# # ChangeLog for doc/supplements/i386 in rtems # # Generated by Trac 1.2.1.dev0 # 05/21/24 02:46:36 Mon, 19 Oct 1998 21:46:32 GMT Joel Sherrill [03889c1] * doc/supplements/i386/Makefile (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/m68k/bsp.t (modified) * doc/supplements/m68k/callconv.t (modified) * doc/supplements/m68k/cpumodel.t (modified) * doc/supplements/m68k/cputable.t (modified) * doc/supplements/m68k/fatalerr.t (modified) * doc/supplements/m68k/intr_NOTIMES.t (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/m68k/memmodel.t (modified) * doc/supplements/m68k/timeMVME136.t (modified) * doc/supplements/powerpc/Makefile (modified) * doc/supplements/sparc/Makefile (modified) * doc/supplements/sparc/bsp.t (modified) * doc/supplements/sparc/callconv.t (modified) * doc/supplements/sparc/cpumodel.t (modified) * doc/supplements/sparc/cputable.t (modified) * doc/supplements/sparc/fatalerr.t (modified) * doc/supplements/sparc/intr_NOTIMES.t (modified) * doc/supplements/sparc/memmodel.t (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/supplements/template/Makefile (modified) All of the Supplemental manuals are now generated as automatically ... Mon, 19 Oct 1998 18:25:16 GMT Joel Sherrill [8eba470] * doc/supplements/i386/Makefile (modified) * doc/supplements/i386/bsp.t (modified) * doc/supplements/i386/bsp.texi (deleted) * doc/supplements/i386/callconv.t (modified) * doc/supplements/i386/callconv.texi (deleted) * doc/supplements/i386/cpumodel.t (modified) * doc/supplements/i386/cpumodel.texi (deleted) * doc/supplements/i386/cputable.t (modified) * doc/supplements/i386/cputable.texi (deleted) * doc/supplements/i386/fatalerr.t (modified) * doc/supplements/i386/fatalerr.texi (deleted) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i386/intr.t (deleted) * doc/supplements/i386/intr_NOTIMES.t (modified) * doc/supplements/i386/memmodel.t (modified) * doc/supplements/i386/memmodel.texi (deleted) * doc/supplements/i386/timeFORCE386.t (modified) * doc/supplements/i386/timedata.t (deleted) Nearly everything that can be is now automatically generated. Mon, 19 Oct 1998 17:17:42 GMT Joel Sherrill [e4f7860f] * doc/supplements/i386/Makefile (modified) * doc/supplements/i386/bsp.t (modified) * doc/supplements/i386/bsp.texi (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i386/timeFORCE386.t (modified) * doc/supplements/i386/timedata.t (modified) * doc/supplements/i960/Makefile (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/i960/timeCVME961.t (modified) * doc/supplements/i960/timedata.t (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/m68k/timeMVME136.t (modified) * doc/supplements/m68k/timedata.t (modified) * doc/supplements/powerpc/Makefile (modified) * doc/supplements/powerpc/powerpc.texi (modified) * doc/supplements/powerpc/timePSIM.t (modified) * doc/supplements/powerpc/timedata.t (modified) * doc/supplements/sparc/Makefile (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/supplements/sparc/timeERC32.t (modified) * doc/supplements/sparc/timedata.t (modified) Makefiles in much better shape even though not all files have ... Mon, 19 Oct 1998 15:06:22 GMT Joel Sherrill [c59eb61] * doc/supplements/hppa1_1/Makefile (modified) * doc/supplements/i386/Makefile (modified) * doc/supplements/i960/Makefile (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/powerpc/Makefile (modified) * doc/supplements/sparc/Makefile (modified) * doc/supplements/template/Makefile (modified) * doc/supplements/template/template.texi (modified) Worksheets now generated from a common file and the node info ... Mon, 12 Oct 1998 21:27:10 GMT Joel Sherrill [a1c57e4] * doc/supplements/hppa1_1/cputable.t (modified) * doc/supplements/hppa1_1/cputable.texi (modified) * doc/supplements/i386/cputable.t (modified) * doc/supplements/i386/cputable.texi (modified) * doc/supplements/i960/cputable.t (modified) * doc/supplements/i960/cputable.texi (modified) * doc/supplements/m68k/cputable.t (modified) * doc/supplements/powerpc/cputable.t (modified) * doc/supplements/powerpc/cputable.texi (modified) * doc/supplements/sparc/cputable.t (modified) * doc/supplements/sparc/cputable.texi (modified) Added idle_task_stack_size field to CPU Table. Thu, 13 Aug 1998 21:24:50 GMT Joel Sherrill [6ddf054] * doc/supplements/hppa1_1/SIMHPPA_TIMES (modified) * doc/supplements/hppa1_1/TIMES (modified) * doc/supplements/i386/FORCE386_TIMES (modified) * doc/supplements/i386/Makefile (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i386/timeFORCE386.t (modified) * doc/supplements/i386/timedata.t (modified) * doc/supplements/i960/CVME961_TIMES (modified) * doc/supplements/i960/Makefile (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/i960/timeCVME961.t (modified) * doc/supplements/i960/timedata.t (modified) * doc/supplements/m68k/MVME136_TIMES (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/m68k/timeMVME136.t (modified) * doc/supplements/m68k/timedata.t (modified) * doc/supplements/sparc/ERC32_TIMES (modified) * doc/supplements/sparc/SIS_TIMES (modified) Switched from presenting timing data based on CPU models to ... Thu, 13 Aug 1998 18:17:49 GMT Joel Sherrill [3e6d749] * doc/supplements/i386/cpumodel.t (modified) * doc/supplements/i386/cpumodel.texi (modified) Added bswap feature. Mon, 01 Jun 1998 15:14:36 GMT Joel Sherrill [3b0f7cc] * doc/supplements/i386/bsp.t (modified) * doc/supplements/i386/bsp.texi (modified) Added text from Erik Ivanenko describing ... Sat, 11 Apr 1998 15:20:22 GMT Joel Sherrill [2aaac528] * doc/supplements/hppa1_1/Makefile (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/i386/Makefile (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i386/timeFORCE386.t (modified) * doc/supplements/i386/timedata.t (modified) * doc/supplements/i960/Makefile (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/i960/timeCVME961.t (modified) * doc/supplements/i960/timedata.t (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/m68k/timeMVME136.t (modified) * doc/supplements/m68k/timedata.t (modified) * doc/supplements/powerpc/Makefile (modified) * doc/supplements/powerpc/powerpc.texi (modified) * doc/supplements/powerpc/timePSIM.t (modified) * doc/supplements/powerpc/timedata.t (modified) * doc/supplements/sparc/Makefile (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/supplements/sparc/timeERC32.t (modified) * doc/supplements/sparc/timedata.t (modified) Corrected paths after moving all supplements into a subdirectory. Mon, 30 Mar 1998 14:58:53 GMT Joel Sherrill [eff6983d] * doc/Make.config (modified) * doc/Makefile (modified) * doc/ada_user/Makefile (modified) * doc/develenv/Makefile (modified) * doc/new_chapters/Makefile (modified) * doc/posix1003.1/Makefile (modified) * doc/posix_users/Makefile (modified) * doc/relnotes/Makefile (modified) * doc/supplements/hppa1_1/Makefile (modified) * doc/supplements/i386/Makefile (modified) * doc/supplements/i960/Makefile (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/powerpc/Makefile (modified) * doc/supplements/sparc/Makefile (modified) * doc/user/Makefile (modified) Making the stanza right and improving the way the isntall directories ... Mon, 30 Mar 1998 14:42:11 GMT Joel Sherrill [ca0b18a1] * doc/Make.config (modified) * doc/ada_user/Makefile (modified) * doc/develenv/Makefile (modified) * doc/new_chapters/Makefile (modified) * doc/posix1003.1/Makefile (modified) * doc/posix_users/Makefile (modified) * doc/relnotes/Makefile (modified) * doc/supplements/hppa1_1/Makefile (modified) * doc/supplements/i386/Makefile (modified) * doc/supplements/i960/Makefile (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/powerpc/Makefile (modified) * doc/supplements/sparc/Makefile (modified) * doc/user/Makefile (modified) Corrected distribution levels for html Mon, 30 Mar 1998 14:27:11 GMT Joel Sherrill [3754660c] * doc/ada_user/Makefile (modified) * doc/develenv/Makefile (modified) * doc/new_chapters/Makefile (modified) * doc/posix1003.1/Makefile (modified) * doc/posix_users/Makefile (modified) * doc/relnotes/Makefile (modified) * doc/supplements/hppa1_1/Makefile (modified) * doc/supplements/i386/Makefile (modified) * doc/supplements/i960/Makefile (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/powerpc/Makefile (modified) * doc/supplements/sparc/Makefile (modified) * doc/user/Makefile (modified) Added distribution level to each manual Thu, 26 Mar 1998 20:30:52 GMT Joel Sherrill [8a8b7519] * doc/ada_user/ada_user.texi (modified) * doc/common/setup.texi (modified) * doc/develenv/develenv.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/rtems_footer.html (modified) * doc/rtems_header.html (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/powerpc/powerpc.texi (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/user/c_user.texi (modified) Added variables for dates and revision info Fri, 06 Feb 1998 14:14:30 GMT Joel Sherrill [1e524995] * doc/HELP.html (modified) * doc/ada_user/Makefile (modified) * doc/ada_user/ada_user.texi (modified) * doc/ada_user/example.texi (modified) * doc/common/cpright.texi (modified) * doc/common/setup.texi (modified) * doc/common/timemac.texi (modified) * doc/common/timetbl.t (modified) * doc/common/timing.texi (modified) * doc/common/wksheets.t (modified) * doc/develenv/Makefile (modified) * doc/develenv/compile.texi (modified) * doc/develenv/develenv.texi (modified) * doc/develenv/direct.texi (modified) * doc/develenv/intro.texi (modified) * doc/develenv/sample.texi (modified) * doc/develenv/utils.texi (modified) * doc/new_chapters/Makefile (modified) * doc/new_chapters/base.texi (modified) * doc/new_chapters/clock.texi (modified) * doc/new_chapters/cond.texi (modified) * doc/new_chapters/key.texi (modified) * doc/new_chapters/mutex.texi (modified) * doc/new_chapters/posix_test_plan.texi (modified) * doc/new_chapters/preface.texi (modified) * doc/new_chapters/sched.texi (modified) * doc/new_chapters/signal.texi (modified) * doc/new_chapters/thread.texi (modified) * doc/posix_users/Makefile (modified) * doc/posix_users/base.texi (modified) * doc/posix_users/clock.texi (modified) * doc/posix_users/cond.texi (modified) * doc/posix_users/key.texi (modified) * doc/posix_users/mutex.texi (modified) * doc/posix_users/posix_test_plan.texi (modified) * doc/posix_users/preface.texi (modified) * doc/posix_users/sched.texi (modified) * doc/posix_users/signal.texi (modified) * doc/posix_users/thread.texi (modified) * doc/relnotes/Makefile (modified) * doc/relnotes/install.texi (modified) * doc/relnotes/intro.texi (modified) * doc/relnotes/probrep.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/relnotes/status.texi (modified) * doc/rtems.html (modified) * doc/rtems_footer.html (modified) * doc/supplements/hppa1_1/Makefile (modified) * doc/supplements/hppa1_1/bsp.t (modified) * doc/supplements/hppa1_1/bsp.texi (modified) * doc/supplements/hppa1_1/callconv.t (modified) * doc/supplements/hppa1_1/callconv.texi (modified) * doc/supplements/hppa1_1/cpumodel.t (modified) * doc/supplements/hppa1_1/cpumodel.texi (modified) * doc/supplements/hppa1_1/cputable.t (modified) * doc/supplements/hppa1_1/cputable.texi (modified) * doc/supplements/hppa1_1/fatalerr.t (modified) * doc/supplements/hppa1_1/fatalerr.texi (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/hppa1_1/intr.t (modified) * doc/supplements/hppa1_1/intr_NOTIMES.t (modified) * doc/supplements/hppa1_1/memmodel.t (modified) * doc/supplements/hppa1_1/memmodel.texi (modified) * doc/supplements/hppa1_1/preface.texi (modified) * doc/supplements/hppa1_1/timedata.t (modified) * doc/supplements/i386/Makefile (modified) * doc/supplements/i386/bsp.t (modified) * doc/supplements/i386/bsp.texi (modified) * doc/supplements/i386/callconv.t (modified) * doc/supplements/i386/callconv.texi (modified) * doc/supplements/i386/cpumodel.t (modified) * doc/supplements/i386/cpumodel.texi (modified) * doc/supplements/i386/cputable.t (modified) * doc/supplements/i386/cputable.texi (modified) * doc/supplements/i386/fatalerr.t (modified) * doc/supplements/i386/fatalerr.texi (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i386/intr.t (modified) * doc/supplements/i386/intr_NOTIMES.t (modified) * doc/supplements/i386/memmodel.t (modified) * doc/supplements/i386/memmodel.texi (modified) * doc/supplements/i386/preface.texi (modified) * doc/supplements/i386/timeFORCE386.t (modified) * doc/supplements/i386/timedata.t (modified) * doc/supplements/i960/Makefile (modified) * doc/supplements/i960/bsp.t (modified) * doc/supplements/i960/bsp.texi (modified) * doc/supplements/i960/callconv.t (modified) * doc/supplements/i960/callconv.texi (modified) * doc/supplements/i960/cpumodel.t (modified) * doc/supplements/i960/cpumodel.texi (modified) * doc/supplements/i960/cputable.t (modified) * doc/supplements/i960/cputable.texi (modified) * doc/supplements/i960/fatalerr.t (modified) * doc/supplements/i960/fatalerr.texi (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/i960/intr.t (modified) * doc/supplements/i960/intr_NOTIMES.t (modified) * doc/supplements/i960/memmodel.t (modified) * doc/supplements/i960/memmodel.texi (modified) * doc/supplements/i960/preface.texi (modified) * doc/supplements/i960/timeCVME961.t (modified) * doc/supplements/i960/timedata.t (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/m68k/bsp.t (modified) * doc/supplements/m68k/callconv.t (modified) * doc/supplements/m68k/cpumodel.t (modified) * doc/supplements/m68k/cputable.t (modified) * doc/supplements/m68k/fatalerr.t (modified) * doc/supplements/m68k/intr_NOTIMES.t (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/m68k/memmodel.t (modified) * doc/supplements/m68k/preface.texi (modified) * doc/supplements/m68k/timeMVME136.t (modified) * doc/supplements/m68k/timedata.t (modified) * doc/supplements/powerpc/Makefile (modified) * doc/supplements/powerpc/bsp.t (modified) * doc/supplements/powerpc/bsp.texi (modified) * doc/supplements/powerpc/callconv.t (modified) * doc/supplements/powerpc/callconv.texi (modified) * doc/supplements/powerpc/cpumodel.t (modified) * doc/supplements/powerpc/cpumodel.texi (modified) * doc/supplements/powerpc/cputable.t (modified) * doc/supplements/powerpc/cputable.texi (modified) * doc/supplements/powerpc/fatalerr.t (modified) * doc/supplements/powerpc/fatalerr.texi (modified) * doc/supplements/powerpc/intr.t (modified) * doc/supplements/powerpc/intr_NOTIMES.t (modified) * doc/supplements/powerpc/memmodel.t (modified) * doc/supplements/powerpc/memmodel.texi (modified) * doc/supplements/powerpc/powerpc.texi (modified) * doc/supplements/powerpc/preface.texi (modified) * doc/supplements/powerpc/timePSIM.t (modified) * doc/supplements/powerpc/timedata.t (modified) * doc/supplements/sparc/Makefile (modified) * doc/supplements/sparc/bsp.t (modified) * doc/supplements/sparc/bsp.texi (modified) * doc/supplements/sparc/callconv.t (modified) * doc/supplements/sparc/callconv.texi (modified) * doc/supplements/sparc/cpumodel.t (modified) * doc/supplements/sparc/cpumodel.texi (modified) * doc/supplements/sparc/cputable.t (modified) * doc/supplements/sparc/cputable.texi (modified) * doc/supplements/sparc/fatalerr.t (modified) * doc/supplements/sparc/fatalerr.texi (modified) * doc/supplements/sparc/intr.t (modified) * doc/supplements/sparc/intr_NOTIMES.t (modified) * doc/supplements/sparc/memmodel.t (modified) * doc/supplements/sparc/memmodel.texi (modified) * doc/supplements/sparc/preface.texi (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/supplements/sparc/timeERC32.t (modified) * doc/supplements/sparc/timedata.t (modified) * doc/tools/bmenu/Makefile (modified) * doc/tools/bmenu/address.h (modified) * doc/tools/bmenu/address.inl (modified) * doc/tools/bmenu/base.h (modified) * doc/tools/bmenu/chain.c (modified) * doc/tools/bmenu/chain.h (modified) * doc/tools/bmenu/chain.inl (modified) * doc/tools/bmenu/isr.h (modified) * doc/tools/bmenu/main.c (modified) * doc/tools/bmenu/system.h (modified) * doc/user/Makefile (modified) * doc/user/bsp.t (modified) * doc/user/c_user.texi (modified) * doc/user/clock.t (modified) * doc/user/concepts.t (modified) * doc/user/conf.t (modified) * doc/user/dirstat.texi (modified) * doc/user/dpmem.t (modified) * doc/user/event.t (modified) * doc/user/example.texi (modified) * doc/user/fatal.t (modified) * doc/user/glossary.texi (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/overview.t (modified) * doc/user/part.t (modified) * doc/user/preface.texi (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) Updated copyrights Fri, 23 Jan 1998 16:57:29 GMT Joel Sherrill [173c59c8] * doc/Make.config (modified) * doc/ada_user/ada_user.texi (modified) * doc/develenv/develenv.texi (modified) * doc/new_chapters/clock.texi (modified) * doc/new_chapters/posix_test_plan.texi (modified) * doc/posix_users/clock.texi (modified) * doc/posix_users/posix_test_plan.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/powerpc/bsp.t (modified) * doc/supplements/powerpc/bsp.texi (modified) * doc/supplements/powerpc/callconv.t (modified) * doc/supplements/powerpc/callconv.texi (modified) * doc/supplements/powerpc/powerpc.texi (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/user/c_user.texi (modified) * doc/user/intr.t (modified) minor updates .. mostly version Mon, 04 Aug 1997 20:06:33 GMT Joel Sherrill [1f552a0] * doc/supplements/i386/Makefile (modified) Fixed wildcard in copy command. Thu, 31 Jul 1997 19:00:09 GMT Joel Sherrill [b930f43] * doc/supplements/i386/Makefile (modified) Corrected bug in Makefile Thu, 31 Jul 1997 18:45:58 GMT Joel Sherrill [db91520] * doc/ada_user/ada_user.texi (modified) * doc/develenv/develenv.texi (modified) * doc/develenv/direct.texi (modified) * doc/develenv/sample.texi (modified) * doc/do_docs (modified) * doc/new_chapters/posix_test_plan.texi (modified) * doc/posix_users/posix_test_plan.texi (modified) * doc/relnotes/install.texi (modified) * doc/relnotes/intro.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/relnotes/status.texi (modified) * doc/rtems.html (modified) * doc/supplements/i386/cputable.t (modified) * doc/supplements/i386/cputable.texi (modified) * doc/supplements/i960/cputable.t (modified) * doc/supplements/i960/cputable.texi (modified) * doc/supplements/m68k/cputable.t (modified) * doc/supplements/sparc/bsp.t (modified) * doc/supplements/sparc/bsp.texi (modified) * doc/supplements/sparc/cpumodel.t (modified) * doc/supplements/sparc/cpumodel.texi (modified) * doc/supplements/sparc/cputable.t (modified) * doc/supplements/sparc/cputable.texi (modified) corrected typos and changes LANGUAGE to RTEMS-LANGUAGE. Wed, 04 Jun 1997 18:32:07 GMT Joel Sherrill [139b2e4a] * doc/Make.config (modified) * doc/README (modified) * doc/ada_user/Makefile (modified) * doc/ada_user/ada_user.texi (modified) * doc/ada_user/example.texi (modified) * doc/common/cpright.texi (modified) * doc/common/setup.texi (modified) * doc/common/timemac.texi (modified) * doc/common/timetbl.t (modified) * doc/common/timing.texi (modified) * doc/common/wksheets.t (modified) * doc/develenv/Makefile (modified) * doc/develenv/compile.texi (modified) * doc/develenv/develenv.texi (modified) * doc/develenv/direct.texi (modified) * doc/develenv/intro.texi (modified) * doc/develenv/sample.texi (modified) * doc/develenv/utils.texi (modified) * doc/import_ami_txt (modified) * doc/new_chapters/Makefile (modified) * doc/new_chapters/base.texi (modified) * doc/new_chapters/clock.texi (modified) * doc/new_chapters/cond.texi (modified) * doc/new_chapters/key.texi (modified) * doc/new_chapters/mutex.texi (modified) * doc/new_chapters/posix_test_plan.texi (modified) * doc/new_chapters/preface.texi (modified) * doc/new_chapters/sched.texi (modified) * doc/new_chapters/signal.texi (modified) * doc/new_chapters/thread.texi (modified) * doc/posix_users/Makefile (modified) * doc/posix_users/base.texi (modified) * doc/posix_users/clock.texi (modified) * doc/posix_users/cond.texi (modified) * doc/posix_users/key.texi (modified) * doc/posix_users/mutex.texi (modified) * doc/posix_users/posix_test_plan.texi (modified) * doc/posix_users/preface.texi (modified) * doc/posix_users/sched.texi (modified) * doc/posix_users/signal.texi (modified) * doc/posix_users/thread.texi (modified) * doc/relnotes/Makefile (modified) * doc/relnotes/install.texi (modified) * doc/relnotes/intro.texi (modified) * doc/relnotes/probrep.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/relnotes/status.texi (modified) * doc/supplements/hppa1_1/Makefile (modified) * doc/supplements/hppa1_1/SIMHPPA_TIMES (modified) * doc/supplements/hppa1_1/TIMES (modified) * doc/supplements/hppa1_1/bsp.t (modified) * doc/supplements/hppa1_1/bsp.texi (modified) * doc/supplements/hppa1_1/callconv.t (modified) * doc/supplements/hppa1_1/callconv.texi (modified) * doc/supplements/hppa1_1/cpumodel.t (modified) * doc/supplements/hppa1_1/cpumodel.texi (modified) * doc/supplements/hppa1_1/cputable.t (modified) * doc/supplements/hppa1_1/cputable.texi (modified) * doc/supplements/hppa1_1/fatalerr.t (modified) * doc/supplements/hppa1_1/fatalerr.texi (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/hppa1_1/intr.t (modified) * doc/supplements/hppa1_1/intr_NOTIMES.t (modified) * doc/supplements/hppa1_1/memmodel.t (modified) * doc/supplements/hppa1_1/memmodel.texi (modified) * doc/supplements/hppa1_1/preface.texi (modified) * doc/supplements/hppa1_1/timedata.t (modified) * doc/supplements/i386/FORCE386_TIMES (modified) * doc/supplements/i386/Makefile (modified) * doc/supplements/i386/bsp.t (modified) * doc/supplements/i386/bsp.texi (modified) * doc/supplements/i386/callconv.t (modified) * doc/supplements/i386/callconv.texi (modified) * doc/supplements/i386/cpumodel.t (modified) * doc/supplements/i386/cpumodel.texi (modified) * doc/supplements/i386/cputable.t (modified) * doc/supplements/i386/cputable.texi (modified) * doc/supplements/i386/fatalerr.t (modified) * doc/supplements/i386/fatalerr.texi (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i386/intr.t (modified) * doc/supplements/i386/intr_NOTIMES.t (modified) * doc/supplements/i386/memmodel.t (modified) * doc/supplements/i386/memmodel.texi (modified) * doc/supplements/i386/preface.texi (modified) * doc/supplements/i386/timeFORCE386.t (modified) * doc/supplements/i386/timedata.t (modified) * doc/supplements/i960/CVME961_TIMES (modified) * doc/supplements/i960/Makefile (modified) * doc/supplements/i960/bsp.t (modified) * doc/supplements/i960/bsp.texi (modified) * doc/supplements/i960/callconv.t (modified) * doc/supplements/i960/callconv.texi (modified) * doc/supplements/i960/cpumodel.t (modified) * doc/supplements/i960/cpumodel.texi (modified) * doc/supplements/i960/cputable.t (modified) * doc/supplements/i960/cputable.texi (modified) * doc/supplements/i960/fatalerr.t (modified) * doc/supplements/i960/fatalerr.texi (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/i960/intr.t (modified) * doc/supplements/i960/intr_NOTIMES.t (modified) * doc/supplements/i960/memmodel.t (modified) * doc/supplements/i960/memmodel.texi (modified) * doc/supplements/i960/preface.texi (modified) * doc/supplements/i960/timeCVME961.t (modified) * doc/supplements/i960/timedata.t (modified) * doc/supplements/m68k/MVME136_TIMES (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/m68k/bsp.t (modified) * doc/supplements/m68k/callconv.t (modified) * doc/supplements/m68k/cpumodel.t (modified) * doc/supplements/m68k/cputable.t (modified) * doc/supplements/m68k/fatalerr.t (modified) * doc/supplements/m68k/intr_NOTIMES.t (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/m68k/memmodel.t (modified) * doc/supplements/m68k/preface.texi (modified) * doc/supplements/m68k/timeMVME136.t (modified) * doc/supplements/m68k/timedata.t (modified) * doc/supplements/sparc/ERC32_TIMES (modified) * doc/supplements/sparc/Makefile (modified) * doc/supplements/sparc/SIS_TIMES (modified) * doc/supplements/sparc/bsp.t (modified) * doc/supplements/sparc/bsp.texi (modified) * doc/supplements/sparc/callconv.t (modified) * doc/supplements/sparc/callconv.texi (modified) * doc/supplements/sparc/cpumodel.t (modified) * doc/supplements/sparc/cpumodel.texi (modified) * doc/supplements/sparc/cputable.t (modified) * doc/supplements/sparc/cputable.texi (modified) * doc/supplements/sparc/fatalerr.t (modified) * doc/supplements/sparc/fatalerr.texi (modified) * doc/supplements/sparc/intr.t (modified) * doc/supplements/sparc/intr_NOTIMES.t (modified) * doc/supplements/sparc/memmodel.t (modified) * doc/supplements/sparc/memmodel.texi (modified) * doc/supplements/sparc/preface.texi (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/supplements/sparc/timeERC32.t (modified) * doc/supplements/sparc/timedata.t (modified) * doc/tools/bmenu/Makefile (modified) * doc/tools/bmenu/address.h (modified) * doc/tools/bmenu/address.inl (modified) * doc/tools/bmenu/base.h (modified) * doc/tools/bmenu/chain.c (modified) * doc/tools/bmenu/chain.h (modified) * doc/tools/bmenu/chain.inl (modified) * doc/tools/bmenu/isr.h (modified) * doc/tools/bmenu/main.c (modified) * doc/tools/bmenu/system.h (modified) * doc/tools/update (modified) * doc/tools/word-replace (modified) * doc/user/Makefile (modified) * doc/user/bsp.t (modified) * doc/user/c_user.texi (modified) * doc/user/clock.t (modified) * doc/user/concepts.t (modified) * doc/user/conf.t (modified) * doc/user/dirstat.texi (modified) * doc/user/dpmem.t (modified) * doc/user/event.t (modified) * doc/user/example.texi (modified) * doc/user/fatal.t (modified) * doc/user/glossary.texi (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/overview.t (modified) * doc/user/part.t (modified) * doc/user/preface.texi (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) added CVS Id string Wed, 04 Jun 1997 16:06:28 GMT Joel Sherrill [25c5bee5] * doc/supplements/i386/i386.texi (modified) added CVS Id string Wed, 04 Jun 1997 15:15:59 GMT Joel Sherrill [bf56ac8] * doc/Make.config (modified) * doc/ada_user/ada_user.texi (modified) * doc/common/cpright.texi (modified) * doc/common/setup.texi (modified) * doc/develenv/develenv.texi (modified) * doc/new_chapters/posix_test_plan.texi (modified) * doc/posix_users/posix_test_plan.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/sparc/ERC32_TIMES (modified) * doc/supplements/sparc/SIS_TIMES (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/user/c_user.texi (modified) changed edition and version information Sat, 31 May 1997 15:55:10 GMT Joel Sherrill [a94c5a5d] * doc/new_chapters/posix_test_plan.texi (modified) * doc/posix_users/posix_test_plan.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/user/bsp.t (modified) * doc/user/c_user.texi (modified) * doc/user/clock.t (modified) * doc/user/conf.t (modified) * doc/user/dirstat.texi (modified) * doc/user/event.t (modified) * doc/user/fatal.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/overview.t (modified) * doc/user/part.t (modified) * doc/user/preface.texi (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) Changed bitwise OR's used to build up option and attribute sets to ... Fri, 30 May 1997 22:57:25 GMT Joel Sherrill [17a3c69] * doc/HELP.html (modified) * doc/develenv/sample.texi (modified) * doc/do_docs (modified) * doc/relnotes/intro.texi (modified) * doc/rtems.html (modified) * doc/supplements/hppa1_1/bsp.t (modified) * doc/supplements/hppa1_1/bsp.texi (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/i386/bsp.t (modified) * doc/supplements/i386/bsp.texi (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i960/bsp.t (modified) * doc/supplements/i960/bsp.texi (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/m68k/bsp.t (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/sparc/bsp.t (modified) * doc/supplements/sparc/bsp.texi (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/user/conf.t (modified) * doc/user/fatal.t (modified) * doc/user/intr.t (modified) * doc/user/overview.t (modified) fixed typos Wed, 28 May 1997 20:34:49 GMT Joel Sherrill [5c995d7] * doc/develenv/develenv.texi (modified) * doc/new_chapters/posix_test_plan.texi (modified) * doc/posix_users/posix_test_plan.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/user/c_user.texi (modified) version changed Wed, 28 May 1997 13:57:50 GMT Joel Sherrill [3dc513e] * doc/develenv/develenv.texi (modified) * doc/new_chapters/posix_test_plan.texi (modified) * doc/posix_users/posix_test_plan.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/i386/FORCE386_TIMES (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/m68k/MVME136_TIMES (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/sparc/ERC32_TIMES (modified) * doc/supplements/sparc/SIS_TIMES (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/user/c_user.texi (modified) 4.0.0 release docs Tue, 27 May 1997 12:40:11 GMT Joel Sherrill [ae68ff0] * doc/HELP.html (added) * doc/Make.config (added) * doc/Makefile (added) * doc/README (added) * doc/archgrey.gif (added) * doc/common/cpright.texi (added) * doc/common/missing-arrow.gif (added) * doc/common/next-arrow.gif (added) * doc/common/oaronly.jpg (added) * doc/common/prev-arrow.gif (added) * doc/common/setup.texi (added) * doc/common/timemac.texi (added) * doc/common/timetbl.t (added) * doc/common/timing.texi (added) * doc/common/up-arrow.gif (added) * doc/common/wksheets.t (added) * doc/develenv/Makefile (added) * doc/develenv/compile.texi (added) * doc/develenv/develenv.texi (added) * doc/develenv/direct.texi (added) * doc/develenv/intro.texi (added) * doc/develenv/sample.texi (added) * doc/develenv/utils.texi (added) * doc/do_docs (added) * doc/import_ami_txt (added) * doc/new_chapters/Makefile (added) * doc/new_chapters/base.texi (added) * doc/new_chapters/clock.texi (added) * doc/new_chapters/cond.texi (added) * doc/new_chapters/key.texi (added) * doc/new_chapters/mutex.texi (added) * doc/new_chapters/posix_test_plan.texi (added) * doc/new_chapters/preface.texi (added) * doc/new_chapters/sched.texi (added) * doc/new_chapters/signal.texi (added) * doc/new_chapters/thread.texi (added) * doc/oaronly.jpg (added) * doc/posix_users/Makefile (added) * doc/posix_users/base.texi (added) * doc/posix_users/clock.texi (added) * doc/posix_users/cond.texi (added) * doc/posix_users/key.texi (added) * doc/posix_users/mutex.texi (added) * doc/posix_users/posix_test_plan.texi (added) * doc/posix_users/preface.texi (added) * doc/posix_users/sched.texi (added) * doc/posix_users/signal.texi (added) * doc/posix_users/thread.texi (added) * doc/relnotes/Makefile (added) * doc/relnotes/install.texi (added) * doc/relnotes/intro.texi (added) * doc/relnotes/probrep.texi (added) * doc/relnotes/relnotes.texi (added) * doc/relnotes/status.texi (added) * doc/rtems.html (added) * doc/rtems_footer.html (added) * doc/rtems_header.html (added) * doc/supplements/hppa1_1/Makefile (added) * doc/supplements/hppa1_1/SIMHPPA_TIMES (added) * doc/supplements/hppa1_1/TIMES (added) * doc/supplements/hppa1_1/bsp.t (added) * doc/supplements/hppa1_1/bsp.texi (added) * doc/supplements/hppa1_1/callconv.t (added) * doc/supplements/hppa1_1/callconv.texi (added) * doc/supplements/hppa1_1/cpumodel.t (added) * doc/supplements/hppa1_1/cpumodel.texi (added) * doc/supplements/hppa1_1/cputable.t (added) * doc/supplements/hppa1_1/cputable.texi (added) * doc/supplements/hppa1_1/fatalerr.t (added) * doc/supplements/hppa1_1/fatalerr.texi (added) * doc/supplements/hppa1_1/hppa1_1.texi (added) * doc/supplements/hppa1_1/intr.t (added) * doc/supplements/hppa1_1/intr_NOTIMES.t (added) * doc/supplements/hppa1_1/memmodel.t (added) * doc/supplements/hppa1_1/memmodel.texi (added) * doc/supplements/hppa1_1/preface.texi (added) * doc/supplements/hppa1_1/timedata.t (added) * doc/supplements/i386/FORCE386_TIMES (added) * doc/supplements/i386/Makefile (added) * doc/supplements/i386/bsp.t (added) * doc/supplements/i386/bsp.texi (added) * doc/supplements/i386/callconv.t (added) * doc/supplements/i386/callconv.texi (added) * doc/supplements/i386/cpumodel.t (added) * doc/supplements/i386/cpumodel.texi (added) * doc/supplements/i386/cputable.t (added) * doc/supplements/i386/cputable.texi (added) * doc/supplements/i386/fatalerr.t (added) * doc/supplements/i386/fatalerr.texi (added) * doc/supplements/i386/i386.texi (added) * doc/supplements/i386/intr.t (added) * doc/supplements/i386/intr_NOTIMES.t (added) * doc/supplements/i386/memmodel.t (added) * doc/supplements/i386/memmodel.texi (added) * doc/supplements/i386/preface.texi (added) * doc/supplements/i386/timeFORCE386.t (added) * doc/supplements/i386/timedata.t (added) * doc/supplements/i960/CVME961_TIMES (added) * doc/supplements/i960/Makefile (added) * doc/supplements/i960/bsp.t (added) * doc/supplements/i960/bsp.texi (added) * doc/supplements/i960/callconv.t (added) * doc/supplements/i960/callconv.texi (added) * doc/supplements/i960/cpumodel.t (added) * doc/supplements/i960/cpumodel.texi (added) * doc/supplements/i960/cputable.t (added) * doc/supplements/i960/cputable.texi (added) * doc/supplements/i960/fatalerr.t (added) * doc/supplements/i960/fatalerr.texi (added) * doc/supplements/i960/i960.texi (added) * doc/supplements/i960/intr.t (added) * doc/supplements/i960/intr_NOTIMES.t (added) * doc/supplements/i960/memmodel.t (added) * doc/supplements/i960/memmodel.texi (added) * doc/supplements/i960/preface.texi (added) * doc/supplements/i960/timeCVME961.t (added) * doc/supplements/i960/timedata.t (added) * doc/supplements/m68k/MVME136_TIMES (added) * doc/supplements/m68k/Makefile (added) * doc/supplements/m68k/bsp.t (added) * doc/supplements/m68k/callconv.t (added) * doc/supplements/m68k/cpumodel.t (added) * doc/supplements/m68k/cputable.t (added) * doc/supplements/m68k/fatalerr.t (added) * doc/supplements/m68k/intr_NOTIMES.t (added) * doc/supplements/m68k/m68k.texi (added) * doc/supplements/m68k/memmodel.t (added) * doc/supplements/m68k/preface.texi (added) * doc/supplements/m68k/timeMVME136.t (added) * doc/supplements/m68k/timedata.t (added) * doc/supplements/sparc/ERC32_TIMES (added) * doc/supplements/sparc/Makefile (added) * doc/supplements/sparc/SIS_TIMES (added) * doc/supplements/sparc/bsp.t (added) * doc/supplements/sparc/bsp.texi (added) * doc/supplements/sparc/callconv.t (added) * doc/supplements/sparc/callconv.texi (added) * doc/supplements/sparc/cpumodel.t (added) * doc/supplements/sparc/cpumodel.texi (added) * doc/supplements/sparc/cputable.t (added) * doc/supplements/sparc/cputable.texi (added) * doc/supplements/sparc/fatalerr.t (added) * doc/supplements/sparc/fatalerr.texi (added) * doc/supplements/sparc/intr.t (added) * doc/supplements/sparc/intr_NOTIMES.t (added) * doc/supplements/sparc/memmodel.t (added) * doc/supplements/sparc/memmodel.texi (added) * doc/supplements/sparc/preface.texi (added) * doc/supplements/sparc/sparc.texi (added) * doc/supplements/sparc/timeERC32.t (added) * doc/supplements/sparc/timedata.t (added) * doc/texinfo/texinfo.tex (added) * doc/tools/bmenu/Makefile (added) * doc/tools/bmenu/address.h (added) * doc/tools/bmenu/address.inl (added) * doc/tools/bmenu/base.h (added) * doc/tools/bmenu/bmenu (added) * doc/tools/bmenu/chain.c (added) * doc/tools/bmenu/chain.h (added) * doc/tools/bmenu/chain.inl (added) * doc/tools/bmenu/chain.o (added) * doc/tools/bmenu/isr.h (added) * doc/tools/bmenu/main.c (added) * doc/tools/bmenu/main.o (added) * doc/tools/bmenu/system.h (added) * doc/tools/update (added) * doc/tools/word-replace (added) * doc/user/Makefile (added) * doc/user/bsp.t (added) * doc/user/c_user.texi (added) * doc/user/clock.t (added) * doc/user/concepts.t (added) * doc/user/conf.t (added) * doc/user/dirstat.texi (added) * doc/user/dpmem.t (added) * doc/user/event.t (added) * doc/user/example.texi (added) * doc/user/fatal.t (added) * doc/user/glossary.texi (added) * doc/user/init.t (added) * doc/user/intr.t (added) * doc/user/io.t (added) * doc/user/mp.t (added) * doc/user/msg.t (added) * doc/user/overview.t (added) * doc/user/part.t (added) * doc/user/preface.texi (added) * doc/user/region.t (added) * doc/user/rtemsarc.gif (added) * doc/user/rtemspie.gif (added) * doc/user/rtmon.t (added) * doc/user/schedule.t (added) * doc/user/sem.t (added) * doc/user/signal.t (added) * doc/user/states.gif (added) * doc/user/task.t (added) * doc/user/timer.t (added) * doc/user/userext.t (added) Initial revision
