# # ChangeLog for doc in rtems # # Generated by Trac 1.2.1.dev0 # 05/21/24 12:24:08 Fri, 27 Mar 1998 20:50:31 GMT Joel Sherrill [fb94e65] * doc/user/Makefile (modified) Added dependency so html would build from scratch. Fri, 27 Mar 1998 20:50:14 GMT Joel Sherrill [0a702cfb] * doc/index.html (modified) Corrected by adding "end markers". Fri, 27 Mar 1998 18:53:17 GMT Joel Sherrill [20515fc] * doc/user/Makefile (modified) * doc/user/bsp.t (modified) * doc/user/clock.t (modified) * doc/user/concepts.t (modified) * doc/user/conf.t (modified) * doc/user/dirstat.texi (modified) * doc/user/dpmem.t (modified) * doc/user/event.t (modified) * doc/user/fatal.t (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/overview.t (modified) * doc/user/part.t (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) Nodes, menus, etc are automatically generated now Fri, 27 Mar 1998 17:34:25 GMT Joel Sherrill [1f020c6] * doc/do_docs (modified) Renamed extra_manuals to oar_manuals. Fri, 27 Mar 1998 17:30:42 GMT Joel Sherrill [9809ab1e] * doc/rtems_footer.html (modified) Removed ruler line since it is automatically inserted now along with ... Fri, 27 Mar 1998 16:49:23 GMT Joel Sherrill [e8f7f83] * doc/tools/update (modified) Localized for use in doc tree. Fri, 27 Mar 1998 16:48:50 GMT Joel Sherrill [b753a345] * doc/ada_user/ada_user.texi (modified) Added directive and constant prefixes. Fri, 27 Mar 1998 16:47:53 GMT Joel Sherrill [75e22db] * doc/user/bsp.t (modified) * doc/user/clock.t (modified) * doc/user/conf.t (modified) * doc/user/dpmem.t (modified) * doc/user/event.t (modified) * doc/user/example.texi (modified) * doc/user/fatal.t (modified) * doc/user/glossary.texi (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/part.t (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) Completed sweep adding directive and constant prefixes. Fri, 27 Mar 1998 13:24:52 GMT Joel Sherrill [f331481c] * doc/user/dpmem.t (modified) * doc/user/event.t (modified) * doc/user/fatal.t (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/part.t (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) Conditionally adding RTEMS_ and rtems_ prefixes. Fri, 27 Mar 1998 13:24:21 GMT Joel Sherrill [4fa4ea65] * doc/user/bsp.t (modified) * doc/user/c_user.texi (modified) * doc/user/clock.t (modified) * doc/user/conf.t (modified) * doc/user/dirstat.texi (modified) * doc/user/preface.texi (modified) Added Hitachi SH Fri, 27 Mar 1998 13:04:02 GMT Joel Sherrill [a3a7527] * doc/user/c_user.texi (modified) * doc/user/event.t (modified) * doc/user/intr.t (modified) * doc/user/msg.t (modified) * doc/user/region.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) Attempting to add variable so that in C all constants start with ... Fri, 27 Mar 1998 11:53:51 GMT Joel Sherrill [0ef0ff2] * doc/do_docs (modified) Added POSIX 1003.1h and PowerPC supplement to internal manuals. Thu, 26 Mar 1998 20:47:42 GMT Joel Sherrill [fad4de2b] * doc/supplements/sh/callconv.texi (added) New file. Basically m68k version with Hitachi SH comments thrown in. Thu, 26 Mar 1998 20:44:35 GMT Joel Sherrill [54fc6fe] * doc/do_docs (modified) The script did not handle public distributions at all. Thu, 26 Mar 1998 20:40:34 GMT Joel Sherrill [433a01b] * doc/do_docs (modified) Added support for easily building different sets of the manuals for ... Thu, 26 Mar 1998 20:34:38 GMT Joel Sherrill [7c8c767] * doc/Make.config (modified) Better handling of local documentation tools and corrected invocation ... Thu, 26 Mar 1998 20:33:56 GMT Joel Sherrill [5a348d3] * doc/HELP.html (modified) Updated for SH port and variable insertion of version. Thu, 26 Mar 1998 20:33:27 GMT Joel Sherrill [bc0307e] * doc/Makefile (modified) Added build of tools to build procedure. Automatically insert ... Thu, 26 Mar 1998 20:32:41 GMT Joel Sherrill [c027242] * doc/index.html (moved) rtems.html renamed index.html since that is what httpd looks for ... Thu, 26 Mar 1998 20:31:13 GMT Joel Sherrill [090f1a4] * doc/do_docs (modified) Attempt at separating public, support, partners, and internal. Thu, 26 Mar 1998 20:30:52 GMT Joel Sherrill [8a8b7519] * doc/ada_user/ada_user.texi (modified) * doc/common/setup.texi (modified) * doc/develenv/develenv.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/rtems_footer.html (modified) * doc/rtems_header.html (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/powerpc/powerpc.texi (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/user/c_user.texi (modified) Added variables for dates and revision info Thu, 26 Mar 1998 20:30:01 GMT Joel Sherrill [9cb1040c] * doc/posix1003.1/preface.texi (modified) Enhanced. Thu, 26 Mar 1998 20:29:49 GMT Joel Sherrill [2e9dfd59] * doc/posix1003.1/Makefile (modified) Installed in partners subdirectory Thu, 26 Mar 1998 20:29:08 GMT Joel Sherrill [b317e78c] * doc/tools/bmenu/main.c (modified) removed @ifinfo around something needed for html structure Thu, 26 Mar 1998 20:28:13 GMT Joel Sherrill [e8b63db4] * doc/develenv/Makefile (modified) Do not copy headers, use make Thu, 26 Mar 1998 17:16:53 GMT Joel Sherrill [9ec289ca] * doc/rtems.html (modified) More appropriate for public consumption Thu, 26 Mar 1998 17:15:03 GMT Joel Sherrill [3c7117d] * doc/rtems.html (modified) Made more appropriate for public consumption. Thu, 26 Mar 1998 17:10:03 GMT Joel Sherrill [fb9a80f] * doc/new_chapters/Makefile (modified) * doc/new_chapters/posix_users.texi (moved) * doc/new_chapters/preface.texi (modified) * doc/posix_users/Makefile (modified) * doc/posix_users/posix_users.texi (moved) * doc/posix_users/preface.texi (modified) renamed to user's guide. Wed, 25 Mar 1998 18:36:19 GMT Joel Sherrill [059dbcf] * doc/develenv/direct.texi (modified) Added group and example around tree pictures in html. Wed, 18 Mar 1998 18:15:01 GMT Joel Sherrill [7331714] * doc/posix1003.1/Makefile (modified) * doc/posix1003.1/ch02.t (modified) * doc/posix1003.1/ch03.t (modified) * doc/posix1003.1/ch04.t (modified) * doc/posix1003.1/ch05.t (modified) * doc/posix1003.1/ch06.t (modified) * doc/posix1003.1/ch07.t (modified) * doc/posix1003.1/ch08.t (modified) * doc/posix1003.1/ch10.t (modified) * doc/posix1003.1/ch11.t (modified) * doc/posix1003.1/ch12.t (modified) * doc/posix1003.1/ch13.t (modified) * doc/posix1003.1/ch14.t (modified) * doc/posix1003.1/ch15.t (modified) * doc/posix1003.1/ch16.t (modified) * doc/posix1003.1/ch18.t (modified) * doc/posix1003.1/summarize (modified) Added Constants, Feature Flags, and Macros (included in Functions). ... Tue, 17 Mar 1998 23:10:33 GMT Joel Sherrill [c78be42] * doc/posix1003.1/Makefile (modified) * doc/posix1003.1/ch01.t (modified) * doc/posix1003.1/ch02.t (modified) * doc/posix1003.1/ch08.t (modified) * doc/posix1003.1/summarize (modified) First attempt at adding constants and feature flags Tue, 17 Mar 1998 18:50:14 GMT Joel Sherrill [6984a19] * doc/posix1003.1/ch02.t (modified) * doc/posix1003.1/ch03.t (modified) * doc/posix1003.1/ch04.t (modified) * doc/posix1003.1/ch05.t (modified) * doc/posix1003.1/ch06.t (modified) * doc/posix1003.1/ch08.t (modified) * doc/posix1003.1/ch09.t (modified) * doc/posix1003.1/ch10.t (modified) * doc/posix1003.1/ch11.t (modified) * doc/posix1003.1/ch13.t (modified) * doc/posix1003.1/ch15.t (modified) * doc/posix1003.1/posix1003_1.texi (modified) Completed status pass on functions and data types. Tue, 17 Mar 1998 16:37:57 GMT Joel Sherrill [3cffce87] * doc/posix1003.1/ch11.t (modified) * doc/posix1003.1/ch12.t (modified) * doc/posix1003.1/ch13.t (modified) * doc/posix1003.1/ch14.t (modified) * doc/posix1003.1/ch15.t (modified) * doc/posix1003.1/ch16.t (modified) * doc/posix1003.1/ch17.t (modified) * doc/posix1003.1/ch18.t (modified) * doc/posix1003.1/summarize (modified) Completed first pass at function status. Added most data types ... Mon, 16 Mar 1998 22:43:37 GMT Joel Sherrill [2a087f3] * doc/posix1003.1/ch04.t (modified) * doc/posix1003.1/ch05.t (modified) * doc/posix1003.1/ch06.t (modified) * doc/posix1003.1/ch07.t (modified) * doc/posix1003.1/ch08.t (modified) * doc/posix1003.1/ch09.t (modified) * doc/posix1003.1/ch10.t (modified) * doc/posix1003.1/ch11.t (modified) * doc/posix1003.1/summarize (modified) Added types, status of functions, cleaned up output of summarize. Mon, 16 Mar 1998 18:08:38 GMT Joel Sherrill [3349409] * doc/posix1003.1/ch02.t (modified) * doc/posix1003.1/ch03.t (modified) * doc/posix1003.1/ch04.t (modified) Added function status and data types Mon, 16 Mar 1998 18:08:25 GMT Joel Sherrill [aedf452] * doc/posix1003.1/summarize (modified) Cleaned up format and added data types. Mon, 16 Mar 1998 17:08:52 GMT Joel Sherrill [34683fee] * doc/posix1003.1/ch03.t (modified) * doc/posix1003.1/ch04.t (modified) * doc/posix1003.1/ch05.t (modified) * doc/posix1003.1/ch06.t (modified) * doc/posix1003.1/ch07.t (modified) * doc/posix1003.1/ch08.t (modified) * doc/posix1003.1/ch09.t (modified) * doc/posix1003.1/ch11.t (modified) * doc/posix1003.1/ch12.t (modified) * doc/posix1003.1/ch13.t (modified) * doc/posix1003.1/ch14.t (modified) * doc/posix1003.1/ch15.t (modified) * doc/posix1003.1/ch16.t (modified) * doc/posix1003.1/ch17.t (modified) * doc/posix1003.1/ch18.t (modified) Added Function field. Mon, 16 Mar 1998 17:06:12 GMT Joel Sherrill [53d804ff] * doc/posix1003.1/Makefile (modified) * doc/posix1003.1/summarize (modified) summarize now generates a nicely formatted function status summary. Mon, 16 Mar 1998 17:05:47 GMT Joel Sherrill [4936b65] * doc/posix1003.1/ch03.t (modified) Function implmentation status information correct. Mon, 16 Mar 1998 16:15:32 GMT Joel Sherrill [e7acb60] * doc/posix1003.1/Makefile (modified) * doc/posix1003.1/posix1003_1.texi (modified) * doc/posix1003.1/summarize (modified) First time summary chapter is included in the document. Sat, 14 Mar 1998 18:06:27 GMT Joel Sherrill [17ab8f5b] * doc/posix1003.1/ch01.t (modified) * doc/posix1003.1/ch02.t (modified) Added blank lines. Sat, 14 Mar 1998 18:06:08 GMT Joel Sherrill [2071990] * doc/posix1003.1/Makefile (modified) Added summary chapter. Sat, 14 Mar 1998 18:05:51 GMT Joel Sherrill [22c9e0e] * doc/posix1003.1/summarize (added) New file. Sat, 14 Mar 1998 17:43:56 GMT Joel Sherrill [5e53171d] * doc/posix1003.1/ch12.t (modified) * doc/posix1003.1/ch13.t (modified) * doc/posix1003.1/ch14.t (modified) * doc/posix1003.1/ch15.t (modified) * doc/posix1003.1/ch16.t (modified) * doc/posix1003.1/ch17.t (modified) * doc/posix1003.1/ch18.t (modified) Added functions from POSIX standard. Sat, 14 Mar 1998 17:09:27 GMT Joel Sherrill [76fa649] * doc/posix1003.1/ch09.t (modified) * doc/posix1003.1/ch10.t (modified) * doc/posix1003.1/ch11.t (modified) Added functions from POSIX standard. Sat, 14 Mar 1998 16:33:20 GMT Joel Sherrill [24331760] * doc/posix1003.1/ch09.t (modified) Added copyright header Sat, 14 Mar 1998 16:31:11 GMT Joel Sherrill [0874502] * doc/posix1003.1/ch03.t (modified) * doc/posix1003.1/ch04.t (modified) * doc/posix1003.1/ch05.t (modified) * doc/posix1003.1/ch06.t (modified) * doc/posix1003.1/ch07.t (modified) * doc/posix1003.1/ch08.t (modified) * doc/posix1003.1/posix1003_1.texi (modified) Added functions from POSIX standard. Wed, 11 Mar 1998 22:56:23 GMT Joel Sherrill [68feecfd] * doc/posix1003.1/Makefile (modified) * doc/posix1003.1/ch04.t (modified) * doc/posix1003.1/ch05.t (modified) * doc/posix1003.1/ch07.t (modified) * doc/posix1003.1/ch09.t (modified) * doc/posix1003.1/ch10.t (modified) * doc/posix1003.1/ch11.t (modified) * doc/posix1003.1/ch12.t (modified) * doc/posix1003.1/ch13.t (modified) * doc/posix1003.1/ch14.t (modified) * doc/posix1003.1/ch15.t (modified) * doc/posix1003.1/ch16.t (modified) * doc/posix1003.1/ch17.t (modified) * doc/posix1003.1/ch18.t (modified) * doc/posix1003.1/posix1003_1.texi (modified) * doc/posix1003.1/preface.texi (modified) Outline complete and apparently correct. Wed, 11 Mar 1998 22:06:41 GMT Joel Sherrill [2d19ed6c] * doc/posix1003.1/Makefile (added) * doc/posix1003.1/ch01.t (added) * doc/posix1003.1/ch02.t (added) * doc/posix1003.1/ch03.t (added) * doc/posix1003.1/ch04.t (added) * doc/posix1003.1/ch05.t (added) * doc/posix1003.1/ch06.t (added) * doc/posix1003.1/ch07.t (added) * doc/posix1003.1/ch08.t (added) * doc/posix1003.1/ch09.t (added) * doc/posix1003.1/ch10.t (added) * doc/posix1003.1/ch11.t (added) * doc/posix1003.1/ch12.t (added) * doc/posix1003.1/ch13.t (added) * doc/posix1003.1/ch14.t (added) * doc/posix1003.1/ch15.t (added) * doc/posix1003.1/ch16.t (added) * doc/posix1003.1/ch17.t (added) * doc/posix1003.1/ch18.t (added) * doc/posix1003.1/posix1003_1.texi (added) * doc/posix1003.1/preface.texi (added) Baseline Wed, 11 Feb 1998 15:03:38 GMT Joel Sherrill [c2c5fc2] * doc/tools/pdl2texi/test_cases/enum.d (added) * doc/tools/pdl2texi/test_cases/enumbad.d (added) new test cases Wed, 11 Feb 1998 14:58:23 GMT Joel Sherrill [94a6c986] * doc/Make.config (modified) * doc/do_docs (modified) new directory structure for hwapi Wed, 11 Feb 1998 14:50:49 GMT Joel Sherrill [7175b59] * doc/do_docs (modified) hwapi added Wed, 11 Feb 1998 14:50:31 GMT Joel Sherrill [9aceddaf] * doc/supplements/powerpc/bsp.t (modified) * doc/supplements/powerpc/bsp.texi (modified) * doc/supplements/powerpc/callconv.t (modified) * doc/supplements/powerpc/callconv.texi (modified) * doc/supplements/powerpc/cpumodel.t (modified) * doc/supplements/powerpc/cpumodel.texi (modified) * doc/supplements/powerpc/cputable.t (modified) * doc/supplements/powerpc/cputable.texi (modified) * doc/supplements/powerpc/fatalerr.t (modified) * doc/supplements/powerpc/fatalerr.texi (modified) * doc/supplements/powerpc/intr.t (modified) * doc/supplements/powerpc/intr_NOTIMES.t (modified) * doc/supplements/powerpc/memmodel.t (modified) * doc/supplements/powerpc/memmodel.texi (modified) * doc/supplements/powerpc/preface.texi (modified) * doc/supplements/sparc/bsp.t (modified) * doc/supplements/sparc/bsp.texi (modified) updates Fri, 06 Feb 1998 14:14:30 GMT Joel Sherrill [1e524995] * doc/HELP.html (modified) * doc/ada_user/Makefile (modified) * doc/ada_user/ada_user.texi (modified) * doc/ada_user/example.texi (modified) * doc/common/cpright.texi (modified) * doc/common/setup.texi (modified) * doc/common/timemac.texi (modified) * doc/common/timetbl.t (modified) * doc/common/timing.texi (modified) * doc/common/wksheets.t (modified) * doc/develenv/Makefile (modified) * doc/develenv/compile.texi (modified) * doc/develenv/develenv.texi (modified) * doc/develenv/direct.texi (modified) * doc/develenv/intro.texi (modified) * doc/develenv/sample.texi (modified) * doc/develenv/utils.texi (modified) * doc/new_chapters/Makefile (modified) * doc/new_chapters/base.texi (modified) * doc/new_chapters/clock.texi (modified) * doc/new_chapters/cond.texi (modified) * doc/new_chapters/key.texi (modified) * doc/new_chapters/mutex.texi (modified) * doc/new_chapters/posix_test_plan.texi (modified) * doc/new_chapters/preface.texi (modified) * doc/new_chapters/sched.texi (modified) * doc/new_chapters/signal.texi (modified) * doc/new_chapters/thread.texi (modified) * doc/posix_users/Makefile (modified) * doc/posix_users/base.texi (modified) * doc/posix_users/clock.texi (modified) * doc/posix_users/cond.texi (modified) * doc/posix_users/key.texi (modified) * doc/posix_users/mutex.texi (modified) * doc/posix_users/posix_test_plan.texi (modified) * doc/posix_users/preface.texi (modified) * doc/posix_users/sched.texi (modified) * doc/posix_users/signal.texi (modified) * doc/posix_users/thread.texi (modified) * doc/relnotes/Makefile (modified) * doc/relnotes/install.texi (modified) * doc/relnotes/intro.texi (modified) * doc/relnotes/probrep.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/relnotes/status.texi (modified) * doc/rtems.html (modified) * doc/rtems_footer.html (modified) * doc/supplements/hppa1_1/Makefile (modified) * doc/supplements/hppa1_1/bsp.t (modified) * doc/supplements/hppa1_1/bsp.texi (modified) * doc/supplements/hppa1_1/callconv.t (modified) * doc/supplements/hppa1_1/callconv.texi (modified) * doc/supplements/hppa1_1/cpumodel.t (modified) * doc/supplements/hppa1_1/cpumodel.texi (modified) * doc/supplements/hppa1_1/cputable.t (modified) * doc/supplements/hppa1_1/cputable.texi (modified) * doc/supplements/hppa1_1/fatalerr.t (modified) * doc/supplements/hppa1_1/fatalerr.texi (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/hppa1_1/intr.t (modified) * doc/supplements/hppa1_1/intr_NOTIMES.t (modified) * doc/supplements/hppa1_1/memmodel.t (modified) * doc/supplements/hppa1_1/memmodel.texi (modified) * doc/supplements/hppa1_1/preface.texi (modified) * doc/supplements/hppa1_1/timedata.t (modified) * doc/supplements/i386/Makefile (modified) * doc/supplements/i386/bsp.t (modified) * doc/supplements/i386/bsp.texi (modified) * doc/supplements/i386/callconv.t (modified) * doc/supplements/i386/callconv.texi (modified) * doc/supplements/i386/cpumodel.t (modified) * doc/supplements/i386/cpumodel.texi (modified) * doc/supplements/i386/cputable.t (modified) * doc/supplements/i386/cputable.texi (modified) * doc/supplements/i386/fatalerr.t (modified) * doc/supplements/i386/fatalerr.texi (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i386/intr.t (modified) * doc/supplements/i386/intr_NOTIMES.t (modified) * doc/supplements/i386/memmodel.t (modified) * doc/supplements/i386/memmodel.texi (modified) * doc/supplements/i386/preface.texi (modified) * doc/supplements/i386/timeFORCE386.t (modified) * doc/supplements/i386/timedata.t (modified) * doc/supplements/i960/Makefile (modified) * doc/supplements/i960/bsp.t (modified) * doc/supplements/i960/bsp.texi (modified) * doc/supplements/i960/callconv.t (modified) * doc/supplements/i960/callconv.texi (modified) * doc/supplements/i960/cpumodel.t (modified) * doc/supplements/i960/cpumodel.texi (modified) * doc/supplements/i960/cputable.t (modified) * doc/supplements/i960/cputable.texi (modified) * doc/supplements/i960/fatalerr.t (modified) * doc/supplements/i960/fatalerr.texi (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/i960/intr.t (modified) * doc/supplements/i960/intr_NOTIMES.t (modified) * doc/supplements/i960/memmodel.t (modified) * doc/supplements/i960/memmodel.texi (modified) * doc/supplements/i960/preface.texi (modified) * doc/supplements/i960/timeCVME961.t (modified) * doc/supplements/i960/timedata.t (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/m68k/bsp.t (modified) * doc/supplements/m68k/callconv.t (modified) * doc/supplements/m68k/cpumodel.t (modified) * doc/supplements/m68k/cputable.t (modified) * doc/supplements/m68k/fatalerr.t (modified) * doc/supplements/m68k/intr_NOTIMES.t (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/m68k/memmodel.t (modified) * doc/supplements/m68k/preface.texi (modified) * doc/supplements/m68k/timeMVME136.t (modified) * doc/supplements/m68k/timedata.t (modified) * doc/supplements/powerpc/Makefile (modified) * doc/supplements/powerpc/bsp.t (modified) * doc/supplements/powerpc/bsp.texi (modified) * doc/supplements/powerpc/callconv.t (modified) * doc/supplements/powerpc/callconv.texi (modified) * doc/supplements/powerpc/cpumodel.t (modified) * doc/supplements/powerpc/cpumodel.texi (modified) * doc/supplements/powerpc/cputable.t (modified) * doc/supplements/powerpc/cputable.texi (modified) * doc/supplements/powerpc/fatalerr.t (modified) * doc/supplements/powerpc/fatalerr.texi (modified) * doc/supplements/powerpc/intr.t (modified) * doc/supplements/powerpc/intr_NOTIMES.t (modified) * doc/supplements/powerpc/memmodel.t (modified) * doc/supplements/powerpc/memmodel.texi (modified) * doc/supplements/powerpc/powerpc.texi (modified) * doc/supplements/powerpc/preface.texi (modified) * doc/supplements/powerpc/timePSIM.t (modified) * doc/supplements/powerpc/timedata.t (modified) * doc/supplements/sparc/Makefile (modified) * doc/supplements/sparc/bsp.t (modified) * doc/supplements/sparc/bsp.texi (modified) * doc/supplements/sparc/callconv.t (modified) * doc/supplements/sparc/callconv.texi (modified) * doc/supplements/sparc/cpumodel.t (modified) * doc/supplements/sparc/cpumodel.texi (modified) * doc/supplements/sparc/cputable.t (modified) * doc/supplements/sparc/cputable.texi (modified) * doc/supplements/sparc/fatalerr.t (modified) * doc/supplements/sparc/fatalerr.texi (modified) * doc/supplements/sparc/intr.t (modified) * doc/supplements/sparc/intr_NOTIMES.t (modified) * doc/supplements/sparc/memmodel.t (modified) * doc/supplements/sparc/memmodel.texi (modified) * doc/supplements/sparc/preface.texi (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/supplements/sparc/timeERC32.t (modified) * doc/supplements/sparc/timedata.t (modified) * doc/tools/bmenu/Makefile (modified) * doc/tools/bmenu/address.h (modified) * doc/tools/bmenu/address.inl (modified) * doc/tools/bmenu/base.h (modified) * doc/tools/bmenu/chain.c (modified) * doc/tools/bmenu/chain.h (modified) * doc/tools/bmenu/chain.inl (modified) * doc/tools/bmenu/isr.h (modified) * doc/tools/bmenu/main.c (modified) * doc/tools/bmenu/system.h (modified) * doc/user/Makefile (modified) * doc/user/bsp.t (modified) * doc/user/c_user.texi (modified) * doc/user/clock.t (modified) * doc/user/concepts.t (modified) * doc/user/conf.t (modified) * doc/user/dirstat.texi (modified) * doc/user/dpmem.t (modified) * doc/user/event.t (modified) * doc/user/example.texi (modified) * doc/user/fatal.t (modified) * doc/user/glossary.texi (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/overview.t (modified) * doc/user/part.t (modified) * doc/user/preface.texi (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) Updated copyrights Fri, 06 Feb 1998 13:48:44 GMT Joel Sherrill [5599d6e] * doc/tools/pdl2texi/Makefile (modified) * doc/tools/pdl2texi/main.c (modified) * doc/tools/pdl2texi/test_cases/avdas.d (added) Added @table/@end table capability along with the avdas.d test case ... Thu, 05 Feb 1998 20:05:26 GMT Joel Sherrill [02d19d8] * doc/tools/pdl2texi/Makefile (modified) * doc/tools/pdl2texi/main.c (modified) Added code to more correctly process abstract types (handle, range, etc). Fri, 30 Jan 1998 21:49:51 GMT Joel Sherrill [5c3511e] * Makefile.in (modified) * c/Makefile.in (modified) * c/build-tools/Makefile.in (modified) * c/build-tools/os/Makefile.in (modified) * c/build-tools/os/msdos/Makefile.in (modified) * c/build-tools/scripts/Makefile.in (modified) * c/build-tools/src/Makefile.in (modified) * c/src/Makefile.in (modified) * c/src/exec/Makefile.in (modified) * c/src/exec/posix/Makefile.in (modified) * c/src/exec/posix/base/Makefile.in (modified) * c/src/exec/posix/headers/Makefile.in (modified) * c/src/exec/posix/include/rtems/posix/Makefile.in (modified) * c/src/exec/posix/include/sys/Makefile.in (modified) * c/src/exec/posix/include/wrap/Makefile.in (modified) * c/src/exec/posix/inline/Makefile.in (modified) * c/src/exec/posix/inline/rtems/posix/Makefile.in (modified) * c/src/exec/posix/macros/Makefile.in (modified) * c/src/exec/posix/macros/rtems/posix/Makefile.in (modified) * c/src/exec/posix/optman/Makefile.in (modified) * c/src/exec/posix/src/Makefile.in (modified) * c/src/exec/posix/sys/Makefile.in (modified) * c/src/exec/rtems/Makefile.in (modified) * c/src/exec/rtems/headers/Makefile.in (modified) * c/src/exec/rtems/include/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/inline/Makefile.in (modified) * c/src/exec/rtems/inline/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/macros/Makefile.in (modified) * c/src/exec/rtems/macros/rtems/rtems/Makefile.in (modified) * c/src/exec/rtems/optman/Makefile.in (modified) * c/src/exec/rtems/src/Makefile.in (modified) * c/src/exec/sapi/Makefile.in (modified) * c/src/exec/sapi/headers/Makefile.in (modified) * c/src/exec/sapi/include/rtems/Makefile.in (modified) * c/src/exec/sapi/inline/Makefile.in (modified) * c/src/exec/sapi/inline/rtems/Makefile.in (modified) * c/src/exec/sapi/macros/Makefile.in (modified) * c/src/exec/sapi/macros/rtems/Makefile.in (modified) * c/src/exec/sapi/optman/Makefile.in (modified) * c/src/exec/sapi/src/Makefile.in (modified) * c/src/exec/score/Makefile.in (modified) * c/src/exec/score/cpu/Makefile.in (modified) * c/src/exec/score/cpu/a29k/Makefile.in (modified) * c/src/exec/score/cpu/hppa1.1/Makefile.in (modified) * c/src/exec/score/cpu/i386/Makefile.in (modified) * c/src/exec/score/cpu/i960/Makefile.in (modified) * c/src/exec/score/cpu/m68k/Makefile.in (modified) * c/src/exec/score/cpu/mips64orion/Makefile.in (modified) * c/src/exec/score/cpu/no_cpu/Makefile.in (modified) * c/src/exec/score/cpu/powerpc/Makefile.in (modified) * c/src/exec/score/cpu/sparc/Makefile.in (modified) * c/src/exec/score/cpu/unix/Makefile.in (modified) * c/src/exec/score/headers/Makefile.in (modified) * c/src/exec/score/include/rtems/score/Makefile.in (modified) * c/src/exec/score/inline/Makefile.in (modified) * c/src/exec/score/inline/rtems/score/Makefile.in (modified) * c/src/exec/score/macros/Makefile.in (modified) * c/src/exec/score/macros/rtems/score/Makefile.in (modified) * c/src/exec/score/src/Makefile.in (modified) * c/src/exec/score/tools/Makefile.in (modified) * c/src/exec/score/tools/generic/Makefile.in (modified) * c/src/exec/score/tools/hppa1.1/Makefile.in (modified) * c/src/exec/score/tools/unix/Makefile.in (modified) * c/src/exec/wrapup/Makefile.in (modified) * c/src/exec/wrapup/posix/Makefile.in (modified) * c/src/exec/wrapup/rtems/Makefile.in (modified) * c/src/lib/Makefile.in (modified) * c/src/lib/include/Makefile.in (modified) * c/src/lib/libbsp/Makefile.in (modified) * c/src/lib/libbsp/a29k/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/console/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/include/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/start/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/startup/Makefile.in (modified) * c/src/lib/libbsp/a29k/portsw/wrapup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/include/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tty/Makefile.in (modified) * c/src/lib/libbsp/hppa1.1/simhppa/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/force386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/console/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/include/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/go32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/console/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/include/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/i386ex/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/clock/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/console/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/include/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/start/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/startup/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/timer/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/tools/Makefile.in (modified) * c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in (modified) * c/src/lib/libbsp/i960/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/clock/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/console/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/include/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/start/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/startup/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/timer/Makefile.in (modified) * c/src/lib/libbsp/i960/cvme961/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/dmv152/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/start332/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi332/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/spurious/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/start68k/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/efi68k/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/network/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/start360/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/gen68360/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/idp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme136/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme147s/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/consolex/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tod/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/tools/Makefile.in (modified) * c/src/lib/libbsp/m68k/mvme162/wrapup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/clock/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/console/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/include/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/start302/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/startup/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/timer/Makefile.in (modified) * c/src/lib/libbsp/m68k/ods68302/wrapup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/console/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/include/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/liblnk/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/start/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/Makefile.in (modified) * c/src/lib/libbsp/mips64orion/p4000/wrapup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/clock/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/console/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/include/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/timer/Makefile.in (modified) * c/src/lib/libbsp/no_cpu/no_bsp/wrapup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/dlentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/flashentry/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/include/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/Makefile.in (modified) * c/src/lib/libbsp/powerpc/papyrus/wrapup/Makefile.in (modified) * c/src/lib/libbsp/shmdr/Makefile.in (modified) * c/src/lib/libbsp/sparc/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/clock/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/console/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/include/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/start/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startsis/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/startup/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/timer/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/tools/Makefile.in (modified) * c/src/lib/libbsp/sparc/erc32/wrapup/Makefile.in (modified) * c/src/lib/libbsp/unix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/clock/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/console/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/include/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/shmsupp/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/startup/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/timer/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/tools/Makefile.in (modified) * c/src/lib/libbsp/unix/posix/wrapup/Makefile.in (modified) * c/src/lib/libc/Makefile.in (modified) * c/src/lib/libcpu/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/clock/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/include/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/milli/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/runway/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/semaphore/Makefile.in (modified) * c/src/lib/libcpu/hppa1.1/timer/Makefile.in (modified) * c/src/lib/libcpu/m68k/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/Makefile.in (modified) * c/src/lib/libcpu/m68k/m68040/fpsp/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/clock/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/include/Makefile.in (modified) * c/src/lib/libcpu/mips64orion/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/clock/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/console/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/include/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/timer/Makefile.in (modified) * c/src/lib/libcpu/powerpc/ppc403/vectors/Makefile.in (modified) * c/src/lib/libcpu/sparc/Makefile.in (modified) * c/src/lib/libcpu/sparc/reg_win/Makefile.in (modified) * c/src/lib/libmisc/Makefile.in (modified) * c/src/lib/libmisc/assoc/Makefile.in (modified) * c/src/lib/libmisc/cpuuse/Makefile.in (modified) * c/src/lib/libmisc/error/Makefile.in (modified) * c/src/lib/libmisc/monitor/Makefile.in (modified) * c/src/lib/libmisc/rtmonuse/Makefile.in (modified) * c/src/lib/libmisc/stackchk/Makefile.in (modified) * c/src/lib/libmisc/wrapup/Makefile.in (modified) * c/src/lib/librtems++/Makefile.in (modified) * c/src/lib/start/Makefile.in (modified) * c/src/lib/start/a29k/Makefile.in (modified) * c/src/lib/start/i960/Makefile.in (modified) * c/src/lib/start/m68k/Makefile.in (modified) * c/src/lib/start/mips64orion/Makefile.in (modified) * c/src/lib/wrapup/Makefile.in (modified) * c/src/libmisc/assoc/Makefile.in (modified) * c/src/libmisc/cpuuse/Makefile.in (modified) * c/src/libmisc/error/Makefile.in (modified) * c/src/libmisc/monitor/Makefile.in (modified) * c/src/libmisc/rtmonuse/Makefile.in (modified) * c/src/libmisc/stackchk/Makefile.in (modified) * c/src/libmisc/wrapup/Makefile.in (modified) * c/src/librtems++/src/Makefile.in (modified) * c/src/tests/Makefile.in (modified) * c/src/tests/libtests/Makefile.in (modified) * c/src/tests/libtests/cpuuse/Makefile.in (modified) * c/src/tests/libtests/malloctest/Makefile.in (modified) * c/src/tests/libtests/monitor/Makefile.in (modified) * c/src/tests/libtests/rtems++/Makefile.in (modified) * c/src/tests/libtests/rtmonuse/Makefile.in (modified) * c/src/tests/libtests/stackchk/Makefile.in (modified) * c/src/tests/libtests/termios/Makefile.in (modified) * c/src/tests/mptests/Makefile.in (modified) * c/src/tests/mptests/mp01/Makefile.in (modified) * c/src/tests/mptests/mp01/node1/Makefile.in (modified) * c/src/tests/mptests/mp01/node2/Makefile.in (modified) * c/src/tests/mptests/mp02/Makefile.in (modified) * c/src/tests/mptests/mp02/node1/Makefile.in (modified) * c/src/tests/mptests/mp02/node2/Makefile.in (modified) * c/src/tests/mptests/mp03/Makefile.in (modified) * c/src/tests/mptests/mp03/node1/Makefile.in (modified) * c/src/tests/mptests/mp03/node2/Makefile.in (modified) * c/src/tests/mptests/mp04/Makefile.in (modified) * c/src/tests/mptests/mp04/node1/Makefile.in (modified) * c/src/tests/mptests/mp04/node2/Makefile.in (modified) * c/src/tests/mptests/mp05/Makefile.in (modified) * c/src/tests/mptests/mp05/node1/Makefile.in (modified) * c/src/tests/mptests/mp05/node2/Makefile.in (modified) * c/src/tests/mptests/mp06/Makefile.in (modified) * c/src/tests/mptests/mp06/node1/Makefile.in (modified) * c/src/tests/mptests/mp06/node2/Makefile.in (modified) * c/src/tests/mptests/mp07/Makefile.in (modified) * c/src/tests/mptests/mp07/node1/Makefile.in (modified) * c/src/tests/mptests/mp07/node2/Makefile.in (modified) * c/src/tests/mptests/mp08/Makefile.in (modified) * c/src/tests/mptests/mp08/node1/Makefile.in (modified) * c/src/tests/mptests/mp08/node2/Makefile.in (modified) * c/src/tests/mptests/mp09/Makefile.in (modified) * c/src/tests/mptests/mp09/node1/Makefile.in (modified) * c/src/tests/mptests/mp09/node2/Makefile.in (modified) * c/src/tests/mptests/mp10/Makefile.in (modified) * c/src/tests/mptests/mp10/node1/Makefile.in (modified) * c/src/tests/mptests/mp10/node2/Makefile.in (modified) * c/src/tests/mptests/mp11/Makefile.in (modified) * c/src/tests/mptests/mp11/node1/Makefile.in (modified) * c/src/tests/mptests/mp11/node2/Makefile.in (modified) * c/src/tests/mptests/mp12/Makefile.in (modified) * c/src/tests/mptests/mp12/node1/Makefile.in (modified) * c/src/tests/mptests/mp12/node2/Makefile.in (modified) * c/src/tests/mptests/mp13/Makefile.in (modified) * c/src/tests/mptests/mp13/node1/Makefile.in (modified) * c/src/tests/mptests/mp13/node2/Makefile.in (modified) * c/src/tests/mptests/mp14/Makefile.in (modified) * c/src/tests/mptests/mp14/node1/Makefile.in (modified) * c/src/tests/mptests/mp14/node2/Makefile.in (modified) * c/src/tests/psxtests/Makefile.in (modified) * c/src/tests/psxtests/psx01/Makefile.in (modified) * c/src/tests/psxtests/psx02/Makefile.in (modified) * c/src/tests/psxtests/psx03/Makefile.in (modified) * c/src/tests/psxtests/psx04/Makefile.in (modified) * c/src/tests/psxtests/psx05/Makefile.in (modified) * c/src/tests/psxtests/psx06/Makefile.in (modified) * c/src/tests/psxtests/psx07/Makefile.in (modified) * c/src/tests/psxtests/psx08/Makefile.in (modified) * c/src/tests/psxtests/psx09/Makefile.in (modified) * c/src/tests/psxtests/psx10/Makefile.in (modified) * c/src/tests/psxtests/psx11/Makefile.in (modified) * c/src/tests/psxtests/psx12/Makefile.in (modified) * c/src/tests/psxtests/psxhdrs/Makefile.in (modified) * c/src/tests/psxtests/support/Makefile.in (modified) * c/src/tests/psxtests/support/include/Makefile.in (modified) * c/src/tests/samples/Makefile.in (modified) * c/src/tests/samples/base_mp/Makefile.in (modified) * c/src/tests/samples/base_mp/node1/Makefile.in (modified) * c/src/tests/samples/base_mp/node2/Makefile.in (modified) * c/src/tests/samples/base_sp/Makefile.in (modified) * c/src/tests/samples/cdtest/Makefile.in (modified) * c/src/tests/samples/hello/Makefile.in (modified) * c/src/tests/samples/paranoia/Makefile.in (modified) * c/src/tests/samples/ticker/Makefile.in (modified) * c/src/tests/sptests/Makefile.in (modified) * c/src/tests/sptests/sp01/Makefile.in (modified) * c/src/tests/sptests/sp02/Makefile.in (modified) * c/src/tests/sptests/sp03/Makefile.in (modified) * c/src/tests/sptests/sp04/Makefile.in (modified) * c/src/tests/sptests/sp05/Makefile.in (modified) * c/src/tests/sptests/sp06/Makefile.in (modified) * c/src/tests/sptests/sp07/Makefile.in (modified) * c/src/tests/sptests/sp08/Makefile.in (modified) * c/src/tests/sptests/sp09/Makefile.in (modified) * c/src/tests/sptests/sp11/Makefile.in (modified) * c/src/tests/sptests/sp12/Makefile.in (modified) * c/src/tests/sptests/sp13/Makefile.in (modified) * c/src/tests/sptests/sp14/Makefile.in (modified) * c/src/tests/sptests/sp15/Makefile.in (modified) * c/src/tests/sptests/sp16/Makefile.in (modified) * c/src/tests/sptests/sp17/Makefile.in (modified) * c/src/tests/sptests/sp19/Makefile.in (modified) * c/src/tests/sptests/sp20/Makefile.in (modified) * c/src/tests/sptests/sp21/Makefile.in (modified) * c/src/tests/sptests/sp22/Makefile.in (modified) * c/src/tests/sptests/sp23/Makefile.in (modified) * c/src/tests/sptests/sp24/Makefile.in (modified) * c/src/tests/sptests/sp25/Makefile.in (modified) * c/src/tests/sptests/spfatal/Makefile.in (modified) * c/src/tests/sptests/spsize/Makefile.in (modified) * c/src/tests/support/Makefile.in (modified) * c/src/tests/support/include/Makefile.in (modified) * c/src/tests/support/stubdr/Makefile.in (modified) * c/src/tests/support/wrapup/Makefile.in (modified) * c/src/tests/tmtests/Makefile.in (modified) * c/src/tests/tmtests/include/Makefile.in (modified) * c/src/tests/tmtests/tm01/Makefile.in (modified) * c/src/tests/tmtests/tm02/Makefile.in (modified) * c/src/tests/tmtests/tm03/Makefile.in (modified) * c/src/tests/tmtests/tm04/Makefile.in (modified) * c/src/tests/tmtests/tm05/Makefile.in (modified) * c/src/tests/tmtests/tm06/Makefile.in (modified) * c/src/tests/tmtests/tm07/Makefile.in (modified) * c/src/tests/tmtests/tm08/Makefile.in (modified) * c/src/tests/tmtests/tm09/Makefile.in (modified) * c/src/tests/tmtests/tm10/Makefile.in (modified) * c/src/tests/tmtests/tm11/Makefile.in (modified) * c/src/tests/tmtests/tm12/Makefile.in (modified) * c/src/tests/tmtests/tm13/Makefile.in (modified) * c/src/tests/tmtests/tm14/Makefile.in (modified) * c/src/tests/tmtests/tm15/Makefile.in (modified) * c/src/tests/tmtests/tm16/Makefile.in (modified) * c/src/tests/tmtests/tm17/Makefile.in (modified) * c/src/tests/tmtests/tm18/Makefile.in (modified) * c/src/tests/tmtests/tm19/Makefile.in (modified) * c/src/tests/tmtests/tm20/Makefile.in (modified) * c/src/tests/tmtests/tm21/Makefile.in (modified) * c/src/tests/tmtests/tm22/Makefile.in (modified) * c/src/tests/tmtests/tm23/Makefile.in (modified) * c/src/tests/tmtests/tm24/Makefile.in (modified) * c/src/tests/tmtests/tm25/Makefile.in (modified) * c/src/tests/tmtests/tm26/Makefile.in (modified) * c/src/tests/tmtests/tm27/Makefile.in (modified) * c/src/tests/tmtests/tm28/Makefile.in (modified) * c/src/tests/tmtests/tm29/Makefile.in (modified) * c/src/tests/tmtests/tmck/Makefile.in (modified) * c/src/tests/tmtests/tmoverhd/Makefile.in (modified) * c/src/tests/tools/generic/Makefile.in (modified) * c/src/wrapup/Makefile.in (modified) * c/update-tools/Makefile.in (modified) * configure (modified) * configure.in (modified) * doc/Makefile.in (modified) * make/Makefile.in (modified) * make/Templates/Makefile.dir (modified) * make/Templates/Makefile.inc.in (modified) * make/Templates/Makefile.leaf (modified) * make/Templates/Makefile.lib (modified) * make/target.cfg.in (modified) * tools/build/Makefile.in (modified) * tools/build/os/Makefile.in (modified) * tools/build/os/msdos/Makefile.in (modified) * tools/build/scripts/Makefile.in (modified) * tools/build/src/Makefile.in (modified) * tools/cpu/Makefile.in (modified) * tools/cpu/generic/Makefile.in (modified) * tools/cpu/unix/Makefile.in (modified) * tools/update/Makefile.in (modified) Big patch form Ralf Corsepius described in this email: Here is ... Fri, 30 Jan 1998 19:17:25 GMT Joel Sherrill [b4767da] * doc/tools/pdl2texi/base.h (modified) * doc/tools/pdl2texi/main.c (modified) Modified output of @Example style in MsWord output routine so it ... Fri, 23 Jan 1998 16:57:29 GMT Joel Sherrill [173c59c8] * doc/Make.config (modified) * doc/ada_user/ada_user.texi (modified) * doc/develenv/develenv.texi (modified) * doc/new_chapters/clock.texi (modified) * doc/new_chapters/posix_test_plan.texi (modified) * doc/posix_users/clock.texi (modified) * doc/posix_users/posix_test_plan.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/powerpc/bsp.t (modified) * doc/supplements/powerpc/bsp.texi (modified) * doc/supplements/powerpc/callconv.t (modified) * doc/supplements/powerpc/callconv.texi (modified) * doc/supplements/powerpc/powerpc.texi (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/user/c_user.texi (modified) * doc/user/intr.t (modified) minor updates .. mostly version Fri, 23 Jan 1998 16:56:40 GMT Joel Sherrill [1d012410] * doc/tools/bmenu/main.c (modified) Fixed some "NodeNameIncludesChapterName" problems which were ... Wed, 21 Jan 1998 16:50:45 GMT Joel Sherrill [d73ed76b] * doc/Makefile.in (modified) Changed reference from PROJECT_ROOT to RTEMS_ROOT. Wed, 21 Jan 1998 15:15:12 GMT Joel Sherrill [972dc40] * doc/tools/pdl2texi/Makefile (modified) * doc/tools/pdl2texi/base.h (modified) * doc/tools/pdl2texi/main.c (modified) Added Code to dop the output in a format which a custom Visual Basic ... Tue, 02 Dec 1997 16:27:15 GMT Jennifer Averett [3013e18] * doc/supplements/powerpc/bsp.t (modified) * doc/supplements/powerpc/bsp.texi (modified) Modified SPARC to PowerPC. Modified specific requirements to be for ... Tue, 02 Dec 1997 16:02:45 GMT Jennifer Averett [bfad6e2] * doc/supplements/powerpc/cputable.t (modified) * doc/supplements/powerpc/cputable.texi (modified) Added definations for serial_per_sec, serial_rate, and serial_xon_xoff. Tue, 02 Dec 1997 15:38:10 GMT Jennifer Averett [ba2d45e6] * doc/supplements/powerpc/cputable.t (modified) * doc/supplements/powerpc/cputable.texi (modified) Modified referances to SPARC to PowerPC. Updated the Information ... Fri, 31 Oct 1997 19:44:42 GMT Joel Sherrill [87926ab] * doc/tools/bmenu/testdoc.texi (added) Test document. Fri, 31 Oct 1997 19:44:32 GMT Joel Sherrill [f70c6adc] * doc/tools/bmenu/Makefile (modified) New test file. Fri, 31 Oct 1997 19:44:23 GMT Joel Sherrill [2744eec] * doc/tools/bmenu/main.c (modified) Replaced the algorithm used to build the texinfo nodes and menus. ... Wed, 03 Sep 1997 15:36:05 GMT Joel Sherrill [cf5ef6d] * doc/user/rtmon.t (modified) More specific information on error code. Fri, 15 Aug 1997 16:40:21 GMT Joel Sherrill [5b9ec351] * doc/tools/bmenu/main.c (modified) Added command line options for next, previous, and up node. Added ... Mon, 04 Aug 1997 20:06:33 GMT Joel Sherrill [1f552a0] * doc/supplements/i386/Makefile (modified) Fixed wildcard in copy command. Mon, 04 Aug 1997 20:06:16 GMT Joel Sherrill [0e5dd428] * doc/common/timetbl.t (modified) * doc/common/wksheets.t (modified) Added comments to help avoid editting generated file. Mon, 04 Aug 1997 20:05:48 GMT Joel Sherrill [1ca951ce] * doc/user/event.t (modified) * doc/user/msg.t (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/sem.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) Added information based on comments from Katsu Shibuya. Mon, 04 Aug 1997 20:04:43 GMT Joel Sherrill [6059e111] * doc/supplements/powerpc/Makefile (modified) * doc/supplements/powerpc/timePSIM.t (modified) * doc/supplements/powerpc/timedata.t (modified) Fixed node links. Mon, 04 Aug 1997 20:04:25 GMT Joel Sherrill [6943b0e] * doc/tools/bmenu/bmenu (deleted) * doc/tools/bmenu/chain.o (deleted) * doc/tools/bmenu/main.o (deleted) removed binary files Thu, 31 Jul 1997 19:00:09 GMT Joel Sherrill [b930f43] * doc/supplements/i386/Makefile (modified) Corrected bug in Makefile Thu, 31 Jul 1997 18:59:59 GMT Joel Sherrill [60593076] * doc/Make.config (modified) * doc/Makefile (modified) * doc/do_docs (modified) Corrected problem where directories where not being properly created. ... Thu, 31 Jul 1997 18:45:58 GMT Joel Sherrill [db91520] * doc/ada_user/ada_user.texi (modified) * doc/develenv/develenv.texi (modified) * doc/develenv/direct.texi (modified) * doc/develenv/sample.texi (modified) * doc/do_docs (modified) * doc/new_chapters/posix_test_plan.texi (modified) * doc/posix_users/posix_test_plan.texi (modified) * doc/relnotes/install.texi (modified) * doc/relnotes/intro.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/relnotes/status.texi (modified) * doc/rtems.html (modified) * doc/supplements/i386/cputable.t (modified) * doc/supplements/i386/cputable.texi (modified) * doc/supplements/i960/cputable.t (modified) * doc/supplements/i960/cputable.texi (modified) * doc/supplements/m68k/cputable.t (modified) * doc/supplements/sparc/bsp.t (modified) * doc/supplements/sparc/bsp.texi (modified) * doc/supplements/sparc/cpumodel.t (modified) * doc/supplements/sparc/cpumodel.texi (modified) * doc/supplements/sparc/cputable.t (modified) * doc/supplements/sparc/cputable.texi (modified) corrected typos and changes LANGUAGE to RTEMS-LANGUAGE. Thu, 31 Jul 1997 18:45:32 GMT Joel Sherrill [03c8223] * doc/supplements/powerpc/bsp.t (modified) * doc/supplements/powerpc/bsp.texi (modified) * doc/supplements/powerpc/cpumodel.t (modified) * doc/supplements/powerpc/cpumodel.texi (modified) * doc/supplements/powerpc/intr.t (modified) * doc/supplements/powerpc/intr_NOTIMES.t (modified) Added more info. Thu, 31 Jul 1997 18:44:10 GMT Joel Sherrill [c3fec1c] * doc/user/clock.t (modified) Added info on what data type is expected by the clock_get directive ... Thu, 31 Jul 1997 18:24:06 GMT Joel Sherrill [d1f19f0] * doc/user/msg.t (modified) Added rtems_message_queue_get_number_pending directive. Fri, 18 Jul 1997 15:04:19 GMT Joel Sherrill [372a382a] * doc/user/timer.t (modified) Fixed typo of "::" Wed, 02 Jul 1997 17:54:33 GMT Joel Sherrill [2e6d68c4] * doc/supplements/powerpc/cputable.t (modified) * doc/supplements/powerpc/cputable.texi (modified) Updated to the PowerPC. Wed, 02 Jul 1997 17:49:23 GMT Joel Sherrill [ce90366] * doc/supplements/powerpc/callconv.t (modified) * doc/supplements/powerpc/callconv.texi (modified) * doc/supplements/powerpc/fatalerr.t (modified) * doc/supplements/powerpc/fatalerr.texi (modified) * doc/supplements/powerpc/memmodel.t (modified) * doc/supplements/powerpc/memmodel.texi (modified) updated to properly reflect powerpc Tue, 01 Jul 1997 18:39:44 GMT Joel Sherrill [563f7e0] * doc/supplements/powerpc/Makefile (added) * doc/supplements/powerpc/PSIM_TIMES (added) * doc/supplements/powerpc/bsp.t (added) * doc/supplements/powerpc/bsp.texi (added) * doc/supplements/powerpc/callconv.t (added) * doc/supplements/powerpc/callconv.texi (added) * doc/supplements/powerpc/cpumodel.t (added) * doc/supplements/powerpc/cpumodel.texi (added) * doc/supplements/powerpc/cputable.t (added) * doc/supplements/powerpc/cputable.texi (added) * doc/supplements/powerpc/fatalerr.t (added) * doc/supplements/powerpc/fatalerr.texi (added) * doc/supplements/powerpc/intr.t (added) * doc/supplements/powerpc/intr_NOTIMES.t (added) * doc/supplements/powerpc/memmodel.t (added) * doc/supplements/powerpc/memmodel.texi (added) * doc/supplements/powerpc/powerpc.texi (added) * doc/supplements/powerpc/preface.texi (added) * doc/supplements/powerpc/timePSIM.t (added) * doc/supplements/powerpc/timedata.t (added) New files -- PowerPC supplement is based on the SPARC supplement. ... Mon, 16 Jun 1997 21:30:08 GMT Joel Sherrill [85ecda8] * doc/tools/pdl2texi/address.h (added) * doc/tools/pdl2texi/address.inl (added) * doc/tools/pdl2texi/chain.c (added) * doc/tools/pdl2texi/chain.h (added) * doc/tools/pdl2texi/chain.inl (added) * doc/tools/pdl2texi/isr.h (added) * doc/tools/pdl2texi/s.d (added) * doc/tools/pdl2texi/sample.d (added) * doc/tools/pdl2texi/system.h (added) This commit was generated by cvs2svn to compensate for changes in ... Mon, 16 Jun 1997 21:30:08 GMT Joel Sherrill [a66872f6] * doc/tools/pdl2texi/address.h (added) * doc/tools/pdl2texi/address.inl (added) * doc/tools/pdl2texi/chain.c (added) * doc/tools/pdl2texi/chain.h (added) * doc/tools/pdl2texi/chain.inl (added) * doc/tools/pdl2texi/isr.h (added) * doc/tools/pdl2texi/s.d (added) * doc/tools/pdl2texi/sample.d (added) * doc/tools/pdl2texi/system.h (added) base PDL 2 TEXI Mon, 16 Jun 1997 21:30:07 GMT Joel Sherrill [d4bc481] * doc/tools/pdl2texi/Drive.d (added) * doc/tools/pdl2texi/Makefile (added) * doc/tools/pdl2texi/afcc.texi (added) * doc/tools/pdl2texi/base.h (added) * doc/tools/pdl2texi/drive.d (added) * doc/tools/pdl2texi/main.c (added) * doc/tools/pdl2texi/t1.d (added) Initial revision Wed, 04 Jun 1997 18:32:07 GMT Joel Sherrill [139b2e4a] * doc/Make.config (modified) * doc/README (modified) * doc/ada_user/Makefile (modified) * doc/ada_user/ada_user.texi (modified) * doc/ada_user/example.texi (modified) * doc/common/cpright.texi (modified) * doc/common/setup.texi (modified) * doc/common/timemac.texi (modified) * doc/common/timetbl.t (modified) * doc/common/timing.texi (modified) * doc/common/wksheets.t (modified) * doc/develenv/Makefile (modified) * doc/develenv/compile.texi (modified) * doc/develenv/develenv.texi (modified) * doc/develenv/direct.texi (modified) * doc/develenv/intro.texi (modified) * doc/develenv/sample.texi (modified) * doc/develenv/utils.texi (modified) * doc/import_ami_txt (modified) * doc/new_chapters/Makefile (modified) * doc/new_chapters/base.texi (modified) * doc/new_chapters/clock.texi (modified) * doc/new_chapters/cond.texi (modified) * doc/new_chapters/key.texi (modified) * doc/new_chapters/mutex.texi (modified) * doc/new_chapters/posix_test_plan.texi (modified) * doc/new_chapters/preface.texi (modified) * doc/new_chapters/sched.texi (modified) * doc/new_chapters/signal.texi (modified) * doc/new_chapters/thread.texi (modified) * doc/posix_users/Makefile (modified) * doc/posix_users/base.texi (modified) * doc/posix_users/clock.texi (modified) * doc/posix_users/cond.texi (modified) * doc/posix_users/key.texi (modified) * doc/posix_users/mutex.texi (modified) * doc/posix_users/posix_test_plan.texi (modified) * doc/posix_users/preface.texi (modified) * doc/posix_users/sched.texi (modified) * doc/posix_users/signal.texi (modified) * doc/posix_users/thread.texi (modified) * doc/relnotes/Makefile (modified) * doc/relnotes/install.texi (modified) * doc/relnotes/intro.texi (modified) * doc/relnotes/probrep.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/relnotes/status.texi (modified) * doc/supplements/hppa1_1/Makefile (modified) * doc/supplements/hppa1_1/SIMHPPA_TIMES (modified) * doc/supplements/hppa1_1/TIMES (modified) * doc/supplements/hppa1_1/bsp.t (modified) * doc/supplements/hppa1_1/bsp.texi (modified) * doc/supplements/hppa1_1/callconv.t (modified) * doc/supplements/hppa1_1/callconv.texi (modified) * doc/supplements/hppa1_1/cpumodel.t (modified) * doc/supplements/hppa1_1/cpumodel.texi (modified) * doc/supplements/hppa1_1/cputable.t (modified) * doc/supplements/hppa1_1/cputable.texi (modified) * doc/supplements/hppa1_1/fatalerr.t (modified) * doc/supplements/hppa1_1/fatalerr.texi (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/hppa1_1/intr.t (modified) * doc/supplements/hppa1_1/intr_NOTIMES.t (modified) * doc/supplements/hppa1_1/memmodel.t (modified) * doc/supplements/hppa1_1/memmodel.texi (modified) * doc/supplements/hppa1_1/preface.texi (modified) * doc/supplements/hppa1_1/timedata.t (modified) * doc/supplements/i386/FORCE386_TIMES (modified) * doc/supplements/i386/Makefile (modified) * doc/supplements/i386/bsp.t (modified) * doc/supplements/i386/bsp.texi (modified) * doc/supplements/i386/callconv.t (modified) * doc/supplements/i386/callconv.texi (modified) * doc/supplements/i386/cpumodel.t (modified) * doc/supplements/i386/cpumodel.texi (modified) * doc/supplements/i386/cputable.t (modified) * doc/supplements/i386/cputable.texi (modified) * doc/supplements/i386/fatalerr.t (modified) * doc/supplements/i386/fatalerr.texi (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i386/intr.t (modified) * doc/supplements/i386/intr_NOTIMES.t (modified) * doc/supplements/i386/memmodel.t (modified) * doc/supplements/i386/memmodel.texi (modified) * doc/supplements/i386/preface.texi (modified) * doc/supplements/i386/timeFORCE386.t (modified) * doc/supplements/i386/timedata.t (modified) * doc/supplements/i960/CVME961_TIMES (modified) * doc/supplements/i960/Makefile (modified) * doc/supplements/i960/bsp.t (modified) * doc/supplements/i960/bsp.texi (modified) * doc/supplements/i960/callconv.t (modified) * doc/supplements/i960/callconv.texi (modified) * doc/supplements/i960/cpumodel.t (modified) * doc/supplements/i960/cpumodel.texi (modified) * doc/supplements/i960/cputable.t (modified) * doc/supplements/i960/cputable.texi (modified) * doc/supplements/i960/fatalerr.t (modified) * doc/supplements/i960/fatalerr.texi (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/i960/intr.t (modified) * doc/supplements/i960/intr_NOTIMES.t (modified) * doc/supplements/i960/memmodel.t (modified) * doc/supplements/i960/memmodel.texi (modified) * doc/supplements/i960/preface.texi (modified) * doc/supplements/i960/timeCVME961.t (modified) * doc/supplements/i960/timedata.t (modified) * doc/supplements/m68k/MVME136_TIMES (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/m68k/bsp.t (modified) * doc/supplements/m68k/callconv.t (modified) * doc/supplements/m68k/cpumodel.t (modified) * doc/supplements/m68k/cputable.t (modified) * doc/supplements/m68k/fatalerr.t (modified) * doc/supplements/m68k/intr_NOTIMES.t (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/m68k/memmodel.t (modified) * doc/supplements/m68k/preface.texi (modified) * doc/supplements/m68k/timeMVME136.t (modified) * doc/supplements/m68k/timedata.t (modified) * doc/supplements/sparc/ERC32_TIMES (modified) * doc/supplements/sparc/Makefile (modified) * doc/supplements/sparc/SIS_TIMES (modified) * doc/supplements/sparc/bsp.t (modified) * doc/supplements/sparc/bsp.texi (modified) * doc/supplements/sparc/callconv.t (modified) * doc/supplements/sparc/callconv.texi (modified) * doc/supplements/sparc/cpumodel.t (modified) * doc/supplements/sparc/cpumodel.texi (modified) * doc/supplements/sparc/cputable.t (modified) * doc/supplements/sparc/cputable.texi (modified) * doc/supplements/sparc/fatalerr.t (modified) * doc/supplements/sparc/fatalerr.texi (modified) * doc/supplements/sparc/intr.t (modified) * doc/supplements/sparc/intr_NOTIMES.t (modified) * doc/supplements/sparc/memmodel.t (modified) * doc/supplements/sparc/memmodel.texi (modified) * doc/supplements/sparc/preface.texi (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/supplements/sparc/timeERC32.t (modified) * doc/supplements/sparc/timedata.t (modified) * doc/tools/bmenu/Makefile (modified) * doc/tools/bmenu/address.h (modified) * doc/tools/bmenu/address.inl (modified) * doc/tools/bmenu/base.h (modified) * doc/tools/bmenu/chain.c (modified) * doc/tools/bmenu/chain.h (modified) * doc/tools/bmenu/chain.inl (modified) * doc/tools/bmenu/isr.h (modified) * doc/tools/bmenu/main.c (modified) * doc/tools/bmenu/system.h (modified) * doc/tools/update (modified) * doc/tools/word-replace (modified) * doc/user/Makefile (modified) * doc/user/bsp.t (modified) * doc/user/c_user.texi (modified) * doc/user/clock.t (modified) * doc/user/concepts.t (modified) * doc/user/conf.t (modified) * doc/user/dirstat.texi (modified) * doc/user/dpmem.t (modified) * doc/user/event.t (modified) * doc/user/example.texi (modified) * doc/user/fatal.t (modified) * doc/user/glossary.texi (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/overview.t (modified) * doc/user/part.t (modified) * doc/user/preface.texi (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) added CVS Id string Wed, 04 Jun 1997 16:06:28 GMT Joel Sherrill [25c5bee5] * doc/supplements/i386/i386.texi (modified) added CVS Id string Wed, 04 Jun 1997 16:04:51 GMT Joel Sherrill [dfce9272] * doc/Makefile (modified) * doc/do_docs (modified) Added CVS Id string Wed, 04 Jun 1997 16:04:17 GMT Joel Sherrill [02f19bf] * doc/do_docs (modified) * doc/rtems.html (modified) * doc/rtems_footer.html (modified) * doc/rtems_header.html (modified) changed version number Wed, 04 Jun 1997 15:15:59 GMT Joel Sherrill [bf56ac8] * doc/Make.config (modified) * doc/ada_user/ada_user.texi (modified) * doc/common/cpright.texi (modified) * doc/common/setup.texi (modified) * doc/develenv/develenv.texi (modified) * doc/new_chapters/posix_test_plan.texi (modified) * doc/posix_users/posix_test_plan.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/sparc/ERC32_TIMES (modified) * doc/supplements/sparc/SIS_TIMES (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/user/c_user.texi (modified) changed edition and version information Wed, 04 Jun 1997 15:15:28 GMT Joel Sherrill [022fbf3e] * doc/user/conf.t (modified) Fixed formatting problem where @example did not start early enough. Wed, 04 Jun 1997 13:04:36 GMT Joel Sherrill [7e8a1fc] * doc/rtems_footer.html (modified) * doc/rtems_header.html (modified) * doc/user/clock.t (modified) * doc/user/conf.t (modified) * doc/user/fatal.t (modified) * doc/user/glossary.texi (modified) * doc/user/intr.t (modified) * doc/user/overview.t (modified) * doc/user/rtmon.t (modified) * doc/user/task.t (modified) * doc/user/userext.t (modified) final corrections before 4.1.0 documentation freeze. Sat, 31 May 1997 15:55:10 GMT Joel Sherrill [a94c5a5d] * doc/new_chapters/posix_test_plan.texi (modified) * doc/posix_users/posix_test_plan.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/user/bsp.t (modified) * doc/user/c_user.texi (modified) * doc/user/clock.t (modified) * doc/user/conf.t (modified) * doc/user/dirstat.texi (modified) * doc/user/event.t (modified) * doc/user/fatal.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/overview.t (modified) * doc/user/part.t (modified) * doc/user/preface.texi (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) Changed bitwise OR's used to build up option and attribute sets to ... Sat, 31 May 1997 15:54:51 GMT Joel Sherrill [1499931d] * doc/ada_user/ada_user.texi (modified) * doc/develenv/develenv.texi (modified) Changed bitwise OR's used to build up option and attribute sets to ... Fri, 30 May 1997 22:57:25 GMT Joel Sherrill [17a3c69] * doc/HELP.html (modified) * doc/develenv/sample.texi (modified) * doc/do_docs (modified) * doc/relnotes/intro.texi (modified) * doc/rtems.html (modified) * doc/supplements/hppa1_1/bsp.t (modified) * doc/supplements/hppa1_1/bsp.texi (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/i386/bsp.t (modified) * doc/supplements/i386/bsp.texi (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i960/bsp.t (modified) * doc/supplements/i960/bsp.texi (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/m68k/bsp.t (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/sparc/bsp.t (modified) * doc/supplements/sparc/bsp.texi (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/user/conf.t (modified) * doc/user/fatal.t (modified) * doc/user/intr.t (modified) * doc/user/overview.t (modified) fixed typos Fri, 30 May 1997 21:15:28 GMT Joel Sherrill [92c2ae1f] * doc/user/conf.t (modified) * doc/user/init.t (modified) updated to reflect Ada Fri, 30 May 1997 21:15:20 GMT Joel Sherrill [b64905a] * doc/ada_user/Makefile (modified) * doc/ada_user/ada_user.texi (modified) * doc/ada_user/example.texi (added) new file -- Ada specific
