# # ChangeLog for doc in rtems # # Generated by Trac 1.2.1.dev0 # 04/16/24 20:00:45 Thu, 29 May 1997 21:53:39 GMT Joel Sherrill [3a8256d] * doc/ada_user/Makefile (added) * doc/ada_user/ada_user.texi (added) * doc/do_docs (modified) first cut at adding an Ada bindings manual Wed, 28 May 1997 20:34:49 GMT Joel Sherrill [5c995d7] * doc/develenv/develenv.texi (modified) * doc/new_chapters/posix_test_plan.texi (modified) * doc/posix_users/posix_test_plan.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/user/c_user.texi (modified) version changed Wed, 28 May 1997 20:34:15 GMT Joel Sherrill [32cbfa7] * doc/common/setup.texi (modified) *** empty log message *** Wed, 28 May 1997 20:34:00 GMT Joel Sherrill [04e5f1c] * doc/Make.config (modified) * doc/Makefile (modified) * doc/do_docs (modified) * doc/rtems.html (modified) * doc/rtems_footer.html (modified) updated to add ka9q documents Wed, 28 May 1997 13:57:50 GMT Joel Sherrill [3dc513e] * doc/develenv/develenv.texi (modified) * doc/new_chapters/posix_test_plan.texi (modified) * doc/posix_users/posix_test_plan.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/i386/FORCE386_TIMES (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/m68k/MVME136_TIMES (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/sparc/ERC32_TIMES (modified) * doc/supplements/sparc/SIS_TIMES (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/user/c_user.texi (modified) 4.0.0 release docs Tue, 27 May 1997 12:40:11 GMT Joel Sherrill [ae68ff0] * doc/HELP.html (added) * doc/Make.config (added) * doc/Makefile (added) * doc/README (added) * doc/archgrey.gif (added) * doc/common/cpright.texi (added) * doc/common/missing-arrow.gif (added) * doc/common/next-arrow.gif (added) * doc/common/oaronly.jpg (added) * doc/common/prev-arrow.gif (added) * doc/common/setup.texi (added) * doc/common/timemac.texi (added) * doc/common/timetbl.t (added) * doc/common/timing.texi (added) * doc/common/up-arrow.gif (added) * doc/common/wksheets.t (added) * doc/develenv/Makefile (added) * doc/develenv/compile.texi (added) * doc/develenv/develenv.texi (added) * doc/develenv/direct.texi (added) * doc/develenv/intro.texi (added) * doc/develenv/sample.texi (added) * doc/develenv/utils.texi (added) * doc/do_docs (added) * doc/import_ami_txt (added) * doc/new_chapters/Makefile (added) * doc/new_chapters/base.texi (added) * doc/new_chapters/clock.texi (added) * doc/new_chapters/cond.texi (added) * doc/new_chapters/key.texi (added) * doc/new_chapters/mutex.texi (added) * doc/new_chapters/posix_test_plan.texi (added) * doc/new_chapters/preface.texi (added) * doc/new_chapters/sched.texi (added) * doc/new_chapters/signal.texi (added) * doc/new_chapters/thread.texi (added) * doc/oaronly.jpg (added) * doc/posix_users/Makefile (added) * doc/posix_users/base.texi (added) * doc/posix_users/clock.texi (added) * doc/posix_users/cond.texi (added) * doc/posix_users/key.texi (added) * doc/posix_users/mutex.texi (added) * doc/posix_users/posix_test_plan.texi (added) * doc/posix_users/preface.texi (added) * doc/posix_users/sched.texi (added) * doc/posix_users/signal.texi (added) * doc/posix_users/thread.texi (added) * doc/relnotes/Makefile (added) * doc/relnotes/install.texi (added) * doc/relnotes/intro.texi (added) * doc/relnotes/probrep.texi (added) * doc/relnotes/relnotes.texi (added) * doc/relnotes/status.texi (added) * doc/rtems.html (added) * doc/rtems_footer.html (added) * doc/rtems_header.html (added) * doc/supplements/hppa1_1/Makefile (added) * doc/supplements/hppa1_1/SIMHPPA_TIMES (added) * doc/supplements/hppa1_1/TIMES (added) * doc/supplements/hppa1_1/bsp.t (added) * doc/supplements/hppa1_1/bsp.texi (added) * doc/supplements/hppa1_1/callconv.t (added) * doc/supplements/hppa1_1/callconv.texi (added) * doc/supplements/hppa1_1/cpumodel.t (added) * doc/supplements/hppa1_1/cpumodel.texi (added) * doc/supplements/hppa1_1/cputable.t (added) * doc/supplements/hppa1_1/cputable.texi (added) * doc/supplements/hppa1_1/fatalerr.t (added) * doc/supplements/hppa1_1/fatalerr.texi (added) * doc/supplements/hppa1_1/hppa1_1.texi (added) * doc/supplements/hppa1_1/intr.t (added) * doc/supplements/hppa1_1/intr_NOTIMES.t (added) * doc/supplements/hppa1_1/memmodel.t (added) * doc/supplements/hppa1_1/memmodel.texi (added) * doc/supplements/hppa1_1/preface.texi (added) * doc/supplements/hppa1_1/timedata.t (added) * doc/supplements/i386/FORCE386_TIMES (added) * doc/supplements/i386/Makefile (added) * doc/supplements/i386/bsp.t (added) * doc/supplements/i386/bsp.texi (added) * doc/supplements/i386/callconv.t (added) * doc/supplements/i386/callconv.texi (added) * doc/supplements/i386/cpumodel.t (added) * doc/supplements/i386/cpumodel.texi (added) * doc/supplements/i386/cputable.t (added) * doc/supplements/i386/cputable.texi (added) * doc/supplements/i386/fatalerr.t (added) * doc/supplements/i386/fatalerr.texi (added) * doc/supplements/i386/i386.texi (added) * doc/supplements/i386/intr.t (added) * doc/supplements/i386/intr_NOTIMES.t (added) * doc/supplements/i386/memmodel.t (added) * doc/supplements/i386/memmodel.texi (added) * doc/supplements/i386/preface.texi (added) * doc/supplements/i386/timeFORCE386.t (added) * doc/supplements/i386/timedata.t (added) * doc/supplements/i960/CVME961_TIMES (added) * doc/supplements/i960/Makefile (added) * doc/supplements/i960/bsp.t (added) * doc/supplements/i960/bsp.texi (added) * doc/supplements/i960/callconv.t (added) * doc/supplements/i960/callconv.texi (added) * doc/supplements/i960/cpumodel.t (added) * doc/supplements/i960/cpumodel.texi (added) * doc/supplements/i960/cputable.t (added) * doc/supplements/i960/cputable.texi (added) * doc/supplements/i960/fatalerr.t (added) * doc/supplements/i960/fatalerr.texi (added) * doc/supplements/i960/i960.texi (added) * doc/supplements/i960/intr.t (added) * doc/supplements/i960/intr_NOTIMES.t (added) * doc/supplements/i960/memmodel.t (added) * doc/supplements/i960/memmodel.texi (added) * doc/supplements/i960/preface.texi (added) * doc/supplements/i960/timeCVME961.t (added) * doc/supplements/i960/timedata.t (added) * doc/supplements/m68k/MVME136_TIMES (added) * doc/supplements/m68k/Makefile (added) * doc/supplements/m68k/bsp.t (added) * doc/supplements/m68k/callconv.t (added) * doc/supplements/m68k/cpumodel.t (added) * doc/supplements/m68k/cputable.t (added) * doc/supplements/m68k/fatalerr.t (added) * doc/supplements/m68k/intr_NOTIMES.t (added) * doc/supplements/m68k/m68k.texi (added) * doc/supplements/m68k/memmodel.t (added) * doc/supplements/m68k/preface.texi (added) * doc/supplements/m68k/timeMVME136.t (added) * doc/supplements/m68k/timedata.t (added) * doc/supplements/sparc/ERC32_TIMES (added) * doc/supplements/sparc/Makefile (added) * doc/supplements/sparc/SIS_TIMES (added) * doc/supplements/sparc/bsp.t (added) * doc/supplements/sparc/bsp.texi (added) * doc/supplements/sparc/callconv.t (added) * doc/supplements/sparc/callconv.texi (added) * doc/supplements/sparc/cpumodel.t (added) * doc/supplements/sparc/cpumodel.texi (added) * doc/supplements/sparc/cputable.t (added) * doc/supplements/sparc/cputable.texi (added) * doc/supplements/sparc/fatalerr.t (added) * doc/supplements/sparc/fatalerr.texi (added) * doc/supplements/sparc/intr.t (added) * doc/supplements/sparc/intr_NOTIMES.t (added) * doc/supplements/sparc/memmodel.t (added) * doc/supplements/sparc/memmodel.texi (added) * doc/supplements/sparc/preface.texi (added) * doc/supplements/sparc/sparc.texi (added) * doc/supplements/sparc/timeERC32.t (added) * doc/supplements/sparc/timedata.t (added) * doc/texinfo/texinfo.tex (added) * doc/tools/bmenu/Makefile (added) * doc/tools/bmenu/address.h (added) * doc/tools/bmenu/address.inl (added) * doc/tools/bmenu/base.h (added) * doc/tools/bmenu/bmenu (added) * doc/tools/bmenu/chain.c (added) * doc/tools/bmenu/chain.h (added) * doc/tools/bmenu/chain.inl (added) * doc/tools/bmenu/chain.o (added) * doc/tools/bmenu/isr.h (added) * doc/tools/bmenu/main.c (added) * doc/tools/bmenu/main.o (added) * doc/tools/bmenu/system.h (added) * doc/tools/update (added) * doc/tools/word-replace (added) * doc/user/Makefile (added) * doc/user/bsp.t (added) * doc/user/c_user.texi (added) * doc/user/clock.t (added) * doc/user/concepts.t (added) * doc/user/conf.t (added) * doc/user/dirstat.texi (added) * doc/user/dpmem.t (added) * doc/user/event.t (added) * doc/user/example.texi (added) * doc/user/fatal.t (added) * doc/user/glossary.texi (added) * doc/user/init.t (added) * doc/user/intr.t (added) * doc/user/io.t (added) * doc/user/mp.t (added) * doc/user/msg.t (added) * doc/user/overview.t (added) * doc/user/part.t (added) * doc/user/preface.texi (added) * doc/user/region.t (added) * doc/user/rtemsarc.gif (added) * doc/user/rtemspie.gif (added) * doc/user/rtmon.t (added) * doc/user/schedule.t (added) * doc/user/sem.t (added) * doc/user/signal.t (added) * doc/user/states.gif (added) * doc/user/task.t (added) * doc/user/timer.t (added) * doc/user/userext.t (added) Initial revision Tue, 27 May 1997 12:40:10 GMT Joel Sherrill [b65131dc] * doc/common/treedef.tex (added) This commit was generated by cvs2svn to compensate for changes in ... Tue, 27 May 1997 12:40:10 GMT Joel Sherrill [a3035e71] * doc/common/treedef.tex (added) base RTEMS documentation Wed, 09 Apr 1997 14:46:16 GMT Joel Sherrill [48d6de3] * doc/Makefile.in (added) Adding missing files.
