# # ChangeLog for doc/posix_users/libm.t in rtems # # Generated by Trac 1.2.1.dev0 # 06/01/24 03:08:58 Thu, 17 Jan 2002 21:47:47 GMT Joel Sherrill [6449498] * doc/ChangeLog (modified) * doc/FAQ/FAQ.texi (modified) * doc/FAQ/Makefile.am (modified) * doc/FAQ/basic.t (modified) * doc/FAQ/bsp.t (modified) * doc/FAQ/build45.t (modified) * doc/FAQ/concepts.t (modified) * doc/FAQ/debug.t (modified) * doc/FAQ/embeddedinfo.t (modified) * doc/FAQ/endoftime.t (modified) * doc/FAQ/freesw.t (modified) * doc/FAQ/hwdebugaids.t (modified) * doc/FAQ/projects.t (modified) * doc/FAQ/stamp-vti (modified) * doc/FAQ/tools.t (modified) * doc/FAQ/version.texi (modified) * doc/HELP.html (modified) * doc/README (modified) * doc/SUPPORT (added) * doc/VERSION (modified) * doc/ada_user/Makefile.am (modified) * doc/ada_user/ada_user.texi (modified) * doc/ada_user/example.texi (modified) * doc/ada_user/stamp-vti (modified) * doc/ada_user/version.texi (modified) * doc/bsp_howto/Makefile.am (modified) * doc/bsp_howto/adaintr.t (modified) * doc/bsp_howto/analog.t (modified) * doc/bsp_howto/bsp_howto.texi (modified) * doc/bsp_howto/clock.t (modified) * doc/bsp_howto/console.t (modified) * doc/bsp_howto/discrete.t (modified) * doc/bsp_howto/init.t (modified) * doc/bsp_howto/intro.t (modified) * doc/bsp_howto/linkcmds.t (modified) * doc/bsp_howto/makefiles.t (modified) * doc/bsp_howto/nvmem.t (modified) * doc/bsp_howto/rtc.t (modified) * doc/bsp_howto/shmsupp.t (modified) * doc/bsp_howto/stamp-vti (modified) * doc/bsp_howto/support.t (modified) * doc/bsp_howto/target.t (modified) * doc/bsp_howto/timer.t (modified) * doc/bsp_howto/version.texi (modified) * doc/common/cpright.texi (modified) * doc/common/setup.texi (modified) * doc/common/timemac.texi (modified) * doc/common/timetbl.t (modified) * doc/common/timing.t (modified) * doc/common/wksheets.t (modified) * doc/configure.in (modified) * doc/develenv/Makefile.am (modified) * doc/develenv/compile.texi (modified) * doc/develenv/develenv.texi (modified) * doc/develenv/direct.texi (modified) * doc/develenv/intro.texi (modified) * doc/develenv/sample.texi (modified) * doc/develenv/stamp-vti (modified) * doc/develenv/utils.texi (modified) * doc/develenv/version.texi (modified) * doc/filesystem/Makefile.am (modified) * doc/filesystem/filesystem.texi (modified) * doc/filesystem/fsrequirements.t (modified) * doc/filesystem/imfs.t (modified) * doc/filesystem/init.t (modified) * doc/filesystem/miniimfs.t (modified) * doc/filesystem/mounting.t (modified) * doc/filesystem/patheval.t (modified) * doc/filesystem/preface.texi (modified) * doc/filesystem/stamp-vti (modified) * doc/filesystem/syscalls.t (modified) * doc/filesystem/tftp.t (modified) * doc/filesystem/version.texi (modified) * doc/gnu_docs/gen_docs (modified) * doc/gnu_docs/gnu_footer.html (modified) * doc/gnu_docs/index.html (modified) * doc/gnu_docs/refcard.html (modified) * doc/gnu_docs/rtems_tools_index.html (modified) * doc/index.html.in (modified) * doc/itron3.0/Makefile.am (modified) * doc/itron3.0/config.t (modified) * doc/itron3.0/eventflags.t (modified) * doc/itron3.0/fixedblock.t (modified) * doc/itron3.0/interrupt.t (modified) * doc/itron3.0/itron.texi (modified) * doc/itron3.0/mailbox.t (modified) * doc/itron3.0/memorypool.t (modified) * doc/itron3.0/msgbuffer.t (modified) * doc/itron3.0/network.t (modified) * doc/itron3.0/preface.texi (modified) * doc/itron3.0/rendezvous.t (modified) * doc/itron3.0/semaphore.t (modified) * doc/itron3.0/stamp-vti (modified) * doc/itron3.0/status.t (modified) * doc/itron3.0/task.t (modified) * doc/itron3.0/tasksync.t (modified) * doc/itron3.0/time.t (modified) * doc/itron3.0/version.texi (modified) * doc/networking/Makefile.am (modified) * doc/networking/driver.t (modified) * doc/networking/networkapp.t (modified) * doc/networking/networking.texi (modified) * doc/networking/networktasks.t (modified) * doc/networking/preface.texi (modified) * doc/networking/servers.t (modified) * doc/networking/stamp-vti (modified) * doc/networking/testing.t (modified) * doc/networking/version.texi (modified) * doc/new_chapters/Makefile.am (modified) * doc/new_chapters/adminiface.t (modified) * doc/new_chapters/base.t (modified) * doc/new_chapters/confspace.t (modified) * doc/new_chapters/cpuuse.t (modified) * doc/new_chapters/dumpcontrol.t (modified) * doc/new_chapters/error.t (modified) * doc/new_chapters/eventlog.t (modified) * doc/new_chapters/gen_section (modified) * doc/new_chapters/monitor.t (modified) * doc/new_chapters/new_chapters.texi (modified) * doc/new_chapters/rtmonuse.t (modified) * doc/new_chapters/stackchk.t (modified) * doc/new_chapters/stamp-vti (modified) * doc/new_chapters/version.texi (modified) * doc/porting/Makefile.am (modified) * doc/porting/codetuning.t (modified) * doc/porting/cpuinit.t (modified) * doc/porting/cpumodels.t (modified) * doc/porting/developtools.t (modified) * doc/porting/idlethread.t (modified) * doc/porting/interrupts.t (modified) * doc/porting/miscellaneous.t (modified) * doc/porting/porting.texi (modified) * doc/porting/preface.texi (modified) * doc/porting/prioritybitmap.t (modified) * doc/porting/sourcecode.t (modified) * doc/porting/stamp-vti (modified) * doc/porting/taskcontext.t (modified) * doc/porting/version.texi (modified) * doc/posix1003.1/Makefile.am (modified) * doc/posix1003.1/ch01.t (modified) * doc/posix1003.1/ch02.t (modified) * doc/posix1003.1/ch03.t (modified) * doc/posix1003.1/ch04.t (modified) * doc/posix1003.1/ch05.t (modified) * doc/posix1003.1/ch06.t (modified) * doc/posix1003.1/ch07.t (modified) * doc/posix1003.1/ch08.t (modified) * doc/posix1003.1/ch09.t (modified) * doc/posix1003.1/ch10.t (modified) * doc/posix1003.1/ch11.t (modified) * doc/posix1003.1/ch12.t (modified) * doc/posix1003.1/ch13.t (modified) * doc/posix1003.1/ch14.t (modified) * doc/posix1003.1/ch15.t (modified) * doc/posix1003.1/ch16.t (modified) * doc/posix1003.1/ch17.t (modified) * doc/posix1003.1/ch18.t (modified) * doc/posix1003.1/posix1003_1.texi (modified) * doc/posix1003.1/preface.texi (modified) * doc/posix1003.1/stamp-vti (modified) * doc/posix1003.1/version.texi (modified) * doc/posix_users/Makefile.am (modified) * doc/posix_users/cancel.t (modified) * doc/posix_users/clock.t (modified) * doc/posix_users/cond.t (modified) * doc/posix_users/cspecific.t (modified) * doc/posix_users/device.t (modified) * doc/posix_users/files.t (modified) * doc/posix_users/io.t (modified) * doc/posix_users/key.t (modified) * doc/posix_users/libc.t (modified) * doc/posix_users/libm.t (modified) * doc/posix_users/memorymgmt.t (modified) * doc/posix_users/message.t (modified) * doc/posix_users/mutex.t (modified) * doc/posix_users/posix_users.texi (modified) * doc/posix_users/preface.texi (modified) * doc/posix_users/procenv.t (modified) * doc/posix_users/process.t (modified) * doc/posix_users/sched.t (modified) * doc/posix_users/semaphores.t (modified) * doc/posix_users/signal.t (modified) * doc/posix_users/stamp-vti (modified) * doc/posix_users/status.t (modified) * doc/posix_users/systemdb.t (modified) * doc/posix_users/thread.t (modified) * doc/posix_users/version.texi (modified) * doc/project.am (modified) * doc/relnotes/Makefile.am (modified) * doc/relnotes/install.texi (modified) * doc/relnotes/intro.texi (modified) * doc/relnotes/probrep.texi (modified) * doc/relnotes/relnotes.texi (modified) * doc/relnotes/stamp-vti (modified) * doc/relnotes/status.texi (modified) * doc/relnotes/version.texi (modified) * doc/rgdb_specs/Makefile.am (modified) * doc/rgdb_specs/rgdb_specs.texi (modified) * doc/rgdb_specs/stamp-vti (modified) * doc/rgdb_specs/version.texi (modified) * doc/rtems_footer.html.in (modified) * doc/rtems_gdb/Makefile.am (modified) * doc/rtems_gdb/commands.t (modified) * doc/rtems_gdb/example.t (modified) * doc/rtems_gdb/intro.t (modified) * doc/rtems_gdb/rtems_gdb.texi (modified) * doc/rtems_gdb/stamp-vti (modified) * doc/rtems_gdb/started.t (modified) * doc/rtems_gdb/swarch.t (modified) * doc/rtems_gdb/trouble.t (modified) * doc/rtems_gdb/version.texi (modified) * doc/rtems_support.html.in (modified) * doc/src2html/Makefile.am (modified) * doc/started/Makefile.am (modified) * doc/started/binaries.t (modified) * doc/started/buildc.t (modified) * doc/started/buildrt.t (modified) * doc/started/gdb.t (modified) * doc/started/intro.t (modified) * doc/started/nextstep.t (modified) * doc/started/nt.t (modified) * doc/started/require.t (modified) * doc/started/sample.t (modified) * doc/started/stamp-vti (modified) * doc/started/started.texi (modified) * doc/started/tversions.texi (modified) * doc/started/version.texi (modified) * doc/started_ada/Makefile.am (modified) * doc/started_ada/buildada.t (modified) * doc/started_ada/gdb.t (modified) * doc/started_ada/intro.t (modified) * doc/started_ada/require.t (modified) * doc/started_ada/sample.t (modified) * doc/started_ada/stamp-vti (modified) * doc/started_ada/started_ada.texi (modified) * doc/started_ada/tversions.texi (modified) * doc/started_ada/version.texi (modified) * doc/supplements/hppa1_1/Makefile.am (modified) * doc/supplements/hppa1_1/bsp.t (modified) * doc/supplements/hppa1_1/callconv.t (modified) * doc/supplements/hppa1_1/cpumodel.t (modified) * doc/supplements/hppa1_1/cputable.t (modified) * doc/supplements/hppa1_1/fatalerr.t (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/hppa1_1/intr_NOTIMES.t (modified) * doc/supplements/hppa1_1/memmodel.t (modified) * doc/supplements/hppa1_1/preface.texi (modified) * doc/supplements/hppa1_1/stamp-vti (modified) * doc/supplements/hppa1_1/timeSIMHPPA.t (modified) * doc/supplements/hppa1_1/version.texi (modified) * doc/supplements/i386/Makefile.am (modified) * doc/supplements/i386/bsp.t (modified) * doc/supplements/i386/callconv.t (modified) * doc/supplements/i386/cpumodel.t (modified) * doc/supplements/i386/cputable.t (modified) * doc/supplements/i386/fatalerr.t (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i386/intr_NOTIMES.t (modified) * doc/supplements/i386/memmodel.t (modified) * doc/supplements/i386/preface.texi (modified) * doc/supplements/i386/stamp-vti (modified) * doc/supplements/i386/timeFORCE386.t (modified) * doc/supplements/i386/version.texi (modified) * doc/supplements/i960/Makefile.am (modified) * doc/supplements/i960/bsp.t (modified) * doc/supplements/i960/callconv.t (modified) * doc/supplements/i960/cpumodel.t (modified) * doc/supplements/i960/cputable.t (modified) * doc/supplements/i960/fatalerr.t (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/i960/intr_NOTIMES.t (modified) * doc/supplements/i960/memmodel.t (modified) * doc/supplements/i960/preface.texi (modified) * doc/supplements/i960/stamp-vti (modified) * doc/supplements/i960/timeCVME961.t (modified) * doc/supplements/i960/version.texi (modified) * doc/supplements/m68k/Makefile.am (modified) * doc/supplements/m68k/bsp.t (modified) * doc/supplements/m68k/callconv.t (modified) * doc/supplements/m68k/cpumodel.t (modified) * doc/supplements/m68k/cputable.t (modified) * doc/supplements/m68k/fatalerr.t (modified) * doc/supplements/m68k/intr_NOTIMES.t (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/m68k/memmodel.t (modified) * doc/supplements/m68k/preface.texi (modified) * doc/supplements/m68k/stamp-vti (modified) * doc/supplements/m68k/timeMVME136.t (modified) * doc/supplements/m68k/timedata.t (modified) * doc/supplements/m68k/version.texi (modified) * doc/supplements/mips64orion/Makefile.am (modified) * doc/supplements/mips64orion/bsp.t (modified) * doc/supplements/mips64orion/callconv.t (modified) * doc/supplements/mips64orion/cpumodel.t (modified) * doc/supplements/mips64orion/cputable.t (modified) * doc/supplements/mips64orion/fatalerr.t (modified) * doc/supplements/mips64orion/intr_NOTIMES.t (modified) * doc/supplements/mips64orion/memmodel.t (modified) * doc/supplements/mips64orion/mips64orion.texi (modified) * doc/supplements/mips64orion/preface.texi (modified) * doc/supplements/mips64orion/stamp-vti (modified) * doc/supplements/mips64orion/timeBSP.t (modified) * doc/supplements/mips64orion/version.texi (modified) * doc/supplements/powerpc/Makefile.am (modified) * doc/supplements/powerpc/bsp.t (modified) * doc/supplements/powerpc/callconv.t (modified) * doc/supplements/powerpc/cpumodel.t (modified) * doc/supplements/powerpc/cputable.t (modified) * doc/supplements/powerpc/fatalerr.t (modified) * doc/supplements/powerpc/intr_NOTIMES.t (modified) * doc/supplements/powerpc/memmodel.t (modified) * doc/supplements/powerpc/powerpc.texi (modified) * doc/supplements/powerpc/preface.texi (modified) * doc/supplements/powerpc/stamp-vti (modified) * doc/supplements/powerpc/timeDMV177.t (modified) * doc/supplements/powerpc/timePSIM.t (modified) * doc/supplements/powerpc/version.texi (modified) * doc/supplements/sh/Makefile.am (modified) * doc/supplements/sh/bsp.t (modified) * doc/supplements/sh/callconv.t (modified) * doc/supplements/sh/cpumodel.t (modified) * doc/supplements/sh/cputable.t (modified) * doc/supplements/sh/fatalerr.t (modified) * doc/supplements/sh/intr_NOTIMES.t (modified) * doc/supplements/sh/memmodel.t (modified) * doc/supplements/sh/preface.texi (modified) * doc/supplements/sh/sh.texi (modified) * doc/supplements/sh/stamp-vti (modified) * doc/supplements/sh/timeBSP.t (modified) * doc/supplements/sh/version.texi (modified) * doc/supplements/sparc/Makefile.am (modified) * doc/supplements/sparc/bsp.t (modified) * doc/supplements/sparc/callconv.t (modified) * doc/supplements/sparc/cpumodel.t (modified) * doc/supplements/sparc/cputable.t (modified) * doc/supplements/sparc/fatalerr.t (modified) * doc/supplements/sparc/intr_NOTIMES.t (modified) * doc/supplements/sparc/memmodel.t (modified) * doc/supplements/sparc/preface.texi (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/supplements/sparc/stamp-vti (modified) * doc/supplements/sparc/timeERC32.t (modified) * doc/supplements/sparc/version.texi (modified) * doc/supplements/template/Makefile.am (modified) * doc/supplements/template/bsp.t (modified) * doc/supplements/template/callconv.t (modified) * doc/supplements/template/cpumodel.t (modified) * doc/supplements/template/cputable.t (modified) * doc/supplements/template/fatalerr.t (modified) * doc/supplements/template/intr_NOTIMES.t (modified) * doc/supplements/template/memmodel.t (modified) * doc/supplements/template/preface.texi (modified) * doc/supplements/template/stamp-vti (modified) * doc/supplements/template/template.texi (modified) * doc/supplements/template/timeBSP.t (modified) * doc/supplements/template/version.texi (modified) * doc/tools/bmenu/Makefile.am (modified) * doc/tools/bmenu/address.h (modified) * doc/tools/bmenu/address.inl (modified) * doc/tools/bmenu/base.h (modified) * doc/tools/bmenu/bmenu2.c (modified) * doc/tools/bmenu/chain.c (modified) * doc/tools/bmenu/chain.h (modified) * doc/tools/bmenu/chain.inl (modified) * doc/tools/bmenu/isr.h (modified) * doc/tools/bmenu/system.h (modified) * doc/tools/pdl2texi/Makefile.am (modified) * doc/tools/src2html/Makefile.am (modified) * doc/tools/texi2www/Makefile.am (modified) * doc/tools/texi2www/texi2www (modified) * doc/tools/texi2www/texi2www.texi (modified) * doc/user/Makefile.am (modified) * doc/user/bsp.t (modified) * doc/user/c_user.texi (modified) * doc/user/clock.t (modified) * doc/user/concepts.t (modified) * doc/user/conf.t (modified) * doc/user/datatypes.t (modified) * doc/user/dirstat.texi (modified) * doc/user/dpmem.t (modified) * doc/user/event.t (modified) * doc/user/example.texi (modified) * doc/user/fatal.t (modified) * doc/user/glossary.texi (modified) * doc/user/init.t (modified) * doc/user/intr.t (modified) * doc/user/io.t (modified) * doc/user/mp.t (modified) * doc/user/msg.t (modified) * doc/user/overview.t (modified) * doc/user/part.t (modified) * doc/user/preface.texi (modified) * doc/user/region.t (modified) * doc/user/rtmon.t (modified) * doc/user/schedule.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/stamp-vti (modified) * doc/user/task.t (modified) * doc/user/timer.t (modified) * doc/user/userext.t (modified) * doc/user/version.texi (modified) 2001-01-17 Joel Sherrill * SUPPORT, ... Mon, 29 Nov 1999 15:11:20 GMT Joel Sherrill [61581a1] * doc/posix_users/gen_size_report (modified) * doc/posix_users/libc.t (modified) * doc/posix_users/libm.t (modified) Updated. Wed, 24 Nov 1999 19:03:06 GMT Joel Sherrill [0894d35d] * doc/posix_users/Makefile (modified) * doc/posix_users/libc.t (modified) * doc/posix_users/libm.t (added) * doc/posix_users/posix_users.texi (modified) Added chapter of list of routines provided by libm.
