# # ChangeLog for doc/itron3.0 in rtems # # Generated by Trac 1.2.1.dev0 # 05/19/24 11:43:01 Tue, 13 Jul 1999 18:04:13 GMT Joel Sherrill [d2633470] * doc/itron3.0/eventflags.t (modified) Update including fixes for my comments from Xiangyang Wu ... Thu, 08 Jul 1999 15:35:38 GMT Joel Sherrill [0f8a69e7] * doc/itron3.0/eventflags.t (modified) Some cleanup to make it format better. Compensated for multiple ... Thu, 08 Jul 1999 15:28:15 GMT Joel Sherrill [e74dc82] * doc/itron3.0/eventflags.t (modified) First draft from Xiangyang Wu . Tue, 06 Jul 1999 14:52:55 GMT Joel Sherrill [2aab33e5] * doc/itron3.0/msgbuffer.t (modified) From Fei Ling . Fri, 18 Jun 1999 14:47:02 GMT Joel Sherrill [373d359] * doc/itron3.0/semaphore.t (modified) Corrected and fleshed out. Fri, 04 Jun 1999 13:37:43 GMT Joel Sherrill [eb91a4b] * doc/itron3.0/Makefile (modified) * doc/itron3.0/config.t (modified) * doc/itron3.0/eventflags.t (modified) * doc/itron3.0/fixedblock.t (modified) * doc/itron3.0/interrupt.t (modified) * doc/itron3.0/itron.texi (modified) * doc/itron3.0/mailbox.t (modified) * doc/itron3.0/memorypool.t (modified) * doc/itron3.0/msgbuffer.t (modified) * doc/itron3.0/network.t (modified) * doc/itron3.0/rendezvous.t (modified) * doc/itron3.0/tasksync.t (modified) * doc/itron3.0/time.t (modified) Significantly cleaned up to make a much better starting point for the ... Fri, 04 Jun 1999 13:37:23 GMT Joel Sherrill [6ff1ac4e] * doc/itron3.0/semaphore.t (modified) Added much of the text required to turn this into a real chapter. Wed, 26 May 1999 19:45:42 GMT Joel Sherrill [339eba5d] * doc/itron3.0/gen_all (added) New file. Wed, 26 May 1999 18:20:40 GMT Joel Sherrill [110bdfe] * doc/itron3.0/config.t (modified) * doc/itron3.0/eventflags.t (modified) * doc/itron3.0/fixedblock.t (modified) * doc/itron3.0/gen_section (modified) * doc/itron3.0/interrupt.t (modified) * doc/itron3.0/mailbox.t (modified) * doc/itron3.0/memorypool.t (modified) * doc/itron3.0/msgbuffer.t (modified) * doc/itron3.0/network.t (modified) * doc/itron3.0/rendezvous.t (modified) * doc/itron3.0/semaphore.t (modified) * doc/itron3.0/tasksync.t (modified) * doc/itron3.0/time.t (modified) Made the gen_section more accurate. Wed, 26 May 1999 18:10:59 GMT Joel Sherrill [e968366] * doc/itron3.0/config.t (modified) * doc/itron3.0/eventflags.t (modified) * doc/itron3.0/fixedblock.t (modified) * doc/itron3.0/interrupt.t (modified) * doc/itron3.0/mailbox.t (modified) * doc/itron3.0/memorypool.t (modified) * doc/itron3.0/msgbuffer.t (modified) * doc/itron3.0/network.t (modified) * doc/itron3.0/rendezvous.t (modified) * doc/itron3.0/tasksync.t (modified) * doc/itron3.0/time.t (modified) Prototypes are now based on how the TRON specification states them. ... Wed, 26 May 1999 18:07:37 GMT Joel Sherrill [1e72d70] * doc/itron3.0/gen_section (modified) Basic prototypes are now included. Wed, 26 May 1999 17:59:45 GMT Joel Sherrill [b4b24f4] * doc/itron3.0/config.t (modified) * doc/itron3.0/eventflags.t (modified) * doc/itron3.0/fixedblock.t (modified) * doc/itron3.0/gen_section (modified) * doc/itron3.0/interrupt.t (modified) * doc/itron3.0/mailbox.t (modified) * doc/itron3.0/memorypool.t (modified) * doc/itron3.0/msgbuffer.t (modified) * doc/itron3.0/network.t (modified) * doc/itron3.0/rendezvous.t (modified) * doc/itron3.0/tasksync.t (modified) * doc/itron3.0/time.t (modified) Regenerated to include more information in the stub. Now they have ... Wed, 26 May 1999 17:59:16 GMT Joel Sherrill [ce66895e] * doc/itron3.0/semaphore.t (modified) Changed word "directive" to "system call." Wed, 26 May 1999 17:51:04 GMT Joel Sherrill [315b929] * doc/itron3.0/semaphore.t (modified) Added error codes to all service calls Wed, 26 May 1999 16:08:09 GMT Joel Sherrill [b1b4fd26] * doc/itron3.0/config.t (modified) * doc/itron3.0/eventflags.t (modified) * doc/itron3.0/fixedblock.t (modified) * doc/itron3.0/gen_section (modified) * doc/itron3.0/interrupt.t (modified) * doc/itron3.0/mailbox.t (modified) * doc/itron3.0/memorypool.t (modified) * doc/itron3.0/msgbuffer.t (modified) * doc/itron3.0/network.t (modified) * doc/itron3.0/rendezvous.t (modified) * doc/itron3.0/tasksync.t (modified) * doc/itron3.0/time.t (modified) Corrected error code section. Wed, 26 May 1999 16:06:52 GMT Joel Sherrill [e67c585] * doc/itron3.0/config.t (modified) * doc/itron3.0/eventflags.t (modified) * doc/itron3.0/fixedblock.t (modified) * doc/itron3.0/gen_section (modified) * doc/itron3.0/interrupt.t (modified) * doc/itron3.0/mailbox.t (modified) * doc/itron3.0/memorypool.t (modified) * doc/itron3.0/msgbuffer.t (modified) * doc/itron3.0/network.t (modified) * doc/itron3.0/rendezvous.t (modified) * doc/itron3.0/tasksync.t (modified) * doc/itron3.0/time.t (modified) Replaced error code section. Wed, 26 May 1999 16:03:50 GMT Joel Sherrill [c239f715] * doc/itron3.0/semaphore.t (modified) Enhanced. Thu, 20 May 1999 21:55:30 GMT Joel Sherrill [10122b7] * doc/itron3.0/Makefile (added) * doc/itron3.0/config.t (added) * doc/itron3.0/eventflags.t (added) * doc/itron3.0/fixedblock.t (added) * doc/itron3.0/gen_section (added) * doc/itron3.0/interrupt.t (added) * doc/itron3.0/itron.texi (added) * doc/itron3.0/mailbox.t (added) * doc/itron3.0/memorypool.t (added) * doc/itron3.0/msgbuffer.t (added) * doc/itron3.0/network.t (added) * doc/itron3.0/rendezvous.t (added) * doc/itron3.0/semaphore.t (added) * doc/itron3.0/task.t (added) * doc/itron3.0/tasksync.t (added) * doc/itron3.0/time.t (added) Initial revision
