# # ChangeLog for doc in rtems # # Generated by Trac 1.2.1.dev0 # 05/20/24 15:17:48 Tue, 02 Mar 1999 15:56:04 GMT Joel Sherrill [97b8b8f] * doc/bsp_howto/network.t (deleted) This file is linked in Wed, 10 Feb 1999 19:51:13 GMT Joel Sherrill [cef8302] * doc/rtems_gdb/intro.t (modified) Added thank you. Wed, 10 Feb 1999 19:51:01 GMT Joel Sherrill [90fe8b3] * doc/posix1003.1/ch14.t (modified) Added POSIX timers. Wed, 10 Feb 1999 19:50:44 GMT Joel Sherrill [6ea3da8] * doc/bsp_howto/bsp_howto.texi (modified) Corrected title Wed, 10 Feb 1999 19:50:28 GMT Joel Sherrill [c626652] * doc/do_docs (modified) * doc/index.html (modified) * doc/rtems_support.html (modified) Added gdb_rtems Wed, 10 Feb 1999 19:50:01 GMT Joel Sherrill [9414e3f8] * doc/Make.config (modified) * doc/common/setup.texi (modified) * doc/started/versions.texi (modified) Changed versions. Wed, 10 Feb 1999 18:54:14 GMT Joel Sherrill [7b597b85] * doc/rtems_gdb/Makefile (modified) * doc/rtems_gdb/commands.t (modified) * doc/rtems_gdb/example.t (modified) * doc/rtems_gdb/intro.t (modified) * doc/rtems_gdb/rtems_gdb.texi (modified) * doc/rtems_gdb/started.t (modified) * doc/rtems_gdb/trouble.t (modified) Now generates HTML, PostScript, and info correctly. Wed, 10 Feb 1999 18:35:36 GMT Joel Sherrill [89d177eb] * doc/rtems_gdb/rtems_gdb.texi (added) Base file. Wed, 10 Feb 1999 18:33:15 GMT Joel Sherrill [387f41a] * doc/rtems_gdb/Makefile (added) * doc/rtems_gdb/commands.t (added) * doc/rtems_gdb/example.t (added) * doc/rtems_gdb/intro.t (added) * doc/rtems_gdb/started.t (added) * doc/rtems_gdb/swarch.t (added) * doc/rtems_gdb/trouble.t (added) Base version. Tue, 09 Feb 1999 20:31:34 GMT Joel Sherrill [c13cd48] * doc/user/conf.t (modified) Added maximum_timers field to configuration table. Tue, 09 Feb 1999 20:31:09 GMT Joel Sherrill [afc40a5] * doc/started_ada/versions.texi (modified) Changed version numbers. Tue, 09 Feb 1999 20:30:46 GMT Joel Sherrill [ba0bd42] * doc/started/versions.texi (modified) Changed versions. Tue, 09 Feb 1999 20:30:34 GMT Joel Sherrill [381fc99] * doc/networking/testing.t (modified) Added information on debug modes that can be enabled in the network ... Tue, 09 Feb 1999 20:30:11 GMT Joel Sherrill [5bb77c4] * doc/networking/Makefile (modified) Changed the name of a section. Tue, 09 Feb 1999 20:29:43 GMT Joel Sherrill [67b8f47] * doc/bsp_howto/Makefile (modified) Install the PostScript file. Tue, 09 Feb 1999 20:05:03 GMT Joel Sherrill [3ce8540] * doc/Make.config (modified) * doc/common/setup.texi (modified) Changed version. Tue, 09 Feb 1999 20:04:50 GMT Joel Sherrill [b7111263] * doc/common/cpright.texi (modified) Changed date. Wed, 03 Feb 1999 13:46:12 GMT Joel Sherrill [2a766a0] * doc/user/conf.t (modified) Added POSIX timers. Thu, 21 Jan 1999 14:51:34 GMT Joel Sherrill [3048b8f] * doc/started/Makefile (modified) * doc/started/buildc.t (modified) Added common problems section after post by Philippe Le Foll ... Thu, 17 Dec 1998 18:34:01 GMT Joel Sherrill [0296c071] * doc/user/userext.t (modified) Updated to correct information on post switch extension and to make ... Thu, 17 Dec 1998 18:21:39 GMT Joel Sherrill [94c0943] * doc/user/conf.t (modified) Corrected information about the post_switch extension. Thu, 17 Dec 1998 18:18:44 GMT Joel Sherrill [0ed9ac7] * doc/networking/networkapp.t (modified) Updated socket information Thu, 17 Dec 1998 18:15:39 GMT Joel Sherrill [183369d] * doc/bsp_howto/analog.t (modified) * doc/bsp_howto/clock.t (modified) * doc/bsp_howto/console.t (modified) * doc/bsp_howto/discrete.t (modified) * doc/bsp_howto/init.t (modified) * doc/bsp_howto/linkcmds.t (modified) * doc/bsp_howto/makefiles.t (modified) * doc/bsp_howto/nvmem.t (modified) * doc/bsp_howto/rtc.t (modified) * doc/bsp_howto/target.t (modified) * doc/bsp_howto/timer.t (modified) * doc/networking/driver.t (modified) Incorporated Jeff's suggestions. Thu, 17 Dec 1998 17:30:24 GMT Joel Sherrill [9d36726] * doc/rtems_support.html (modified) Added MIPS supplement template. Thu, 10 Dec 1998 23:35:40 GMT Joel Sherrill [cdd26ca2] * doc/networking/networkapp.t (modified) Document from Ian Lance Taylor on the tap function. Wed, 25 Nov 1998 16:25:12 GMT Joel Sherrill [8f30e3e] * doc/supplements/sh/BSP_TIMES (added) * doc/supplements/sh/Makefile (added) * doc/supplements/sh/bsp.t (added) * doc/supplements/sh/callconv.t (moved) * doc/supplements/sh/cpumodel.t (added) * doc/supplements/sh/cputable.t (added) * doc/supplements/sh/fatalerr.t (added) * doc/supplements/sh/intr_NOTIMES.t (added) * doc/supplements/sh/memmodel.t (added) * doc/supplements/sh/preface.texi (added) * doc/supplements/sh/sh.texi (added) * doc/supplements/sh/timeBSP.t (added) First Cut at Hitachi SH. Mon, 23 Nov 1998 22:09:47 GMT Joel Sherrill [f48b1000] * doc/supplements/mips64orion/BSP_TIMES (added) * doc/supplements/mips64orion/Makefile (added) * doc/supplements/mips64orion/bsp.t (added) * doc/supplements/mips64orion/callconv.t (added) * doc/supplements/mips64orion/cpumodel.t (added) * doc/supplements/mips64orion/cputable.t (added) * doc/supplements/mips64orion/fatalerr.t (added) * doc/supplements/mips64orion/intr_NOTIMES.t (added) * doc/supplements/mips64orion/memmodel.t (added) * doc/supplements/mips64orion/mips64orion.texi (added) * doc/supplements/mips64orion/preface.texi (added) * doc/supplements/mips64orion/timeBSP.t (added) New files copied from template and personalized. Thu, 19 Nov 1998 17:08:20 GMT Joel Sherrill [df4eb76e] * doc/networking/networkapp.t (modified) * doc/networking/testing.t (modified) Changed BOOTP -> BOOTP/DHCP. Thu, 19 Nov 1998 16:59:38 GMT Joel Sherrill [febb47e] * doc/Make.config (modified) * doc/bsp_howto/network.t (modified) * doc/common/setup.texi (modified) * doc/do_docs (modified) * doc/networking/Makefile (modified) * doc/networking/networking.texi (modified) * doc/posix_users/Makefile (modified) * doc/posix_users/posix_users.texi (modified) * doc/rtems_support.html (modified) Changed version string. Added much new stuff to the POSIX User's ... Thu, 19 Nov 1998 16:41:04 GMT Joel Sherrill [982e295e] * doc/new_chapters/Makefile (modified) * doc/new_chapters/new_chapters.texi (modified) Stripped down to be just new chapters. Thu, 19 Nov 1998 16:37:00 GMT Joel Sherrill [424b9b2f] * doc/new_chapters/new_chapters.texi (moved) Renamed entire document so this is a transient working directory. Thu, 19 Nov 1998 16:33:49 GMT Joel Sherrill [e926451] * doc/new_chapters/cancel.t (deleted) * doc/new_chapters/clock.t (deleted) * doc/new_chapters/cond.t (deleted) * doc/new_chapters/cspecific.t (deleted) * doc/new_chapters/device.t (deleted) * doc/new_chapters/files.t (deleted) * doc/new_chapters/io.t (deleted) * doc/new_chapters/key.t (deleted) * doc/new_chapters/memorymgmt.t (deleted) * doc/new_chapters/message.t (deleted) * doc/new_chapters/mutex.t (deleted) * doc/new_chapters/preface.texi (deleted) * doc/new_chapters/procenv.t (deleted) * doc/new_chapters/process.t (deleted) * doc/new_chapters/sched.t (deleted) * doc/new_chapters/semaphores.t (deleted) * doc/new_chapters/signal.t (deleted) * doc/new_chapters/systemdb.t (deleted) * doc/new_chapters/thread.t (deleted) Merged these into POSIX manual. Thu, 19 Nov 1998 16:08:34 GMT Joel Sherrill [28c6b2a1] * doc/posix_users/cancel.t (added) Added. Thu, 19 Nov 1998 16:07:52 GMT Joel Sherrill [cee261b] * doc/posix_users/preface.texi (added) Readded preface Thu, 19 Nov 1998 16:06:46 GMT Joel Sherrill [c4dddee] * doc/posix_users/base.texi (deleted) * doc/posix_users/clock.t (moved) * doc/posix_users/cond.t (moved) * doc/posix_users/cspecific.t (added) * doc/posix_users/device.t (added) * doc/posix_users/files.t (added) * doc/posix_users/io.t (added) * doc/posix_users/key.t (moved) * doc/posix_users/memorymgmt.t (added) * doc/posix_users/message.t (added) * doc/posix_users/mutex.t (moved) * doc/posix_users/preface.texi (deleted) * doc/posix_users/procenv.t (added) * doc/posix_users/process.t (added) * doc/posix_users/sched.t (moved) * doc/posix_users/semaphores.t (added) * doc/posix_users/signal.t (moved) * doc/posix_users/systemdb.t (added) * doc/posix_users/thread.t (moved) Major update/merge of POSIX manual. Thu, 19 Nov 1998 16:05:05 GMT Joel Sherrill [d82f3e81] * doc/new_chapters/TODO (added) * doc/new_chapters/cpuuse.t (added) * doc/new_chapters/error.t (added) * doc/new_chapters/monitor.t (added) * doc/new_chapters/rtmonuse.t (added) * doc/new_chapters/stackchk.t (added) New files Thu, 19 Nov 1998 16:02:06 GMT Joel Sherrill [bc950e87] * doc/bsp_howto/Makefile (modified) * doc/bsp_howto/analog.t (modified) * doc/bsp_howto/bsp_howto.texi (modified) * doc/bsp_howto/clock.t (modified) * doc/bsp_howto/console.t (modified) * doc/bsp_howto/discrete.t (modified) * doc/bsp_howto/init.t (modified) * doc/bsp_howto/network.t (modified) * doc/bsp_howto/nvmem.t (modified) * doc/bsp_howto/rtc.t (modified) * doc/bsp_howto/shmsupp.t (modified) * doc/bsp_howto/support.t (modified) * doc/bsp_howto/timer.t (modified) * doc/networking/driver.t (modified) * doc/new_chapters/Makefile (modified) * doc/new_chapters/files.t (modified) * doc/new_chapters/gen_section (modified) * doc/new_chapters/posix_users.texi (modified) * doc/new_chapters/signal.t (modified) * doc/posix1003.1/Makefile (modified) * doc/posix1003.1/ch06.t (modified) * doc/posix1003.1/ch14.t (modified) * doc/started/Makefile (modified) * doc/supplements/hppa1_1/cputable.t (modified) * doc/supplements/i386/cputable.t (modified) * doc/supplements/i960/cputable.t (modified) * doc/supplements/m68k/cputable.t (modified) * doc/supplements/powerpc/cputable.t (modified) * doc/supplements/sparc/cputable.t (modified) * doc/supplements/template/cputable.t (modified) Applied updates from remote work while doing class. Thu, 29 Oct 1998 16:42:51 GMT Joel Sherrill [2119f9d] * doc/do_docs (modified) * doc/posix1003.1/ch06.t (modified) * doc/posix1003.1/ch14.t (modified) * doc/rtems_support.html (modified) making release docs Tue, 27 Oct 1998 23:45:52 GMT Joel Sherrill [ecbba5fc] * doc/Make.config (modified) * doc/common/setup.texi (modified) * doc/relnotes/intro.texi (modified) * doc/started/versions.texi (modified) * doc/started_ada/buildada.t (modified) * doc/started_ada/versions.texi (modified) Version changed. Tue, 27 Oct 1998 23:34:52 GMT Joel Sherrill [b4bbd1e] * doc/started/nt.t (modified) fixes from David Fiddes Tue, 27 Oct 1998 21:29:46 GMT Joel Sherrill [2323536] * doc/tools/texi2www/texi2dvi (modified) Minor change to ease debugging. Tue, 27 Oct 1998 21:29:30 GMT Joel Sherrill [b95914f] * doc/user/task.t (modified) Spacing. Tue, 27 Oct 1998 20:40:41 GMT Joel Sherrill [9fc4ed0] * doc/started_ada/versions.texi (modified) Updated for beta4b Tue, 27 Oct 1998 20:40:22 GMT Joel Sherrill [829a116] * doc/posix1003.1/Makefile (modified) * doc/started_ada/Makefile (modified) Corrected 2nd invocation of texi2dvi so indices are built. Tue, 27 Oct 1998 19:28:20 GMT Joel Sherrill [cdf30aba] * doc/started/Makefile (modified) * doc/started/buildc.t (modified) * doc/started/nt.t (modified) * doc/started/versions.texi (modified) Update from David Fiddes. Tue, 27 Oct 1998 17:44:11 GMT Joel Sherrill [71e1207] * doc/networking/driver.t (modified) Clarifed description of driver name. Tue, 27 Oct 1998 17:43:48 GMT Joel Sherrill [0ed55ed] * doc/common/setup.texi (modified) Version changed. Tue, 27 Oct 1998 17:43:37 GMT Joel Sherrill [0a74154] * doc/Make.config (modified) Version change. Wed, 21 Oct 1998 20:21:51 GMT Joel Sherrill [c4cbe17] * doc/bsp_howto/Makefile (modified) * doc/bsp_howto/init.t (modified) * doc/bsp_howto/linkcmds.t (modified) * doc/bsp_howto/makefiles.t (modified) * doc/bsp_howto/target.t (modified) Corrections from Jennifer and Jeff plus additions to the ... Tue, 20 Oct 1998 20:36:28 GMT Joel Sherrill [b43744a6] * doc/bsp_howto/linkcmds.t (modified) * doc/bsp_howto/makefiles.t (modified) * doc/bsp_howto/target.t (modified) Spell checked. Tue, 20 Oct 1998 20:34:12 GMT Joel Sherrill [71f575e5] * doc/bsp_howto/Makefile (modified) * doc/bsp_howto/linkcmds.t (modified) * doc/bsp_howto/target.t (modified) Added much text to the linkcmds chapter. Cleaned up sections in the ... Tue, 20 Oct 1998 19:27:13 GMT Joel Sherrill [051ab3b] * doc/bsp_howto/Makefile (modified) * doc/bsp_howto/makefiles.t (modified) * doc/bsp_howto/target.t (modified) Links between chapters up to Linker Script in place. First draft of ... Tue, 20 Oct 1998 16:25:29 GMT Joel Sherrill [ee3dd9ae] * doc/bsp_howto/target.t (modified) Significant additions. Tue, 20 Oct 1998 16:25:08 GMT Joel Sherrill [acee84c] * doc/bsp_howto/bsp_howto.texi (modified) Renamed the target dependent code chapter. Tue, 20 Oct 1998 16:24:46 GMT Joel Sherrill [3912f39] * doc/bsp_howto/Makefile (modified) Added some links between chapters. Tue, 20 Oct 1998 15:06:02 GMT Joel Sherrill [a3558489] * doc/bsp_howto/intro.t (modified) Spacing changed. Tue, 20 Oct 1998 15:05:51 GMT Joel Sherrill [8c1aaa9] * doc/bsp_howto/Makefile (modified) Added new chapters. Tue, 20 Oct 1998 15:05:36 GMT Joel Sherrill [2dce00e] * doc/bsp_howto/bsp_howto.texi (modified) Added multiple chapters and reordered them somewhat. Tue, 20 Oct 1998 15:00:33 GMT Joel Sherrill [49267ee] * doc/bsp_howto/analog.t (added) * doc/bsp_howto/discrete.t (added) * doc/bsp_howto/network.t (added) * doc/bsp_howto/nvmem.t (added) * doc/bsp_howto/rtc.t (added) * doc/bsp_howto/shmsupp.t (added) * doc/bsp_howto/support.t (added) New files. Tue, 20 Oct 1998 13:49:43 GMT Joel Sherrill [4ed0f06d] * doc/bsp_howto/linkcmds.t (modified) Added numerous comments to the linker script. Now this chapter has ... Tue, 20 Oct 1998 12:51:15 GMT Joel Sherrill [5e8a37c7] * doc/new_chapters/gen_section (modified) Added initial cut at some of the libc chapters. Tue, 20 Oct 1998 12:35:47 GMT Joel Sherrill [4e40853] * doc/index.html (modified) Removed KA9Q manual. Tue, 20 Oct 1998 12:34:47 GMT Joel Sherrill [3bf5c6c] * doc/tools/texi2www/dir-arrow.gif (modified) New picture. Tue, 20 Oct 1998 12:34:32 GMT Joel Sherrill [9df94ec] * doc/started/versions.texi (modified) * doc/started_ada/versions.texi (modified) Updated. Tue, 20 Oct 1998 12:34:27 GMT Joel Sherrill [c9c605f1] * doc/started_ada/require.t (modified) Added more disk space to the requirements and included information ... Tue, 20 Oct 1998 12:34:00 GMT Joel Sherrill [00be3747] * doc/started/intro.t (modified) * doc/started_ada/intro.t (modified) Minor cleanup. Tue, 20 Oct 1998 12:33:48 GMT Joel Sherrill [3fccbb34] * doc/started/buildrt.t (modified) * doc/started_ada/buildrt.t (modified) Added information about the bit_rtems script. Tue, 20 Oct 1998 12:33:33 GMT Joel Sherrill [b7ea3ec] * doc/started_ada/buildada.t (modified) Added information about the new build scripts. Added host OS ... Tue, 20 Oct 1998 12:32:41 GMT Joel Sherrill [a5ef387f] * doc/started_ada/Makefile (modified) Added sections and had to change build menu commands. Tue, 20 Oct 1998 12:32:11 GMT Joel Sherrill [0749d858] * doc/started/require.t (modified) Increased required disk space along with information about the ... Tue, 20 Oct 1998 12:30:59 GMT Joel Sherrill [e8e2cf13] * doc/started/gdb.t (modified) Added information about the bit_gdb script. Tue, 20 Oct 1998 12:30:06 GMT Joel Sherrill [77ea5d30] * doc/started/buildc.t (modified) Added information about the new build scripts. The biggest thing was ... Tue, 20 Oct 1998 12:28:56 GMT Joel Sherrill [0b5dbf1f] * doc/started/Makefile (modified) Added sections so had to change the build menu commands. Mon, 19 Oct 1998 21:52:56 GMT Joel Sherrill [77f0853] * doc/new_chapters/procenv.t (modified) Enhanced times() with copy from the other chapter. Mon, 19 Oct 1998 21:52:40 GMT Joel Sherrill [883ffec] * doc/new_chapters/clock.t (modified) Removed times() since it is duplicated. Mon, 19 Oct 1998 21:52:15 GMT Joel Sherrill [ebaeec1] * doc/develenv/direct.texi (modified) Updated to reflect the longer list of libraries. Mon, 19 Oct 1998 21:51:59 GMT Joel Sherrill [477e06b3] * doc/common/wksheets.t (modified) Removed node information. Mon, 19 Oct 1998 21:51:42 GMT Joel Sherrill [d23a3e6] * doc/common/timetbl.t (modified) Removed node information now that it is automatically generated. Mon, 19 Oct 1998 21:51:21 GMT Joel Sherrill [f09e5a6] * doc/common/setup.texi (modified) Changed version and date strings. Mon, 19 Oct 1998 21:50:52 GMT Joel Sherrill [0d94c26] * doc/rtems_support.html (modified) Changed KA9Q to Networking. Mon, 19 Oct 1998 21:50:27 GMT Joel Sherrill [b0c34910] * doc/do_docs (modified) Cleaned up list of docs. Mon, 19 Oct 1998 21:50:16 GMT Joel Sherrill [1e19ef61] * doc/TODO (modified) Removed KA9Q issues. Mon, 19 Oct 1998 21:50:04 GMT Joel Sherrill [7e4c8246] * doc/Make.config (modified) Changed version. Mon, 19 Oct 1998 21:49:36 GMT Joel Sherrill [62cd76e] * doc/supplements/hppa1_1/Makefile (modified) * doc/supplements/i386/Makefile (modified) * doc/supplements/i960/Makefile (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/powerpc/Makefile (modified) * doc/supplements/sparc/Makefile (modified) * doc/supplements/template/Makefile (modified) Moved things around so html and clean were above stanzas which ... Mon, 19 Oct 1998 21:46:32 GMT Joel Sherrill [03889c1] * doc/supplements/i386/Makefile (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/m68k/bsp.t (modified) * doc/supplements/m68k/callconv.t (modified) * doc/supplements/m68k/cpumodel.t (modified) * doc/supplements/m68k/cputable.t (modified) * doc/supplements/m68k/fatalerr.t (modified) * doc/supplements/m68k/intr_NOTIMES.t (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/m68k/memmodel.t (modified) * doc/supplements/m68k/timeMVME136.t (modified) * doc/supplements/powerpc/Makefile (modified) * doc/supplements/sparc/Makefile (modified) * doc/supplements/sparc/bsp.t (modified) * doc/supplements/sparc/callconv.t (modified) * doc/supplements/sparc/cpumodel.t (modified) * doc/supplements/sparc/cputable.t (modified) * doc/supplements/sparc/fatalerr.t (modified) * doc/supplements/sparc/intr_NOTIMES.t (modified) * doc/supplements/sparc/memmodel.t (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/supplements/template/Makefile (modified) All of the Supplemental manuals are now generated as automatically ... Mon, 19 Oct 1998 19:53:26 GMT Joel Sherrill [2df2bef] * doc/supplements/sparc/timeERC32.t (modified) No node info Mon, 19 Oct 1998 19:46:30 GMT Joel Sherrill [17c2680] * doc/supplements/sparc/SIS_TIMES (deleted) * doc/supplements/sparc/intr.t (deleted) * doc/supplements/sparc/timedata.t (deleted) Renamed. Mon, 19 Oct 1998 19:39:55 GMT Joel Sherrill [69b5f9d] * doc/supplements/sparc/memmodel.texi (deleted) Renamed memmodel.texi to memmodel.t. Mon, 19 Oct 1998 19:39:54 GMT Joel Sherrill [34f058e] * doc/supplements/sparc/fatalerr.texi (deleted) Renamed fatalerr.texi to fatalerr.t. Mon, 19 Oct 1998 19:39:53 GMT Joel Sherrill [bbdec14] * doc/supplements/sparc/cputable.texi (deleted) Renamed cputable.texi to cputable.t. Mon, 19 Oct 1998 19:39:52 GMT Joel Sherrill [024bcb82] * doc/supplements/sparc/cpumodel.texi (deleted) Renamed cpumodel.texi to cpumodel.t. Mon, 19 Oct 1998 19:39:50 GMT Joel Sherrill [b4d53c0] * doc/supplements/sparc/callconv.texi (deleted) Renamed callconv.texi to callconv.t. Mon, 19 Oct 1998 19:39:49 GMT Joel Sherrill [cb773a5] * doc/supplements/sparc/bsp.texi (deleted) Renamed bsp.texi to bsp.t. Mon, 19 Oct 1998 19:38:19 GMT Joel Sherrill [f0c3864] * doc/supplements/powerpc/Makefile (modified) * doc/supplements/powerpc/bsp.t (modified) * doc/supplements/powerpc/callconv.t (modified) * doc/supplements/powerpc/cpumodel.t (modified) * doc/supplements/powerpc/cputable.t (modified) * doc/supplements/powerpc/fatalerr.t (modified) * doc/supplements/powerpc/intr_NOTIMES.t (modified) * doc/supplements/powerpc/memmodel.t (modified) * doc/supplements/powerpc/powerpc.texi (modified) * doc/supplements/powerpc/timeDMV177.t (modified) * doc/supplements/powerpc/timePSIM.t (modified) Renamed a lot and got as much as possible automatically generated. Mon, 19 Oct 1998 19:32:57 GMT Joel Sherrill [2b768e30] * doc/supplements/powerpc/intr.t (deleted) Renamed. Mon, 19 Oct 1998 19:31:22 GMT Joel Sherrill [9d100231] * doc/supplements/powerpc/timedata.t (deleted) * doc/supplements/powerpc/timedatadmv177.t (deleted) * doc/supplements/powerpc/timetbldmv177.t (deleted) Renamed Mon, 19 Oct 1998 19:24:46 GMT Joel Sherrill [88b1c14] * doc/supplements/powerpc/memmodel.texi (deleted) Renamed memmodel.texi to memmodel.t. Mon, 19 Oct 1998 19:24:45 GMT Joel Sherrill [ca57ebb] * doc/supplements/powerpc/fatalerr.texi (deleted) Renamed fatalerr.texi to fatalerr.t. Mon, 19 Oct 1998 19:24:43 GMT Joel Sherrill [6a912a1e] * doc/supplements/powerpc/cputable.texi (deleted) Renamed cputable.texi to cputable.t. Mon, 19 Oct 1998 19:24:42 GMT Joel Sherrill [a619136] * doc/supplements/powerpc/cpumodel.texi (deleted) Renamed cpumodel.texi to cpumodel.t.
