@f1eb368d
12/12/12 11:25:40 |
matkallada |
cpukit/rtems: Header File Doxygen Enhancement GCI Task #8
4.115
@9bff3752
12/11/12 23:54:46 |
matkallada |
libfs: Doxygen Enhancement GCI Task #7
4.115
@cc390b62
12/11/12 22:35:30 |
alexivanov97 |
libcsupport: Doxygen enhancement GCI task #6
4.115
@17c6ad6a
12/11/12 21:51:08 |
alexivanov97 |
libcsupport: Doxygen enhancement GCI task #4
4.115
@c9bb60a
12/11/12 11:49:45 |
alexivanov97 |
libcsupport: GCI Doxygen Task #7
4.115
@3750995
12/10/12 19:51:23 |
alexivanov97 |
libcsupport: Doxygen enhancement task #5
4.115
@bcd0ea64
12/09/12 22:55:17 |
alexivanov97 |
libcsupport: Doxygen enhancement task #2
4.115
@7e73181
12/09/12 13:26:02 |
Sebastian Huber |
libcsupport: Fix documentation
4.115
@9090c0a
12/09/12 13:25:16 |
Sebastian Huber |
Filesystem: Revert documentation change
4.115
@700b2f63
12/09/12 13:16:28 |
Sebastian Huber |
rtems: Revert documentation change
4.115
@e12f5acf
12/09/12 13:12:19 |
Sebastian Huber |
sapi: Fix previous commit
4.115
@50dd75a
12/09/12 13:06:56 |
Sebastian Huber |
sapi: Revert documentation change
4.115
@ceaa999
12/08/12 20:43:29 |
matkallada |
libcsupport: Doxygen Enhancement Task #3
4.115
@4c90eb4
12/08/12 13:48:37 |
matkallada |
misc rtems: Clean up Doxygen GCI Task #8
4.115
@b7185613
12/07/12 14:57:04 |
alexivanov97 |
score misc: Clean up Doxygen GCI Task #12
4.115
@4c98a3e
12/07/12 14:49:54 |
Christopher Kerl |
sapi misc: Clean up Doxygen GCI task #1
4.115
@48bff53b
12/06/12 16:47:30 |
Sebastian Huber |
score: rtems_initialize_start_multitasking()
Do not return from …
4.115
@8b03bbc
12/06/12 15:24:53 |
Gedare Bloom |
rtems misc: doxygen minor fixes
4.115
@4efe1955
12/06/12 00:46:05 |
matkallada |
rtems misc: Clean up Doxygen GCI Task #5
4.115
@a6500136
12/05/12 23:16:48 |
alexivanov97 |
rtems misc: Clean up Doxygen GCI Task #7
4.115
@60ceb613
12/05/12 23:15:32 |
alexivanov97 |
rtems misc: Clean up Doxygen GCI Task #6
4.115
@9465fca
12/03/12 10:59:08 |
Sebastian Huber |
posix: Add signal post switch extension on the fly
4.115
@f9340ed7
12/03/12 10:35:43 |
Sebastian Huber |
posix: Add and use <rtems/posix/psignalimpl.h>
This file contains the …
4.115
@ba316313
11/28/12 12:33:11 |
Sebastian Huber |
rtems: Add signal post switch extension on the fly
4.115
@04b5d17
11/28/12 09:45:38 |
Sebastian Huber |
score: Add API extensions post switch list
Move post switch hook from …
4.115
@0d66dd7
12/05/12 15:04:02 |
Sebastian Huber |
score: Add _Chain_Append_if_is_off_chain_*()
4.115
@038bc6e7
12/05/12 16:56:19 |
Sebastian Huber |
score: Critical fix for timer server
Under certain conditions it is …
4.115
@42a22f08
12/05/12 12:43:34 |
ralf.kirchner |
dosfs: Cluster write optimization
Separate cluster write from sector …
4.115
@a20fbe7
11/28/12 13:43:32 |
ralf.kirchner |
dosfs: Block size optimization
Change block size of bdbuf to the …
4.115
@697cf9df
11/29/12 13:35:23 |
ralf.kirchner |
dosfs: Documentation
4.115
@a0bc1dc
12/05/12 12:58:19 |
ralf.kirchner |
dosfs: Delete fattype parameter for msdos_format()
Delete fattype …
4.115
@5b8d935a
12/05/12 13:11:26 |
ralf.kirchner |
dosfs: Add skip_alignment for msdos_format()
Add skip_alignment …
4.115
@7fab7fc
12/05/12 09:54:17 |
ralf.kirchner |
libblock: Add sparse disk
4.115
@c18e0ba
12/04/12 22:59:11 |
alexivanov97 |
rtems misc: Clean up Doxygen GCI Task #4
4.115
@205dbb9d
12/03/12 19:18:33 |
alexivanov97 |
cpukit: Clean up Doxygen #3 (GCI 2012)
4.115
@9683b27
10/31/12 10:08:09 |
ralf.kirchner |
dosfs: Fix msdos_format()
For FAT32 msdos_format() used to initialize …
4.115
@c05d7502
12/02/12 22:59:17 |
matkallada |
score misc: Clean up Doxygen #14 (GCI 2012)
This patch is a task from …
4.115
@43e0599
12/02/12 21:23:57 |
matkallada |
score misc: Clean up Doxygen #13 (GCI 2012)
4.115
@52adc808
12/02/12 16:03:09 |
alexivanov97 |
score misc: Clean up Doxygen #12 (GCI 2012)
4.115
@5a58b1e
12/01/12 14:53:45 |
daniel.georgiev95 |
score misc: Score misc: Clean up Doxygen #11 (GCI 2012)
This patch is …
4.115
@f839bf5a
12/01/12 14:47:07 |
Christopher Kerl |
score misc: Score misc: Clean up Doxygen #10 (GCI 2012)
This patch is …
4.115
@809b726a
12/01/12 00:12:59 |
Ric Claus |
Print MCSR and ESR.
The Machine Check and Exception Syndrome …
4.115
@22e98377
11/30/12 23:52:51 |
Ric Claus |
Support additional shell keystrokes.
Emacs style keystrokes Ctrl-B, …
4.115
@8219438
11/30/12 23:50:40 |
Ric Claus |
Updated mount usage line.
The mount usage line didn't mention the '-o …
4.115
@fcfef0e
11/30/12 23:49:57 |
Ric Claus |
Updated mkdos options string.
The usage statement for the mkdos …
4.115
@1a33a6c
11/30/12 23:21:20 |
Ric Claus |
PR 2048: Removed use of PPC440 macro.
Retrying this patch as a stand …
4.115
@e0f91da
11/30/12 21:34:17 |
alexivanov97 |
score misc: Score misc: Clean up Doxygen #9 (GCI 2012)
This patch is …
4.115
@4a7dc837
11/30/12 20:56:14 |
Joel Sherrill |
sparc cpu.h: Correct spacing
4.115
@8396c18e
11/30/12 02:01:26 |
matkallada |
Score misc: Clean up Doxygen #8 (GCI 2012)
This patch is a task …
4.115
@f2f63d1
11/29/12 23:14:28 |
alexivanov97 |
score misc: Score misc: Clean up Doxygen #7 (GCI 2012)
This patch …
4.115
@1b475860
11/29/12 19:39:17 |
Christopher Kerl |
score misc: Score misc: Clean up Doxygen #6 (GCI 2012)
This patch is …
4.115
@e655f7e
11/29/12 18:39:19 |
alexivanov97 |
score misc: Score misc: Clean up Doxygen #5
4.115
@db650357
10/30/12 12:28:07 |
ralf.kirchner |
libblock: Documentation
4.115
@f12e021c
11/29/12 13:12:01 |
ralf.kirchner |
Filesystem: Documentation
4.115
@f8ac52f2
11/29/12 14:07:12 |
Sebastian Huber |
score: Documentation
4.115
@bf54252
11/28/12 20:14:50 |
deviennealexandre |
Score misc: Clean up Doxygen #4 (GCI 2012)
4.115
@355ee7d
11/28/12 19:57:31 |
alexivanov97 |
score misc: Clean up Doxygen #3 (GCI 2012)
4.115
@d4d7899
11/28/12 19:31:53 |
Christopher Kerl |
score misc: Clean up Doxygen #2 (GCI 2012)
4.115
@f7f1d77
11/28/12 14:11:31 |
alexivanov97 |
score misc: Clean up Doxygen (GCI 2012)
This patch is a task from GCI …
4.115
@815994f
11/25/12 16:48:11 |
Sebastian Huber |
score: Add CPU_Exception_frame
Add CPU port type CPU_Exception_frame …
4.115
@d2202ac
11/26/12 17:04:12 |
Sebastian Huber |
powerpc: Add CPU_Exception_frame
The powerpc port uses now a unified …
4.115
@acec386
11/22/12 16:28:41 |
Sebastian Huber |
Filesystem: PR1619: Use ENOSYS for default statvfs
POSIX does not …
4.115
@f1738ed
11/04/12 20:04:39 |
Sebastian Huber |
score: PR1607: Add and use CPU_SIZEOF_POINTER
Add and use new CPU …
4.115
@74d22fd1
11/22/12 12:03:09 |
Sebastian Huber |
score: Inline _API_extensions_Run_postswitch()
The …
4.115
@32b2c83
11/22/12 14:00:21 |
Sebastian Huber |
score: Inline _User_extensions_Thread_switch()
The …
4.115
@3be0c9a
11/22/12 13:51:25 |
Sebastian Huber |
score: Add and use <rtems/score/userextimpl.h>
4.115
@67a9159e
11/22/12 11:40:33 |
Sebastian Huber |
score: Avoid superfluous loads
4.115
@1906a36
11/18/12 18:51:10 |
Sebastian Huber |
score: Change _Internal_error_Occurred()
Call the fatal handlers of …
4.115
@e5a2249a
11/18/12 18:19:18 |
Sebastian Huber |
score: Delete nest level from internal error state
This reverts …
4.115
@82eb2c4
11/22/12 13:08:38 |
Sebastian Huber |
ftpfs: Fix NULL pointer access
4.115
@fe0f24e
11/21/12 14:27:43 |
Sebastian Huber |
ftpfs: Use SIZE command
4.115
@ad5e070
11/21/12 14:47:46 |
Sebastian Huber |
ftpfs: Open control connection during path eval
4.115
@be6f505
11/21/12 11:20:14 |
Sebastian Huber |
ftpfs: Format
4.115
@55a36b7
11/21/12 09:59:18 |
Sebastian Huber |
ftpd: Add SIZE command
4.115
@f4539aa
11/18/12 18:47:40 |
Sebastian Huber |
arm: Add _CPU_Thread_Idle_body for ARMv7-M
4.115
@7e32b62
11/17/12 11:31:22 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_POWERPC_EXCEPTION
Add …
4.115
@3fbcadf
11/16/12 13:17:31 |
Sebastian Huber |
libnetworking: Use rtems_clock_get_uptime_seconds
This reduces the …
4.115
@94eb1bb
11/16/12 13:16:03 |
Sebastian Huber |
libnetworking: Use rtems_clock_get_uptime_timeval
4.115
@90733a86
11/16/12 13:14:03 |
Sebastian Huber |
rtems: Add rtems_clock_get_uptime_seconds()
4.115
@bfddb047
11/16/12 13:02:12 |
Sebastian Huber |
rtems: Add rtems_clock_get_uptime_timeval()
4.115
@62181b21
11/16/12 12:59:27 |
Sebastian Huber |
score: Add and use _TOD_Get_with_nanoseconds()
Delete …
4.115
@154721c4
11/16/12 12:39:55 |
Sebastian Huber |
score: Add _Timestamp_To_timeval()
4.115
@7f23ead
11/21/12 08:16:32 |
Sebastian Huber |
powerpc: Add more BUCSR register values
4.115
@5adf02e5
11/20/12 09:37:16 |
Sebastian Huber |
monitor: Typo
4.115
@a12f7e9
11/14/12 14:10:46 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_STACK_CHECKER
4.115
@a0c7aa55
11/14/12 13:54:09 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_ASSERT
4.115
@b9bc399
11/14/12 12:50:11 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_BSP_SPECIFIC
4.115
@9d10cf90
11/14/12 12:58:22 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_BSP_GENERIC
4.115
@a052181
11/14/12 08:59:10 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_EXIT
Include …
4.115
@038e2f4a
11/14/12 08:58:53 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_APPLICATION
4.115
@608940f
11/14/12 09:12:57 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_BDBUF
Add rtems_bdbuf_fatal_code as a …
4.115
@156e91e
11/14/12 09:11:22 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_LAST
This enum value ensures that the …
4.115
@e2e5b492
11/14/12 08:51:41 |
Sebastian Huber |
score: Add rtems_fatal()
4.115
@b31a960
11/13/12 16:53:43 |
Sebastian Huber |
score: Add INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR
Use …
4.115
@dc6e830
11/13/12 16:40:33 |
Sebastian Huber |
sapi: Add and use rtems_internal_error_description
4.115
@e4b40531
11/14/12 11:37:24 |
Sebastian Huber |
sapi: Add rtems_fatal_source and rtems_fatal_code
4.115
@7d0bdca
11/14/12 08:27:43 |
Sebastian Huber |
score: Add nest level to interal error state
Add …
4.115
@891d0d96
11/14/12 14:56:04 |
Sebastian Huber |
4.115
@00dae186
11/13/12 15:39:26 |
Sebastian Huber |
powerpc: Delete _CPU_Install_interrupt_stack()
This function is only …
4.115
@3c1d387
11/09/12 15:02:02 |
Sebastian Huber |
Filesystem: Preserve source NULL pointer in mount
4.115
