@8b18b8eb
11/04/16 09:53:16 |
Sebastian Huber |
posix: Fix _POSIX_RWLock_Manager_initialization()
Use right object class.
5
@76ad5e0c
11/04/16 07:29:43 |
Sebastian Huber |
score: Fix _Scheduler_Try_to_schedule_node()
In case the thread is …
5
@afa92ab7
11/03/16 13:43:03 |
Sebastian Huber |
score: Add _Watchdog_Ticks_from_sbintime
Necessary to support a …
5
@9599b468
11/02/16 05:27:06 |
Sebastian Huber |
score: Delete unused _Scheduler_Is_id_valid()
5
@47d2464
10/31/16 15:23:52 |
Sebastian Huber |
score: Conditionally enable thread resource count
Maintain the thread …
5
@9e7fa07
10/31/16 15:23:13 |
Sebastian Huber |
score: Relax _Scheduler_Set() restrictions
No longer unconditionally …
5
@0dd49d0
10/31/16 15:10:32 |
Sebastian Huber |
score: Introduce thread resource count methods
This makes it easier …
5
@6e31b56f
11/03/16 09:52:53 |
Sebastian Huber |
rtems: Fix binary semaphore resource count
Binary semaphores (not …
5
@86d3a2e8
11/03/16 06:33:11 |
Sebastian Huber |
testsupport: Determine worker index via processor
Determine worker …
5
@63e2ca1b
10/31/16 08:13:35 |
Sebastian Huber |
score: Simplify yield and unblock scheduler ops
Update #2556.
5
@2dd098a
10/31/16 07:33:11 |
Sebastian Huber |
score: Introduce Thread_Scheduler_control::home
Replace …
5
@7f742432
10/31/16 07:22:02 |
Sebastian Huber |
score: Delete Thread_Scheduler_control::own_node
Update #2556.
5
@c0f1f52
10/31/16 07:08:48 |
Sebastian Huber |
score: Delete Thread_Scheduler_control::node
Update #2556.
5
@b5f1b24
10/31/16 07:04:07 |
Sebastian Huber |
score: Delete Scheduler_Node::accepts_help
Update #2556.
5
@1cafc46
10/31/16 05:19:43 |
Sebastian Huber |
score: Delete Resource Handler
Update #2556.
5
@6771359f
10/27/16 04:42:06 |
Sebastian Huber |
score: Second part of new MrsP implementation
Update #2556.
5
@0e754fac
10/21/16 12:41:19 |
Sebastian Huber |
score: Delete unused scheduler ask for help X op
5
@9c238e1
10/21/16 12:33:01 |
Sebastian Huber |
score: Simplify update priority scheduler op
Remove unused return status.
5
@97f7dac
10/21/16 07:23:48 |
Sebastian Huber |
score: Delete _Scheduler_Ask_for_help_if_necessary
Delete …
5
@73a193f
10/21/16 12:15:30 |
Sebastian Huber |
score: Delete unused functions
Delete …
5
@3a27248
10/21/16 07:23:58 |
Sebastian Huber |
score: First part of new MrsP implementation
Update #2556.
5
@913864c
10/13/16 06:57:29 |
Sebastian Huber |
score: Use scheduler instance specific locks
Update #2556.
5
@6a82f1ae
10/10/16 09:46:07 |
Sebastian Huber |
score: Yield support for new SMP helping protocol
Update #2556.
5
@351c14d
09/27/16 09:33:36 |
Sebastian Huber |
score: Add new SMP scheduler helping protocol
Update #2556.
5
@2403473
09/23/16 12:54:04 |
Sebastian Huber |
score: Add _Thread_Scheduler_process_requests()
Update #2556.
5
@ebdd2a3
09/23/16 11:24:06 |
Sebastian Huber |
score: Add scheduler node requests
Add the ability to add/remove …
5
@edb020c
10/14/16 11:03:46 |
Sebastian Huber |
score: Protect thread CPU by thread scheduler lock
Update #2556.
5
@a7a8ec03
10/12/16 07:55:34 |
Sebastian Huber |
score: Protect thread scheduler state changes
Update #2556.
5
@07a32d19
09/23/16 09:57:59 |
Sebastian Huber |
score: Add thread scheduler lock
Update #2556.
5
@70c22d93
09/23/16 08:47:22 |
Sebastian Huber |
score: Add _Thread_Scheduler_remove_wait_node()
Update #2556.
5
@36d7aba
09/23/16 08:46:49 |
Sebastian Huber |
score: Add _Thread_Scheduler_add_wait_node()
Update #2556.
5
@1c9688a9
09/27/16 09:37:22 |
Sebastian Huber |
score: Add _Scheduler_Node_get_scheduler()
Update #2556.
5
@3a72411
10/10/16 13:03:39 |
Sebastian Huber |
score: Simplify _Scheduler_SMP_Node_change_state()
Update #2556.
5
@72e0bdb
10/10/16 12:50:19 |
Sebastian Huber |
score: Pass scheduler node to unblock operation
Changed for …
5
@e382a1b
10/10/16 12:33:17 |
Sebastian Huber |
score: Pass scheduler node to block operation
Changed for consistency …
5
@2df4abc
10/10/16 12:01:55 |
Sebastian Huber |
score: Pass scheduler node to yield operation
5
@501043a
09/30/16 12:38:04 |
Sebastian Huber |
score: Pass scheduler node to update priority op
This enables to call …
5
@d097b546
09/21/16 13:17:37 |
Sebastian Huber |
score: Rename scheduler ask for help stuff
Rename the scheduler ask …
5
@d057d653
09/30/16 08:10:22 |
Sebastian Huber |
score: Fix _Scheduler_Try_to_schedule_node() usage
Fix wrong use of …
5
@4cf58905
10/31/16 13:45:30 |
Sebastian Huber |
cpuuse: Use rtems_task_iterate()
Update #2423.
5
@d271c3bb
10/31/16 12:37:59 |
Sebastian Huber |
rtems: Add rtems_task_iterate()
Update #2423.
5
@bb9f09f
10/31/16 12:07:34 |
Sebastian Huber |
posix: Fix timer interval
Do not overwrite timer interval with …
5
@3e9f4c92
10/31/16 12:05:55 |
Sebastian Huber |
posix: Fix timeout handling in sigtimedwait()
Update #2798.
5
@1aae680
10/21/16 13:34:21 |
Sebastian Huber |
sys/sockio.h: Update to FreeBSD head 2016-05-03
5
@505eb55
10/26/16 11:55:51 |
Sebastian Huber |
sys/uio.h: Update to FreeBSD head 2015-12-03
5
@8b8d05f
10/26/16 11:50:56 |
Sebastian Huber |
sys/event.h: Update to FreeBSD head 2016-06-27
5
@f5eff00
10/13/16 05:09:49 |
Sebastian Huber |
score: Rename RTEMS_OBFUSCATE_POINTER()
The inline asm construct …
5
@826f3afa
10/11/16 22:15:23 |
Chris Johns |
libmisc/xz: Add xz decompression.
Add support to untar XZ compressed …
5
@be57318
09/23/16 04:45:07 |
Sebastian Huber |
score: More robust linker sets
Update #2408.
Update #2790.
5
@97eaefd4
10/12/16 08:44:51 |
Sebastian Huber |
score: Add RTEMS_OBFUSCATE_POINTER()
Update #2790.
5
@2ba0c035
10/12/16 07:54:58 |
Sebastian Huber |
score: Simplify check for migrations
5
@4745650
09/25/16 00:34:55 |
pisa |
pci.h add PCI_COMMAND_INTX_DISABLE definition.
5
@271690e
10/11/16 12:42:55 |
Sebastian Huber |
score: Enhance _SMP_barrier_Wait()
Indicate which processor released …
5
@8714684
10/04/16 21:30:22 |
pisa |
score/arm: Correct logic to select 64 byte cache line maximum size for …
5
@89b4a5cc
10/03/16 09:01:39 |
pisa |
libdl/rtl-obj.c: synchronize cache should not depend on …
5
@9b04456
09/30/16 05:54:29 |
Sebastian Huber |
monitor: Support priority inheritance queues
5
@8797c76
09/27/16 13:23:00 |
Sebastian Huber |
score: Unify CORE mutex seize/surrender
Use the …
5
@4e02681
09/23/16 09:56:45 |
Sebastian Huber |
score: Simplify ISR lock name
5
@94d5b390
09/23/16 09:29:48 |
Sebastian Huber |
score: Simplify CORE mutex seize
Rename …
5
@f0115ab
09/23/16 08:47:36 |
Sebastian Huber |
score: Fix warning
5
@9149c87e
09/23/16 04:52:33 |
Sebastian Huber |
score: Fix C/C++ compatibility issue
Only use CPU_Per_CPU_control if …
5
@f6142c19
09/09/16 09:00:06 |
Sebastian Huber |
score: Scheduler node awareness for thread queues
Maintain the …
5
@8123cae8
09/08/16 13:32:22 |
Sebastian Huber |
rtems: Add rtems_task_get_priority()
Update #2556.
Update #2784.
5
@266d383
09/08/16 12:07:12 |
Sebastian Huber |
score: Manage scheduler nodes via thread queues
Update #2556.
5
@5d6b211
09/07/16 07:04:45 |
Sebastian Huber |
score: Add scheduler node table for each thread
Update #2556.
5
@300f6a48
06/22/16 15:09:23 |
Sebastian Huber |
score: Rework thread priority management
Add priority nodes which …
5
@e814a23
09/16/16 12:20:07 |
Sebastian Huber |
termios: Add IO control handler
Update #2785.
5
@55e0be36
09/16/16 10:58:06 |
Sebastian Huber |
termios: Use IMFS nodes for new Termios devices
This makes the new …
5
@d496e097
09/16/16 11:56:08 |
Sebastian Huber |
imfs: Untangle dependencies
This helps to use …
5
@a3e9ae5d
09/16/16 11:54:18 |
Sebastian Huber |
imfs: Fix IMFS_stat_file()
Use the adjusted and not the requested …
5
@a42be52
09/12/16 13:00:46 |
alexander.krutwig |
Add SPI bus framework
User API is compatible to Linux userspace API. …
5
@b20b736
06/28/16 04:54:50 |
Sebastian Huber |
score: Introduce _Thread_Get_priority()
Avoid direct access to thread …
5
@52a661e8
08/02/16 06:55:00 |
Sebastian Huber |
score: Add scheduler node implementation header
Update #2556.
5
@15b5678d
08/01/16 09:03:16 |
Sebastian Huber |
score: Move thread wait node to scheduler node
Update #2556.
5
@e27421f
08/01/16 09:12:52 |
Sebastian Huber |
score: Move scheduler node to own header file
This makes it possible …
5
@1f210ac1
08/10/16 06:37:16 |
Sebastian Huber |
score: Optimize thread queue enqueue
Optimize the enqueue to empty …
5
@e41308ea
08/22/16 08:58:34 |
Sebastian Huber |
score: Introduce Thread_queue_Lock_context
Introduce …
5
@114e408
08/22/16 11:17:05 |
Sebastian Huber |
score: Simplify thread queue acquire/release
5
@db563698
09/08/16 06:08:53 |
Sebastian Huber |
score: Fix warning
5
@63b36cbf
09/08/16 05:48:44 |
Sebastian Huber |
score: Fix warning
5
@8af1663
09/08/16 07:53:34 |
Sebastian Huber |
score: Fix for RTEMS_DEBUG
5
@11323b7
09/06/16 06:20:14 |
Chris Johns |
libdl: Add ARM C++ relocation record support.
Closes #2767
5
@84e960e
09/07/16 12:25:30 |
Sebastian Huber |
stackchk: Fix stack checker thread initialization
Commit …
5
@8bb9d41
09/07/16 12:08:06 |
Sebastian Huber |
stackchk: Use a const pattern to check
5
@bba988d
09/07/16 11:46:40 |
Sebastian Huber |
stackchk: Remove superfluous internal header file
5
@29594b4
09/07/16 07:27:59 |
Sebastian Huber |
score: Remove superfluous SMP debug support
This information turned …
5
@3709987
08/10/16 06:21:54 |
Sebastian Huber |
score: Add _Chain_Initialize_one()
5
@da15db78
08/24/16 13:25:33 |
Sebastian Huber |
score: Improve red-black tree debug support
Ensure that we extract a …
5
@83b0229
06/28/16 04:59:29 |
Sebastian Huber |
score: Add _RBTree_Initialize_one()
5
@796f12a
08/19/16 11:37:01 |
Sebastian Huber |
score: Add missing const qualifiers
5
@1dd8fff
09/06/16 08:50:50 |
Sebastian Huber |
capture: Use proper accessor functions
5
@7af6b58c
09/06/16 05:44:06 |
Sebastian Huber |
capture: Workaround to avoid misaligned access
Move the 64-bit field …
5
@1c18ebf0
08/31/16 08:56:09 |
Chris Johns |
libmisc/capture: Remove the reserved _t in the types.
5
@6da06c5
08/30/16 06:46:25 |
Chris Johns |
libmisc/capture: Fix the capture engine on SMP.
This patches some …
5
@36fad91
08/19/16 05:38:07 |
Kevin-Kirspel |
arm: Add VFP context validate support for ARMv5
5
@9c42752
08/17/16 05:33:14 |
Sebastian Huber |
score: Fix undefined behaviour
Cast POSIX error codes to unsigned int …
5
@97d395b
08/12/16 08:55:53 |
Chris Johns |
testsuite: Add libdl/dl03 cache test.
5
@58c34961
08/12/16 08:02:52 |
Chris Johns |
libdl: Fix cache corruption bugs.
This patch fixes a number of bugs …
5
@75386e11
08/12/16 07:57:51 |
Chris Johns |
libdl: Add trace output when reading section headers.
5
@55faa44
08/12/16 09:16:45 |
Sebastian Huber |
score: Improve _RBTree_Insert_inline()
Return if the inserted node is …
5
