@98fd415
03/20/14 21:19:22 |
Joel Sherrill |
relnotes/status.texi: Update to Bugzilla
4.115
@0b7e5f75
03/20/14 21:18:34 |
Joel Sherrill |
HELP.html Makefile.am: Remove unused HELP.html
4.115
@0dd02c68
03/20/14 21:17:24 |
Joel Sherrill |
cpright.texi: Update to reflect services and community
4.115
@a86d13a
03/20/14 16:57:53 |
Joel Sherrill |
texi2html_init.in: Reword rtems.com to rtems.org
4.115
@f5bbc042
03/20/14 21:16:39 |
Joel Sherrill |
started/buildc.t: Change CVS to Git
4.115
@df40cc9
03/20/14 21:16:02 |
Joel Sherrill |
started/buildrt.t: Change CVS to Git
4.115
@c499856
03/20/14 21:10:47 |
Chris Johns |
Change all references of rtems.com to rtems.org.
4.115
@6cd4a5c
03/19/14 16:17:39 |
Christian.Mauderer |
cpukit/shell: Replace task variables with posix keys.
Use posix keys …
4.115
@0bf59cf
03/12/14 08:23:34 |
Sebastian Huber |
Add documentation for profiling
4.115
@2aeeaa0
03/10/14 14:47:06 |
Joel Sherrill |
doc: Improve description of rtems_status_text for ToC
4.115
@89e72a80
03/10/14 16:35:16 |
Joel Sherrill |
smp.t: Add Background and Operation Sections
4.115
@d46ab11b
03/07/14 19:20:04 |
Joel Sherrill |
Classic API Users Guide: Add SMP and affinity services.
This patch …
4.115
@4013d25
03/07/14 19:18:40 |
Joel Sherrill |
POSIX Users Guide: Add thread affinity services.
4.115
@30d11766
03/11/14 20:08:54 |
Joel Sherrill |
stackchk.t task.t: Change can not to cannot for consistency
4.115
@48198f1b
03/07/14 21:00:37 |
Joel Sherrill |
cpright.texi: Update to 2014.
4.115
@653ed5e
03/07/14 19:18:03 |
Joel Sherrill |
gen_section: Update for use with new SMP chapters.
4.115
@24bf11e
02/12/14 09:31:38 |
Sebastian Huber |
score: Add CPU counter support
Add a CPU counter interface to allow …
4.115
@bab16de2
02/07/14 08:53:47 |
Sebastian Huber |
score: Change debug helper functions
Rename …
4.115
@920a43e
02/05/14 16:00:09 |
Sebastian Huber |
rtems: Add rtems_status_code_description()
4.115
@022851a
01/28/14 11:10:08 |
Sebastian Huber |
Add thread-local storage (TLS) support
Tested and implemented on ARM, …
4.115
@2d1bdc8
12/24/13 05:38:42 |
Chris Johns |
cpukit/rtems: Add rtems_clock_get_uptime_nanoseconds to the RTEMS API. …
4.115
@259328a7
12/16/13 00:59:51 |
Chris Johns |
cpukit/shell: Control help break with SHELL_LINES env variable.
4.115
@98b9a3b
12/05/13 15:16:11 |
sahil.patnayakuni |
doc/posix_users: add notes and descriptions for pthread_key functions
4.115
@5124d64
11/20/13 21:25:43 |
Joel Sherrill |
sparc.t: Correct for V8/V9
4.115
@e4ced53
10/15/13 17:14:13 |
shubhamsomani92 |
doc: Document format in conf.t
4.115
@8ac962e
09/17/13 17:44:08 |
Vipul Nayyar |
bsp_howto/support.t: Add PIC Interrupt Model API Information
4.115
@99b3505
08/07/13 13:35:47 |
Sebastian Huber |
smp: Add Deterministic Priority SMP Scheduler
4.115
@540e8603
08/14/13 09:06:16 |
Sebastian Huber |
documentation: Directives allowed from an ISR
Update list.
4.115
@45ca51c
07/29/13 18:03:30 |
shubhamsomani92 |
doc/user/conf.t: More clean ups
4.115
@989604a5
07/24/13 20:30:24 |
Joel Sherrill |
conf.t: Fix minor typos.
4.115
@3c495d51
07/24/13 18:06:26 |
cynt6007 |
doc/user/conf.t: Fix SMP_MAXIMUM_PROCESSORS and add Go configuration
4.115
@1f6138e5
07/22/13 23:30:07 |
cynt6007 |
doc/user/conf.t: Fix SMP_MAXIMUM_PROCESSORS and add Go Configuration
4.115
@b885fe1
07/22/13 23:29:49 |
Joel Sherrill |
doc/shell/Makefile.am: Fix dependency
4.115
@873859a4
06/09/13 02:13:00 |
cynt6007 |
Make the default values easier for the configuration GUI to parse
4.115
@fed92f5f
06/10/13 12:36:44 |
Sebastian Huber |
termios: Notify driver about inactive transmit
Returning this state …
4.115
@c7bc6d4
06/10/13 09:14:35 |
Sebastian Huber |
rtems: Add interrupt locks
Interrupt locks are low-level lock to …
4.115
@7bb71c7
05/16/13 09:24:09 |
Andrey Mozzhuhin |
shell: Add df command
4.115
@39993d6
05/07/13 08:14:55 |
Sebastian Huber |
score: Add CPU context validation
4.115
@14c55cc
04/10/13 12:42:26 |
Sebastian Huber |
doc: Config documentation changes throughout
4.115
@a6a88f4
04/10/13 13:46:54 |
Sebastian Huber |
doc: Add bdbuf configuration options
4.115
@b2cf295f
04/09/13 16:56:11 |
Joel Sherrill |
user/conf.t: Address User Feedback from Stephen Tether
Stephen Tether …
4.115
@034483dc
04/09/13 16:55:12 |
Joel Sherrill |
user/overview.t: Fix broken cross reference
4.115
@6cb3567
03/09/13 13:43:03 |
Joel Sherrill |
doc/user/conf.t: Rewrite to emphasize confdefs.h and add detail
This …
4.115
@76e8683
03/11/13 22:11:48 |
Joel Sherrill |
doc/texi2html_init.in: Correct typo
4.115
@c5e76b0
03/11/13 22:11:21 |
Joel Sherrill |
doc/texi2any_init.in: Correct link to Library index.html
4.115
@68286f3
03/11/13 22:10:51 |
Joel Sherrill |
doc/main.am: Tweak TEXI2ANY_ARGS to make HTML menus look better
4.115
@ba07fee
03/11/13 20:32:05 |
Joel Sherrill |
doc/texi2html_init.in: Update copyright on html output
4.115
@f3bf8235
03/11/13 20:22:41 |
Joel Sherrill |
doc/project.am: texi2html invocation had file name twice
4.115
@0322a4f
03/11/13 20:22:05 |
Joel Sherrill |
doc/main.am: TEXI2HTML_ARGS macro clean up
4.115
@fad2d38
03/08/13 20:55:06 |
Gedare Bloom |
RTEMS: Delete ChangeLog? files.
This commit deletes all RTEMS …
4.115
@83b555f
02/26/13 18:49:29 |
Joel Sherrill |
doc: Build html into subdirectory (fix make clean)
Building with a …
4.115
@9215bfb3
02/25/13 23:54:24 |
Joel Sherrill |
user/preface.texi: Add NEC V850 and SPARC V9
4.115
@a26834d2
02/25/13 23:34:04 |
Joel Sherrill |
user/overview.t: Add missing chapters to overview
4.115
@4eaf781
02/25/13 21:23:59 |
Joel Sherrill |
doc master include files: Do not include top node on printed output
4.115
@e0bf787
02/25/13 17:55:45 |
Joel Sherrill |
doc/project.am: Make texi2html and texi2any stanzas share
4.115
@941e345
02/25/13 17:54:39 |
Joel Sherrill |
doc: Update copyright year in common files
4.115
@838bfb6
02/25/13 17:52:04 |
Joel Sherrill |
doc: Update version.texi and stamp-vti files
See …
4.115
@df0ec89
02/24/13 16:07:40 |
Joel Sherrill |
doc/user Object Id Figures: Correct rotation and border
The 16 bit …
4.115
@3695c588
02/25/13 20:03:09 |
Joel Sherrill |
doc/user/semaphore_attributes.eps: Correct rotation
4.115
@380daa25
02/22/13 22:02:23 |
Joel Sherrill |
doc/c_user: Fix Lines that were too long
4.115
@0c59b4b
02/22/13 19:43:12 |
Joel Sherrill |
doc: Use More Readable Names for Generated Nodes
Per a discussion …
4.115
@94ca070
02/22/13 01:19:48 |
Joel Sherrill |
doc: Support texi2any and texi2html
This was tested with …
4.115
@b6ecf33
02/21/13 14:53:11 |
Joel Sherrill |
doc: Update to build info format with texinfo 4.13 and 5.0
Texinfo …
4.115
@f2448903
02/26/13 07:10:34 |
Ralf Corsepius |
Add missing @item.
4.115
@a420a489
02/26/13 07:10:16 |
Ralf Corsepius |
Add missing @items.
4.115
@609cc9c
02/25/13 14:58:50 |
Ralf Corsepius |
Fix typo.
4.115
@baa60b5e
02/12/13 10:25:25 |
Sebastian Huber |
make: Remove -qrtems_debug flag usage
4.115
@7571a23
01/27/13 14:10:39 |
Sebastian Huber |
sapi: PR1911: Add CONFIGURE_DISABLE_BSP_SETTINGS
4.115
@f2f39b62
01/07/13 15:01:45 |
Sebastian Huber |
sapi: Add rtems_fatal_source_description()
4.115
@cbd07e4
12/21/12 08:50:15 |
Sebastian Huber |
score: Add rtems_chain_node_count_unprotected()
4.115
@48bff53b
12/06/12 16:47:30 |
Sebastian Huber |
score: rtems_initialize_start_multitasking()
Do not return from …
4.115
@815994f
11/25/12 16:48:11 |
Sebastian Huber |
score: Add CPU_Exception_frame
Add CPU port type CPU_Exception_frame …
4.115
@1906a36
11/18/12 18:51:10 |
Sebastian Huber |
score: Change _Internal_error_Occurred()
Call the fatal handlers of …
4.115
@90733a86
11/16/12 13:14:03 |
Sebastian Huber |
rtems: Add rtems_clock_get_uptime_seconds()
4.115
@bfddb047
11/16/12 13:02:12 |
Sebastian Huber |
rtems: Add rtems_clock_get_uptime_timeval()
4.115
@e2e5b492
11/14/12 08:51:41 |
Sebastian Huber |
score: Add rtems_fatal()
4.115
@dc6e830
11/13/12 16:40:33 |
Sebastian Huber |
sapi: Add and use rtems_internal_error_description
4.115
@15aaea97
11/07/12 16:09:01 |
Sebastian Huber |
doc/user: Fix scheduler configuration
4.115
@47a3cd8
08/09/12 14:48:00 |
Sebastian Huber |
score: Work area initialization API change
The work areas (RTEMS work …
4.115
@880e2f37
10/02/12 16:45:09 |
Joel Sherrill |
User's Guide: Correct typos in return status bullets
4.115
@66dacbfb
08/30/12 23:38:50 |
joel |
timespec: Add documentation for struct timespec Helpers
Joel editted …
4.115
@bb2b825
07/19/12 13:47:55 |
Ralf Corsepius |
Require automake-1.12.2.
4.115
@0f77281
07/19/12 13:44:32 |
Ralf Corsepius |
Require autoconf-2.69.
4.115
@2d7ae960
06/11/12 18:37:29 |
Joel Sherrill |
v850 port: Initial addition with BSP for simulator in GDB
Port
4.115
@65c6425
05/03/12 17:24:46 |
Joel Sherrill |
Remove CVS Id Strings (manual edits after script)
These modifications …
4.115
@9b4422a2
05/03/12 15:09:24 |
Joel Sherrill |
Remove All CVS Id Strings Possible Using a Script
Script does what is …
4.115
@33a105fb
05/07/12 16:08:48 |
Joel Sherrill |
Revert: Remove CVS Ids
See …
4.115
@9847d61d
05/04/12 06:58:25 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@f8e57718
05/04/12 06:58:21 |
Ralf Corsepius |
Remove CVS-Ids.
4.115
@cfaa366
05/03/12 17:55:58 |
Joel Sherrill |
General - Remove extraneous blank line in license message
Many files …
4.115
@bce41f4
04/15/12 17:54:10 |
Petr Benes |
PR 1912: Add Scheduler Documentation
Add new file for CBS documentation.
4.115
@7cc2199
04/15/12 17:50:11 |
Petr Benes |
Adds documentation on the …
4.115
@ced0816
04/11/12 14:29:28 |
Sebastian Huber |
doc: Document new macros
4.115
@e53aae2
03/26/12 20:42:38 |
Gedare Bloom |
confdefs: Add declaration for unlimited objects.
Adds to confdefs a …
4.115
@935ae4a
02/03/12 21:49:44 |
Joel Sherrill |
Update copyright year on manuals to 2012.
4.115
@6d1a1d3
02/02/12 21:02:16 |
Joel Sherrill |
PR 2012 - mdump/wdump shell cmds handle length arg incorrectly; add …
4.115
@61250b4
02/01/12 16:59:44 |
Joel Sherrill |
Remove all .cvsignore files.
4.115
@2571c79e
12/09/11 15:20:14 |
Ralf Corsepius |
2011-12-09 Ralf Corsépius <ralf.corsepius@…>
* project.am …
4.115
@e6584da
12/07/11 20:08:42 |
Joel Sherrill |
2011-12-07 Joel Sherrill <joel.sherrilL@…>
PR 1984/doc
4.115
@a756eff
12/07/11 20:04:05 |
Joel Sherrill |
2011-12-07 Joel Sherrill <joel.sherrill@…>
* user/conf.t: …
4.115
