# # ChangeLog for doc in rtems # # Generated by Trac 1.2.1.dev0 # 05/02/24 00:47:30 Fri, 19 Sep 2003 18:03:27 GMT Joel Sherrill [89ae24f2] * doc/started_ada/ChangeLog (modified) * doc/started_ada/intro.t (modified) * doc/started_ada/started_ada.texi (modified) * doc/started_ada/tversions.texi (modified) 2003-09-19 Joel Sherrill * intro.t, ... Fri, 19 Sep 2003 18:03:17 GMT Joel Sherrill [ea15c26] * doc/supplements/arm/ChangeLog (modified) * doc/supplements/arm/arm.texi (modified) 2003-09-19 Joel Sherrill * ... Fri, 19 Sep 2003 18:03:14 GMT Joel Sherrill [7828a149] * doc/supplements/c4x/ChangeLog (modified) * doc/supplements/c4x/c4x.texi (modified) 2003-09-19 Joel Sherrill * ... Fri, 19 Sep 2003 18:03:11 GMT Joel Sherrill [470a44c] * doc/supplements/hppa1_1/ChangeLog (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) 2003-09-19 Joel Sherrill * ... Fri, 19 Sep 2003 18:03:07 GMT Joel Sherrill [e440b90] * doc/supplements/i386/ChangeLog (modified) * doc/supplements/i386/i386.texi (modified) 2003-09-19 Joel Sherrill * ... Fri, 19 Sep 2003 18:02:57 GMT Joel Sherrill [dfcace49] * doc/supplements/i960/ChangeLog (modified) * doc/supplements/i960/i960.texi (modified) 2003-09-19 Joel Sherrill * ... Fri, 19 Sep 2003 18:02:55 GMT Joel Sherrill [a137edf] * doc/supplements/m68k/ChangeLog (modified) * doc/supplements/m68k/m68k.texi (modified) 2003-09-19 Joel Sherrill * ... Fri, 19 Sep 2003 18:02:52 GMT Joel Sherrill [d068b8cf] * doc/supplements/mips/ChangeLog (modified) * doc/supplements/mips/mips.texi (modified) 2003-09-19 Joel Sherrill * ... Fri, 19 Sep 2003 18:02:49 GMT Joel Sherrill [23f7089] * doc/supplements/mips64orion/ChangeLog (modified) * doc/supplements/mips64orion/mips64orion.texi (modified) 2003-09-19 Joel Sherrill * ... Fri, 19 Sep 2003 18:02:42 GMT Joel Sherrill [92dc203d] * doc/supplements/powerpc/ChangeLog (modified) * doc/supplements/powerpc/powerpc.texi (modified) 2003-09-19 Joel Sherrill * ... Fri, 19 Sep 2003 18:02:39 GMT Joel Sherrill [f2f3772a] * doc/supplements/sh/ChangeLog (modified) * doc/supplements/sh/sh.texi (modified) 2003-09-19 Joel Sherrill * sh.texi: ... Fri, 19 Sep 2003 18:02:37 GMT Joel Sherrill [80fe9220] * doc/supplements/sparc/ChangeLog (modified) * doc/supplements/sparc/sparc.texi (modified) 2003-09-19 Joel Sherrill * ... Fri, 19 Sep 2003 18:02:34 GMT Joel Sherrill [2b643701] * doc/supplements/template/ChangeLog (modified) * doc/supplements/template/template.texi (modified) 2003-09-19 Joel Sherrill * ... Fri, 19 Sep 2003 18:02:21 GMT Joel Sherrill [44e7129] * doc/user/ChangeLog (modified) * doc/user/c_user.texi (modified) * doc/user/rtmon.t (modified) 2003-09-19 Joel Sherrill * ... Thu, 04 Sep 2003 13:01:19 GMT Joel Sherrill [f82edff0] * doc/posix_users/ChangeLog (modified) * doc/posix_users/io.t (modified) 2003-09-04 Joel Sherrill PR 466/doc ... Wed, 27 Aug 2003 16:51:24 GMT Ralf Corsepius [1e9fbb5c] * doc/started/ChangeLog (modified) * doc/started/intro.t (modified) * doc/started/nextstep.t (modified) 2003-08-27 Ralf Corsepius * ... Wed, 27 Aug 2003 16:18:53 GMT Ralf Corsepius [50bd388] * doc/started_ada/ChangeLog (modified) * doc/started_ada/buildada.t (modified) * doc/started_ada/gdb.t (modified) * doc/started_ada/tversions.texi (modified) 2003-08-27 Ralf Corsepius * ... Wed, 27 Aug 2003 16:14:26 GMT Ralf Corsepius [6e8d424] * doc/started/ChangeLog (modified) * doc/started/buildc.t (modified) * doc/started/buildrt.t (modified) * doc/started/nt.t (modified) * doc/started/sample.t (modified) * doc/started/tversions.texi (modified) 2003-08-27 Ralf Corsepius * ... Fri, 22 Aug 2003 20:00:18 GMT Joel Sherrill [9789eefc] * doc/started/ChangeLog (modified) * doc/started/buildc.t (modified) 2003-08-22 Joel Sherrill PR 469/doc ... Fri, 22 Aug 2003 19:54:58 GMT Joel Sherrill [a543b4f] * doc/started/ChangeLog (modified) * doc/started/tversions.texi (modified) 2003-08-22 Joel Sherrill * ... Fri, 22 Aug 2003 13:15:51 GMT Joel Sherrill [14780ecf] * doc/porting/ChangeLog (modified) * doc/porting/cpumodels.t (modified) * doc/porting/sourcecode.t (modified) 2003-08-22 Joel Sherrill * ... Fri, 22 Aug 2003 13:14:31 GMT Joel Sherrill [94a762cb] * doc/bsp_howto/ChangeLog (modified) * doc/bsp_howto/adaintr.t (modified) * doc/bsp_howto/ata.t (modified) * doc/bsp_howto/target.t (modified) 2003-08-22 Joel Sherrill * ... Wed, 13 Aug 2003 08:04:44 GMT Ralf Corsepius [2907b36] * doc/bsp_howto/ChangeLog (modified) * doc/bsp_howto/ide-ctrl.t (modified) 2003-08-13 Ralf Corsepius * ... Mon, 11 Aug 2003 14:20:43 GMT Ralf Corsepius [7dcc3fe] * ChangeLog (modified) * c/ChangeLog (modified) * c/configure.ac (modified) * c/src/ChangeLog (modified) * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/configure.ac (modified) * c/src/configure.ac (modified) * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/ChangeLog (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/configure.ac (modified) * c/src/lib/libbsp/arm/armulator/ChangeLog (modified) * c/src/lib/libbsp/arm/armulator/configure.ac (modified) * c/src/lib/libbsp/arm/configure.ac (modified) * c/src/lib/libbsp/arm/edb7312/ChangeLog (modified) * c/src/lib/libbsp/arm/edb7312/configure.ac (modified) * c/src/lib/libbsp/arm/vegaplus/ChangeLog (modified) * c/src/lib/libbsp/arm/vegaplus/configure.ac (modified) * c/src/lib/libbsp/bare/ChangeLog (modified) * c/src/lib/libbsp/bare/configure.ac (modified) * c/src/lib/libbsp/c4x/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/configure.ac (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/configure.ac (modified) * c/src/lib/libbsp/c4x/configure.ac (modified) * c/src/lib/libbsp/h8300/ChangeLog (modified) * c/src/lib/libbsp/h8300/configure.ac (modified) * c/src/lib/libbsp/h8300/h8sim/ChangeLog (modified) * c/src/lib/libbsp/h8300/h8sim/configure.ac (modified) * c/src/lib/libbsp/hppa1.1/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/configure.ac (modified) * c/src/lib/libbsp/hppa1.1/simhppa/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/simhppa/configure.ac (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure.ac (modified) * c/src/lib/libbsp/i386/ChangeLog (modified) * c/src/lib/libbsp/i386/configure.ac (modified) * c/src/lib/libbsp/i386/i386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/i386ex/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/configure.ac (modified) * c/src/lib/libbsp/i960/ChangeLog (modified) * c/src/lib/libbsp/i960/configure.ac (modified) * c/src/lib/libbsp/i960/cvme961/ChangeLog (modified) * c/src/lib/libbsp/i960/cvme961/configure.ac (modified) * c/src/lib/libbsp/i960/i960sim/ChangeLog (modified) * c/src/lib/libbsp/i960/i960sim/configure.ac (modified) * c/src/lib/libbsp/i960/rxgen960/ChangeLog (modified) * c/src/lib/libbsp/i960/rxgen960/configure.ac (modified) * c/src/lib/libbsp/m68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/configure.ac (modified) * c/src/lib/libbsp/m68k/dmv152/ChangeLog (modified) * c/src/lib/libbsp/m68k/dmv152/configure.ac (modified) * c/src/lib/libbsp/m68k/efi332/ChangeLog (modified) * c/src/lib/libbsp/m68k/efi332/configure.ac (modified) * c/src/lib/libbsp/m68k/efi68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/efi68k/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68302/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68340/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68340/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68360/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68360/configure.ac (modified) * c/src/lib/libbsp/m68k/idp/ChangeLog (modified) * c/src/lib/libbsp/m68k/idp/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mrm332/ChangeLog (modified) * c/src/lib/libbsp/m68k/mrm332/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme136/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme136/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147s/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme167/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme167/configure.ac (modified) * c/src/lib/libbsp/m68k/ods68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/ods68302/configure.ac (modified) * c/src/lib/libbsp/m68k/sim68000/ChangeLog (modified) * c/src/lib/libbsp/m68k/sim68000/configure.ac (modified) * c/src/lib/libbsp/mips/ChangeLog (modified) * c/src/lib/libbsp/mips/configure.ac (modified) * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/tools/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/tools/configure.ac (modified) * c/src/lib/libbsp/mips/p4000/ChangeLog (modified) * c/src/lib/libbsp/mips/p4000/configure.ac (modified) * c/src/lib/libbsp/mips64orion/ChangeLog (modified) * c/src/lib/libbsp/mips64orion/configure.ac (modified) * c/src/lib/libbsp/mips64orion/p4000/ChangeLog (modified) * c/src/lib/libbsp/mips64orion/p4000/configure.ac (modified) * c/src/lib/libbsp/no_cpu/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/configure.ac (modified) * c/src/lib/libbsp/no_cpu/no_bsp/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.ac (modified) * c/src/lib/libbsp/or32/ChangeLog (modified) * c/src/lib/libbsp/or32/configure.ac (modified) * c/src/lib/libbsp/or32/orp/ChangeLog (modified) * c/src/lib/libbsp/or32/orp/configure.ac (modified) * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/dmv177/ChangeLog (modified) * c/src/lib/libbsp/powerpc/dmv177/configure.ac (modified) * c/src/lib/libbsp/powerpc/eth_comm/ChangeLog (modified) * c/src/lib/libbsp/powerpc/eth_comm/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen405/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen405/configure.ac (modified) * c/src/lib/libbsp/powerpc/helas403/ChangeLog (modified) * c/src/lib/libbsp/powerpc/helas403/configure.ac (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mbx8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/tools/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure.ac (modified) * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/configure.ac (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/ChangeLog (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/configure.ac (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/ChangeLog (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/configure.ac (modified) * c/src/lib/libbsp/sh/ChangeLog (modified) * c/src/lib/libbsp/sh/configure.ac (modified) * c/src/lib/libbsp/sh/gensh1/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh1/configure.ac (modified) * c/src/lib/libbsp/sh/gensh2/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh2/configure.ac (modified) * c/src/lib/libbsp/sh/gensh4/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh4/configure.ac (modified) * c/src/lib/libbsp/sh/shsim/ChangeLog (modified) * c/src/lib/libbsp/sh/shsim/configure.ac (modified) * c/src/lib/libbsp/sh/simsh4/ChangeLog (modified) * c/src/lib/libbsp/sh/simsh4/configure.ac (modified) * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure.ac (modified) * c/src/lib/libbsp/sparc/leon/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon/configure.ac (modified) * c/src/lib/libbsp/sparc/leon/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon/tools/configure.ac (modified) * c/src/lib/libbsp/unix/ChangeLog (modified) * c/src/lib/libbsp/unix/configure.ac (modified) * c/src/lib/libbsp/unix/posix/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/configure.ac (modified) * c/src/lib/libbsp/unix/posix/tools/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/tools/configure.ac (modified) * c/src/lib/libcpu/hppa1.1/ChangeLog (modified) * c/src/lib/libcpu/hppa1.1/configure.ac (modified) * c/src/lib/libcpu/i386/ChangeLog (modified) * c/src/lib/libcpu/i386/configure.ac (modified) * c/src/lib/libcpu/i960/ChangeLog (modified) * c/src/lib/libcpu/i960/configure.ac (modified) * c/src/lib/libcpu/m68k/ChangeLog (modified) * c/src/lib/libcpu/m68k/configure.ac (modified) * c/src/lib/libcpu/m68k/mcf5206/ChangeLog (modified) * c/src/lib/libcpu/m68k/mcf5206/configure.ac (modified) * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips/configure.ac (modified) * c/src/lib/libcpu/mips64orion/ChangeLog (modified) * c/src/lib/libcpu/mips64orion/configure.ac (modified) * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) * c/src/lib/libcpu/powerpc/new-exceptions/ChangeLog (modified) * c/src/lib/libcpu/powerpc/old-exceptions/ChangeLog (modified) * c/src/lib/libcpu/sh/ChangeLog (modified) * c/src/lib/libcpu/sh/configure.ac (modified) * c/src/lib/libcpu/sh/sh7032/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7032/configure.ac (modified) * c/src/lib/libcpu/sh/sh7045/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7045/configure.ac (modified) * c/src/lib/libcpu/sh/sh7750/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7750/configure.ac (modified) * c/src/lib/libcpu/sparc/ChangeLog (modified) * c/src/lib/libcpu/sparc/configure.ac (modified) * c/src/librtems++/ChangeLog (modified) * c/src/librtems++/configure.ac (modified) * c/src/make/ChangeLog (modified) * c/src/make/configure.ac (modified) * c/src/tests/ChangeLog (modified) * c/src/tests/configure.ac (modified) * c/src/tests/itrontests/ChangeLog (modified) * c/src/tests/itrontests/configure.ac (modified) * c/src/tests/libtests/ChangeLog (modified) * c/src/tests/libtests/configure.ac (modified) * c/src/tests/mptests/ChangeLog (modified) * c/src/tests/mptests/configure.ac (modified) * c/src/tests/psxtests/ChangeLog (modified) * c/src/tests/psxtests/configure.ac (modified) * c/src/tests/samples/ChangeLog (modified) * c/src/tests/samples/configure.ac (modified) * c/src/tests/sptests/ChangeLog (modified) * c/src/tests/sptests/configure.ac (modified) * c/src/tests/support/ChangeLog (modified) * c/src/tests/support/configure.ac (modified) * c/src/tests/tmitrontests/ChangeLog (modified) * c/src/tests/tmitrontests/configure.ac (modified) * c/src/tests/tmtests/ChangeLog (modified) * c/src/tests/tmtests/configure.ac (modified) * c/src/tests/tools/ChangeLog (modified) * c/src/tests/tools/configure.ac (modified) * c/src/tests/tools/generic/ChangeLog (modified) * c/src/tests/tools/generic/configure.ac (modified) * configure.ac (modified) * contrib/cygwin/ChangeLog (modified) * contrib/cygwin/configure.ac (modified) * contrib/solaris/ChangeLog (modified) * contrib/solaris/configure.ac (modified) * cpukit/ChangeLog (modified) * cpukit/configure.ac (modified) * cpukit/score/cpu/arm/ChangeLog (modified) * cpukit/score/cpu/arm/configure.ac (modified) * cpukit/score/cpu/c4x/ChangeLog (modified) * cpukit/score/cpu/c4x/configure.ac (modified) * cpukit/score/cpu/h8300/ChangeLog (modified) * cpukit/score/cpu/h8300/configure.ac (modified) * cpukit/score/cpu/hppa1.1/ChangeLog (modified) * cpukit/score/cpu/hppa1.1/configure.ac (modified) * cpukit/score/cpu/i386/ChangeLog (modified) * cpukit/score/cpu/i386/configure.ac (modified) * cpukit/score/cpu/i960/ChangeLog (modified) * cpukit/score/cpu/i960/configure.ac (modified) * cpukit/score/cpu/m68k/ChangeLog (modified) * cpukit/score/cpu/m68k/configure.ac (modified) * cpukit/score/cpu/mips/ChangeLog (modified) * cpukit/score/cpu/mips/configure.ac (modified) * cpukit/score/cpu/mips64orion/ChangeLog (modified) * cpukit/score/cpu/mips64orion/configure.ac (modified) * cpukit/score/cpu/no_cpu/ChangeLog (modified) * cpukit/score/cpu/no_cpu/configure.ac (modified) * cpukit/score/cpu/or32/ChangeLog (modified) * cpukit/score/cpu/or32/configure.ac (modified) * cpukit/score/cpu/powerpc/ChangeLog (modified) * cpukit/score/cpu/powerpc/configure.ac (modified) * cpukit/score/cpu/sh/ChangeLog (modified) * cpukit/score/cpu/sh/configure.ac (modified) * cpukit/score/cpu/sparc/ChangeLog (modified) * cpukit/score/cpu/sparc/configure.ac (modified) * cpukit/score/cpu/unix/ChangeLog (modified) * cpukit/score/cpu/unix/configure.ac (modified) * doc/ChangeLog (modified) * doc/configure.ac (modified) * doc/tools/ChangeLog (modified) * doc/tools/configure.ac (modified) * scripts/ChangeLog (modified) * scripts/configure.ac (modified) * testsuites/ChangeLog (modified) * testsuites/configure.ac (modified) * testsuites/itrontests/ChangeLog (modified) * testsuites/itrontests/configure.ac (modified) * testsuites/libtests/ChangeLog (modified) * testsuites/libtests/configure.ac (modified) * testsuites/mptests/ChangeLog (modified) * testsuites/mptests/configure.ac (modified) * testsuites/psxtests/ChangeLog (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/samples/ChangeLog (modified) * testsuites/samples/configure.ac (modified) * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/configure.ac (modified) * testsuites/support/ChangeLog (modified) * testsuites/support/configure.ac (modified) * testsuites/tmitrontests/ChangeLog (modified) * testsuites/tmitrontests/configure.ac (modified) * testsuites/tmtests/ChangeLog (modified) * testsuites/tmtests/configure.ac (modified) * testsuites/tools/ChangeLog (modified) * testsuites/tools/configure.ac (modified) * testsuites/tools/generic/ChangeLog (modified) * testsuites/tools/generic/configure.ac (modified) * tools/build/ChangeLog (modified) * tools/build/configure.ac (modified) * tools/cpu/ChangeLog (modified) * tools/cpu/configure.ac (modified) * tools/cpu/generic/ChangeLog (modified) * tools/cpu/generic/configure.ac (modified) * tools/cpu/hppa1.1/ChangeLog (modified) * tools/cpu/hppa1.1/configure.ac (modified) * tools/cpu/sh/ChangeLog (modified) * tools/cpu/sh/configure.ac (modified) 2003-08-11 Ralf Corsepius * ... Thu, 07 Aug 2003 05:17:27 GMT Ralf Corsepius [8e7cdc8b] * doc/ChangeLog (modified) * doc/configure.ac (modified) * doc/project.am (modified) Merger from rtems-4-6-branch Thu, 07 Aug 2003 05:07:43 GMT Ralf Corsepius [6b5a7b50] * doc/started/ChangeLog (modified) * doc/started/buildc.t (modified) * doc/started/sample.t (modified) Merger from rtems-4-6-branch Thu, 22 May 2003 08:27:11 GMT Ralf Corsepius [9c8530f7] * doc/user/ChangeLog (modified) * doc/user/fatal.t (modified) 2003-05-22 Ralf Corsepius * ... Thu, 22 May 2003 08:10:04 GMT Ralf Corsepius [aa84e20] * doc/supplements/c4x/ChangeLog (modified) * doc/supplements/c4x/cpumodel.t (modified) * doc/supplements/hppa1_1/ChangeLog (modified) * doc/supplements/hppa1_1/cpumodel.t (modified) * doc/supplements/i386/ChangeLog (modified) * doc/supplements/i386/cpumodel.t (modified) * doc/supplements/i960/ChangeLog (modified) * doc/supplements/i960/cpumodel.t (modified) * doc/supplements/m68k/ChangeLog (modified) * doc/supplements/m68k/cpumodel.t (modified) * doc/supplements/mips/ChangeLog (modified) * doc/supplements/mips/cpumodel.t (modified) * doc/supplements/mips64orion/ChangeLog (modified) * doc/supplements/mips64orion/cpumodel.t (modified) * doc/supplements/powerpc/ChangeLog (modified) * doc/supplements/powerpc/cpumodel.t (modified) * doc/supplements/sh/ChangeLog (modified) * doc/supplements/sh/cpumodel.t (modified) * doc/supplements/sparc/ChangeLog (modified) * doc/supplements/sparc/cpumodel.t (modified) * doc/supplements/template/ChangeLog (modified) * doc/supplements/template/cpumodel.t (modified) Merger from rtems-4-6-branch Thu, 22 May 2003 08:00:44 GMT Ralf Corsepius [c6af99c3] * doc/rgdb_specs/daemon.t (modified) 2003-05-22 Ralf Corsepius * ... Thu, 22 May 2003 08:00:40 GMT Ralf Corsepius [ecce793] * doc/rtems_gdb/example.t (modified) 2003-05-22 Ralf Corsepius * ... Thu, 22 May 2003 08:00:37 GMT Ralf Corsepius [98caa4d] * doc/FAQ/build45.t (modified) 2003-05-22 Ralf Corsepius * ... Thu, 22 May 2003 07:55:14 GMT Ralf Corsepius [8ed29f5] * doc/rgdb_specs/ChangeLog (modified) 2003-05-22 Ralf Corsepius * ... Thu, 22 May 2003 07:55:12 GMT Ralf Corsepius [0da77cd6] * doc/rtems_gdb/ChangeLog (modified) 2003-05-22 Ralf Corsepius * ... Thu, 22 May 2003 07:55:11 GMT Ralf Corsepius [f69ccda9] * doc/FAQ/ChangeLog (modified) 2003-05-22 Ralf Corsepius * ... Wed, 21 May 2003 19:33:35 GMT Ralf Corsepius [4567d3ce] * doc/tools/texi2www/ChangeLog (modified) * doc/tools/texi2www/texi2www (modified) 2003-05-21 Ralf Corsepius * ... Tue, 29 Apr 2003 10:45:29 GMT Ralf Corsepius [401ae9c] * doc/develenv/ChangeLog (modified) * doc/develenv/develenv.texi (modified) Merger from rtems-4-6-branch. Thu, 17 Apr 2003 19:37:11 GMT Joel Sherrill [712d19d] * doc/ChangeLog (modified) * doc/started/tversions.texi (modified) 2003-04-11 Joel Sherrill * ... Wed, 16 Apr 2003 13:15:14 GMT Joel Sherrill [4a29412] * doc/develenv/ChangeLog (modified) * doc/develenv/Makefile.am (modified) * doc/develenv/compile.texi (deleted) * doc/develenv/develenv.texi (modified) 2003-04-16 Joel Sherrill * ... Wed, 16 Apr 2003 13:08:03 GMT Joel Sherrill [82f9768c] * doc/develenv/ChangeLog (modified) * doc/develenv/Makefile.am (modified) 2003-04-16 Joel Sherrill * ... Fri, 11 Apr 2003 21:46:24 GMT Joel Sherrill [f72c3bf] * doc/ChangeLog (modified) * doc/index.html.in (modified) 2003-04-11 Joel Sherrill * ... Mon, 24 Mar 2003 16:40:49 GMT Joel Sherrill [818ab36a] * doc/develenv/ChangeLog (modified) * doc/develenv/direct.t (modified) * doc/develenv/sample.t (modified) * doc/develenv/utils.t (modified) 2003-03-24 Joel Sherrill * ... Fri, 28 Feb 2003 14:09:32 GMT Joel Sherrill [68d4f9e] * doc/develenv/.cvsignore (modified) * doc/develenv/ChangeLog (modified) 2003-02-28 Joel Sherrill * ... Tue, 18 Feb 2003 16:17:00 GMT Joel Sherrill [64151bf] * doc/ChangeLog (modified) * doc/Makefile.am (modified) * doc/configure.ac (modified) * doc/index.html.in (modified) 2003-02-18 Joel Sherrill * ... Tue, 18 Feb 2003 16:16:12 GMT Joel Sherrill [aa41429] * doc/develenv/ChangeLog (modified) * doc/develenv/Makefile.am (modified) * doc/develenv/develenv.texi (modified) * doc/develenv/direct.t (moved) * doc/develenv/sample.t (moved) * doc/develenv/utils.t (moved) 2003-02-18 Joel Sherrill * ... Fri, 14 Feb 2003 19:50:29 GMT Joel Sherrill [c4b0613f] * doc/ChangeLog (modified) * doc/index.html.in (modified) 2003-02-14 Joel Sherrill * ... Fri, 14 Feb 2003 19:50:11 GMT Joel Sherrill [37b30dc] * doc/porting/ChangeLog (modified) * doc/porting/cpumodels.t (modified) 2003-02-14 Joel Sherrill * ... Fri, 14 Feb 2003 19:49:44 GMT Joel Sherrill [53d5cf48] * doc/user/ChangeLog (modified) * doc/user/preface.texi (modified) 2003-02-14 Joel Sherrill * ... Fri, 14 Feb 2003 19:49:20 GMT Joel Sherrill [52ffa3e] * doc/FAQ/ChangeLog (modified) * doc/FAQ/basic.t (modified) * doc/FAQ/entry (modified) 2003-02-14 Joel Sherrill * basic.t, ... Fri, 14 Feb 2003 19:33:56 GMT Joel Sherrill [a6f8daab] * ChangeLog (modified) * cpukit/score/cpu/powerpc/rtems/powerpc/registers.h (modified) * doc/src2html/.cvsignore (deleted) * doc/src2html/ChangeLog (deleted) * doc/src2html/Makefile.am (deleted) * doc/src2html/RTEMS.test (deleted) * doc/tools/ChangeLog (modified) 2003-02-14 Till Straumann ... Fri, 14 Feb 2003 03:29:01 GMT Ralf Corsepius [e84c5286] * doc/tools/ChangeLog (modified) * doc/tools/Makefile.am (modified) * doc/tools/configure.ac (modified) * doc/tools/src2html/.cvsignore (deleted) * doc/tools/src2html/ChangeLog (deleted) * doc/tools/src2html/Makefile.am (deleted) * doc/tools/src2html1.4a/.cvsignore (deleted) * doc/tools/src2html1.4a/ChangeLog (deleted) * doc/tools/src2html1.4a/Ctags/.cvsignore (deleted) * doc/tools/src2html1.4a/Ctags/C.c (deleted) * doc/tools/src2html1.4a/Ctags/Makefile.am (deleted) * doc/tools/src2html1.4a/Ctags/ctags.1 (deleted) * doc/tools/src2html1.4a/Ctags/ctags.c (deleted) * doc/tools/src2html1.4a/Ctags/ctags.h (deleted) * doc/tools/src2html1.4a/Ctags/fortran.c (deleted) * doc/tools/src2html1.4a/Ctags/lisp.c (deleted) * doc/tools/src2html1.4a/Ctags/print.c (deleted) * doc/tools/src2html1.4a/Ctags/strerror.c (deleted) * doc/tools/src2html1.4a/Ctags/tree.c (deleted) * doc/tools/src2html1.4a/Ctags/yacc.c (deleted) * doc/tools/src2html1.4a/Ctags/z.c (deleted) * doc/tools/src2html1.4a/FreeBSD/.cvsignore (deleted) * doc/tools/src2html1.4a/FreeBSD/FreeBSD.hdr (deleted) * doc/tools/src2html1.4a/FreeBSD/FreeBSD.s2h (deleted) * doc/tools/src2html1.4a/FreeBSD/Makefile.am (deleted) * doc/tools/src2html1.4a/FreeBSD/conf.hdr (deleted) * doc/tools/src2html1.4a/FreeBSD/ddb.hdr (deleted) * doc/tools/src2html1.4a/FreeBSD/i386.i386.hdr (deleted) * doc/tools/src2html1.4a/FreeBSD/i386.include.hdr (deleted) * doc/tools/src2html1.4a/FreeBSD/i386.isa.hdr (deleted) * doc/tools/src2html1.4a/FreeBSD/i386.stand.hdr (deleted) * doc/tools/src2html1.4a/FreeBSD/kern.hdr (deleted) * doc/tools/src2html1.4a/FreeBSD/net.hdr (deleted) * doc/tools/src2html1.4a/FreeBSD/netinet.hdr (deleted) * doc/tools/src2html1.4a/FreeBSD/nfs.hdr (deleted) * doc/tools/src2html1.4a/FreeBSD/stand.hdr (deleted) * doc/tools/src2html1.4a/FreeBSD/sys.hdr (deleted) * doc/tools/src2html1.4a/FreeBSD/ufs.hdr (deleted) * doc/tools/src2html1.4a/FreeBSD/vm.hdr (deleted) * doc/tools/src2html1.4a/Makefile.am (deleted) * doc/tools/src2html1.4a/Readme (deleted) * doc/tools/src2html1.4a/ctags-emacs/.cvsignore (deleted) * doc/tools/src2html1.4a/ctags-emacs/Makefile.am (deleted) * doc/tools/src2html1.4a/ctags-emacs/README (deleted) * doc/tools/src2html1.4a/ctags-emacs/ctags (deleted) * doc/tools/src2html1.4a/ctags-emacs/etags.c-ada-patch (deleted) * doc/tools/src2html1.4a/ctags-wr (deleted) * doc/tools/src2html1.4a/src2html (deleted) * doc/tools/src2html1.4a/src2html.1 (deleted) * doc/tools/src2html1.4a/src2html.cgi (deleted) Merger from rtems-4-6-branch. Tue, 11 Feb 2003 23:44:41 GMT Joel Sherrill [eed01493] * doc/porting/ChangeLog (modified) * doc/porting/interrupts.t (modified) 2003-02-11 Joel Sherrill * ... Tue, 11 Feb 2003 23:08:49 GMT Joel Sherrill [593904c] * doc/networking/ChangeLog (modified) * doc/networking/networkapp.t (modified) 2003-02-11 Jay Monkman * ... Tue, 11 Feb 2003 23:04:41 GMT Joel Sherrill [aba138b] * doc/networking/ChangeLog (modified) * doc/networking/networkapp.t (modified) 2003-02-11 Mike Siers * ... Tue, 11 Feb 2003 11:47:49 GMT Ralf Corsepius [ccd81b60] * c/ChangeLog (modified) * c/configure.ac (modified) * c/src/ChangeLog (modified) * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/configure.ac (modified) * c/src/ada/ChangeLog (modified) * c/src/configure.ac (modified) * c/src/lib/libbsp/ChangeLog (modified) * c/src/lib/libbsp/a29k/ChangeLog (modified) * c/src/lib/libbsp/a29k/configure.ac (modified) * c/src/lib/libbsp/a29k/portsw/ChangeLog (modified) * c/src/lib/libbsp/a29k/portsw/configure.ac (modified) * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/ChangeLog (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/configure.ac (modified) * c/src/lib/libbsp/arm/armulator/ChangeLog (modified) * c/src/lib/libbsp/arm/armulator/configure.ac (modified) * c/src/lib/libbsp/arm/configure.ac (modified) * c/src/lib/libbsp/arm/edb7312/ChangeLog (modified) * c/src/lib/libbsp/arm/edb7312/configure.ac (modified) * c/src/lib/libbsp/arm/vegaplus/ChangeLog (modified) * c/src/lib/libbsp/arm/vegaplus/configure.ac (modified) * c/src/lib/libbsp/bare/ChangeLog (modified) * c/src/lib/libbsp/bare/configure.ac (modified) * c/src/lib/libbsp/c4x/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/configure.ac (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/configure.ac (modified) * c/src/lib/libbsp/c4x/configure.ac (modified) * c/src/lib/libbsp/configure.ac (modified) * c/src/lib/libbsp/h8300/ChangeLog (modified) * c/src/lib/libbsp/h8300/configure.ac (modified) * c/src/lib/libbsp/h8300/h8sim/ChangeLog (modified) * c/src/lib/libbsp/h8300/h8sim/configure.ac (modified) * c/src/lib/libbsp/hppa1.1/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/configure.ac (modified) * c/src/lib/libbsp/hppa1.1/simhppa/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/simhppa/configure.ac (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure.ac (modified) * c/src/lib/libbsp/i386/ChangeLog (modified) * c/src/lib/libbsp/i386/configure.ac (modified) * c/src/lib/libbsp/i386/i386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/i386ex/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/configure.ac (modified) * c/src/lib/libbsp/i960/ChangeLog (modified) * c/src/lib/libbsp/i960/configure.ac (modified) * c/src/lib/libbsp/i960/cvme961/ChangeLog (modified) * c/src/lib/libbsp/i960/cvme961/configure.ac (modified) * c/src/lib/libbsp/i960/i960sim/ChangeLog (modified) * c/src/lib/libbsp/i960/i960sim/configure.ac (modified) * c/src/lib/libbsp/i960/rxgen960/ChangeLog (modified) * c/src/lib/libbsp/i960/rxgen960/configure.ac (modified) * c/src/lib/libbsp/m68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/configure.ac (modified) * c/src/lib/libbsp/m68k/dmv152/ChangeLog (modified) * c/src/lib/libbsp/m68k/dmv152/configure.ac (modified) * c/src/lib/libbsp/m68k/efi332/ChangeLog (modified) * c/src/lib/libbsp/m68k/efi332/configure.ac (modified) * c/src/lib/libbsp/m68k/efi68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/efi68k/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68302/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68340/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68340/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68360/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68360/configure.ac (modified) * c/src/lib/libbsp/m68k/idp/ChangeLog (modified) * c/src/lib/libbsp/m68k/idp/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mrm332/ChangeLog (modified) * c/src/lib/libbsp/m68k/mrm332/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme136/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme136/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147s/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme167/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme167/configure.ac (modified) * c/src/lib/libbsp/m68k/ods68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/ods68302/configure.ac (modified) * c/src/lib/libbsp/m68k/sim68000/ChangeLog (modified) * c/src/lib/libbsp/m68k/sim68000/configure.ac (modified) * c/src/lib/libbsp/mips/ChangeLog (modified) * c/src/lib/libbsp/mips/configure.ac (modified) * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/tools/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/tools/configure.ac (modified) * c/src/lib/libbsp/mips/p4000/ChangeLog (modified) * c/src/lib/libbsp/mips/p4000/configure.ac (modified) * c/src/lib/libbsp/mips64orion/ChangeLog (modified) * c/src/lib/libbsp/mips64orion/configure.ac (modified) * c/src/lib/libbsp/mips64orion/p4000/ChangeLog (modified) * c/src/lib/libbsp/mips64orion/p4000/configure.ac (modified) * c/src/lib/libbsp/no_cpu/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/configure.ac (modified) * c/src/lib/libbsp/no_cpu/no_bsp/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.ac (modified) * c/src/lib/libbsp/or32/ChangeLog (modified) * c/src/lib/libbsp/or32/configure.ac (modified) * c/src/lib/libbsp/or32/orp/ChangeLog (modified) * c/src/lib/libbsp/or32/orp/configure.ac (modified) * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/dmv177/ChangeLog (modified) * c/src/lib/libbsp/powerpc/dmv177/configure.ac (modified) * c/src/lib/libbsp/powerpc/eth_comm/ChangeLog (modified) * c/src/lib/libbsp/powerpc/eth_comm/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen405/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen405/configure.ac (modified) * c/src/lib/libbsp/powerpc/helas403/ChangeLog (modified) * c/src/lib/libbsp/powerpc/helas403/configure.ac (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mbx8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/tools/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure.ac (modified) * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/configure.ac (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/ChangeLog (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/configure.ac (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/ChangeLog (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/configure.ac (modified) * c/src/lib/libbsp/sh/ChangeLog (modified) * c/src/lib/libbsp/sh/configure.ac (modified) * c/src/lib/libbsp/sh/gensh1/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh1/configure.ac (modified) * c/src/lib/libbsp/sh/gensh2/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh2/configure.ac (modified) * c/src/lib/libbsp/sh/gensh4/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh4/configure.ac (modified) * c/src/lib/libbsp/sh/shsim/ChangeLog (modified) * c/src/lib/libbsp/sh/shsim/configure.ac (modified) * c/src/lib/libbsp/sh/simsh4/ChangeLog (modified) * c/src/lib/libbsp/sh/simsh4/configure.ac (modified) * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure.ac (modified) * c/src/lib/libbsp/sparc/leon/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon/configure.ac (modified) * c/src/lib/libbsp/sparc/leon/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon/tools/configure.ac (modified) * c/src/lib/libbsp/unix/ChangeLog (modified) * c/src/lib/libbsp/unix/configure.ac (modified) * c/src/lib/libbsp/unix/posix/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/configure.ac (modified) * c/src/lib/libbsp/unix/posix/tools/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/tools/configure.ac (modified) * c/src/lib/libcpu/ChangeLog (modified) * c/src/lib/libcpu/a29k/ChangeLog (modified) * c/src/lib/libcpu/a29k/configure.ac (modified) * c/src/lib/libcpu/configure.ac (modified) * c/src/lib/libcpu/hppa1.1/ChangeLog (modified) * c/src/lib/libcpu/hppa1.1/configure.ac (modified) * c/src/lib/libcpu/i386/ChangeLog (modified) * c/src/lib/libcpu/i386/configure.ac (modified) * c/src/lib/libcpu/i960/ChangeLog (modified) * c/src/lib/libcpu/i960/configure.ac (modified) * c/src/lib/libcpu/m68k/ChangeLog (modified) * c/src/lib/libcpu/m68k/configure.ac (modified) * c/src/lib/libcpu/m68k/mcf5206/ChangeLog (modified) * c/src/lib/libcpu/m68k/mcf5206/configure.ac (modified) * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips/configure.ac (modified) * c/src/lib/libcpu/mips64orion/ChangeLog (modified) * c/src/lib/libcpu/mips64orion/configure.ac (modified) * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) * c/src/lib/libcpu/powerpc/new-exceptions/ChangeLog (modified) * c/src/lib/libcpu/powerpc/old-exceptions/ChangeLog (modified) * c/src/lib/libcpu/sh/ChangeLog (modified) * c/src/lib/libcpu/sh/configure.ac (modified) * c/src/lib/libcpu/sh/sh7032/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7032/configure.ac (modified) * c/src/lib/libcpu/sh/sh7045/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7045/configure.ac (modified) * c/src/lib/libcpu/sh/sh7750/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7750/configure.ac (modified) * c/src/lib/libcpu/sparc/ChangeLog (modified) * c/src/lib/libcpu/sparc/configure.ac (modified) * c/src/libchip/ChangeLog (modified) * c/src/libchip/configure.ac (modified) * c/src/libnetworking/ChangeLog (modified) * c/src/libnetworking/configure.ac (modified) * c/src/librdbg/ChangeLog (modified) * c/src/librdbg/configure.ac (modified) * c/src/make/ChangeLog (modified) * c/src/make/configure.ac (modified) * c/src/optman/ChangeLog (modified) * c/src/optman/configure.ac (modified) * c/src/tests/ChangeLog (modified) * c/src/tests/configure.ac (modified) * c/src/tests/itrontests/ChangeLog (modified) * c/src/tests/itrontests/configure.ac (modified) * c/src/tests/mptests/ChangeLog (modified) * c/src/tests/mptests/configure.ac (modified) * c/src/tests/psxtests/ChangeLog (modified) * c/src/tests/psxtests/configure.ac (modified) * c/src/tests/samples/ChangeLog (modified) * c/src/tests/samples/configure.ac (modified) * c/src/tests/sptests/ChangeLog (modified) * c/src/tests/sptests/configure.ac (modified) * c/src/tests/support/ChangeLog (modified) * c/src/tests/support/configure.ac (modified) * c/src/tests/tmitrontests/ChangeLog (modified) * c/src/tests/tmitrontests/configure.ac (modified) * c/src/tests/tmtests/ChangeLog (modified) * c/src/tests/tmtests/configure.ac (modified) * c/src/tests/tools/ChangeLog (modified) * c/src/tests/tools/configure.ac (modified) * c/src/tests/tools/generic/ChangeLog (modified) * c/src/tests/tools/generic/configure.ac (modified) * contrib/cygwin/ChangeLog (modified) * contrib/cygwin/configure.ac (modified) * contrib/solaris/ChangeLog (modified) * contrib/solaris/configure.ac (modified) * cpukit/ada/ChangeLog (modified) * cpukit/ada/configure.ac (modified) * cpukit/itron/ChangeLog (modified) * cpukit/itron/configure.ac (modified) * cpukit/libblock/ChangeLog (modified) * cpukit/libblock/configure.ac (modified) * cpukit/libcsupport/ChangeLog (modified) * cpukit/libcsupport/configure.ac (modified) * cpukit/libfs/ChangeLog (modified) * cpukit/libfs/configure.ac (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/configure.ac (modified) * cpukit/librpc/ChangeLog (modified) * cpukit/librpc/configure.ac (modified) * cpukit/posix/ChangeLog (modified) * cpukit/posix/configure.ac (modified) * doc/tools/ChangeLog (modified) * doc/tools/configure.ac (modified) * scripts/ChangeLog (modified) * scripts/configure.ac (modified) * testsuites/ChangeLog (modified) * testsuites/configure.ac (modified) * testsuites/itrontests/ChangeLog (modified) * testsuites/itrontests/configure.ac (modified) * testsuites/mptests/ChangeLog (modified) * testsuites/mptests/configure.ac (modified) * testsuites/psxtests/ChangeLog (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/samples/ChangeLog (modified) * testsuites/samples/configure.ac (modified) * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/configure.ac (modified) * testsuites/support/ChangeLog (modified) * testsuites/support/configure.ac (modified) * testsuites/tmitrontests/ChangeLog (modified) * testsuites/tmitrontests/configure.ac (modified) * testsuites/tmtests/ChangeLog (modified) * testsuites/tmtests/configure.ac (modified) * testsuites/tools/ChangeLog (modified) * testsuites/tools/configure.ac (modified) * testsuites/tools/generic/ChangeLog (modified) * testsuites/tools/generic/configure.ac (modified) * tools/build/ChangeLog (modified) * tools/build/configure.ac (modified) * tools/cpu/ChangeLog (modified) * tools/cpu/configure.ac (modified) * tools/cpu/generic/ChangeLog (modified) * tools/cpu/generic/configure.ac (modified) * tools/cpu/hppa1.1/ChangeLog (modified) * tools/cpu/hppa1.1/configure.ac (modified) * tools/cpu/sh/ChangeLog (modified) * tools/cpu/sh/configure.ac (modified) * tools/update/ChangeLog (modified) * tools/update/configure.ac (modified) 2003-02-11 Ralf Corsepius * ... Tue, 11 Feb 2003 11:11:33 GMT Ralf Corsepius [9b5c258] * c/ChangeLog (modified) * c/configure.ac (modified) * c/src/ChangeLog (modified) * c/src/ada-tests/ChangeLog (modified) * c/src/ada-tests/configure.ac (modified) * c/src/ada/ChangeLog (modified) * c/src/configure.ac (modified) * c/src/lib/libbsp/ChangeLog (modified) * c/src/lib/libbsp/a29k/ChangeLog (modified) * c/src/lib/libbsp/a29k/configure.ac (modified) * c/src/lib/libbsp/a29k/portsw/ChangeLog (modified) * c/src/lib/libbsp/a29k/portsw/configure.ac (modified) * c/src/lib/libbsp/arm/ChangeLog (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/ChangeLog (modified) * c/src/lib/libbsp/arm/arm_bare_bsp/configure.ac (modified) * c/src/lib/libbsp/arm/armulator/ChangeLog (modified) * c/src/lib/libbsp/arm/armulator/configure.ac (modified) * c/src/lib/libbsp/arm/configure.ac (modified) * c/src/lib/libbsp/arm/edb7312/ChangeLog (modified) * c/src/lib/libbsp/arm/edb7312/configure.ac (modified) * c/src/lib/libbsp/arm/vegaplus/ChangeLog (modified) * c/src/lib/libbsp/arm/vegaplus/configure.ac (modified) * c/src/lib/libbsp/bare/ChangeLog (modified) * c/src/lib/libbsp/bare/configure.ac (modified) * c/src/lib/libbsp/c4x/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/configure.ac (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/ChangeLog (modified) * c/src/lib/libbsp/c4x/c4xsim/tools/configure.ac (modified) * c/src/lib/libbsp/c4x/configure.ac (modified) * c/src/lib/libbsp/configure.ac (modified) * c/src/lib/libbsp/h8300/ChangeLog (modified) * c/src/lib/libbsp/h8300/configure.ac (modified) * c/src/lib/libbsp/h8300/h8sim/ChangeLog (modified) * c/src/lib/libbsp/h8300/h8sim/configure.ac (modified) * c/src/lib/libbsp/hppa1.1/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/configure.ac (modified) * c/src/lib/libbsp/hppa1.1/simhppa/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/simhppa/configure.ac (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/ChangeLog (modified) * c/src/lib/libbsp/hppa1.1/simhppa/tools/configure.ac (modified) * c/src/lib/libbsp/i386/configure.ac (modified) * c/src/lib/libbsp/i386/i386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/i386ex/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/configure.ac (modified) * c/src/lib/libbsp/i386/pc386/tools/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/configure.ac (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/ChangeLog (modified) * c/src/lib/libbsp/i386/ts_386ex/tools/configure.ac (modified) * c/src/lib/libbsp/i960/ChangeLog (modified) * c/src/lib/libbsp/i960/configure.ac (modified) * c/src/lib/libbsp/i960/cvme961/ChangeLog (modified) * c/src/lib/libbsp/i960/cvme961/configure.ac (modified) * c/src/lib/libbsp/i960/i960sim/ChangeLog (modified) * c/src/lib/libbsp/i960/i960sim/configure.ac (modified) * c/src/lib/libbsp/i960/rxgen960/ChangeLog (modified) * c/src/lib/libbsp/i960/rxgen960/configure.ac (modified) * c/src/lib/libbsp/m68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/configure.ac (modified) * c/src/lib/libbsp/m68k/dmv152/ChangeLog (modified) * c/src/lib/libbsp/m68k/dmv152/configure.ac (modified) * c/src/lib/libbsp/m68k/efi332/ChangeLog (modified) * c/src/lib/libbsp/m68k/efi332/configure.ac (modified) * c/src/lib/libbsp/m68k/efi68k/ChangeLog (modified) * c/src/lib/libbsp/m68k/efi68k/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68302/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68340/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68340/configure.ac (modified) * c/src/lib/libbsp/m68k/gen68360/ChangeLog (modified) * c/src/lib/libbsp/m68k/gen68360/configure.ac (modified) * c/src/lib/libbsp/m68k/idp/ChangeLog (modified) * c/src/lib/libbsp/m68k/idp/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/configure.ac (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mcf5206elite/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mrm332/ChangeLog (modified) * c/src/lib/libbsp/m68k/mrm332/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme136/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme136/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme147s/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme147s/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme162/tools/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme162/tools/configure.ac (modified) * c/src/lib/libbsp/m68k/mvme167/ChangeLog (modified) * c/src/lib/libbsp/m68k/mvme167/configure.ac (modified) * c/src/lib/libbsp/m68k/ods68302/ChangeLog (modified) * c/src/lib/libbsp/m68k/ods68302/configure.ac (modified) * c/src/lib/libbsp/m68k/sim68000/ChangeLog (modified) * c/src/lib/libbsp/m68k/sim68000/configure.ac (modified) * c/src/lib/libbsp/mips/ChangeLog (modified) * c/src/lib/libbsp/mips/configure.ac (modified) * c/src/lib/libbsp/mips/genmongoosev/ChangeLog (modified) * c/src/lib/libbsp/mips/genmongoosev/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/configure.ac (modified) * c/src/lib/libbsp/mips/jmr3904/tools/ChangeLog (modified) * c/src/lib/libbsp/mips/jmr3904/tools/configure.ac (modified) * c/src/lib/libbsp/mips/p4000/ChangeLog (modified) * c/src/lib/libbsp/mips/p4000/configure.ac (modified) * c/src/lib/libbsp/mips64orion/ChangeLog (modified) * c/src/lib/libbsp/mips64orion/configure.ac (modified) * c/src/lib/libbsp/mips64orion/p4000/ChangeLog (modified) * c/src/lib/libbsp/mips64orion/p4000/configure.ac (modified) * c/src/lib/libbsp/no_cpu/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/configure.ac (modified) * c/src/lib/libbsp/no_cpu/no_bsp/ChangeLog (modified) * c/src/lib/libbsp/no_cpu/no_bsp/configure.ac (modified) * c/src/lib/libbsp/or32/ChangeLog (modified) * c/src/lib/libbsp/or32/configure.ac (modified) * c/src/lib/libbsp/or32/orp/ChangeLog (modified) * c/src/lib/libbsp/or32/orp/configure.ac (modified) * c/src/lib/libbsp/powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/dmv177/ChangeLog (modified) * c/src/lib/libbsp/powerpc/dmv177/configure.ac (modified) * c/src/lib/libbsp/powerpc/eth_comm/ChangeLog (modified) * c/src/lib/libbsp/powerpc/eth_comm/configure.ac (modified) * c/src/lib/libbsp/powerpc/gen405/ChangeLog (modified) * c/src/lib/libbsp/powerpc/gen405/configure.ac (modified) * c/src/lib/libbsp/powerpc/helas403/ChangeLog (modified) * c/src/lib/libbsp/powerpc/helas403/configure.ac (modified) * c/src/lib/libbsp/powerpc/mbx8xx/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mbx8xx/configure.ac (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/ChangeLog (modified) * c/src/lib/libbsp/powerpc/motorola_powerpc/configure.ac (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/ChangeLog (modified) * c/src/lib/libbsp/powerpc/mpc8260ads/configure.ac (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/ChangeLog (modified) * c/src/lib/libbsp/powerpc/ppcn_60x/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/configure.ac (modified) * c/src/lib/libbsp/powerpc/psim/tools/ChangeLog (modified) * c/src/lib/libbsp/powerpc/psim/tools/configure.ac (modified) * c/src/lib/libbsp/powerpc/score603e/ChangeLog (modified) * c/src/lib/libbsp/powerpc/score603e/configure.ac (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/ChangeLog (modified) * c/src/lib/libbsp/powerpc/support/new_exception_processing/configure.ac (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/ChangeLog (modified) * c/src/lib/libbsp/powerpc/support/old_exception_processing/configure.ac (modified) * c/src/lib/libbsp/sh/ChangeLog (modified) * c/src/lib/libbsp/sh/configure.ac (modified) * c/src/lib/libbsp/sh/gensh1/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh1/configure.ac (modified) * c/src/lib/libbsp/sh/gensh2/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh2/configure.ac (modified) * c/src/lib/libbsp/sh/gensh4/ChangeLog (modified) * c/src/lib/libbsp/sh/gensh4/configure.ac (modified) * c/src/lib/libbsp/sh/shsim/ChangeLog (modified) * c/src/lib/libbsp/sh/shsim/configure.ac (modified) * c/src/lib/libbsp/sh/simsh4/ChangeLog (modified) * c/src/lib/libbsp/sh/simsh4/configure.ac (modified) * c/src/lib/libbsp/sparc/ChangeLog (modified) * c/src/lib/libbsp/sparc/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/configure.ac (modified) * c/src/lib/libbsp/sparc/erc32/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/erc32/tools/configure.ac (modified) * c/src/lib/libbsp/sparc/leon/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon/configure.ac (modified) * c/src/lib/libbsp/sparc/leon/tools/ChangeLog (modified) * c/src/lib/libbsp/sparc/leon/tools/configure.ac (modified) * c/src/lib/libbsp/unix/ChangeLog (modified) * c/src/lib/libbsp/unix/configure.ac (modified) * c/src/lib/libbsp/unix/posix/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/configure.ac (modified) * c/src/lib/libbsp/unix/posix/tools/ChangeLog (modified) * c/src/lib/libbsp/unix/posix/tools/configure.ac (modified) * c/src/lib/libcpu/ChangeLog (modified) * c/src/lib/libcpu/a29k/ChangeLog (modified) * c/src/lib/libcpu/a29k/configure.ac (modified) * c/src/lib/libcpu/configure.ac (modified) * c/src/lib/libcpu/hppa1.1/ChangeLog (modified) * c/src/lib/libcpu/hppa1.1/configure.ac (modified) * c/src/lib/libcpu/i386/ChangeLog (modified) * c/src/lib/libcpu/i386/configure.ac (modified) * c/src/lib/libcpu/i960/ChangeLog (modified) * c/src/lib/libcpu/i960/configure.ac (modified) * c/src/lib/libcpu/m68k/ChangeLog (modified) * c/src/lib/libcpu/m68k/configure.ac (modified) * c/src/lib/libcpu/m68k/mcf5206/ChangeLog (modified) * c/src/lib/libcpu/m68k/mcf5206/configure.ac (modified) * c/src/lib/libcpu/mips/ChangeLog (modified) * c/src/lib/libcpu/mips/configure.ac (modified) * c/src/lib/libcpu/mips64orion/ChangeLog (modified) * c/src/lib/libcpu/mips64orion/configure.ac (modified) * c/src/lib/libcpu/powerpc/ChangeLog (modified) * c/src/lib/libcpu/powerpc/configure.ac (modified) * c/src/lib/libcpu/powerpc/new-exceptions/ChangeLog (modified) * c/src/lib/libcpu/powerpc/old-exceptions/ChangeLog (modified) * c/src/lib/libcpu/sh/ChangeLog (modified) * c/src/lib/libcpu/sh/configure.ac (modified) * c/src/lib/libcpu/sh/sh7032/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7032/configure.ac (modified) * c/src/lib/libcpu/sh/sh7045/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7045/configure.ac (modified) * c/src/lib/libcpu/sh/sh7750/ChangeLog (modified) * c/src/lib/libcpu/sh/sh7750/configure.ac (modified) * c/src/lib/libcpu/sparc/ChangeLog (modified) * c/src/lib/libcpu/sparc/configure.ac (modified) * c/src/libchip/ChangeLog (modified) * c/src/libchip/configure.ac (modified) * c/src/libnetworking/configure.ac (modified) * c/src/librdbg/ChangeLog (modified) * c/src/librdbg/configure.ac (modified) * c/src/make/ChangeLog (modified) * c/src/make/configure.ac (modified) * c/src/optman/ChangeLog (modified) * c/src/optman/configure.ac (modified) * c/src/tests/ChangeLog (modified) * c/src/tests/configure.ac (modified) * c/src/tests/itrontests/ChangeLog (modified) * c/src/tests/itrontests/configure.ac (modified) * c/src/tests/mptests/ChangeLog (modified) * c/src/tests/mptests/configure.ac (modified) * c/src/tests/psxtests/ChangeLog (modified) * c/src/tests/psxtests/configure.ac (modified) * c/src/tests/samples/ChangeLog (modified) * c/src/tests/samples/configure.ac (modified) * c/src/tests/sptests/ChangeLog (modified) * c/src/tests/sptests/configure.ac (modified) * c/src/tests/support/ChangeLog (modified) * c/src/tests/support/configure.ac (modified) * c/src/tests/tmitrontests/ChangeLog (modified) * c/src/tests/tmitrontests/configure.ac (modified) * c/src/tests/tmtests/ChangeLog (modified) * c/src/tests/tmtests/configure.ac (modified) * c/src/tests/tools/ChangeLog (modified) * c/src/tests/tools/configure.ac (modified) * c/src/tests/tools/generic/ChangeLog (modified) * c/src/tests/tools/generic/configure.ac (modified) * contrib/cygwin/ChangeLog (modified) * contrib/cygwin/configure.ac (modified) * contrib/solaris/ChangeLog (modified) * contrib/solaris/configure.ac (modified) * cpukit/ada/ChangeLog (modified) * cpukit/ada/configure.ac (modified) * cpukit/itron/ChangeLog (modified) * cpukit/itron/configure.ac (modified) * cpukit/libblock/ChangeLog (modified) * cpukit/libblock/configure.ac (modified) * cpukit/libcsupport/ChangeLog (modified) * cpukit/libcsupport/configure.ac (modified) * cpukit/libfs/ChangeLog (modified) * cpukit/libfs/configure.ac (modified) * cpukit/libnetworking/ChangeLog (modified) * cpukit/libnetworking/configure.ac (modified) * cpukit/librpc/ChangeLog (modified) * cpukit/librpc/configure.ac (modified) * cpukit/posix/ChangeLog (modified) * cpukit/posix/configure.ac (modified) * doc/tools/ChangeLog (modified) * doc/tools/configure.ac (modified) * scripts/ChangeLog (modified) * scripts/configure.ac (modified) * testsuites/ChangeLog (modified) * testsuites/configure.ac (modified) * testsuites/itrontests/ChangeLog (modified) * testsuites/itrontests/configure.ac (modified) * testsuites/mptests/ChangeLog (modified) * testsuites/mptests/configure.ac (modified) * testsuites/psxtests/ChangeLog (modified) * testsuites/psxtests/configure.ac (modified) * testsuites/samples/ChangeLog (modified) * testsuites/samples/configure.ac (modified) * testsuites/sptests/ChangeLog (modified) * testsuites/sptests/configure.ac (modified) * testsuites/support/ChangeLog (modified) * testsuites/support/configure.ac (modified) * testsuites/tmitrontests/ChangeLog (modified) * testsuites/tmitrontests/configure.ac (modified) * testsuites/tmtests/ChangeLog (modified) * testsuites/tmtests/configure.ac (modified) * testsuites/tools/ChangeLog (modified) * testsuites/tools/configure.ac (modified) * testsuites/tools/generic/ChangeLog (modified) * testsuites/tools/generic/configure.ac (modified) * tools/build/ChangeLog (modified) * tools/build/configure.ac (modified) * tools/cpu/ChangeLog (modified) * tools/cpu/configure.ac (modified) * tools/cpu/generic/ChangeLog (modified) * tools/cpu/generic/configure.ac (modified) * tools/cpu/hppa1.1/ChangeLog (modified) * tools/cpu/hppa1.1/configure.ac (modified) * tools/cpu/sh/ChangeLog (modified) * tools/cpu/sh/configure.ac (modified) * tools/update/ChangeLog (modified) * tools/update/configure.ac (modified) 2003-02-11 Ralf Corsepius * ... Mon, 03 Feb 2003 23:58:50 GMT Joel Sherrill [f4ab3d3] * doc/user/ChangeLog (modified) * doc/user/io.t (modified) 2003-02-03 Joel Sherrill PR ... Mon, 03 Feb 2003 22:06:09 GMT Joel Sherrill [50381010] * doc/user/ChangeLog (modified) * doc/user/io.t (modified) 2003-02-03 Steven Johnson PR ... Tue, 28 Jan 2003 18:46:38 GMT Joel Sherrill [34e0189a] * doc/started/ChangeLog (modified) * doc/started/tversions.texi (modified) 2003-01-28 Joel Sherrill * ... Tue, 28 Jan 2003 18:44:38 GMT Joel Sherrill [4896576c] * doc/bsp_howto/ChangeLog (modified) * doc/bsp_howto/makefiles.t (modified) * doc/bsp_howto/support.t (modified) 2003-01-28 Joel Sherrill * ... Tue, 28 Jan 2003 17:41:42 GMT Joel Sherrill [ccad44f5] * doc/supplements/c4x/.cvsignore (added) * doc/supplements/c4x/ChangeLog (modified) 2003-01-28 Joel Sherrill * ... Mon, 27 Jan 2003 14:01:27 GMT Ralf Corsepius [339ee1c8] * doc/ChangeLog (modified) * doc/index.html.in (modified) 2003-01-27 Ralf Corsepius * ... Sat, 25 Jan 2003 16:48:39 GMT Ralf Corsepius [24276d3] * doc/ChangeLog (modified) * doc/index.html.in (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 16:46:48 GMT Ralf Corsepius [d1996079] * doc/user/ChangeLog (modified) * doc/user/c_user.texi (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 16:46:46 GMT Ralf Corsepius [a1f4d99] * doc/supplements/template/ChangeLog (modified) * doc/supplements/template/template.texi (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 16:46:44 GMT Ralf Corsepius [690ca24] * doc/supplements/sparc/ChangeLog (modified) * doc/supplements/sparc/sparc.texi (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 16:46:42 GMT Ralf Corsepius [277d4fc] * doc/supplements/sh/ChangeLog (modified) * doc/supplements/sh/sh.texi (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 16:46:40 GMT Ralf Corsepius [87a4a35] * doc/supplements/powerpc/ChangeLog (modified) * doc/supplements/powerpc/powerpc.texi (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 16:46:38 GMT Ralf Corsepius [35c1543] * doc/supplements/mips64orion/ChangeLog (modified) * doc/supplements/mips64orion/mips64orion.texi (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 16:46:36 GMT Ralf Corsepius [43f0f1e] * doc/supplements/mips/ChangeLog (modified) * doc/supplements/mips/mips.texi (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 16:46:34 GMT Ralf Corsepius [4cfdfb00] * doc/supplements/m68k/ChangeLog (modified) * doc/supplements/m68k/m68k.texi (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 16:46:32 GMT Ralf Corsepius [0609066] * doc/supplements/i960/ChangeLog (modified) * doc/supplements/i960/i960.texi (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 16:46:30 GMT Ralf Corsepius [01f46a73] * doc/supplements/i386/ChangeLog (modified) * doc/supplements/i386/i386.texi (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 16:46:28 GMT Ralf Corsepius [7ff55d43] * doc/supplements/hppa1_1/ChangeLog (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 16:46:26 GMT Ralf Corsepius [b88b6bd] * doc/supplements/c4x/ChangeLog (modified) * doc/supplements/c4x/c4x.texi (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 16:46:24 GMT Ralf Corsepius [80ba9e3] * doc/supplements/arm/ChangeLog (modified) * doc/supplements/arm/arm.texi (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 16:46:22 GMT Ralf Corsepius [4eda2450] * doc/started_ada/ChangeLog (modified) * doc/started_ada/started_ada.texi (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 16:46:20 GMT Ralf Corsepius [9a237e8b] * doc/started/ChangeLog (modified) * doc/started/started.texi (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 16:46:18 GMT Ralf Corsepius [26f9f12] * doc/rtems_gdb/ChangeLog (modified) * doc/rtems_gdb/rtems_gdb.texi (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 16:46:15 GMT Ralf Corsepius [74d3d8ee] * doc/rgdb_specs/ChangeLog (modified) * doc/rgdb_specs/rgdb_specs.texi (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 16:46:13 GMT Ralf Corsepius [c48dc6dc] * doc/relnotes/ChangeLog (modified) * doc/relnotes/relnotes.texi (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 16:46:10 GMT Ralf Corsepius [8ea8326] * doc/posix_users/ChangeLog (modified) * doc/posix_users/posix_users.texi (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 16:46:07 GMT Ralf Corsepius [3664547d] * doc/posix1003.1/ChangeLog (modified) * doc/posix1003.1/posix1003_1.texi (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 16:46:05 GMT Ralf Corsepius [aa85585] * doc/porting/ChangeLog (modified) * doc/porting/porting.texi (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 16:46:03 GMT Ralf Corsepius [4be3f4d] * doc/new_chapters/ChangeLog (modified) * doc/new_chapters/new_chapters.texi (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 16:46:01 GMT Ralf Corsepius [8479103] * doc/networking/ChangeLog (modified) * doc/networking/networking.texi (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 16:45:59 GMT Ralf Corsepius [090ab6eb] * doc/itron3.0/ChangeLog (modified) * doc/itron3.0/itron.texi (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 16:45:57 GMT Ralf Corsepius [e88f92b2] * doc/filesystem/ChangeLog (modified) * doc/filesystem/filesystem.texi (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 16:45:55 GMT Ralf Corsepius [0069692] * doc/develenv/ChangeLog (modified) * doc/develenv/develenv.texi (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 16:45:53 GMT Ralf Corsepius [d1fbaa6] * doc/bsp_howto/ChangeLog (modified) * doc/bsp_howto/bsp_howto.texi (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 16:45:50 GMT Ralf Corsepius [5db2323] * doc/ada_user/ChangeLog (modified) * doc/ada_user/ada_user.texi (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 16:45:48 GMT Ralf Corsepius [ee9dde16] * doc/FAQ/ChangeLog (modified) * doc/FAQ/FAQ.texi (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 14:58:37 GMT Ralf Corsepius [58e3ab3d] * doc/ChangeLog (modified) * doc/configure.ac (modified) * doc/project.am (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 14:56:20 GMT Ralf Corsepius [f5e6429] * doc/supplements/ChangeLog (modified) * doc/supplements/Makefile.am (modified) 2003-01-25 Ralf Corsepius * ... Sat, 25 Jan 2003 14:54:27 GMT Ralf Corsepius [80bdcd7c] * doc/supplements/c4x/ChangeLog (modified) * doc/supplements/c4x/Makefile.am (added) * doc/supplements/c4x/c4x.texi (modified) * doc/supplements/c4x/cpumodel.t (modified) * doc/supplements/c4x/timeBSP.t (modified) 2003-01-25 Ralf Corsepius * ... Fri, 24 Jan 2003 13:57:31 GMT Joel Sherrill [22bd219b] * doc/supplements/c4x/BSP_TIMES (added) * doc/supplements/c4x/ChangeLog (added) * doc/supplements/c4x/bsp.t (added) * doc/supplements/c4x/c4x.texi (added) * doc/supplements/c4x/callconv.t (added) * doc/supplements/c4x/cpumodel.t (added) * doc/supplements/c4x/cputable.t (added) * doc/supplements/c4x/fatalerr.t (added) * doc/supplements/c4x/intr_NOTIMES.t (added) * doc/supplements/c4x/memmodel.t (added) * doc/supplements/c4x/preface.texi (added) * doc/supplements/c4x/timeBSP.t (added) 2003-01-24 Joel Sherrill * ... Fri, 24 Jan 2003 11:28:04 GMT Ralf Corsepius [086aae8f] * doc/supplements/ChangeLog (modified) * doc/supplements/supplement.am (modified) 2003-01-24 Ralf Corsepius * ... Fri, 24 Jan 2003 11:24:58 GMT Ralf Corsepius [3ebc6dc] * doc/itron3.0/ChangeLog (modified) * doc/itron3.0/Makefile.am (modified) * doc/networking/ChangeLog (modified) * doc/networking/Makefile.am (modified) * doc/new_chapters/ChangeLog (modified) * doc/new_chapters/Makefile.am (modified) * doc/porting/ChangeLog (modified) * doc/porting/Makefile.am (modified) * doc/posix1003.1/ChangeLog (modified) * doc/posix1003.1/Makefile.am (modified) * doc/posix_users/ChangeLog (modified) * doc/posix_users/Makefile.am (modified) * doc/rgdb_specs/ChangeLog (modified) * doc/rgdb_specs/Makefile.am (modified) * doc/rtems_gdb/ChangeLog (modified) * doc/rtems_gdb/Makefile.am (modified) * doc/started/ChangeLog (modified) * doc/started/Makefile.am (modified) * doc/started_ada/ChangeLog (modified) * doc/started_ada/Makefile.am (modified) * doc/supplements/arm/ChangeLog (modified) * doc/supplements/arm/Makefile.am (modified) * doc/supplements/hppa1_1/ChangeLog (modified) * doc/supplements/hppa1_1/Makefile.am (modified) * doc/supplements/i386/ChangeLog (modified) * doc/supplements/i386/Makefile.am (modified) * doc/supplements/i960/ChangeLog (modified) * doc/supplements/i960/Makefile.am (modified) * doc/supplements/m68k/ChangeLog (modified) * doc/supplements/m68k/Makefile.am (modified) * doc/supplements/mips/ChangeLog (modified) * doc/supplements/mips/Makefile.am (modified) * doc/supplements/mips64orion/ChangeLog (modified) * doc/supplements/mips64orion/Makefile.am (modified) * doc/supplements/powerpc/ChangeLog (modified) * doc/supplements/powerpc/Makefile.am (modified) * doc/supplements/sh/ChangeLog (modified) * doc/supplements/sh/Makefile.am (modified) * doc/supplements/sparc/ChangeLog (modified) * doc/supplements/sparc/Makefile.am (modified) * doc/supplements/template/ChangeLog (modified) * doc/supplements/template/Makefile.am (modified) * doc/user/ChangeLog (modified) * doc/user/Makefile.am (modified) 2003-01-24 Ralf Corsepius * ... Fri, 24 Jan 2003 11:16:56 GMT Ralf Corsepius [c7ddb172] * doc/FAQ/ChangeLog (modified) * doc/FAQ/Makefile.am (modified) * doc/ada_user/ChangeLog (modified) * doc/ada_user/Makefile.am (modified) * doc/bsp_howto/ChangeLog (modified) * doc/bsp_howto/Makefile.am (modified) * doc/filesystem/ChangeLog (modified) * doc/filesystem/Makefile.am (modified) 2003-01-24 Ralf Corsepius * ... Fri, 24 Jan 2003 11:16:35 GMT Ralf Corsepius [f28a6af2] * doc/ChangeLog (modified) * doc/main.am (modified) * doc/project.am (modified) 2003-01-24 Ralf Corsepius * ... Thu, 23 Jan 2003 00:04:48 GMT Ralf Corsepius [cf22081] * doc/supplements/ChangeLog (modified) * doc/supplements/supplement.am (modified) 2003-01-22 Ralf Corsepius * ...
