source: rtems/cpukit
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @e897c7d   Nov 8, 2018, 11:57:26 AM Sebastian Huber rtems: Avoid include of <rtems/score/scheduler.h> Update #3598.
(edit) @2fa014db   Nov 8, 2018, 11:05:44 AM Sebastian Huber rtems: Avoid include of <rtems/score/thread.h> Update #3598.
(edit) @805f9c26   Nov 8, 2018, 10:55:11 AM Sebastian Huber score: Avoid complex include in heap.h Update #3598.
(edit) @9763245   Nov 8, 2018, 10:53:12 AM Sebastian Huber rtems: Remove superfluous include Update #3598.
(edit) @ccc6695   Nov 8, 2018, 10:50:24 AM Sebastian Huber score: Introduce <rtems/score/watchdogticks.h> Separate the …
(edit) @98c01a5   Nov 8, 2018, 10:32:13 AM Sebastian Huber rtems: Avoid <rtems/score/timecounter.h> in API Use a real function …
(edit) @a11b98c   Nov 8, 2018, 12:12:32 PM Sebastian Huber score: Avoid include of <rtems/score/thread.h> Update #3598.
(edit) @742d6db   Nov 8, 2018, 10:14:04 AM Sebastian Huber score: Remove empty <rtems/score/tod.h> Update #3598.
(edit) @5fc855d   Nov 8, 2018, 12:17:37 PM Sebastian Huber rtems: Move internal structures to extensiondata.h Update #3598.
(edit) @e1b7c188   Nov 8, 2018, 10:07:57 AM Sebastian Huber rtems: Move internal structures to timerdata.h Update #3598.
(edit) @b7af3e44   Nov 8, 2018, 9:57:21 AM Sebastian Huber rtems: Move internal structures to tasksdata.h Update #3598.
(edit) @739df1f5   Nov 8, 2018, 9:45:44 AM Sebastian Huber rtems: Move internal structures to semdata.h Update #3598.
(edit) @e8e914b3   Nov 8, 2018, 9:37:22 AM Sebastian Huber rtems: Move internal structures to regiondata.h Update #3598.
(edit) @f00c5c6   Nov 8, 2018, 9:32:14 AM Sebastian Huber rtems: Move internal structures to partdata.h Update #3598.
(edit) @257668d   Nov 8, 2018, 9:28:49 AM Sebastian Huber rtems: Move internal structures to messagedata.h Update #3598.
(edit) @efc227cd   Nov 8, 2018, 9:24:19 AM Sebastian Huber rtems: Move internal structures to eventdata.h Update #3598.
(edit) @72a4a42   Nov 8, 2018, 9:19:39 AM Sebastian Huber rtems: Move internal structures to dpmemdata.h Update #3598.
(edit) @395a49e1   Nov 8, 2018, 9:12:21 AM Sebastian Huber rtems: Move internal structures to barrierdata.h Update #3598.
(edit) @bdd4eb8   Nov 8, 2018, 8:13:59 AM Sebastian Huber rtems: Remove Modes_Control Use rtems_mode directly. This is in line …
(edit) @257cf74   Nov 8, 2018, 8:03:47 AM Sebastian Huber rtems: Move internal structures to asrdata.h Update #3598.
(edit) @78bbe59   Nov 7, 2018, 1:12:52 PM Sebastian Huber rtems: Move internal structures to ratemondata.h Update #3598.
(edit) @93fae332   Nov 12, 2018, 8:33:04 AM Sebastian Huber Include missing <sys/types.h> Update #3598.
(edit) @0a9378af   Nov 12, 2018, 12:09:36 PM Sebastian Huber x86_64: Remove duplicate _CPU_Thread_Idle_body()
(edit) @bfcf1473   Nov 8, 2018, 3:21:48 PM Sebastian Huber m32c: Remove this target Update #3599.
(edit) @84aedca   Nov 8, 2018, 12:49:38 PM Sebastian Huber Include missing <rtems/score/thread.h> Update #3598.
(edit) @1e039fb3   Nov 8, 2018, 7:01:13 AM Sebastian Huber rtems: Deprecate rtems_rate_monotonic_period_time_t The …
(edit) @aacc7a0   Nov 8, 2018, 6:59:04 AM Sebastian Huber rtems: Deprecate rtems_thread_cpu_usage_t The …
(edit) @d53862a   Nov 8, 2018, 6:56:54 AM Sebastian Huber rtems: Deprecate region_information_block The …
(edit) @7e86e00   Nov 8, 2018, 6:54:03 AM Sebastian Huber rtems: Deprecate rtems_context_fp The rtems_context_fp typedef as no …
(edit) @0ac4a77   Nov 8, 2018, 6:53:14 AM Sebastian Huber rtems: Deprecate rtems_context The rtems_context typedef as no …
(edit) @947b679   Nov 8, 2018, 3:46:17 PM Sebastian Huber h8300: Remove left over files Update #2452.
(edit) @4f4ed2f0   Nov 8, 2018, 12:11:54 PM Sebastian Huber rtems: Add missing include Update #3598.
(edit) @ac8025c   Nov 8, 2018, 12:09:54 PM Sebastian Huber libcsupport: Add missing include Update #3598.
(edit) @2c8b87f   Nov 8, 2018, 11:10:41 AM Sebastian Huber rtems: Move includes out of extern "C" scope
(edit) @795dfaac   Nov 8, 2018, 9:49:43 AM Malte Münch small typo
(edit) @ea8cf79   Nov 8, 2018, 11:00:12 AM Sebastian Huber config: Move includes out of extern "C" scope
(edit) @ef30eb1   Nov 8, 2018, 6:52:28 AM Sebastian Huber monitor: Remove dead code Update #3587. Update #3589.
(edit) @a9767a07   Nov 7, 2018, 1:27:17 PM Sebastian Huber score: Use RTEMS_DEPRECATED for deprecated types Update #3584.
(edit) @4fea054c   Nov 6, 2018, 6:34:15 PM Sebastian Huber score: Remove _ISR_Dispatch() This function was only used on some …
(edit) @ff081aee   Nov 6, 2018, 3:58:02 PM Sebastian Huber score: Rename interrupt stack symbols Rename * …
(edit) @e94b73f   Nov 7, 2018, 1:28:55 PM Sebastian Huber config: Include <rtems.h> for RTEMS_NEWLIB
(edit) @97a86719   Nov 6, 2018, 3:57:21 PM Sebastian Huber config: Move definitions after includes
(edit) @e292beba   Nov 7, 2018, 9:47:48 AM Sebastian Huber termios: Move default lock functions Move …
(edit) @d1f7204   Nov 6, 2018, 12:04:11 PM Sebastian Huber config: Fix CONFIGURE_DISABLE_NEWLIB_REENTRANCY Move the getreent() …
(edit) @99d6172   Nov 7, 2018, 12:50:38 AM zenon.hans.taneka Correct minor spelling and grammar errors This work was performed as …
(edit) @878487b0   Nov 5, 2018, 8:53:04 AM Sebastian Huber score: Optimize Objects_Information Reduce structure internal …
(edit) @fa0adf36   Oct 30, 2018, 10:53:46 AM Sebastian Huber ftpd: Avoid TOCTOU problem Assume that opendir() returns only …
(edit) @8c3cd1e8   Oct 30, 2018, 10:34:16 AM Sebastian Huber ftpd: Deal with too long command lines Update #3530.
(edit) @706802f8   Oct 30, 2018, 8:35:06 AM Sebastian Huber ftpd: Make send_dirline() more robust Account for large file names. …
(edit) @7e2aabd7   Oct 30, 2018, 12:23:57 PM Sebastian Huber config: Fix check networking This Autoconf macro used cache variables …
(edit) @54f35888   Oct 25, 2018, 8:54:12 AM Sebastian Huber posix: Provide threads by default Update #2514.
(edit) @033f31c8   Oct 25, 2018, 8:26:40 AM Sebastian Huber posix: Hide POSIX_API_Control by default Update #2514.
(edit) @fe7aefd5   Oct 25, 2018, 8:12:39 AM Sebastian Huber posix: Provide message queues by default Update #2514.
(edit) @701057e0   Oct 25, 2018, 8:07:46 AM Sebastian Huber posix: Provide shared memory objects by default Update #2514.
(edit) @9318cfb0   Oct 14, 2018, 10:43:13 AM Sebastian Huber posix: Provide named semaphores by default Update #2514.
(edit) @e97806a   Oct 14, 2018, 5:20:05 PM Sebastian Huber posix: Split posix_api_configuration_table Use separate configuration …
(edit) @55b69ed   Oct 15, 2018, 6:33:45 AM Sebastian Huber Move default config to librtemsdefaultconfig.a An RTEMS application …
(edit) @7038271   Oct 25, 2018, 10:05:53 AM Sebastian Huber Remove RTEMS_SCORE_OBJECT_ENABLE_STRING_NAMES Enable support for …
(edit) @5090a71b   Oct 25, 2018, 9:32:01 AM Sebastian Huber score: Remove bogus thread object name support Update #2514.
(edit) @0dbf67b   Oct 25, 2018, 12:37:08 PM Sebastian Huber posix: Provide aio_suspend() by default Update #2514.
(edit) @135cb10   Oct 25, 2018, 7:56:02 AM Sebastian Huber posix: Provide more functions by default Update #2514.
(edit) @4a7be22   Oct 25, 2018, 8:03:46 AM Sebastian Huber posix: Fix build with POSIX API disabled Update #2514.
(edit) @24b5807   Oct 24, 2018, 5:35:51 AM Sebastian Huber config: Modify CONFIGURE_INTERRUPT_STACK_SIZE Use …
(edit) @4b801ac   Oct 24, 2018, 5:54:27 AM Sebastian Huber posix: Provide simple thread functions by default Update #2514.
(edit) @c1ce9a2   Oct 24, 2018, 5:40:23 AM Sebastian Huber posix: Provide get thread attributes by default Update #2514.
(edit) @8d81622   Oct 14, 2018, 3:10:32 PM Sebastian Huber posix: Provide non-thread functions by default Update #2514.
(edit) @0b2808ce   Oct 14, 2018, 10:41:22 AM Sebastian Huber posix: Provide scheduler support by default Update #2514.
(edit) @dd804bb   Oct 14, 2018, 10:36:22 AM Sebastian Huber posix: Provide cancel state/type by default Sort POSIX sources …
(edit) @6da1bb0   Oct 18, 2018, 12:58:31 PM Sebastian Huber Remove superfluous configure checks The results of these checks are …
(edit) @167654e   Oct 18, 2018, 12:45:24 PM Sebastian Huber Remove checks for flockfile(), etc. declarations Declarations …
(edit) @f59edebf   Oct 18, 2018, 12:39:09 PM Sebastian Huber Remove getcwd() This function is provided by Newlib since 2000. …
(edit) @79d145a7   Oct 18, 2018, 12:36:44 PM Sebastian Huber Remove optional getrusage() declaration Declaration provided by …
(edit) @e161767e   Oct 18, 2018, 12:33:58 PM Sebastian Huber Remove ttyname() This function is provided by Newlib since 2000. …
(edit) @658ec75   Oct 18, 2018, 12:28:17 PM Sebastian Huber Remove assert() This function is provided by Newlib since 2000. …
(edit) @87a9900f   Oct 18, 2018, 12:22:46 PM Sebastian Huber Remove isatty() These functions are provided by Newlib since 2000. …
(edit) @3cf12c9   Oct 18, 2018, 12:11:10 PM Sebastian Huber Remove strlcat(), strlcpy(), strsep(), readdir_r() These functions …
(edit) @1ad26cd   Oct 18, 2018, 10:38:58 AM Sebastian Huber Support O_NOFOLLOW open() flag Close #3546.
(edit) @b4043ea   Sep 24, 2018, 2:32:49 PM joel check-networking.m4: Disable legacy stack for x86_64 and epiphany …
(edit) @4af18b3   Oct 11, 2018, 8:51:21 AM Sebastian Huber Support O_DIRECTORY open() flag Close #3545.
(edit) @c980eaf   Oct 16, 2018, 12:35:12 PM Sebastian Huber console: Be fair in simple console read Wait for one tick in case no …
(edit) @c6023b7   Oct 12, 2018, 12:40:52 PM Sebastian Huber posix: Fix unused result warning
(edit) @9d1f17a9   Oct 11, 2018, 5:34:35 PM Sebastian Huber build: Fix build on Windows Avoid a long argument list while creating …
(edit) @26b58b7e   Oct 10, 2018, 11:12:50 AM Sebastian Huber telnetd: Add server port to configuration Close #3543.
(edit) @0dc303f   Oct 10, 2018, 8:40:21 AM Sebastian Huber telnetd: Create sessions at start Update #3543.
(edit) @0f0e130   Oct 10, 2018, 7:11:47 AM Sebastian Huber telnetd: Allocate the server context Update #3543.
(edit) @bf4c7ff6   Oct 10, 2018, 7:04:47 AM Sebastian Huber telnetd: Create server socket at start Update #3543.
(edit) @1c567c5   Oct 9, 2018, 1:42:42 PM Sebastian Huber telnetd: Rename shell_args to telnetd_session Update #3543.
(edit) @6d3ec58a   Oct 9, 2018, 1:31:46 PM Sebastian Huber telnetd: Simplify task spawn function Use the minimum task size for …
(edit) @2548d14   Sep 10, 2018, 3:38:14 PM Sebastian Huber build: Include header.am in cpukit/Makefile.am Include all …
(edit) @629faf9   Oct 9, 2018, 12:47:02 PM Sebastian Huber telnetd: Remove keep stdio feature The Telnet service started via …
(edit) @477bca2   Oct 6, 2018, 8:59:10 AM Sebastian Huber build: Remove local.am
(edit) @9da5d5fd   Oct 6, 2018, 8:12:21 AM Sebastian Huber build: Directly reference libraries in tests Remove use of …
(edit) @637546a   Oct 5, 2018, 6:12:40 PM Sebastian Huber build: Merge score/cpu/*/Makefile.am
(edit) @96ad2b2   Oct 4, 2018, 6:32:12 PM Sebastian Huber build: Merge libmisc/Makefile.am
(edit) @19b7db50   Oct 4, 2018, 6:07:16 PM Sebastian Huber build: Merge libnetworking/Makefile.am
(edit) @a40bb03   Oct 4, 2018, 3:58:48 PM Sebastian Huber build: Merge zlib/Makefile.am
(edit) @7f0eac30   Oct 4, 2018, 3:48:23 PM Sebastian Huber build: Merge telnetd/Makefile.am
(edit) @1d93843   Sep 14, 2018, 6:02:02 PM Sebastian Huber build: Merge score/Makefile.am
(edit) @640271f   Sep 14, 2018, 5:55:00 PM Sebastian Huber build: Merge rtems/Makefile.am
(edit) @24312f34   Sep 14, 2018, 5:51:38 PM Sebastian Huber build: Merge pppd/Makefile.am
