# # ChangeLog for doc/user/task.t in rtems # # Generated by Trac 1.2.1.dev0 # 06/03/24 12:58:01 Wed, 28 Nov 2007 16:23:59 GMT Glenn Humphrey [ae10dbd] * doc/ChangeLog (modified) * doc/user/barrier.t (modified) * doc/user/clock.t (modified) * doc/user/concepts.t (modified) * doc/user/conf.t (modified) * doc/user/datatypes.t (modified) * doc/user/dpmem.t (modified) * doc/user/fatal.t (modified) * doc/user/init.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/part.t (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/sem.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) 2007-11-28 Glenn Humphrey ... Thu, 25 Oct 2007 19:46:41 GMT Glenn Humphrey [4ffbc49] * doc/ChangeLog (modified) * doc/user/barrier.t (modified) * doc/user/clock.t (modified) * doc/user/concepts.t (modified) * doc/user/cpuuse.t (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/rtmon.t (modified) * doc/user/sem.t (modified) * doc/user/stackchk.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) 2007-10-25 Glenn Humphrey ... Thu, 05 Apr 2007 15:24:32 GMT Joel Sherrill [540de0e5] * doc/ChangeLog (modified) * doc/user/task.t (modified) 2007-04-05 Joel Sherrill * ... Wed, 13 Sep 2006 16:21:09 GMT Joel Sherrill [aba8a85] * doc/ChangeLog (modified) * doc/new_chapters/Makefile.am (modified) * doc/user/Makefile.am (modified) * doc/user/c_user.texi (modified) * doc/user/dirstat.texi (modified) * doc/user/stackchk.t (moved) * doc/user/task.t (modified) 2006-09-13 Joel Sherrill * ... Fri, 05 Nov 2004 14:37:57 GMT Joel Sherrill [1c89b86] * doc/ChangeLog (modified) * doc/user/task.t (modified) 2004-11-05 Joel Sherrill PR 706/doc ... Fri, 21 May 2004 16:04:47 GMT Joel Sherrill [34d934a] * doc/ChangeLog (modified) * doc/user/task.t (modified) 2004-05-21 Joel Sherrill PR 627/doc ... Thu, 06 May 2004 19:21:50 GMT Joel Sherrill [f8892c9] * doc/ChangeLog (modified) * doc/user/clock.t (modified) * doc/user/dpmem.t (modified) * doc/user/event.t (modified) * doc/user/msg.t (modified) * doc/user/part.t (modified) * doc/user/region.t (modified) * doc/user/sem.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) 2004-05-06 Joel Sherrill PR ... Tue, 25 Nov 2003 14:15:24 GMT Joel Sherrill [444d048] * doc/user/ChangeLog (modified) * doc/user/task.t (modified) 2003-11-25 Joel Sherrill PR ... Thu, 17 Jan 2002 21:47:47 GMT Joel Sherrill [6449498] * doc/ChangeLog (modified) * doc/FAQ/FAQ.texi (modified) * doc/FAQ/Makefile.am (modified) * doc/FAQ/basic.t (modified) * doc/FAQ/bsp.t (modified) * doc/FAQ/build45.t (modified) * doc/FAQ/concepts.t (modified) * doc/FAQ/debug.t (modified) * doc/FAQ/embeddedinfo.t (modified) * doc/FAQ/endoftime.t (modified) * doc/FAQ/freesw.t (modified) * doc/FAQ/hwdebugaids.t (modified) * doc/FAQ/projects.t (modified) * doc/FAQ/stamp-vti (modified) * doc/FAQ/tools.t (modified) * doc/FAQ/version.texi (modified) * doc/HELP.html (modified) * doc/README (modified) * doc/SUPPORT (added) * doc/VERSION (modified) * doc/ada_user/Makefile.am (modified) * doc/ada_user/ada_user.texi (modified) * doc/ada_user/example.texi (modified) * doc/ada_user/stamp-vti (modified) * doc/ada_user/version.texi (modified) * doc/bsp_howto/Makefile.am (modified) * doc/bsp_howto/adaintr.t (modified) * doc/bsp_howto/analog.t (modified) * doc/bsp_howto/bsp_howto.texi (modified) * doc/bsp_howto/clock.t (modified) * doc/bsp_howto/console.t (modified) * doc/bsp_howto/discrete.t (modified) * doc/bsp_howto/init.t (modified) * doc/bsp_howto/intro.t (modified) * doc/bsp_howto/linkcmds.t (modified) * doc/bsp_howto/makefiles.t (modified) * doc/bsp_howto/nvmem.t (modified) * doc/bsp_howto/rtc.t (modified) * doc/bsp_howto/shmsupp.t (modified) * doc/bsp_howto/stamp-vti (modified) * doc/bsp_howto/support.t (modified) * doc/bsp_howto/target.t (modified) * doc/bsp_howto/timer.t (modified) * doc/bsp_howto/version.texi (modified) * doc/common/cpright.texi (modified) * doc/common/setup.texi (modified) * doc/common/timemac.texi (modified) * doc/common/timetbl.t (modified) * doc/common/timing.t (modified) * doc/common/wksheets.t (modified) * doc/configure.in (modified) * doc/develenv/Makefile.am (modified) * doc/develenv/compile.texi (modified) * doc/develenv/develenv.texi (modified) * doc/develenv/direct.texi (modified) * doc/develenv/intro.texi (modified) * doc/develenv/sample.texi (modified) * doc/develenv/stamp-vti (modified) * doc/develenv/utils.texi (modified) * doc/develenv/version.texi (modified) * doc/filesystem/Makefile.am (modified) * doc/filesystem/filesystem.texi (modified) * doc/filesystem/fsrequirements.t (modified) * doc/filesystem/imfs.t (modified) * doc/filesystem/init.t (modified) * doc/filesystem/miniimfs.t (modified) * doc/filesystem/mounting.t (modified) * doc/filesystem/patheval.t (modified) * doc/filesystem/preface.texi (modified) * doc/filesystem/stamp-vti (modified) * doc/filesystem/syscalls.t (modified) * doc/filesystem/tftp.t (modified) * doc/filesystem/version.texi (modified) * doc/gnu_docs/gen_docs (modified) * doc/gnu_docs/gnu_footer.html (modified) * doc/gnu_docs/index.html (modified) * doc/gnu_docs/refcard.html (modified) * doc/gnu_docs/rtems_tools_index.html (modified) * doc/index.html.in (modified) * doc/itron3.0/Makefile.am (modified) * doc/itron3.0/config.t (modified) * doc/itron3.0/eventflags.t (modified) * doc/itron3.0/fixedblock.t (modified) * doc/itron3.0/interrupt.t (modified) * doc/itron3.0/itron.texi (modified) * doc/itron3.0/mailbox.t (modified) * doc/itron3.0/memorypool.t (modified) * doc/itron3.0/msgbuffer.t (modified) * doc/itron3.0/network.t (modified) * doc/itron3.0/preface.texi (modified) * doc/itron3.0/rendezvous.t (modified) * doc/itron3.0/semaphore.t (modified) * doc/itron3.0/stamp-vti (modified) * doc/itron3.0/status.t (modified) * doc/itron3.0/task.t (modified) * doc/itron3.0/tasksync.t (modified) * doc/itron3.0/time.t (modified) * doc/itron3.0/version.texi (modified) * doc/networking/Makefile.am (modified) * doc/networking/driver.t (modified) * doc/networking/networkapp.t (modified) * doc/networking/networking.texi (modified) * doc/networking/networktasks.t (modified) * doc/networking/preface.texi (modified) * doc/networking/servers.t (modified) * doc/networking/stamp-vti (modified) * doc/networking/testing.t (modified) * doc/networking/version.texi (modified) * doc/new_chapters/Makefile.am (modified) * doc/new_chapters/adminiface.t (modified) * doc/new_chapters/base.t (modified) * doc/new_chapters/confspace.t (modified) * doc/new_chapters/cpuuse.t (modified) * doc/new_chapters/dumpcontrol.t (modified) * doc/new_chapters/error.t (modified) * doc/new_chapters/eventlog.t (modified) * doc/new_chapters/gen_section (modified) * doc/new_chapters/monitor.t (modified) * doc/new_chapters/new_chapters.texi (modified) * doc/new_chapters/rtmonuse.t (modified) * doc/new_chapters/stackchk.t (modified) * doc/new_chapters/stamp-vti (modified) * doc/new_chapters/version.texi (modified) * doc/porting/Makefile.am (modified) * doc/porting/codetuning.t (modified) * doc/porting/cpuinit.t (modified) * doc/porting/cpumodels.t (modified) * doc/porting/developtools.t (modified) * doc/porting/idlethread.t (modified) * doc/porting/interrupts.t (modified) * doc/porting/miscellaneous.t (modified) * doc/porting/porting.texi (modified) * doc/porting/preface.texi (modified) * doc/porting/prioritybitmap.t (modified) * doc/porting/sourcecode.t (modified) * doc/porting/stamp-vti (modified) * doc/porting/taskcontext.t (modified) * doc/porting/version.texi (modified) * doc/posix1003.1/Makefile.am (modified) * doc/posix1003.1/ch01.t (modified) * doc/posix1003.1/ch02.t (modified) * doc/posix1003.1/ch03.t (modified) * doc/posix1003.1/ch04.t (modified) * doc/posix1003.1/ch05.t (modified) * doc/posix1003.1/ch06.t (modified) * doc/posix1003.1/ch07.t (modified) * doc/posix1003.1/ch08.t (modified) * doc/posix1003.1/ch09.t (modified) * doc/posix1003.1/ch10.t (modified) * doc/posix1003.1/ch11.t (modified) * doc/posix1003.1/ch12.t (modified) * doc/posix1003.1/ch13.t (modified) * doc/posix1003.1/ch14.t (modified) * doc/posix1003.1/ch15.t (modified) * doc/posix1003.1/ch16.t (modified) * doc/posix1003.1/ch17.t (modified) * doc/posix1003.1/ch18.t (modified) * doc/posix1003.1/posix1003_1.texi (modified) * doc/posix1003.1/preface.texi (modified) * doc/posix1003.1/stamp-vti (modified) * doc/posix1003.1/version.texi (modified) * doc/posix_users/Makefile.am (modified) * doc/posix_users/cancel.t (modified) * doc/posix_users/clock.t (modified) * doc/posix_users/cond.t (modified) * doc/posix_users/cspecific.t (modified) * doc/posix_users/device.t (modified) * doc/posix_users/files.t (modified) * doc/posix_users/io.t (modified) * doc/posix_users/key.t (modified) * doc/posix_users/libc.t (modified) * doc/posix_users/libm.t (modified) * doc/posix_users/memorymgmt.t (modified) * doc/posix_users/message.t (modified) * doc/posix_users/mutex.t (modified) * doc/posix_users/posix_users.texi (modified) * doc/posix_users/preface.texi (modified) * doc/posix_users/procenv.t (modified) * doc/posix_users/process.t (modified) * doc/posix_users/sched.t (modified) * doc/posix_users/semaphores.t (modified) * doc/posix_users/signal.t (modified) * doc/posix_users/stamp-vti (modified) * doc/posix_users/status.t (modified) * doc/posix_users/systemdb.t (modified) * doc/posix_users/thread.t (modified) * doc/posix_users/version.texi (modified) * doc/project.am (modified) * doc/relnotes/Makefile.am (modified) * doc/relnotes/install.texi (modified) * doc/relnotes/intro.texi (modified) * doc/relnotes/probrep.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/relnotes/stamp-vti (modified) * doc/relnotes/status.texi (modified) * doc/relnotes/version.texi (modified) * doc/rgdb_specs/Makefile.am (modified) * doc/rgdb_specs/rgdb_specs.texi (modified) * doc/rgdb_specs/stamp-vti (modified) * doc/rgdb_specs/version.texi (modified) * doc/rtems_footer.html.in (modified) * doc/rtems_gdb/Makefile.am (modified) * doc/rtems_gdb/commands.t (modified) * doc/rtems_gdb/example.t (modified) * doc/rtems_gdb/intro.t (modified) * doc/rtems_gdb/rtems_gdb.texi (modified) * doc/rtems_gdb/stamp-vti (modified) * doc/rtems_gdb/started.t (modified) * doc/rtems_gdb/swarch.t (modified) * doc/rtems_gdb/trouble.t (modified) * doc/rtems_gdb/version.texi (modified) * doc/rtems_support.html.in (modified) * doc/src2html/Makefile.am (modified) * doc/started/Makefile.am (modified) * doc/started/binaries.t (modified) * doc/started/buildc.t (modified) * doc/started/buildrt.t (modified) * doc/started/gdb.t (modified) * doc/started/intro.t (modified) * doc/started/nextstep.t (modified) * doc/started/nt.t (modified) * doc/started/require.t (modified) * doc/started/sample.t (modified) * doc/started/stamp-vti (modified) * doc/started/started.texi (modified) * doc/started/tversions.texi (modified) * doc/started/version.texi (modified) * doc/started_ada/Makefile.am (modified) * doc/started_ada/buildada.t (modified) * doc/started_ada/gdb.t (modified) * doc/started_ada/intro.t (modified) * doc/started_ada/require.t (modified) * doc/started_ada/sample.t (modified) * doc/started_ada/stamp-vti (modified) * doc/started_ada/started_ada.texi (modified) * doc/started_ada/tversions.texi (modified) * doc/started_ada/version.texi (modified) * doc/supplements/hppa1_1/Makefile.am (modified) * doc/supplements/hppa1_1/bsp.t (modified) * doc/supplements/hppa1_1/callconv.t (modified) * doc/supplements/hppa1_1/cpumodel.t (modified) * doc/supplements/hppa1_1/cputable.t (modified) * doc/supplements/hppa1_1/fatalerr.t (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/hppa1_1/intr_NOTIMES.t (modified) * doc/supplements/hppa1_1/memmodel.t (modified) * doc/supplements/hppa1_1/preface.texi (modified) * doc/supplements/hppa1_1/stamp-vti (modified) * doc/supplements/hppa1_1/timeSIMHPPA.t (modified) * doc/supplements/hppa1_1/version.texi (modified) * doc/supplements/i386/Makefile.am (modified) * doc/supplements/i386/bsp.t (modified) * doc/supplements/i386/callconv.t (modified) * doc/supplements/i386/cpumodel.t (modified) * doc/supplements/i386/cputable.t (modified) * doc/supplements/i386/fatalerr.t (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i386/intr_NOTIMES.t (modified) * doc/supplements/i386/memmodel.t (modified) * doc/supplements/i386/preface.texi (modified) * doc/supplements/i386/stamp-vti (modified) * doc/supplements/i386/timeFORCE386.t (modified) * doc/supplements/i386/version.texi (modified) * doc/supplements/i960/Makefile.am (modified) * doc/supplements/i960/bsp.t (modified) * doc/supplements/i960/callconv.t (modified) * doc/supplements/i960/cpumodel.t (modified) * doc/supplements/i960/cputable.t (modified) * doc/supplements/i960/fatalerr.t (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/i960/intr_NOTIMES.t (modified) * doc/supplements/i960/memmodel.t (modified) * doc/supplements/i960/preface.texi (modified) * doc/supplements/i960/stamp-vti (modified) * doc/supplements/i960/timeCVME961.t (modified) * doc/supplements/i960/version.texi (modified) * doc/supplements/m68k/Makefile.am (modified) * doc/supplements/m68k/bsp.t (modified) * doc/supplements/m68k/callconv.t (modified) * doc/supplements/m68k/cpumodel.t (modified) * doc/supplements/m68k/cputable.t (modified) * doc/supplements/m68k/fatalerr.t (modified) * doc/supplements/m68k/intr_NOTIMES.t (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/m68k/memmodel.t (modified) * doc/supplements/m68k/preface.texi (modified) * doc/supplements/m68k/stamp-vti (modified) * doc/supplements/m68k/timeMVME136.t (modified) * doc/supplements/m68k/timedata.t (modified) * doc/supplements/m68k/version.texi (modified) * doc/supplements/mips64orion/Makefile.am (modified) * doc/supplements/mips64orion/bsp.t (modified) * doc/supplements/mips64orion/callconv.t (modified) * doc/supplements/mips64orion/cpumodel.t (modified) * doc/supplements/mips64orion/cputable.t (modified) * doc/supplements/mips64orion/fatalerr.t (modified) * doc/supplements/mips64orion/intr_NOTIMES.t (modified) * doc/supplements/mips64orion/memmodel.t (modified) * doc/supplements/mips64orion/mips64orion.texi (modified) * doc/supplements/mips64orion/preface.texi (modified) * doc/supplements/mips64orion/stamp-vti (modified) * doc/supplements/mips64orion/timeBSP.t (modified) * doc/supplements/mips64orion/version.texi (modified) * doc/supplements/powerpc/Makefile.am (modified) * doc/supplements/powerpc/bsp.t (modified) * doc/supplements/powerpc/callconv.t (modified) * doc/supplements/powerpc/cpumodel.t (modified) * doc/supplements/powerpc/cputable.t (modified) * doc/supplements/powerpc/fatalerr.t (modified) * doc/supplements/powerpc/intr_NOTIMES.t (modified) * doc/supplements/powerpc/memmodel.t (modified) * doc/supplements/powerpc/powerpc.texi (modified) * doc/supplements/powerpc/preface.texi (modified) * doc/supplements/powerpc/stamp-vti (modified) * doc/supplements/powerpc/timeDMV177.t (modified) * doc/supplements/powerpc/timePSIM.t (modified) * doc/supplements/powerpc/version.texi (modified) * doc/supplements/sh/Makefile.am (modified) * doc/supplements/sh/bsp.t (modified) * doc/supplements/sh/callconv.t (modified) * doc/supplements/sh/cpumodel.t (modified) * doc/supplements/sh/cputable.t (modified) * doc/supplements/sh/fatalerr.t (modified) * doc/supplements/sh/intr_NOTIMES.t (modified) * doc/supplements/sh/memmodel.t (modified) * doc/supplements/sh/preface.texi (modified) * doc/supplements/sh/sh.texi (modified) * doc/supplements/sh/stamp-vti (modified) * doc/supplements/sh/timeBSP.t (modified) * doc/supplements/sh/version.texi (modified) * doc/supplements/sparc/Makefile.am (modified) * doc/supplements/sparc/bsp.t (modified) * doc/supplements/sparc/callconv.t (modified) * doc/supplements/sparc/cpumodel.t (modified) * doc/supplements/sparc/cputable.t (modified) * doc/supplements/sparc/fatalerr.t (modified) * doc/supplements/sparc/intr_NOTIMES.t (modified) * doc/supplements/sparc/memmodel.t (modified) * doc/supplements/sparc/preface.texi (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/supplements/sparc/stamp-vti (modified) * doc/supplements/sparc/timeERC32.t (modified) * doc/supplements/sparc/version.texi (modified) * doc/supplements/template/Makefile.am (modified) * doc/supplements/template/bsp.t (modified) * doc/supplements/template/callconv.t (modified) * doc/supplements/template/cpumodel.t (modified) * doc/supplements/template/cputable.t (modified) * doc/supplements/template/fatalerr.t (modified) * doc/supplements/template/intr_NOTIMES.t (modified) * doc/supplements/template/memmodel.t (modified) * doc/supplements/template/preface.texi (modified) * doc/supplements/template/stamp-vti (modified) * doc/supplements/template/template.texi (modified) * doc/supplements/template/timeBSP.t (modified) * doc/supplements/template/version.texi (modified) * doc/tools/bmenu/Makefile.am (modified) * doc/tools/bmenu/address.h (modified) * doc/tools/bmenu/address.inl (modified) * doc/tools/bmenu/base.h (modified) * doc/tools/bmenu/bmenu2.c (modified) * doc/tools/bmenu/chain.c (modified) * doc/tools/bmenu/chain.h (modified) * doc/tools/bmenu/chain.inl (modified) * doc/tools/bmenu/isr.h (modified) * doc/tools/bmenu/system.h (modified) * doc/tools/pdl2texi/Makefile.am (modified) * doc/tools/src2html/Makefile.am (modified) * doc/tools/texi2www/Makefile.am (modified) * doc/tools/texi2www/texi2www (modified) * doc/tools/texi2www/texi2www.texi (modified) * doc/user/Makefile.am (modified) * doc/user/bsp.t (modified) * doc/user/c_user.texi (modified) * doc/user/clock.t (modified) * doc/user/concepts.t (modified) * doc/user/conf.t (modified) * doc/user/datatypes.t (modified) * doc/user/dirstat.texi (modified) * doc/user/dpmem.t (modified) * doc/user/event.t (modified) * doc/user/example.texi (modified) * doc/user/fatal.t (modified) * doc/user/glossary.texi (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/overview.t (modified) * doc/user/part.t (modified) * doc/user/preface.texi (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/stamp-vti (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) * doc/user/version.texi (modified) 2001-01-17 Joel Sherrill * SUPPORT, ... Tue, 09 May 2000 21:34:46 GMT Joel Sherrill [dd960070] * doc/user/task.t (modified) Added comment on RTEMS_DEFAULT_MODE. Mon, 08 May 2000 16:15:04 GMT Joel Sherrill [d5f2eec] * doc/user/task.t (modified) Fixed type so constant would have "RTEMS_" in front of it. Thu, 04 May 2000 19:45:17 GMT Joel Sherrill [adee5979] * doc/FAQ/debug.t (modified) * doc/TODO (modified) * doc/networking/testing.t (modified) * doc/posix_users/message.t (modified) * doc/posix_users/semaphores.t (modified) * doc/started/Makefile.am (modified) * doc/started/buildc.t (modified) * doc/started/buildrt.t (modified) * doc/started/intro.t (modified) * doc/started/nt.t (modified) * doc/started/require.t (modified) * doc/started/started.texi (modified) * doc/started/tversions.texi (modified) * doc/started_ada/buildada.t (modified) * doc/started_ada/require.t (modified) * doc/started_ada/tversions.texi (modified) * doc/user/clock.t (modified) * doc/user/concepts.t (modified) * doc/user/conf.t (modified) * doc/user/event.t (modified) * doc/user/example.texi (modified) * doc/user/fatal.t (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/rtmon.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) Numerous changes based on comments from Stephan Wilms ... Mon, 01 May 2000 20:08:58 GMT Joel Sherrill [da874de] * doc/user/task.t (modified) A bit more explanation for task variables per Eric Norum ... Tue, 29 Feb 2000 14:07:38 GMT Joel Sherrill [6f645ff] * doc/user/task.t (modified) Eric Norum spotted this sentence where it said preemption had to be ... Fri, 18 Feb 2000 14:12:16 GMT Joel Sherrill [9b10d22] * doc/user/task.t (modified) Fixed typo. Thu, 27 Jan 2000 14:40:00 GMT Joel Sherrill [e26ce93] * doc/user/task.t (modified) Added note from Ian Lance Taylor . Sun, 23 Jan 2000 19:06:09 GMT Joel Sherrill [b5a31d4] * doc/user/task.t (modified) Added rtems_task_variable_get from Eric Norum. Sun, 23 Jan 2000 18:59:17 GMT Joel Sherrill [a6900508] * doc/user/task.t (modified) Updated to reflect changing to void * on task variables by Eric ... Tue, 16 Nov 1999 19:50:56 GMT Joel Sherrill [0660b4f8] * doc/FAQ/FAQ.texi (modified) * doc/FAQ/Makefile (modified) * doc/FAQ/basic.t (modified) * doc/FAQ/bsp.t (modified) * doc/FAQ/concepts.t (modified) * doc/FAQ/debug.t (modified) * doc/FAQ/embeddedinfo.t (modified) * doc/FAQ/freesw.t (modified) * doc/FAQ/hwdebugaids.t (modified) * doc/FAQ/tools.t (modified) * doc/ada_user/Makefile (modified) * doc/ada_user/ada_user.texi (modified) * doc/ada_user/example.texi (modified) * doc/bsp_howto/Makefile (modified) * doc/bsp_howto/adaintr.t (modified) * doc/bsp_howto/analog.t (modified) * doc/bsp_howto/bsp_howto.texi (modified) * doc/bsp_howto/clock.t (modified) * doc/bsp_howto/console.t (modified) * doc/bsp_howto/discrete.t (modified) * doc/bsp_howto/init.t (modified) * doc/bsp_howto/intro.t (modified) * doc/bsp_howto/linkcmds.t (modified) * doc/bsp_howto/makefiles.t (modified) * doc/bsp_howto/nvmem.t (modified) * doc/bsp_howto/rtc.t (modified) * doc/bsp_howto/shmsupp.t (modified) * doc/bsp_howto/support.t (modified) * doc/bsp_howto/target.t (modified) * doc/bsp_howto/timer.t (modified) * doc/common/cpright.texi (modified) * doc/common/setup.texi (modified) * doc/common/timemac.texi (modified) * doc/common/timetbl.t (modified) * doc/common/timing.t (modified) * doc/common/wksheets.t (modified) * doc/develenv/Makefile (modified) * doc/develenv/compile.texi (modified) * doc/develenv/develenv.texi (modified) * doc/develenv/direct.texi (modified) * doc/develenv/intro.texi (modified) * doc/develenv/sample.texi (modified) * doc/develenv/utils.texi (modified) * doc/filesystem/Makefile (modified) * doc/filesystem/filesystem.texi (modified) * doc/filesystem/fsrequirements.t (modified) * doc/filesystem/imfs.t (modified) * doc/filesystem/init.t (modified) * doc/filesystem/miniimfs.t (modified) * doc/filesystem/mounting.t (modified) * doc/filesystem/patheval.t (modified) * doc/filesystem/preface.texi (modified) * doc/filesystem/syscalls.t (modified) * doc/filesystem/tftp.t (modified) * doc/itron3.0/Makefile (modified) * doc/itron3.0/itron.texi (modified) * doc/networking/Makefile (modified) * doc/networking/driver.t (modified) * doc/networking/networkapp.t (modified) * doc/networking/networking.texi (modified) * doc/networking/networktasks.t (modified) * doc/networking/preface.texi (modified) * doc/networking/servers.t (modified) * doc/networking/testing.t (modified) * doc/new_chapters/Makefile (modified) * doc/new_chapters/adminiface.t (modified) * doc/new_chapters/base.t (modified) * doc/new_chapters/confspace.t (modified) * doc/new_chapters/cpuuse.t (modified) * doc/new_chapters/dumpcontrol.t (modified) * doc/new_chapters/error.t (modified) * doc/new_chapters/eventlog.t (modified) * doc/new_chapters/gen_section (modified) * doc/new_chapters/monitor.t (modified) * doc/new_chapters/new_chapters.texi (modified) * doc/new_chapters/rtmonuse.t (modified) * doc/new_chapters/stackchk.t (modified) * doc/porting/Makefile (modified) * doc/porting/codetuning.t (modified) * doc/porting/cpuinit.t (modified) * doc/porting/cpumodels.t (modified) * doc/porting/developtools.t (modified) * doc/porting/idlethread.t (modified) * doc/porting/interrupts.t (modified) * doc/porting/miscellaneous.t (modified) * doc/porting/porting.texi (modified) * doc/porting/preface.texi (modified) * doc/porting/prioritybitmap.t (modified) * doc/porting/sourcecode.t (modified) * doc/porting/taskcontext.t (modified) * doc/posix1003.1/Makefile (modified) * doc/posix1003.1/ch01.t (modified) * doc/posix1003.1/ch02.t (modified) * doc/posix1003.1/ch03.t (modified) * doc/posix1003.1/ch04.t (modified) * doc/posix1003.1/ch05.t (modified) * doc/posix1003.1/ch06.t (modified) * doc/posix1003.1/ch07.t (modified) * doc/posix1003.1/ch08.t (modified) * doc/posix1003.1/ch09.t (modified) * doc/posix1003.1/ch10.t (modified) * doc/posix1003.1/ch11.t (modified) * doc/posix1003.1/ch12.t (modified) * doc/posix1003.1/ch13.t (modified) * doc/posix1003.1/ch14.t (modified) * doc/posix1003.1/ch15.t (modified) * doc/posix1003.1/ch16.t (modified) * doc/posix1003.1/ch17.t (modified) * doc/posix1003.1/ch18.t (modified) * doc/posix1003.1/posix1003_1.texi (modified) * doc/posix1003.1/preface.texi (modified) * doc/posix_users/Makefile (modified) * doc/posix_users/cancel.t (modified) * doc/posix_users/clock.t (modified) * doc/posix_users/cond.t (modified) * doc/posix_users/cspecific.t (modified) * doc/posix_users/device.t (modified) * doc/posix_users/files.t (modified) * doc/posix_users/io.t (modified) * doc/posix_users/key.t (modified) * doc/posix_users/memorymgmt.t (modified) * doc/posix_users/mutex.t (modified) * doc/posix_users/posix_users.texi (modified) * doc/posix_users/preface.texi (modified) * doc/posix_users/procenv.t (modified) * doc/posix_users/process.t (modified) * doc/posix_users/sched.t (modified) * doc/posix_users/signal.t (modified) * doc/posix_users/status.t (modified) * doc/posix_users/systemdb.t (modified) * doc/posix_users/thread.t (modified) * doc/relnotes/Makefile (modified) * doc/relnotes/install.texi (modified) * doc/relnotes/intro.texi (modified) * doc/relnotes/probrep.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/relnotes/status.texi (modified) * doc/rgdb_specs/Makefile (modified) * doc/rgdb_specs/rgdb_specs.texi (modified) * doc/rtems_gdb/Makefile (modified) * doc/rtems_gdb/commands.t (modified) * doc/rtems_gdb/example.t (modified) * doc/rtems_gdb/intro.t (modified) * doc/rtems_gdb/rtems_gdb.texi (modified) * doc/rtems_gdb/started.t (modified) * doc/rtems_gdb/swarch.t (modified) * doc/rtems_gdb/trouble.t (modified) * doc/src2html/Makefile (modified) * doc/started/Makefile (modified) * doc/started/buildc.t (modified) * doc/started/buildrt.t (modified) * doc/started/gdb.t (modified) * doc/started/intro.t (modified) * doc/started/nt.t (modified) * doc/started/require.t (modified) * doc/started/sample.t (modified) * doc/started/started.texi (modified) * doc/started/versions.texi (modified) * doc/started_ada/Makefile (modified) * doc/started_ada/buildada.t (modified) * doc/started_ada/buildrt.t (modified) * doc/started_ada/gdb.t (modified) * doc/started_ada/intro.t (modified) * doc/started_ada/require.t (modified) * doc/started_ada/sample.t (modified) * doc/started_ada/started_ada.texi (modified) * doc/started_ada/versions.texi (modified) * doc/supplements/hppa1_1/Makefile (modified) * doc/supplements/hppa1_1/bsp.t (modified) * doc/supplements/hppa1_1/callconv.t (modified) * doc/supplements/hppa1_1/cpumodel.t (modified) * doc/supplements/hppa1_1/cputable.t (modified) * doc/supplements/hppa1_1/fatalerr.t (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/hppa1_1/intr_NOTIMES.t (modified) * doc/supplements/hppa1_1/memmodel.t (modified) * doc/supplements/hppa1_1/preface.texi (modified) * doc/supplements/hppa1_1/timeSIMHPPA.t (modified) * doc/supplements/i386/Makefile (modified) * doc/supplements/i386/bsp.t (modified) * doc/supplements/i386/callconv.t (modified) * doc/supplements/i386/cpumodel.t (modified) * doc/supplements/i386/cputable.t (modified) * doc/supplements/i386/fatalerr.t (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i386/intr_NOTIMES.t (modified) * doc/supplements/i386/memmodel.t (modified) * doc/supplements/i386/preface.texi (modified) * doc/supplements/i386/timeFORCE386.t (modified) * doc/supplements/i960/Makefile (modified) * doc/supplements/i960/bsp.t (modified) * doc/supplements/i960/callconv.t (modified) * doc/supplements/i960/cpumodel.t (modified) * doc/supplements/i960/cputable.t (modified) * doc/supplements/i960/fatalerr.t (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/i960/intr_NOTIMES.t (modified) * doc/supplements/i960/memmodel.t (modified) * doc/supplements/i960/preface.texi (modified) * doc/supplements/i960/timeCVME961.t (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/m68k/bsp.t (modified) * doc/supplements/m68k/callconv.t (modified) * doc/supplements/m68k/cpumodel.t (modified) * doc/supplements/m68k/cputable.t (modified) * doc/supplements/m68k/fatalerr.t (modified) * doc/supplements/m68k/intr_NOTIMES.t (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/m68k/memmodel.t (modified) * doc/supplements/m68k/preface.texi (modified) * doc/supplements/m68k/timeMVME136.t (modified) * doc/supplements/m68k/timedata.t (modified) * doc/supplements/mips64orion/Makefile (modified) * doc/supplements/mips64orion/bsp.t (modified) * doc/supplements/mips64orion/callconv.t (modified) * doc/supplements/mips64orion/cpumodel.t (modified) * doc/supplements/mips64orion/cputable.t (modified) * doc/supplements/mips64orion/fatalerr.t (modified) * doc/supplements/mips64orion/intr_NOTIMES.t (modified) * doc/supplements/mips64orion/memmodel.t (modified) * doc/supplements/mips64orion/mips64orion.texi (modified) * doc/supplements/mips64orion/preface.texi (modified) * doc/supplements/mips64orion/timeBSP.t (modified) * doc/supplements/powerpc/Makefile (modified) * doc/supplements/powerpc/bsp.t (modified) * doc/supplements/powerpc/callconv.t (modified) * doc/supplements/powerpc/cpumodel.t (modified) * doc/supplements/powerpc/cputable.t (modified) * doc/supplements/powerpc/fatalerr.t (modified) * doc/supplements/powerpc/intr_NOTIMES.t (modified) * doc/supplements/powerpc/memmodel.t (modified) * doc/supplements/powerpc/powerpc.texi (modified) * doc/supplements/powerpc/preface.texi (modified) * doc/supplements/powerpc/timeDMV177.t (modified) * doc/supplements/powerpc/timePSIM.t (modified) * doc/supplements/sh/Makefile (modified) * doc/supplements/sh/bsp.t (modified) * doc/supplements/sh/callconv.t (modified) * doc/supplements/sh/cpumodel.t (modified) * doc/supplements/sh/cputable.t (modified) * doc/supplements/sh/fatalerr.t (modified) * doc/supplements/sh/intr_NOTIMES.t (modified) * doc/supplements/sh/memmodel.t (modified) * doc/supplements/sh/preface.texi (modified) * doc/supplements/sh/sh.texi (modified) * doc/supplements/sh/timeBSP.t (modified) * doc/supplements/sparc/Makefile (modified) * doc/supplements/sparc/bsp.t (modified) * doc/supplements/sparc/callconv.t (modified) * doc/supplements/sparc/cpumodel.t (modified) * doc/supplements/sparc/cputable.t (modified) * doc/supplements/sparc/fatalerr.t (modified) * doc/supplements/sparc/intr_NOTIMES.t (modified) * doc/supplements/sparc/memmodel.t (modified) * doc/supplements/sparc/preface.texi (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/supplements/sparc/timeERC32.t (modified) * doc/supplements/template/Makefile (modified) * doc/supplements/template/bsp.t (modified) * doc/supplements/template/callconv.t (modified) * doc/supplements/template/cpumodel.t (modified) * doc/supplements/template/cputable.t (modified) * doc/supplements/template/fatalerr.t (modified) * doc/supplements/template/intr_NOTIMES.t (modified) * doc/supplements/template/memmodel.t (modified) * doc/supplements/template/preface.texi (modified) * doc/supplements/template/template.texi (modified) * doc/supplements/template/timeBSP.t (modified) * doc/tools/bmenu/Makefile (modified) * doc/tools/bmenu/address.h (modified) * doc/tools/bmenu/address.inl (modified) * doc/tools/bmenu/base.h (modified) * doc/tools/bmenu/chain.c (modified) * doc/tools/bmenu/chain.h (modified) * doc/tools/bmenu/chain.inl (modified) * doc/tools/bmenu/isr.h (modified) * doc/tools/bmenu/main.c (modified) * doc/tools/bmenu/system.h (modified) * doc/tools/src2html/Makefile (modified) * doc/tools/texi2www/Makefile (modified) * doc/user/Makefile (modified) * doc/user/bsp.t (modified) * doc/user/c_user.texi (modified) * doc/user/clock.t (modified) * doc/user/concepts.t (modified) * doc/user/conf.t (modified) * doc/user/dirstat.texi (modified) * doc/user/dpmem.t (modified) * doc/user/event.t (modified) * doc/user/example.texi (modified) * doc/user/fatal.t (modified) * doc/user/glossary.texi (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/overview.t (modified) * doc/user/part.t (modified) * doc/user/preface.texi (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) Changed copyright date to 1999. Tue, 16 Nov 1999 18:28:20 GMT Joel Sherrill [dc2b337] * doc/user/Makefile (modified) * doc/user/task.t (modified) Added task variable services. Mon, 11 Oct 1999 19:03:05 GMT Joel Sherrill [169502e] * doc/user/Makefile (modified) * doc/user/bsp.t (modified) * doc/user/c_user.texi (modified) * doc/user/clock.t (modified) * doc/user/concepts.t (modified) * doc/user/conf.t (modified) * doc/user/dpmem.t (modified) * doc/user/event.t (modified) * doc/user/fatal.t (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/part.t (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) Turned on concept and function name indexing. Thu, 07 Oct 1999 16:26:13 GMT Joel Sherrill [5ad8673] * doc/user/task.t (modified) Added rtems_task_is_suspended. Fri, 01 Oct 1999 17:44:06 GMT Joel Sherrill [ed11cadf] * doc/FAQ/FAQ.texi (modified) * doc/FAQ/Makefile (modified) * doc/FAQ/basic.t (modified) * doc/FAQ/freesw.t (modified) * doc/Make.config (modified) * doc/Makefile (modified) * doc/ada_user/Makefile (modified) * doc/ada_user/ada_user.texi (modified) * doc/bsp_howto/Makefile (modified) * doc/bsp_howto/bsp_howto.texi (modified) * doc/bsp_howto/target.t (modified) * doc/develenv/Makefile (modified) * doc/develenv/develenv.texi (modified) * doc/networking/Makefile (modified) * doc/networking/networking.texi (modified) * doc/networking/preface.texi (modified) * doc/new_chapters/Makefile (modified) * doc/new_chapters/new_chapters.texi (modified) * doc/posix1003.1/Makefile (modified) * doc/posix1003.1/ch03.t (modified) * doc/posix1003.1/ch04.t (modified) * doc/posix1003.1/ch05.t (modified) * doc/posix1003.1/ch06.t (modified) * doc/posix1003.1/ch07.t (modified) * doc/posix1003.1/ch08.t (modified) * doc/posix1003.1/posix1003_1.texi (modified) * doc/posix_users/Makefile (modified) * doc/posix_users/files.t (modified) * doc/posix_users/io.t (modified) * doc/posix_users/posix_users.texi (modified) * doc/relnotes/Makefile (modified) * doc/relnotes/relnotes.texi (modified) * doc/rgdb_specs/Makefile (modified) * doc/rgdb_specs/rgdb_specs.texi (modified) * doc/rtems_gdb/Makefile (modified) * doc/rtems_gdb/rtems_gdb.texi (modified) * doc/src2html/Makefile (modified) * doc/started/Makefile (modified) * doc/started/buildc.t (modified) * doc/started/nt.t (modified) * doc/started/started.texi (modified) * doc/started_ada/Makefile (modified) * doc/started_ada/buildada.t (modified) * doc/started_ada/started_ada.texi (modified) * doc/supplements/hppa1_1/Makefile (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/i386/Makefile (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i960/Makefile (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/mips64orion/Makefile (modified) * doc/supplements/mips64orion/mips64orion.texi (modified) * doc/supplements/powerpc/Makefile (modified) * doc/supplements/powerpc/powerpc.texi (modified) * doc/supplements/sh/Makefile (modified) * doc/supplements/sh/sh.texi (modified) * doc/supplements/sparc/Makefile (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/supplements/template/Makefile (modified) * doc/supplements/template/template.texi (modified) * doc/tools/bmenu/main.c (modified) * doc/tools/pdl2texi/Makefile (modified) * doc/tools/pdl2texi/main.c (modified) * doc/tools/texi2www/Makefile (modified) * doc/tools/texi2www/texi2www (modified) * doc/tools/texi2www/texi2www.texi (modified) * doc/user/Makefile (modified) * doc/user/c_user.texi (modified) * doc/user/msg.t (modified) * doc/user/part.t (modified) * doc/user/rtmon.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) Numerous minor changes required to transition to the latest version ... Thu, 01 Jul 1999 23:06:29 GMT Joel Sherrill [2a6a029f] * doc/user/task.t (modified) Added error status for bad return pointer argument on ... Tue, 27 Oct 1998 21:29:30 GMT Joel Sherrill [b95914f] * doc/user/task.t (modified) Spacing. Thu, 02 Apr 1998 16:18:26 GMT Joel Sherrill [87ed029] * doc/user/c_user.texi (modified) * doc/user/clock.t (modified) * doc/user/dpmem.t (modified) * doc/user/event.t (modified) * doc/user/fatal.t (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/part.t (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) Added "findex" for all directive pages but it turns out that this ... Fri, 27 Mar 1998 18:53:17 GMT Joel Sherrill [20515fc] * doc/user/Makefile (modified) * doc/user/bsp.t (modified) * doc/user/clock.t (modified) * doc/user/concepts.t (modified) * doc/user/conf.t (modified) * doc/user/dirstat.texi (modified) * doc/user/dpmem.t (modified) * doc/user/event.t (modified) * doc/user/fatal.t (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/overview.t (modified) * doc/user/part.t (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) Nodes, menus, etc are automatically generated now Fri, 27 Mar 1998 16:47:53 GMT Joel Sherrill [75e22db] * doc/user/bsp.t (modified) * doc/user/clock.t (modified) * doc/user/conf.t (modified) * doc/user/dpmem.t (modified) * doc/user/event.t (modified) * doc/user/example.texi (modified) * doc/user/fatal.t (modified) * doc/user/glossary.texi (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/part.t (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) Completed sweep adding directive and constant prefixes. Fri, 27 Mar 1998 13:24:52 GMT Joel Sherrill [f331481c] * doc/user/dpmem.t (modified) * doc/user/event.t (modified) * doc/user/fatal.t (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/part.t (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) Conditionally adding RTEMS_ and rtems_ prefixes. Fri, 27 Mar 1998 13:04:02 GMT Joel Sherrill [a3a7527] * doc/user/c_user.texi (modified) * doc/user/event.t (modified) * doc/user/intr.t (modified) * doc/user/msg.t (modified) * doc/user/region.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) Attempting to add variable so that in C all constants start with ... Fri, 06 Feb 1998 14:14:30 GMT Joel Sherrill [1e524995] * doc/HELP.html (modified) * doc/ada_user/Makefile (modified) * doc/ada_user/ada_user.texi (modified) * doc/ada_user/example.texi (modified) * doc/common/cpright.texi (modified) * doc/common/setup.texi (modified) * doc/common/timemac.texi (modified) * doc/common/timetbl.t (modified) * doc/common/timing.texi (modified) * doc/common/wksheets.t (modified) * doc/develenv/Makefile (modified) * doc/develenv/compile.texi (modified) * doc/develenv/develenv.texi (modified) * doc/develenv/direct.texi (modified) * doc/develenv/intro.texi (modified) * doc/develenv/sample.texi (modified) * doc/develenv/utils.texi (modified) * doc/new_chapters/Makefile (modified) * doc/new_chapters/base.texi (modified) * doc/new_chapters/clock.texi (modified) * doc/new_chapters/cond.texi (modified) * doc/new_chapters/key.texi (modified) * doc/new_chapters/mutex.texi (modified) * doc/new_chapters/posix_test_plan.texi (modified) * doc/new_chapters/preface.texi (modified) * doc/new_chapters/sched.texi (modified) * doc/new_chapters/signal.texi (modified) * doc/new_chapters/thread.texi (modified) * doc/posix_users/Makefile (modified) * doc/posix_users/base.texi (modified) * doc/posix_users/clock.texi (modified) * doc/posix_users/cond.texi (modified) * doc/posix_users/key.texi (modified) * doc/posix_users/mutex.texi (modified) * doc/posix_users/posix_test_plan.texi (modified) * doc/posix_users/preface.texi (modified) * doc/posix_users/sched.texi (modified) * doc/posix_users/signal.texi (modified) * doc/posix_users/thread.texi (modified) * doc/relnotes/Makefile (modified) * doc/relnotes/install.texi (modified) * doc/relnotes/intro.texi (modified) * doc/relnotes/probrep.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/relnotes/status.texi (modified) * doc/rtems.html (modified) * doc/rtems_footer.html (modified) * doc/supplements/hppa1_1/Makefile (modified) * doc/supplements/hppa1_1/bsp.t (modified) * doc/supplements/hppa1_1/bsp.texi (modified) * doc/supplements/hppa1_1/callconv.t (modified) * doc/supplements/hppa1_1/callconv.texi (modified) * doc/supplements/hppa1_1/cpumodel.t (modified) * doc/supplements/hppa1_1/cpumodel.texi (modified) * doc/supplements/hppa1_1/cputable.t (modified) * doc/supplements/hppa1_1/cputable.texi (modified) * doc/supplements/hppa1_1/fatalerr.t (modified) * doc/supplements/hppa1_1/fatalerr.texi (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/hppa1_1/intr.t (modified) * doc/supplements/hppa1_1/intr_NOTIMES.t (modified) * doc/supplements/hppa1_1/memmodel.t (modified) * doc/supplements/hppa1_1/memmodel.texi (modified) * doc/supplements/hppa1_1/preface.texi (modified) * doc/supplements/hppa1_1/timedata.t (modified) * doc/supplements/i386/Makefile (modified) * doc/supplements/i386/bsp.t (modified) * doc/supplements/i386/bsp.texi (modified) * doc/supplements/i386/callconv.t (modified) * doc/supplements/i386/callconv.texi (modified) * doc/supplements/i386/cpumodel.t (modified) * doc/supplements/i386/cpumodel.texi (modified) * doc/supplements/i386/cputable.t (modified) * doc/supplements/i386/cputable.texi (modified) * doc/supplements/i386/fatalerr.t (modified) * doc/supplements/i386/fatalerr.texi (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i386/intr.t (modified) * doc/supplements/i386/intr_NOTIMES.t (modified) * doc/supplements/i386/memmodel.t (modified) * doc/supplements/i386/memmodel.texi (modified) * doc/supplements/i386/preface.texi (modified) * doc/supplements/i386/timeFORCE386.t (modified) * doc/supplements/i386/timedata.t (modified) * doc/supplements/i960/Makefile (modified) * doc/supplements/i960/bsp.t (modified) * doc/supplements/i960/bsp.texi (modified) * doc/supplements/i960/callconv.t (modified) * doc/supplements/i960/callconv.texi (modified) * doc/supplements/i960/cpumodel.t (modified) * doc/supplements/i960/cpumodel.texi (modified) * doc/supplements/i960/cputable.t (modified) * doc/supplements/i960/cputable.texi (modified) * doc/supplements/i960/fatalerr.t (modified) * doc/supplements/i960/fatalerr.texi (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/i960/intr.t (modified) * doc/supplements/i960/intr_NOTIMES.t (modified) * doc/supplements/i960/memmodel.t (modified) * doc/supplements/i960/memmodel.texi (modified) * doc/supplements/i960/preface.texi (modified) * doc/supplements/i960/timeCVME961.t (modified) * doc/supplements/i960/timedata.t (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/m68k/bsp.t (modified) * doc/supplements/m68k/callconv.t (modified) * doc/supplements/m68k/cpumodel.t (modified) * doc/supplements/m68k/cputable.t (modified) * doc/supplements/m68k/fatalerr.t (modified) * doc/supplements/m68k/intr_NOTIMES.t (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/m68k/memmodel.t (modified) * doc/supplements/m68k/preface.texi (modified) * doc/supplements/m68k/timeMVME136.t (modified) * doc/supplements/m68k/timedata.t (modified) * doc/supplements/powerpc/Makefile (modified) * doc/supplements/powerpc/bsp.t (modified) * doc/supplements/powerpc/bsp.texi (modified) * doc/supplements/powerpc/callconv.t (modified) * doc/supplements/powerpc/callconv.texi (modified) * doc/supplements/powerpc/cpumodel.t (modified) * doc/supplements/powerpc/cpumodel.texi (modified) * doc/supplements/powerpc/cputable.t (modified) * doc/supplements/powerpc/cputable.texi (modified) * doc/supplements/powerpc/fatalerr.t (modified) * doc/supplements/powerpc/fatalerr.texi (modified) * doc/supplements/powerpc/intr.t (modified) * doc/supplements/powerpc/intr_NOTIMES.t (modified) * doc/supplements/powerpc/memmodel.t (modified) * doc/supplements/powerpc/memmodel.texi (modified) * doc/supplements/powerpc/powerpc.texi (modified) * doc/supplements/powerpc/preface.texi (modified) * doc/supplements/powerpc/timePSIM.t (modified) * doc/supplements/powerpc/timedata.t (modified) * doc/supplements/sparc/Makefile (modified) * doc/supplements/sparc/bsp.t (modified) * doc/supplements/sparc/bsp.texi (modified) * doc/supplements/sparc/callconv.t (modified) * doc/supplements/sparc/callconv.texi (modified) * doc/supplements/sparc/cpumodel.t (modified) * doc/supplements/sparc/cpumodel.texi (modified) * doc/supplements/sparc/cputable.t (modified) * doc/supplements/sparc/cputable.texi (modified) * doc/supplements/sparc/fatalerr.t (modified) * doc/supplements/sparc/fatalerr.texi (modified) * doc/supplements/sparc/intr.t (modified) * doc/supplements/sparc/intr_NOTIMES.t (modified) * doc/supplements/sparc/memmodel.t (modified) * doc/supplements/sparc/memmodel.texi (modified) * doc/supplements/sparc/preface.texi (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/supplements/sparc/timeERC32.t (modified) * doc/supplements/sparc/timedata.t (modified) * doc/tools/bmenu/Makefile (modified) * doc/tools/bmenu/address.h (modified) * doc/tools/bmenu/address.inl (modified) * doc/tools/bmenu/base.h (modified) * doc/tools/bmenu/chain.c (modified) * doc/tools/bmenu/chain.h (modified) * doc/tools/bmenu/chain.inl (modified) * doc/tools/bmenu/isr.h (modified) * doc/tools/bmenu/main.c (modified) * doc/tools/bmenu/system.h (modified) * doc/user/Makefile (modified) * doc/user/bsp.t (modified) * doc/user/c_user.texi (modified) * doc/user/clock.t (modified) * doc/user/concepts.t (modified) * doc/user/conf.t (modified) * doc/user/dirstat.texi (modified) * doc/user/dpmem.t (modified) * doc/user/event.t (modified) * doc/user/example.texi (modified) * doc/user/fatal.t (modified) * doc/user/glossary.texi (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/overview.t (modified) * doc/user/part.t (modified) * doc/user/preface.texi (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) Updated copyrights Mon, 04 Aug 1997 20:05:48 GMT Joel Sherrill [1ca951ce] * doc/user/event.t (modified) * doc/user/msg.t (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/sem.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) Added information based on comments from Katsu Shibuya. Wed, 04 Jun 1997 18:32:07 GMT Joel Sherrill [139b2e4a] * doc/Make.config (modified) * doc/README (modified) * doc/ada_user/Makefile (modified) * doc/ada_user/ada_user.texi (modified) * doc/ada_user/example.texi (modified) * doc/common/cpright.texi (modified) * doc/common/setup.texi (modified) * doc/common/timemac.texi (modified) * doc/common/timetbl.t (modified) * doc/common/timing.texi (modified) * doc/common/wksheets.t (modified) * doc/develenv/Makefile (modified) * doc/develenv/compile.texi (modified) * doc/develenv/develenv.texi (modified) * doc/develenv/direct.texi (modified) * doc/develenv/intro.texi (modified) * doc/develenv/sample.texi (modified) * doc/develenv/utils.texi (modified) * doc/import_ami_txt (modified) * doc/new_chapters/Makefile (modified) * doc/new_chapters/base.texi (modified) * doc/new_chapters/clock.texi (modified) * doc/new_chapters/cond.texi (modified) * doc/new_chapters/key.texi (modified) * doc/new_chapters/mutex.texi (modified) * doc/new_chapters/posix_test_plan.texi (modified) * doc/new_chapters/preface.texi (modified) * doc/new_chapters/sched.texi (modified) * doc/new_chapters/signal.texi (modified) * doc/new_chapters/thread.texi (modified) * doc/posix_users/Makefile (modified) * doc/posix_users/base.texi (modified) * doc/posix_users/clock.texi (modified) * doc/posix_users/cond.texi (modified) * doc/posix_users/key.texi (modified) * doc/posix_users/mutex.texi (modified) * doc/posix_users/posix_test_plan.texi (modified) * doc/posix_users/preface.texi (modified) * doc/posix_users/sched.texi (modified) * doc/posix_users/signal.texi (modified) * doc/posix_users/thread.texi (modified) * doc/relnotes/Makefile (modified) * doc/relnotes/install.texi (modified) * doc/relnotes/intro.texi (modified) * doc/relnotes/probrep.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/relnotes/status.texi (modified) * doc/supplements/hppa1_1/Makefile (modified) * doc/supplements/hppa1_1/SIMHPPA_TIMES (modified) * doc/supplements/hppa1_1/TIMES (modified) * doc/supplements/hppa1_1/bsp.t (modified) * doc/supplements/hppa1_1/bsp.texi (modified) * doc/supplements/hppa1_1/callconv.t (modified) * doc/supplements/hppa1_1/callconv.texi (modified) * doc/supplements/hppa1_1/cpumodel.t (modified) * doc/supplements/hppa1_1/cpumodel.texi (modified) * doc/supplements/hppa1_1/cputable.t (modified) * doc/supplements/hppa1_1/cputable.texi (modified) * doc/supplements/hppa1_1/fatalerr.t (modified) * doc/supplements/hppa1_1/fatalerr.texi (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/hppa1_1/intr.t (modified) * doc/supplements/hppa1_1/intr_NOTIMES.t (modified) * doc/supplements/hppa1_1/memmodel.t (modified) * doc/supplements/hppa1_1/memmodel.texi (modified) * doc/supplements/hppa1_1/preface.texi (modified) * doc/supplements/hppa1_1/timedata.t (modified) * doc/supplements/i386/FORCE386_TIMES (modified) * doc/supplements/i386/Makefile (modified) * doc/supplements/i386/bsp.t (modified) * doc/supplements/i386/bsp.texi (modified) * doc/supplements/i386/callconv.t (modified) * doc/supplements/i386/callconv.texi (modified) * doc/supplements/i386/cpumodel.t (modified) * doc/supplements/i386/cpumodel.texi (modified) * doc/supplements/i386/cputable.t (modified) * doc/supplements/i386/cputable.texi (modified) * doc/supplements/i386/fatalerr.t (modified) * doc/supplements/i386/fatalerr.texi (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i386/intr.t (modified) * doc/supplements/i386/intr_NOTIMES.t (modified) * doc/supplements/i386/memmodel.t (modified) * doc/supplements/i386/memmodel.texi (modified) * doc/supplements/i386/preface.texi (modified) * doc/supplements/i386/timeFORCE386.t (modified) * doc/supplements/i386/timedata.t (modified) * doc/supplements/i960/CVME961_TIMES (modified) * doc/supplements/i960/Makefile (modified) * doc/supplements/i960/bsp.t (modified) * doc/supplements/i960/bsp.texi (modified) * doc/supplements/i960/callconv.t (modified) * doc/supplements/i960/callconv.texi (modified) * doc/supplements/i960/cpumodel.t (modified) * doc/supplements/i960/cpumodel.texi (modified) * doc/supplements/i960/cputable.t (modified) * doc/supplements/i960/cputable.texi (modified) * doc/supplements/i960/fatalerr.t (modified) * doc/supplements/i960/fatalerr.texi (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/i960/intr.t (modified) * doc/supplements/i960/intr_NOTIMES.t (modified) * doc/supplements/i960/memmodel.t (modified) * doc/supplements/i960/memmodel.texi (modified) * doc/supplements/i960/preface.texi (modified) * doc/supplements/i960/timeCVME961.t (modified) * doc/supplements/i960/timedata.t (modified) * doc/supplements/m68k/MVME136_TIMES (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/m68k/bsp.t (modified) * doc/supplements/m68k/callconv.t (modified) * doc/supplements/m68k/cpumodel.t (modified) * doc/supplements/m68k/cputable.t (modified) * doc/supplements/m68k/fatalerr.t (modified) * doc/supplements/m68k/intr_NOTIMES.t (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/m68k/memmodel.t (modified) * doc/supplements/m68k/preface.texi (modified) * doc/supplements/m68k/timeMVME136.t (modified) * doc/supplements/m68k/timedata.t (modified) * doc/supplements/sparc/ERC32_TIMES (modified) * doc/supplements/sparc/Makefile (modified) * doc/supplements/sparc/SIS_TIMES (modified) * doc/supplements/sparc/bsp.t (modified) * doc/supplements/sparc/bsp.texi (modified) * doc/supplements/sparc/callconv.t (modified) * doc/supplements/sparc/callconv.texi (modified) * doc/supplements/sparc/cpumodel.t (modified) * doc/supplements/sparc/cpumodel.texi (modified) * doc/supplements/sparc/cputable.t (modified) * doc/supplements/sparc/cputable.texi (modified) * doc/supplements/sparc/fatalerr.t (modified) * doc/supplements/sparc/fatalerr.texi (modified) * doc/supplements/sparc/intr.t (modified) * doc/supplements/sparc/intr_NOTIMES.t (modified) * doc/supplements/sparc/memmodel.t (modified) * doc/supplements/sparc/memmodel.texi (modified) * doc/supplements/sparc/preface.texi (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/supplements/sparc/timeERC32.t (modified) * doc/supplements/sparc/timedata.t (modified) * doc/tools/bmenu/Makefile (modified) * doc/tools/bmenu/address.h (modified) * doc/tools/bmenu/address.inl (modified) * doc/tools/bmenu/base.h (modified) * doc/tools/bmenu/chain.c (modified) * doc/tools/bmenu/chain.h (modified) * doc/tools/bmenu/chain.inl (modified) * doc/tools/bmenu/isr.h (modified) * doc/tools/bmenu/main.c (modified) * doc/tools/bmenu/system.h (modified) * doc/tools/update (modified) * doc/tools/word-replace (modified) * doc/user/Makefile (modified) * doc/user/bsp.t (modified) * doc/user/c_user.texi (modified) * doc/user/clock.t (modified) * doc/user/concepts.t (modified) * doc/user/conf.t (modified) * doc/user/dirstat.texi (modified) * doc/user/dpmem.t (modified) * doc/user/event.t (modified) * doc/user/example.texi (modified) * doc/user/fatal.t (modified) * doc/user/glossary.texi (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/overview.t (modified) * doc/user/part.t (modified) * doc/user/preface.texi (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) added CVS Id string Wed, 04 Jun 1997 13:04:36 GMT Joel Sherrill [7e8a1fc] * doc/rtems_footer.html (modified) * doc/rtems_header.html (modified) * doc/user/clock.t (modified) * doc/user/conf.t (modified) * doc/user/fatal.t (modified) * doc/user/glossary.texi (modified) * doc/user/intr.t (modified) * doc/user/overview.t (modified) * doc/user/rtmon.t (modified) * doc/user/task.t (modified) * doc/user/userext.t (modified) final corrections before 4.1.0 documentation freeze. Sat, 31 May 1997 15:55:10 GMT Joel Sherrill [a94c5a5d] * doc/new_chapters/posix_test_plan.texi (modified) * doc/posix_users/posix_test_plan.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/user/bsp.t (modified) * doc/user/c_user.texi (modified) * doc/user/clock.t (modified) * doc/user/conf.t (modified) * doc/user/dirstat.texi (modified) * doc/user/event.t (modified) * doc/user/fatal.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/overview.t (modified) * doc/user/part.t (modified) * doc/user/preface.texi (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) Changed bitwise OR's used to build up option and attribute sets to ... Thu, 29 May 1997 21:53:58 GMT Joel Sherrill [61389eac] * doc/user/c_user.texi (modified) * doc/user/clock.t (modified) * doc/user/concepts.t (modified) * doc/user/conf.t (modified) * doc/user/dpmem.t (modified) * doc/user/event.t (modified) * doc/user/fatal.t (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/overview.t (modified) * doc/user/part.t (modified) * doc/user/preface.texi (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) first cut at Ada bindings manual Tue, 27 May 1997 12:40:11 GMT Joel Sherrill [ae68ff0] * doc/HELP.html (added) * doc/Make.config (added) * doc/Makefile (added) * doc/README (added) * doc/archgrey.gif (added) * doc/common/cpright.texi (added) * doc/common/missing-arrow.gif (added) * doc/common/next-arrow.gif (added) * doc/common/oaronly.jpg (added) * doc/common/prev-arrow.gif (added) * doc/common/setup.texi (added) * doc/common/timemac.texi (added) * doc/common/timetbl.t (added) * doc/common/timing.texi (added) * doc/common/up-arrow.gif (added) * doc/common/wksheets.t (added) * doc/develenv/Makefile (added) * doc/develenv/compile.texi (added) * doc/develenv/develenv.texi (added) * doc/develenv/direct.texi (added) * doc/develenv/intro.texi (added) * doc/develenv/sample.texi (added) * doc/develenv/utils.texi (added) * doc/do_docs (added) * doc/import_ami_txt (added) * doc/new_chapters/Makefile (added) * doc/new_chapters/base.texi (added) * doc/new_chapters/clock.texi (added) * doc/new_chapters/cond.texi (added) * doc/new_chapters/key.texi (added) * doc/new_chapters/mutex.texi (added) * doc/new_chapters/posix_test_plan.texi (added) * doc/new_chapters/preface.texi (added) * doc/new_chapters/sched.texi (added) * doc/new_chapters/signal.texi (added) * doc/new_chapters/thread.texi (added) * doc/oaronly.jpg (added) * doc/posix_users/Makefile (added) * doc/posix_users/base.texi (added) * doc/posix_users/clock.texi (added) * doc/posix_users/cond.texi (added) * doc/posix_users/key.texi (added) * doc/posix_users/mutex.texi (added) * doc/posix_users/posix_test_plan.texi (added) * doc/posix_users/preface.texi (added) * doc/posix_users/sched.texi (added) * doc/posix_users/signal.texi (added) * doc/posix_users/thread.texi (added) * doc/relnotes/Makefile (added) * doc/relnotes/install.texi (added) * doc/relnotes/intro.texi (added) * doc/relnotes/probrep.texi (added) * doc/relnotes/relnotes.texi (added) * doc/relnotes/status.texi (added) * doc/rtems.html (added) * doc/rtems_footer.html (added) * doc/rtems_header.html (added) * doc/supplements/hppa1_1/Makefile (added) * doc/supplements/hppa1_1/SIMHPPA_TIMES (added) * doc/supplements/hppa1_1/TIMES (added) * doc/supplements/hppa1_1/bsp.t (added) * doc/supplements/hppa1_1/bsp.texi (added) * doc/supplements/hppa1_1/callconv.t (added) * doc/supplements/hppa1_1/callconv.texi (added) * doc/supplements/hppa1_1/cpumodel.t (added) * doc/supplements/hppa1_1/cpumodel.texi (added) * doc/supplements/hppa1_1/cputable.t (added) * doc/supplements/hppa1_1/cputable.texi (added) * doc/supplements/hppa1_1/fatalerr.t (added) * doc/supplements/hppa1_1/fatalerr.texi (added) * doc/supplements/hppa1_1/hppa1_1.texi (added) * doc/supplements/hppa1_1/intr.t (added) * doc/supplements/hppa1_1/intr_NOTIMES.t (added) * doc/supplements/hppa1_1/memmodel.t (added) * doc/supplements/hppa1_1/memmodel.texi (added) * doc/supplements/hppa1_1/preface.texi (added) * doc/supplements/hppa1_1/timedata.t (added) * doc/supplements/i386/FORCE386_TIMES (added) * doc/supplements/i386/Makefile (added) * doc/supplements/i386/bsp.t (added) * doc/supplements/i386/bsp.texi (added) * doc/supplements/i386/callconv.t (added) * doc/supplements/i386/callconv.texi (added) * doc/supplements/i386/cpumodel.t (added) * doc/supplements/i386/cpumodel.texi (added) * doc/supplements/i386/cputable.t (added) * doc/supplements/i386/cputable.texi (added) * doc/supplements/i386/fatalerr.t (added) * doc/supplements/i386/fatalerr.texi (added) * doc/supplements/i386/i386.texi (added) * doc/supplements/i386/intr.t (added) * doc/supplements/i386/intr_NOTIMES.t (added) * doc/supplements/i386/memmodel.t (added) * doc/supplements/i386/memmodel.texi (added) * doc/supplements/i386/preface.texi (added) * doc/supplements/i386/timeFORCE386.t (added) * doc/supplements/i386/timedata.t (added) * doc/supplements/i960/CVME961_TIMES (added) * doc/supplements/i960/Makefile (added) * doc/supplements/i960/bsp.t (added) * doc/supplements/i960/bsp.texi (added) * doc/supplements/i960/callconv.t (added) * doc/supplements/i960/callconv.texi (added) * doc/supplements/i960/cpumodel.t (added) * doc/supplements/i960/cpumodel.texi (added) * doc/supplements/i960/cputable.t (added) * doc/supplements/i960/cputable.texi (added) * doc/supplements/i960/fatalerr.t (added) * doc/supplements/i960/fatalerr.texi (added) * doc/supplements/i960/i960.texi (added) * doc/supplements/i960/intr.t (added) * doc/supplements/i960/intr_NOTIMES.t (added) * doc/supplements/i960/memmodel.t (added) * doc/supplements/i960/memmodel.texi (added) * doc/supplements/i960/preface.texi (added) * doc/supplements/i960/timeCVME961.t (added) * doc/supplements/i960/timedata.t (added) * doc/supplements/m68k/MVME136_TIMES (added) * doc/supplements/m68k/Makefile (added) * doc/supplements/m68k/bsp.t (added) * doc/supplements/m68k/callconv.t (added) * doc/supplements/m68k/cpumodel.t (added) * doc/supplements/m68k/cputable.t (added) * doc/supplements/m68k/fatalerr.t (added) * doc/supplements/m68k/intr_NOTIMES.t (added) * doc/supplements/m68k/m68k.texi (added) * doc/supplements/m68k/memmodel.t (added) * doc/supplements/m68k/preface.texi (added) * doc/supplements/m68k/timeMVME136.t (added) * doc/supplements/m68k/timedata.t (added) * doc/supplements/sparc/ERC32_TIMES (added) * doc/supplements/sparc/Makefile (added) * doc/supplements/sparc/SIS_TIMES (added) * doc/supplements/sparc/bsp.t (added) * doc/supplements/sparc/bsp.texi (added) * doc/supplements/sparc/callconv.t (added) * doc/supplements/sparc/callconv.texi (added) * doc/supplements/sparc/cpumodel.t (added) * doc/supplements/sparc/cpumodel.texi (added) * doc/supplements/sparc/cputable.t (added) * doc/supplements/sparc/cputable.texi (added) * doc/supplements/sparc/fatalerr.t (added) * doc/supplements/sparc/fatalerr.texi (added) * doc/supplements/sparc/intr.t (added) * doc/supplements/sparc/intr_NOTIMES.t (added) * doc/supplements/sparc/memmodel.t (added) * doc/supplements/sparc/memmodel.texi (added) * doc/supplements/sparc/preface.texi (added) * doc/supplements/sparc/sparc.texi (added) * doc/supplements/sparc/timeERC32.t (added) * doc/supplements/sparc/timedata.t (added) * doc/texinfo/texinfo.tex (added) * doc/tools/bmenu/Makefile (added) * doc/tools/bmenu/address.h (added) * doc/tools/bmenu/address.inl (added) * doc/tools/bmenu/base.h (added) * doc/tools/bmenu/bmenu (added) * doc/tools/bmenu/chain.c (added) * doc/tools/bmenu/chain.h (added) * doc/tools/bmenu/chain.inl (added) * doc/tools/bmenu/chain.o (added) * doc/tools/bmenu/isr.h (added) * doc/tools/bmenu/main.c (added) * doc/tools/bmenu/main.o (added) * doc/tools/bmenu/system.h (added) * doc/tools/update (added) * doc/tools/word-replace (added) * doc/user/Makefile (added) * doc/user/bsp.t (added) * doc/user/c_user.texi (added) * doc/user/clock.t (added) * doc/user/concepts.t (added) * doc/user/conf.t (added) * doc/user/dirstat.texi (added) * doc/user/dpmem.t (added) * doc/user/event.t (added) * doc/user/example.texi (added) * doc/user/fatal.t (added) * doc/user/glossary.texi (added) * doc/user/init.t (added) * doc/user/intr.t (added) * doc/user/io.t (added) * doc/user/mp.t (added) * doc/user/msg.t (added) * doc/user/overview.t (added) * doc/user/part.t (added) * doc/user/preface.texi (added) * doc/user/region.t (added) * doc/user/rtemsarc.gif (added) * doc/user/rtemspie.gif (added) * doc/user/rtmon.t (added) * doc/user/schedule.t (added) * doc/user/sem.t (added) * doc/user/signal.t (added) * doc/user/states.gif (added) * doc/user/task.t (added) * doc/user/timer.t (added) * doc/user/userext.t (added) Initial revision
