc/src/rpc/auth_des.c (modified) * c/src/exec/librpc/src/rpc/auth_none.c (modified) * c/src/exec/librpc/src/rpc/auth_time.c (modified) * c/src/exec/librpc/src/rpc/auth_unix.c (modified) * c/src/exec/librpc/src/rpc/authdes_prot.c (modified) * c/src/exec/librpc/src/rpc/authunix_prot.c (modified) * c/src/exec/librpc/src/rpc/bindresvport.3 (modified) * c/src/exec/librpc/src/rpc/bindresvport.c (modified) * c/src/exec/librpc/src/rpc/clnt_generic.c (modified) * c/src/exec/librpc/src/rpc/clnt_perror.c (modified) * c/src/exec/librpc/src/rpc/clnt_raw.c (modified) * c/src/exec/librpc/src/rpc/clnt_simple.c (modified) * c/src/exec/librpc/src/rpc/clnt_tcp.c (modified) * c/src/exec/librpc/src/rpc/clnt_udp.c (modified) * c/src/exec/librpc/src/rpc/clnt_unix.c (modified) * c/src/exec/librpc/src/rpc/crypt_client.c (modified) * c/src/exec/librpc/src/rpc/des_crypt.3 (modified) * c/src/exec/librpc/src/rpc/des_crypt.c (modified) * c/src/exec/librpc/src/rpc/des_soft.c (modified) * c/src/exec/librpc/src/rpc/get_myaddress.c (modified) * c/src/exec/librpc/src/rpc/getpublickey.c (modified) * c/src/exec/librpc/src/rpc/getrpcent.3 (modified) * c/src/exec/librpc/src/rpc/getrpcent.c (modified) * c/src/exec/librpc/src/rpc/getrpcport.3 (modified) * c/src/exec/librpc/src/rpc/getrpcport.c (modified) * c/src/exec/librpc/src/rpc/key_call.c (modified) * c/src/exec/librpc/src/rpc/key_prot_xdr.c (modified) * c/src/exec/librpc/src/rpc/netname.c (modified) * c/src/exec/librpc/src/rpc/netnamer.c (modified) * c/src/exec/librpc/src/rpc/pmap_clnt.c (modified) * c/src/exec/librpc/src/rpc/pmap_getmaps.c (modified) * c/src/exec/librpc/src/rpc/pmap_getport.c (modified) * c/src/exec/librpc/src/rpc/pmap_prot.c (modified) * c/src/exec/librpc/src/rpc/pmap_prot2.c (modified) * c/src/exec/librpc/src/rpc/pmap_rmt.c (modified) * c/src/exec/librpc/src/rpc/publickey.3 (modified) * c/src/exec/librpc/src/rpc/publickey.5 (modified) * c/src/exec/librpc/src/rpc/rpc.3 (modified) * c/src/exec/librpc/src/rpc/rpc.5 (modified) * c/src/exec/librpc/src/rpc/rpc_callmsg.c (modified) * c/src/exec/librpc/src/rpc/rpc_commondata.c (modified) * c/src/exec/librpc/src/rpc/rpc_dtablesize.c (modified) * c/src/exec/librpc/src/rpc/rpc_prot.c (modified) * c/src/exec/librpc/src/rpc/rpc_secure.3 (modified) * c/src/exec/librpc/src/rpc/rpcdname.c (modified) * c/src/exec/librpc/src/rpc/rstat.1 (modified) * c/src/exec/librpc/src/rpc/rstat_svc.8 (modified) * c/src/exec/librpc/src/rpc/rtems_portmapper.c (modified) * c/src/exec/librpc/src/rpc/rtems_rpc.c (modified) * c/src/exec/librpc/src/rpc/rtime.3 (modified) * c/src/exec/librpc/src/rpc/rtime.c (modified) * c/src/exec/librpc/src/rpc/svc.c (modified) * c/src/exec/librpc/src/rpc/svc_auth.c (modified) * c/src/exec/librpc/src/rpc/svc_auth_des.c (modified) * c/src/exec/librpc/src/rpc/svc_auth_unix.c (modified) * c/src/exec/librpc/src/rpc/svc_raw.c (modified) * c/src/exec/librpc/src/rpc/svc_run.c (modified) * c/src/exec/librpc/src/rpc/svc_simple.c (modified) * c/src/exec/librpc/src/rpc/svc_tcp.c (modified) * c/src/exec/librpc/src/rpc/svc_udp.c (modified) * c/src/exec/librpc/src/rpc/svc_unix.c (modified) * c/src/exec/librpc/src/xdr/Makefile.am (modified) * c/src/exec/librpc/src/xdr/xdr.3 (modified) * c/src/exec/librpc/src/xdr/xdr.c (modified) * c/src/exec/librpc/src/xdr/xdr_array.c (modified) * c/src/exec/librpc/src/xdr/xdr_float.c (modified) * c/src/exec/librpc/src/xdr/xdr_mem.c (modified) * c/src/exec/librpc/src/xdr/xdr_rec.c (modified) * c/src/exec/librpc/src/xdr/xdr_reference.c (modified) * c/src/exec/librpc/src/xdr/xdr_sizeof.c (modified) * c/src/exec/librpc/src/xdr/xdr_stdio.c (modified) * c/src/exec/posix/include/Makefile.am (modified) * c/src/exec/posix/include/pthread.h (deleted) * c/src/exec/posix/include/rtems/posix/Makefile.am (modified) * c/src/exec/posix/include/sys/Makefile.am (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.am (modified) * c/src/exec/posix/inline/rtems/posix/cond.inl (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.am (modified) * c/src/exec/posix/optman/Makefile.am (modified) * c/src/exec/posix/src/Makefile.am (modified) * c/src/exec/posix/src/mqueuecreatesupp.c (modified) * c/src/exec/posix/src/mqueuedeletesupp.c (modified) * c/src/exec/posix/src/mqueueunlink.c (modified) * c/src/exec/posix/src/pthread.c (modified) * c/src/exec/posix/src/pthreadcreate.c (modified) * c/src/exec/posix/src/sigtimedwait.c (modified) * c/src/exec/posix/src/waitpid.c (modified) * c/src/exec/rtems/include/Makefile.am (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/include/rtems/rtems/rtemsapi.h (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/optman/Makefile.am (modified) * c/src/exec/rtems/optman/no-mp.c (modified) * c/src/exec/rtems/src/Makefile.am (modified) * c/src/exec/rtems/src/semdelete.c (modified) * c/src/exec/rtems/src/tasks.c (modified) * c/src/exec/rtems/src/taskvariableadd.c (modified) * c/src/exec/rtems/src/taskvariabledelete.c (modified) * c/src/exec/rtems/src/taskvariableget.c (modified) * c/src/exec/sapi/include/Makefile.am (modified) * c/src/exec/sapi/include/confdefs.h (modified) * c/src/exec/sapi/include/rtems/Makefile.am (modified) * c/src/exec/sapi/include/rtems/README (modified) * c/src/exec/sapi/inline/rtems/Makefile.am (modified) * c/src/exec/sapi/macros/rtems/Makefile.am (modified) * c/src/exec/sapi/optman/Makefile.am (modified) * c/src/exec/sapi/src/Makefile.am (modified) * c/src/exec/score/cpu/a29k/Makefile.am (modified) * c/src/exec/score/cpu/a29k/rtems/Makefile.am (modified) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/a29k/rtems/score/a29k.h (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/hppa.h (modified) * c/src/exec/score/cpu/i386/Makefile.am (modified) * c/src/exec/score/cpu/i386/rtems/Makefile.am (modified) * c/src/exec/score/cpu/i386/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/i386/rtems/score/i386.h (modified) * c/src/exec/score/cpu/i960/Makefile.am (modified) * c/src/exec/score/cpu/i960/rtems/Makefile.am (modified) * c/src/exec/score/cpu/i960/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/i960/rtems/score/i960.h (modified) * c/src/exec/score/cpu/m68k/Makefile.am (modified) * c/src/exec/score/cpu/m68k/qsm.h (modified) * c/src/exec/score/cpu/m68k/rtems/Makefile.am (modified) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/m68k/rtems/score/m68k.h (modified) * c/src/exec/score/cpu/m68k/sim.h (modified) * c/src/exec/score/cpu/mips/Makefile.am (modified) * c/src/exec/score/cpu/mips/rtems/Makefile.am (modified) * c/src/exec/score/cpu/mips/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/mips/rtems/score/mips.h (modified) * c/src/exec/score/cpu/mips/rtems/score/mips64orion.h (modified) * c/src/exec/score/cpu/mips64orion/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/mips64orion.h (modified) * c/src/exec/score/cpu/no_cpu/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/cpu.c (modified) * c/src/exec/score/cpu/no_cpu/cpu_asm.c (modified) * c/src/exec/score/cpu/no_cpu/rtems.c (modified) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/no_cpu.h (modified) * c/src/exec/score/cpu/powerpc/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/new_exception_processing/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/old_exception_processing/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/old_exception_processing/irq_stub.S (modified) * c/src/exec/score/cpu/powerpc/rtems/score/ppc.h (modified) * c/src/exec/score/cpu/powerpc/shared/Makefile.am (modified) * c/src/exec/score/cpu/powerpc/shared/ppc.h (modified) * c/src/exec/score/cpu/sh/Makefile.am (modified) * c/src/exec/score/cpu/sh/rtems/Makefile.am (modified) * c/src/exec/score/cpu/sh/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/sh/rtems/score/sh.h (modified) * c/src/exec/score/cpu/sparc/Makefile.am (modified) * c/src/exec/score/cpu/sparc/rtems/Makefile.am (modified) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/sparc/rtems/score/sparc.h (modified) * c/src/exec/score/cpu/unix/Makefile.am (modified) * c/src/exec/score/cpu/unix/cpu.c (modified) * c/src/exec/score/cpu/unix/rtems/Makefile.am (modified) * c/src/exec/score/cpu/unix/rtems/score/Makefile.am (modified) * c/src/exec/score/cpu/unix/rtems/score/cpu.h (modified) * c/src/exec/score/cpu/unix/rtems/score/unix.h (modified) * c/src/exec/score/include/rtems/Makefile.am (modified) * c/src/exec/score/include/rtems/score/Makefile.am (modified) * c/src/exec/score/include/rtems/score/thread.h (modified) * c/src/exec/score/include/rtems/system.h (modified) * c/src/exec/score/inline/rtems/score/Makefile.am (modified) * c/src/exec/score/macros/rtems/score/Makefile.am (modified) * c/src/exec/score/macros/rtems/score/address.inl (modified) * c/src/exec/score/src/Makefile.am (modified) * c/src/exec/score/src/objectcopynamestring.c (modified) * c/src/exec/wrapup/itron/Makefile.am (modified) * c/src/exec/wrapup/posix/Makefile.am (modified) * c/src/exec/wrapup/rtems/Makefile.am (modified) * c/src/lib/Makefile.am (modified) * c/src/lib/configure.in (modified) * c/src/lib/include/Makefile.am (modified) * c/src/lib/include/console.h (modified) * c/src/lib/include/motorola/Makefile.am (modified) * c/src/lib/include/rtems/error.h (modified) * c/src/lib/include/sys/Makefile.am (modified) * c/src/lib/include/sys/termios.h (modified) * c/src/lib/include/zilog/Makefile.am (modified) * c/src/lib/libbsp/Makefile.am (modified) * c/src/lib/libbsp/a29k/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/include/bsp.h (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.am (modified) * c/src/lib/libbsp/a29k/portsw/startup/bspstart.c (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.am (modified) * c/src/lib/libbsp/bare/Makefile.am (modified) * c/src/lib/libbsp/bare/bsp_specs (modified) * c/src/lib/libbsp/bare/include/Makefile.am (modified) * c/src/lib/libbsp/bare/include/bsp.h (modified) * c/src/lib/libbsp/hppa1.1/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/bsp.h (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/console/console.c (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/include/bsp.h (modified) * c/src/lib/libbsp/i386/i386ex/network/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/start/start.S (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/3c509/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/HOWTO (modified) * c/src/lib/libbsp/i386/pc386/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/console/console.c (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/include/bsp.h (modified) * c/src/lib/libbsp/i386/pc386/ne2000/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/start/start16.S (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/wd8003/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/comm/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/io/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/irq/Makefile.am (modified) * c/src/lib/libbsp/i386/shared/pci/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/clock/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/console/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/console/console.c (modified) * c/src/lib/libbsp/i386/ts_386ex/include/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/include/bsp.h (modified) * c/src/lib/libbsp/i386/ts_386ex/network/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/start/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/start/start.S (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/ts_386ex/timer/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_ada/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_ada/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_c/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/debug_c/system.h (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/adasockets/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/listener/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/listener/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/tcprelay/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/network_ada/tcprelay/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/init.c (modified) * c/src/lib/libbsp/i386/ts_386ex/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i960/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/include/bsp.h (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.am (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/bsp_specs (modified) * c/src/lib/libbsp/i960/rxgen960/clock/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/console/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/include/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/include/bsp.h (modified) * c/src/lib/libbsp/i960/rxgen960/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/rxgen960/timer/Makefile.am (modified) * c/src/lib/libbsp/i960/rxgen960/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/console/console.c (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/include/bsp.h (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/README (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/include/bsp.h (modified) * c/src/lib/libbsp/m68k/efi332/misc/dotests (modified) * c/src/lib/libbsp/m68k/efi332/misc/gdbinit68 (modified) * c/src/lib/libbsp/m68k/efi332/misc/interr.c (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/start/start.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/except_vect_332_ROM.S (modified) * c/src/lib/libbsp/m68k/efi332/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/efi332/startup/linkcmds_ROM (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/include/bsp.h (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/console/console.c (modified) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68340/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/console/consolereserveresources.c (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/network/network.c (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/start/start.S (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/init68360.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.bootp (modified) * c/src/lib/libbsp/m68k/gen68360/startup/linkcmds.prom (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/include/bsp.h (modified) * c/src/lib/libbsp/m68k/idp/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme162/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/README (modified) * c/src/lib/libbsp/m68k/mvme167/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/configure.in (modified) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/console/console-recording.c (modified) * c/src/lib/libbsp/m68k/mvme167/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/include/bsp.h (modified) * c/src/lib/libbsp/m68k/mvme167/network/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/network/network.c (modified) * c/src/lib/libbsp/m68k/mvme167/network/uti596.h (modified) * c/src/lib/libbsp/m68k/mvme167/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme167/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/mvme167/startup/page_table.c (modified) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/include/bsp.h (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/linkcmds (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.am (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.am (modified) * c/src/lib/libbsp/m68k/shared/m68kpretaskinghook.c (modified) * c/src/lib/libbsp/m68k/shared/start.S (modified) * c/src/lib/libbsp/mips/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/console/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/include/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/include/bsp.h (modified) * c/src/lib/libbsp/mips/p4000/liblnk/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/start/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/startup/Makefile.am (modified) * c/src/lib/libbsp/mips/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/p4000/wrapup/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/include/bsp.h (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.am (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.am (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/bsp_specs (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/bsp_specs (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/start.S (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/helas403/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bsp_specs (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/motorola/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/bsp_specs (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/console.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/bsp_specs (modified) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/console/console.c (modified) * c/src/lib/libbsp/powerpc/psim/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/tools/runtest (modified) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/bsp_specs (modified) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/console/consolereserveresources.c (modified) * c/src/lib/libbsp/powerpc/score603e/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/bootloader/misc.c (modified) * c/src/lib/libbsp/powerpc/shared/clock/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/console/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/console/console.c (modified) * c/src/lib/libbsp/powerpc/shared/include/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/include/bsp.h (modified) * c/src/lib/libbsp/powerpc/shared/irq/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/irq/irq_asm.S (modified) * c/src/lib/libbsp/powerpc/shared/motorola/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/openpic/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/pci/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/residual/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/start/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/start/start.S (modified) * c/src/lib/libbsp/powerpc/shared/startup/Makefile.am (modified) * c/src/lib/libbsp/powerpc/shared/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/shared/vectors/Makefile.am (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/Makefile.am (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/Makefile.am (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/irq_stub.S (modified) * c/src/lib/libbsp/sh/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/bsp_specs (modified) * c/src/lib/libbsp/sh/gensh1/console/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/include/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh1/startup/bspstart.c (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/README (modified) * c/src/lib/libbsp/sh/gensh2/bsp_specs (modified) * c/src/lib/libbsp/sh/gensh2/console/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/include/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/include/bsp.h (modified) * c/src/lib/libbsp/sh/gensh2/scitab/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/start/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/start/start.S (modified) * c/src/lib/libbsp/sh/gensh2/startup/Makefile.am (modified) * c/src/lib/libbsp/sh/gensh2/startup/bspstart.c (modified) * c/src/lib/libbsp/sh/gensh2/startup/hw_init.c (modified) * c/src/lib/libbsp/sh/gensh2/wrapup/Makefile.am (modified) * c/src/lib/libbsp/sh/shared/Makefile.am (modified) * c/src/lib/libbsp/shared/console.c (modified) * c/src/lib/libbsp/shmdr/Makefile.am (modified) * c/src/lib/libbsp/sparc/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/console/consolereserveresources.c (modified) * c/src/lib/libbsp/sparc/erc32/gnatsupp/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/include/bsp.h (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/linkcmds (modified) * c/src/lib/libbsp/sparc/erc32/startup/spurious.c (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/tools/runtest.in (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.am (modified) * c/src/lib/libbsp/unix/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/configure.in (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/include/bsp.h (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/startup/bspstart.c (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.am (modified) * c/src/lib/libc/Makefile.am (modified) * c/src/lib/libc/error.h (modified) * c/src/lib/libc/gxx_wrappers.c (modified) * c/src/lib/libc/imfs.h (modified) * c/src/lib/libc/imfs_creat.c (modified) * c/src/lib/libc/imfs_directory.c (modified) * c/src/lib/libc/imfs_stat.c (modified) * c/src/lib/libc/imfs_utime.c (modified) * c/src/lib/libc/libio.c (modified) * c/src/lib/libc/malloc.c (modified) * c/src/lib/libc/scandir.c (modified) * c/src/lib/libc/termios.c (modified) * c/src/lib/libc/termiosreserveresources.c (modified) * c/src/lib/libc/unmount.c (modified) * c/src/lib/libcpu/Makefile.am (modified) * c/src/lib/libcpu/a29k/Makefile.am (modified) * c/src/lib/libcpu/a29k/clock/Makefile.am (modified) * c/src/lib/libcpu/a29k/timer/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.am (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.am (modified) * c/src/lib/libcpu/i386/Makefile.am (modified) * c/src/lib/libcpu/m68k/Makefile.am (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.am (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.am (modified) * c/src/lib/libcpu/mips/Makefile.am (modified) * c/src/lib/libcpu/mips/clock/Makefile.am (modified) * c/src/lib/libcpu/mips/timer/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.am (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc505/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc6xx/wrapup/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc821/include/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc821/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/console-generic.c (modified) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/include/mpc860.h (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/mpc860/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/new_exception_processing/Makefile.am (modified) * c/src/lib/libcpu/powerpc/old-exceptions/irq_stub.S (modified) * c/src/lib/libcpu/powerpc/old_exception_processing/Makefile.am (modified) * c/src/lib/libcpu/powerpc/old_exception_processing/irq_stub.S (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/console/console.c (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.am (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.am (modified) * c/src/lib/libcpu/powerpc/shared/Makefile.am (modified) * c/src/lib/libcpu/powerpc/wrapup/Makefile.am (modified) * c/src/lib/libcpu/sh/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/delay/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/sci/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/clock/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/include/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/null/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/sci/Makefile.am (modified) * c/src/lib/libcpu/sh/sh7045/sci/sci.c (modified) * c/src/lib/libcpu/sh/sh7045/timer/Makefile.am (modified) * c/src/lib/libcpu/sparc/Makefile.am (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.am (modified) * c/src/lib/libcpu/sparc/syscall/Makefile.am (modified) * c/src/libchip/network/Makefile.am (modified) * c/src/libchip/network/README.dec21140 (modified) * c/src/libchip/network/dec21140.c (modified) * c/src/libchip/rtc/Makefile.am (modified) * c/src/libchip/serial/Makefile.am (modified) * c/src/libchip/serial/README.ns16550 (modified) * c/src/libchip/serial/STATUS (modified) * c/src/libchip/serial/ns16550.c (modified) * c/src/libchip/serial/ns16550_p.h (modified) * c/src/libfs/src/imfs/imfs.h (modified) * c/src/libfs/src/imfs/imfs_creat.c (modified) * c/src/libfs/src/imfs/imfs_directory.c (modified) * c/src/libfs/src/imfs/imfs_stat.c (modified) * c/src/libfs/src/imfs/imfs_utime.c (modified) * c/src/libmisc/cpuuse/Makefile.am (modified) * c/src/libmisc/dummy/Makefile.am (modified) * c/src/libmisc/dummy/dummy.c (modified) * c/src/libmisc/dumpbuf/Makefile.am (modified) * c/src/libmisc/monitor/Makefile.am (modified) * c/src/libmisc/monitor/mon-server.c (modified) * c/src/libmisc/rtmonuse/Makefile.am (modified) * c/src/libmisc/stackchk/Makefile.am (modified) * c/src/libmisc/stackchk/internal.h (modified) * c/src/libmisc/untar/Makefile.am (modified) * c/src/libmisc/wrapup/Makefile.am (modified) * c/src/libnetworking/Makefile.am (modified) * c/src/libnetworking/arpa/Makefile.am (modified) * c/src/libnetworking/include/Makefile.am (modified) * c/src/libnetworking/kern/Makefile.am (modified) * c/src/libnetworking/lib/Makefile.am (modified) * c/src/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * c/src/libnetworking/libc/Makefile.am (modified) * c/src/libnetworking/machine/Makefile.am (modified) * c/src/libnetworking/memory.h (modified) * c/src/libnetworking/net/Makefile.am (modified) * c/src/libnetworking/net/if_loop.c (modified) * c/src/libnetworking/netinet/Makefile.am (modified) * c/src/libnetworking/netinet/in.h (modified) * c/src/libnetworking/nfs/Makefile.am (modified) * c/src/libnetworking/pppd/Makefile.am (modified) * c/src/libnetworking/pppd/options.c (modified) * c/src/libnetworking/pppd/pppd.h (modified) * c/src/libnetworking/pppd/rtems-ppp.c (modified) * c/src/libnetworking/rtems/Makefile.am (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * c/src/libnetworking/rtems_servers/Makefile.am (modified) * c/src/libnetworking/rtems_servers/ftpd.c (modified) * c/src/libnetworking/rtems_webserver/Makefile.am (modified) * c/src/libnetworking/rtems_webserver/balloc.c (modified) * c/src/libnetworking/rtems_webserver/ejlex.c (modified) * c/src/libnetworking/rtems_webserver/handler.c (modified) * c/src/libnetworking/rtems_webserver/uemf.c (modified) * c/src/libnetworking/rtems_webserver/uemf.h (modified) * c/src/libnetworking/rtems_webserver/webs.c (modified) * c/src/libnetworking/sys/Makefile.am (modified) * c/src/libnetworking/sys/un.h (modified) * c/src/libnetworking/vm/Makefile.am (modified) * c/src/libnetworking/wrapup/Makefile.am (modified) * c/src/librdbg/include/rdbg/Makefile.am (modified) * c/src/librdbg/include/rdbg/i386/Makefile.am (modified) * c/src/librdbg/include/rdbg/powerpc/Makefile.am (modified) * c/src/librdbg/src/Makefile.am (modified) * c/src/librdbg/src/i386/Makefile.am (modified) * c/src/librdbg/src/i386/any/Makefile.am (modified) * c/src/librdbg/src/powerpc/Makefile.am (modified) * c/src/librdbg/src/powerpc/mcp750/Makefile.am (modified) * c/src/librdbg/src/powerpc/new_exception_processing/Makefile.am (modified) * c/src/librpc/Makefile.am (modified) * c/src/librpc/README_RTEMS (modified) * c/src/librpc/configure.in (modified) * c/src/librpc/include/Makefile.am (modified) * c/src/librpc/include/rpc/Makefile.am (modified) * c/src/librpc/include/rpc/auth.h (modified) * c/src/librpc/include/rpc/auth_des.h (modified) * c/src/librpc/include/rpc/auth_unix.h (modified) * c/src/librpc/include/rpc/clnt.h (modified) * c/src/librpc/include/rpc/des.h (modified) * c/src/librpc/include/rpc/des_crypt.h (modified) * c/src/librpc/include/rpc/pmap_clnt.h (modified) * c/src/librpc/include/rpc/pmap_prot.h (modified) * c/src/librpc/include/rpc/pmap_rmt.h (modified) * c/src/librpc/include/rpc/rpc.h (modified) * c/src/librpc/include/rpc/rpc_com.h (modified) * c/src/librpc/include/rpc/rpc_msg.h (modified) * c/src/librpc/include/rpc/svc.h (modified) * c/src/librpc/include/rpc/svc_auth.h (modified) * c/src/librpc/include/rpc/types.h (modified) * c/src/librpc/include/rpc/xdr.h (modified) * c/src/librpc/include/rpcsvc/.cvsignore (modified) * c/src/librpc/include/rpcsvc/Makefile.am (modified) * c/src/librpc/include/rpcsvc/bootparam_prot.x (modified) * c/src/librpc/include/rpcsvc/crypt.x (modified) * c/src/librpc/include/rpcsvc/key_prot.x (modified) * c/src/librpc/include/rpcsvc/klm_prot.x (modified) * c/src/librpc/include/rpcsvc/mount.x (modified) * c/src/librpc/include/rpcsvc/nfs_prot.x (modified) * c/src/librpc/include/rpcsvc/nis.x (modified) * c/src/librpc/include/rpcsvc/nis_cache.x (modified) * c/src/librpc/include/rpcsvc/nis_callback.x (modified) * c/src/librpc/include/rpcsvc/nis_db.h (modified) * c/src/librpc/include/rpcsvc/nis_object.x (modified) * c/src/librpc/include/rpcsvc/nis_tags.h (modified) * c/src/librpc/include/rpcsvc/nislib.h (modified) * c/src/librpc/include/rpcsvc/nlm_prot.x (modified) * c/src/librpc/include/rpcsvc/pmap_prot.x (modified) * c/src/librpc/include/rpcsvc/rex.x (modified) * c/src/librpc/include/rpcsvc/rnusers.x (modified) * c/src/librpc/include/rpcsvc/rquota.x (modified) * c/src/librpc/include/rpcsvc/rstat.x (modified) * c/src/librpc/include/rpcsvc/rwall.x (modified) * c/src/librpc/include/rpcsvc/sm_inter.x (modified) * c/src/librpc/include/rpcsvc/spray.x (modified) * c/src/librpc/include/rpcsvc/yp.x (modified) * c/src/librpc/include/rpcsvc/yp_prot.h (modified) * c/src/librpc/include/rpcsvc/ypclnt.h (modified) * c/src/librpc/include/rpcsvc/yppasswd.x (modified) * c/src/librpc/include/rpcsvc/ypupdate_prot.x (modified) * c/src/librpc/include/rpcsvc/ypxfrd.x (modified) * c/src/librpc/src/Makefile.am (modified) * c/src/librpc/src/rpc/DISCLAIMER (modified) * c/src/librpc/src/rpc/Makefile.am (modified) * c/src/librpc/src/rpc/PSD.doc/.cvsignore (modified) * c/src/librpc/src/rpc/PSD.doc/Makefile.am (modified) * c/src/librpc/src/rpc/PSD.doc/nfs.rfc.ms (modified) * c/src/librpc/src/rpc/PSD.doc/rpc.prog.ms (modified) * c/src/librpc/src/rpc/PSD.doc/rpc.rfc.ms (modified) * c/src/librpc/src/rpc/PSD.doc/rpcgen.ms (modified) * c/src/librpc/src/rpc/PSD.doc/xdr.nts.ms (modified) * c/src/librpc/src/rpc/PSD.doc/xdr.rfc.ms (modified) * c/src/librpc/src/rpc/README (modified) * c/src/librpc/src/rpc/auth_des.c (modified) * c/src/librpc/src/rpc/auth_none.c (modified) * c/src/librpc/src/rpc/auth_time.c (modified) * c/src/librpc/src/rpc/auth_unix.c (modified) * c/src/librpc/src/rpc/authdes_prot.c (modified) * c/src/librpc/src/rpc/authunix_prot.c (modified) * c/src/librpc/src/rpc/bindresvport.3 (modified) * c/src/librpc/src/rpc/bindresvport.c (modified) * c/src/librpc/src/rpc/clnt_generic.c (modified) * c/src/librpc/src/rpc/clnt_perror.c (modified) * c/src/librpc/src/rpc/clnt_raw.c (modified) * c/src/librpc/src/rpc/clnt_simple.c (modified) * c/src/librpc/src/rpc/clnt_tcp.c (modified) * c/src/librpc/src/rpc/clnt_udp.c (modified) * c/src/librpc/src/rpc/clnt_unix.c (modified) * c/src/librpc/src/rpc/crypt_client.c (modified) * c/src/librpc/src/rpc/des_crypt.3 (modified) * c/src/librpc/src/rpc/des_crypt.c (modified) * c/src/librpc/src/rpc/des_soft.c (modified) * c/src/librpc/src/rpc/get_myaddress.c (modified) * c/src/librpc/src/rpc/getpublickey.c (modified) * c/src/librpc/src/rpc/getrpcent.3 (modified) * c/src/librpc/src/rpc/getrpcent.c (modified) * c/src/librpc/src/rpc/getrpcport.3 (modified) * c/src/librpc/src/rpc/getrpcport.c (modified) * c/src/librpc/src/rpc/key_call.c (modified) * c/src/librpc/src/rpc/key_prot_xdr.c (modified) * c/src/librpc/src/rpc/netname.c (modified) * c/src/librpc/src/rpc/netnamer.c (modified) * c/src/librpc/src/rpc/pmap_clnt.c (modified) * c/src/librpc/src/rpc/pmap_getmaps.c (modified) * c/src/librpc/src/rpc/pmap_getport.c (modified) * c/src/librpc/src/rpc/pmap_prot.c (modified) * c/src/librpc/src/rpc/pmap_prot2.c (modified) * c/src/librpc/src/rpc/pmap_rmt.c (modified) * c/src/librpc/src/rpc/publickey.3 (modified) * c/src/librpc/src/rpc/publickey.5 (modified) * c/src/librpc/src/rpc/rpc.3 (modified) * c/src/librpc/src/rpc/rpc.5 (modified) * c/src/librpc/src/rpc/rpc_callmsg.c (modified) * c/src/librpc/src/rpc/rpc_commondata.c (modified) * c/src/librpc/src/rpc/rpc_dtablesize.c (modified) * c/src/librpc/src/rpc/rpc_prot.c (modified) * c/src/librpc/src/rpc/rpc_secure.3 (modified) * c/src/librpc/src/rpc/rpcdname.c (modified) * c/src/librpc/src/rpc/rstat.1 (modified) * c/src/librpc/src/rpc/rstat_svc.8 (modified) * c/src/librpc/src/rpc/rtems_portmapper.c (modified) * c/src/librpc/src/rpc/rtems_rpc.c (modified) * c/src/librpc/src/rpc/rtime.3 (modified) * c/src/librpc/src/rpc/rtime.c (modified) * c/src/librpc/src/rpc/svc.c (modified) * c/src/librpc/src/rpc/svc_auth.c (modified) * c/src/librpc/src/rpc/svc_auth_des.c (modified) * c/src/librpc/src/rpc/svc_auth_unix.c (modified) * c/src/librpc/src/rpc/svc_raw.c (modified) * c/src/librpc/src/rpc/svc_run.c (modified) * c/src/librpc/src/rpc/svc_simple.c (modified) * c/src/librpc/src/rpc/svc_tcp.c (modified) * c/src/librpc/src/rpc/svc_udp.c (modified) * c/src/librpc/src/rpc/svc_unix.c (modified) * c/src/librpc/src/rpc_callmsg.c (deleted) * c/src/librpc/src/rpc_prot.c (deleted) * c/src/librpc/src/svc.c (deleted) * c/src/librpc/src/svc_auth.c (deleted) * c/src/librpc/src/svc_udp.c (deleted) * c/src/librpc/src/xdr.c (deleted) * c/src/librpc/src/xdr/Makefile.am (modified) * c/src/librpc/src/xdr/xdr.3 (modified) * c/src/librpc/src/xdr/xdr.c (modified) * c/src/librpc/src/xdr/xdr_array.c (modified) * c/src/librpc/src/xdr/xdr_float.c (modified) * c/src/librpc/src/xdr/xdr_mem.c (modified) * c/src/librpc/src/xdr/xdr_rec.c (modified) * c/src/librpc/src/xdr/xdr_reference.c (modified) * c/src/librpc/src/xdr/xdr_sizeof.c (modified) * c/src/librpc/src/xdr/xdr_stdio.c (modified) * c/src/librpc/src/xdr_array.c (deleted) * c/src/librpc/src/xdr_mem.c (deleted) * c/src/librtems++/include/rtems++/Makefile.am (modified) * c/src/librtems++/src/Makefile.am (modified) * c/src/make/Makefile.am (modified) * c/src/make/README (modified) * c/src/make/compilers/Makefile.am (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/configure.in (modified) * c/src/make/custom/Makefile.am (modified) * c/src/make/host.cfg.in (modified) * c/src/make/leaf.cfg (modified) * c/src/make/main.cfg.in (modified) * c/src/optman/rtems/Makefile.am (modified) * c/src/optman/rtems/no-mp.c (modified) * c/src/optman/sapi/Makefile.am (modified) * c/src/tests/itrontests/itronhello/Makefile.am (modified) * c/src/tests/itrontests/itronhello/system.h (modified) * c/src/tests/itrontests/itronmbf01/Makefile.am (modified) * c/src/tests/itrontests/itronmbf01/system.h (modified) * c/src/tests/itrontests/itronmbox01/Makefile.am (modified) * c/src/tests/itrontests/itronmbox01/itronmbox01.scn (modified) * c/src/tests/itrontests/itronmbox01/system.h (modified) * c/src/tests/itrontests/itronsem01/Makefile.am (modified) * c/src/tests/itrontests/itronsem01/init.c (modified) * c/src/tests/itrontests/itronsem01/system.h (modified) * c/src/tests/itrontests/itrontask01/Makefile.am (modified) * c/src/tests/itrontests/itrontask01/system.h (modified) * c/src/tests/itrontests/itrontask02/Makefile.am (modified) * c/src/tests/itrontests/itrontask02/system.h (modified) * c/src/tests/itrontests/itrontask03/Makefile.am (modified) * c/src/tests/itrontests/itrontask03/system.h (modified) * c/src/tests/itrontests/itrontask04/Makefile.am (modified) * c/src/tests/itrontests/itrontask04/system.h (modified) * c/src/tests/itrontests/itrontime01/Makefile.am (modified) * c/src/tests/itrontests/itrontime01/itrontime01.scn (modified) * c/src/tests/itrontests/itrontime01/system.h (modified) * c/src/tests/libtests/cpuuse/Makefile.am (modified) * c/src/tests/libtests/cpuuse/cpuuse.scn (modified) * c/src/tests/libtests/cpuuse/system.h (modified) * c/src/tests/libtests/cpuuse/task2.c (modified) * c/src/tests/libtests/cpuuse/tswitch.c (modified) * c/src/tests/libtests/malloctest/Makefile.am (modified) * c/src/tests/libtests/malloctest/malloctest.scn (modified) * c/src/tests/libtests/malloctest/system.h (modified) * c/src/tests/libtests/monitor/Makefile.am (modified) * c/src/tests/libtests/monitor/system.h (modified) * c/src/tests/libtests/putenvtest/Makefile.am (modified) * c/src/tests/libtests/putenvtest/init.c (modified) * c/src/tests/libtests/rtems++/Makefile.am (modified) * c/src/tests/libtests/rtems++/System.h (modified) * c/src/tests/libtests/rtmonuse/Makefile.am (modified) * c/src/tests/libtests/rtmonuse/system.h (modified) * c/src/tests/libtests/stackchk/Makefile.am (modified) * c/src/tests/libtests/stackchk/system.h (modified) * c/src/tests/libtests/termios/Makefile.am (modified) * c/src/tests/libtests/termios/README (modified) * c/src/tests/libtests/termios/init.c (modified) * c/src/tests/mptests/mp01/node1/Makefile.am (modified) * c/src/tests/mptests/mp01/node2/Makefile.am (modified) * c/src/tests/mptests/mp01/system.h (modified) * c/src/tests/mptests/mp02/node1/Makefile.am (modified) * c/src/tests/mptests/mp02/node2/Makefile.am (modified) * c/src/tests/mptests/mp02/system.h (modified) * c/src/tests/mptests/mp03/node1/Makefile.am (modified) * c/src/tests/mptests/mp03/node2/Makefile.am (modified) * c/src/tests/mptests/mp03/system.h (modified) * c/src/tests/mptests/mp04/node1/Makefile.am (modified) * c/src/tests/mptests/mp04/node2/Makefile.am (modified) * c/src/tests/mptests/mp04/system.h (modified) * c/src/tests/mptests/mp05/node1/Makefile.am (modified) * c/src/tests/mptests/mp05/node2/Makefile.am (modified) * c/src/tests/mptests/mp05/system.h (modified) * c/src/tests/mptests/mp06/node1/Makefile.am (modified) * c/src/tests/mptests/mp06/node2/Makefile.am (modified) * c/src/tests/mptests/mp06/system.h (modified) * c/src/tests/mptests/mp07/node1/Makefile.am (modified) * c/src/tests/mptests/mp07/node2/Makefile.am (modified) * c/src/tests/mptests/mp07/system.h (modified) * c/src/tests/mptests/mp08/node1/Makefile.am (modified) * c/src/tests/mptests/mp08/node2/Makefile.am (modified) * c/src/tests/mptests/mp08/system.h (modified) * c/src/tests/mptests/mp09/node1/Makefile.am (modified) * c/src/tests/mptests/mp09/node2/Makefile.am (modified) * c/src/tests/mptests/mp09/system.h (modified) * c/src/tests/mptests/mp10/node1/Makefile.am (modified) * c/src/tests/mptests/mp10/node2/Makefile.am (modified) * c/src/tests/mptests/mp10/system.h (modified) * c/src/tests/mptests/mp11/node1/Makefile.am (modified) * c/src/tests/mptests/mp11/node2/Makefile.am (modified) * c/src/tests/mptests/mp11/system.h (modified) * c/src/tests/mptests/mp12/node1/Makefile.am (modified) * c/src/tests/mptests/mp12/node2/Makefile.am (modified) * c/src/tests/mptests/mp12/system.h (modified) * c/src/tests/mptests/mp13/node1/Makefile.am (modified) * c/src/tests/mptests/mp13/node2/Makefile.am (modified) * c/src/tests/mptests/mp13/system.h (modified) * c/src/tests/mptests/mp14/Makefile.am (modified) * c/src/tests/mptests/mp14/node1/Makefile.am (modified) * c/src/tests/mptests/mp14/node2/Makefile.am (modified) * c/src/tests/mptests/mp14/system.h (modified) * c/src/tests/psxtests/Makefile.am (modified) * c/src/tests/psxtests/psx01/Makefile.am (modified) * c/src/tests/psxtests/psx01/psx01.scn (modified) * c/src/tests/psxtests/psx01/system.h (modified) * c/src/tests/psxtests/psx02/Makefile.am (modified) * c/src/tests/psxtests/psx02/system.h (modified) * c/src/tests/psxtests/psx03/Makefile.am (modified) * c/src/tests/psxtests/psx03/system.h (modified) * c/src/tests/psxtests/psx04/Makefile.am (modified) * c/src/tests/psxtests/psx04/system.h (modified) * c/src/tests/psxtests/psx05/Makefile.am (modified) * c/src/tests/psxtests/psx05/system.h (modified) * c/src/tests/psxtests/psx06/Makefile.am (modified) * c/src/tests/psxtests/psx06/system.h (modified) * c/src/tests/psxtests/psx07/Makefile.am (modified) * c/src/tests/psxtests/psx07/system.h (modified) * c/src/tests/psxtests/psx08/Makefile.am (modified) * c/src/tests/psxtests/psx08/system.h (modified) * c/src/tests/psxtests/psx09/Makefile.am (modified) * c/src/tests/psxtests/psx09/system.h (modified) * c/src/tests/psxtests/psx10/Makefile.am (modified) * c/src/tests/psxtests/psx10/system.h (modified) * c/src/tests/psxtests/psx11/Makefile.am (modified) * c/src/tests/psxtests/psx11/system.h (modified) * c/src/tests/psxtests/psx12/Makefile.am (modified) * c/src/tests/psxtests/psx12/system.h (modified) * c/src/tests/psxtests/psx13/Makefile.am (modified) * c/src/tests/psxtests/psx13/main.c (modified) * c/src/tests/psxtests/psxcancel/Makefile.am (modified) * c/src/tests/psxtests/psxcancel/system.h (modified) * c/src/tests/psxtests/psxfile01/Makefile.am (modified) * c/src/tests/psxtests/psxfile01/main.c (modified) * c/src/tests/psxtests/psxfile01/psxfile01.scn (modified) * c/src/tests/psxtests/psxfile01/test.c (modified) * c/src/tests/psxtests/psxhdrs/Makefile.am (modified) * c/src/tests/psxtests/psxmount/Makefile.am (modified) * c/src/tests/psxtests/psxmount/main.c (modified) * c/src/tests/psxtests/psxmsgq01/Makefile.am (modified) * c/src/tests/psxtests/psxmsgq01/system.h (modified) * c/src/tests/psxtests/psxreaddir/Makefile.am (modified) * c/src/tests/psxtests/psxreaddir/main.c (modified) * c/src/tests/psxtests/psxsem01/Makefile.am (modified) * c/src/tests/psxtests/psxsem01/system.h (modified) * c/src/tests/psxtests/psxstat/Makefile.am (modified) * c/src/tests/psxtests/psxstat/main.c (modified) * c/src/tests/psxtests/psxstat/test.c (modified) * c/src/tests/psxtests/psxtime/Makefile.am (modified) * c/src/tests/psxtests/psxtime/main.c (modified) * c/src/tests/psxtests/psxtimer/Makefile.am (modified) * c/src/tests/psxtests/psxtimer/system.h (modified) * c/src/tests/samples/Makefile.am (modified) * c/src/tests/samples/base_mp/apptask.c (modified) * c/src/tests/samples/base_mp/init.c (modified) * c/src/tests/samples/base_mp/system.h (modified) * c/src/tests/samples/base_sp/apptask.c (modified) * c/src/tests/samples/base_sp/init.c (modified) * c/src/tests/samples/base_sp/system.h (modified) * c/src/tests/samples/cdtest/Makefile.am (modified) * c/src/tests/samples/cdtest/init.c (modified) * c/src/tests/samples/cdtest/system.h (modified) * c/src/tests/samples/hello/Makefile.am (modified) * c/src/tests/samples/hello/init.c (modified) * c/src/tests/samples/hello/system.h (modified) * c/src/tests/samples/minimum/Makefile.am (modified) * c/src/tests/samples/minimum/init.c (modified) * c/src/tests/samples/paranoia/Makefile.am (modified) * c/src/tests/samples/paranoia/init.c (modified) * c/src/tests/samples/paranoia/system.h (modified) * c/src/tests/samples/ticker/Makefile.am (modified) * c/src/tests/samples/ticker/init.c (modified) * c/src/tests/samples/ticker/system.h (modified) * c/src/tests/samples/ticker/tasks.c (modified) * c/src/tests/samples/unlimited/Makefile.am (modified) * c/src/tests/samples/unlimited/init.c (modified) * c/src/tests/samples/unlimited/system.h (modified) * c/src/tests/sptests/sp01/Makefile.am (modified) * c/src/tests/sptests/sp01/system.h (modified) * c/src/tests/sptests/sp02/Makefile.am (modified) * c/src/tests/sptests/sp02/system.h (modified) * c/src/tests/sptests/sp03/Makefile.am (modified) * c/src/tests/sptests/sp03/system.h (modified) * c/src/tests/sptests/sp04/Makefile.am (modified) * c/src/tests/sptests/sp04/system.h (modified) * c/src/tests/sptests/sp04/tswitch.c (modified) * c/src/tests/sptests/sp05/Makefile.am (modified) * c/src/tests/sptests/sp05/system.h (modified) * c/src/tests/sptests/sp06/Makefile.am (modified) * c/src/tests/sptests/sp06/system.h (modified) * c/src/tests/sptests/sp07/Makefile.am (modified) * c/src/tests/sptests/sp07/system.h (modified) * c/src/tests/sptests/sp08/Makefile.am (modified) * c/src/tests/sptests/sp08/system.h (modified) * c/src/tests/sptests/sp09/Makefile.am (modified) * c/src/tests/sptests/sp09/screen07.c (modified) * c/src/tests/sptests/sp09/screen08.c (modified) * c/src/tests/sptests/sp09/system.h (modified) * c/src/tests/sptests/sp11/Makefile.am (modified) * c/src/tests/sptests/sp11/system.h (modified) * c/src/tests/sptests/sp12/Makefile.am (modified) * c/src/tests/sptests/sp12/system.h (modified) * c/src/tests/sptests/sp13/Makefile.am (modified) * c/src/tests/sptests/sp13/fillbuff.c (modified) * c/src/tests/sptests/sp13/init.c (modified) * c/src/tests/sptests/sp13/putbuff.c (modified) * c/src/tests/sptests/sp13/system.h (modified) * c/src/tests/sptests/sp13/task1.c (modified) * c/src/tests/sptests/sp13/task2.c (modified) * c/src/tests/sptests/sp14/Makefile.am (modified) * c/src/tests/sptests/sp14/system.h (modified) * c/src/tests/sptests/sp15/Makefile.am (modified) * c/src/tests/sptests/sp15/system.h (modified) * c/src/tests/sptests/sp16/Makefile.am (modified) * c/src/tests/sptests/sp16/system.h (modified) * c/src/tests/sptests/sp17/Makefile.am (modified) * c/src/tests/sptests/sp17/system.h (modified) * c/src/tests/sptests/sp19/Makefile.am (modified) * c/src/tests/sptests/sp19/system.h (modified) * c/src/tests/sptests/sp20/Makefile.am (modified) * c/src/tests/sptests/sp20/system.h (modified) * c/src/tests/sptests/sp21/Makefile.am (modified) * c/src/tests/sptests/sp21/system.h (modified) * c/src/tests/sptests/sp22/Makefile.am (modified) * c/src/tests/sptests/sp22/system.h (modified) * c/src/tests/sptests/sp23/Makefile.am (modified) * c/src/tests/sptests/sp23/system.h (modified) * c/src/tests/sptests/sp24/Makefile.am (modified) * c/src/tests/sptests/sp24/system.h (modified) * c/src/tests/sptests/sp25/Makefile.am (modified) * c/src/tests/sptests/sp25/sp25.scn (modified) * c/src/tests/sptests/sp25/system.h (modified) * c/src/tests/sptests/sp26/Makefile.am (modified) * c/src/tests/sptests/sp26/system.h (modified) * c/src/tests/sptests/sp27/Makefile.am (modified) * c/src/tests/sptests/sp27/init.c (modified) * c/src/tests/sptests/sp28/Makefile.am (modified) * c/src/tests/sptests/sp28/init.c (modified) * c/src/tests/sptests/sp29/Makefile.am (modified) * c/src/tests/sptests/sp29/init.c (modified) * c/src/tests/sptests/spfatal/Makefile.am (modified) * c/src/tests/sptests/spfatal/system.h (modified) * c/src/tests/sptests/spsize/Makefile.am (modified) * c/src/tests/sptests/spsize/system.h (modified) * c/src/tests/support/include/Makefile.am (modified) * c/src/tests/support/stubdr/Makefile.am (modified) * c/src/tests/support/wrapup/Makefile.am (modified) * c/src/tests/tmitrontests/tmitronsem01/Makefile.am (modified) * c/src/tests/tmitrontests/tmitronsem01/system.h (modified) * c/src/tests/tmtests/Makefile.am (modified) * c/src/tests/tmtests/tm01/Makefile.am (modified) * c/src/tests/tmtests/tm01/system.h (modified) * c/src/tests/tmtests/tm02/Makefile.am (modified) * c/src/tests/tmtests/tm02/system.h (modified) * c/src/tests/tmtests/tm03/Makefile.am (modified) * c/src/tests/tmtests/tm03/system.h (modified) * c/src/tests/tmtests/tm04/Makefile.am (modified) * c/src/tests/tmtests/tm04/system.h (modified) * c/src/tests/tmtests/tm05/Makefile.am (modified) * c/src/tests/tmtests/tm05/system.h (modified) * c/src/tests/tmtests/tm06/Makefile.am (modified) * c/src/tests/tmtests/tm06/system.h (modified) * c/src/tests/tmtests/tm07/Makefile.am (modified) * c/src/tests/tmtests/tm07/system.h (modified) * c/src/tests/tmtests/tm08/Makefile.am (modified) * c/src/tests/tmtests/tm08/system.h (modified) * c/src/tests/tmtests/tm09/Makefile.am (modified) * c/src/tests/tmtests/tm09/system.h (modified) * c/src/tests/tmtests/tm09/task1.c (modified) * c/src/tests/tmtests/tm10/Makefile.am (modified) * c/src/tests/tmtests/tm10/system.h (modified) * c/src/tests/tmtests/tm11/Makefile.am (modified) * c/src/tests/tmtests/tm11/system.h (modified) * c/src/tests/tmtests/tm11/task1.c (modified) * c/src/tests/tmtests/tm12/Makefile.am (modified) * c/src/tests/tmtests/tm12/system.h (modified) * c/src/tests/tmtests/tm12/task1.c (modified) * c/src/tests/tmtests/tm13/Makefile.am (modified) * c/src/tests/tmtests/tm13/system.h (modified) * c/src/tests/tmtests/tm13/task1.c (modified) * c/src/tests/tmtests/tm14/Makefile.am (modified) * c/src/tests/tmtests/tm14/system.h (modified) * c/src/tests/tmtests/tm14/task1.c (modified) * c/src/tests/tmtests/tm15/Makefile.am (modified) * c/src/tests/tmtests/tm15/system.h (modified) * c/src/tests/tmtests/tm16/Makefile.am (modified) * c/src/tests/tmtests/tm16/system.h (modified) * c/src/tests/tmtests/tm17/Makefile.am (modified) * c/src/tests/tmtests/tm17/system.h (modified) * c/src/tests/tmtests/tm18/Makefile.am (modified) * c/src/tests/tmtests/tm18/system.h (modified) * c/src/tests/tmtests/tm19/Makefile.am (modified) * c/src/tests/tmtests/tm19/system.h (modified) * c/src/tests/tmtests/tm20/Makefile.am (modified) * c/src/tests/tmtests/tm20/system.h (modified) * c/src/tests/tmtests/tm21/Makefile.am (modified) * c/src/tests/tmtests/tm21/system.h (modified) * c/src/tests/tmtests/tm21/task1.c (modified) * c/src/tests/tmtests/tm22/Makefile.am (modified) * c/src/tests/tmtests/tm22/system.h (modified) * c/src/tests/tmtests/tm22/task1.c (modified) * c/src/tests/tmtests/tm23/Makefile.am (modified) * c/src/tests/tmtests/tm23/system.h (modified) * c/src/tests/tmtests/tm24/Makefile.am (modified) * c/src/tests/tmtests/tm24/system.h (modified) * c/src/tests/tmtests/tm25/Makefile.am (modified) * c/src/tests/tmtests/tm25/system.h (modified) * c/src/tests/tmtests/tm26/Makefile.am (modified) * c/src/tests/tmtests/tm26/system.h (modified) * c/src/tests/tmtests/tm27/Makefile.am (modified) * c/src/tests/tmtests/tm27/system.h (modified) * c/src/tests/tmtests/tm28/Makefile.am (modified) * c/src/tests/tmtests/tm28/system.h (modified) * c/src/tests/tmtests/tm29/Makefile.am (modified) * c/src/tests/tmtests/tm29/system.h (modified) * c/src/tests/tmtests/tmck/Makefile.am (modified) * c/src/tests/tmtests/tmck/system.h (modified) * c/src/tests/tmtests/tmoverhd/Makefile.am (modified) * c/src/tests/tmtests/tmoverhd/system.h (modified) * c/src/tests/tools/Makefile.am (modified) * c/src/tests/tools/generic/Makefile.am (modified) * c/src/wrapup/Makefile.am (modified) * configure.in (modified) * cpukit/ftpd/Makefile.am (modified) * cpukit/ftpd/ftpd.c (modified) * cpukit/httpd/Makefile.am (modified) * cpukit/httpd/balloc.c (modified) * cpukit/httpd/ejlex.c (modified) * cpukit/httpd/handler.c (modified) * cpukit/httpd/uemf.c (modified) * cpukit/httpd/uemf.h (modified) * cpukit/httpd/webs.c (modified) * cpukit/itron/include/Makefile.am (modified) * cpukit/itron/src/Makefile.am (modified) * cpukit/itron/src/cre_tsk.c (modified) * cpukit/itron/src/eventflags.c (modified) * cpukit/itron/src/fmempool.c (modified) * cpukit/itron/src/itronsem.c (modified) * cpukit/itron/src/mbox.c (modified) * cpukit/itron/src/msgbuffer.c (modified) * cpukit/itron/src/port.c (modified) * cpukit/itron/src/vmempool.c (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libcsupport/include/console.h (modified) * cpukit/libcsupport/include/rtems/error.h (modified) * cpukit/libcsupport/include/sys/termios.h (modified) * cpukit/libcsupport/src/gxx_wrappers.c (modified) * cpukit/libcsupport/src/libio.c (modified) * cpukit/libcsupport/src/malloc.c (modified) * cpukit/libcsupport/src/scandir.c (modified) * cpukit/libcsupport/src/termios.c (modified) * cpukit/libcsupport/src/termiosreserveresources.c (modified) * cpukit/libcsupport/src/unmount.c (modified) * cpukit/libfs/src/imfs/imfs.h (modified) * cpukit/libfs/src/imfs/imfs_creat.c (modified) * cpukit/libfs/src/imfs/imfs_directory.c (modified) * cpukit/libfs/src/imfs/imfs_stat.c (modified) * cpukit/libfs/src/imfs/imfs_utime.c (modified) * cpukit/libmisc/cpuuse/Makefile.am (modified) * cpukit/libmisc/dummy/Makefile.am (modified) * cpukit/libmisc/dummy/dummy.c (modified) * cpukit/libmisc/dumpbuf/Makefile.am (modified) * cpukit/libmisc/monitor/Makefile.am (modified) * cpukit/libmisc/monitor/mon-server.c (modified) * cpukit/libmisc/rtmonuse/Makefile.am (modified) * cpukit/libmisc/stackchk/Makefile.am (modified) * cpukit/libmisc/stackchk/internal.h (modified) * cpukit/libmisc/untar/Makefile.am (modified) * cpukit/libmisc/wrapup/Makefile.am (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/libnetworking/arpa/Makefile.am (modified) * cpukit/libnetworking/kern/Makefile.am (modified) * cpukit/libnetworking/lib/Makefile.am (modified) * cpukit/libnetworking/lib/rtems_bsdnet_ntp.c (modified) * cpukit/libnetworking/libc/Makefile.am (modified) * cpukit/libnetworking/machine/Makefile.am (modified) * cpukit/libnetworking/memory.h (modified) * cpukit/libnetworking/net/Makefile.am (modified) * cpukit/libnetworking/net/if_loop.c (modified) * cpukit/libnetworking/netinet/Makefile.am (modified) * cpukit/libnetworking/netinet/in.h (modified) * cpukit/libnetworking/nfs/Makefile.am (modified) * cpukit/libnetworking/rtems/Makefile.am (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) * cpukit/libnetworking/sys/Makefile.am (modified) * cpukit/libnetworking/sys/un.h (modified) * cpukit/libnetworking/vm/Makefile.am (modified) * cpukit/libnetworking/wrapup/Makefile.am (modified) * cpukit/librpc/Makefile.am (modified) * cpukit/librpc/README_RTEMS (modified) * cpukit/librpc/include/Makefile.am (modified) * cpukit/librpc/include/rpc/Makefile.am (modified) * cpukit/librpc/include/rpc/auth.h (modified) * cpukit/librpc/include/rpc/auth_des.h (modified) * cpukit/librpc/include/rpc/auth_unix.h (modified) * cpukit/librpc/include/rpc/clnt.h (modified) * cpukit/librpc/include/rpc/des.h (modified) * cpukit/librpc/include/rpc/des_crypt.h (modified) * cpukit/librpc/include/rpc/pmap_clnt.h (modified) * cpukit/librpc/include/rpc/pmap_prot.h (modified) * cpukit/librpc/include/rpc/pmap_rmt.h (modified) * cpukit/librpc/include/rpc/rpc.h (modified) * cpukit/librpc/include/rpc/rpc_com.h (modified) * cpukit/librpc/include/rpc/rpc_msg.h (modified) * cpukit/librpc/include/rpc/svc.h (modified) * cpukit/librpc/include/rpc/svc_auth.h (modified) * cpukit/librpc/include/rpc/types.h (modified) * cpukit/librpc/include/rpc/xdr.h (modified) * cpukit/librpc/include/rpcsvc/.cvsignore (modified) * cpukit/librpc/include/rpcsvc/Makefile.am (modified) * cpukit/librpc/include/rpcsvc/bootparam_prot.x (modified) * cpukit/librpc/include/rpcsvc/crypt.x (modified) * cpukit/librpc/include/rpcsvc/key_prot.x (modified) * cpukit/librpc/include/rpcsvc/klm_prot.x (modified) * cpukit/librpc/include/rpcsvc/mount.x (modified) * cpukit/librpc/include/rpcsvc/nfs_prot.x (modified) * cpukit/librpc/include/rpcsvc/nis.x (modified) * cpukit/librpc/include/rpcsvc/nis_cache.x (modified) * cpukit/librpc/include/rpcsvc/nis_callback.x (modified) * cpukit/librpc/include/rpcsvc/nis_db.h (modified) * cpukit/librpc/include/rpcsvc/nis_object.x (modified) * cpukit/librpc/include/rpcsvc/nis_tags.h (modified) * cpukit/librpc/include/rpcsvc/nislib.h (modified) * cpukit/librpc/include/rpcsvc/nlm_prot.x (modified) * cpukit/librpc/include/rpcsvc/pmap_prot.x (modified) * cpukit/librpc/include/rpcsvc/rex.x (modified) * cpukit/librpc/include/rpcsvc/rnusers.x (modified) * cpukit/librpc/include/rpcsvc/rquota.x (modified) * cpukit/librpc/include/rpcsvc/rstat.x (modified) * cpukit/librpc/include/rpcsvc/rwall.x (modified) * cpukit/librpc/include/rpcsvc/sm_inter.x (modified) * cpukit/librpc/include/rpcsvc/spray.x (modified) * cpukit/librpc/include/rpcsvc/yp.x (modified) * cpukit/librpc/include/rpcsvc/yp_prot.h (modified) * cpukit/librpc/include/rpcsvc/ypclnt.h (modified) * cpukit/librpc/include/rpcsvc/yppasswd.x (modified) * cpukit/librpc/include/rpcsvc/ypupdate_prot.x (modified) * cpukit/librpc/include/rpcsvc/ypxfrd.x (modified) * cpukit/librpc/src/Makefile.am (modified) * cpukit/librpc/src/rpc/DISCLAIMER (modified) * cpukit/librpc/src/rpc/Makefile.am (modified) * cpukit/librpc/src/rpc/PSD.doc/.cvsignore (modified) * cpukit/librpc/src/rpc/PSD.doc/Makefile.am (modified) * cpukit/librpc/src/rpc/PSD.doc/nfs.rfc.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/rpc.prog.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/rpc.rfc.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/rpcgen.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/xdr.nts.ms (modified) * cpukit/librpc/src/rpc/PSD.doc/xdr.rfc.ms (modified) * cpukit/librpc/src/rpc/README (modified) * cpukit/librpc/src/rpc/auth_des.c (modified) * cpukit/librpc/src/rpc/auth_none.c (modified) * cpukit/librpc/src/rpc/auth_time.c (modified) * cpukit/librpc/src/rpc/auth_unix.c (modified) * cpukit/librpc/src/rpc/authdes_prot.c (modified) * cpukit/librpc/src/rpc/authunix_prot.c (modified) * cpukit/librpc/src/rpc/bindresvport.3 (modified) * cpukit/librpc/src/rpc/bindresvport.c (modified) * cpukit/librpc/src/rpc/clnt_generic.c (modified) * cpukit/librpc/src/rpc/clnt_perror.c (modified) * cpukit/librpc/src/rpc/clnt_raw.c (modified) * cpukit/librpc/src/rpc/clnt_simple.c (modified) * cpukit/librpc/src/rpc/clnt_tcp.c (modified) * cpukit/librpc/src/rpc/clnt_udp.c (modified) * cpukit/librpc/src/rpc/clnt_unix.c (modified) * cpukit/librpc/src/rpc/crypt_client.c (modified) * cpukit/librpc/src/rpc/des_crypt.3 (modified) * cpukit/librpc/src/rpc/des_crypt.c (modified) * cpukit/librpc/src/rpc/des_soft.c (modified) * cpukit/librpc/src/rpc/get_myaddress.c (modified) * cpukit/librpc/src/rpc/getpublickey.c (modified) * cpukit/librpc/src/rpc/getrpcent.3 (modified) * cpukit/librpc/src/rpc/getrpcent.c (modified) * cpukit/librpc/src/rpc/getrpcport.3 (modified) * cpukit/librpc/src/rpc/getrpcport.c (modified) * cpukit/librpc/src/rpc/key_call.c (modified) * cpukit/librpc/src/rpc/key_prot_xdr.c (modified) * cpukit/librpc/src/rpc/netname.c (modified) * cpukit/librpc/src/rpc/netnamer.c (modified) * cpukit/librpc/src/rpc/pmap_clnt.c (modified) * cpukit/librpc/src/rpc/pmap_getmaps.c (modified) * cpukit/librpc/src/rpc/pmap_getport.c (modified) * cpukit/librpc/src/rpc/pmap_prot.c (modified) * cpukit/librpc/src/rpc/pmap_prot2.c (modified) * cpukit/librpc/src/rpc/pmap_rmt.c (modified) * cpukit/librpc/src/rpc/publickey.3 (modified) * cpukit/librpc/src/rpc/publickey.5 (modified) * cpukit/librpc/src/rpc/rpc.3 (modified) * cpukit/librpc/src/rpc/rpc.5 (modified) * cpukit/librpc/src/rpc/rpc_callmsg.c (modified) * cpukit/librpc/src/rpc/rpc_commondata.c (modified) * cpukit/librpc/src/rpc/rpc_dtablesize.c (modified) * cpukit/librpc/src/rpc/rpc_prot.c (modified) * cpukit/librpc/src/rpc/rpc_secure.3 (modified) * cpukit/librpc/src/rpc/rpcdname.c (modified) * cpukit/librpc/src/rpc/rstat.1 (modified) * cpukit/librpc/src/rpc/rstat_svc.8 (modified) * cpukit/librpc/src/rpc/rtems_portmapper.c (modified) * cpukit/librpc/src/rpc/rtems_rpc.c (modified) * cpukit/librpc/src/rpc/rtime.3 (modified) * cpukit/librpc/src/rpc/rtime.c (modified) * cpukit/librpc/src/rpc/svc.c (modified) * cpukit/librpc/src/rpc/svc_auth.c (modified) * cpukit/librpc/src/rpc/svc_auth_des.c (modified) * cpukit/librpc/src/rpc/svc_auth_unix.c (modified) * cpukit/librpc/src/rpc/svc_raw.c (modified) * cpukit/librpc/src/rpc/svc_run.c (modified) * cpukit/librpc/src/rpc/svc_simple.c (modified) * cpukit/librpc/src/rpc/svc_tcp.c (modified) * cpukit/librpc/src/rpc/svc_udp.c (modified) * cpukit/librpc/src/rpc/svc_unix.c (modified) * cpukit/librpc/src/xdr/Makefile.am (modified) * cpukit/librpc/src/xdr/xdr.3 (modified) * cpukit/librpc/src/xdr/xdr.c (modified) * cpukit/librpc/src/xdr/xdr_array.c (modified) * cpukit/librpc/src/xdr/xdr_float.c (modified) * cpukit/librpc/src/xdr/xdr_mem.c (modified) * cpukit/librpc/src/xdr/xdr_rec.c (modified) * cpukit/librpc/src/xdr/xdr_reference.c (modified) * cpukit/librpc/src/xdr/xdr_sizeof.c (modified) * cpukit/librpc/src/xdr/xdr_stdio.c (modified) * cpukit/posix/include/Makefile.am (modified) * cpukit/posix/inline/rtems/posix/cond.inl (modified) * cpukit/posix/src/Makefile.am (modified) * cpukit/posix/src/mqueuecreatesupp.c (modified) * cpukit/posix/src/mqueuedeletesupp.c (modified) * cpukit/posix/src/mqueueunlink.c (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/sigtimedwait.c (modified) * cpukit/posix/src/waitpid.c (modified) * cpukit/pppd/Makefile.am (modified) * cpukit/pppd/options.c (modified) * cpukit/pppd/pppd.h (modified) * cpukit/rtems/include/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/rtemsapi.h (modified) * cpukit/rtems/src/Makefile.am (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/taskvariableadd.c (modified) * cpukit/rtems/src/taskvariabledelete.c (modified) * cpukit/rtems/src/taskvariableget.c (modified) * cpukit/sapi/include/Makefile.am (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/README (modified) * cpukit/sapi/src/Makefile.am (modified) * cpukit/score/cpu/a29k/Makefile.am (modified) * cpukit/score/cpu/a29k/rtems/score/a29k.h (modified) * cpukit/score/cpu/hppa1.1/Makefile.am (modified) * cpukit/score/cpu/hppa1.1/rtems/score/hppa.h (modified) * cpukit/score/cpu/i386/Makefile.am (modified) * cpukit/score/cpu/i386/rtems/score/i386.h (modified) * cpukit/score/cpu/i960/Makefile.am (modified) * cpukit/score/cpu/i960/rtems/score/i960.h (modified) * cpukit/score/cpu/m68k/Makefile.am (modified) * cpukit/score/cpu/m68k/qsm.h (modified) * cpukit/score/cpu/m68k/rtems/m68k/qsm.h (modified) * cpukit/score/cpu/m68k/rtems/m68k/sim.h (modified) * cpukit/score/cpu/m68k/rtems/score/m68k.h (modified) * cpukit/score/cpu/m68k/sim.h (modified) * cpukit/score/cpu/mips/Makefile.am (modified) * cpukit/score/cpu/mips/rtems/score/mips.h (modified) * cpukit/score/cpu/mips64orion/Makefile.am (modified) * cpukit/score/cpu/mips64orion/rtems/score/mips64orion.h (modified) * cpukit/score/cpu/no_cpu/Makefile.am (modified) * cpukit/score/cpu/no_cpu/cpu.c (modified) * cpukit/score/cpu/no_cpu/cpu_asm.c (modified) * cpukit/score/cpu/no_cpu/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/rtems/score/no_cpu.h (modified) * cpukit/score/cpu/powerpc/Makefile.am (modified) * cpukit/score/cpu/powerpc/rtems/score/ppc.h (modified) * cpukit/score/cpu/sh/Makefile.am (modified) * cpukit/score/cpu/sh/rtems/score/sh.h (modified) * cpukit/score/cpu/sparc/Makefile.am (modified) * cpukit/score/cpu/sparc/rtems/score/sparc.h (modified) * cpukit/score/cpu/unix/Makefile.am (modified) * cpukit/score/cpu/unix/cpu.c (modified) * cpukit/score/cpu/unix/rtems/score/cpu.h (modified) * cpukit/score/cpu/unix/rtems/score/unix.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/system.h (modified) * cpukit/score/macros/rtems/score/address.inl (modified) * cpukit/score/src/Makefile.am (modified) * cpukit/score/src/objectcopynamestring.c (modified) * make/Makefile.am (modified) * make/README (modified) * make/Templates/Makefile.am (modified) * make/Templates/Makefile.dir (modified) * make/Templates/Makefile.leaf (modified) * make/Templates/Makefile.lib (modified) * make/compilers/Makefile.am (modified) * make/compilers/gcc-no_bsp.cfg (modified) * make/compilers/gcc-portsw.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Makefile.am (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/dmv177.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/eth_comm.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gen68340.cfg (modified) * make/custom/gen68360.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/gensh2.cfg (modified) * make/custom/helas403.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mcp750.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/mvme167.cfg (modified) * make/custom/mvme2307.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/pc386.cfg (modified) * make/custom/ppcn_60x.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/rxgen960.cfg (modified) * make/custom/score603e.cfg (modified) * make/custom/simhppa.cfg (modified) * make/custom/ts_386ex.cfg (modified) * make/host.cfg.in (modified) * make/leaf.cfg (modified) * make/main.cfg (modified) * scripts-ada/.cvsignore (modified) * scripts-ada/Makefile.am (modified) * scripts-ada/binutils/.cvsignore (modified) * scripts-ada/binutils/Makefile.am (modified) * scripts-ada/binutils/binutils.spec.in (modified) * scripts-ada/buildall.in (modified) * scripts-ada/configure.in (modified) * scripts-ada/gdb/.cvsignore (modified) * scripts-ada/gdb/Makefile.am (modified) * scripts-ada/gdb/gdb.spec.in (modified) * scripts-ada/gnatnewlib/.cvsignore (modified) * scripts-ada/gnatnewlib/Makefile.am (modified) * scripts-ada/gnatnewlib/gnatnewlib.spec.in (modified) * scripts-ada/mkbinutilspec.in (modified) * scripts-ada/mkgdbspec.in (modified) * scripts-ada/mkgnatnewlibspec.in (modified) * scripts-ada/setup.def (modified) * scripts/Makefile.am (modified) * scripts/binutils/.cvsignore (modified) * scripts/binutils/Makefile.am (modified) * scripts/binutils/base-binutils.add (modified) * scripts/binutils/binutils.add (modified) * scripts/binutils/target-binutils.add (modified) * scripts/buildall.in (modified) * scripts/configure.in (modified) * scripts/gccnewlib/.cvsignore (modified) * scripts/gccnewlib/Makefile.am (modified) * scripts/gccnewlib/README (added) * scripts/gccnewlib/base-chill.add (modified) * scripts/gccnewlib/base-g77.add (modified) * scripts/gccnewlib/base-gcc.add (modified) * scripts/gccnewlib/base-gcj.add (modified) * scripts/gccnewlib/gccnewlib.add (modified) * scripts/gccnewlib/target-chill.add (modified) * scripts/gccnewlib/target-g77.add (modified) * scripts/gccnewlib/target-gcc.add (modified) * scripts/gccnewlib/target-gcj.add (modified) * scripts/gccnewlib/target-objc.add (modified) * scripts/gdb/.cvsignore (modified) * scripts/gdb/Makefile.am (modified) * scripts/gdb/base-gdb.add (modified) * scripts/gdb/gdb.add (modified) * scripts/gdb/target-gdb.add (modified) * scripts/rtems/.cvsignore (modified) * scripts/rtems/Makefile.am (modified) * scripts/rtems/rtems.spec.in (modified) * scripts/setup.def (modified) * testsuites/itrontests/itronhello/Makefile.am (modified) * testsuites/itrontests/itronhello/system.h (modified) * testsuites/itrontests/itronmbf01/Makefile.am (modified) * testsuites/itrontests/itronmbf01/system.h (modified) * testsuites/itrontests/itronmbox01/Makefile.am (modified) * testsuites/itrontests/itronmbox01/itronmbox01.scn (modified) * testsuites/itrontests/itronmbox01/system.h (modified) * testsuites/itrontests/itronsem01/Makefile.am (modified) * testsuites/itrontests/itronsem01/init.c (modified) * testsuites/itrontests/itronsem01/system.h (modified) * testsuites/itrontests/itrontask01/Makefile.am (modified) * testsuites/itrontests/itrontask01/system.h (modified) * testsuites/itrontests/itrontask02/Makefile.am (modified) * testsuites/itrontests/itrontask02/system.h (modified) * testsuites/itrontests/itrontask03/Makefile.am (modified) * testsuites/itrontests/itrontask03/system.h (modified) * testsuites/itrontests/itrontask04/Makefile.am (modified) * testsuites/itrontests/itrontask04/system.h (modified) * testsuites/itrontests/itrontime01/Makefile.am (modified) * testsuites/itrontests/itrontime01/itrontime01.scn (modified) * testsuites/itrontests/itrontime01/system.h (modified) * testsuites/libtests/cpuuse/Makefile.am (modified) * testsuites/libtests/cpuuse/cpuuse.scn (modified) * testsuites/libtests/cpuuse/system.h (modified) * testsuites/libtests/cpuuse/task2.c (modified) * testsuites/libtests/cpuuse/tswitch.c (modified) * testsuites/libtests/malloctest/Makefile.am (modified) * testsuites/libtests/malloctest/malloctest.scn (modified) * testsuites/libtests/malloctest/system.h (modified) * testsuites/libtests/monitor/Makefile.am (modified) * testsuites/libtests/monitor/system.h (modified) * testsuites/libtests/putenvtest/Makefile.am (modified) * testsuites/libtests/putenvtest/init.c (modified) * testsuites/libtests/rtems++/Makefile.am (modified) * testsuites/libtests/rtems++/System.h (modified) * testsuites/libtests/rtmonuse/Makefile.am (modified) * testsuites/libtests/rtmonuse/system.h (modified) * testsuites/libtests/stackchk/Makefile.am (modified) * testsuites/libtests/stackchk/system.h (modified) * testsuites/libtests/termios/Makefile.am (modified) * testsuites/libtests/termios/README (modified) * testsuites/libtests/termios/init.c (modified) * testsuites/mptests/mp01/node1/Makefile.am (modified) * testsuites/mptests/mp01/node2/Makefile.am (modified) * testsuites/mptests/mp01/system.h (modified) * testsuites/mptests/mp02/node1/Makefile.am (modified) * testsuites/mptests/mp02/node2/Makefile.am (modified) * testsuites/mptests/mp02/system.h (modified) * testsuites/mptests/mp03/node1/Makefile.am (modified) * testsuites/mptests/mp03/node2/Makefile.am (modified) * testsuites/mptests/mp03/system.h (modified) * testsuites/mptests/mp04/node1/Makefile.am (modified) * testsuites/mptests/mp04/node2/Makefile.am (modified) * testsuites/mptests/mp04/system.h (modified) * testsuites/mptests/mp05/node1/Makefile.am (modified) * testsuites/mptests/mp05/node2/Makefile.am (modified) * testsuites/mptests/mp05/system.h (modified) * testsuites/mptests/mp06/node1/Makefile.am (modified) * testsuites/mptests/mp06/node2/Makefile.am (modified) * testsuites/mptests/mp06/system.h (modified) * testsuites/mptests/mp07/node1/Makefile.am (modified) * testsuites/mptests/mp07/node2/Makefile.am (modified) * testsuites/mptests/mp07/system.h (modified) * testsuites/mptests/mp08/node1/Makefile.am (modified) * testsuites/mptests/mp08/node2/Makefile.am (modified) * testsuites/mptests/mp08/system.h (modified) * testsuites/mptests/mp09/node1/Makefile.am (modified) * testsuites/mptests/mp09/node2/Makefile.am (modified) * testsuites/mptests/mp09/system.h (modified) * testsuites/mptests/mp10/node1/Makefile.am (modified) * testsuites/mptests/mp10/node2/Makefile.am (modified) * testsuites/mptests/mp10/system.h (modified) * testsuites/mptests/mp11/node1/Makefile.am (modified) * testsuites/mptests/mp11/node2/Makefile.am (modified) * testsuites/mptests/mp11/system.h (modified) * testsuites/mptests/mp12/node1/Makefile.am (modified) * testsuites/mptests/mp12/node2/Makefile.am (modified) * testsuites/mptests/mp12/system.h (modified) * testsuites/mptests/mp13/node1/Makefile.am (modified) * testsuites/mptests/mp13/node2/Makefile.am (modified) * testsuites/mptests/mp13/system.h (modified) * testsuites/mptests/mp14/Makefile.am (modified) * testsuites/mptests/mp14/node1/Makefile.am (modified) * testsuites/mptests/mp14/node2/Makefile.am (modified) * testsuites/mptests/mp14/system.h (modified) * testsuites/psxtests/Makefile.am (modified) * testsuites/psxtests/psx01/Makefile.am (modified) * testsuites/psxtests/psx01/psx01.scn (modified) * testsuites/psxtests/psx01/system.h (modified) * testsuites/psxtests/psx02/Makefile.am (modified) * testsuites/psxtests/psx02/system.h (modified) * testsuites/psxtests/psx03/Makefile.am (modified) * testsuites/psxtests/psx03/system.h (modified) * testsuites/psxtests/psx04/Makefile.am (modified) * testsuites/psxtests/psx04/system.h (modified) * testsuites/psxtests/psx05/Makefile.am (modified) * testsuites/psxtests/psx05/system.h (modified) * testsuites/psxtests/psx06/Makefile.am (modified) * testsuites/psxtests/psx06/system.h (modified) * testsuites/psxtests/psx07/Makefile.am (modified) * testsuites/psxtests/psx07/system.h (modified) * testsuites/psxtests/psx08/Makefile.am (modified) * testsuites/psxtests/psx08/system.h (modified) * testsuites/psxtests/psx09/Makefile.am (modified) * testsuites/psxtests/psx09/system.h (modified) * testsuites/psxtests/psx10/Makefile.am (modified) * testsuites/psxtests/psx10/system.h (modified) * testsuites/psxtests/psx11/Makefile.am (modified) * testsuites/psxtests/psx11/system.h (modified) * testsuites/psxtests/psx12/Makefile.am (modified) * testsuites/psxtests/psx12/system.h (modified) * testsuites/psxtests/psx13/Makefile.am (modified) * testsuites/psxtests/psx13/main.c (modified) * testsuites/psxtests/psxcancel/Makefile.am (modified) * testsuites/psxtests/psxfile01/Makefile.am (modified) * testsuites/psxtests/psxfile01/main.c (modified) * testsuites/psxtests/psxfile01/psxfile01.scn (modified) * testsuites/psxtests/psxfile01/test.c (modified) * testsuites/psxtests/psxhdrs/Makefile.am (modified) * testsuites/psxtests/psxmount/Makefile.am (modified) * testsuites/psxtests/psxmount/main.c (modified) * testsuites/psxtests/psxmsgq01/Makefile.am (modified) * testsuites/psxtests/psxmsgq01/system.h (modified) * testsuites/psxtests/psxreaddir/Makefile.am (modified) * testsuites/psxtests/psxreaddir/main.c (modified) * testsuites/psxtests/psxsem01/Makefile.am (modified) * testsuites/psxtests/psxsem01/system.h (modified) * testsuites/psxtests/psxstat/Makefile.am (modified) * testsuites/psxtests/psxstat/main.c (modified) * testsuites/psxtests/psxstat/test.c (modified) * testsuites/psxtests/psxtime/Makefile.am (modified) * testsuites/psxtests/psxtime/main.c (modified) * testsuites/psxtests/psxtimer/Makefile.am (modified) * testsuites/psxtests/psxtimer/system.h (modified) * testsuites/samples/Makefile.am (modified) * testsuites/samples/base_mp/apptask.c (modified) * testsuites/samples/base_mp/init.c (modified) * testsuites/samples/base_mp/system.h (modified) * testsuites/samples/base_sp/apptask.c (modified) * testsuites/samples/base_sp/init.c (modified) * testsuites/samples/base_sp/system.h (modified) * testsuites/samples/cdtest/Makefile.am (modified) * testsuites/samples/cdtest/init.c (modified) * testsuites/samples/cdtest/system.h (modified) * testsuites/samples/hello/Makefile.am (modified) * testsuites/samples/hello/init.c (modified) * testsuites/samples/hello/system.h (modified) * testsuites/samples/minimum/Makefile.am (modified) * testsuites/samples/minimum/init.c (modified) * testsuites/samples/paranoia/Makefile.am (modified) * testsuites/samples/paranoia/init.c (modified) * testsuites/samples/paranoia/system.h (modified) * testsuites/samples/ticker/Makefile.am (modified) * testsuites/samples/ticker/init.c (modified) * testsuites/samples/ticker/system.h (modified) * testsuites/samples/ticker/tasks.c (modified) * testsuites/samples/unlimited/Makefile.am (modified) * testsuites/samples/unlimited/init.c (modified) * testsuites/samples/unlimited/system.h (modified) * testsuites/sptests/sp01/Makefile.am (modified) * testsuites/sptests/sp01/system.h (modified) * testsuites/sptests/sp02/Makefile.am (modified) * testsuites/sptests/sp02/system.h (modified) * testsuites/sptests/sp03/Makefile.am (modified) * testsuites/sptests/sp03/system.h (modified) * testsuites/sptests/sp04/Makefile.am (modified) * testsuites/sptests/sp04/system.h (modified) * testsuites/sptests/sp04/tswitch.c (modified) * testsuites/sptests/sp05/Makefile.am (modified) * testsuites/sptests/sp05/system.h (modified) * testsuites/sptests/sp06/Makefile.am (modified) * testsuites/sptests/sp06/system.h (modified) * testsuites/sptests/sp07/Makefile.am (modified) * testsuites/sptests/sp07/system.h (modified) * testsuites/sptests/sp08/Makefile.am (modified) * testsuites/sptests/sp08/system.h (modified) * testsuites/sptests/sp09/Makefile.am (modified) * testsuites/sptests/sp09/screen07.c (modified) * testsuites/sptests/sp09/screen08.c (modified) * testsuites/sptests/sp09/system.h (modified) * testsuites/sptests/sp11/Makefile.am (modified) * testsuites/sptests/sp11/system.h (modified) * testsuites/sptests/sp12/Makefile.am (modified) * testsuites/sptests/sp12/system.h (modified) * testsuites/sptests/sp13/Makefile.am (modified) * testsuites/sptests/sp13/fillbuff.c (modified) * testsuites/sptests/sp13/init.c (modified) * testsuites/sptests/sp13/putbuff.c (modified) * testsuites/sptests/sp13/system.h (modified) * testsuites/sptests/sp13/task1.c (modified) * testsuites/sptests/sp13/task2.c (modified) * testsuites/sptests/sp14/Makefile.am (modified) * testsuites/sptests/sp14/system.h (modified) * testsuites/sptests/sp15/Makefile.am (modified) * testsuites/sptests/sp15/system.h (modified) * testsuites/sptests/sp16/Makefile.am (modified) * testsuites/sptests/sp16/system.h (modified) * testsuites/sptests/sp17/Makefile.am (modified) * testsuites/sptests/sp17/system.h (modified) * testsuites/sptests/sp19/Makefile.am (modified) * testsuites/sptests/sp19/system.h (modified) * testsuites/sptests/sp20/Makefile.am (modified) * testsuites/sptests/sp20/system.h (modified) * testsuites/sptests/sp21/Makefile.am (modified) * testsuites/sptests/sp21/system.h (modified) * testsuites/sptests/sp22/Makefile.am (modified) * testsuites/sptests/sp22/system.h (modified) * testsuites/sptests/sp23/Makefile.am (modified) * testsuites/sptests/sp23/system.h (modified) * testsuites/sptests/sp24/Makefile.am (modified) * testsuites/sptests/sp24/system.h (modified) * testsuites/sptests/sp25/Makefile.am (modified) * testsuites/sptests/sp25/sp25.scn (modified) * testsuites/sptests/sp25/system.h (modified) * testsuites/sptests/sp26/Makefile.am (modified) * testsuites/sptests/sp26/system.h (modified) * testsuites/sptests/sp27/Makefile.am (modified) * testsuites/sptests/sp27/init.c (modified) * testsuites/sptests/sp28/Makefile.am (modified) * testsuites/sptests/sp28/init.c (modified) * testsuites/sptests/sp29/Makefile.am (modified) * testsuites/sptests/sp29/init.c (modified) * testsuites/sptests/spfatal/Makefile.am (modified) * testsuites/sptests/spfatal/system.h (modified) * testsuites/sptests/spsize/Makefile.am (modified) * testsuites/sptests/spsize/system.h (modified) * testsuites/tmitrontests/tmitronsem01/Makefile.am (modified) * testsuites/tmitrontests/tmitronsem01/system.h (modified) * testsuites/tmtests/Makefile.am (modified) * testsuites/tmtests/tm01/Makefile.am (modified) * testsuites/tmtests/tm01/system.h (modified) * testsuites/tmtests/tm02/Makefile.am (modified) * testsuites/tmtests/tm02/system.h (modified) * testsuites/tmtests/tm03/Makefile.am (modified) * testsuites/tmtests/tm03/system.h (modified) * testsuites/tmtests/tm04/Makefile.am (modified) * testsuites/tmtests/tm04/system.h (modified) * testsuites/tmtests/tm05/Makefile.am (modified) * testsuites/tmtests/tm05/system.h (modified) * testsuites/tmtests/tm06/Makefile.am (modified) * testsuites/tmtests/tm06/system.h (modified) * testsuites/tmtests/tm07/Makefile.am (modified) * testsuites/tmtests/tm07/system.h (modified) * testsuites/tmtests/tm08/Makefile.am (modified) * testsuites/tmtests/tm08/system.h (modified) * testsuites/tmtests/tm09/Makefile.am (modified) * testsuites/tmtests/tm09/system.h (modified) * testsuites/tmtests/tm09/task1.c (modified) * testsuites/tmtests/tm10/Makefile.am (modified) * testsuites/tmtests/tm10/system.h (modified) * testsuites/tmtests/tm11/Makefile.am (modified) * testsuites/tmtests/tm11/system.h (modified) * testsuites/tmtests/tm11/task1.c (modified) * testsuites/tmtests/tm12/Makefile.am (modified) * testsuites/tmtests/tm12/system.h (modified) * testsuites/tmtests/tm12/task1.c (modified) * testsuites/tmtests/tm13/Makefile.am (modified) * testsuites/tmtests/tm13/system.h (modified) * testsuites/tmtests/tm13/task1.c (modified) * testsuites/tmtests/tm14/Makefile.am (modified) * testsuites/tmtests/tm14/system.h (modified) * testsuites/tmtests/tm14/task1.c (modified) * testsuites/tmtests/tm15/Makefile.am (modified) * testsuites/tmtests/tm15/system.h (modified) * testsuites/tmtests/tm16/Makefile.am (modified) * testsuites/tmtests/tm16/system.h (modified) * testsuites/tmtests/tm17/Makefile.am (modified) * testsuites/tmtests/tm17/system.h (modified) * testsuites/tmtests/tm18/Makefile.am (modified) * testsuites/tmtests/tm18/system.h (modified) * testsuites/tmtests/tm19/Makefile.am (modified) * testsuites/tmtests/tm19/system.h (modified) * testsuites/tmtests/tm20/Makefile.am (modified) * testsuites/tmtests/tm20/system.h (modified) * testsuites/tmtests/tm21/Makefile.am (modified) * testsuites/tmtests/tm21/system.h (modified) * testsuites/tmtests/tm21/task1.c (modified) * testsuites/tmtests/tm22/Makefile.am (modified) * testsuites/tmtests/tm22/system.h (modified) * testsuites/tmtests/tm22/task1.c (modified) * testsuites/tmtests/tm23/Makefile.am (modified) * testsuites/tmtests/tm23/system.h (modified) * testsuites/tmtests/tm24/Makefile.am (modified) * testsuites/tmtests/tm24/system.h (modified) * testsuites/tmtests/tm25/Makefile.am (modified) * testsuites/tmtests/tm25/system.h (modified) * testsuites/tmtests/tm26/Makefile.am (modified) * testsuites/tmtests/tm26/system.h (modified) * testsuites/tmtests/tm27/Makefile.am (modified) * testsuites/tmtests/tm27/system.h (modified) * testsuites/tmtests/tm28/Makefile.am (modified) * testsuites/tmtests/tm28/system.h (modified) * testsuites/tmtests/tm29/Makefile.am (modified) * testsuites/tmtests/tm29/system.h (modified) * testsuites/tmtests/tmck/Makefile.am (modified) * testsuites/tmtests/tmck/system.h (modified) * testsuites/tmtests/tmoverhd/Makefile.am (modified) * testsuites/tmtests/tmoverhd/system.h (modified) * testsuites/tools/Makefile.am (modified) * testsuites/tools/generic/Makefile.am (modified) * tools/Makefile.am (modified) * tools/build/Makefile.am (modified) * tools/cpu/Makefile.am (modified) * tools/cpu/generic/Makefile.am (modified) * tools/cpu/generic/size_rtems.in (modified) * tools/cpu/hppa1.1/Makefile.am (modified) * tools/cpu/sh/Makefile.am (modified) * tools/cpu/sh/configure.in (modified) * tools/cpu/sh/shgen.c (modified) * tools/cpu/unix/Makefile.am (modified) * tools/cpu/unix/gensize.c (modified) * tools/update/Makefile.am (modified) * tools/update/acpolish (modified) * tools/update/ampolish (modified) * tools/update/cipolish (modified) * tools/update/rtems-polish.sh (modified) Merged from 4.5.0-beta3a Thu, 13 Apr 2000 14:37:14 GMT Joel Sherrill [bf85b19] * c/.cvsignore (added) * c/make/.cvsignore (added) * c/src/.cvsignore (added) * c/src/exec/itron/.cvsignore (added) * c/src/exec/itron/include/.cvsignore (added) * c/src/exec/itron/include/itronsys/.cvsignore (added) * c/src/exec/itron/include/rtems/.cvsignore (added) * c/src/exec/itron/include/rtems/itron/.cvsignore (added) * c/src/exec/itron/inline/.cvsignore (added) * c/src/exec/itron/inline/rtems/.cvsignore (added) * c/src/exec/itron/inline/rtems/itron/.cvsignore (added) * c/src/exec/itron/src/.cvsignore (added) * c/src/exec/libcsupport/.cvsignore (added) * c/src/exec/libnetworking/.cvsignore (added) * c/src/exec/libnetworking/arpa/.cvsignore (added) * c/src/exec/libnetworking/kern/.cvsignore (added) * c/src/exec/libnetworking/lib/.cvsignore (added) * c/src/exec/libnetworking/libc/.cvsignore (added) * c/src/exec/libnetworking/machine/.cvsignore (added) * c/src/exec/libnetworking/net/.cvsignore (added) * c/src/exec/libnetworking/netinet/.cvsignore (added) * c/src/exec/libnetworking/nfs/.cvsignore (added) * c/src/exec/libnetworking/rtems/.cvsignore (added) * c/src/exec/libnetworking/sys/.cvsignore (added) * c/src/exec/libnetworking/vm/.cvsignore (added) * c/src/exec/libnetworking/wrapup/.cvsignore (added) * c/src/exec/librpc/.cvsignore (added) * c/src/exec/librpc/include/.cvsignore (added) * c/src/exec/librpc/include/rpc/.cvsignore (added) * c/src/exec/librpc/src/.cvsignore (added) * c/src/exec/posix/.cvsignore (added) * c/src/exec/posix/include/.cvsignore (added) * c/src/exec/posix/include/rtems/.cvsignore (added) * c/src/exec/posix/include/rtems/posix/.cvsignore (added) * c/src/exec/posix/include/sys/.cvsignore (added) * c/src/exec/posix/inline/.cvsignore (added) * c/src/exec/posix/inline/rtems/.cvsignore (added) * c/src/exec/posix/inline/rtems/posix/.cvsignore (added) * c/src/exec/posix/macros/.cvsignore (added) * c/src/exec/posix/macros/rtems/.cvsignore (added) * c/src/exec/posix/macros/rtems/posix/.cvsignore (added) * c/src/exec/posix/optman/.cvsignore (added) * c/src/exec/posix/src/.cvsignore (added) * c/src/exec/rtems/.cvsignore (added) * c/src/exec/rtems/include/.cvsignore (added) * c/src/exec/rtems/include/rtems/.cvsignore (added) * c/src/exec/rtems/include/rtems/rtems/.cvsignore (added) * c/src/exec/rtems/inline/.cvsignore (added) * c/src/exec/rtems/inline/rtems/.cvsignore (added) * c/src/exec/rtems/inline/rtems/rtems/.cvsignore (added) * c/src/exec/rtems/macros/.cvsignore (added) * c/src/exec/rtems/macros/rtems/.cvsignore (added) * c/src/exec/rtems/macros/rtems/rtems/.cvsignore (added) * c/src/exec/rtems/optman/.cvsignore (added) * c/src/exec/rtems/src/.cvsignore (added) * c/src/exec/sapi/.cvsignore (added) * c/src/exec/sapi/include/.cvsignore (added) * c/src/exec/sapi/include/rtems/.cvsignore (added) * c/src/exec/sapi/inline/.cvsignore (added) * c/src/exec/sapi/inline/rtems/.cvsignore (added) * c/src/exec/sapi/macros/.cvsignore (added) * c/src/exec/sapi/macros/rtems/.cvsignore (added) * c/src/exec/sapi/optman/.cvsignore (added) * c/src/exec/sapi/src/.cvsignore (added) * c/src/exec/score/cpu/a29k/.cvsignore (added) * c/src/exec/score/cpu/a29k/rtems/.cvsignore (added) * c/src/exec/score/cpu/a29k/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/hppa1.1/.cvsignore (added) * c/src/exec/score/cpu/hppa1.1/rtems/.cvsignore (added) * c/src/exec/score/cpu/hppa1.1/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/i386/.cvsignore (added) * c/src/exec/score/cpu/i386/rtems/.cvsignore (added) * c/src/exec/score/cpu/i386/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/i960/.cvsignore (added) * c/src/exec/score/cpu/i960/rtems/.cvsignore (added) * c/src/exec/score/cpu/i960/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/m68k/.cvsignore (added) * c/src/exec/score/cpu/m68k/rtems/.cvsignore (added) * c/src/exec/score/cpu/m68k/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/mips/.cvsignore (added) * c/src/exec/score/cpu/mips/rtems/.cvsignore (added) * c/src/exec/score/cpu/mips/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/mips64orion/.cvsignore (added) * c/src/exec/score/cpu/mips64orion/rtems/.cvsignore (added) * c/src/exec/score/cpu/mips64orion/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/no_cpu/.cvsignore (added) * c/src/exec/score/cpu/no_cpu/rtems/.cvsignore (added) * c/src/exec/score/cpu/no_cpu/rtems/score/.cvsignore (added) * c/src/exec/score/cpu/powerpc/new_exception_processing/.cvsignore (added) * c/src/exec/score/cpu/powerpc/old_exception_processing/.cvsignore (added) * c/src/exec/score/cpu/powerpc/shared/.cvsignore (added) * c/src/lib/.cvsignore (added) * c/src/lib/libbsp/.cvsignore (added) * c/src/lib/libbsp/powerpc/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/motorola/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/openpic/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/pci/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/residual/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/start/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/startup/.cvsignore (added) * c/src/lib/libbsp/powerpc/shared/vectors/.cvsignore (added) * c/src/lib/libbsp/powerpc/support/new_exception_processing/.cvsignore (added) * c/src/lib/libbsp/powerpc/support/old_exception_processing/.cvsignore (added) * c/src/lib/libbsp/sh/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/console/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/include/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/scitab/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/start/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/startup/.cvsignore (added) * c/src/lib/libbsp/sh/gensh1/wrapup/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/console/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/include/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/scitab/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/start/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/startup/.cvsignore (added) * c/src/lib/libbsp/sh/gensh2/wrapup/.cvsignore (added) * c/src/lib/libbsp/sh/shared/.cvsignore (added) * c/src/lib/libbsp/shmdr/.cvsignore (added) * c/src/lib/libbsp/sparc/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/clock/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/console/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/gnatsupp/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/include/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/start/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/startup/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/timer/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/tools/.cvsignore (added) * c/src/lib/libbsp/sparc/erc32/wrapup/.cvsignore (added) * c/src/lib/libbsp/unix/.cvsignore (added) * c/src/lib/libbsp/unix/posix/.cvsignore (added) * c/src/lib/libbsp/unix/posix/clock/.cvsignore (added) * c/src/lib/libbsp/unix/posix/console/.cvsignore (added) * c/src/lib/libbsp/unix/posix/include/.cvsignore (added) * c/src/lib/libbsp/unix/posix/shmsupp/.cvsignore (added) * c/src/lib/libbsp/unix/posix/startup/.cvsignore (added) * c/src/lib/libbsp/unix/posix/timer/.cvsignore (added) * c/src/lib/libbsp/unix/posix/tools/.cvsignore (added) * c/src/lib/libbsp/unix/posix/wrapup/.cvsignore (added) * c/src/lib/libc/.cvsignore (added) * c/src/lib/libcpu/.cvsignore (added) * c/src/lib/libcpu/a29k/.cvsignore (added) * c/src/lib/libcpu/a29k/clock/.cvsignore (added) * c/src/lib/libcpu/a29k/timer/.cvsignore (added) * c/src/lib/libcpu/hppa1.1/.cvsignore (added) * c/src/lib/libcpu/hppa1.1/clock/.cvsignore (added) * c/src/lib/libcpu/hppa1.1/include/.cvsignore (added) * c/src/lib/libcpu/hppa1.1/milli/.cvsignore (added) * c/src/lib/libcpu/hppa1.1/semaphore/.cvsignore (added) * c/src/lib/libcpu/hppa1.1/timer/.cvsignore (added) * c/src/lib/libcpu/i386/.cvsignore (added) * c/src/lib/libcpu/m68k/.cvsignore (added) * c/src/lib/libcpu/m68k/m68040/.cvsignore (added) * c/src/lib/libcpu/m68k/m68040/fpsp/.cvsignore (added) * c/src/lib/libcpu/mips/.cvsignore (added) * c/src/lib/libcpu/mips/clock/.cvsignore (added) * c/src/lib/libcpu/mips/timer/.cvsignore (added) * c/src/lib/libcpu/mips64orion/.cvsignore (added) * c/src/lib/libcpu/mips64orion/clock/.cvsignore (added) * c/src/lib/libcpu/mips64orion/timer/.cvsignore (added) * c/src/lib/libcpu/powerpc/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc505/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc505/timer/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc505/vectors/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc6xx/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc6xx/clock/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc6xx/exceptions/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc6xx/mmu/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc6xx/timer/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc6xx/wrapup/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc821/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc821/clock/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc821/console-generic/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc821/include/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc821/timer/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc821/vectors/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc860/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc860/clock/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc860/console-generic/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc860/include/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc860/timer/.cvsignore (added) * c/src/lib/libcpu/powerpc/mpc860/vectors/.cvsignore (added) * c/src/lib/libcpu/powerpc/new_exception_processing/.cvsignore (added) * c/src/lib/libcpu/powerpc/old_exception_processing/.cvsignore (added) * c/src/lib/libcpu/powerpc/ppc403/.cvsignore (added) * c/src/lib/libcpu/powerpc/ppc403/clock/.cvsignore (added) * c/src/lib/libcpu/powerpc/ppc403/console/.cvsignore (added) * c/src/lib/libcpu/powerpc/ppc403/ictrl/.cvsignore (added) * c/src/lib/libcpu/powerpc/ppc403/timer/.cvsignore (added) * c/src/lib/libcpu/powerpc/ppc403/vectors/.cvsignore (added) * c/src/lib/libcpu/powerpc/shared/.cvsignore (added) * c/src/lib/libcpu/powerpc/wrapup/.cvsignore (added) * c/src/lib/libcpu/sh/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/clock/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/delay/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/include/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/null/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/sci/.cvsignore (added) * c/src/lib/libcpu/sh/sh7032/timer/.cvsignore (added) * c/src/lib/libcpu/sh/sh7045/.cvsignore (added) * c/src/lib/libcpu/sh/sh7045/clock/.cvsignore (added) * c/src/lib/libcpu/sh/sh7045/include/.cvsignore (added) * c/src/lib/libcpu/sh/sh7045/null/.cvsignore (added) * c/src/lib/libcpu/sh/sh7045/sci/.cvsignore (added) * c/src/lib/libcpu/sh/sh7045/timer/.cvsignore (added) * c/src/lib/libcpu/sparc/.cvsignore (added) * c/src/lib/libcpu/sparc/reg_win/.cvsignore (added) * c/src/lib/libcpu/sparc/syscall/.cvsignore (added) * c/src/libchip/.cvsignore (added) * c/src/libchip/network/.cvsignore (added) * c/src/libchip/rtc/.cvsignore (added) * c/src/libchip/serial/.cvsignore (added) * c/src/libchip/shmdr/.cvsignore (added) * c/src/libmisc/.cvsignore (added) * c/src/libmisc/cpuuse/.cvsignore (added) * c/src/libmisc/dummy/.cvsignore (added) * c/src/libmisc/dumpbuf/.cvsignore (added) * c/src/libmisc/monitor/.cvsignore (added) * c/src/libmisc/rtmonuse/.cvsignore (added) * c/src/libmisc/stackchk/.cvsignore (added) * c/src/libmisc/untar/.cvsignore (added) * c/src/libmisc/wrapup/.cvsignore (added) * c/src/libnetworking/.cvsignore (added) * c/src/libnetworking/arpa/.cvsignore (added) * c/src/libnetworking/include/.cvsignore (added) * c/src/libnetworking/kern/.cvsignore (added) * c/src/libnetworking/lib/.cvsignore (added) * c/src/libnetworking/libc/.cvsignore (added) * c/src/libnetworking/machine/.cvsignore (added) * c/src/libnetworking/net/.cvsignore (added) * c/src/libnetworking/netinet/.cvsignore (added) * c/src/libnetworking/nfs/.cvsignore (added) * c/src/libnetworking/pppd/.cvsignore (added) * c/src/libnetworking/rtems/.cvsignore (added) * c/src/libnetworking/rtems_servers/.cvsignore (added) * c/src/libnetworking/rtems_webserver/.cvsignore (added) * c/src/libnetworking/sys/.cvsignore (added) * c/src/libnetworking/vm/.cvsignore (added) * c/src/libnetworking/wrapup/.cvsignore (added) * c/src/librdbg/.cvsignore (added) * c/src/librdbg/include/.cvsignore (added) * c/src/librdbg/include/rdbg/.cvsignore (added) * c/src/librdbg/include/rdbg/i386/.cvsignore (added) * c/src/librdbg/include/rdbg/powerpc/.cvsignore (added) * c/src/librdbg/src/.cvsignore (added) * c/src/librdbg/src/i386/.cvsignore (added) * c/src/librdbg/src/i386/any/.cvsignore (added) * c/src/librdbg/src/powerpc/.cvsignore (added) * c/src/librdbg/src/powerpc/mcp750/.cvsignore (added) * c/src/librdbg/src/powerpc/new_exception_processing/.cvsignore (added) * c/src/librpc/.cvsignore (added) * c/src/librpc/include/.cvsignore (added) * c/src/librpc/include/rpc/.cvsignore (added) * c/src/librpc/src/.cvsignore (added) * c/src/librtems++/.cvsignore (added) * c/src/librtems++/include/.cvsignore (added) * c/src/librtems++/include/rtems++/.cvsignore (added) * c/src/librtems++/src/.cvsignore (added) * c/src/make/.cvsignore (added) * c/src/make/compilers/.cvsignore (added) * c/src/make/custom/.cvsignore (added) * c/src/tests/.cvsignore (added) * c/src/tests/itrontests/.cvsignore (added) * c/src/tests/itrontests/itronhello/.cvsignore (added) * c/src/tests/itrontests/itronmbf01/.cvsignore (added) * c/src/tests/itrontests/itronmbox01/.cvsignore (added) * c/src/tests/itrontests/itronsem01/.cvsignore (added) * c/src/tests/itrontests/itrontask01/.cvsignore (added) * c/src/tests/itrontests/itrontask02/.cvsignore (added) * c/src/tests/itrontests/itrontask03/.cvsignore (added) * c/src/tests/itrontests/itrontask04/.cvsignore (added) * c/src/tests/itrontests/itrontime01/.cvsignore (added) * c/src/tests/libtests/.cvsignore (added) * c/src/tests/libtests/cpuuse/.cvsignore (added) * c/src/tests/libtests/malloctest/.cvsignore (added) * c/src/tests/libtests/monitor/.cvsignore (added) * c/src/tests/libtests/putenvtest/.cvsignore (added) * c/src/tests/libtests/rtems++/.cvsignore (added) * c/src/tests/libtests/rtmonuse/.cvsignore (added) * c/src/tests/libtests/stackchk/.cvsignore (added) * c/src/tests/libtests/termios/.cvsignore (added) * c/src/tests/mptests/.cvsignore (added) * c/src/tests/mptests/mp01/.cvsignore (added) * c/src/tests/mptests/mp01/node1/.cvsignore (added) * c/src/tests/mptests/mp01/node2/.cvsignore (added) * c/src/tests/mptests/mp02/.cvsignore (added) * c/src/tests/mptests/mp02/node1/.cvsignore (added) * c/src/tests/mptests/mp02/node2/.cvsignore (added) * c/src/tests/mptests/mp03/.cvsignore (added) * c/src/tests/mptests/mp03/node1/.cvsignore (added) * c/src/tests/mptests/mp03/node2/.cvsignore (added) * c/src/tests/mptests/mp04/.cvsignore (added) * c/src/tests/mptests/mp04/node1/.cvsignore (added) * c/src/tests/mptests/mp04/node2/.cvsignore (added) * c/src/tests/mptests/mp05/.cvsignore (added) * c/src/tests/mptests/mp05/node1/.cvsignore (added) * c/src/tests/mptests/mp05/node2/.cvsignore (added) * c/src/tests/mptests/mp06/.cvsignore (added) * c/src/tests/mptests/mp06/node1/.cvsignore (added) * c/src/tests/mptests/mp06/node2/.cvsignore (added) * c/src/tests/mptests/mp07/.cvsignore (added) * c/src/tests/mptests/mp07/node1/.cvsignore (added) * c/src/tests/mptests/mp07/node2/.cvsignore (added) * c/src/tests/mptests/mp08/.cvsignore (added) * c/src/tests/mptests/mp08/node1/.cvsignore (added) * c/src/tests/mptests/mp08/node2/.cvsignore (added) * c/src/tests/mptests/mp09/.cvsignore (added) * c/src/tests/mptests/mp09/node1/.cvsignore (added) * c/src/tests/mptests/mp09/node2/.cvsignore (added) * c/src/tests/mptests/mp10/.cvsignore (added) * c/src/tests/mptests/mp10/node1/.cvsignore (added) * c/src/tests/mptests/mp10/node2/.cvsignore (added) * c/src/tests/mptests/mp11/.cvsignore (added) * c/src/tests/mptests/mp11/node1/.cvsignore (added) * c/src/tests/mptests/mp11/node2/.cvsignore (added) * c/src/tests/mptests/mp12/.cvsignore (added) * c/src/tests/mptests/mp12/node1/.cvsignore (added) * c/src/tests/mptests/mp12/node2/.cvsignore (added) * c/src/tests/mptests/mp13/.cvsignore (added) * c/src/tests/mptests/mp13/node1/.cvsignore (added) * c/src/tests/mptests/mp13/node2/.cvsignore (added) * c/src/tests/mptests/mp14/.cvsignore (added) * c/src/tests/mptests/mp14/node1/.cvsignore (added) * c/src/tests/mptests/mp14/node2/.cvsignore (added) * c/src/tests/psxtests/.cvsignore (added) * c/src/tests/psxtests/include/.cvsignore (added) * c/src/tests/psxtests/psx01/.cvsignore (added) * c/src/tests/psxtests/psx02/.cvsignore (added) * c/src/tests/psxtests/psx03/.cvsignore (added) * c/src/tests/psxtests/psx04/.cvsignore (added) * c/src/tests/psxtests/psx05/.cvsignore (added) * c/src/tests/psxtests/psx06/.cvsignore (added) * c/src/tests/psxtests/psx07/.cvsignore (added) * c/src/tests/psxtests/psx08/.cvsignore (added) * c/src/tests/psxtests/psx09/.cvsignore (added) * c/src/tests/psxtests/psx10/.cvsignore (added) * c/src/tests/psxtests/psx11/.cvsignore (added) * c/src/tests/psxtests/psx12/.cvsignore (added) * c/src/tests/psxtests/psx13/.cvsignore (added) * c/src/tests/psxtests/psxcancel/.cvsignore (added) * c/src/tests/psxtests/psxfile01/.cvsignore (added) * c/src/tests/psxtests/psxhdrs/.cvsignore (added) * c/src/tests/psxtests/psxmount/.cvsignore (added) * c/src/tests/psxtests/psxmsgq01/.cvsignore (added) * c/src/tests/psxtests/psxreaddir/.cvsignore (added) * c/src/tests/psxtests/psxsem01/.cvsignore (added) * c/src/tests/psxtests/psxstat/.cvsignore (added) * c/src/tests/psxtests/psxtime/.cvsignore (added) * c/src/tests/psxtests/psxtimer/.cvsignore (added) * c/src/tests/samples/.cvsignore (added) * c/src/tests/samples/base_mp/.cvsignore (added) * c/src/tests/samples/base_mp/node1/.cvsignore (added) * c/src/tests/samples/base_mp/node2/.cvsignore (added) * c/src/tests/samples/base_sp/.cvsignore (added) * c/src/tests/samples/cdtest/.cvsignore (added) * c/src/tests/samples/hello/.cvsignore (added) * c/src/tests/samples/minimum/.cvsignore (added) * c/src/tests/samples/paranoia/.cvsignore (added) * c/src/tests/samples/ticker/.cvsignore (added) * c/src/tests/samples/unlimited/.cvsignore (added) * c/src/tests/sptests/.cvsignore (added) * c/src/tests/sptests/sp01/.cvsignore (added) * c/src/tests/sptests/sp02/.cvsignore (added) * c/src/tests/sptests/sp03/.cvsignore (added) * c/src/tests/sptests/sp04/.cvsignore (added) * c/src/tests/sptests/sp05/.cvsignore (added) * c/src/tests/sptests/sp06/.cvsignore (added) * c/src/tests/sptests/sp07/.cvsignore (added) * c/src/tests/sptests/sp08/.cvsignore (added) * c/src/tests/sptests/sp09/.cvsignore (added) * c/src/tests/sptests/sp11/.cvsignore (added) * c/src/tests/sptests/sp12/.cvsignore (added) * c/src/tests/sptests/sp13/.cvsignore (added) * c/src/tests/sptests/sp14/.cvsignore (added) * c/src/tests/sptests/sp15/.cvsignore (added) * c/src/tests/sptests/sp16/.cvsignore (added) * c/src/tests/sptests/sp17/.cvsignore (added) * c/src/tests/sptests/sp19/.cvsignore (added) * c/src/tests/sptests/sp20/.cvsignore (added) * c/src/tests/sptests/sp21/.cvsignore (added) * c/src/tests/sptests/sp22/.cvsignore (added) * c/src/tests/sptests/sp23/.cvsignore (added) * c/src/tests/sptests/sp24/.cvsignore (added) * c/src/tests/sptests/sp25/.cvsignore (added) * c/src/tests/sptests/sp26/.cvsignore (added) * c/src/tests/sptests/sp27/.cvsignore (added) * c/src/tests/sptests/sp28/.cvsignore (added) * c/src/tests/sptests/sp29/.cvsignore (added) * c/src/tests/sptests/spfatal/.cvsignore (added) * c/src/tests/sptests/spsize/.cvsignore (added) * c/src/tests/support/.cvsignore (added) * c/src/tests/support/include/.cvsignore (added) * c/src/tests/support/stubdr/.cvsignore (added) * c/src/tests/support/wrapup/.cvsignore (added) * c/src/tests/tmitrontests/.cvsignore (added) * c/src/tests/tmitrontests/include/.cvsignore (added) * c/src/tests/tmitrontests/tmitronsem01/.cvsignore (added) * c/src/tests/tmtests/.cvsignore (added) * c/src/tests/tmtests/include/.cvsignore (added) * c/src/tests/tmtests/tm01/.cvsignore (added) * c/src/tests/tmtests/tm02/.cvsignore (added) * c/src/tests/tmtests/tm03/.cvsignore (added) * c/src/tests/tmtests/tm04/.cvsignore (added) * c/src/tests/tmtests/tm05/.cvsignore (added) * c/src/tests/tmtests/tm06/.cvsignore (added) * c/src/tests/tmtests/tm07/.cvsignore (added) * c/src/tests/tmtests/tm08/.cvsignore (added) * c/src/tests/tmtests/tm09/.cvsignore (added) * c/src/tests/tmtests/tm10/.cvsignore (added) * c/src/tests/tmtests/tm11/.cvsignore (added) * c/src/tests/tmtests/tm12/.cvsignore (added) * c/src/tests/tmtests/tm13/.cvsignore (added) * c/src/tests/tmtests/tm14/.cvsignore (added) * c/src/tests/tmtests/tm15/.cvsignore (added) * c/src/tests/tmtests/tm16/.cvsignore (added) * c/src/tests/tmtests/tm17/.cvsignore (added) * c/src/tests/tmtests/tm18/.cvsignore (added) * c/src/tests/tmtests/tm19/.cvsignore (added) * c/src/tests/tmtests/tm20/.cvsignore (added) * c/src/tests/tmtests/tm21/.cvsignore (added) * c/src/tests/tmtests/tm22/.cvsignore (added) * c/src/tests/tmtests/tm23/.cvsignore (added) * c/src/tests/tmtests/tm24/.cvsignore (added) * c/src/tests/tmtests/tm25/.cvsignore (added) * c/src/tests/tmtests/tm26/.cvsignore (added) * c/src/tests/tmtests/tm27/.cvsignore (added) * c/src/tests/tmtests/tm28/.cvsignore (added) * c/src/tests/tmtests/tm29/.cvsignore (added) * c/src/tests/tmtests/tmck/.cvsignore (added) * c/src/tests/tmtests/tmoverhd/.cvsignore (added) * c/src/tests/tools/.cvsignore (added) * c/src/tests/tools/generic/.cvsignore (added) * c/src/wrapup/.cvsignore (added) * cpukit/httpd/.cvsignore (added) * cpukit/itron/.cvsignore (added) * cpukit/itron/include/.cvsignore (added) * cpukit/itron/include/itronsys/.cvsignore (added) * cpukit/itron/include/rtems/.cvsignore (added) * cpukit/itron/include/rtems/itron/.cvsignore (added) * cpukit/itron/inline/.cvsignore (added) * cpukit/itron/inline/rtems/.cvsignore (added) * cpukit/itron/inline/rtems/itron/.cvsignore (added) * cpukit/itron/src/.cvsignore (added) * cpukit/libcsupport/.cvsignore (added) * cpukit/libmisc/.cvsignore (added) * cpukit/libmisc/cpuuse/.cvsignore (added) * cpukit/libmisc/dummy/.cvsignore (added) * cpukit/libmisc/dumpbuf/.cvsignore (added) * cpukit/libmisc/monitor/.cvsignore (added) * cpukit/libmisc/rtmonuse/.cvsignore (added) * cpukit/libmisc/stackchk/.cvsignore (added) * cpukit/libmisc/untar/.cvsignore (added) * cpukit/libmisc/wrapup/.cvsignore (added) * cpukit/libnetworking/.cvsignore (added) * cpukit/libnetworking/arpa/.cvsignore (added) * cpukit/libnetworking/kern/.cvsignore (added) * cpukit/libnetworking/lib/.cvsignore (added) * cpukit/libnetworking/libc/.cvsignore (added) * cpukit/libnetworking/machine/.cvsignore (added) * cpukit/libnetworking/net/.cvsignore (added) * cpukit/libnetworking/netinet/.cvsignore (added) * cpukit/libnetworking/nfs/.cvsignore (added) * cpukit/libnetworking/rtems/.cvsignore (added) * cpukit/libnetworking/sys/.cvsignore (added) * cpukit/libnetworking/vm/.cvsignore (added) * cpukit/libnetworking/wrapup/.cvsignore (added) * cpukit/librpc/.cvsignore (added) * cpukit/librpc/include/.cvsignore (added) * cpukit/librpc/include/rpc/.cvsignore (added) * cpukit/librpc/src/.cvsignore (added) * cpukit/posix/.cvsignore (added) * cpukit/posix/include/.cvsignore (added) * cpukit/posix/include/rtems/.cvsignore (added) * cpukit/posix/include/rtems/posix/.cvsignore (added) * cpukit/posix/inline/.cvsignore (added) * cpukit/posix/inline/rtems/.cvsignore (added) * cpukit/posix/inline/rtems/posix/.cvsignore (added) * cpukit/posix/macros/.cvsignore (added) * cpukit/posix/macros/rtems/.cvsignore (added) * cpukit/posix/macros/rtems/posix/.cvsignore (added) * cpukit/posix/src/.cvsignore (added) * cpukit/rtems/.cvsignore (added) * cpukit/rtems/include/.cvsignore (added) * cpukit/rtems/include/rtems/.cvsignore (added) * cpukit/rtems/include/rtems/rtems/.cvsignore (added) * cpukit/rtems/inline/.cvsignore (added) * cpukit/rtems/inline/rtems/.cvsignore (added) * cpukit/rtems/inline/rtems/rtems/.cvsignore (added) * cpukit/rtems/macros/.cvsignore (added) * cpukit/rtems/macros/rtems/.cvsignore (added) * cpukit/rtems/macros/rtems/rtems/.cvsignore (added) * cpukit/rtems/src/.cvsignore (added) * cpukit/sapi/.cvsignore (added) * cpukit/sapi/include/.cvsignore (added) * cpukit/sapi/include/rtems/.cvsignore (added) * cpukit/sapi/inline/.cvsignore (added) * cpukit/sapi/inline/rtems/.cvsignore (added) * cpukit/sapi/macros/.cvsignore (added) * cpukit/sapi/macros/rtems/.cvsignore (added) * cpukit/sapi/src/.cvsignore (added) * cpukit/score/cpu/a29k/.cvsignore (added) * cpukit/score/cpu/a29k/rtems/.cvsignore (added) * cpukit/score/cpu/a29k/rtems/score/.cvsignore (added) * cpukit/score/cpu/hppa1.1/.cvsignore (added) * cpukit/score/cpu/hppa1.1/rtems/.cvsignore (added) * cpukit/score/cpu/hppa1.1/rtems/score/.cvsignore (added) * cpukit/score/cpu/i386/.cvsignore (added) * cpukit/score/cpu/i386/rtems/.cvsignore (added) * cpukit/score/cpu/i386/rtems/score/.cvsignore (added) * cpukit/score/cpu/i960/.cvsignore (added) * cpukit/score/cpu/i960/rtems/.cvsignore (added) * cpukit/score/cpu/i960/rtems/score/.cvsignore (added) * cpukit/score/cpu/m68k/.cvsignore (added) * cpukit/score/cpu/m68k/rtems/.cvsignore (added) * cpukit/score/cpu/m68k/rtems/score/.cvsignore (added) * cpukit/score/cpu/mips/.cvsignore (added) * cpukit/score/cpu/mips/rtems/.cvsignore (added) * cpukit/score/cpu/mips/rtems/score/.cvsignore (added) * cpukit/score/cpu/mips64orion/.cvsignore (added) * cpukit/score/cpu/mips64orion/rtems/.cvsignore (added) * cpukit/score/cpu/mips64orion/rtems/score/.cvsignore (added) * cpukit/score/cpu/no_cpu/.cvsignore (added) * cpukit/score/cpu/no_cpu/rtems/.cvsignore (added) * cpukit/score/cpu/no_cpu/rtems/score/.cvsignore (added) * doc/.cvsignore (added) * make/.cvsignore (added) * make/Templates/.cvsignore (added) * make/compilers/.cvsignore (added) * make/custom/.cvsignore (added) * scripts-ada/.cvsignore (added) * scripts-ada/binutils/.cvsignore (added) * scripts-ada/gdb/.cvsignore (added) * scripts-ada/gnatnewlib/.cvsignore (added) * scripts/.cvsignore (added) * scripts/binutils/.cvsignore (added) * scripts/gccnewlib/.cvsignore (added) * scripts/gdb/.cvsignore (added) * scripts/rtems/.cvsignore (added) * testsuites/.cvsignore (added) * testsuites/itrontests/.cvsignore (added) * testsuites/itrontests/itronhello/.cvsignore (added) * testsuites/itrontests/itronmbf01/.cvsignore (added) * testsuites/itrontests/itronmbox01/.cvsignore (added) * testsuites/itrontests/itronsem01/.cvsignore (added) * testsuites/itrontests/itrontask01/.cvsignore (added) * testsuites/itrontests/itrontask02/.cvsignore (added) * testsuites/itrontests/itrontask03/.cvsignore (added) * testsuites/itrontests/itrontask04/.cvsignore (added) * testsuites/itrontests/itrontime01/.cvsignore (added) * testsuites/libtests/.cvsignore (added) * testsuites/libtests/cpuuse/.cvsignore (added) * testsuites/libtests/malloctest/.cvsignore (added) * testsuites/libtests/monitor/.cvsignore (added) * testsuites/libtests/putenvtest/.cvsignore (added) * testsuites/libtests/rtems++/.cvsignore (added) * testsuites/libtests/rtmonuse/.cvsignore (added) * testsuites/libtests/stackchk/.cvsignore (added) * testsuites/libtests/termios/.cvsignore (added) * testsuites/mptests/.cvsignore (added) * testsuites/mptests/mp01/.cvsignore (added) * testsuites/mptests/mp01/node1/.cvsignore (added) * testsuites/mptests/mp01/node2/.cvsignore (added) * testsuites/mptests/mp02/.cvsignore (added) * testsuites/mptests/mp02/node1/.cvsignore (added) * testsuites/mptests/mp02/node2/.cvsignore (added) * testsuites/mptests/mp03/.cvsignore (added) * testsuites/mptests/mp03/node1/.cvsignore (added) * testsuites/mptests/mp03/node2/.cvsignore (added) * testsuites/mptests/mp04/.cvsignore (added) * testsuites/mptests/mp04/node1/.cvsignore (added) * testsuites/mptests/mp04/node2/.cvsignore (added) * testsuites/mptests/mp05/.cvsignore (added) * testsuites/mptests/mp05/node1/.cvsignore (added) * testsuites/mptests/mp05/node2/.cvsignore (added) * testsuites/mptests/mp06/.cvsignore (added) * testsuites/mptests/mp06/node1/.cvsignore (added) * testsuites/mptests/mp06/node2/.cvsignore (added) * testsuites/mptests/mp07/.cvsignore (added) * testsuites/mptests/mp07/node1/.cvsignore (added) * testsuites/mptests/mp07/node2/.cvsignore (added) * testsuites/mptests/mp08/.cvsignore (added) * testsuites/mptests/mp08/node1/.cvsignore (added) * testsuites/mptests/mp08/node2/.cvsignore (added) * testsuites/mptests/mp09/.cvsignore (added) * testsuites/mptests/mp09/node1/.cvsignore (added) * testsuites/mptests/mp09/node2/.cvsignore (added) * testsuites/mptests/mp10/.cvsignore (added) * testsuites/mptests/mp10/node1/.cvsignore (added) * testsuites/mptests/mp10/node2/.cvsignore (added) * testsuites/mptests/mp11/.cvsignore (added) * testsuites/mptests/mp11/node1/.cvsignore (added) * testsuites/mptests/mp11/node2/.cvsignore (added) * testsuites/mptests/mp12/.cvsignore (added) * testsuites/mptests/mp12/node1/.cvsignore (added) * testsuites/mptests/mp12/node2/.cvsignore (added) * testsuites/mptests/mp13/.cvsignore (added) * testsuites/mptests/mp13/node1/.cvsignore (added) * testsuites/mptests/mp13/node2/.cvsignore (added) * testsuites/mptests/mp14/.cvsignore (added) * testsuites/mptests/mp14/node1/.cvsignore (added) * testsuites/mptests/mp14/node2/.cvsignore (added) * testsuites/psxtests/.cvsignore (added) * testsuites/psxtests/include/.cvsignore (added) * testsuites/psxtests/psx01/.cvsignore (added) * testsuites/psxtests/psx02/.cvsignore (added) * testsuites/psxtests/psx03/.cvsignore (added) * testsuites/psxtests/psx04/.cvsignore (added) * testsuites/psxtests/psx05/.cvsignore (added) * testsuites/psxtests/psx06/.cvsignore (added) * testsuites/psxtests/psx07/.cvsignore (added) * testsuites/psxtests/psx08/.cvsignore (added) * testsuites/psxtests/psx09/.cvsignore (added) * testsuites/psxtests/psx10/.cvsignore (added) * testsuites/psxtests/psx11/.cvsignore (added) * testsuites/psxtests/psx12/.cvsignore (added) * testsuites/psxtests/psx13/.cvsignore (added) * testsuites/psxtests/psxcancel/.cvsignore (added) * testsuites/psxtests/psxfile01/.cvsignore (added) * testsuites/psxtests/psxhdrs/.cvsignore (added) * testsuites/psxtests/psxmount/.cvsignore (added) * testsuites/psxtests/psxmsgq01/.cvsignore (added) * testsuites/psxtests/psxreaddir/.cvsignore (added) * testsuites/psxtests/psxsem01/.cvsignore (added) * testsuites/psxtests/psxstat/.cvsignore (added) * testsuites/psxtests/psxtime/.cvsignore (added) * testsuites/psxtests/psxtimer/.cvsignore (added) * testsuites/samples/.cvsignore (added) * testsuites/samples/base_mp/.cvsignore (added) * testsuites/samples/base_mp/node1/.cvsignore (added) * testsuites/samples/base_mp/node2/.cvsignore (added) * testsuites/samples/base_sp/.cvsignore (added) * testsuites/samples/cdtest/.cvsignore (added) * testsuites/samples/hello/.cvsignore (added) * testsuites/samples/minimum/.cvsignore (added) * testsuites/samples/paranoia/.cvsignore (added) * testsuites/samples/ticker/.cvsignore (added) * testsuites/samples/unlimited/.cvsignore (added) * testsuites/sptests/.cvsignore (added) * testsuites/sptests/sp01/.cvsignore (added) * testsuites/sptests/sp02/.cvsignore (added) * testsuites/sptests/sp03/.cvsignore (added) * testsuites/sptests/sp04/.cvsignore (added) * testsuites/sptests/sp05/.cvsignore (added) * testsuites/sptests/sp06/.cvsignore (added) * testsuites/sptests/sp07/.cvsignore (added) * testsuites/sptests/sp08/.cvsignore (added) * testsuites/sptests/sp09/.cvsignore (added) * testsuites/sptests/sp11/.cvsignore (added) * testsuites/sptests/sp12/.cvsignore (added) * testsuites/sptests/sp13/.cvsignore (added) * testsuites/sptests/sp14/.cvsignore (added) * testsuites/sptests/sp15/.cvsignore (added) * testsuites/sptests/sp16/.cvsignore (added) * testsuites/sptests/sp17/.cvsignore (added) * testsuites/sptests/sp19/.cvsignore (added) * testsuites/sptests/sp20/.cvsignore (added) * testsuites/sptests/sp21/.cvsignore (added) * testsuites/sptests/sp22/.cvsignore (added) * testsuites/sptests/sp23/.cvsignore (added) * testsuites/sptests/sp24/.cvsignore (added) * testsuites/sptests/sp25/.cvsignore (added) * testsuites/sptests/sp26/.cvsignore (added) * testsuites/sptests/sp27/.cvsignore (added) * testsuites/sptests/sp28/.cvsignore (added) * testsuites/sptests/sp29/.cvsignore (added) * testsuites/sptests/spfatal/.cvsignore (added) * testsuites/sptests/spsize/.cvsignore (added) * testsuites/support/.cvsignore (added) * testsuites/support/include/.cvsignore (added) * testsuites/tmitrontests/.cvsignore (added) * testsuites/tmitrontests/include/.cvsignore (added) * testsuites/tmitrontests/tmitronsem01/.cvsignore (added) * testsuites/tmtests/.cvsignore (added) * testsuites/tmtests/include/.cvsignore (added) * testsuites/tmtests/tm01/.cvsignore (added) * testsuites/tmtests/tm02/.cvsignore (added) * testsuites/tmtests/tm03/.cvsignore (added) * testsuites/tmtests/tm04/.cvsignore (added) * testsuites/tmtests/tm05/.cvsignore (added) * testsuites/tmtests/tm06/.cvsignore (added) * testsuites/tmtests/tm07/.cvsignore (added) * testsuites/tmtests/tm08/.cvsignore (added) * testsuites/tmtests/tm09/.cvsignore (added) * testsuites/tmtests/tm10/.cvsignore (added) * testsuites/tmtests/tm11/.cvsignore (added) * testsuites/tmtests/tm12/.cvsignore (added) * testsuites/tmtests/tm13/.cvsignore (added) * testsuites/tmtests/tm14/.cvsignore (added) * testsuites/tmtests/tm15/.cvsignore (added) * testsuites/tmtests/tm16/.cvsignore (added) * testsuites/tmtests/tm17/.cvsignore (added) * testsuites/tmtests/tm18/.cvsignore (added) * testsuites/tmtests/tm19/.cvsignore (added) * testsuites/tmtests/tm20/.cvsignore (added) * testsuites/tmtests/tm21/.cvsignore (added) * testsuites/tmtests/tm22/.cvsignore (added) * testsuites/tmtests/tm23/.cvsignore (added) * testsuites/tmtests/tm24/.cvsignore (added) * testsuites/tmtests/tm25/.cvsignore (added) * testsuites/tmtests/tm26/.cvsignore (added) * testsuites/tmtests/tm27/.cvsignore (added) * testsuites/tmtests/tm28/.cvsignore (added) * testsuites/tmtests/tm29/.cvsignore (added) * testsuites/tmtests/tmck/.cvsignore (added) * testsuites/tmtests/tmoverhd/.cvsignore (added) * testsuites/tools/.cvsignore (added) * testsuites/tools/generic/.cvsignore (added) * tools/.cvsignore (added) * tools/build/.cvsignore (added) * tools/cpu/.cvsignore (added) * tools/cpu/generic/.cvsignore (added) * tools/cpu/hppa1.1/.cvsignore (added) * tools/cpu/sh/.cvsignore (added) * tools/cpu/unix/.cvsignore (added) * tools/update/.cvsignore (added) Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius [70810dc] * aclocal/canonicalize-tools.m4 (modified) * aclocal/gcc-pipe.m4 (modified) * aclocal/prog-cc.m4 (modified) * aclocal/prog-cxx.m4 (modified) * aclocal/project-root.m4 (modified) * c/configure.in (modified) * c/make/Makefile.am (modified) * c/make/configure.in (modified) * c/src/configure.in (modified) * c/src/exec/configure.in (modified) * c/src/exec/itron/configure.in (modified) * c/src/exec/itron/src/Makefile.am (modified) * c/src/exec/libcsupport/src/Makefile.am (modified) * c/src/exec/posix/configure.in (modified) * c/src/exec/posix/src/Makefile.am (modified) * c/src/exec/rtems/src/Makefile.am (modified) * c/src/exec/sapi/src/Makefile.am (modified) * c/src/exec/score/cpu/a29k/configure.in (modified) * c/src/exec/score/cpu/hppa1.1/configure.in (modified) * c/src/exec/score/cpu/i386/configure.in (modified) * c/src/exec/score/cpu/i960/configure.in (modified) * c/src/exec/score/cpu/m68k/configure.in (modified) * c/src/exec/score/cpu/mips/configure.in (modified) * c/src/exec/score/cpu/mips64orion/configure.in (modified) * c/src/exec/score/cpu/no_cpu/configure.in (modified) * c/src/exec/score/cpu/powerpc/configure.in (modified) * c/src/exec/score/cpu/sh/configure.in (modified) * c/src/exec/score/cpu/sparc/configure.in (modified) * c/src/exec/score/cpu/unix/configure.in (modified) * c/src/exec/score/src/Makefile.am (modified) * c/src/lib/configure.in (modified) * c/src/lib/libbsp/a29k/configure.in (modified) * c/src/lib/libbsp/a29k/portsw/configure.in (modified) * c/src/lib/libbsp/bare/configure.in (modified) * c/src/lib/libbsp/configure.in (modified) * c/src/lib/libbsp/hppa1.1/configure.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/configure.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure.in (modified) * c/src/lib/libbsp/i386/configure.in (modified) * c/src/lib/libbsp/i386/i386ex/configure.in (modified) * c/src/lib/libbsp/i386/pc386/configure.in (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.in (modified) * c/src/lib/libbsp/i386/ts_386ex/configure.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/configure.in (modified) * c/src/lib/libbsp/i960/configure.in (modified) * c/src/lib/libbsp/i960/cvme961/configure.in (modified) * c/src/lib/libbsp/i960/rxgen960/configure.in (modified) * c/src/lib/libbsp/i960/rxgen960/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/configure.in (modified) * c/src/lib/libbsp/m68k/dmv152/configure.in (modified) * c/src/lib/libbsp/m68k/efi332/configure.in (modified) * c/src/lib/libbsp/m68k/efi68k/configure.in (modified) * c/src/lib/libbsp/m68k/gen68302/configure.in (modified) * c/src/lib/libbsp/m68k/gen68340/configure.in (modified) * c/src/lib/libbsp/m68k/gen68360/configure.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.am (modified) * c/src/lib/libbsp/m68k/idp/configure.in (modified) * c/src/lib/libbsp/m68k/mvme136/configure.in (modified) * c/src/lib/libbsp/m68k/mvme147/configure.in (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.in (modified) * c/src/lib/libbsp/m68k/mvme162/configure.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.in (modified) * c/src/lib/libbsp/m68k/mvme167/configure.in (modified) * c/src/lib/libbsp/m68k/ods68302/configure.in (modified) * c/src/lib/libbsp/mips/configure.in (modified) * c/src/lib/libbsp/mips/p4000/configure.in (modified) * c/src/lib/libbsp/mips64orion/configure.in (modified) * c/src/lib/libbsp/mips64orion/p4000/configure.in (modified) * c/src/lib/libbsp/no_cpu/configure.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.in (modified) * c/src/lib/libbsp/powerpc/configure.in (modified) * c/src/lib/libbsp/powerpc/dmv177/configure.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/configure.in (modified) * c/src/lib/libbsp/powerpc/helas403/configure.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.in (modified) * c/src/lib/libbsp/powerpc/papyrus/configure.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/configure.in (modified) * c/src/lib/libbsp/powerpc/psim/configure.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure.in (modified) * c/src/lib/libbsp/powerpc/score603e/configure.in (modified) * c/src/lib/libbsp/sh/configure.in (modified) * c/src/lib/libbsp/sh/gensh1/configure.in (modified) * c/src/lib/libbsp/sh/gensh2/configure.in (modified) * c/src/lib/libbsp/sparc/configure.in (modified) * c/src/lib/libbsp/sparc/erc32/configure.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure.in (modified) * c/src/lib/libbsp/unix/configure.in (modified) * c/src/lib/libbsp/unix/posix/configure.in (modified) * c/src/lib/libbsp/unix/posix/tools/configure.in (modified) * c/src/lib/libc/Makefile.am (modified) * c/src/lib/libcpu/a29k/clock/Makefile.am (modified) * c/src/lib/libcpu/a29k/configure.in (modified) * c/src/lib/libcpu/a29k/timer/Makefile.am (modified) * c/src/lib/libcpu/configure.in (modified) * c/src/lib/libcpu/hppa1.1/configure.in (modified) * c/src/lib/libcpu/i386/configure.in (modified) * c/src/lib/libcpu/m68k/configure.in (modified) * c/src/lib/libcpu/mips/configure.in (modified) * c/src/lib/libcpu/mips64orion/configure.in (modified) * c/src/lib/libcpu/powerpc/configure.in (modified) * c/src/lib/libcpu/sh/configure.in (modified) * c/src/lib/libcpu/sparc/configure.in (modified) * c/src/libchip/configure.in (modified) * c/src/libchip/network/Makefile.am (modified) * c/src/libchip/rtc/Makefile.am (modified) * c/src/libchip/serial/Makefile.am (modified) * c/src/libmisc/configure.in (modified) * c/src/libmisc/cpuuse/Makefile.am (modified) * c/src/libmisc/monitor/Makefile.am (modified) * c/src/libmisc/rtmonuse/Makefile.am (modified) * c/src/libmisc/stackchk/Makefile.am (modified) * c/src/libmisc/untar/Makefile.am (modified) * c/src/libmisc/wrapup/Makefile.am (modified) * c/src/libnetworking/configure.in (modified) * c/src/librdbg/configure.in (modified) * c/src/librdbg/include/Makefile.am (modified) * c/src/librdbg/src/Makefile.am (modified) * c/src/librdbg/src/i386/Makefile.am (modified) * c/src/librdbg/src/powerpc/Makefile.am (modified) * c/src/librpc/configure.in (modified) * c/src/librtems++/configure.in (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/configure.in (modified) * c/src/make/lib.cfg (modified) * c/src/tests/configure.in (modified) * c/src/tests/itrontests/configure.in (modified) * c/src/tests/libtests/configure.in (modified) * c/src/tests/mptests/configure.in (modified) * c/src/tests/psxtests/configure.in (modified) * c/src/tests/samples/configure.in (modified) * c/src/tests/samples/hello/Makefile.am (modified) * c/src/tests/samples/ticker/Makefile.am (modified) * c/src/tests/sptests/configure.in (modified) * c/src/tests/support/configure.in (modified) * c/src/tests/tmitrontests/configure.in (modified) * c/src/tests/tmtests/configure.in (modified) * c/src/tests/tools/configure.in (modified) * c/src/tests/tools/generic/configure.in (modified) * configure.in (modified) * cpukit/itron/src/Makefile.am (modified) * cpukit/libmisc/cpuuse/Makefile.am (modified) * cpukit/libmisc/monitor/Makefile.am (modified) * cpukit/libmisc/rtmonuse/Makefile.am (modified) * cpukit/libmisc/stackchk/Makefile.am (modified) * cpukit/libmisc/untar/Makefile.am (modified) * cpukit/libmisc/wrapup/Makefile.am (modified) * cpukit/posix/src/Makefile.am (modified) * cpukit/rtems/src/Makefile.am (modified) * cpukit/sapi/src/Makefile.am (modified) * cpukit/score/src/Makefile.am (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/gen68360.cfg (modified) * make/lib.cfg (modified) * scripts-ada/configure.in (modified) * scripts/configure.in (modified) * testsuites/samples/hello/Makefile.am (modified) * testsuites/samples/ticker/Makefile.am (modified) * tools/build/configure.in (modified) * tools/cpu/configure.in (modified) * tools/cpu/generic/configure.in (modified) * tools/cpu/hppa1.1/configure.in (modified) * tools/cpu/sh/configure.in (modified) * tools/cpu/unix/configure.in (modified) * tools/update/cipolish (modified) * tools/update/configure.in (modified) Patches rtems-rc-20000204-0.diff from Ralf Corsepius [9f4868c] * Makefile.am (modified) * aclocal/enable-itron.m4 (modified) * aclocal/enable-networking.m4 (modified) * aclocal/enable-posix.m4 (modified) * c/src/exec/librpc/include/rpc/Makefile.am (modified) * c/src/libchip/network/Makefile.am (modified) * c/src/libchip/rtc/Makefile.am (modified) * c/src/libchip/serial/Makefile.am (modified) * c/src/libnetworking/include/Makefile.in (modified) * c/src/libnetworking/rtems_webserver/Makefile.in (modified) * c/src/libnetworking/wrapup/Makefile.in (modified) * c/src/librdbg/src/i386/Makefile.am (modified) * c/src/librdbg/src/i386/any/Makefile.in (modified) * c/src/librdbg/src/i386/pc386/Makefile.in (modified) * c/src/librpc/include/rpc/Makefile.am (modified) * c/src/librpc/src/Makefile.in (modified) * c/src/librtems++/src/Makefile.in (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/tests/psxtests/Makefile.am (modified) * c/src/tests/psxtests/configure.in (modified) * c/src/tests/support/stubdr/Makefile.in (modified) * c/src/wrapup/Makefile.in (modified) * cpukit/httpd/Makefile.in (modified) * cpukit/librpc/include/rpc/Makefile.am (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/pc386.cfg (modified) * testsuites/psxtests/Makefile.am (modified) * tools/update/acpolish (modified) * tools/update/ampolish (modified) Miscellaneous patches from Ralf Corsepius ... Mon, 22 Nov 1999 13:41:11 GMT Joel Sherrill [9608320] * aclocal/check-cpu.m4 (modified) * aclocal/check-multiprocessing.m4 (modified) * aclocal/check-networking.m4 (modified) * aclocal/check-posix.m4 (modified) * aclocal/enable-rtemsbsp.m4 (modified) * automake/local.am (modified) * c/src/Makefile.am (modified) * c/src/exec/configure.in (modified) * c/src/exec/itron/include/Makefile.am (modified) * c/src/exec/itron/include/itronsys/Makefile.am (modified) * c/src/exec/itron/include/rtems/itron/Makefile.am (modified) * c/src/exec/itron/inline/rtems/itron/Makefile.am (modified) * c/src/exec/librpc/include/rpc/Makefile.am (modified) * c/src/exec/posix/configure.in (modified) * c/src/exec/posix/include/Makefile.am (modified) * c/src/exec/posix/include/rtems/posix/Makefile.am (modified) * c/src/exec/posix/include/sys/Makefile.am (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.am (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.am (modified) * c/src/exec/rtems/include/Makefile.am (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.am (modified) * c/src/exec/sapi/include/Makefile.am (modified) * c/src/exec/sapi/include/rtems/Makefile.am (modified) * c/src/exec/sapi/inline/rtems/Makefile.am (modified) * c/src/exec/sapi/macros/rtems/Makefile.am (modified) * c/src/exec/score/cpu/Makefile.in (modified) * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/Makefile.in (modified) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/sh/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/Makefile.in (modified) * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/Makefile.in (modified) * c/src/exec/score/include/rtems/Makefile.am (modified) * c/src/exec/score/inline/rtems/score/Makefile.am (modified) * c/src/exec/score/macros/rtems/score/Makefile.am (modified) * c/src/lib/include/Makefile.am (modified) * c/src/lib/include/motorola/Makefile.am (modified) * c/src/lib/include/sys/Makefile.am (modified) * c/src/lib/include/zilog/Makefile.am (modified) * c/src/lib/libbsp/Makefile.in (modified) * c/src/lib/libbsp/a29k/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.in (modified) * c/src/lib/libbsp/bare/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (modified) * c/src/lib/libbsp/i386/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/Makefile.in (modified) * c/src/lib/libbsp/i960/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.in (modified) * c/src/lib/libbsp/i960/rxgen960/Makefile.in (modified) * c/src/lib/libbsp/m68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.in (modified) * c/src/lib/libbsp/powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mvme2307/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.in (modified) * c/src/lib/libbsp/sh/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh2/Makefile.in (modified) * c/src/lib/libbsp/sparc/Makefile.in (modified) * c/src/lib/libbsp/unix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/Makefile.in (modified) * c/src/lib/libcpu/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/Makefile.in (modified) * c/src/lib/libcpu/m68k/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/Makefile.in (modified) * c/src/lib/libcpu/powerpc/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc505/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.in (modified) * c/src/lib/libcpu/sh/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7045/Makefile.in (modified) * c/src/lib/libcpu/sparc/Makefile.in (modified) * c/src/libchip/network/Makefile.am (added) * c/src/libchip/network/Makefile.in (deleted) * c/src/libchip/rtc/Makefile.am (added) * c/src/libchip/rtc/Makefile.in (deleted) * c/src/libchip/serial/Makefile.am (added) * c/src/libchip/serial/Makefile.in (deleted) * c/src/libmisc/configure.in (modified) * c/src/libmisc/cpuuse/Makefile.am (added) * c/src/libmisc/cpuuse/Makefile.in (deleted) * c/src/libmisc/dummy/Makefile.am (added) * c/src/libmisc/dummy/Makefile.in (deleted) * c/src/libmisc/dumpbuf/Makefile.am (added) * c/src/libmisc/dumpbuf/Makefile.in (deleted) * c/src/libmisc/monitor/Makefile.am (added) * c/src/libmisc/monitor/Makefile.in (deleted) * c/src/libmisc/rtmonuse/Makefile.am (added) * c/src/libmisc/rtmonuse/Makefile.in (deleted) * c/src/libmisc/stackchk/Makefile.am (added) * c/src/libmisc/stackchk/Makefile.in (deleted) * c/src/libmisc/untar/Makefile.am (added) * c/src/libmisc/untar/Makefile.in (deleted) * c/src/libmisc/wrapup/Makefile.am (added) * c/src/libmisc/wrapup/Makefile.in (deleted) * c/src/librdbg/include/rdbg/Makefile.am (modified) * c/src/librdbg/include/rdbg/i386/Makefile.am (modified) * c/src/librdbg/include/rdbg/powerpc/Makefile.am (modified) * c/src/librpc/include/rpc/Makefile.am (modified) * c/src/librtems++/include/rtems++/Makefile.am (modified) * c/src/make/README (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/directory.cfg (modified) * c/src/make/lib.cfg (modified) * c/src/make/main.cfg.in (modified) * c/src/tests/mptests/mp01/Makefile.in (modified) * c/src/tests/mptests/mp02/Makefile.in (modified) * c/src/tests/mptests/mp03/Makefile.in (modified) * c/src/tests/mptests/mp04/Makefile.in (modified) * c/src/tests/mptests/mp05/Makefile.in (modified) * c/src/tests/mptests/mp06/Makefile.in (modified) * c/src/tests/mptests/mp07/Makefile.in (modified) * c/src/tests/mptests/mp08/Makefile.in (modified) * c/src/tests/mptests/mp09/Makefile.in (modified) * c/src/tests/mptests/mp10/Makefile.in (modified) * c/src/tests/mptests/mp11/Makefile.in (modified) * c/src/tests/mptests/mp12/Makefile.in (modified) * c/src/tests/mptests/mp13/Makefile.in (modified) * c/src/tests/mptests/mp14/Makefile.in (modified) * c/src/tests/psxtests/support/Makefile.in (modified) * c/src/tests/samples/base_mp/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.am (modified) * cpukit/itron/include/Makefile.am (modified) * cpukit/libmisc/cpuuse/Makefile.am (added) * cpukit/libmisc/dummy/Makefile.am (added) * cpukit/libmisc/dumpbuf/Makefile.am (added) * cpukit/libmisc/monitor/Makefile.am (added) * cpukit/libmisc/rtmonuse/Makefile.am (added) * cpukit/libmisc/stackchk/Makefile.am (added) * cpukit/libmisc/untar/Makefile.am (added) * cpukit/libmisc/wrapup/Makefile.am (added) * cpukit/librpc/include/rpc/Makefile.am (modified) * cpukit/posix/include/Makefile.am (modified) * cpukit/rtems/include/Makefile.am (modified) * cpukit/sapi/include/Makefile.am (modified) * make/README (modified) * make/Templates/Makefile.dir (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/erc32.cfg (modified) * make/directory.cfg (modified) * make/lib.cfg (modified) * make/main.cfg (modified) * testsuites/tools/generic/Makefile.am (modified) Patch rtems-rc-19991117-4.diff from Ralf Corsepius [d6c83529] * Makefile.am (modified) * bootstrap (moved) * c/Makefile.am (modified) * c/configure.in (modified) * c/make/Makefile.am (added) * c/make/configure.in (added) * c/make/target.cfg.in (moved) * c/src/make/Makefile.am (modified) * c/src/make/bsp.cfg.in (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/configure.in (modified) * c/src/make/custom/default.cfg.in (modified) * c/src/make/main.cfg.in (modified) * c/src/tests/samples/cdtest/Makefile.in (modified) * c/src/tests/samples/paranoia/Makefile.in (modified) * make/Makefile.am (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/bare.cfg (modified) * make/custom/default.cfg (modified) * make/custom/gen68360.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/ods68302.cfg (modified) * make/leaf.cfg (modified) * make/main.cfg (modified) Patch rtems-rc-19991105-1.diff.gz from Ralf Corsepius ... Tue, 26 Oct 1999 14:22:55 GMT Joel Sherrill [65a60cd] * c/src/make/README (modified) * c/src/make/compilers/Makefile.am (modified) * c/src/make/compilers/gcc.cfg.in (deleted) * c/src/make/configure.in (modified) * make/README (modified) * make/compilers/Makefile.am (modified) * make/compilers/gcc.cfg.in (deleted) * make/custom/HPUX9-posix.cfg (modified) * make/custom/default.cfg (modified) * make/leaf.cfg (modified) Removed all references to HOST_ARCH including the file gcc.cfg.in. ... Mon, 04 Oct 1999 19:15:14 GMT Joel Sherrill [811804fe] * Makefile.am (modified) * c/Makefile.am (modified) * c/src/Makefile.am (modified) * c/src/exec/Makefile.am (modified) * c/src/exec/libcsupport/Makefile.am (modified) * c/src/exec/libnetworking/Makefile.am (modified) * c/src/exec/librpc/include/rpc/Makefile.am (modified) * c/src/exec/posix/Makefile.am (modified) * c/src/exec/posix/include/Makefile.am (modified) * c/src/exec/posix/include/rtems/Makefile.am (modified) * c/src/exec/posix/include/rtems/posix/Makefile.am (modified) * c/src/exec/posix/include/sys/Makefile.am (modified) * c/src/exec/posix/inline/Makefile.am (modified) * c/src/exec/posix/inline/rtems/Makefile.am (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.am (modified) * c/src/exec/posix/macros/Makefile.am (modified) * c/src/exec/posix/macros/rtems/Makefile.am (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.am (modified) * c/src/exec/rtems/Makefile.am (modified) * c/src/exec/rtems/include/Makefile.am (modified) * c/src/exec/rtems/include/rtems/Makefile.am (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/inline/Makefile.am (modified) * c/src/exec/rtems/inline/rtems/Makefile.am (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.am (modified) * c/src/exec/rtems/macros/Makefile.am (modified) * c/src/exec/rtems/macros/rtems/Makefile.am (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.am (modified) * c/src/exec/sapi/Makefile.am (modified) * c/src/exec/sapi/include/Makefile.am (modified) * c/src/exec/sapi/include/rtems/Makefile.am (modified) * c/src/exec/sapi/inline/Makefile.am (modified) * c/src/exec/sapi/inline/rtems/Makefile.am (modified) * c/src/exec/sapi/macros/Makefile.am (modified) * c/src/exec/sapi/macros/rtems/Makefile.am (modified) * c/src/exec/score/Makefile.am (modified) * c/src/exec/score/include/Makefile.am (modified) * c/src/exec/score/include/rtems/Makefile.am (modified) * c/src/exec/score/inline/Makefile.am (modified) * c/src/exec/score/inline/rtems/Makefile.am (modified) * c/src/exec/score/inline/rtems/score/Makefile.am (modified) * c/src/exec/score/macros/Makefile.am (modified) * c/src/exec/score/macros/rtems/Makefile.am (modified) * c/src/exec/score/macros/rtems/score/Makefile.am (modified) * c/src/exec/wrapup/Makefile.am (modified) * c/src/lib/Makefile.am (modified) * c/src/lib/include/motorola/Makefile.am (modified) * c/src/lib/include/rdbg/Makefile.am (modified) * c/src/lib/include/rdbg/i386/Makefile.am (modified) * c/src/lib/include/rdbg/powerpc/Makefile.am (modified) * c/src/lib/include/rpc/Makefile.am (modified) * c/src/lib/include/sys/Makefile.am (modified) * c/src/lib/include/zilog/Makefile.am (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/Makefile.am (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.am (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.am (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.am (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.am (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.am (modified) * c/src/lib/libchip/Makefile.am (modified) * c/src/lib/libmisc/Makefile.am (modified) * c/src/lib/start/Makefile.am (modified) * c/src/libchip/Makefile.am (modified) * c/src/libmisc/Makefile.am (modified) * c/src/libnetworking/Makefile.am (modified) * c/src/librdbg/include/rdbg/Makefile.am (modified) * c/src/librdbg/include/rdbg/i386/Makefile.am (modified) * c/src/librdbg/include/rdbg/powerpc/Makefile.am (modified) * c/src/librpc/include/rpc/Makefile.am (modified) * c/src/make/Makefile.am (modified) * c/src/make/compilers/Makefile.am (modified) * c/src/make/custom/Makefile.am (modified) * c/src/tests/Makefile.am (modified) * c/src/tests/libtests/Makefile.am (modified) * c/src/tests/mptests/Makefile.am (modified) * c/src/tests/psxtests/Makefile.am (modified) * c/src/tests/samples/Makefile.am (modified) * c/src/tests/sptests/Makefile.am (modified) * c/src/tests/support/Makefile.am (modified) * c/src/tests/support/include/Makefile.am (modified) * c/src/tests/tmtests/Makefile.am (modified) * c/src/tests/tmtests/include/Makefile.am (modified) * c/src/tests/tools/Makefile.am (modified) * c/src/tests/tools/generic/Makefile.am (modified) * cpukit/Makefile.am (modified) * cpukit/libcsupport/Makefile.am (modified) * cpukit/libmisc/Makefile.am (modified) * cpukit/libnetworking/Makefile.am (modified) * cpukit/librpc/include/rpc/Makefile.am (modified) * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/Makefile.am (modified) * cpukit/posix/inline/Makefile.am (modified) * cpukit/posix/macros/Makefile.am (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/Makefile.am (modified) * cpukit/rtems/inline/Makefile.am (modified) * cpukit/rtems/macros/Makefile.am (modified) * cpukit/sapi/Makefile.am (modified) * cpukit/sapi/include/Makefile.am (modified) * cpukit/sapi/inline/Makefile.am (modified) * cpukit/sapi/macros/Makefile.am (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/Makefile.am (modified) * cpukit/score/inline/Makefile.am (modified) * cpukit/score/macros/Makefile.am (modified) * cpukit/wrapup/Makefile.am (modified) * make/Makefile.am (modified) * make/Templates/Makefile.am (modified) * make/compilers/Makefile.am (modified) * make/custom/Makefile.am (modified) * testsuites/Makefile.am (modified) * testsuites/libtests/Makefile.am (modified) * testsuites/mptests/Makefile.am (modified) * testsuites/psxtests/Makefile.am (modified) * testsuites/samples/Makefile.am (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/support/Makefile.am (modified) * testsuites/tmtests/Makefile.am (modified) * testsuites/tmtests/include/Makefile.am (modified) * testsuites/tools/Makefile.am (modified) * testsuites/tools/generic/Makefile.am (modified) * tools/build/Makefile.am (modified) * tools/cpu/Makefile.am (modified) * tools/cpu/generic/Makefile.am (modified) * tools/cpu/hppa1.1/Makefile.am (modified) * tools/cpu/sh/Makefile.am (modified) * tools/cpu/unix/Makefile.am (modified) * tools/update/Makefile.am (modified) Patch from Ralf Corsepius to make fix bug ... Mon, 04 Oct 1999 17:33:23 GMT Joel Sherrill [4f021c0] * Makefile.in (deleted) * c/Makefile.in (deleted) * c/src/Makefile.in (deleted) * c/src/exec/Makefile.in (deleted) * c/src/exec/posix/Makefile.in (deleted) * c/src/exec/posix/include/Makefile.in (deleted) * c/src/exec/posix/include/rtems/Makefile.in (deleted) * c/src/exec/posix/include/rtems/posix/Makefile.in (deleted) * c/src/exec/posix/include/sys/Makefile.in (deleted) * c/src/exec/posix/inline/Makefile.in (deleted) * c/src/exec/posix/inline/rtems/Makefile.in (deleted) * c/src/exec/posix/inline/rtems/posix/Makefile.in (deleted) * c/src/exec/posix/macros/Makefile.in (deleted) * c/src/exec/posix/macros/rtems/Makefile.in (deleted) * c/src/exec/posix/macros/rtems/posix/Makefile.in (deleted) * c/src/exec/rtems/Makefile.in (deleted) * c/src/exec/rtems/include/Makefile.in (deleted) * c/src/exec/rtems/include/rtems/Makefile.in (deleted) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (deleted) * c/src/exec/rtems/inline/Makefile.in (deleted) * c/src/exec/rtems/inline/rtems/Makefile.in (deleted) * c/src/exec/rtems/inline/rtems/rtems/Makefile.in (deleted) * c/src/exec/rtems/macros/Makefile.in (deleted) * c/src/exec/rtems/macros/rtems/Makefile.in (deleted) * c/src/exec/rtems/macros/rtems/rtems/Makefile.in (deleted) * c/src/exec/sapi/Makefile.in (deleted) * c/src/exec/sapi/include/Makefile.in (deleted) * c/src/exec/sapi/include/rtems/Makefile.in (deleted) * c/src/exec/sapi/inline/Makefile.in (deleted) * c/src/exec/sapi/inline/rtems/Makefile.in (deleted) * c/src/exec/sapi/macros/Makefile.in (deleted) * c/src/exec/sapi/macros/rtems/Makefile.in (deleted) * c/src/exec/score/Makefile.in (deleted) * c/src/exec/score/include/Makefile.in (deleted) * c/src/exec/score/include/rtems/Makefile.in (deleted) * c/src/exec/score/inline/Makefile.in (deleted) * c/src/exec/score/inline/rtems/Makefile.in (deleted) * c/src/exec/score/inline/rtems/score/Makefile.in (deleted) * c/src/exec/score/macros/Makefile.in (deleted) * c/src/exec/score/macros/rtems/Makefile.in (deleted) * c/src/exec/score/macros/rtems/score/Makefile.in (deleted) * c/src/exec/wrapup/Makefile.in (deleted) * c/src/lib/Makefile.in (deleted) * c/src/lib/include/Makefile.in (deleted) * c/src/lib/include/motorola/Makefile.in (deleted) * c/src/lib/include/rdbg/Makefile.in (deleted) * c/src/lib/include/rdbg/i386/Makefile.in (deleted) * c/src/lib/include/rdbg/powerpc/Makefile.in (deleted) * c/src/lib/include/rpc/Makefile.in (deleted) * c/src/lib/include/sys/Makefile.in (deleted) * c/src/lib/include/zilog/Makefile.in (deleted) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (deleted) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (deleted) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.in (deleted) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/Makefile.in (deleted) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.in (deleted) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.in (deleted) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.in (deleted) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (deleted) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (deleted) * c/src/lib/libchip/Makefile.in (deleted) * c/src/lib/libmisc/Makefile.in (deleted) * c/src/lib/libnetworking/Makefile.in (deleted) * c/src/lib/start/Makefile.in (deleted) * c/src/libnetworking/Makefile.in (deleted) * c/src/librdbg/include/rdbg/Makefile.in (deleted) * c/src/librdbg/include/rdbg/i386/Makefile.in (deleted) * c/src/librdbg/include/rdbg/powerpc/Makefile.in (deleted) * c/src/librtems++/Makefile.in (deleted) * c/src/librtems++/include/Makefile.in (deleted) * c/src/librtems++/include/rtems++/Makefile.in (deleted) * c/src/make/Makefile.in (deleted) * c/src/make/compilers/Makefile.in (deleted) * c/src/make/custom/Makefile.in (deleted) * c/src/tests/Makefile.in (deleted) * c/src/tests/libtests/Makefile.in (deleted) * c/src/tests/mptests/Makefile.in (deleted) * c/src/tests/psxtests/Makefile.in (deleted) * c/src/tests/samples/Makefile.in (deleted) * c/src/tests/sptests/Makefile.in (deleted) * c/src/tests/support/Makefile.in (deleted) * c/src/tests/support/include/Makefile.in (deleted) * c/src/tests/tmtests/Makefile.in (deleted) * c/src/tests/tmtests/include/Makefile.in (deleted) * c/src/tests/tools/Makefile.in (deleted) * c/src/tests/tools/generic/Makefile.in (deleted) * doc/Makefile.in (deleted) * make/Makefile.in (deleted) * make/Templates/Makefile.in (deleted) * make/compilers/Makefile.in (deleted) * make/custom/Makefile.in (deleted) * tools/Makefile.in (deleted) * tools/build/Makefile.in (deleted) * tools/cpu/Makefile.in (deleted) * tools/cpu/generic/Makefile.in (deleted) * tools/cpu/sh/Makefile.in (deleted) * tools/cpu/unix/Makefile.in (deleted) * tools/update/Makefile.in (deleted) Removed Makefile.in generated from Makefile.am Mon, 04 Oct 1999 13:30:15 GMT Joel Sherrill [473b4e5] * Makefile.in (modified) * aclocal.m4 (modified) * c/Makefile.in (modified) * c/aclocal.m4 (modified) * c/configure (modified) * c/src/Makefile.in (modified) * c/src/aclocal.m4 (modified) * c/src/configure (modified) * c/src/exec/Makefile.in (modified) * c/src/exec/aclocal.m4 (modified) * c/src/exec/configure (modified) * c/src/exec/posix/Makefile.in (modified) * c/src/exec/posix/aclocal.m4 (modified) * c/src/exec/posix/configure (modified) * c/src/exec/posix/include/Makefile.in (modified) * c/src/exec/posix/include/rtems/Makefile.in (modified) * c/src/exec/posix/include/rtems/posix/Makefile.in (modified) * c/src/exec/posix/include/sys/Makefile.in (modified) * c/src/exec/posix/inline/Makefile.in (modified) * c/src/exec/posix/inline/rtems/Makefile.in (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.in (modified) * c/src/exec/posix/macros/Makefile.in (modified) * c/src/exec/posix/macros/rtems/Makefile.in (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.in (modified) * c/src/exec/rtems/Makefile.in (modified) * c/src/exec/rtems/include/Makefile.in (modified) * c/src/exec/rtems/include/rtems/Makefile.in (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/inline/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.in (modified) * c/src/exec/sapi/Makefile.in (modified) * c/src/exec/sapi/include/Makefile.in (modified) * c/src/exec/sapi/include/rtems/Makefile.in (modified) * c/src/exec/sapi/inline/Makefile.in (modified) * c/src/exec/sapi/inline/rtems/Makefile.in (modified) * c/src/exec/sapi/macros/Makefile.in (modified) * c/src/exec/sapi/macros/rtems/Makefile.in (modified) * c/src/exec/score/Makefile.in (modified) * c/src/exec/score/cpu/aclocal.m4 (modified) * c/src/exec/score/include/Makefile.in (modified) * c/src/exec/score/include/rtems/Makefile.in (modified) * c/src/exec/score/inline/Makefile.in (modified) * c/src/exec/score/inline/rtems/Makefile.in (modified) * c/src/exec/score/inline/rtems/score/Makefile.in (modified) * c/src/exec/score/macros/Makefile.in (modified) * c/src/exec/score/macros/rtems/Makefile.in (modified) * c/src/exec/score/macros/rtems/score/Makefile.in (modified) * c/src/exec/wrapup/Makefile.in (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/aclocal.m4 (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/include/motorola/Makefile.in (modified) * c/src/lib/include/rdbg/Makefile.in (modified) * c/src/lib/include/rdbg/i386/Makefile.in (modified) * c/src/lib/include/rdbg/powerpc/Makefile.in (modified) * c/src/lib/include/rpc/Makefile.in (modified) * c/src/lib/include/sys/Makefile.in (modified) * c/src/lib/include/zilog/Makefile.in (modified) * c/src/lib/libbsp/aclocal.m4 (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/aclocal.m4 (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/aclocal.m4 (modified) * c/src/lib/libbsp/i386/pc386/tools/configure (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/aclocal.m4 (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/configure (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/aclocal.m4 (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/aclocal.m4 (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/aclocal.m4 (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/aclocal.m4 (modified) * c/src/lib/libbsp/unix/posix/tools/configure (modified) * c/src/lib/libchip/Makefile.in (modified) * c/src/lib/libchip/aclocal.m4 (modified) * c/src/lib/libchip/configure (modified) * c/src/lib/libcpu/aclocal.m4 (modified) * c/src/lib/libmisc/Makefile.in (modified) * c/src/lib/libmisc/aclocal.m4 (modified) * c/src/lib/libmisc/configure (modified) * c/src/lib/libnetworking/Makefile.in (modified) * c/src/lib/libnetworking/aclocal.m4 (modified) * c/src/lib/libnetworking/configure (modified) * c/src/lib/librdbg/aclocal.m4 (modified) * c/src/lib/librdbg/configure (modified) * c/src/lib/librpc/aclocal.m4 (modified) * c/src/lib/start/Makefile.in (modified) * c/src/lib/start/a29k/aclocal.m4 (modified) * c/src/lib/start/i960/aclocal.m4 (modified) * c/src/lib/start/m68k/aclocal.m4 (modified) * c/src/lib/start/mips64orion/aclocal.m4 (modified) * c/src/lib/start/sh/aclocal.m4 (modified) * c/src/libnetworking/Makefile.in (modified) * c/src/libnetworking/aclocal.m4 (modified) * c/src/libnetworking/configure (modified) * c/src/librdbg/include/rdbg/Makefile.in (modified) * c/src/librdbg/include/rdbg/i386/Makefile.in (modified) * c/src/librdbg/include/rdbg/powerpc/Makefile.in (modified) * c/src/librdbg/src/aclocal.m4 (modified) * c/src/librdbg/src/configure (modified) * c/src/librtems++/Makefile.in (modified) * c/src/librtems++/aclocal.m4 (modified) * c/src/librtems++/configure (modified) * c/src/librtems++/include/Makefile.in (modified) * c/src/librtems++/include/rtems++/Makefile.in (modified) * c/src/make/Makefile.in (modified) * c/src/make/aclocal.m4 (modified) * c/src/make/compilers/Makefile.in (modified) * c/src/make/configure (modified) * c/src/make/custom/Makefile.in (modified) * c/src/tests/Makefile.in (modified) * c/src/tests/aclocal.m4 (modified) * c/src/tests/configure (modified) * c/src/tests/libtests/Makefile.in (modified) * c/src/tests/libtests/aclocal.m4 (modified) * c/src/tests/libtests/configure (modified) * c/src/tests/mptests/Makefile.in (modified) * c/src/tests/mptests/aclocal.m4 (modified) * c/src/tests/mptests/configure (modified) * c/src/tests/psxtests/Makefile.in (modified) * c/src/tests/psxtests/aclocal.m4 (modified) * c/src/tests/psxtests/configure (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/tests/samples/aclocal.m4 (modified) * c/src/tests/samples/configure (modified) * c/src/tests/sptests/Makefile.in (modified) * c/src/tests/sptests/aclocal.m4 (modified) * c/src/tests/sptests/configure (modified) * c/src/tests/support/Makefile.in (modified) * c/src/tests/support/aclocal.m4 (modified) * c/src/tests/support/configure (modified) * c/src/tests/support/include/Makefile.in (modified) * c/src/tests/tmtests/Makefile.in (modified) * c/src/tests/tmtests/aclocal.m4 (modified) * c/src/tests/tmtests/configure (modified) * c/src/tests/tmtests/include/Makefile.in (modified) * c/src/tests/tools/Makefile.in (modified) * c/src/tests/tools/aclocal.m4 (modified) * c/src/tests/tools/configure (modified) * c/src/tests/tools/generic/Makefile.in (modified) * c/src/tests/tools/generic/aclocal.m4 (modified) * c/src/tests/tools/generic/configure (modified) * configure (modified) * doc/Makefile.in (modified) * make/Makefile.in (modified) * make/Templates/Makefile.in (modified) * make/compilers/Makefile.in (modified) * make/custom/Makefile.in (modified) * tools/Makefile.in (modified) * tools/build/Makefile.in (modified) * tools/build/aclocal.m4 (modified) * tools/build/configure (modified) * tools/cpu/Makefile.in (modified) * tools/cpu/aclocal.m4 (modified) * tools/cpu/configure (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/generic/aclocal.m4 (modified) * tools/cpu/generic/configure (modified) * tools/cpu/hppa1.1/aclocal.m4 (modified) * tools/cpu/hppa1.1/configure (modified) * tools/cpu/sh/Makefile.in (modified) * tools/cpu/sh/aclocal.m4 (modified) * tools/cpu/sh/configure (modified) * tools/cpu/unix/Makefile.in (modified) * tools/cpu/unix/aclocal.m4 (modified) * tools/cpu/unix/configure (modified) * tools/update/Makefile.in (modified) * tools/update/aclocal.m4 (modified) * tools/update/configure (modified) Regenerated. Tue, 07 Sep 1999 13:45:03 GMT Joel Sherrill [e1d8abb] * Makefile.in (modified) * aclocal/check-cxx.m4 (modified) * automake/local.am (modified) * c/Makefile.in (modified) * c/src/Makefile.am (modified) * c/src/Makefile.in (modified) * c/src/aclocal.m4 (modified) * c/src/configure (modified) * c/src/configure.in (modified) * c/src/exec/Makefile.am (added) * c/src/exec/Makefile.in (modified) * c/src/exec/aclocal.m4 (modified) * c/src/exec/configure (modified) * c/src/exec/configure.in (modified) * c/src/exec/libcsupport/Makefile.am (added) * c/src/exec/libnetworking/Makefile.am (added) * c/src/exec/librpc/include/rpc/Makefile.am (added) * c/src/exec/posix/Makefile.am (added) * c/src/exec/posix/Makefile.in (modified) * c/src/exec/posix/configure.in (added) * c/src/exec/posix/include/Makefile.am (added) * c/src/exec/posix/include/Makefile.in (modified) * c/src/exec/posix/include/rtems/Makefile.am (added) * c/src/exec/posix/include/rtems/Makefile.in (modified) * c/src/exec/posix/include/rtems/posix/Makefile.am (added) * c/src/exec/posix/include/rtems/posix/Makefile.in (modified) * c/src/exec/posix/include/sys/Makefile.am (added) * c/src/exec/posix/include/sys/Makefile.in (modified) * c/src/exec/posix/inline/Makefile.am (added) * c/src/exec/posix/inline/Makefile.in (modified) * c/src/exec/posix/inline/rtems/Makefile.am (added) * c/src/exec/posix/inline/rtems/Makefile.in (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.am (added) * c/src/exec/posix/inline/rtems/posix/Makefile.in (modified) * c/src/exec/posix/macros/Makefile.am (added) * c/src/exec/posix/macros/Makefile.in (modified) * c/src/exec/posix/macros/rtems/Makefile.am (added) * c/src/exec/posix/macros/rtems/Makefile.in (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.am (added) * c/src/exec/posix/macros/rtems/posix/Makefile.in (modified) * c/src/exec/posix/optman/Makefile.in (modified) * c/src/exec/posix/src/Makefile.in (modified) * c/src/exec/rtems/Makefile.am (added) * c/src/exec/rtems/Makefile.in (modified) * c/src/exec/rtems/include/Makefile.am (added) * c/src/exec/rtems/include/Makefile.in (modified) * c/src/exec/rtems/include/rtems/Makefile.am (added) * c/src/exec/rtems/include/rtems/Makefile.in (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.am (added) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/inline/Makefile.am (added) * c/src/exec/rtems/inline/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/Makefile.am (added) * c/src/exec/rtems/inline/rtems/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.am (added) * c/src/exec/rtems/inline/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/Makefile.am (added) * c/src/exec/rtems/macros/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/Makefile.am (added) * c/src/exec/rtems/macros/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.am (added) * c/src/exec/rtems/macros/rtems/rtems/Makefile.in (modified) * c/src/exec/sapi/Makefile.am (added) * c/src/exec/sapi/Makefile.in (modified) * c/src/exec/sapi/include/Makefile.am (added) * c/src/exec/sapi/include/Makefile.in (modified) * c/src/exec/sapi/include/rtems/Makefile.am (added) * c/src/exec/sapi/include/rtems/Makefile.in (modified) * c/src/exec/sapi/inline/Makefile.am (added) * c/src/exec/sapi/inline/Makefile.in (modified) * c/src/exec/sapi/inline/rtems/Makefile.am (added) * c/src/exec/sapi/inline/rtems/Makefile.in (modified) * c/src/exec/sapi/macros/Makefile.am (added) * c/src/exec/sapi/macros/Makefile.in (modified) * c/src/exec/sapi/macros/rtems/Makefile.am (added) * c/src/exec/sapi/macros/rtems/Makefile.in (modified) * c/src/exec/score/Makefile.am (added) * c/src/exec/score/Makefile.in (modified) * c/src/exec/score/cpu/Makefile.in (modified) * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/a29k/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/a29k/wrap/Makefile.in (modified) * c/src/exec/score/cpu/configure.in (added) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/wrap/Makefile.in (modified) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i386/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/i386/wrap/Makefile.in (modified) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/Makefile.in (modified) * c/src/exec/score/cpu/i960/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/i960/wrap/Makefile.in (modified) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/Makefile.in (modified) * c/src/exec/score/cpu/m68k/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/m68k/wrap/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/wrap/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/wrap/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/mpc750/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/other_cpu/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/shared/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/wrap/Makefile.in (modified) * c/src/exec/score/cpu/sh/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sh/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sh/wrap/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/Makefile.in (modified) * c/src/exec/score/cpu/sparc/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/sparc/wrap/Makefile.in (modified) * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/Makefile.in (modified) * c/src/exec/score/cpu/unix/rtems/score/Makefile.in (modified) * c/src/exec/score/cpu/unix/wrap/Makefile.in (modified) * c/src/exec/score/include/Makefile.am (added) * c/src/exec/score/include/Makefile.in (modified) * c/src/exec/score/include/rtems/Makefile.am (added) * c/src/exec/score/include/rtems/Makefile.in (modified) * c/src/exec/score/inline/Makefile.am (added) * c/src/exec/score/inline/Makefile.in (modified) * c/src/exec/score/inline/rtems/Makefile.am (added) * c/src/exec/score/inline/rtems/Makefile.in (modified) * c/src/exec/score/inline/rtems/score/Makefile.am (added) * c/src/exec/score/inline/rtems/score/Makefile.in (modified) * c/src/exec/score/macros/Makefile.am (added) * c/src/exec/score/macros/Makefile.in (modified) * c/src/exec/score/macros/rtems/Makefile.am (added) * c/src/exec/score/macros/rtems/Makefile.in (modified) * c/src/exec/score/macros/rtems/score/Makefile.am (added) * c/src/exec/score/macros/rtems/score/Makefile.in (modified) * c/src/exec/wrapup/Makefile.am (added) * c/src/exec/wrapup/Makefile.in (modified) * c/src/exec/wrapup/posix/Makefile.in (modified) * c/src/lib/Makefile.am (added) * c/src/lib/Makefile.in (modified) * c/src/lib/aclocal.m4 (modified) * c/src/lib/configure (modified) * c/src/lib/configure.in (modified) * c/src/lib/include/Makefile.am (added) * c/src/lib/include/Makefile.in (modified) * c/src/lib/include/motorola/Makefile.am (added) * c/src/lib/include/rdbg/Makefile.am (added) * c/src/lib/include/rdbg/i386/Makefile.am (added) * c/src/lib/include/rdbg/powerpc/Makefile.am (added) * c/src/lib/include/rpc/Makefile.am (added) * c/src/lib/include/sys/Makefile.am (added) * c/src/lib/include/zilog/Makefile.am (added) * c/src/lib/libbsp/Makefile.am.new (added) * c/src/lib/libbsp/Makefile.in (modified) * c/src/lib/libbsp/a29k/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.in (modified) * c/src/lib/libbsp/bare/Makefile.in (modified) * c/src/lib/libbsp/bare/include/Makefile.in (modified) * c/src/lib/libbsp/bare/wrapup/Makefile.in (modified) * c/src/lib/libbsp/configure.in (added) * c/src/lib/libbsp/hppa1.1/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/console/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/include/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/network/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/3c509/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/dec21140/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/ne2000/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wd8003/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/comm/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/io/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/irq/Makefile.in (modified) * c/src/lib/libbsp/i386/shared/pci/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/include/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/network/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/start/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i960/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme167/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/fatal/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/scv64/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/canbus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/bootloader/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/irq/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/openpic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/residual/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/bootloader/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/irq/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/openpic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/residual/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/network/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/nvram/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/pci/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/universe/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startsim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/PCI_bus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/tod/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/score603e/wrapup/Makefile.in (modified) * c/src/lib/libbsp/sh/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/include/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/wrapup/Makefile.in (modified) * c/src/lib/libbsp/shmdr/Makefile.in (modified) * c/src/lib/libbsp/sparc/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/gnatsupp/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startsis/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/unix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.in (modified) * c/src/lib/libchip/Makefile.am (added) * c/src/lib/libchip/Makefile.in (modified) * c/src/lib/libchip/configure.in (added) * c/src/lib/libchip/network/Makefile.in (modified) * c/src/lib/libchip/rtc/Makefile.in (modified) * c/src/lib/libchip/serial/Makefile.in (modified) * c/src/lib/libcpu/Makefile.in (modified) * c/src/lib/libcpu/configure.in (added) * c/src/lib/libcpu/hppa1.1/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/runway/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.in (modified) * c/src/lib/libcpu/i386/Makefile.in (modified) * c/src/lib/libcpu/i386/wrapup/Makefile.in (modified) * c/src/lib/libcpu/m68k/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/include/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc505/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc505/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc505/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/exceptions/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/mmu/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc750/wrapup/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/console-generic/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc821/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/console-generic/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/mpc860/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/shared/Makefile.in (modified) * c/src/lib/libcpu/powerpc/wrapup/Makefile.in (modified) * c/src/lib/libcpu/sh/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/console/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/include/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.in (modified) * c/src/lib/libcpu/sparc/Makefile.in (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.in (modified) * c/src/lib/libcpu/sparc/syscall/Makefile.in (modified) * c/src/lib/libmisc/Makefile.am (added) * c/src/lib/libmisc/Makefile.in (modified) * c/src/lib/libmisc/assoc/Makefile.in (modified) * c/src/lib/libmisc/configure.in (added) * c/src/lib/libmisc/cpuuse/Makefile.in (modified) * c/src/lib/libmisc/dumpbuf/Makefile.in (modified) * c/src/lib/libmisc/error/Makefile.in (modified) * c/src/lib/libmisc/monitor/Makefile.in (modified) * c/src/lib/libmisc/rtmonuse/Makefile.in (modified) * c/src/lib/libmisc/stackchk/Makefile.in (modified) * c/src/lib/libmisc/untar/Makefile.in (modified) * c/src/lib/libmisc/wrapup/Makefile.in (modified) * c/src/lib/libnetworking/Makefile.am (added) * c/src/lib/libnetworking/Makefile.in (modified) * c/src/lib/libnetworking/configure.in (added) * c/src/lib/libnetworking/include/Makefile.in (modified) * c/src/lib/libnetworking/kern/Makefile.in (modified) * c/src/lib/libnetworking/lib/Makefile.in (modified) * c/src/lib/libnetworking/libc/Makefile.in (modified) * c/src/lib/libnetworking/net/Makefile.in (modified) * c/src/lib/libnetworking/netinet/Makefile.in (modified) * c/src/lib/libnetworking/nfs/Makefile.in (modified) * c/src/lib/libnetworking/rtems/Makefile.in (modified) * c/src/lib/libnetworking/rtems_servers/Makefile.in (modified) * c/src/lib/libnetworking/wrapup/Makefile.in (modified) * c/src/lib/librdbg/Makefile.in (modified) * c/src/lib/librdbg/configure.in (added) * c/src/lib/librdbg/i386/Makefile.in (modified) * c/src/lib/librdbg/i386/pc386/Makefile.in (modified) * c/src/lib/librdbg/powerpc/Makefile.in (modified) * c/src/lib/librdbg/powerpc/mcp750/Makefile.in (modified) * c/src/lib/librpc/Makefile.in (modified) * c/src/lib/librpc/configure.in (added) * c/src/lib/start/Makefile.am (added) * c/src/lib/start/Makefile.in (modified) * c/src/lib/start/a29k/Makefile.in (modified) * c/src/lib/start/a29k/configure.in (added) * c/src/lib/start/i960/Makefile.in (modified) * c/src/lib/start/i960/configure.in (added) * c/src/lib/start/m68k/Makefile.in (modified) * c/src/lib/start/m68k/configure.in (added) * c/src/lib/start/mips64orion/Makefile.in (modified) * c/src/lib/start/mips64orion/configure.in (added) * c/src/lib/start/sh/Makefile.in (modified) * c/src/lib/start/sh/configure.in (added) * c/src/libchip/Makefile.am (added) * c/src/libchip/configure.in (added) * c/src/libchip/network/Makefile.in (modified) * c/src/libchip/rtc/Makefile.in (modified) * c/src/libchip/serial/Makefile.in (modified) * c/src/libmisc/Makefile.am (added) * c/src/libmisc/assoc/Makefile.in (modified) * c/src/libmisc/configure.in (added) * c/src/libmisc/cpuuse/Makefile.in (modified) * c/src/libmisc/dumpbuf/Makefile.in (modified) * c/src/libmisc/error/Makefile.in (modified) * c/src/libmisc/monitor/Makefile.in (modified) * c/src/libmisc/rtmonuse/Makefile.in (modified) * c/src/libmisc/stackchk/Makefile.in (modified) * c/src/libmisc/untar/Makefile.in (modified) * c/src/libmisc/wrapup/Makefile.in (modified) * c/src/libnetworking/Makefile.am (added) * c/src/libnetworking/Makefile.in (modified) * c/src/libnetworking/configure.in (added) * c/src/libnetworking/include/Makefile.in (modified) * c/src/libnetworking/kern/Makefile.in (modified) * c/src/libnetworking/lib/Makefile.in (modified) * c/src/libnetworking/libc/Makefile.in (modified) * c/src/libnetworking/net/Makefile.in (modified) * c/src/libnetworking/netinet/Makefile.in (modified) * c/src/libnetworking/nfs/Makefile.in (modified) * c/src/libnetworking/rtems/Makefile.in (modified) * c/src/libnetworking/rtems_servers/Makefile.in (modified) * c/src/libnetworking/wrapup/Makefile.in (modified) * c/src/librdbg/include/rdbg/Makefile.am (added) * c/src/librdbg/include/rdbg/i386/Makefile.am (added) * c/src/librdbg/include/rdbg/powerpc/Makefile.am (added) * c/src/librdbg/src/Makefile.in (modified) * c/src/librdbg/src/configure.in (added) * c/src/librdbg/src/i386/Makefile.in (modified) * c/src/librdbg/src/i386/any/Makefile.in (modified) * c/src/librdbg/src/i386/pc386/Makefile.in (modified) * c/src/librdbg/src/powerpc/Makefile.in (modified) * c/src/librdbg/src/powerpc/mcp750/Makefile.in (modified) * c/src/librpc/include/rpc/Makefile.am (added) * c/src/librpc/src/Makefile.in (modified) * c/src/librtems++/Makefile.am (added) * c/src/librtems++/Makefile.in (added) * c/src/librtems++/aclocal.m4 (added) * c/src/librtems++/configure (added) * c/src/librtems++/configure.in (added) * c/src/librtems++/include/Makefile.am (added) * c/src/librtems++/include/Makefile.in (added) * c/src/librtems++/include/rtems++/Makefile.am (added) * c/src/librtems++/include/rtems++/Makefile.in (added) * c/src/make/Makefile.in (modified) * c/src/make/aclocal.m4 (modified) * c/src/make/compilers/Makefile.in (modified) * c/src/make/custom/Makefile.in (modified) * c/src/make/custom/default.cfg.in (modified) * c/src/tests/Makefile.in (modified) * c/src/tests/libtests/Makefile.in (modified) * c/src/tests/libtests/aclocal.m4 (modified) * c/src/tests/mptests/Makefile.in (modified) * c/src/tests/psxtests/Makefile.in (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/tests/samples/aclocal.m4 (modified) * c/src/tests/sptests/Makefile.in (modified) * c/src/tests/support/Makefile.in (modified) * c/src/tests/support/include/Makefile.in (modified) * c/src/tests/tmtests/Makefile.in (modified) * c/src/tests/tmtests/include/Makefile.in (modified) * c/src/tests/tools/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.in (modified) * cpukit/Makefile.am (added) * cpukit/libcsupport/Makefile.am (added) * cpukit/libmisc/Makefile.am (added) * cpukit/libnetworking/Makefile.am (added) * cpukit/librpc/include/rpc/Makefile.am (added) * cpukit/posix/Makefile.am (added) * cpukit/posix/include/Makefile.am (added) * cpukit/posix/inline/Makefile.am (added) * cpukit/posix/macros/Makefile.am (added) * cpukit/rtems/Makefile.am (added) * cpukit/rtems/include/Makefile.am (added) * cpukit/rtems/inline/Makefile.am (added) * cpukit/rtems/macros/Makefile.am (added) * cpukit/sapi/Makefile.am (added) * cpukit/sapi/include/Makefile.am (added) * cpukit/sapi/inline/Makefile.am (added) * cpukit/sapi/macros/Makefile.am (added) * cpukit/score/Makefile.am (added) * cpukit/score/include/Makefile.am (added) * cpukit/score/inline/Makefile.am (added) * cpukit/score/macros/Makefile.am (added) * cpukit/wrapup/Makefile.am (added) * doc/Makefile.in (modified) * make/Makefile.in (modified) * make/Templates/Makefile.in (modified) * make/compilers/Makefile.in (modified) * make/custom/Makefile.in (modified) * tools/Makefile.in (modified) * tools/build/Makefile.in (modified) * tools/build/configure (modified) * tools/build/configure.in (modified) * tools/cpu/Makefile.am (modified) * tools/cpu/Makefile.in (modified) * tools/cpu/configure (modified) * tools/cpu/configure.in (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/sh/Makefile.in (modified) * tools/cpu/unix/Makefile.in (modified) * tools/update/Makefile.in (modified) * tools/update/configure (modified) * tools/update/configure.in (modified) Applied patch rtems-rc-19990820-6.diff.gz from Ralf Corsepius ... Mon, 23 Aug 1999 18:48:07 GMT Joel Sherrill [72f9937b] * c/src/lib/libnetworking/include/Makefile.in (modified) * c/src/libnetworking/include/Makefile.in (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) Removed need for use of separate include/networking directory. Fri, 06 Aug 1999 17:55:25 GMT Joel Sherrill [3a8915e] * aclocal/check-multiprocessing.m4 (modified) * aclocal/check-rdbg.m4 (modified) * c/Makefile.am (modified) * c/src/exec/aclocal.m4 (modified) * c/src/exec/configure (modified) * c/src/exec/configure.in (modified) * c/src/lib/aclocal.m4 (modified) * c/src/lib/configure (modified) * c/src/lib/configure.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/libbsp/bare/include/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/bsp_specs (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme167/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/eth_comm/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/mcp750/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.in (modified) * c/src/lib/libmisc/wrapup/Makefile.in (modified) * c/src/lib/start/sh/Makefile.in (modified) * c/src/libmisc/wrapup/Makefile.in (modified) * c/src/make/Makefile.am (modified) * c/src/make/Makefile.in (modified) * c/src/make/Makefile.inc.in (modified) * c/src/make/Templates/Makefile.in (modified) * c/src/make/aclocal.m4 (modified) * c/src/make/bsp.cfg.in (modified) * c/src/make/compilers/Makefile.in (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/configure (modified) * c/src/make/configure.in (modified) * c/src/make/custom/Makefile.in (modified) * c/src/make/custom/default.cfg.in (modified) * c/src/make/host.cfg.in (modified) * c/src/tests/Makefile.in (modified) * c/src/tests/aclocal.m4 (modified) * c/src/tests/configure (modified) * c/src/tests/configure.in (modified) * c/src/tests/libtests/Makefile.in (modified) * c/src/tests/libtests/cpuuse/Makefile.in (modified) * c/src/tests/libtests/malloctest/Makefile.in (modified) * c/src/tests/libtests/monitor/Makefile.in (modified) * c/src/tests/libtests/rtems++/Makefile.in (modified) * c/src/tests/libtests/rtmonuse/Makefile.in (modified) * c/src/tests/libtests/stackchk/Makefile.in (modified) * c/src/tests/libtests/termios/Makefile.in (modified) * c/src/tests/mptests/Makefile.in (modified) * c/src/tests/mptests/mp01/Makefile.in (modified) * c/src/tests/mptests/mp01/node1/Makefile.in (modified) * c/src/tests/mptests/mp01/node2/Makefile.in (modified) * c/src/tests/mptests/mp02/Makefile.in (modified) * c/src/tests/mptests/mp02/node1/Makefile.in (modified) * c/src/tests/mptests/mp02/node2/Makefile.in (modified) * c/src/tests/mptests/mp03/Makefile.in (modified) * c/src/tests/mptests/mp03/node1/Makefile.in (modified) * c/src/tests/mptests/mp03/node2/Makefile.in (modified) * c/src/tests/mptests/mp04/Makefile.in (modified) * c/src/tests/mptests/mp04/node1/Makefile.in (modified) * c/src/tests/mptests/mp04/node2/Makefile.in (modified) * c/src/tests/mptests/mp05/Makefile.in (modified) * c/src/tests/mptests/mp05/node1/Makefile.in (modified) * c/src/tests/mptests/mp05/node2/Makefile.in (modified) * c/src/tests/mptests/mp06/Makefile.in (modified) * c/src/tests/mptests/mp06/node1/Makefile.in (modified) * c/src/tests/mptests/mp06/node2/Makefile.in (modified) * c/src/tests/mptests/mp07/Makefile.in (modified) * c/src/tests/mptests/mp07/node1/Makefile.in (modified) * c/src/tests/mptests/mp07/node2/Makefile.in (modified) * c/src/tests/mptests/mp08/Makefile.in (modified) * c/src/tests/mptests/mp08/node1/Makefile.in (modified) * c/src/tests/mptests/mp08/node2/Makefile.in (modified) * c/src/tests/mptests/mp09/Makefile.in (modified) * c/src/tests/mptests/mp09/node1/Makefile.in (modified) * c/src/tests/mptests/mp09/node2/Makefile.in (modified) * c/src/tests/mptests/mp10/Makefile.in (modified) * c/src/tests/mptests/mp10/node1/Makefile.in (modified) * c/src/tests/mptests/mp10/node2/Makefile.in (modified) * c/src/tests/mptests/mp11/Makefile.in (modified) * c/src/tests/mptests/mp11/node1/Makefile.in (modified) * c/src/tests/mptests/mp11/node2/Makefile.in (modified) * c/src/tests/mptests/mp12/Makefile.in (modified) * c/src/tests/mptests/mp12/node1/Makefile.in (modified) * c/src/tests/mptests/mp12/node2/Makefile.in (modified) * c/src/tests/mptests/mp13/Makefile.in (modified) * c/src/tests/mptests/mp13/node1/Makefile.in (modified) * c/src/tests/mptests/mp13/node2/Makefile.in (modified) * c/src/tests/mptests/mp14/Makefile.in (modified) * c/src/tests/mptests/mp14/node1/Makefile.in (modified) * c/src/tests/mptests/mp14/node2/Makefile.in (modified) * c/src/tests/psxtests/Makefile.in (modified) * c/src/tests/psxtests/psx01/Makefile.in (modified) * c/src/tests/psxtests/psx02/Makefile.in (modified) * c/src/tests/psxtests/psx03/Makefile.in (modified) * c/src/tests/psxtests/psx04/Makefile.in (modified) * c/src/tests/psxtests/psx05/Makefile.in (modified) * c/src/tests/psxtests/psx06/Makefile.in (modified) * c/src/tests/psxtests/psx07/Makefile.in (modified) * c/src/tests/psxtests/psx08/Makefile.in (modified) * c/src/tests/psxtests/psx09/Makefile.in (modified) * c/src/tests/psxtests/psx10/Makefile.in (modified) * c/src/tests/psxtests/psx11/Makefile.in (modified) * c/src/tests/psxtests/psx12/Makefile.in (modified) * c/src/tests/psxtests/psx13/Makefile.in (modified) * c/src/tests/psxtests/psxfile01/Makefile.in (modified) * c/src/tests/psxtests/psxfile02/Makefile.in (modified) * c/src/tests/psxtests/psxhdrs/Makefile.in (modified) * c/src/tests/psxtests/psxmount/Makefile.in (modified) * c/src/tests/psxtests/psxreaddir/Makefile.in (modified) * c/src/tests/psxtests/psxstat/Makefile.in (modified) * c/src/tests/psxtests/psxtime/Makefile.in (modified) * c/src/tests/psxtests/psxtimer/Makefile.in (modified) * c/src/tests/psxtests/support/Makefile.in (modified) * c/src/tests/psxtests/support/include/Makefile.in (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/tests/samples/base_mp/Makefile.in (modified) * c/src/tests/samples/base_mp/node1/Makefile.in (modified) * c/src/tests/samples/base_mp/node2/Makefile.in (modified) * c/src/tests/samples/base_sp/Makefile.in (modified) * c/src/tests/samples/cdtest/Makefile.in (modified) * c/src/tests/samples/hello/Makefile.in (modified) * c/src/tests/samples/minimum/Makefile.in (modified) * c/src/tests/samples/paranoia/Makefile.in (modified) * c/src/tests/samples/ticker/Makefile.in (modified) * c/src/tests/samples/unlimited/Makefile.in (modified) * c/src/tests/sptests/Makefile.in (modified) * c/src/tests/sptests/sp01/Makefile.in (modified) * c/src/tests/sptests/sp02/Makefile.in (modified) * c/src/tests/sptests/sp03/Makefile.in (modified) * c/src/tests/sptests/sp04/Makefile.in (modified) * c/src/tests/sptests/sp05/Makefile.in (modified) * c/src/tests/sptests/sp06/Makefile.in (modified) * c/src/tests/sptests/sp07/Makefile.in (modified) * c/src/tests/sptests/sp08/Makefile.in (modified) * c/src/tests/sptests/sp09/Makefile.in (modified) * c/src/tests/sptests/sp11/Makefile.in (modified) * c/src/tests/sptests/sp12/Makefile.in (modified) * c/src/tests/sptests/sp13/Makefile.in (modified) * c/src/tests/sptests/sp14/Makefile.in (modified) * c/src/tests/sptests/sp15/Makefile.in (modified) * c/src/tests/sptests/sp16/Makefile.in (modified) * c/src/tests/sptests/sp17/Makefile.in (modified) * c/src/tests/sptests/sp19/Makefile.in (modified) * c/src/tests/sptests/sp20/Makefile.in (modified) * c/src/tests/sptests/sp21/Makefile.in (modified) * c/src/tests/sptests/sp22/Makefile.in (modified) * c/src/tests/sptests/sp23/Makefile.in (modified) * c/src/tests/sptests/sp24/Makefile.in (modified) * c/src/tests/sptests/sp25/Makefile.in (modified) * c/src/tests/sptests/spfatal/Makefile.in (modified) * c/src/tests/sptests/spsize/Makefile.in (modified) * c/src/tests/support/Makefile.in (modified) * c/src/tests/support/include/Makefile.in (modified) * c/src/tests/support/stubdr/Makefile.in (modified) * c/src/tests/support/wrapup/Makefile.in (modified) * c/src/tests/tmtests/Makefile.in (modified) * c/src/tests/tmtests/include/Makefile.in (modified) * c/src/tests/tmtests/tm01/Makefile.in (modified) * c/src/tests/tmtests/tm02/Makefile.in (modified) * c/src/tests/tmtests/tm03/Makefile.in (modified) * c/src/tests/tmtests/tm04/Makefile.in (modified) * c/src/tests/tmtests/tm05/Makefile.in (modified) * c/src/tests/tmtests/tm06/Makefile.in (modified) * c/src/tests/tmtests/tm07/Makefile.in (modified) * c/src/tests/tmtests/tm08/Makefile.in (modified) * c/src/tests/tmtests/tm09/Makefile.in (modified) * c/src/tests/tmtests/tm10/Makefile.in (modified) * c/src/tests/tmtests/tm11/Makefile.in (modified) * c/src/tests/tmtests/tm12/Makefile.in (modified) * c/src/tests/tmtests/tm13/Makefile.in (modified) * c/src/tests/tmtests/tm14/Makefile.in (modified) * c/src/tests/tmtests/tm15/Makefile.in (modified) * c/src/tests/tmtests/tm16/Makefile.in (modified) * c/src/tests/tmtests/tm17/Makefile.in (modified) * c/src/tests/tmtests/tm18/Makefile.in (modified) * c/src/tests/tmtests/tm19/Makefile.in (modified) * c/src/tests/tmtests/tm20/Makefile.in (modified) * c/src/tests/tmtests/tm21/Makefile.in (modified) * c/src/tests/tmtests/tm22/Makefile.in (modified) * c/src/tests/tmtests/tm23/Makefile.in (modified) * c/src/tests/tmtests/tm24/Makefile.in (modified) * c/src/tests/tmtests/tm25/Makefile.in (modified) * c/src/tests/tmtests/tm26/Makefile.in (modified) * c/src/tests/tmtests/tm27/Makefile.in (modified) * c/src/tests/tmtests/tm28/Makefile.in (modified) * c/src/tests/tmtests/tm29/Makefile.in (modified) * c/src/tests/tmtests/tmck/Makefile.in (modified) * c/src/tests/tmtests/tmoverhd/Makefile.in (modified) * c/src/tests/tools/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.am (modified) * c/src/tests/tools/generic/Makefile.in (modified) * make/Templates/Makefile.am (modified) * make/Templates/Makefile.in (modified) * make/Templates/Makefile.inc.in (deleted) * make/compilers/gcc-target-default.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/default.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/force386.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/go32.cfg (modified) * make/custom/helas403.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/mvme167.cfg (modified) * make/custom/no_bsp.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/portsw.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/score603e.cfg (modified) * make/custom/simhppa.cfg (modified) * make/host.cfg.in (modified) * make/leaf.cfg (modified) * testsuites/tools/generic/Makefile.am (modified) * tools/update/acpolish (modified) Patch rtems-rc-19990709-6-diff from Ralf Corsepius [29e68b75] * Makefile.am (modified) * Makefile.in (modified) * automake/local.am (modified) * automake/subdirs.am (modified) * c/Makefile.am (modified) * c/Makefile.in (modified) * c/src/Makefile.in (modified) * c/src/exec/Makefile.in (modified) * c/src/exec/sapi/include/rtems/Makefile.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure.in (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.am (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/bin2boot.c (modified) * c/src/lib/libbsp/i386/pc386/tools/binpatch.c (deleted) * c/src/lib/libbsp/i386/pc386/tools/configure (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/Makefile.in (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.in (modified) * c/src/lib/libbsp/powerpc/psim/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (modified) * c/src/make/Makefile.in (modified) * c/src/make/README (modified) * c/src/make/Templates/Makefile.in (modified) * c/src/make/compilers/Makefile.in (modified) * c/src/make/custom/Makefile.in (modified) * c/src/make/directory.cfg (modified) * c/src/make/main.cfg.in (modified) * c/src/tests/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.in (modified) * doc/Makefile.in (modified) * make/Makefile.in (modified) * make/README (modified) * make/Templates/Makefile.in (modified) * make/compilers/Makefile.in (modified) * make/custom/Makefile.in (modified) * make/custom/ts_386ex.cfg (modified) * make/directory.cfg (modified) * make/leaf.cfg (modified) * make/main.cfg (modified) * tools/Makefile.in (modified) * tools/build/Makefile.am (modified) * tools/build/Makefile.in (modified) * tools/build/binpatch.c (modified) * tools/build/config.h.in (modified) * tools/build/configure (modified) * tools/build/configure.in (modified) * tools/cpu/Makefile.in (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/hppa1.1/configure (modified) * tools/cpu/hppa1.1/configure.in (modified) * tools/cpu/sh/Makefile.in (modified) * tools/cpu/sh/configure (modified) * tools/cpu/sh/configure.in (modified) * tools/cpu/unix/Makefile.in (modified) * tools/cpu/unix/configure (modified) * tools/cpu/unix/configure.in (modified) * tools/update/Makefile.in (modified) Patch from Ralf Corsepius : This patch ... Mon, 26 Jul 1999 20:20:22 GMT Joel Sherrill [eb299afc] * Makefile.am (added) * aclocal/bsp-alias.m4 (added) * aclocal/check-newlib.m4 (added) * aclocal/check-rdbg.m4 (added) * aclocal/enable-rtemsbsp.m4 (added) * aclocal/project-root.m4 (added) * aclocal/target.m4 (added) * c/Makefile.am (added) * c/aclocal.m4 (added) * c/configure (added) * c/configure.in (added) * c/src/Makefile.am (added) * c/src/aclocal.m4 (added) * c/src/configure (added) * c/src/configure.in (added) * c/src/exec/aclocal.m4 (added) * c/src/exec/configure (added) * c/src/exec/configure.in (added) * c/src/lib/aclocal.m4 (added) * c/src/lib/configure (added) * c/src/lib/configure.in (added) * c/src/lib/libbsp/i386/ts_386ex/tools/Makefile.am (added) * c/src/lib/libbsp/i386/ts_386ex/tools/aclocal.m4 (added) * c/src/lib/libbsp/i386/ts_386ex/tools/configure (added) * c/src/lib/libbsp/i386/ts_386ex/tools/configure.in (added) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/Makefile.am (added) * c/src/lib/libbsp/i386/ts_386ex/tools/dos_sup/Makefile.in (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.am (added) * c/src/lib/libbsp/i386/ts_386ex/tools/ts_1325_ada/Makefile.in (added) * c/src/make/Makefile.am (added) * c/src/make/Makefile.in (added) * c/src/make/Makefile.inc.in (added) * c/src/make/Templates/Makefile.am (added) * c/src/make/Templates/Makefile.dir (added) * c/src/make/Templates/Makefile.in (added) * c/src/make/Templates/Makefile.leaf (added) * c/src/make/Templates/Makefile.lib (added) * c/src/make/aclocal.m4 (added) * c/src/make/compilers/Makefile.am (added) * c/src/make/compilers/Makefile.in (added) * c/src/make/compilers/gcc.cfg.in (added) * c/src/make/configure (added) * c/src/make/configure.in (added) * c/src/make/custom/Makefile.am (added) * c/src/make/custom/Makefile.in (added) * c/src/make/custom/default.cfg.in (added) * c/src/make/main.cfg.in (added) * c/src/make/target.cfg.in (added) * c/src/tests/aclocal.m4 (added) * c/src/tests/configure (added) * c/src/tests/configure.in (added) * make/Makefile.am (added) * make/Templates/Makefile.am (added) * make/Templates/Makefile.in (added) * make/compilers/Makefile.am (added) * make/compilers/Makefile.in (added) * make/custom/Makefile.am (added) * make/custom/Makefile.in (added) * tools/Makefile.am (added) * tools/Makefile.in (added) * tools/cpu/Makefile.am (added) * tools/cpu/aclocal.m4 (added) * tools/cpu/configure (added) * tools/cpu/configure.in (added) This is part of a major patch from Ralf Corsepius [07001360] * c/src/make/compilers/gcc-target-default.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) Added rules to handle alternate suffixes for C++ files. Wed, 17 Mar 1999 16:01:03 GMT Joel Sherrill [f4a8ee1] * c/src/exec/rtems/src/msg.c (modified) * c/src/exec/sapi/include/rtems/config.h (modified) * c/src/exec/score/include/rtems/score/object.h (modified) * c/src/exec/score/inline/rtems/score/coremsg.inl (modified) * c/src/exec/score/inline/rtems/score/object.inl (modified) * c/src/exec/score/macros/rtems/score/object.inl (modified) * c/src/exec/score/macros/rtems/score/userext.inl (modified) * c/src/exec/score/src/object.c (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/tests/samples/unlimited/Makefile.in (added) * c/src/tests/samples/unlimited/init.c (added) * c/src/tests/samples/unlimited/system.h (added) * c/src/tests/samples/unlimited/test1.c (added) * c/src/tests/samples/unlimited/test2.c (added) * c/src/tests/samples/unlimited/test3.c (added) * c/src/tests/samples/unlimited/unlimited.doc (added) * c/src/tests/samples/unlimited/unlimited.scn (added) * cpukit/rtems/src/msg.c (modified) * cpukit/sapi/include/rtems/config.h (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/inline/rtems/score/coremsg.inl (modified) * cpukit/score/inline/rtems/score/object.inl (modified) * cpukit/score/macros/rtems/score/object.inl (modified) * cpukit/score/macros/rtems/score/userext.inl (modified) * cpukit/score/src/object.c (modified) * make/compilers/gcc-target-default.cfg (modified) * testsuites/samples/unlimited/init.c (added) * testsuites/samples/unlimited/system.h (added) * testsuites/samples/unlimited/test1.c (added) * testsuites/samples/unlimited/test2.c (added) * testsuites/samples/unlimited/test3.c (added) * testsuites/samples/unlimited/unlimited.doc (added) * testsuites/samples/unlimited/unlimited.scn (added) Unlimited objects patch from Chris Johns . Email ... Wed, 24 Feb 1999 15:15:29 GMT Joel Sherrill [4d20133] * c/src/make/compilers/gcc-target-default.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) Patch from Ralf Corsepius . The following ... Thu, 18 Feb 1999 18:00:22 GMT Joel Sherrill [4cc89bd] * c/src/make/compilers/gcc-target-default.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) Added rejected patch from automake VI from Ralf Corsepius. Thu, 18 Feb 1999 17:55:49 GMT Joel Sherrill [a110b68] * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * make/compilers/gcc-no_bsp.cfg (modified) * make/compilers/gcc-portsw.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/ods68302.cfg (modified) Part of automake VI patch from Ralf Corsepius [7d0dbf1a] * c/src/make/compilers/gcc-target-default.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) Changed definition of ASMFLAGS since as does not recognize -B option ... Mon, 14 Dec 1998 23:15:38 GMT Joel Sherrill [0162910] * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/a29k/cpu_asm.S (moved) * c/src/exec/score/cpu/a29k/sig.S (moved) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/cpu_asm.S (moved) * c/src/exec/score/cpu/hppa1.1/rtems.S (moved) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i386/cpu_asm.S (moved) * c/src/exec/score/cpu/i386/rtems.S (moved) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/i960/cpu_asm.S (moved) * c/src/exec/score/cpu/i960/rtems.S (moved) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/m68k/cpu_asm.S (moved) * c/src/exec/score/cpu/m68k/rtems.S (moved) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/cpu_asm.S (moved) * c/src/exec/score/cpu/powerpc/irq_stub.S (moved) * c/src/exec/score/cpu/powerpc/rtems.S (moved) * c/src/exec/score/cpu/sh/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/sparc/cpu_asm.S (moved) * c/src/exec/score/cpu/sparc/rtems.S (moved) * c/src/lib/libbsp/a29k/portsw/console/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/start/crt0.S (moved) * c/src/lib/libbsp/a29k/portsw/start/register.S (moved) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/start/start.S (moved) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/start/start.S (moved) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/startup/ldsegs.S (moved) * c/src/lib/libbsp/i386/force386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/timer/timerisr.S (moved) * c/src/lib/libbsp/i386/force386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/timer/timerisr.S (moved) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/start/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/start/start.S (moved) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/timer/timerisr.S (moved) * c/src/lib/libbsp/i386/pc386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/console/videoAsm.S (moved) * c/src/lib/libbsp/i386/pc386/start/start.S (moved) * c/src/lib/libbsp/i386/pc386/start/start16.S (moved) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/ldsegs.S (moved) * c/src/lib/libbsp/i386/pc386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/timer/timerisr.S (moved) * c/src/lib/libbsp/i386/shared/irq/irq_asm.S (moved) * c/src/lib/libbsp/i960/cvme961/start/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/start/start.S (moved) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/timer/timerisr.S (moved) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/timer/timerisr.S (moved) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start/start.S (moved) * c/src/lib/libbsp/m68k/gen68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start302/start302.S (moved) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/timer/timerisr.S (moved) * c/src/lib/libbsp/m68k/gen68340/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/console/Modif_cpu_asm.S (moved) * c/src/lib/libbsp/m68k/gen68340/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start/start.S (moved) * c/src/lib/libbsp/m68k/gen68340/start/startfor340only.S (moved) * c/src/lib/libbsp/m68k/gen68340/start340/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68340/start340/start340.S (moved) * c/src/lib/libbsp/m68k/gen68340/start340/startfor340only.S (moved) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start/start.S (moved) * c/src/lib/libbsp/m68k/gen68360/start360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start360/start360.S (moved) * c/src/lib/libbsp/m68k/idp/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/timer/timerisr.S (moved) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/timer/timerisr.S (moved) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/timer/timerisr.s (deleted) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/timer/timerisr.S (moved) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/timer/timerisr.S (moved) * c/src/lib/libbsp/m68k/shared/start.S (moved) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/sonic/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/start/start.S (moved) * c/src/lib/libbsp/powerpc/dmv177/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/dmv177/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/dlentry/dlentry.S (moved) * c/src/lib/libbsp/powerpc/helas403/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/helas403/flashentry/flashentry.S (moved) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/dlentry.S (moved) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/flashentry.S (moved) * c/src/lib/libbsp/powerpc/psim/clock/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/console/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/console/consupp.S (moved) * c/src/lib/libbsp/powerpc/psim/start/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/start/start.S (moved) * c/src/lib/libbsp/powerpc/psim/startsim/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/startsim/startsim.S (moved) * c/src/lib/libbsp/powerpc/psim/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/timer/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/vectors/Makefile.in (modified) * c/src/lib/libbsp/powerpc/psim/vectors/align_h.S (moved) * c/src/lib/libbsp/powerpc/psim/vectors/vectors.S (moved) * c/src/lib/libbsp/powerpc/psim/wrapup/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/scitab/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/start/Makefile.in (modified) * c/src/lib/libbsp/sh/gensh1/start/start.S (moved) * c/src/lib/libbsp/sh/gensh1/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/start/start.S (moved) * c/src/lib/libbsp/sparc/erc32/startsis/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startsis/startsis.S (moved) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/milli.S (moved) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/bindec.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/binstr.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/bugfix.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/decbin.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/do_func.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/gen_except.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/get_op.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/kernel_ex.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/res_func.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/round.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/rtems_skel.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/sacos.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/sasin.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/satan.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/satanh.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/scale.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/scosh.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/setox.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/sgetem.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/sint.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/slog2.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/slogn.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/smovecr.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/srem_mod.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/ssin.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/ssinh.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/stan.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/stanh.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/sto_res.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/stwotox.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/tbldo.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/util.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/x_bsun.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/x_fline.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/x_operr.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/x_ovfl.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/x_snan.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/x_store.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/x_unfl.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/x_unimp.S (moved) * c/src/lib/libcpu/m68k/m68040/fpsp/x_unsupp.S (moved) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/ictrl/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/align_h.S (moved) * c/src/lib/libcpu/powerpc/ppc403/vectors/vectors.S (moved) * c/src/lib/libcpu/sh/sh7032/clock/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/console/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/null/Makefile.in (modified) * c/src/lib/libcpu/sh/sh7032/timer/Makefile.in (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.in (modified) * c/src/lib/libcpu/sparc/reg_win/window.S (moved) * c/src/lib/librdbg/i386/rdbg_cpu_asm.S (moved) * c/src/lib/start/a29k/Makefile.in (modified) * c/src/lib/start/a29k/crt0.S (added) * c/src/lib/start/a29k/register.S (added) * c/src/lib/start/i960/Makefile.in (modified) * c/src/lib/start/i960/start.S (added) * c/src/lib/start/m68k/Makefile.in (modified) * c/src/lib/start/m68k/start.S (added) * c/src/lib/start/mips64orion/Makefile.in (modified) * c/src/lib/start/sh/Makefile.in (modified) * c/src/lib/start/sh/start.S (added) * c/src/librdbg/src/i386/rdbg_cpu_asm.S (moved) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/tests/support/stubdr/Makefile.in (modified) * cpukit/score/cpu/a29k/cpu_asm.S (added) * cpukit/score/cpu/a29k/sig.S (added) * cpukit/score/cpu/hppa1.1/cpu_asm.S (added) * cpukit/score/cpu/i386/cpu_asm.S (added) * cpukit/score/cpu/i960/cpu_asm.S (added) * cpukit/score/cpu/m68k/cpu_asm.S (added) * cpukit/score/cpu/sparc/cpu_asm.S (added) * make/Templates/Makefile.leaf (modified) * make/Templates/Makefile.lib (modified) * make/compilers/gcc-target-default.cfg (modified) Patch from Ralf Corsepius to rename all .s ... Wed, 14 Oct 1998 19:42:45 GMT Joel Sherrill [946b3cb] * configure (modified) * configure.in (modified) * make/compilers/gcc.cfg.in (modified) Patch from Ralf Corsepius : 2. "make ... Thu, 10 Sep 1998 12:31:27 GMT Joel Sherrill [b67245d0] * c/src/make/compilers/gcc-target-default.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) Patch from Chris Johns : I have managed to build ... Fri, 21 Aug 1998 17:43:22 GMT Joel Sherrill [cce81a7] * configure (modified) * configure.in (modified) * make/Makefile.in (modified) * make/compilers/gcc.cfg.in (added) * make/custom/default.cfg (modified) A patch from Ralf Corsepius : Here is ... Thu, 20 Aug 1998 22:04:22 GMT Joel Sherrill [28e7d7fa] * c/Makefile.in (modified) * c/src/exec/libnetworking/arpa/inet.h (modified) * c/src/exec/libnetworking/rtems/rtems_syscall.c (modified) * c/src/exec/score/cpu/i386/cpu.h (modified) * c/src/exec/score/headers/Makefile.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/libbsp/bare/README (modified) * c/src/lib/libbsp/bare/do-bare-bsp-build (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/network/network.c (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/README (modified) * c/src/lib/libbsp/m68k/gen68360/include/bsp.h (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/libnetworking/arpa/inet.h (modified) * c/src/lib/libnetworking/rtems/rtems_syscall.c (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/libnetworking/arpa/inet.h (modified) * c/src/libnetworking/rtems/rtems_syscall.c (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) * cpukit/libnetworking/arpa/inet.h (modified) * cpukit/libnetworking/rtems/rtems_syscall.c (modified) * make/Templates/Makefile.inc.in (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/default.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/force386.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/go32.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/no_bsp.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/portsw.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/simhppa.cfg (modified) * make/target.cfg.in (modified) Patches from Eric Norum Thu, 20 Aug 1998 14:39:09 GMT Joel Sherrill [0280cb6] * c/Makefile.in (modified) * c/src/exec/score/cpu/i386/cpu.h (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/network.c (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/default.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/force386.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/go32.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/no_bsp.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/portsw.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/simhppa.cfg (modified) * make/target.cfg.in (modified) FreeBSD stack compiles for the first time (except libc/strsep.c) Sat, 01 Aug 1998 14:41:45 GMT Joel Sherrill [8c6e195] * c/src/make/compilers/gcc-target-default.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) Patch from David Fiddes to make ASFLAGS include ... Tue, 28 Jul 1998 16:50:14 GMT Joel Sherrill [30cde042] * c/src/make/compilers/gcc-target-default.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) Added missing parts of patch from Ralf Corsepius [5b8c1b7] * c/src/make/compilers/gcc-target-default.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) Yet another EXEEXT patch. This one is from Ralf Corsepius ... Fri, 10 Jul 1998 14:13:59 GMT Joel Sherrill [cc8a388a] * c/src/make/compilers/gcc-target-default.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) Patch from Ralf Corsepius . Comments: ... Sat, 27 Jun 1998 17:09:47 GMT Joel Sherrill [98100d2] * Makefile.in (modified) * aclocal.m4 (modified) * aclocal/ar-s.m4 (added) * aclocal/canonicalize-tools.m4 (modified) * aclocal/cygwin.m4 (added) * aclocal/exeext.m4 (added) * aclocal/gcc-pipe.m4 (modified) * aclocal/gcc-specs.m4 (modified) * c/PROBLEMS (modified) * c/build-tools/scripts/Makefile.in (modified) * c/build-tools/src/Makefile.in (modified) * c/src/exec/score/tools/generic/size_rtems.in (modified) * c/src/lib/libbsp/i386/pc386/tools/bin2boot.c (modified) * c/src/lib/libbsp/m68k/idp/console/console.c (modified) * c/src/lib/libbsp/m68k/mvme162/console/console.c (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/make/README (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * c/src/make/host.cfg.in (modified) * c/src/wrapup/Makefile.in (modified) * configure (modified) * configure.in (modified) * make/README (modified) * make/compilers/gcc-no_bsp.cfg (modified) * make/compilers/gcc-portsw.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) * make/custom/FreeBSD-posix.cfg (modified) * make/custom/HPUX9-posix.cfg (modified) * make/custom/Linux-posix.cfg (modified) * make/custom/Solaris-posix.cfg (modified) * make/custom/bare.cfg (modified) * make/custom/cvme961.cfg (modified) * make/custom/dmv152.cfg (modified) * make/custom/efi332.cfg (modified) * make/custom/efi68k.cfg (modified) * make/custom/erc32.cfg (modified) * make/custom/force386.cfg (modified) * make/custom/gen68302.cfg (modified) * make/custom/gen68360.cfg (modified) * make/custom/gensh1.cfg (modified) * make/custom/go32.cfg (modified) * make/custom/i386ex.cfg (modified) * make/custom/idp.cfg (modified) * make/custom/mvme136.cfg (modified) * make/custom/mvme147.cfg (modified) * make/custom/mvme162.cfg (modified) * make/custom/no_bsp.cfg (modified) * make/custom/ods68302.cfg (modified) * make/custom/p4000.cfg (modified) * make/custom/p4600.cfg (modified) * make/custom/p4650.cfg (modified) * make/custom/papyrus.cfg (modified) * make/custom/pc386.cfg (modified) * make/custom/psim.cfg (modified) * make/custom/simhppa.cfg (modified) * make/host.cfg.in (modified) * make/target.cfg.in (modified) * tools/build/scripts/Makefile.in (modified) * tools/build/src/Makefile.in (modified) * tools/cpu/generic/size_rtems.in (modified) Monstrous patch from Ralf Corsepius . I ... Tue, 09 Jun 1998 14:21:21 GMT Joel Sherrill [9456087] * c/src/make/compilers/gcc-target-default.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) Added rule for .cxx and .cpp per suggestion from Geoffroy Montel ... Wed, 27 May 1998 19:26:09 GMT Joel Sherrill [c2c9c7e] * c/src/make/compilers/gcc-target-default.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) Added names for C++ compilers. Wed, 20 May 1998 17:01:04 GMT Joel Sherrill [5dd4212] * c/src/make/compilers/gcc-target-default.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) Changed CPP rule per patch from Ralf Corsepius. Mon, 18 May 1998 16:38:38 GMT Joel Sherrill [6ee6abb] * c/src/make/compilers/gcc-target-default.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) Added C++ rule. Added CROSS_TARGET conditionals so unix port can ... Mon, 06 Apr 1998 17:09:44 GMT Joel Sherrill [092940bd] * make/compilers/gcc-no_bsp.cfg (modified) * make/compilers/gcc-portsw.cfg (modified) Purged references to STACK_CHECKER_REPORT_USAGE Mon, 06 Apr 1998 16:26:53 GMT Joel Sherrill [a5cb673] * make/compilers/gcc-no_bsp.cfg (modified) * make/compilers/gcc-portsw.cfg (modified) Reordered CFLAGS definition so CFLAGS_DEFAULT is before ... Tue, 17 Feb 1998 20:42:10 GMT Joel Sherrill [5d1ea96] * make/compilers/gcc-no_bsp.cfg (modified) added -Wno-unused to debug flags Tue, 17 Feb 1998 19:16:18 GMT Joel Sherrill [ac61209b] * c/src/make/compilers/gcc-target-default.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) Added unused warning per discussion on rtems-snapshots list. Tue, 17 Feb 1998 14:12:01 GMT Joel Sherrill [e81ef51] * README.configure (modified) * aclocal.m4 (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * make/compilers/gcc-portsw.cfg (modified) * make/compilers/gcc-target-default.cfg (modified) Patch from Ralf Corsepius : Yep, I have ... Wed, 11 Feb 1998 22:13:46 GMT Joel Sherrill [a858910] * c/src/lib/libbsp/hppa1.1/simhppa/bsp_specs (modified) * c/src/lib/libbsp/i386/force386/bsp_specs (modified) * c/src/lib/libbsp/i386/i386ex/bsp_specs (modified) * c/src/lib/libbsp/i386/pc386/bsp_specs (modified) * c/src/lib/libbsp/i960/cvme961/bsp_specs (modified) * c/src/lib/libbsp/m68k/dmv152/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi332/bsp_specs (modified) * c/src/lib/libbsp/m68k/efi68k/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68302/bsp_specs (modified) * c/src/lib/libbsp/m68k/gen68360/bsp_specs (modified) * c/src/lib/libbsp/m68k/idp/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme136/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme147s/bsp_specs (modified) * c/src/lib/libbsp/m68k/mvme162/bsp_specs (modified) * c/src/lib/libbsp/m68k/ods68302/bsp_specs (modified) * c/src/lib/libbsp/mips/p4000/bsp_specs (modified) * c/src/lib/libbsp/mips64orion/p4000/bsp_specs (modified) * c/src/lib/libbsp/powerpc/papyrus/bsp_specs (modified) * c/src/lib/libbsp/sparc/erc32/bsp_specs (modified) * c/src/make/compilers/gcc-target-default.cfg (modified) * make/Templates/Makefile.leaf (modified) * make/compilers/gcc-target-default.cfg (modified) Incorporated Ralf Corsepius' idea for new -q flags to properly ... Tue, 20 Jan 1998 19:30:30 GMT Joel Sherrill [bffb938] * c/src/make/README (added) * c/src/make/compilers/gcc-target-default.cfg (added) * c/src/make/directory.cfg (added) * c/src/make/host.cfg.in (added) * c/src/make/lib.cfg (added) * make/Makefile.in (added) * make/README (added) * make/Templates/Makefile.dir (added) * make/Templates/Makefile.inc.in (added) * make/Templates/Makefile.leaf (added) * make/Templates/Makefile.lib (added) * make/compilers/gcc-no_bsp.cfg (added) * make/compilers/gcc-portsw.cfg (added) * make/compilers/gcc-target-default.cfg (added) * make/custom/HPUX9-posix.cfg (added) * make/custom/Linux-posix.cfg (added) * make/custom/Solaris-posix.cfg (added) * make/custom/cvme961.cfg (added) * make/custom/default.cfg (added) * make/custom/dmv152.cfg (added) * make/custom/efi332.cfg (added) * make/custom/efi68k.cfg (added) * make/custom/erc32.cfg (added) * make/custom/force386.cfg (added) * make/custom/gen68302.cfg (added) * make/custom/gen68360.cfg (added) * make/custom/gen68360_040.cfg (added) * make/custom/gensh1.cfg (added) * make/custom/go32.cfg (added) * make/custom/go32_p5.cfg (added) * make/custom/i386ex.cfg (added) * make/custom/idp.cfg (added) * make/custom/mvme136.cfg (added) * make/custom/mvme147.cfg (added) * make/custom/mvme147s.cfg (added) * make/custom/mvme162.cfg (added) * make/custom/mvme162lx.cfg (added) * make/custom/no_bsp.cfg (added) * make/custom/ods68302.cfg (added) * make/custom/p4000.cfg (added) * make/custom/p4600.cfg (added) * make/custom/p4650.cfg (added) * make/custom/papyrus.cfg (added) * make/custom/pc386.cfg (added) * make/custom/portsw.cfg (added) * make/custom/posix.cfg (added) * make/custom/simhppa.cfg (added) * make/directory.cfg (added) * make/host.cfg.in (added) * make/leaf.cfg (added) * make/lib.cfg (added) * make/main.cfg (added) * make/target.cfg.in (added) Removed PROJECT_HOME and CONFIG_DIR variables.
