# # ChangeLog for doc/main.am in rtems # # Generated by Trac 1.2.1.dev0 # 05/03/24 00:28:16 Mon, 11 Mar 2013 22:10:51 GMT Joel Sherrill [68286f3] * doc/main.am (modified) doc/main.am: Tweak TEXI2ANY_ARGS to make HTML menus look better Mon, 11 Mar 2013 20:22:05 GMT Joel Sherrill [0322a4f] * doc/main.am (modified) doc/main.am: TEXI2HTML_ARGS macro clean up Tue, 26 Feb 2013 18:49:29 GMT Joel Sherrill [83b555f] * doc/main.am (modified) * doc/project.am (modified) doc: Build html into subdirectory (fix make clean) Building with a ... Fri, 22 Feb 2013 19:43:12 GMT Joel Sherrill [0c59b4b] * doc/main.am (modified) * doc/project.am (modified) doc: Use More Readable Names for Generated Nodes Per a discussion ... Fri, 22 Feb 2013 01:19:48 GMT Joel Sherrill [94ca070] * doc/configure.ac (modified) * doc/index.html.in (modified) * doc/main.am (modified) * doc/project.am (modified) * doc/texi2any_init.in (added) doc: Support texi2any and texi2html This was tested with ... Tue, 06 Dec 2011 15:12:48 GMT Joel Sherrill [abdeac2a] * doc/.cvsignore (modified) * doc/ChangeLog (modified) * doc/Makefile.am (modified) * doc/README (modified) * doc/ada_user/.cvsignore (modified) * doc/ada_user/ada_user.texi (modified) * doc/ada_user/example.texi (modified) * doc/bsp_howto/.cvsignore (modified) * doc/bsp_howto/bsp_howto.texi (modified) * doc/configure.ac (modified) * doc/cpu_supplement/.cvsignore (modified) * doc/cpu_supplement/cpu_supplement.texi (modified) * doc/cpu_supplement/preface.texi (modified) * doc/develenv/.cvsignore (modified) * doc/develenv/develenv.texi (modified) * doc/develenv/intro.texi (modified) * doc/filesystem/.cvsignore (modified) * doc/filesystem/filesystem.texi (modified) * doc/filesystem/preface.texi (modified) * doc/index.html.in (modified) * doc/main.am (modified) * doc/networking/.cvsignore (modified) * doc/networking/networking.texi (modified) * doc/networking/preface.texi (modified) * doc/porting/.cvsignore (modified) * doc/porting/porting.texi (modified) * doc/porting/preface.texi (modified) * doc/posix1003.1/.cvsignore (modified) * doc/posix1003.1/posix1003_1.texi (modified) * doc/posix_users/.cvsignore (modified) * doc/posix_users/posix_users.texi (modified) * doc/posix_users/preface.texi (modified) * doc/project.am (modified) * doc/rtems_footer.html.in (deleted) * doc/rtems_header.html.in (deleted) * doc/shell/.cvsignore (modified) * doc/shell/preface.texi (modified) * doc/shell/shell.texi (modified) * doc/started/.cvsignore (modified) * doc/started/started.texi (modified) * doc/texi2html_init.in (added) * doc/user/.cvsignore (modified) * doc/user/c_user.texi (modified) * doc/user/dirstat.texi (modified) * doc/user/example.texi (modified) * doc/user/glossary.texi (modified) * doc/user/preface.texi (modified) 2011-12-06 Joel Sherrill ... Fri, 11 Jun 2010 10:57:22 GMT Ralf Corsepius [bdd88edc] * doc/ChangeLog (modified) * doc/main.am (modified) 2010-06-11 Ralf Corsépius * ... Fri, 24 Jan 2003 11:16:35 GMT Ralf Corsepius [f28a6af2] * doc/ChangeLog (modified) * doc/main.am (modified) * doc/project.am (modified) 2003-01-24 Ralf Corsepius * ... Thu, 23 Jan 2003 00:04:34 GMT Ralf Corsepius [e2a5ab7] * doc/ChangeLog (modified) * doc/main.am (modified) * doc/project.am (modified) 2003-01-22 Ralf Corsepius * ... Sun, 08 Dec 2002 09:04:43 GMT Ralf Corsepius [2106fc7] * doc/ChangeLog (modified) * doc/Makefile.am (modified) * doc/common/Makefile.am (deleted) * doc/configure.ac (modified) * doc/images/Makefile.am (deleted) * doc/main.am (modified) 2002-12-08 Ralf Corsepius * ... Tue, 22 Jan 2002 17:38:37 GMT Joel Sherrill [fb56a37] * doc/.cvsignore (modified) * doc/ChangeLog (modified) * doc/Makefile.am (modified) * doc/configure.ac (modified) * doc/main.am (modified) * doc/project.am (modified) * doc/texinfo/ChangeLog (deleted) * doc/texinfo/texinfo.tex (deleted) 2002-01-21 Ralf Corsepius * ... Sun, 20 Jan 2002 16:57:07 GMT Joel Sherrill [aecc1d9] * doc/ChangeLog (modified) * doc/Makefile.am (modified) * doc/bootstrap (modified) * doc/configure.ac (modified) * doc/main.am (modified) * doc/project.am (modified) 2002-01-19 Ralf Corsepius * ... Fri, 18 Jan 2002 15:10:54 GMT Joel Sherrill [21e473b] * doc/ChangeLog (modified) * doc/Makefile.am (modified) * doc/bootstrap (modified) * doc/configure.ac (moved) * doc/main.am (added) * doc/project.am (modified) 2002-01-18 Ralf Corsepius * ...
