# # ChangeLog for doc/user in rtems # # Generated by Trac 1.2.1.dev0 # 05/12/24 14:23:16 Fri, 05 May 2000 16:30:58 GMT Joel Sherrill [d1b7579] * doc/user/example.texi (modified) Updated example. Fri, 05 May 2000 16:22:57 GMT Joel Sherrill [794d745] * doc/user/conf.t (modified) Added function indexes for CONFIGURE_ constants. Fri, 05 May 2000 15:22:24 GMT Joel Sherrill [e95cfafb] * doc/user/conf.t (modified) * doc/user/preface.texi (modified) More updates. Fri, 05 May 2000 12:58:39 GMT Joel Sherrill [6e58367] * doc/user/conf.t (modified) Added much information on confdefs.h parameters. Thu, 04 May 2000 19:45:17 GMT Joel Sherrill [adee5979] * doc/FAQ/debug.t (modified) * doc/TODO (modified) * doc/networking/testing.t (modified) * doc/posix_users/message.t (modified) * doc/posix_users/semaphores.t (modified) * doc/started/Makefile.am (modified) * doc/started/buildc.t (modified) * doc/started/buildrt.t (modified) * doc/started/intro.t (modified) * doc/started/nt.t (modified) * doc/started/require.t (modified) * doc/started/started.texi (modified) * doc/started/tversions.texi (modified) * doc/started_ada/buildada.t (modified) * doc/started_ada/require.t (modified) * doc/started_ada/tversions.texi (modified) * doc/user/clock.t (modified) * doc/user/concepts.t (modified) * doc/user/conf.t (modified) * doc/user/event.t (modified) * doc/user/example.texi (modified) * doc/user/fatal.t (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/rtmon.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) Numerous changes based on comments from Stephan Wilms ... Mon, 01 May 2000 20:08:58 GMT Joel Sherrill [da874de] * doc/user/task.t (modified) A bit more explanation for task variables per Eric Norum ... Mon, 01 May 2000 16:53:13 GMT Joel Sherrill [a4ad9487] * doc/FAQ/.cvsignore (modified) * doc/ada_user/.cvsignore (modified) * doc/bsp_howto/.cvsignore (modified) * doc/bsp_howto/Makefile.am (modified) * doc/common/.cvsignore (modified) * doc/common/setup.texi.in (modified) * doc/configure.in (modified) * doc/develenv/.cvsignore (modified) * doc/filesystem/.cvsignore (modified) * doc/gnu_docs/.cvsignore (modified) * doc/images/.cvsignore (modified) * doc/itron3.0/.cvsignore (modified) * doc/networking/.cvsignore (modified) * doc/new_chapters/.cvsignore (modified) * doc/porting/.cvsignore (modified) * doc/posix1003.1/.cvsignore (modified) * doc/posix_users/.cvsignore (modified) * doc/relnotes/.cvsignore (modified) * doc/rgdb_specs/.cvsignore (modified) * doc/rtems_gdb/.cvsignore (modified) * doc/src2html/.cvsignore (modified) * doc/started/.cvsignore (modified) * doc/started/pictures/.cvsignore (modified) * doc/started_ada/.cvsignore (modified) * doc/supplements/.cvsignore (modified) * doc/supplements/hppa1_1/.cvsignore (modified) * doc/supplements/hppa1_1/Makefile.am (modified) * doc/supplements/i386/.cvsignore (modified) * doc/supplements/i386/Makefile.am (modified) * doc/supplements/i960/.cvsignore (modified) * doc/supplements/i960/Makefile.am (modified) * doc/supplements/m68k/.cvsignore (modified) * doc/supplements/m68k/Makefile.am (modified) * doc/supplements/mips64orion/.cvsignore (modified) * doc/supplements/mips64orion/Makefile.am (modified) * doc/supplements/powerpc/.cvsignore (modified) * doc/supplements/powerpc/Makefile.am (modified) * doc/supplements/sh/.cvsignore (modified) * doc/supplements/sh/Makefile.am (modified) * doc/supplements/sparc/.cvsignore (modified) * doc/supplements/sparc/Makefile.am (modified) * doc/supplements/supplement.am (modified) * doc/supplements/template/.cvsignore (modified) * doc/supplements/template/Makefile.am (modified) * doc/tools/.cvsignore (modified) * doc/tools/bmenu/.cvsignore (modified) * doc/tools/bmenu/Makefile.am (modified) * doc/tools/pdl2texi/.cvsignore (modified) * doc/tools/src2html/.cvsignore (modified) * doc/tools/src2html1.4a/.cvsignore (modified) * doc/tools/src2html1.4a/Ctags/.cvsignore (modified) * doc/tools/src2html1.4a/FreeBSD/.cvsignore (modified) * doc/tools/src2html1.4a/ctags-emacs/.cvsignore (modified) * doc/tools/texi2www/.cvsignore (modified) * doc/tools/word-replace2 (modified) * doc/user/.cvsignore (modified) Patch rtemsdoc-4.5.0-rc-3.diff from Ralf Corsepius [91763c9] * doc/FAQ/.cvsignore (added) * doc/ada_user/.cvsignore (added) * doc/bsp_howto/.cvsignore (added) * doc/common/.cvsignore (added) * doc/develenv/.cvsignore (added) * doc/filesystem/.cvsignore (added) * doc/gnu_docs/.cvsignore (added) * doc/images/.cvsignore (added) * doc/itron3.0/.cvsignore (added) * doc/networking/.cvsignore (added) * doc/new_chapters/.cvsignore (added) * doc/porting/.cvsignore (added) * doc/posix1003.1/.cvsignore (added) * doc/posix_users/.cvsignore (added) * doc/relnotes/.cvsignore (added) * doc/rgdb_specs/.cvsignore (added) * doc/rtems_gdb/.cvsignore (added) * doc/src2html/.cvsignore (added) * doc/started/.cvsignore (added) * doc/started/pictures/.cvsignore (added) * doc/started_ada/.cvsignore (added) * doc/supplements/.cvsignore (added) * doc/supplements/hppa1_1/.cvsignore (added) * doc/supplements/i386/.cvsignore (added) * doc/supplements/i960/.cvsignore (added) * doc/supplements/m68k/.cvsignore (added) * doc/supplements/mips64orion/.cvsignore (added) * doc/supplements/powerpc/.cvsignore (added) * doc/supplements/sh/.cvsignore (added) * doc/supplements/sparc/.cvsignore (added) * doc/supplements/template/.cvsignore (added) * doc/tools/.cvsignore (added) * doc/tools/bmenu/.cvsignore (added) * doc/tools/pdl2texi/.cvsignore (added) * doc/tools/src2html/.cvsignore (added) * doc/tools/src2html1.4a/.cvsignore (added) * doc/tools/src2html1.4a/Ctags/.cvsignore (added) * doc/tools/src2html1.4a/FreeBSD/.cvsignore (added) * doc/tools/src2html1.4a/ctags-emacs/.cvsignore (added) * doc/tools/texi2www/.cvsignore (added) * doc/user/.cvsignore (added) New files. First attempt. Wed, 26 Apr 2000 18:05:33 GMT Joel Sherrill [fdbfff18] * doc/ada_user/Makefile.am (modified) * doc/networking/Makefile.am (modified) * doc/project.am (modified) * doc/rgdb_specs/Makefile.am (modified) * doc/tools/Makefile.am (modified) * doc/user/Makefile.am (modified) * doc/user/schedule.t (modified) Patches rtemsdoc-4.5.0-rc.diff from Ralf Corsepius [2ba8875] * doc/FAQ/Makefile (deleted) * doc/FAQ/Makefile.am (added) * doc/Make.config (deleted) * doc/Makefile (deleted) * doc/Makefile.am (added) * doc/VERSION (deleted) * doc/ada_user/Makefile (deleted) * doc/ada_user/Makefile.am (added) * doc/archgrey.gif (deleted) * doc/bootstrap (added) * doc/bsp_howto/Makefile (deleted) * doc/bsp_howto/Makefile.am (added) * doc/bsp_howto/network.t (added) * doc/common/Makefile.am (added) * doc/common/cpright.texi (modified) * doc/common/dvi.gif (deleted) * doc/common/oaronly.jpg (deleted) * doc/common/pdf.gif (deleted) * doc/common/pdf1.gif (deleted) * doc/common/ps.gif (deleted) * doc/common/setup.texi.in (moved) * doc/common/up-arrow.gif (deleted) * doc/configure.in (added) * doc/develenv/Makefile (deleted) * doc/develenv/Makefile.am (added) * doc/do_docs (deleted) * doc/filesystem/Makefile (deleted) * doc/filesystem/Makefile.am (added) * doc/gnu_docs/Makefile.am (added) * doc/index.html (deleted) * doc/index.html.in (added) * doc/itron3.0/Makefile (deleted) * doc/itron3.0/Makefile.am (added) * doc/networking/Makefile (deleted) * doc/networking/Makefile.am (added) * doc/networking/PCIreg.pdf (deleted) * doc/networking/decdriver.t (modified) * doc/networking/networkflow.pdf (deleted) * doc/networking/networktasks.t (modified) * doc/networking/recvbd.pdf (deleted) * doc/new_chapters/Makefile (deleted) * doc/new_chapters/Makefile.am (added) * doc/oaronly.jpg (deleted) * doc/porting/Makefile.am (moved) * doc/posix1003.1/Makefile.am (moved) * doc/posix_users/Makefile (deleted) * doc/posix_users/Makefile.am (added) * doc/project.am (added) * doc/relnotes/Makefile (deleted) * doc/relnotes/Makefile.am (added) * doc/rgdb_specs/Makefile (deleted) * doc/rgdb_specs/Makefile.am (added) * doc/rgdb_specs/garde.eps (deleted) * doc/rgdb_specs/garde.pdf (deleted) * doc/rgdb_specs/layers.pdf (deleted) * doc/rgdb_specs/process.pdf (deleted) * doc/rgdb_specs/seqbreak.pdf (deleted) * doc/rgdb_specs/seqdetach.pdf (deleted) * doc/rgdb_specs/seqinit.pdf (deleted) * doc/rtems_footer.html.in (moved) * doc/rtems_gdb/Makefile (deleted) * doc/rtems_gdb/Makefile.am (added) * doc/rtems_header.html (deleted) * doc/rtems_header.html.in (added) * doc/rtems_support.html.in (moved) * doc/src2html/Makefile (deleted) * doc/src2html/Makefile.am (added) * doc/started/Makefile (deleted) * doc/started/Makefile.am (added) * doc/started/pictures/Makefile.am (added) * doc/started/started.texi (modified) * doc/started/tversions.texi (moved) * doc/started_ada/Makefile (deleted) * doc/started_ada/Makefile.am (added) * doc/started_ada/started_ada.texi (modified) * doc/started_ada/tversions.texi (moved) * doc/supplements/Makefile.am (added) * doc/supplements/hppa1_1/Makefile (deleted) * doc/supplements/hppa1_1/Makefile.am (added) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/i386/Makefile (deleted) * doc/supplements/i386/Makefile.am (added) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i386/timeFORCE386_.t (added) * doc/supplements/i960/Makefile (deleted) * doc/supplements/i960/Makefile.am (added) * doc/supplements/i960/i960.texi (modified) * doc/supplements/i960/timeCVME961_.t (added) * doc/supplements/m68k/Makefile (deleted) * doc/supplements/m68k/Makefile.am (added) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/m68k/timeMVME136_.t (added) * doc/supplements/mips64orion/Makefile (deleted) * doc/supplements/mips64orion/Makefile.am (added) * doc/supplements/mips64orion/mips64orion.texi (modified) * doc/supplements/mips64orion/timeBSP_.t (added) * doc/supplements/powerpc/Makefile (deleted) * doc/supplements/powerpc/Makefile.am (added) * doc/supplements/powerpc/powerpc.texi (modified) * doc/supplements/powerpc/timeDMV177_.t (added) * doc/supplements/powerpc/timePSIM_.t (added) * doc/supplements/sh/Makefile (deleted) * doc/supplements/sh/Makefile.am (added) * doc/supplements/sh/sh.texi (modified) * doc/supplements/sh/timeBSP_.t (added) * doc/supplements/sparc/Makefile (deleted) * doc/supplements/sparc/Makefile.am (added) * doc/supplements/sparc/sparc.texi (modified) * doc/supplements/sparc/timeERC32_.t (added) * doc/supplements/supplement.am (added) * doc/supplements/template/BSP_TIMES (modified) * doc/supplements/template/Makefile (deleted) * doc/supplements/template/Makefile.am (added) * doc/supplements/template/template.texi (modified) * doc/supplements/template/timeBSP.t (modified) * doc/texinfo/texinfo.tex (modified) * doc/tools/Makefile.am (added) * doc/tools/bmenu/Makefile (deleted) * doc/tools/bmenu/Makefile.am (added) * doc/tools/configure.in (added) * doc/tools/pdl2texi/Makefile (deleted) * doc/tools/pdl2texi/Makefile.am (added) * doc/tools/src2html/Makefile (deleted) * doc/tools/src2html/Makefile.am (added) * doc/tools/src2html1.4a/Ctags/Makefile (deleted) * doc/tools/src2html1.4a/Ctags/Makefile.am (added) * doc/tools/src2html1.4a/FreeBSD/Makefile.am (added) * doc/tools/src2html1.4a/Makefile.am (added) * doc/tools/src2html1.4a/ctags-emacs/Makefile.am (added) * doc/tools/texi2www/Makefile (deleted) * doc/tools/texi2www/Makefile.am (added) * doc/tools/word-replace2 (added) * doc/user/Makefile.am (moved) * doc/user/rtemspie.pdf (deleted) * doc/user/states.pdf (deleted) Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius [bb4b574] * doc/Make.config (modified) * doc/common/setup.texi (modified) * doc/porting/interrupts.t (modified) * doc/porting/prioritybitmap.t (modified) * doc/porting/taskcontext.t (modified) * doc/started/gdb.t (modified) * doc/started/intro.t (modified) * doc/started/sample.t (modified) * doc/started_ada/intro.t (modified) * doc/started_ada/sample.t (modified) * doc/user/sem.t (modified) Merged changes from 4.5 branch and removed that branch. Tue, 29 Feb 2000 14:07:38 GMT Joel Sherrill [6f645ff] * doc/user/task.t (modified) Eric Norum spotted this sentence where it said preemption had to be ... Fri, 18 Feb 2000 14:12:16 GMT Joel Sherrill [9b10d22] * doc/user/task.t (modified) Fixed typo. Fri, 18 Feb 2000 14:11:46 GMT Joel Sherrill [edc1347e] * doc/user/sem.t (modified) Patch from Eric Norum to include some information ... Thu, 27 Jan 2000 14:40:00 GMT Joel Sherrill [e26ce93] * doc/user/task.t (modified) Added note from Ian Lance Taylor . Sun, 23 Jan 2000 19:06:09 GMT Joel Sherrill [b5a31d4] * doc/user/task.t (modified) Added rtems_task_variable_get from Eric Norum. Sun, 23 Jan 2000 18:59:17 GMT Joel Sherrill [a6900508] * doc/user/task.t (modified) Updated to reflect changing to void * on task variables by Eric ... Tue, 16 Nov 1999 19:50:56 GMT Joel Sherrill [0660b4f8] * doc/FAQ/FAQ.texi (modified) * doc/FAQ/Makefile (modified) * doc/FAQ/basic.t (modified) * doc/FAQ/bsp.t (modified) * doc/FAQ/concepts.t (modified) * doc/FAQ/debug.t (modified) * doc/FAQ/embeddedinfo.t (modified) * doc/FAQ/freesw.t (modified) * doc/FAQ/hwdebugaids.t (modified) * doc/FAQ/tools.t (modified) * doc/ada_user/Makefile (modified) * doc/ada_user/ada_user.texi (modified) * doc/ada_user/example.texi (modified) * doc/bsp_howto/Makefile (modified) * doc/bsp_howto/adaintr.t (modified) * doc/bsp_howto/analog.t (modified) * doc/bsp_howto/bsp_howto.texi (modified) * doc/bsp_howto/clock.t (modified) * doc/bsp_howto/console.t (modified) * doc/bsp_howto/discrete.t (modified) * doc/bsp_howto/init.t (modified) * doc/bsp_howto/intro.t (modified) * doc/bsp_howto/linkcmds.t (modified) * doc/bsp_howto/makefiles.t (modified) * doc/bsp_howto/nvmem.t (modified) * doc/bsp_howto/rtc.t (modified) * doc/bsp_howto/shmsupp.t (modified) * doc/bsp_howto/support.t (modified) * doc/bsp_howto/target.t (modified) * doc/bsp_howto/timer.t (modified) * doc/common/cpright.texi (modified) * doc/common/setup.texi (modified) * doc/common/timemac.texi (modified) * doc/common/timetbl.t (modified) * doc/common/timing.t (modified) * doc/common/wksheets.t (modified) * doc/develenv/Makefile (modified) * doc/develenv/compile.texi (modified) * doc/develenv/develenv.texi (modified) * doc/develenv/direct.texi (modified) * doc/develenv/intro.texi (modified) * doc/develenv/sample.texi (modified) * doc/develenv/utils.texi (modified) * doc/filesystem/Makefile (modified) * doc/filesystem/filesystem.texi (modified) * doc/filesystem/fsrequirements.t (modified) * doc/filesystem/imfs.t (modified) * doc/filesystem/init.t (modified) * doc/filesystem/miniimfs.t (modified) * doc/filesystem/mounting.t (modified) * doc/filesystem/patheval.t (modified) * doc/filesystem/preface.texi (modified) * doc/filesystem/syscalls.t (modified) * doc/filesystem/tftp.t (modified) * doc/itron3.0/Makefile (modified) * doc/itron3.0/itron.texi (modified) * doc/networking/Makefile (modified) * doc/networking/driver.t (modified) * doc/networking/networkapp.t (modified) * doc/networking/networking.texi (modified) * doc/networking/networktasks.t (modified) * doc/networking/preface.texi (modified) * doc/networking/servers.t (modified) * doc/networking/testing.t (modified) * doc/new_chapters/Makefile (modified) * doc/new_chapters/adminiface.t (modified) * doc/new_chapters/base.t (modified) * doc/new_chapters/confspace.t (modified) * doc/new_chapters/cpuuse.t (modified) * doc/new_chapters/dumpcontrol.t (modified) * doc/new_chapters/error.t (modified) * doc/new_chapters/eventlog.t (modified) * doc/new_chapters/gen_section (modified) * doc/new_chapters/monitor.t (modified) * doc/new_chapters/new_chapters.texi (modified) * doc/new_chapters/rtmonuse.t (modified) * doc/new_chapters/stackchk.t (modified) * doc/porting/Makefile (modified) * doc/porting/codetuning.t (modified) * doc/porting/cpuinit.t (modified) * doc/porting/cpumodels.t (modified) * doc/porting/developtools.t (modified) * doc/porting/idlethread.t (modified) * doc/porting/interrupts.t (modified) * doc/porting/miscellaneous.t (modified) * doc/porting/porting.texi (modified) * doc/porting/preface.texi (modified) * doc/porting/prioritybitmap.t (modified) * doc/porting/sourcecode.t (modified) * doc/porting/taskcontext.t (modified) * doc/posix1003.1/Makefile (modified) * doc/posix1003.1/ch01.t (modified) * doc/posix1003.1/ch02.t (modified) * doc/posix1003.1/ch03.t (modified) * doc/posix1003.1/ch04.t (modified) * doc/posix1003.1/ch05.t (modified) * doc/posix1003.1/ch06.t (modified) * doc/posix1003.1/ch07.t (modified) * doc/posix1003.1/ch08.t (modified) * doc/posix1003.1/ch09.t (modified) * doc/posix1003.1/ch10.t (modified) * doc/posix1003.1/ch11.t (modified) * doc/posix1003.1/ch12.t (modified) * doc/posix1003.1/ch13.t (modified) * doc/posix1003.1/ch14.t (modified) * doc/posix1003.1/ch15.t (modified) * doc/posix1003.1/ch16.t (modified) * doc/posix1003.1/ch17.t (modified) * doc/posix1003.1/ch18.t (modified) * doc/posix1003.1/posix1003_1.texi (modified) * doc/posix1003.1/preface.texi (modified) * doc/posix_users/Makefile (modified) * doc/posix_users/cancel.t (modified) * doc/posix_users/clock.t (modified) * doc/posix_users/cond.t (modified) * doc/posix_users/cspecific.t (modified) * doc/posix_users/device.t (modified) * doc/posix_users/files.t (modified) * doc/posix_users/io.t (modified) * doc/posix_users/key.t (modified) * doc/posix_users/memorymgmt.t (modified) * doc/posix_users/mutex.t (modified) * doc/posix_users/posix_users.texi (modified) * doc/posix_users/preface.texi (modified) * doc/posix_users/procenv.t (modified) * doc/posix_users/process.t (modified) * doc/posix_users/sched.t (modified) * doc/posix_users/signal.t (modified) * doc/posix_users/status.t (modified) * doc/posix_users/systemdb.t (modified) * doc/posix_users/thread.t (modified) * doc/relnotes/Makefile (modified) * doc/relnotes/install.texi (modified) * doc/relnotes/intro.texi (modified) * doc/relnotes/probrep.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/relnotes/status.texi (modified) * doc/rgdb_specs/Makefile (modified) * doc/rgdb_specs/rgdb_specs.texi (modified) * doc/rtems_gdb/Makefile (modified) * doc/rtems_gdb/commands.t (modified) * doc/rtems_gdb/example.t (modified) * doc/rtems_gdb/intro.t (modified) * doc/rtems_gdb/rtems_gdb.texi (modified) * doc/rtems_gdb/started.t (modified) * doc/rtems_gdb/swarch.t (modified) * doc/rtems_gdb/trouble.t (modified) * doc/src2html/Makefile (modified) * doc/started/Makefile (modified) * doc/started/buildc.t (modified) * doc/started/buildrt.t (modified) * doc/started/gdb.t (modified) * doc/started/intro.t (modified) * doc/started/nt.t (modified) * doc/started/require.t (modified) * doc/started/sample.t (modified) * doc/started/started.texi (modified) * doc/started/versions.texi (modified) * doc/started_ada/Makefile (modified) * doc/started_ada/buildada.t (modified) * doc/started_ada/buildrt.t (modified) * doc/started_ada/gdb.t (modified) * doc/started_ada/intro.t (modified) * doc/started_ada/require.t (modified) * doc/started_ada/sample.t (modified) * doc/started_ada/started_ada.texi (modified) * doc/started_ada/versions.texi (modified) * doc/supplements/hppa1_1/Makefile (modified) * doc/supplements/hppa1_1/bsp.t (modified) * doc/supplements/hppa1_1/callconv.t (modified) * doc/supplements/hppa1_1/cpumodel.t (modified) * doc/supplements/hppa1_1/cputable.t (modified) * doc/supplements/hppa1_1/fatalerr.t (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/hppa1_1/intr_NOTIMES.t (modified) * doc/supplements/hppa1_1/memmodel.t (modified) * doc/supplements/hppa1_1/preface.texi (modified) * doc/supplements/hppa1_1/timeSIMHPPA.t (modified) * doc/supplements/i386/Makefile (modified) * doc/supplements/i386/bsp.t (modified) * doc/supplements/i386/callconv.t (modified) * doc/supplements/i386/cpumodel.t (modified) * doc/supplements/i386/cputable.t (modified) * doc/supplements/i386/fatalerr.t (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i386/intr_NOTIMES.t (modified) * doc/supplements/i386/memmodel.t (modified) * doc/supplements/i386/preface.texi (modified) * doc/supplements/i386/timeFORCE386.t (modified) * doc/supplements/i960/Makefile (modified) * doc/supplements/i960/bsp.t (modified) * doc/supplements/i960/callconv.t (modified) * doc/supplements/i960/cpumodel.t (modified) * doc/supplements/i960/cputable.t (modified) * doc/supplements/i960/fatalerr.t (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/i960/intr_NOTIMES.t (modified) * doc/supplements/i960/memmodel.t (modified) * doc/supplements/i960/preface.texi (modified) * doc/supplements/i960/timeCVME961.t (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/m68k/bsp.t (modified) * doc/supplements/m68k/callconv.t (modified) * doc/supplements/m68k/cpumodel.t (modified) * doc/supplements/m68k/cputable.t (modified) * doc/supplements/m68k/fatalerr.t (modified) * doc/supplements/m68k/intr_NOTIMES.t (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/m68k/memmodel.t (modified) * doc/supplements/m68k/preface.texi (modified) * doc/supplements/m68k/timeMVME136.t (modified) * doc/supplements/m68k/timedata.t (modified) * doc/supplements/mips64orion/Makefile (modified) * doc/supplements/mips64orion/bsp.t (modified) * doc/supplements/mips64orion/callconv.t (modified) * doc/supplements/mips64orion/cpumodel.t (modified) * doc/supplements/mips64orion/cputable.t (modified) * doc/supplements/mips64orion/fatalerr.t (modified) * doc/supplements/mips64orion/intr_NOTIMES.t (modified) * doc/supplements/mips64orion/memmodel.t (modified) * doc/supplements/mips64orion/mips64orion.texi (modified) * doc/supplements/mips64orion/preface.texi (modified) * doc/supplements/mips64orion/timeBSP.t (modified) * doc/supplements/powerpc/Makefile (modified) * doc/supplements/powerpc/bsp.t (modified) * doc/supplements/powerpc/callconv.t (modified) * doc/supplements/powerpc/cpumodel.t (modified) * doc/supplements/powerpc/cputable.t (modified) * doc/supplements/powerpc/fatalerr.t (modified) * doc/supplements/powerpc/intr_NOTIMES.t (modified) * doc/supplements/powerpc/memmodel.t (modified) * doc/supplements/powerpc/powerpc.texi (modified) * doc/supplements/powerpc/preface.texi (modified) * doc/supplements/powerpc/timeDMV177.t (modified) * doc/supplements/powerpc/timePSIM.t (modified) * doc/supplements/sh/Makefile (modified) * doc/supplements/sh/bsp.t (modified) * doc/supplements/sh/callconv.t (modified) * doc/supplements/sh/cpumodel.t (modified) * doc/supplements/sh/cputable.t (modified) * doc/supplements/sh/fatalerr.t (modified) * doc/supplements/sh/intr_NOTIMES.t (modified) * doc/supplements/sh/memmodel.t (modified) * doc/supplements/sh/preface.texi (modified) * doc/supplements/sh/sh.texi (modified) * doc/supplements/sh/timeBSP.t (modified) * doc/supplements/sparc/Makefile (modified) * doc/supplements/sparc/bsp.t (modified) * doc/supplements/sparc/callconv.t (modified) * doc/supplements/sparc/cpumodel.t (modified) * doc/supplements/sparc/cputable.t (modified) * doc/supplements/sparc/fatalerr.t (modified) * doc/supplements/sparc/intr_NOTIMES.t (modified) * doc/supplements/sparc/memmodel.t (modified) * doc/supplements/sparc/preface.texi (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/supplements/sparc/timeERC32.t (modified) * doc/supplements/template/Makefile (modified) * doc/supplements/template/bsp.t (modified) * doc/supplements/template/callconv.t (modified) * doc/supplements/template/cpumodel.t (modified) * doc/supplements/template/cputable.t (modified) * doc/supplements/template/fatalerr.t (modified) * doc/supplements/template/intr_NOTIMES.t (modified) * doc/supplements/template/memmodel.t (modified) * doc/supplements/template/preface.texi (modified) * doc/supplements/template/template.texi (modified) * doc/supplements/template/timeBSP.t (modified) * doc/tools/bmenu/Makefile (modified) * doc/tools/bmenu/address.h (modified) * doc/tools/bmenu/address.inl (modified) * doc/tools/bmenu/base.h (modified) * doc/tools/bmenu/chain.c (modified) * doc/tools/bmenu/chain.h (modified) * doc/tools/bmenu/chain.inl (modified) * doc/tools/bmenu/isr.h (modified) * doc/tools/bmenu/main.c (modified) * doc/tools/bmenu/system.h (modified) * doc/tools/src2html/Makefile (modified) * doc/tools/texi2www/Makefile (modified) * doc/user/Makefile (modified) * doc/user/bsp.t (modified) * doc/user/c_user.texi (modified) * doc/user/clock.t (modified) * doc/user/concepts.t (modified) * doc/user/conf.t (modified) * doc/user/dirstat.texi (modified) * doc/user/dpmem.t (modified) * doc/user/event.t (modified) * doc/user/example.texi (modified) * doc/user/fatal.t (modified) * doc/user/glossary.texi (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/overview.t (modified) * doc/user/part.t (modified) * doc/user/preface.texi (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) Changed copyright date to 1999. Tue, 16 Nov 1999 18:40:25 GMT Joel Sherrill [71689d44] * doc/user/concepts.t (modified) Added reference to rtems_get_class, rtems_get_node, and ... Tue, 16 Nov 1999 18:28:20 GMT Joel Sherrill [dc2b337] * doc/user/Makefile (modified) * doc/user/task.t (modified) Added task variable services. Tue, 16 Nov 1999 18:28:06 GMT Joel Sherrill [1dbf307] * doc/user/conf.t (modified) Added categorized list of constants in confdefs.h. Mon, 25 Oct 1999 19:48:42 GMT Joel Sherrill [3a0a97a] * doc/networking/driver.t (modified) * doc/user/conf.t (modified) * doc/user/rtmon.t (modified) Fixed line too long problems. Mon, 25 Oct 1999 16:36:50 GMT Joel Sherrill [5a69fe3] * doc/user/Makefile (modified) * doc/user/conf.t (modified) * doc/user/sem.t (modified) Formatting improvements. Mon, 11 Oct 1999 21:33:42 GMT Joel Sherrill [2ec1156] * doc/ada_user/Makefile (modified) * doc/posix_users/Makefile (modified) * doc/user/Makefile (modified) Added files generated by index process to clean stanza. Mon, 11 Oct 1999 21:25:42 GMT Joel Sherrill [92abaa0] * doc/user/c_user.texi (modified) Corrected spacing. Mon, 11 Oct 1999 19:03:05 GMT Joel Sherrill [169502e] * doc/user/Makefile (modified) * doc/user/bsp.t (modified) * doc/user/c_user.texi (modified) * doc/user/clock.t (modified) * doc/user/concepts.t (modified) * doc/user/conf.t (modified) * doc/user/dpmem.t (modified) * doc/user/event.t (modified) * doc/user/fatal.t (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/part.t (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) Turned on concept and function name indexing. Mon, 11 Oct 1999 18:42:09 GMT Joel Sherrill [0de8359] * doc/user/preface.texi (modified) Fixed variable reference for RTEMS-RELEASE. Thu, 07 Oct 1999 18:24:16 GMT Joel Sherrill [0b81ea1] * doc/user/Makefile (modified) Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the ... Thu, 07 Oct 1999 18:20:02 GMT Joel Sherrill [0749353c] * doc/networking/networkflow.pdf (modified) * doc/user/rtemspie.pdf (modified) * doc/user/states.pdf (modified) Regenerated. Thu, 07 Oct 1999 16:52:16 GMT Joel Sherrill [643ecabb] * doc/user/rtemspie.pdf (added) * doc/user/states.pdf (added) New files. Thu, 07 Oct 1999 16:26:13 GMT Joel Sherrill [5ad8673] * doc/user/task.t (modified) Added rtems_task_is_suspended. Thu, 07 Oct 1999 16:25:58 GMT Joel Sherrill [b9e4815] * doc/user/Makefile (modified) Cleaned up use of $(PROJECT) instead of hard-coding c_user. Added ... Wed, 06 Oct 1999 17:50:07 GMT Joel Sherrill [13fb305] * doc/user/Makefile (modified) * doc/user/overview.t (modified) * doc/user/schedule.t (modified) * doc/user/states.eps (added) * doc/user/states.png (added) Enabled images. They appear to work ok for PostScript but not as ... Wed, 06 Oct 1999 15:52:32 GMT Joel Sherrill [5d2f1922] * doc/user/rtemsarc.png (added) * doc/user/rtemspie.eps (added) * doc/user/rtemspie.png (added) Added multiple formats of the image so we can use the @image command. Wed, 06 Oct 1999 15:52:13 GMT Joel Sherrill [e070a9db] * doc/user/intr.t (modified) * doc/user/overview.t (modified) Corrected a typo. Fri, 01 Oct 1999 18:05:42 GMT Joel Sherrill [0c7aab8] * doc/user/intr.t (modified) Changed rtems_isr_level to rtems_interrupt_level per Chris Johns' ... Fri, 01 Oct 1999 17:44:06 GMT Joel Sherrill [ed11cadf] * doc/FAQ/FAQ.texi (modified) * doc/FAQ/Makefile (modified) * doc/FAQ/basic.t (modified) * doc/FAQ/freesw.t (modified) * doc/Make.config (modified) * doc/Makefile (modified) * doc/ada_user/Makefile (modified) * doc/ada_user/ada_user.texi (modified) * doc/bsp_howto/Makefile (modified) * doc/bsp_howto/bsp_howto.texi (modified) * doc/bsp_howto/target.t (modified) * doc/develenv/Makefile (modified) * doc/develenv/develenv.texi (modified) * doc/networking/Makefile (modified) * doc/networking/networking.texi (modified) * doc/networking/preface.texi (modified) * doc/new_chapters/Makefile (modified) * doc/new_chapters/new_chapters.texi (modified) * doc/posix1003.1/Makefile (modified) * doc/posix1003.1/ch03.t (modified) * doc/posix1003.1/ch04.t (modified) * doc/posix1003.1/ch05.t (modified) * doc/posix1003.1/ch06.t (modified) * doc/posix1003.1/ch07.t (modified) * doc/posix1003.1/ch08.t (modified) * doc/posix1003.1/posix1003_1.texi (modified) * doc/posix_users/Makefile (modified) * doc/posix_users/files.t (modified) * doc/posix_users/io.t (modified) * doc/posix_users/posix_users.texi (modified) * doc/relnotes/Makefile (modified) * doc/relnotes/relnotes.texi (modified) * doc/rgdb_specs/Makefile (modified) * doc/rgdb_specs/rgdb_specs.texi (modified) * doc/rtems_gdb/Makefile (modified) * doc/rtems_gdb/rtems_gdb.texi (modified) * doc/src2html/Makefile (modified) * doc/started/Makefile (modified) * doc/started/buildc.t (modified) * doc/started/nt.t (modified) * doc/started/started.texi (modified) * doc/started_ada/Makefile (modified) * doc/started_ada/buildada.t (modified) * doc/started_ada/started_ada.texi (modified) * doc/supplements/hppa1_1/Makefile (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/i386/Makefile (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i960/Makefile (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/mips64orion/Makefile (modified) * doc/supplements/mips64orion/mips64orion.texi (modified) * doc/supplements/powerpc/Makefile (modified) * doc/supplements/powerpc/powerpc.texi (modified) * doc/supplements/sh/Makefile (modified) * doc/supplements/sh/sh.texi (modified) * doc/supplements/sparc/Makefile (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/supplements/template/Makefile (modified) * doc/supplements/template/template.texi (modified) * doc/tools/bmenu/main.c (modified) * doc/tools/pdl2texi/Makefile (modified) * doc/tools/pdl2texi/main.c (modified) * doc/tools/texi2www/Makefile (modified) * doc/tools/texi2www/texi2www (modified) * doc/tools/texi2www/texi2www.texi (modified) * doc/user/Makefile (modified) * doc/user/c_user.texi (modified) * doc/user/msg.t (modified) * doc/user/part.t (modified) * doc/user/rtmon.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) Numerous minor changes required to transition to the latest version ... Fri, 01 Oct 1999 17:42:44 GMT Joel Sherrill [a25f702] * doc/user/intr.t (modified) Clarified catch and disable per suggestion from Chris Johns ... Sat, 03 Jul 1999 19:06:57 GMT Joel Sherrill [bae90e1] * doc/user/conf.t (modified) Added a lot of information on confdefs.t Sat, 03 Jul 1999 17:13:27 GMT Joel Sherrill [28807e7] * doc/FAQ/Makefile (modified) * doc/Make.config (modified) * doc/ada_user/Makefile (modified) * doc/bsp_howto/Makefile (modified) * doc/develenv/Makefile (modified) * doc/index.html (modified) * doc/networking/Makefile (modified) * doc/new_chapters/Makefile (modified) * doc/posix1003.1/Makefile (modified) * doc/posix_users/Makefile (modified) * doc/relnotes/Makefile (modified) * doc/rgdb_specs/Makefile (modified) * doc/rtems_gdb/Makefile (modified) * doc/src2html/Makefile (modified) * doc/started/Makefile (modified) * doc/started_ada/Makefile (modified) * doc/supplements/hppa1_1/Makefile (modified) * doc/supplements/i386/Makefile (modified) * doc/supplements/i960/Makefile (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/mips64orion/Makefile (modified) * doc/supplements/powerpc/Makefile (modified) * doc/supplements/sh/Makefile (modified) * doc/supplements/sparc/Makefile (modified) * doc/supplements/template/Makefile (modified) * doc/tools/texi2www/Makefile (modified) * doc/user/Makefile (modified) Removed concept of distribution level. Thu, 01 Jul 1999 23:06:29 GMT Joel Sherrill [2a6a029f] * doc/user/task.t (modified) Added error status for bad return pointer argument on ... Thu, 01 Jul 1999 23:05:51 GMT Joel Sherrill [c85b8f2f] * doc/user/sem.t (modified) Corrected formatting so argument was in code font. Thu, 01 Jul 1999 23:05:34 GMT Joel Sherrill [68f54e1] * doc/user/io.t (modified) Fixed reference to initialize_executive to use the current name. Mon, 19 Apr 1999 17:40:20 GMT Joel Sherrill [338502f] * doc/user/conf.t (modified) Unlimited objects information from Chris Johns (ccj@acm.org). Tue, 09 Feb 1999 20:31:34 GMT Joel Sherrill [c13cd48] * doc/user/conf.t (modified) Added maximum_timers field to configuration table. Wed, 03 Feb 1999 13:46:12 GMT Joel Sherrill [2a766a0] * doc/user/conf.t (modified) Added POSIX timers. Thu, 17 Dec 1998 18:34:01 GMT Joel Sherrill [0296c071] * doc/user/userext.t (modified) Updated to correct information on post switch extension and to make ... Thu, 17 Dec 1998 18:21:39 GMT Joel Sherrill [94c0943] * doc/user/conf.t (modified) Corrected information about the post_switch extension. Tue, 27 Oct 1998 21:29:30 GMT Joel Sherrill [b95914f] * doc/user/task.t (modified) Spacing. Fri, 09 Oct 1998 16:47:24 GMT Joel Sherrill [87dea1e4] * doc/user/rtmon.t (modified) Fixed typo spotted by Jeff Mayes. Thu, 13 Aug 1998 18:18:18 GMT Joel Sherrill [eac2c4e] * doc/user/event.t (modified) Added text to clarify the queueing of multiple events. Wed, 15 Apr 1998 00:10:03 GMT Joel Sherrill [9b64c2d5] * c/src/ada/rtems.ads (modified) * c/src/lib/libbsp/a29k/portsw/startup/bspstart.c (modified) * c/src/lib/libbsp/hppa1.1/simhppa/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/force386/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/go32/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/i386ex/startup/bspstart.c (modified) * c/src/lib/libbsp/i386/pc386/startup/bspstart.c (modified) * c/src/lib/libbsp/i960/cvme961/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/dmv152/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi332/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/efi68k/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68302/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/gen68360/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/idp/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme136/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme147s/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/mvme162/startup/bspstart.c (modified) * c/src/lib/libbsp/m68k/ods68302/startup/bspstart.c (modified) * c/src/lib/libbsp/mips/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/mips64orion/p4000/startup/bspstart.c (modified) * c/src/lib/libbsp/no_cpu/no_bsp/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/papyrus/startup/bspstart.c (modified) * c/src/lib/libbsp/powerpc/psim/startup/bspstart.c (modified) * c/src/lib/libbsp/sh/gensh1/startup/bspstart.c (modified) * c/src/lib/libbsp/sparc/erc32/startup/bspstart.c (modified) * c/src/lib/libbsp/unix/posix/startup/bspstart.c (modified) * cpukit/ada/rtems.ads (modified) * doc/user/conf.t (modified) Per suggestion from Eric Norum, went from one initial extension set ... Thu, 02 Apr 1998 16:21:08 GMT Joel Sherrill [56061f5] * doc/user/Makefile (modified) * doc/user/c_user.texi (modified) Went back to not printing an index. makeinfo does fine if you have ... Thu, 02 Apr 1998 16:18:26 GMT Joel Sherrill [87ed029] * doc/user/c_user.texi (modified) * doc/user/clock.t (modified) * doc/user/dpmem.t (modified) * doc/user/event.t (modified) * doc/user/fatal.t (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/part.t (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) Added "findex" for all directive pages but it turns out that this ... Mon, 30 Mar 1998 14:58:53 GMT Joel Sherrill [eff6983d] * doc/Make.config (modified) * doc/Makefile (modified) * doc/ada_user/Makefile (modified) * doc/develenv/Makefile (modified) * doc/new_chapters/Makefile (modified) * doc/posix1003.1/Makefile (modified) * doc/posix_users/Makefile (modified) * doc/relnotes/Makefile (modified) * doc/supplements/hppa1_1/Makefile (modified) * doc/supplements/i386/Makefile (modified) * doc/supplements/i960/Makefile (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/powerpc/Makefile (modified) * doc/supplements/sparc/Makefile (modified) * doc/user/Makefile (modified) Making the stanza right and improving the way the isntall directories ... Mon, 30 Mar 1998 14:42:11 GMT Joel Sherrill [ca0b18a1] * doc/Make.config (modified) * doc/ada_user/Makefile (modified) * doc/develenv/Makefile (modified) * doc/new_chapters/Makefile (modified) * doc/posix1003.1/Makefile (modified) * doc/posix_users/Makefile (modified) * doc/relnotes/Makefile (modified) * doc/supplements/hppa1_1/Makefile (modified) * doc/supplements/i386/Makefile (modified) * doc/supplements/i960/Makefile (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/powerpc/Makefile (modified) * doc/supplements/sparc/Makefile (modified) * doc/user/Makefile (modified) Corrected distribution levels for html Mon, 30 Mar 1998 14:27:11 GMT Joel Sherrill [3754660c] * doc/ada_user/Makefile (modified) * doc/develenv/Makefile (modified) * doc/new_chapters/Makefile (modified) * doc/posix1003.1/Makefile (modified) * doc/posix_users/Makefile (modified) * doc/relnotes/Makefile (modified) * doc/supplements/hppa1_1/Makefile (modified) * doc/supplements/i386/Makefile (modified) * doc/supplements/i960/Makefile (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/powerpc/Makefile (modified) * doc/supplements/sparc/Makefile (modified) * doc/user/Makefile (modified) Added distribution level to each manual Fri, 27 Mar 1998 20:50:31 GMT Joel Sherrill [fb94e65] * doc/user/Makefile (modified) Added dependency so html would build from scratch. Fri, 27 Mar 1998 18:53:17 GMT Joel Sherrill [20515fc] * doc/user/Makefile (modified) * doc/user/bsp.t (modified) * doc/user/clock.t (modified) * doc/user/concepts.t (modified) * doc/user/conf.t (modified) * doc/user/dirstat.texi (modified) * doc/user/dpmem.t (modified) * doc/user/event.t (modified) * doc/user/fatal.t (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/overview.t (modified) * doc/user/part.t (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) Nodes, menus, etc are automatically generated now Fri, 27 Mar 1998 16:47:53 GMT Joel Sherrill [75e22db] * doc/user/bsp.t (modified) * doc/user/clock.t (modified) * doc/user/conf.t (modified) * doc/user/dpmem.t (modified) * doc/user/event.t (modified) * doc/user/example.texi (modified) * doc/user/fatal.t (modified) * doc/user/glossary.texi (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/part.t (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) Completed sweep adding directive and constant prefixes. Fri, 27 Mar 1998 13:24:52 GMT Joel Sherrill [f331481c] * doc/user/dpmem.t (modified) * doc/user/event.t (modified) * doc/user/fatal.t (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/part.t (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) Conditionally adding RTEMS_ and rtems_ prefixes. Fri, 27 Mar 1998 13:24:21 GMT Joel Sherrill [4fa4ea65] * doc/user/bsp.t (modified) * doc/user/c_user.texi (modified) * doc/user/clock.t (modified) * doc/user/conf.t (modified) * doc/user/dirstat.texi (modified) * doc/user/preface.texi (modified) Added Hitachi SH Fri, 27 Mar 1998 13:04:02 GMT Joel Sherrill [a3a7527] * doc/user/c_user.texi (modified) * doc/user/event.t (modified) * doc/user/intr.t (modified) * doc/user/msg.t (modified) * doc/user/region.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) Attempting to add variable so that in C all constants start with ... Thu, 26 Mar 1998 20:30:52 GMT Joel Sherrill [8a8b7519] * doc/ada_user/ada_user.texi (modified) * doc/common/setup.texi (modified) * doc/develenv/develenv.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/rtems_footer.html (modified) * doc/rtems_header.html (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/powerpc/powerpc.texi (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/user/c_user.texi (modified) Added variables for dates and revision info Fri, 06 Feb 1998 14:14:30 GMT Joel Sherrill [1e524995] * doc/HELP.html (modified) * doc/ada_user/Makefile (modified) * doc/ada_user/ada_user.texi (modified) * doc/ada_user/example.texi (modified) * doc/common/cpright.texi (modified) * doc/common/setup.texi (modified) * doc/common/timemac.texi (modified) * doc/common/timetbl.t (modified) * doc/common/timing.texi (modified) * doc/common/wksheets.t (modified) * doc/develenv/Makefile (modified) * doc/develenv/compile.texi (modified) * doc/develenv/develenv.texi (modified) * doc/develenv/direct.texi (modified) * doc/develenv/intro.texi (modified) * doc/develenv/sample.texi (modified) * doc/develenv/utils.texi (modified) * doc/new_chapters/Makefile (modified) * doc/new_chapters/base.texi (modified) * doc/new_chapters/clock.texi (modified) * doc/new_chapters/cond.texi (modified) * doc/new_chapters/key.texi (modified) * doc/new_chapters/mutex.texi (modified) * doc/new_chapters/posix_test_plan.texi (modified) * doc/new_chapters/preface.texi (modified) * doc/new_chapters/sched.texi (modified) * doc/new_chapters/signal.texi (modified) * doc/new_chapters/thread.texi (modified) * doc/posix_users/Makefile (modified) * doc/posix_users/base.texi (modified) * doc/posix_users/clock.texi (modified) * doc/posix_users/cond.texi (modified) * doc/posix_users/key.texi (modified) * doc/posix_users/mutex.texi (modified) * doc/posix_users/posix_test_plan.texi (modified) * doc/posix_users/preface.texi (modified) * doc/posix_users/sched.texi (modified) * doc/posix_users/signal.texi (modified) * doc/posix_users/thread.texi (modified) * doc/relnotes/Makefile (modified) * doc/relnotes/install.texi (modified) * doc/relnotes/intro.texi (modified) * doc/relnotes/probrep.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/relnotes/status.texi (modified) * doc/rtems.html (modified) * doc/rtems_footer.html (modified) * doc/supplements/hppa1_1/Makefile (modified) * doc/supplements/hppa1_1/bsp.t (modified) * doc/supplements/hppa1_1/bsp.texi (modified) * doc/supplements/hppa1_1/callconv.t (modified) * doc/supplements/hppa1_1/callconv.texi (modified) * doc/supplements/hppa1_1/cpumodel.t (modified) * doc/supplements/hppa1_1/cpumodel.texi (modified) * doc/supplements/hppa1_1/cputable.t (modified) * doc/supplements/hppa1_1/cputable.texi (modified) * doc/supplements/hppa1_1/fatalerr.t (modified) * doc/supplements/hppa1_1/fatalerr.texi (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/hppa1_1/intr.t (modified) * doc/supplements/hppa1_1/intr_NOTIMES.t (modified) * doc/supplements/hppa1_1/memmodel.t (modified) * doc/supplements/hppa1_1/memmodel.texi (modified) * doc/supplements/hppa1_1/preface.texi (modified) * doc/supplements/hppa1_1/timedata.t (modified) * doc/supplements/i386/Makefile (modified) * doc/supplements/i386/bsp.t (modified) * doc/supplements/i386/bsp.texi (modified) * doc/supplements/i386/callconv.t (modified) * doc/supplements/i386/callconv.texi (modified) * doc/supplements/i386/cpumodel.t (modified) * doc/supplements/i386/cpumodel.texi (modified) * doc/supplements/i386/cputable.t (modified) * doc/supplements/i386/cputable.texi (modified) * doc/supplements/i386/fatalerr.t (modified) * doc/supplements/i386/fatalerr.texi (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i386/intr.t (modified) * doc/supplements/i386/intr_NOTIMES.t (modified) * doc/supplements/i386/memmodel.t (modified) * doc/supplements/i386/memmodel.texi (modified) * doc/supplements/i386/preface.texi (modified) * doc/supplements/i386/timeFORCE386.t (modified) * doc/supplements/i386/timedata.t (modified) * doc/supplements/i960/Makefile (modified) * doc/supplements/i960/bsp.t (modified) * doc/supplements/i960/bsp.texi (modified) * doc/supplements/i960/callconv.t (modified) * doc/supplements/i960/callconv.texi (modified) * doc/supplements/i960/cpumodel.t (modified) * doc/supplements/i960/cpumodel.texi (modified) * doc/supplements/i960/cputable.t (modified) * doc/supplements/i960/cputable.texi (modified) * doc/supplements/i960/fatalerr.t (modified) * doc/supplements/i960/fatalerr.texi (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/i960/intr.t (modified) * doc/supplements/i960/intr_NOTIMES.t (modified) * doc/supplements/i960/memmodel.t (modified) * doc/supplements/i960/memmodel.texi (modified) * doc/supplements/i960/preface.texi (modified) * doc/supplements/i960/timeCVME961.t (modified) * doc/supplements/i960/timedata.t (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/m68k/bsp.t (modified) * doc/supplements/m68k/callconv.t (modified) * doc/supplements/m68k/cpumodel.t (modified) * doc/supplements/m68k/cputable.t (modified) * doc/supplements/m68k/fatalerr.t (modified) * doc/supplements/m68k/intr_NOTIMES.t (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/m68k/memmodel.t (modified) * doc/supplements/m68k/preface.texi (modified) * doc/supplements/m68k/timeMVME136.t (modified) * doc/supplements/m68k/timedata.t (modified) * doc/supplements/powerpc/Makefile (modified) * doc/supplements/powerpc/bsp.t (modified) * doc/supplements/powerpc/bsp.texi (modified) * doc/supplements/powerpc/callconv.t (modified) * doc/supplements/powerpc/callconv.texi (modified) * doc/supplements/powerpc/cpumodel.t (modified) * doc/supplements/powerpc/cpumodel.texi (modified) * doc/supplements/powerpc/cputable.t (modified) * doc/supplements/powerpc/cputable.texi (modified) * doc/supplements/powerpc/fatalerr.t (modified) * doc/supplements/powerpc/fatalerr.texi (modified) * doc/supplements/powerpc/intr.t (modified) * doc/supplements/powerpc/intr_NOTIMES.t (modified) * doc/supplements/powerpc/memmodel.t (modified) * doc/supplements/powerpc/memmodel.texi (modified) * doc/supplements/powerpc/powerpc.texi (modified) * doc/supplements/powerpc/preface.texi (modified) * doc/supplements/powerpc/timePSIM.t (modified) * doc/supplements/powerpc/timedata.t (modified) * doc/supplements/sparc/Makefile (modified) * doc/supplements/sparc/bsp.t (modified) * doc/supplements/sparc/bsp.texi (modified) * doc/supplements/sparc/callconv.t (modified) * doc/supplements/sparc/callconv.texi (modified) * doc/supplements/sparc/cpumodel.t (modified) * doc/supplements/sparc/cpumodel.texi (modified) * doc/supplements/sparc/cputable.t (modified) * doc/supplements/sparc/cputable.texi (modified) * doc/supplements/sparc/fatalerr.t (modified) * doc/supplements/sparc/fatalerr.texi (modified) * doc/supplements/sparc/intr.t (modified) * doc/supplements/sparc/intr_NOTIMES.t (modified) * doc/supplements/sparc/memmodel.t (modified) * doc/supplements/sparc/memmodel.texi (modified) * doc/supplements/sparc/preface.texi (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/supplements/sparc/timeERC32.t (modified) * doc/supplements/sparc/timedata.t (modified) * doc/tools/bmenu/Makefile (modified) * doc/tools/bmenu/address.h (modified) * doc/tools/bmenu/address.inl (modified) * doc/tools/bmenu/base.h (modified) * doc/tools/bmenu/chain.c (modified) * doc/tools/bmenu/chain.h (modified) * doc/tools/bmenu/chain.inl (modified) * doc/tools/bmenu/isr.h (modified) * doc/tools/bmenu/main.c (modified) * doc/tools/bmenu/system.h (modified) * doc/user/Makefile (modified) * doc/user/bsp.t (modified) * doc/user/c_user.texi (modified) * doc/user/clock.t (modified) * doc/user/concepts.t (modified) * doc/user/conf.t (modified) * doc/user/dirstat.texi (modified) * doc/user/dpmem.t (modified) * doc/user/event.t (modified) * doc/user/example.texi (modified) * doc/user/fatal.t (modified) * doc/user/glossary.texi (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/overview.t (modified) * doc/user/part.t (modified) * doc/user/preface.texi (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) Updated copyrights Fri, 23 Jan 1998 16:57:29 GMT Joel Sherrill [173c59c8] * doc/Make.config (modified) * doc/ada_user/ada_user.texi (modified) * doc/develenv/develenv.texi (modified) * doc/new_chapters/clock.texi (modified) * doc/new_chapters/posix_test_plan.texi (modified) * doc/posix_users/clock.texi (modified) * doc/posix_users/posix_test_plan.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/powerpc/bsp.t (modified) * doc/supplements/powerpc/bsp.texi (modified) * doc/supplements/powerpc/callconv.t (modified) * doc/supplements/powerpc/callconv.texi (modified) * doc/supplements/powerpc/powerpc.texi (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/user/c_user.texi (modified) * doc/user/intr.t (modified) minor updates .. mostly version Wed, 03 Sep 1997 15:36:05 GMT Joel Sherrill [cf5ef6d] * doc/user/rtmon.t (modified) More specific information on error code. Mon, 04 Aug 1997 20:05:48 GMT Joel Sherrill [1ca951ce] * doc/user/event.t (modified) * doc/user/msg.t (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/sem.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) Added information based on comments from Katsu Shibuya. Thu, 31 Jul 1997 18:44:10 GMT Joel Sherrill [c3fec1c] * doc/user/clock.t (modified) Added info on what data type is expected by the clock_get directive ... Thu, 31 Jul 1997 18:24:06 GMT Joel Sherrill [d1f19f0] * doc/user/msg.t (modified) Added rtems_message_queue_get_number_pending directive. Fri, 18 Jul 1997 15:04:19 GMT Joel Sherrill [372a382a] * doc/user/timer.t (modified) Fixed typo of "::" Wed, 04 Jun 1997 18:32:07 GMT Joel Sherrill [139b2e4a] * doc/Make.config (modified) * doc/README (modified) * doc/ada_user/Makefile (modified) * doc/ada_user/ada_user.texi (modified) * doc/ada_user/example.texi (modified) * doc/common/cpright.texi (modified) * doc/common/setup.texi (modified) * doc/common/timemac.texi (modified) * doc/common/timetbl.t (modified) * doc/common/timing.texi (modified) * doc/common/wksheets.t (modified) * doc/develenv/Makefile (modified) * doc/develenv/compile.texi (modified) * doc/develenv/develenv.texi (modified) * doc/develenv/direct.texi (modified) * doc/develenv/intro.texi (modified) * doc/develenv/sample.texi (modified) * doc/develenv/utils.texi (modified) * doc/import_ami_txt (modified) * doc/new_chapters/Makefile (modified) * doc/new_chapters/base.texi (modified) * doc/new_chapters/clock.texi (modified) * doc/new_chapters/cond.texi (modified) * doc/new_chapters/key.texi (modified) * doc/new_chapters/mutex.texi (modified) * doc/new_chapters/posix_test_plan.texi (modified) * doc/new_chapters/preface.texi (modified) * doc/new_chapters/sched.texi (modified) * doc/new_chapters/signal.texi (modified) * doc/new_chapters/thread.texi (modified) * doc/posix_users/Makefile (modified) * doc/posix_users/base.texi (modified) * doc/posix_users/clock.texi (modified) * doc/posix_users/cond.texi (modified) * doc/posix_users/key.texi (modified) * doc/posix_users/mutex.texi (modified) * doc/posix_users/posix_test_plan.texi (modified) * doc/posix_users/preface.texi (modified) * doc/posix_users/sched.texi (modified) * doc/posix_users/signal.texi (modified) * doc/posix_users/thread.texi (modified) * doc/relnotes/Makefile (modified) * doc/relnotes/install.texi (modified) * doc/relnotes/intro.texi (modified) * doc/relnotes/probrep.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/relnotes/status.texi (modified) * doc/supplements/hppa1_1/Makefile (modified) * doc/supplements/hppa1_1/SIMHPPA_TIMES (modified) * doc/supplements/hppa1_1/TIMES (modified) * doc/supplements/hppa1_1/bsp.t (modified) * doc/supplements/hppa1_1/bsp.texi (modified) * doc/supplements/hppa1_1/callconv.t (modified) * doc/supplements/hppa1_1/callconv.texi (modified) * doc/supplements/hppa1_1/cpumodel.t (modified) * doc/supplements/hppa1_1/cpumodel.texi (modified) * doc/supplements/hppa1_1/cputable.t (modified) * doc/supplements/hppa1_1/cputable.texi (modified) * doc/supplements/hppa1_1/fatalerr.t (modified) * doc/supplements/hppa1_1/fatalerr.texi (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/hppa1_1/intr.t (modified) * doc/supplements/hppa1_1/intr_NOTIMES.t (modified) * doc/supplements/hppa1_1/memmodel.t (modified) * doc/supplements/hppa1_1/memmodel.texi (modified) * doc/supplements/hppa1_1/preface.texi (modified) * doc/supplements/hppa1_1/timedata.t (modified) * doc/supplements/i386/FORCE386_TIMES (modified) * doc/supplements/i386/Makefile (modified) * doc/supplements/i386/bsp.t (modified) * doc/supplements/i386/bsp.texi (modified) * doc/supplements/i386/callconv.t (modified) * doc/supplements/i386/callconv.texi (modified) * doc/supplements/i386/cpumodel.t (modified) * doc/supplements/i386/cpumodel.texi (modified) * doc/supplements/i386/cputable.t (modified) * doc/supplements/i386/cputable.texi (modified) * doc/supplements/i386/fatalerr.t (modified) * doc/supplements/i386/fatalerr.texi (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i386/intr.t (modified) * doc/supplements/i386/intr_NOTIMES.t (modified) * doc/supplements/i386/memmodel.t (modified) * doc/supplements/i386/memmodel.texi (modified) * doc/supplements/i386/preface.texi (modified) * doc/supplements/i386/timeFORCE386.t (modified) * doc/supplements/i386/timedata.t (modified) * doc/supplements/i960/CVME961_TIMES (modified) * doc/supplements/i960/Makefile (modified) * doc/supplements/i960/bsp.t (modified) * doc/supplements/i960/bsp.texi (modified) * doc/supplements/i960/callconv.t (modified) * doc/supplements/i960/callconv.texi (modified) * doc/supplements/i960/cpumodel.t (modified) * doc/supplements/i960/cpumodel.texi (modified) * doc/supplements/i960/cputable.t (modified) * doc/supplements/i960/cputable.texi (modified) * doc/supplements/i960/fatalerr.t (modified) * doc/supplements/i960/fatalerr.texi (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/i960/intr.t (modified) * doc/supplements/i960/intr_NOTIMES.t (modified) * doc/supplements/i960/memmodel.t (modified) * doc/supplements/i960/memmodel.texi (modified) * doc/supplements/i960/preface.texi (modified) * doc/supplements/i960/timeCVME961.t (modified) * doc/supplements/i960/timedata.t (modified) * doc/supplements/m68k/MVME136_TIMES (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/m68k/bsp.t (modified) * doc/supplements/m68k/callconv.t (modified) * doc/supplements/m68k/cpumodel.t (modified) * doc/supplements/m68k/cputable.t (modified) * doc/supplements/m68k/fatalerr.t (modified) * doc/supplements/m68k/intr_NOTIMES.t (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/m68k/memmodel.t (modified) * doc/supplements/m68k/preface.texi (modified) * doc/supplements/m68k/timeMVME136.t (modified) * doc/supplements/m68k/timedata.t (modified) * doc/supplements/sparc/ERC32_TIMES (modified) * doc/supplements/sparc/Makefile (modified) * doc/supplements/sparc/SIS_TIMES (modified) * doc/supplements/sparc/bsp.t (modified) * doc/supplements/sparc/bsp.texi (modified) * doc/supplements/sparc/callconv.t (modified) * doc/supplements/sparc/callconv.texi (modified) * doc/supplements/sparc/cpumodel.t (modified) * doc/supplements/sparc/cpumodel.texi (modified) * doc/supplements/sparc/cputable.t (modified) * doc/supplements/sparc/cputable.texi (modified) * doc/supplements/sparc/fatalerr.t (modified) * doc/supplements/sparc/fatalerr.texi (modified) * doc/supplements/sparc/intr.t (modified) * doc/supplements/sparc/intr_NOTIMES.t (modified) * doc/supplements/sparc/memmodel.t (modified) * doc/supplements/sparc/memmodel.texi (modified) * doc/supplements/sparc/preface.texi (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/supplements/sparc/timeERC32.t (modified) * doc/supplements/sparc/timedata.t (modified) * doc/tools/bmenu/Makefile (modified) * doc/tools/bmenu/address.h (modified) * doc/tools/bmenu/address.inl (modified) * doc/tools/bmenu/base.h (modified) * doc/tools/bmenu/chain.c (modified) * doc/tools/bmenu/chain.h (modified) * doc/tools/bmenu/chain.inl (modified) * doc/tools/bmenu/isr.h (modified) * doc/tools/bmenu/main.c (modified) * doc/tools/bmenu/system.h (modified) * doc/tools/update (modified) * doc/tools/word-replace (modified) * doc/user/Makefile (modified) * doc/user/bsp.t (modified) * doc/user/c_user.texi (modified) * doc/user/clock.t (modified) * doc/user/concepts.t (modified) * doc/user/conf.t (modified) * doc/user/dirstat.texi (modified) * doc/user/dpmem.t (modified) * doc/user/event.t (modified) * doc/user/example.texi (modified) * doc/user/fatal.t (modified) * doc/user/glossary.texi (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/overview.t (modified) * doc/user/part.t (modified) * doc/user/preface.texi (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) added CVS Id string Wed, 04 Jun 1997 15:15:59 GMT Joel Sherrill [bf56ac8] * doc/Make.config (modified) * doc/ada_user/ada_user.texi (modified) * doc/common/cpright.texi (modified) * doc/common/setup.texi (modified) * doc/develenv/develenv.texi (modified) * doc/new_chapters/posix_test_plan.texi (modified) * doc/posix_users/posix_test_plan.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/sparc/ERC32_TIMES (modified) * doc/supplements/sparc/SIS_TIMES (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/user/c_user.texi (modified) changed edition and version information Wed, 04 Jun 1997 15:15:28 GMT Joel Sherrill [022fbf3e] * doc/user/conf.t (modified) Fixed formatting problem where @example did not start early enough. Wed, 04 Jun 1997 13:04:36 GMT Joel Sherrill [7e8a1fc] * doc/rtems_footer.html (modified) * doc/rtems_header.html (modified) * doc/user/clock.t (modified) * doc/user/conf.t (modified) * doc/user/fatal.t (modified) * doc/user/glossary.texi (modified) * doc/user/intr.t (modified) * doc/user/overview.t (modified) * doc/user/rtmon.t (modified) * doc/user/task.t (modified) * doc/user/userext.t (modified) final corrections before 4.1.0 documentation freeze. Sat, 31 May 1997 15:55:10 GMT Joel Sherrill [a94c5a5d] * doc/new_chapters/posix_test_plan.texi (modified) * doc/posix_users/posix_test_plan.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/user/bsp.t (modified) * doc/user/c_user.texi (modified) * doc/user/clock.t (modified) * doc/user/conf.t (modified) * doc/user/dirstat.texi (modified) * doc/user/event.t (modified) * doc/user/fatal.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/overview.t (modified) * doc/user/part.t (modified) * doc/user/preface.texi (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) Changed bitwise OR's used to build up option and attribute sets to ... Fri, 30 May 1997 22:57:25 GMT Joel Sherrill [17a3c69] * doc/HELP.html (modified) * doc/develenv/sample.texi (modified) * doc/do_docs (modified) * doc/relnotes/intro.texi (modified) * doc/rtems.html (modified) * doc/supplements/hppa1_1/bsp.t (modified) * doc/supplements/hppa1_1/bsp.texi (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/i386/bsp.t (modified) * doc/supplements/i386/bsp.texi (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i960/bsp.t (modified) * doc/supplements/i960/bsp.texi (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/m68k/bsp.t (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/sparc/bsp.t (modified) * doc/supplements/sparc/bsp.texi (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/user/conf.t (modified) * doc/user/fatal.t (modified) * doc/user/intr.t (modified) * doc/user/overview.t (modified) fixed typos Fri, 30 May 1997 21:15:28 GMT Joel Sherrill [92c2ae1f] * doc/user/conf.t (modified) * doc/user/init.t (modified) updated to reflect Ada Thu, 29 May 1997 21:53:58 GMT Joel Sherrill [61389eac] * doc/user/c_user.texi (modified) * doc/user/clock.t (modified) * doc/user/concepts.t (modified) * doc/user/conf.t (modified) * doc/user/dpmem.t (modified) * doc/user/event.t (modified) * doc/user/fatal.t (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/overview.t (modified) * doc/user/part.t (modified) * doc/user/preface.texi (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) first cut at Ada bindings manual Wed, 28 May 1997 20:34:49 GMT Joel Sherrill [5c995d7] * doc/develenv/develenv.texi (modified) * doc/new_chapters/posix_test_plan.texi (modified) * doc/posix_users/posix_test_plan.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/user/c_user.texi (modified) version changed Wed, 28 May 1997 13:57:50 GMT Joel Sherrill [3dc513e] * doc/develenv/develenv.texi (modified) * doc/new_chapters/posix_test_plan.texi (modified) * doc/posix_users/posix_test_plan.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/i386/FORCE386_TIMES (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/m68k/MVME136_TIMES (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/sparc/ERC32_TIMES (modified) * doc/supplements/sparc/SIS_TIMES (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/user/c_user.texi (modified) 4.0.0 release docs Tue, 27 May 1997 12:40:11 GMT Joel Sherrill [ae68ff0] * doc/HELP.html (added) * doc/Make.config (added) * doc/Makefile (added) * doc/README (added) * doc/archgrey.gif (added) * doc/common/cpright.texi (added) * doc/common/missing-arrow.gif (added) * doc/common/next-arrow.gif (added) * doc/common/oaronly.jpg (added) * doc/common/prev-arrow.gif (added) * doc/common/setup.texi (added) * doc/common/timemac.texi (added) * doc/common/timetbl.t (added) * doc/common/timing.texi (added) * doc/common/up-arrow.gif (added) * doc/common/wksheets.t (added) * doc/develenv/Makefile (added) * doc/develenv/compile.texi (added) * doc/develenv/develenv.texi (added) * doc/develenv/direct.texi (added) * doc/develenv/intro.texi (added) * doc/develenv/sample.texi (added) * doc/develenv/utils.texi (added) * doc/do_docs (added) * doc/import_ami_txt (added) * doc/new_chapters/Makefile (added) * doc/new_chapters/base.texi (added) * doc/new_chapters/clock.texi (added) * doc/new_chapters/cond.texi (added) * doc/new_chapters/key.texi (added) * doc/new_chapters/mutex.texi (added) * doc/new_chapters/posix_test_plan.texi (added) * doc/new_chapters/preface.texi (added) * doc/new_chapters/sched.texi (added) * doc/new_chapters/signal.texi (added) * doc/new_chapters/thread.texi (added) * doc/oaronly.jpg (added) * doc/posix_users/Makefile (added) * doc/posix_users/base.texi (added) * doc/posix_users/clock.texi (added) * doc/posix_users/cond.texi (added) * doc/posix_users/key.texi (added) * doc/posix_users/mutex.texi (added) * doc/posix_users/posix_test_plan.texi (added) * doc/posix_users/preface.texi (added) * doc/posix_users/sched.texi (added) * doc/posix_users/signal.texi (added) * doc/posix_users/thread.texi (added) * doc/relnotes/Makefile (added) * doc/relnotes/install.texi (added) * doc/relnotes/intro.texi (added) * doc/relnotes/probrep.texi (added) * doc/relnotes/relnotes.texi (added) * doc/relnotes/status.texi (added) * doc/rtems.html (added) * doc/rtems_footer.html (added) * doc/rtems_header.html (added) * doc/supplements/hppa1_1/Makefile (added) * doc/supplements/hppa1_1/SIMHPPA_TIMES (added) * doc/supplements/hppa1_1/TIMES (added) * doc/supplements/hppa1_1/bsp.t (added) * doc/supplements/hppa1_1/bsp.texi (added) * doc/supplements/hppa1_1/callconv.t (added) * doc/supplements/hppa1_1/callconv.texi (added) * doc/supplements/hppa1_1/cpumodel.t (added) * doc/supplements/hppa1_1/cpumodel.texi (added) * doc/supplements/hppa1_1/cputable.t (added) * doc/supplements/hppa1_1/cputable.texi (added) * doc/supplements/hppa1_1/fatalerr.t (added) * doc/supplements/hppa1_1/fatalerr.texi (added) * doc/supplements/hppa1_1/hppa1_1.texi (added) * doc/supplements/hppa1_1/intr.t (added) * doc/supplements/hppa1_1/intr_NOTIMES.t (added) * doc/supplements/hppa1_1/memmodel.t (added) * doc/supplements/hppa1_1/memmodel.texi (added) * doc/supplements/hppa1_1/preface.texi (added) * doc/supplements/hppa1_1/timedata.t (added) * doc/supplements/i386/FORCE386_TIMES (added) * doc/supplements/i386/Makefile (added) * doc/supplements/i386/bsp.t (added) * doc/supplements/i386/bsp.texi (added) * doc/supplements/i386/callconv.t (added) * doc/supplements/i386/callconv.texi (added) * doc/supplements/i386/cpumodel.t (added) * doc/supplements/i386/cpumodel.texi (added) * doc/supplements/i386/cputable.t (added) * doc/supplements/i386/cputable.texi (added) * doc/supplements/i386/fatalerr.t (added) * doc/supplements/i386/fatalerr.texi (added) * doc/supplements/i386/i386.texi (added) * doc/supplements/i386/intr.t (added) * doc/supplements/i386/intr_NOTIMES.t (added) * doc/supplements/i386/memmodel.t (added) * doc/supplements/i386/memmodel.texi (added) * doc/supplements/i386/preface.texi (added) * doc/supplements/i386/timeFORCE386.t (added) * doc/supplements/i386/timedata.t (added) * doc/supplements/i960/CVME961_TIMES (added) * doc/supplements/i960/Makefile (added) * doc/supplements/i960/bsp.t (added) * doc/supplements/i960/bsp.texi (added) * doc/supplements/i960/callconv.t (added) * doc/supplements/i960/callconv.texi (added) * doc/supplements/i960/cpumodel.t (added) * doc/supplements/i960/cpumodel.texi (added) * doc/supplements/i960/cputable.t (added) * doc/supplements/i960/cputable.texi (added) * doc/supplements/i960/fatalerr.t (added) * doc/supplements/i960/fatalerr.texi (added) * doc/supplements/i960/i960.texi (added) * doc/supplements/i960/intr.t (added) * doc/supplements/i960/intr_NOTIMES.t (added) * doc/supplements/i960/memmodel.t (added) * doc/supplements/i960/memmodel.texi (added) * doc/supplements/i960/preface.texi (added) * doc/supplements/i960/timeCVME961.t (added) * doc/supplements/i960/timedata.t (added) * doc/supplements/m68k/MVME136_TIMES (added) * doc/supplements/m68k/Makefile (added) * doc/supplements/m68k/bsp.t (added) * doc/supplements/m68k/callconv.t (added) * doc/supplements/m68k/cpumodel.t (added) * doc/supplements/m68k/cputable.t (added) * doc/supplements/m68k/fatalerr.t (added) * doc/supplements/m68k/intr_NOTIMES.t (added) * doc/supplements/m68k/m68k.texi (added) * doc/supplements/m68k/memmodel.t (added) * doc/supplements/m68k/preface.texi (added) * doc/supplements/m68k/timeMVME136.t (added) * doc/supplements/m68k/timedata.t (added) * doc/supplements/sparc/ERC32_TIMES (added) * doc/supplements/sparc/Makefile (added) * doc/supplements/sparc/SIS_TIMES (added) * doc/supplements/sparc/bsp.t (added) * doc/supplements/sparc/bsp.texi (added) * doc/supplements/sparc/callconv.t (added) * doc/supplements/sparc/callconv.texi (added) * doc/supplements/sparc/cpumodel.t (added) * doc/supplements/sparc/cpumodel.texi (added) * doc/supplements/sparc/cputable.t (added) * doc/supplements/sparc/cputable.texi (added) * doc/supplements/sparc/fatalerr.t (added) * doc/supplements/sparc/fatalerr.texi (added) * doc/supplements/sparc/intr.t (added) * doc/supplements/sparc/intr_NOTIMES.t (added) * doc/supplements/sparc/memmodel.t (added) * doc/supplements/sparc/memmodel.texi (added) * doc/supplements/sparc/preface.texi (added) * doc/supplements/sparc/sparc.texi (added) * doc/supplements/sparc/timeERC32.t (added) * doc/supplements/sparc/timedata.t (added) * doc/texinfo/texinfo.tex (added) * doc/tools/bmenu/Makefile (added) * doc/tools/bmenu/address.h (added) * doc/tools/bmenu/address.inl (added) * doc/tools/bmenu/base.h (added) * doc/tools/bmenu/bmenu (added) * doc/tools/bmenu/chain.c (added) * doc/tools/bmenu/chain.h (added) * doc/tools/bmenu/chain.inl (added) * doc/tools/bmenu/chain.o (added) * doc/tools/bmenu/isr.h (added) * doc/tools/bmenu/main.c (added) * doc/tools/bmenu/main.o (added) * doc/tools/bmenu/system.h (added) * doc/tools/update (added) * doc/tools/word-replace (added) * doc/user/Makefile (added) * doc/user/bsp.t (added) * doc/user/c_user.texi (added) * doc/user/clock.t (added) * doc/user/concepts.t (added) * doc/user/conf.t (added) * doc/user/dirstat.texi (added) * doc/user/dpmem.t (added) * doc/user/event.t (added) * doc/user/example.texi (added) * doc/user/fatal.t (added) * doc/user/glossary.texi (added) * doc/user/init.t (added) * doc/user/intr.t (added) * doc/user/io.t (added) * doc/user/mp.t (added) * doc/user/msg.t (added) * doc/user/overview.t (added) * doc/user/part.t (added) * doc/user/preface.texi (added) * doc/user/region.t (added) * doc/user/rtemsarc.gif (added) * doc/user/rtemspie.gif (added) * doc/user/rtmon.t (added) * doc/user/schedule.t (added) * doc/user/sem.t (added) * doc/user/signal.t (added) * doc/user/states.gif (added) * doc/user/task.t (added) * doc/user/timer.t (added) * doc/user/userext.t (added) Initial revision
