@acc25ee
12/02/99 14:31:19 |
Joel Sherrill |
Merged of mcp750 and mvme2307 BSP by Eric Valette …
4.104.114.84.95
@5d3da15b
12/01/99 16:00:38 |
Joel Sherrill |
Removed debugging printfs.
4.104.114.84.95
@017061c
12/01/99 15:54:17 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to fix a spot in the tftp …
4.104.114.84.95
@955a9ba7
12/01/99 15:05:26 |
Joel Sherrill |
Patch rtems-rc-19991123-rc-2.diff from Ralf Corsepius
4.104.114.84.95
@ccf8925b
12/01/99 14:22:12 |
Joel Sherrill |
Patch rtems-rc-19991123-rc-1.diff from Ralf Corsepius …
4.104.114.84.95
@42881534
11/30/99 22:14:28 |
Joel Sherrill |
Added missing files from PPP port.
4.104.114.84.95
@d0950ad
11/30/99 22:12:50 |
Joel Sherrill |
Added port of ppp-2.3.5 from Tomasz Domin <dot@…> of ComArch? …
4.104.114.84.95
@1563d8c
11/30/99 16:52:21 |
Joel Sherrill |
Removed duplicate definition of rtems_filesystem_umask.
4.104.114.84.95
@e4b25c4
11/30/99 13:46:28 |
Joel Sherrill |
Corrected so they would compile with POSIX disabled.
4.104.114.84.95
@1d9a2fc
11/29/99 15:45:11 |
Joel Sherrill |
Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius …
4.104.114.84.95
@64f55e7
11/29/99 15:40:38 |
Joel Sherrill |
Made sure POSIX would build with MP enabled.
4.104.114.84.95
@3dfe0b27
11/29/99 15:10:30 |
Joel Sherrill |
Fixed spacing.
4.104.114.84.95
@23e3f642
11/23/99 14:10:05 |
Joel Sherrill |
Missed in previous automake conversion patches from Ralf Corsepius …
4.104.114.84.95
@9f4868c
11/23/99 13:57:02 |
Joel Sherrill |
Miscellaneous patches from Ralf Corsepius <corsepiu@…> …
4.104.114.84.95
@d5b004b
11/23/99 13:52:59 |
Joel Sherrill |
Patch from Ralf Corsepius <corsepiu@…>
to convert the …
4.104.114.84.95
@fba12eb6
11/23/99 13:29:04 |
Joel Sherrill |
Patch rtems-rc-19991117-11.diff from Ralf Corsepius …
4.104.114.84.95
@101e9b0
11/22/99 16:14:00 |
Jennifer.Averett |
Fixed dispatching and cleaned up code.
4.104.114.84.95
@cb3c1718
11/22/99 16:13:22 |
Jennifer.Averett |
+ Corrected enable/disable of dispatch.
+ Cleaned up code.
4.104.114.84.95
@2545646
11/22/99 16:12:19 |
Jennifer.Averett |
+ Updated comments.
4.104.114.84.95
@94f81bbd
11/22/99 16:11:35 |
Jennifer.Averett |
+ Corrected bug in error check.
4.104.114.84.95
@2c3af4c5
11/22/99 16:10:25 |
Jennifer.Averett |
+ Added description of routine to comment.
4.104.114.84.95
@0ca4fc8
11/22/99 16:09:55 |
Jennifer.Averett |
+ Corrected error processing code.
4.104.114.84.95
@f85409c
11/22/99 16:08:53 |
Jennifer.Averett |
+ Added checks for NULL and NULL string names (for sem_open & sem_unlink).
4.104.114.84.95
@0ebf5694
11/22/99 16:07:02 |
Jennifer.Averett |
+ Cleaned up comments.
4.104.114.84.95
@b7912a89
11/22/99 14:25:01 |
Joel Sherrill |
Changed name of W, X, and Y macros for fields in the Clock
Synthesizer …
4.104.114.84.95
@9608320
11/22/99 13:41:11 |
Joel Sherrill |
Patch rtems-rc-19991117-4.diff from Ralf Corsepius …
4.104.114.84.95
@75f2b0b
11/22/99 13:12:48 |
Joel Sherrill |
Small patch (rtems-rc-19991117-5.diff) from Ralf Corsepius …
4.104.114.84.95
@97c465c
11/18/99 21:30:12 |
Joel Sherrill |
Minor cleanup to reduce the code space.
4.104.114.84.95
@4a238002
11/18/99 21:22:58 |
Joel Sherrill |
Patch from "John M. Mills" <jmills@…> with subsequent cleanup …
4.104.114.84.95
@c38f5f16
11/18/99 19:55:28 |
Jennifer.Averett |
Added EINVAL for passing a NULL pointer in.
4.104.114.84.95
@105d7872
11/18/99 19:50:15 |
Jennifer.Averett |
Added routine to remove an object from the namespace. It just clears …
4.104.114.84.95
@17879f4
11/18/99 19:43:13 |
Jennifer.Averett |
+ Debuged to the point that you could open, unlink and close a …
4.104.114.84.95
@c9ae846
11/18/99 19:41:34 |
Jennifer.Averett |
Added a routine to remove a semaphore name from its namespace.
4.104.114.84.95
@40fe60a3
11/17/99 20:44:13 |
Jennifer.Averett |
Comment added.
4.104.114.84.95
@08311cc3
11/17/99 17:51:34 |
Joel Sherrill |
Updated copyright notice.
4.104.114.84.95
@9d9a3dd
11/17/99 16:47:58 |
Jennifer.Averett |
+ Updated copyright information.
4.104.114.84.95
@2d8a4ed0
11/17/99 15:32:30 |
Joel Sherrill |
Conditionally take out the offensive pragma pack when on RTEMS in …
4.104.114.84.95
@5e96e917
11/17/99 15:24:11 |
Joel Sherrill |
Updated Mailbox Manager submitted and split into multiple files.
4.104.114.84.95
@1c10acc
11/17/99 14:56:18 |
Joel Sherrill |
Update from Andrew D. McDowell? <amcdowel@…> with …
4.104.114.84.95
@aad726e
11/16/99 22:56:38 |
Joel Sherrill |
Moved task_variable pointer to basic shared part of TCB instead of …
4.104.114.84.95
@4efe2b7a
11/16/99 22:47:23 |
Jennifer.Averett |
Added check to return passed if task is not suspended.
4.104.114.84.95
@0fa51b5b
11/16/99 22:46:55 |
Jennifer.Averett |
Added code to catch the error of suspend count exceding the counter value.
4.104.114.84.95
@9181246
11/16/99 22:45:51 |
Jennifer.Averett |
Fixed bug.
4.104.114.84.95
@18c3155
11/16/99 22:45:33 |
Jennifer.Averett |
Added handler for fsync. For the memfile it is the same as the data sync.
4.104.114.84.95
@65a38bc
11/16/99 16:14:37 |
Joel Sherrill |
Web server uses the POSIX API. Therefor, it must be disabled when the …
4.104.114.84.95
@ce18601a
11/16/99 16:13:26 |
Joel Sherrill |
Removed start subdirectory and distributed contents to the appropriate …
4.104.114.84.95
@0cb7cb9
11/16/99 16:10:39 |
Joel Sherrill |
Added comments.
4.104.114.84.95
@d3fdf459
11/16/99 16:09:50 |
Joel Sherrill |
Now use _Thread_Reset().
4.104.114.84.95
@f6d0821
11/16/99 16:07:52 |
Joel Sherrill |
Added prototype for _Thread_Reset() and numerous comments.
4.104.114.84.95
@c094542
11/16/99 16:07:17 |
Joel Sherrill |
Only check for System V IPC if multiprocessing is enabled. The unix …
4.104.114.84.95
@f4b76ab5
11/16/99 16:04:51 |
Joel Sherrill |
Fixed so can be included multiple times in the executive source.
4.104.114.84.95
@31473b7
11/16/99 16:03:21 |
Joel Sherrill |
Works now.
Removed times() since the version in the C Library support …
4.104.114.84.95
@165fe39
11/16/99 16:01:54 |
Joel Sherrill |
Return a reasonable error other than ENOSYS.
4.104.114.84.95
@7fec3b7a
11/16/99 16:01:32 |
Joel Sherrill |
Added call to _Watchdog_Remove to remove the sporadic timer. It was …
4.104.114.84.95
@d280ce18
11/16/99 15:58:21 |
Joel Sherrill |
Comment fixed when adding prototype for …
4.104.114.84.95
@bd462d1
11/16/99 15:52:49 |
Joel Sherrill |
New file.
4.104.114.84.95
@817031f
11/16/99 15:28:03 |
Joel Sherrill |
New file.
4.104.114.84.95
@c7016198
11/16/99 15:27:52 |
Joel Sherrill |
Added.
4.104.114.84.95
@b88691c
11/16/99 15:26:29 |
Joel Sherrill |
Source and destination arguments to strncpy were swapped. This …
4.104.114.84.95
@80fd699
11/15/99 22:19:51 |
Joel Sherrill |
Removed nanosleep() since it is now in its own file.
4.104.114.84.95
@40aac29
11/15/99 21:37:56 |
Jennifer.Averett |
Returned third parameter for a NULL name to the objects open call.
4.104.114.84.95
@25789705
11/15/99 21:35:14 |
Jennifer.Averett |
+ Fixed files to consistantly use a case of the location after calls
4.104.114.84.95
@1ae60eb4
11/15/99 21:31:28 |
Jennifer.Averett |
+ Modified to use new Thread_Reset routine instead of the restart method.
4.104.114.84.95
@9da0994
11/15/99 17:15:58 |
Joel Sherrill |
Split ITRON Message Buffer Manager into multiple files.
4.104.114.84.95
@fb27af76
11/15/99 16:39:01 |
Joel Sherrill |
Split ITRON semaphore manager into multiple files.
4.104.114.84.95
@d8f3f65b
11/12/99 21:23:34 |
Joel Sherrill |
+ Changed validation of the_thread to validation of location.
4.104.114.84.95
@2979c28
11/12/99 21:21:09 |
Joel Sherrill |
4.104.114.84.95
@3971537
11/12/99 21:20:04 |
Joel Sherrill |
4.104.114.84.95
@037a7b1
11/12/99 21:18:36 |
Joel Sherrill |
+ Moved error checks to before the disable dispatch where possible.
4.104.114.84.95
@0c5ab522
11/12/99 21:16:45 |
Joel Sherrill |
Added comment about the E_CTX error condition (Implementation dependent).
4.104.114.84.95
@c257429f
11/12/99 21:15:12 |
Joel Sherrill |
+ Moved error checks to before the dispatch disable where possible.
4.104.114.84.95
@2183b65
11/12/99 21:13:52 |
Joel Sherrill |
+ Modified correct return path to call _ITRON_return_errorno( E_OK ) …
4.104.114.84.95
@ea6bfcb
11/12/99 21:12:27 |
Joel Sherrill |
4.104.114.84.95
@6af81435
11/12/99 15:54:48 |
Joel Sherrill |
Corrected so now actually indexes into the allocation block.
4.104.114.84.95
@1925ec9b
11/12/99 15:54:07 |
Joel Sherrill |
Corrected remaining references to struct rtems_task_variable_t since …
4.104.114.84.95
@a8d72dea
11/12/99 15:53:29 |
Joel Sherrill |
Removed unnecessary 3rd parameter.
4.104.114.84.95
@6bd132e5
11/12/99 15:37:09 |
Joel Sherrill |
New file.
4.104.114.84.95
@95bb279
11/12/99 14:54:13 |
Joel Sherrill |
Used typedef so all "struct rtems_task_variable_t" uses are now
just …
4.104.114.84.95
@884b460
11/12/99 14:52:36 |
Joel Sherrill |
Added per-task variable data stucture (rtems_task_variable_t), …
4.104.114.84.95
@5aa5560
11/12/99 14:38:19 |
Joel Sherrill |
Added per task variables based on patch from Eric Norum …
4.104.114.84.95
@3c49a508
11/12/99 14:15:50 |
Joel Sherrill |
Cleaned up style.
4.104.114.84.95
@3ad17f5
11/12/99 13:46:04 |
Joel Sherrill |
Removed redundant line.
4.104.114.84.95
@59d1127
11/10/99 22:14:26 |
Joel Sherrill |
Corrected to account for the way memory is divided up in …
4.104.114.84.95
@72719d2
11/10/99 20:37:01 |
Joel Sherrill |
Added call to _Thread_Enable_dispatch() and did some cleanup.
4.104.114.84.95
@cbccd37
11/10/99 14:31:11 |
Joel Sherrill |
Patch from Eric Norum <eric@…> which includes:
Patches …
4.104.114.84.95
@eb02f47
11/10/99 13:48:27 |
Joel Sherrill |
Committed modifications from ITRON Task and Task Dependendent …
4.104.114.84.95
@e18ba7f
11/09/99 22:25:55 |
Joel Sherrill |
Commented out single letter type names since they conflict with …
4.104.114.84.95
@352c9b2
11/09/99 22:07:23 |
Joel Sherrill |
This patch adds the basic framework for the ITRON 3.0 API …
4.104.114.84.95
@1007c3c
11/09/99 19:54:40 |
Joel Sherrill |
Fixed warning where initialized default POSIX API structure did
have …
4.104.114.84.95
@bd0b378
11/09/99 19:45:23 |
Joel Sherrill |
Removed unused variable warning.
4.104.114.84.95
@b440e57b
11/09/99 13:40:30 |
Joel Sherrill |
Added imfs_unixstub.c to satisfy linker problems on UNIX port.
4.104.114.84.95
@3fb8909a
11/09/99 13:39:42 |
Joel Sherrill |
sem_close was accidentally lost in the split.
4.104.114.84.95
@a0af97d
11/09/99 03:43:47 |
Joel Sherrill |
Patch from Eric Norum <eric@…> to add NTP BOOTP support …
4.104.114.84.95
@f758f810
11/05/99 22:26:12 |
Jennifer.Averett |
Correctly set and called handlers table for the link.
4.104.114.84.95
@089ad91d
11/05/99 22:25:16 |
Jennifer.Averett |
Fixed comment
4.104.114.84.95
@7f6a0750
11/05/99 22:24:56 |
Jennifer.Averett |
Moved imfs set handlers prototype to the imfs.h file.
4.104.114.84.95
@378fe02
11/05/99 21:11:09 |
Joel Sherrill |
New file.
4.104.114.84.95
@94b357c2
11/05/99 21:10:54 |
Joel Sherrill |
Unmount was failing as a side-effect of splitting the rmnod handler …
4.104.114.84.95
@1c55d2e8
11/05/99 19:38:37 |
Joel Sherrill |
Split unistd.c file into sysconf.c and sleep.c.
4.104.114.84.95
@7edb9281
11/05/99 19:02:03 |
Joel Sherrill |
Following comments from Eric Norum <eric@…>, a fairly …
4.104.114.84.95
