@c3d20eb
07/02/99 18:03:43 |
Joel Sherrill |
Reentrant versions added by Joel. Signficant formatting cleanup.
4.104.114.84.95
@258fd79
07/02/99 17:13:27 |
Joel Sherrill |
Password and group routines added by Ralf Corsepius …
4.104.114.84.95
@ed1a0e51
07/01/99 22:57:23 |
Joel Sherrill |
Honor 0 as PID of caller.
4.104.114.84.95
@51e04a2c
07/01/99 22:28:30 |
Joel Sherrill |
New file to implement signal(2).
4.104.114.84.95
@64b29600
07/01/99 18:57:15 |
Joel Sherrill |
Removed hack to set USER_LABEL_PREFIX since late model gcc's and …
4.104.114.84.95
@937ab62c
06/15/99 22:16:30 |
Joel Sherrill |
After comments D. V. Henkel-Wallace <gumby@…>, the interface …
4.104.114.84.95
@4ecc390
06/14/99 20:18:56 |
Joel Sherrill |
RTEMS_FILESYSTEM_READ_WRITE_ONLY changed to …
4.104.114.84.95
@d741406c
06/14/99 20:18:13 |
Joel Sherrill |
Wrong prototype corrected.
4.104.114.84.95
@0ac8e382
06/14/99 19:44:07 |
Joel Sherrill |
Warning removal from D. V. Henkel-Wallace <gumby@…>.
4.104.114.84.95
@ba46ffa6
06/14/99 16:51:13 |
Joel Sherrill |
This is a large patch from Eric Valette <valette@…> that …
4.104.114.84.95
@d001776f
06/11/99 14:49:13 |
Joel Sherrill |
Added local prototype of ioctl() to avoid requiring sys/ioctl.h.
4.104.114.84.95
@4c3a9c99
06/11/99 14:47:43 |
Joel Sherrill |
Added comments.
4.104.114.84.95
@a6f3cff
06/11/99 14:11:44 |
Joel Sherrill |
Patch from Ian Lance Taylor <ian@…>:
The select function …
4.104.114.84.95
@0643693
06/11/99 14:06:13 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to fix bug reported by
Ian …
4.104.114.84.95
@0860426
06/09/99 16:46:13 |
Joel Sherrill |
Modified to return an error when a bogus return address for the …
4.104.114.84.95
@8dba373
06/09/99 13:50:47 |
Joel Sherrill |
Switched to using strcasecmp() since it is more portable.
D. V. …
4.104.114.84.95
@f74abcf7
05/28/99 18:21:25 |
Joel Sherrill |
Changes from Eric Norum to add a loop and limit on the length of time …
4.104.114.84.95
@403d7b18
05/28/99 16:09:00 |
Joel Sherrill |
Alignment corrected per Eric Norum's suggestion.
4.104.114.84.95
@8f3c1d20
05/28/99 16:08:18 |
Joel Sherrill |
At the request of Gumby, the cpu is now halted rather than spinning
on …
4.104.114.84.95
@11cdbeb
05/27/99 18:03:50 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to eliminate a panic when …
4.104.114.84.95
@1c841bd2
05/27/99 16:13:19 |
Joel Sherrill |
Split out the routine rtems_assoc_name_bad().
4.104.114.84.95
@556ea0e3
05/27/99 16:12:20 |
Joel Sherrill |
Removed usage of printf.
4.104.114.84.95
@5adf355a
05/27/99 16:11:52 |
Joel Sherrill |
Split initialization and reserve resources from termios to reduce
size …
4.104.114.84.95
@82d11f87
05/27/99 15:43:32 |
Joel Sherrill |
Corrected macro names.
4.104.114.84.95
@8bbaf3b
05/20/99 13:32:54 |
Joel Sherrill |
Removed all post 4.0 changes.
4.104.114.84.95
@5a064dca
05/18/99 17:41:16 |
Joel Sherrill |
Patch from Daniel Kelley <dank@…>:
I found a small buglet …
4.104.114.84.95
@9180f63
05/17/99 23:26:50 |
Joel Sherrill |
Fixed some typos.
4.104.114.84.95
@c9973bb
05/17/99 23:22:45 |
Joel Sherrill |
Split Interrupt Manager into one routine per file.
4.104.114.84.95
@0123e3b
05/17/99 23:20:52 |
Joel Sherrill |
Split Signal Manager into one routine per file.
4.104.114.84.95
@1dc030f
05/17/99 23:18:20 |
Joel Sherrill |
Dual-Ported Memory Manager split into one routine per file.
4.104.114.84.95
@842db5f3
05/17/99 23:15:20 |
Joel Sherrill |
Split Partition Manager into one routine per file.
4.104.114.84.95
@be47df9
05/17/99 23:10:36 |
Joel Sherrill |
Split Timer Manager into one routine per file.
4.104.114.84.95
@cc2bc302
05/17/99 23:06:03 |
Joel Sherrill |
Split Event Manager into one routine per file.
4.104.114.84.95
@5f9b3db
05/17/99 23:03:07 |
Joel Sherrill |
Split Rate Monotonic Manager into one routine per file.
4.104.114.84.95
@c06d8f64
05/17/99 22:58:30 |
Joel Sherrill |
Split the Semaphore Manager into one routine per file.
4.104.114.84.95
@a2d0f39
05/17/99 22:56:13 |
Joel Sherrill |
Moved some MP routines to semmp.c.
4.104.114.84.95
@3270ca6
05/17/99 22:53:34 |
Joel Sherrill |
Forgot to actually remove the routines. :)
4.104.114.84.95
@1e1b3e00
05/17/99 22:52:59 |
Joel Sherrill |
Split Message Manager into one routine per file.
4.104.114.84.95
@ef22ab2
05/17/99 22:46:01 |
Joel Sherrill |
Moved an MP routine from msg.c to here.
4.104.114.84.95
@86cb89f
05/17/99 22:45:47 |
Joel Sherrill |
Cleaned up some multiprocessing issues.
4.104.114.84.95
@bd83f47
05/17/99 22:42:47 |
Joel Sherrill |
Split Clock Manager into one routine per file.
4.104.114.84.95
@5aa64518
05/17/99 22:39:20 |
Joel Sherrill |
Split Region Manager into one routine per file.
4.104.114.84.95
@1178b8c
05/17/99 22:19:29 |
Joel Sherrill |
Splitting the Thread Handler forced the inclusion of more prototypes.
4.104.114.84.95
@c4d69e2
05/17/99 21:02:16 |
Joel Sherrill |
Split Task Manager into multiple files. Eventually this effort will …
4.104.114.84.95
@05df0a8
05/17/99 20:41:13 |
Joel Sherrill |
Thread Handler split into multiple files. Eventually, as RTEMS is …
4.104.114.84.95
@a238cc9
05/17/99 15:45:15 |
Joel Sherrill |
Patch from D. V. Henkel-Wallace <gumby@…> to remove compiler …
4.104.114.84.95
@577c4080
05/17/99 15:28:52 |
Joel Sherrill |
Patch from D. V. Henkel-Wallace <gumby@…>:
Here's a tiny …
4.104.114.84.95
@a0b94685
05/14/99 14:43:53 |
Joel Sherrill |
Removed check for initialized ID at request of Rosimildo DaSilva? …
4.104.114.84.95
@4c5080ed
05/11/99 16:30:51 |
Joel Sherrill |
Fix based on bug report from Jay Kulpinski <jskulpin@…> …
4.104.114.84.95
@5a909149
05/07/99 17:09:20 |
Joel Sherrill |
Made all calls to _Thread_Yield_processor consistent in how they are …
4.104.114.84.95
@16775a5
05/07/99 16:36:29 |
Joel Sherrill |
Patch from Jiri Gaisler <jgais@…> to allow stacksize
of …
4.104.114.84.95
@acb644a6
05/07/99 16:30:44 |
Joel Sherrill |
Error reporting fixed by Jennifer.
4.104.114.84.95
@cfcb5a2
04/27/99 17:31:39 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to corrent a miscount in …
4.104.114.84.95
@c7aa9d6
04/26/99 18:22:08 |
Joel Sherrill |
Repairing damage and recovering changes including C++ wrappers..
4.104.114.84.95
@c8cfdcfe
04/26/99 18:04:46 |
Joel Sherrill |
Recovered changes since CVS file was corrupted.
4.104.114.84.95
@933388ae
04/22/99 21:13:23 |
Joel Sherrill |
Added lstat().
4.104.114.84.95
@c2463d9
04/19/99 21:02:31 |
Joel Sherrill |
Intel i960HA support submitted by Jimen Ching <jimen@…> …
4.104.114.84.95
@b56206a
04/19/99 17:30:02 |
Joel Sherrill |
Unlimited objects patch design document. Submitted by Chris Johns …
4.104.114.84.95
@4186b3b
04/19/99 17:17:41 |
Joel Sherrill |
Changed ioctl() prototype to be more like Linux/POSIX than BSD to ease …
4.104.114.84.95
@df3e78a
04/19/99 15:54:03 |
Joel Sherrill |
The default action for real-time signals is supposed to be …
4.104.114.84.95
@ac91855d
04/19/99 15:27:21 |
Joel Sherrill |
After discussion with Eric Norum <eric@…>,
I added …
4.104.114.84.95
@d006519b
04/15/99 19:01:32 |
Joel Sherrill |
Added reentrant versions.
4.104.114.84.95
@a68e6b9
04/15/99 18:58:43 |
Joel Sherrill |
Updated version string.
4.104.114.84.95
@2df1974
04/15/99 18:58:27 |
Joel Sherrill |
Added include of rtems/posix/cancel.h.
4.104.114.84.95
@da41ecbc
04/15/99 18:58:02 |
Joel Sherrill |
Removed alarm(), killinfo() and pause() because they are now in their …
4.104.114.84.95
@93994fdb
04/15/99 18:57:31 |
Joel Sherrill |
Now compiles and is included in normal build even though it is …
4.104.114.84.95
@0f4e074
04/15/99 18:57:02 |
Joel Sherrill |
Cleaned up.
4.104.114.84.95
@3afecf8
04/15/99 18:56:42 |
Joel Sherrill |
Now compiles and is included in normal build even though it is untested.
4.104.114.84.95
@d0f53fe
04/15/99 18:54:01 |
Joel Sherrill |
Enabled cancellation information in POSIX API thread extension structure.
4.104.114.84.95
@2b28307
04/14/99 18:18:03 |
Joel Sherrill |
Bug report from Ralf on UNIX port where the S_IR* constants were not …
4.104.114.84.95
@82f490f
04/12/99 20:24:56 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…> to correct the …
4.104.114.84.95
@d115315
04/12/99 15:36:07 |
Joel Sherrill |
Added line to initialize timer_max.
4.104.114.84.95
@3084de2
04/07/99 15:57:05 |
Joel Sherrill |
MPC821 support and PPC patches from Andrew Bray …
4.104.114.84.95
@b08d3ed9
04/06/99 21:45:06 |
Joel Sherrill |
Untar support submitted by Jake Janovetz <janovetz@…>.
4.104.114.84.95
@85e24a3
04/02/99 14:39:19 |
Joel Sherrill |
Patch from Emmanuel Rauget (raguet@…) to add a htons on the …
4.104.114.84.95
@517660f1
04/01/99 16:36:22 |
Joel Sherrill |
Moved sparc specific version of in_cksum_hdr to an inline routine like …
4.104.114.84.95
@5eb7da97
04/01/99 16:20:03 |
Joel Sherrill |
Disable IXON by default based on comment from Eric Norum …
4.104.114.84.95
@18040d3
03/31/99 23:35:22 |
Joel Sherrill |
Patch from Thomas Doerfler <td@…> to add flow control:
4.104.114.84.95
@ec2328ee
03/31/99 23:24:57 |
Jennifer.Averett |
Removed asserts that shouldn't be called and commented case where this …
4.104.114.84.95
@f719ef1
03/31/99 23:23:52 |
Jennifer.Averett |
Corrected return value.
4.104.114.84.95
@73b943bc
03/31/99 23:21:19 |
Joel Sherrill |
Fixed paths to include files so this will build.
4.104.114.84.95
@6a10709
03/31/99 22:33:14 |
Joel Sherrill |
Patch from Chris Johns <ccj@…>:
joel@… wrote:
4.104.114.84.95
@5c95996
03/31/99 22:09:11 |
Joel Sherrill |
When compiled in debug mode, the POSIX threads inline file was not …
4.104.114.84.95
@efa0baa5
03/31/99 20:51:07 |
Joel Sherrill |
Patch from Eric Norum <eric@…> which changed the exit …
4.104.114.84.95
@ceb06d96
03/30/99 17:43:51 |
Joel Sherrill |
Removed warning for `#ifdef' argument starts with punctuation.
4.104.114.84.95
@707d4d0
03/30/99 17:42:25 |
Joel Sherrill |
Removed warning for const removal.
4.104.114.84.95
@5c6c4c2
03/30/99 17:41:26 |
Joel Sherrill |
Fixed typo where _POSIX_signals_Clear_process_signals was not …
4.104.114.84.95
@6a4096b
03/30/99 15:40:29 |
Joel Sherrill |
Patch to add shutdown() routine from Tony R. Ambardar <tonya@…>.
4.104.114.84.95
@77c81fd2
03/29/99 18:24:34 |
Jennifer.Averett |
Removed an uninitialized variable.
4.104.114.84.95
@a432c4b7
03/24/99 22:52:47 |
Joel Sherrill |
Fix based on bug report from Ralf Corsepius <corsepiu@…>: …
4.104.114.84.95
@e828c2dd
03/23/99 23:06:42 |
Joel Sherrill |
SPARC optimized version of IP checksum header routine. Submitted
by …
4.104.114.84.95
@b6f5f93
03/23/99 22:39:13 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to improve parsing of …
4.104.114.84.95
@4fb9af8
03/19/99 23:26:11 |
Joel Sherrill |
Another cleanup patch for the previous rejected hunk.
4.104.114.84.95
@c0a36429
03/19/99 22:59:20 |
Joel Sherrill |
A cleanup patch on fcntl.c from Eric Norum <eric@…> for …
4.104.114.84.95
@af020036
03/19/99 21:51:58 |
Joel Sherrill |
Patch from Eric Norum <eric@…> that adds external
fcntl …
4.104.114.84.95
@f4a8ee1
03/17/99 16:01:03 |
Joel Sherrill |
Unlimited objects patch from Chris Johns <ccj@…>. Email …
4.104.114.84.95
@6d0e13c
03/16/99 01:51:53 |
Joel Sherrill |
Added ftpd server from Jake Janovetz <janovetz@…>.
4.104.114.84.95
@23c4bbf5
03/16/99 01:41:16 |
Joel Sherrill |
Use proper include for libio.h.
4.104.114.84.95
@b10f6e1
03/08/99 21:39:39 |
Joel Sherrill |
Corrected bug where pointer to doubly linked blocks was being …
4.104.114.84.95
@3195d9c
03/08/99 21:39:16 |
Joel Sherrill |
Added code to translate internal libio flags to POSIX style flags.
4.104.114.84.95
