# # ChangeLog for doc/posix1003.1 in rtems # # Generated by Trac 1.2.1.dev0 # 05/03/24 08:38:49 Thu, 07 Oct 1999 18:22:58 GMT Joel Sherrill [4fa74d8] * doc/new_chapters/Makefile (modified) * doc/porting/Makefile (modified) * doc/posix1003.1/Makefile (modified) * doc/posix_users/Makefile (modified) * doc/relnotes/Makefile (modified) * doc/rtems_gdb/Makefile (modified) * doc/supplements/hppa1_1/Makefile (modified) * doc/supplements/i386/Makefile (modified) * doc/supplements/i960/Makefile (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/mips64orion/Makefile (modified) * doc/supplements/powerpc/Makefile (modified) * doc/supplements/sh/Makefile (modified) * doc/supplements/sparc/Makefile (modified) * doc/supplements/template/Makefile (modified) * doc/tools/pdl2texi/Makefile (modified) * doc/tools/texi2www/Makefile (modified) Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the ... Fri, 01 Oct 1999 17:44:06 GMT Joel Sherrill [ed11cadf] * doc/FAQ/FAQ.texi (modified) * doc/FAQ/Makefile (modified) * doc/FAQ/basic.t (modified) * doc/FAQ/freesw.t (modified) * doc/Make.config (modified) * doc/Makefile (modified) * doc/ada_user/Makefile (modified) * doc/ada_user/ada_user.texi (modified) * doc/bsp_howto/Makefile (modified) * doc/bsp_howto/bsp_howto.texi (modified) * doc/bsp_howto/target.t (modified) * doc/develenv/Makefile (modified) * doc/develenv/develenv.texi (modified) * doc/networking/Makefile (modified) * doc/networking/networking.texi (modified) * doc/networking/preface.texi (modified) * doc/new_chapters/Makefile (modified) * doc/new_chapters/new_chapters.texi (modified) * doc/posix1003.1/Makefile (modified) * doc/posix1003.1/ch03.t (modified) * doc/posix1003.1/ch04.t (modified) * doc/posix1003.1/ch05.t (modified) * doc/posix1003.1/ch06.t (modified) * doc/posix1003.1/ch07.t (modified) * doc/posix1003.1/ch08.t (modified) * doc/posix1003.1/posix1003_1.texi (modified) * doc/posix_users/Makefile (modified) * doc/posix_users/files.t (modified) * doc/posix_users/io.t (modified) * doc/posix_users/posix_users.texi (modified) * doc/relnotes/Makefile (modified) * doc/relnotes/relnotes.texi (modified) * doc/rgdb_specs/Makefile (modified) * doc/rgdb_specs/rgdb_specs.texi (modified) * doc/rtems_gdb/Makefile (modified) * doc/rtems_gdb/rtems_gdb.texi (modified) * doc/src2html/Makefile (modified) * doc/started/Makefile (modified) * doc/started/buildc.t (modified) * doc/started/nt.t (modified) * doc/started/started.texi (modified) * doc/started_ada/Makefile (modified) * doc/started_ada/buildada.t (modified) * doc/started_ada/started_ada.texi (modified) * doc/supplements/hppa1_1/Makefile (modified) * doc/supplements/hppa1_1/hppa1_1.texi (modified) * doc/supplements/i386/Makefile (modified) * doc/supplements/i386/i386.texi (modified) * doc/supplements/i960/Makefile (modified) * doc/supplements/i960/i960.texi (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/m68k/m68k.texi (modified) * doc/supplements/mips64orion/Makefile (modified) * doc/supplements/mips64orion/mips64orion.texi (modified) * doc/supplements/powerpc/Makefile (modified) * doc/supplements/powerpc/powerpc.texi (modified) * doc/supplements/sh/Makefile (modified) * doc/supplements/sh/sh.texi (modified) * doc/supplements/sparc/Makefile (modified) * doc/supplements/sparc/sparc.texi (modified) * doc/supplements/template/Makefile (modified) * doc/supplements/template/template.texi (modified) * doc/tools/bmenu/main.c (modified) * doc/tools/pdl2texi/Makefile (modified) * doc/tools/pdl2texi/main.c (modified) * doc/tools/texi2www/Makefile (modified) * doc/tools/texi2www/texi2www (modified) * doc/tools/texi2www/texi2www.texi (modified) * doc/user/Makefile (modified) * doc/user/c_user.texi (modified) * doc/user/msg.t (modified) * doc/user/part.t (modified) * doc/user/rtmon.t (modified) * doc/user/sem.t (modified) * doc/user/signal.t (modified) * doc/user/task.t (modified) Numerous minor changes required to transition to the latest version ... Sat, 03 Jul 1999 17:13:27 GMT Joel Sherrill [28807e7] * doc/FAQ/Makefile (modified) * doc/Make.config (modified) * doc/ada_user/Makefile (modified) * doc/bsp_howto/Makefile (modified) * doc/develenv/Makefile (modified) * doc/index.html (modified) * doc/networking/Makefile (modified) * doc/new_chapters/Makefile (modified) * doc/posix1003.1/Makefile (modified) * doc/posix_users/Makefile (modified) * doc/relnotes/Makefile (modified) * doc/rgdb_specs/Makefile (modified) * doc/rtems_gdb/Makefile (modified) * doc/src2html/Makefile (modified) * doc/started/Makefile (modified) * doc/started_ada/Makefile (modified) * doc/supplements/hppa1_1/Makefile (modified) * doc/supplements/i386/Makefile (modified) * doc/supplements/i960/Makefile (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/mips64orion/Makefile (modified) * doc/supplements/powerpc/Makefile (modified) * doc/supplements/sh/Makefile (modified) * doc/supplements/sparc/Makefile (modified) * doc/supplements/template/Makefile (modified) * doc/tools/texi2www/Makefile (modified) * doc/user/Makefile (modified) Removed concept of distribution level. Sat, 03 Jul 1999 17:12:52 GMT Joel Sherrill [462648b9] * doc/posix1003.1/ch09.t (modified) Changed System Database routines to implemented. Wed, 10 Feb 1999 19:51:01 GMT Joel Sherrill [90fe8b3] * doc/posix1003.1/ch14.t (modified) Added POSIX timers. Thu, 19 Nov 1998 16:02:06 GMT Joel Sherrill [bc950e87] * doc/bsp_howto/Makefile (modified) * doc/bsp_howto/analog.t (modified) * doc/bsp_howto/bsp_howto.texi (modified) * doc/bsp_howto/clock.t (modified) * doc/bsp_howto/console.t (modified) * doc/bsp_howto/discrete.t (modified) * doc/bsp_howto/init.t (modified) * doc/bsp_howto/network.t (modified) * doc/bsp_howto/nvmem.t (modified) * doc/bsp_howto/rtc.t (modified) * doc/bsp_howto/shmsupp.t (modified) * doc/bsp_howto/support.t (modified) * doc/bsp_howto/timer.t (modified) * doc/networking/driver.t (modified) * doc/new_chapters/Makefile (modified) * doc/new_chapters/files.t (modified) * doc/new_chapters/gen_section (modified) * doc/new_chapters/posix_users.texi (modified) * doc/new_chapters/signal.t (modified) * doc/posix1003.1/Makefile (modified) * doc/posix1003.1/ch06.t (modified) * doc/posix1003.1/ch14.t (modified) * doc/started/Makefile (modified) * doc/supplements/hppa1_1/cputable.t (modified) * doc/supplements/i386/cputable.t (modified) * doc/supplements/i960/cputable.t (modified) * doc/supplements/m68k/cputable.t (modified) * doc/supplements/powerpc/cputable.t (modified) * doc/supplements/sparc/cputable.t (modified) * doc/supplements/template/cputable.t (modified) Applied updates from remote work while doing class. Thu, 29 Oct 1998 16:42:51 GMT Joel Sherrill [2119f9d] * doc/do_docs (modified) * doc/posix1003.1/ch06.t (modified) * doc/posix1003.1/ch14.t (modified) * doc/rtems_support.html (modified) making release docs Tue, 27 Oct 1998 20:40:22 GMT Joel Sherrill [829a116] * doc/posix1003.1/Makefile (modified) * doc/started_ada/Makefile (modified) Corrected 2nd invocation of texi2dvi so indices are built. Mon, 12 Oct 1998 21:25:52 GMT Joel Sherrill [5f4c109] * doc/posix1003.1/ch05.t (modified) * doc/posix1003.1/ch06.t (modified) Updated to reflect MG-10 IMFS effort. Thu, 13 Aug 1998 18:10:26 GMT Joel Sherrill [368d64ae] * doc/posix1003.1/ch07.t (modified) Updated. Fri, 22 May 1998 15:05:33 GMT Joel Sherrill [a31f064] * doc/posix1003.1/ch07.t (modified) Changed process group routines to unimplementable. Fri, 22 May 1998 15:02:53 GMT Joel Sherrill [9cc86e2] * doc/posix1003.1/ch07.t (modified) Updated after addition of some routines by Eric Norum. Fri, 03 Apr 1998 18:50:31 GMT Joel Sherrill [5ed1beb5] * doc/posix1003.1/ch02.t (modified) * doc/posix1003.1/ch07.t (modified) * doc/posix1003.1/ch08.t (modified) Fixed improperly named sections for info Fri, 03 Apr 1998 18:09:23 GMT Joel Sherrill [bda1a73] * doc/posix1003.1/ch08.t (modified) * doc/posix1003.1/ch14.t (modified) * doc/posix1003.1/ch16.t (modified) * doc/posix1003.1/ch18.t (modified) Completed pass at constants. Thu, 02 Apr 1998 20:02:27 GMT Joel Sherrill [180ca02] * doc/posix1003.1/ch02.t (modified) * doc/posix1003.1/ch03.t (modified) * doc/posix1003.1/ch04.t (modified) * doc/posix1003.1/ch05.t (modified) * doc/posix1003.1/ch06.t (modified) * doc/posix1003.1/ch07.t (modified) * doc/posix1003.1/ch08.t (modified) * doc/posix1003.1/ch10.t (modified) * doc/posix1003.1/ch11.t (modified) * doc/posix1003.1/ch12.t (modified) * doc/posix1003.1/ch13.t (modified) Added constants through ch13 Mon, 30 Mar 1998 14:58:53 GMT Joel Sherrill [eff6983d] * doc/Make.config (modified) * doc/Makefile (modified) * doc/ada_user/Makefile (modified) * doc/develenv/Makefile (modified) * doc/new_chapters/Makefile (modified) * doc/posix1003.1/Makefile (modified) * doc/posix_users/Makefile (modified) * doc/relnotes/Makefile (modified) * doc/supplements/hppa1_1/Makefile (modified) * doc/supplements/i386/Makefile (modified) * doc/supplements/i960/Makefile (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/powerpc/Makefile (modified) * doc/supplements/sparc/Makefile (modified) * doc/user/Makefile (modified) Making the stanza right and improving the way the isntall directories ... Mon, 30 Mar 1998 14:42:11 GMT Joel Sherrill [ca0b18a1] * doc/Make.config (modified) * doc/ada_user/Makefile (modified) * doc/develenv/Makefile (modified) * doc/new_chapters/Makefile (modified) * doc/posix1003.1/Makefile (modified) * doc/posix_users/Makefile (modified) * doc/relnotes/Makefile (modified) * doc/supplements/hppa1_1/Makefile (modified) * doc/supplements/i386/Makefile (modified) * doc/supplements/i960/Makefile (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/powerpc/Makefile (modified) * doc/supplements/sparc/Makefile (modified) * doc/user/Makefile (modified) Corrected distribution levels for html Mon, 30 Mar 1998 14:27:11 GMT Joel Sherrill [3754660c] * doc/ada_user/Makefile (modified) * doc/develenv/Makefile (modified) * doc/new_chapters/Makefile (modified) * doc/posix1003.1/Makefile (modified) * doc/posix_users/Makefile (modified) * doc/relnotes/Makefile (modified) * doc/supplements/hppa1_1/Makefile (modified) * doc/supplements/i386/Makefile (modified) * doc/supplements/i960/Makefile (modified) * doc/supplements/m68k/Makefile (modified) * doc/supplements/powerpc/Makefile (modified) * doc/supplements/sparc/Makefile (modified) * doc/user/Makefile (modified) Added distribution level to each manual Thu, 26 Mar 1998 20:30:01 GMT Joel Sherrill [9cb1040c] * doc/posix1003.1/preface.texi (modified) Enhanced. Thu, 26 Mar 1998 20:29:49 GMT Joel Sherrill [2e9dfd59] * doc/posix1003.1/Makefile (modified) Installed in partners subdirectory Wed, 18 Mar 1998 18:15:01 GMT Joel Sherrill [7331714] * doc/posix1003.1/Makefile (modified) * doc/posix1003.1/ch02.t (modified) * doc/posix1003.1/ch03.t (modified) * doc/posix1003.1/ch04.t (modified) * doc/posix1003.1/ch05.t (modified) * doc/posix1003.1/ch06.t (modified) * doc/posix1003.1/ch07.t (modified) * doc/posix1003.1/ch08.t (modified) * doc/posix1003.1/ch10.t (modified) * doc/posix1003.1/ch11.t (modified) * doc/posix1003.1/ch12.t (modified) * doc/posix1003.1/ch13.t (modified) * doc/posix1003.1/ch14.t (modified) * doc/posix1003.1/ch15.t (modified) * doc/posix1003.1/ch16.t (modified) * doc/posix1003.1/ch18.t (modified) * doc/posix1003.1/summarize (modified) Added Constants, Feature Flags, and Macros (included in Functions). ... Tue, 17 Mar 1998 23:10:33 GMT Joel Sherrill [c78be42] * doc/posix1003.1/Makefile (modified) * doc/posix1003.1/ch01.t (modified) * doc/posix1003.1/ch02.t (modified) * doc/posix1003.1/ch08.t (modified) * doc/posix1003.1/summarize (modified) First attempt at adding constants and feature flags Tue, 17 Mar 1998 18:50:14 GMT Joel Sherrill [6984a19] * doc/posix1003.1/ch02.t (modified) * doc/posix1003.1/ch03.t (modified) * doc/posix1003.1/ch04.t (modified) * doc/posix1003.1/ch05.t (modified) * doc/posix1003.1/ch06.t (modified) * doc/posix1003.1/ch08.t (modified) * doc/posix1003.1/ch09.t (modified) * doc/posix1003.1/ch10.t (modified) * doc/posix1003.1/ch11.t (modified) * doc/posix1003.1/ch13.t (modified) * doc/posix1003.1/ch15.t (modified) * doc/posix1003.1/posix1003_1.texi (modified) Completed status pass on functions and data types. Tue, 17 Mar 1998 16:37:57 GMT Joel Sherrill [3cffce87] * doc/posix1003.1/ch11.t (modified) * doc/posix1003.1/ch12.t (modified) * doc/posix1003.1/ch13.t (modified) * doc/posix1003.1/ch14.t (modified) * doc/posix1003.1/ch15.t (modified) * doc/posix1003.1/ch16.t (modified) * doc/posix1003.1/ch17.t (modified) * doc/posix1003.1/ch18.t (modified) * doc/posix1003.1/summarize (modified) Completed first pass at function status. Added most data types ... Mon, 16 Mar 1998 22:43:37 GMT Joel Sherrill [2a087f3] * doc/posix1003.1/ch04.t (modified) * doc/posix1003.1/ch05.t (modified) * doc/posix1003.1/ch06.t (modified) * doc/posix1003.1/ch07.t (modified) * doc/posix1003.1/ch08.t (modified) * doc/posix1003.1/ch09.t (modified) * doc/posix1003.1/ch10.t (modified) * doc/posix1003.1/ch11.t (modified) * doc/posix1003.1/summarize (modified) Added types, status of functions, cleaned up output of summarize. Mon, 16 Mar 1998 18:08:38 GMT Joel Sherrill [3349409] * doc/posix1003.1/ch02.t (modified) * doc/posix1003.1/ch03.t (modified) * doc/posix1003.1/ch04.t (modified) Added function status and data types Mon, 16 Mar 1998 18:08:25 GMT Joel Sherrill [aedf452] * doc/posix1003.1/summarize (modified) Cleaned up format and added data types. Mon, 16 Mar 1998 17:08:52 GMT Joel Sherrill [34683fee] * doc/posix1003.1/ch03.t (modified) * doc/posix1003.1/ch04.t (modified) * doc/posix1003.1/ch05.t (modified) * doc/posix1003.1/ch06.t (modified) * doc/posix1003.1/ch07.t (modified) * doc/posix1003.1/ch08.t (modified) * doc/posix1003.1/ch09.t (modified) * doc/posix1003.1/ch11.t (modified) * doc/posix1003.1/ch12.t (modified) * doc/posix1003.1/ch13.t (modified) * doc/posix1003.1/ch14.t (modified) * doc/posix1003.1/ch15.t (modified) * doc/posix1003.1/ch16.t (modified) * doc/posix1003.1/ch17.t (modified) * doc/posix1003.1/ch18.t (modified) Added Function field. Mon, 16 Mar 1998 17:06:12 GMT Joel Sherrill [53d804ff] * doc/posix1003.1/Makefile (modified) * doc/posix1003.1/summarize (modified) summarize now generates a nicely formatted function status summary. Mon, 16 Mar 1998 17:05:47 GMT Joel Sherrill [4936b65] * doc/posix1003.1/ch03.t (modified) Function implmentation status information correct. Mon, 16 Mar 1998 16:15:32 GMT Joel Sherrill [e7acb60] * doc/posix1003.1/Makefile (modified) * doc/posix1003.1/posix1003_1.texi (modified) * doc/posix1003.1/summarize (modified) First time summary chapter is included in the document. Sat, 14 Mar 1998 18:06:27 GMT Joel Sherrill [17ab8f5b] * doc/posix1003.1/ch01.t (modified) * doc/posix1003.1/ch02.t (modified) Added blank lines. Sat, 14 Mar 1998 18:06:08 GMT Joel Sherrill [2071990] * doc/posix1003.1/Makefile (modified) Added summary chapter. Sat, 14 Mar 1998 18:05:51 GMT Joel Sherrill [22c9e0e] * doc/posix1003.1/summarize (added) New file. Sat, 14 Mar 1998 17:43:56 GMT Joel Sherrill [5e53171d] * doc/posix1003.1/ch12.t (modified) * doc/posix1003.1/ch13.t (modified) * doc/posix1003.1/ch14.t (modified) * doc/posix1003.1/ch15.t (modified) * doc/posix1003.1/ch16.t (modified) * doc/posix1003.1/ch17.t (modified) * doc/posix1003.1/ch18.t (modified) Added functions from POSIX standard. Sat, 14 Mar 1998 17:09:27 GMT Joel Sherrill [76fa649] * doc/posix1003.1/ch09.t (modified) * doc/posix1003.1/ch10.t (modified) * doc/posix1003.1/ch11.t (modified) Added functions from POSIX standard. Sat, 14 Mar 1998 16:33:20 GMT Joel Sherrill [24331760] * doc/posix1003.1/ch09.t (modified) Added copyright header Sat, 14 Mar 1998 16:31:11 GMT Joel Sherrill [0874502] * doc/posix1003.1/ch03.t (modified) * doc/posix1003.1/ch04.t (modified) * doc/posix1003.1/ch05.t (modified) * doc/posix1003.1/ch06.t (modified) * doc/posix1003.1/ch07.t (modified) * doc/posix1003.1/ch08.t (modified) * doc/posix1003.1/posix1003_1.texi (modified) Added functions from POSIX standard. Wed, 11 Mar 1998 22:56:23 GMT Joel Sherrill [68feecfd] * doc/posix1003.1/Makefile (modified) * doc/posix1003.1/ch04.t (modified) * doc/posix1003.1/ch05.t (modified) * doc/posix1003.1/ch07.t (modified) * doc/posix1003.1/ch09.t (modified) * doc/posix1003.1/ch10.t (modified) * doc/posix1003.1/ch11.t (modified) * doc/posix1003.1/ch12.t (modified) * doc/posix1003.1/ch13.t (modified) * doc/posix1003.1/ch14.t (modified) * doc/posix1003.1/ch15.t (modified) * doc/posix1003.1/ch16.t (modified) * doc/posix1003.1/ch17.t (modified) * doc/posix1003.1/ch18.t (modified) * doc/posix1003.1/posix1003_1.texi (modified) * doc/posix1003.1/preface.texi (modified) Outline complete and apparently correct. Wed, 11 Mar 1998 22:06:41 GMT Joel Sherrill [2d19ed6c] * doc/posix1003.1/Makefile (added) * doc/posix1003.1/ch01.t (added) * doc/posix1003.1/ch02.t (added) * doc/posix1003.1/ch03.t (added) * doc/posix1003.1/ch04.t (added) * doc/posix1003.1/ch05.t (added) * doc/posix1003.1/ch06.t (added) * doc/posix1003.1/ch07.t (added) * doc/posix1003.1/ch08.t (added) * doc/posix1003.1/ch09.t (added) * doc/posix1003.1/ch10.t (added) * doc/posix1003.1/ch11.t (added) * doc/posix1003.1/ch12.t (added) * doc/posix1003.1/ch13.t (added) * doc/posix1003.1/ch14.t (added) * doc/posix1003.1/ch15.t (added) * doc/posix1003.1/ch16.t (added) * doc/posix1003.1/ch17.t (added) * doc/posix1003.1/ch18.t (added) * doc/posix1003.1/posix1003_1.texi (added) * doc/posix1003.1/preface.texi (added) Baseline
