@fb24f698
02/09/07 15:06:37 |
Ralf Corsepius |
Use size_t for stack-sizes.
4.104.114.84.95
@ba2f913
02/07/07 04:34:46 |
Ralf Corsepius |
2007-02-07 Ralf Corsépius <ralf.corsepius@…>
4.104.114.84.95
@9a673dba
02/07/07 03:36:52 |
Ralf Corsepius |
* configure.ac: …
4.104.114.84.95
@64e442a
02/06/07 22:57:35 |
strauman |
2007-02-06 Till Straumann <strauman@…>
4.104.114.84.95
@b3b82e7a
02/06/07 14:46:24 |
Ralf Corsepius |
2007-02-06 Ralf Corsépius <ralf.corsepius@…>
4.104.114.84.95
@cddd2d0
02/06/07 14:45:54 |
Ralf Corsepius |
Remove getpagesize.c.
4.104.114.84.95
@f350dcf8
02/06/07 14:45:34 |
Ralf Corsepius |
Add getpagesize.c.
4.104.114.84.95
@bee19fe
02/06/07 14:45:10 |
Ralf Corsepius |
Removed (moved to libcsupport/src).
4.104.114.84.95
@6fb68a5
02/06/07 14:44:34 |
Ralf Corsepius |
New (moved from posix/src).
4.104.114.84.95
@70261d1
02/06/07 14:36:02 |
Ralf Corsepius |
4.104.114.84.95
@f629a8b
02/06/07 13:51:30 |
Ralf Corsepius |
4.104.114.84.95
@f0bc3835
02/06/07 13:40:57 |
Ralf Corsepius |
4.104.114.84.95
@a33a6e43
02/06/07 11:27:54 |
Ralf Corsepius |
4.104.114.84.95
@2e22795
02/06/07 11:27:42 |
Ralf Corsepius |
Use size_t for sizes.
4.104.114.84.95
@8ae331d8
02/06/07 10:23:05 |
Ralf Corsepius |
4.104.114.84.95
@8f99833b
02/06/07 08:57:56 |
Ralf Corsepius |
4.104.114.84.95
@6703e491
02/06/07 08:57:40 |
Ralf Corsepius |
4.104.114.84.95
@638aaba1
02/06/07 05:57:20 |
Ralf Corsepius |
4.104.114.84.95
@c8b0f1cb
02/06/07 05:57:07 |
Ralf Corsepius |
4.104.114.84.95
@85c03ce3
02/06/07 05:18:03 |
Ralf Corsepius |
4.104.114.84.95
@d9b3141
02/06/07 05:17:48 |
Ralf Corsepius |
4.104.114.84.95
@e26913b0
02/06/07 04:47:52 |
Ralf Corsepius |
4.104.114.84.95
@f4e0118
02/06/07 04:46:56 |
Ralf Corsepius |
4.104.114.84.95
@2af864d
02/06/07 03:50:47 |
Ralf Corsepius |
4.104.114.84.95
@4b0971d4
02/06/07 03:50:32 |
Ralf Corsepius |
4.104.114.84.95
@11f2f0cd
02/05/07 18:05:37 |
Ralf Corsepius |
2007-02-05 Ralf Corsépius <ralf.corsepius@…>
4.104.114.84.95
@df095da
02/05/07 18:05:21 |
Ralf Corsepius |
4.104.114.84.95
@8eacfb52
02/05/07 15:35:49 |
Ralf Corsepius |
4.104.114.84.95
@32e101b
02/05/07 15:35:36 |
Ralf Corsepius |
4.104.114.84.95
@1cf2581b
01/30/07 09:11:10 |
Ralf Corsepius |
2007-01-30 Ralf Corsépius <ralf.corsepius@…>
4.104.114.84.95
@53cd606
01/30/07 07:55:58 |
Ralf Corsepius |
4.104.114.84.95
@7c7aabd
01/29/07 04:27:26 |
Ralf Corsepius |
2007-01-29 Ralf Corsépius <ralf.corsepius@…>
4.104.114.84.95
@07d0ce8
01/28/07 03:57:09 |
Ralf Corsepius |
2007-01-28 Ralf Corsépius <ralf.corsepius@…>
4.104.114.84.95
@460175ef
01/27/07 18:18:05 |
Ralf Corsepius |
2007-01-27 Ralf Corsépius <ralf.corsepius@…>
4.104.114.84.95
@7364df6
01/27/07 07:26:37 |
Ralf Corsepius |
4.104.114.84.95
@ea35fdc6
01/27/07 07:21:27 |
Ralf Corsepius |
Dynamically derive RTEMS_MAJOR,
RTEMS_MINOR, …
4.104.114.84.95
@8db96e5
01/27/07 07:21:05 |
Ralf Corsepius |
Remove RTEMS_MAJOR,
RTEMS_MINOR, RTEMS_REVISION (moved to …
4.104.114.84.95
@0454464
01/26/07 05:52:43 |
Ralf Corsepius |
2007-01-26 Ralf Corsépius <ralf.corsepius@…>
4.104.114.84.95
@6200dc9
01/22/07 23:02:02 |
Joel Sherrill |
Formatting.
4.104.114.84.95
@3d14a45
01/21/07 18:25:31 |
Thomas.Doerfler |
mproved gen5200 MSCAN driver
fixed synchronization bug between ata.c …
4.104.114.84.95
@6a03edd5
01/17/07 06:19:38 |
strauman |
2007-01-16 Till Straumann <strauman@…>
4.104.114.84.95
@05cdf2a8
01/17/07 06:15:19 |
strauman |
4.104.114.84.95
@e411dda
01/09/07 21:54:52 |
Joel Sherrill |
2007-01-09 Joel Sherrill <joel@…>
4.104.114.84.95
@63a88eb
01/08/07 08:43:28 |
Ralf Corsepius |
Regenerate.
4.104.114.84.95
@e9c1b5f
01/02/07 06:34:57 |
Ralf Corsepius |
2007-01-02 Ralf Corsépius <ralf.corsepius@…>
4.104.114.84.95
@d07cb3a
12/13/06 07:27:42 |
Ralf Corsepius |
2006-12-13 Ralf Corsépius <ralf.corsepius@…>
4.104.114.84.95
@ff32049b
12/13/06 07:27:06 |
Ralf Corsepius |
Abandon.
4.104.114.84.95
@c50c6bf
12/13/06 07:24:32 |
Ralf Corsepius |
4.104.114.84.95
@f065e42
12/13/06 07:24:10 |
Ralf Corsepius |
Abandon backward compatibility types.
4.104.114.84.95
@8373c318
12/13/06 07:22:54 |
Ralf Corsepius |
Regenerate.
4.104.114.84.95
@7ecaafa
12/13/06 07:21:53 |
Ralf Corsepius |
Abandon DEPRECATED_TYPES.
4.104.114.84.95
@d547ff9f
12/13/06 07:21:38 |
Ralf Corsepius |
Abandon DEPRECATED_TYPES/--enable-deprecated.
4.104.114.84.95
@294de470
12/13/06 05:39:19 |
Ralf Corsepius |
4.104.114.84.95
@b25d6119
12/13/06 05:37:07 |
Ralf Corsepius |
Use am_aux_dir/ampolish3.
4.104.114.84.95
@f4cf0ea
12/13/06 03:23:44 |
Ralf Corsepius |
Fix ugly typos.
4.104.114.84.95
@48415d1e
12/12/06 16:42:16 |
Ralf Corsepius |
2006-12-12 Ralf Corsépius <ralf.corsepius@…>
4.104.114.84.95
@a208413
12/12/06 16:41:22 |
Ralf Corsepius |
Remove RTEMS_AMPOLISH.
4.104.114.84.95
@e00746b3
12/12/06 16:37:22 |
Ralf Corsepius |
4.104.114.84.95
@ada8d531
12/12/06 16:36:38 |
Ralf Corsepius |
Add RTEMS_AMPOLISH.
4.104.114.84.95
@fcb08612
12/12/06 16:36:21 |
Ralf Corsepius |
4.104.114.84.95
@195e209a
12/12/06 13:26:06 |
Ralf Corsepius |
4.104.114.84.95
@cdc2fcb
12/12/06 13:25:57 |
Ralf Corsepius |
Regenerate.
4.104.114.84.95
@7d16b755
12/12/06 13:25:47 |
Ralf Corsepius |
Remove rtems/score/ppc.h.
4.104.114.84.95
@1598a7b
12/12/06 13:25:29 |
Ralf Corsepius |
Remove (Deprecated in 4.7).
4.104.114.84.95
@fb8c4e9
12/12/06 10:01:56 |
Ralf Corsepius |
4.104.114.84.95
@adb3c11
12/12/06 10:01:38 |
Ralf Corsepius |
Remove stray rtems_unsigned32.
4.104.114.84.95
@74393f7
12/12/06 03:37:40 |
Ralf Corsepius |
4.104.114.84.95
@4093c4b3
12/08/06 15:49:02 |
Ralf Corsepius |
2006-12-08 Ralf Corsépius <ralf.corsepius@…>
4.104.114.84.95
@5821bfd
12/08/06 15:48:34 |
Ralf Corsepius |
Cosmetics from FreeBSD.
4.104.114.84.95
@cbe366e
12/08/06 09:08:51 |
Ralf Corsepius |
4.104.114.84.95
@8147b49
12/08/06 09:08:28 |
Ralf Corsepius |
Remove local extern strdup.
4.104.114.84.95
@11458809
12/08/06 07:19:19 |
Ralf Corsepius |
4.104.114.84.95
@7192476f
12/08/06 07:18:27 |
Ralf Corsepius |
Use size_t instead of uint32_t for read/write count-args.
4.104.114.84.95
@3f77f718
12/08/06 06:55:03 |
Ralf Corsepius |
4.104.114.84.95
@fe571be
12/08/06 06:54:08 |
Ralf Corsepius |
Remove local extern _Timer_Ticks_chain.
4.104.114.84.95
@70f54cfc
12/08/06 06:53:46 |
Ralf Corsepius |
Remove local extern _Timer_Seconds_chain.
4.104.114.84.95
@c73f11d
12/06/06 09:46:52 |
Ralf Corsepius |
2006-12-06 Ralf Corsépius <ralf.corsepius@…>
4.104.114.84.95
@f5c5a1db
12/06/06 09:46:46 |
Ralf Corsepius |
Add const qualifiers, use size_t where appropriate.
4.104.114.84.95
@6876ce7
12/05/06 15:57:31 |
Ralf Corsepius |
2006-12-05 Ralf Corsépius <ralf.corsepius@…>
4.104.114.84.95
@86aa7980
12/04/06 14:44:33 |
Ralf Corsepius |
More consts
4.104.114.84.95
@852d53f7
12/04/06 14:31:32 |
Ralf Corsepius |
2006-12-04 Ralf Corsépius <ralf.corsepius@…>
4.104.114.84.95
@6bc7a5e
12/04/06 14:16:26 |
Joel Sherrill |
2006-12-04 Joel Sherrill <joel.sherrill@…>
4.104.114.84.95
@fcb0cd46
12/02/06 06:06:55 |
Ralf Corsepius |
2006-12-02 Ralf Corsépius <ralf.corsepius@…>
* configure.ac: …
4.104.114.84.95
@297e238
11/27/06 09:55:09 |
Ralf Corsepius |
2006-11-27 Ralf Corsépius <ralf.corsepius@…>
4.104.114.84.95
@fbfb37e7
11/27/06 09:54:27 |
Ralf Corsepius |
Remove score/src/threadget.c.
4.104.114.84.95
@266165b1
11/27/06 09:54:02 |
Ralf Corsepius |
Remove (Unused).
4.104.114.84.95
@b4bf2897
11/21/06 11:07:04 |
Ralf Corsepius |
2006-11-21 Ralf Corsépius <ralf.corsepius@…>
4.104.114.84.95
@1a741fdc
11/21/06 11:06:31 |
Ralf Corsepius |
Remove (unused).
4.104.114.84.95
@70bb55f
11/20/06 05:55:01 |
Ralf Corsepius |
2006-11-20 Ralf Corsépius <ralf.corsepius@…>
* Makefile.am: …
4.104.114.84.95
@f9f51d0
11/19/06 02:59:47 |
Ralf Corsepius |
Cosmetics.
4.104.114.84.95
@7d6701d
11/19/06 02:17:10 |
Ralf Corsepius |
Fix typo in yesterday's patch.
4.104.114.84.95
@a607d363
11/18/06 14:48:13 |
Joel Sherrill |
2006-11-18 Joel Sherrill <joel@…>
* score/src/heapwalk.c: …
4.104.114.84.95
@fb678af
11/18/06 05:33:15 |
Ralf Corsepius |
2006-11-18 Ralf Corsépius <ralf.corsepius@…>
* configure.ac: …
4.104.114.84.95
@2751cbe0
11/18/06 05:32:29 |
Ralf Corsepius |
Use uintmax_t instead of uint64_t for MALLOC_STATS statistics.
Use …
4.104.114.84.95
@ce135a4f
11/18/06 05:31:43 |
Ralf Corsepius |
Add check for uintmax_t.
4.104.114.84.95
@aab1ef5
11/18/06 03:42:31 |
Ralf Corsepius |
4.104.114.84.95
@6e46fa73
11/18/06 03:42:04 |
Ralf Corsepius |
Use rtems_cv_HAS_NETWORKING instead of HAS_NETWORKING.
4.104.114.84.95
@d4cbf34
11/18/06 03:41:42 |
Ralf Corsepius |
Integrate type checks.
4.104.114.84.95
@9ca2ee4
11/18/06 03:15:52 |
Ralf Corsepius |
4.104.114.84.95
@8d4b5cf
11/18/06 03:15:13 |
Ralf Corsepius |
Remove ITRON-type checks.
Move RTEMS_CHECK* after type-checks.
4.104.114.84.95
