@c980eaf
10/16/18 12:35:12 |
Sebastian Huber |
console: Be fair in simple console read
Wait for one tick in case no …
5
@c6023b7
10/12/18 12:40:52 |
Sebastian Huber |
posix: Fix unused result warning
5
@9d1f17a9
10/11/18 17:34:35 |
Sebastian Huber |
build: Fix build on Windows
Avoid a long argument list while creating …
5
@26b58b7e
10/10/18 11:12:50 |
Sebastian Huber |
telnetd: Add server port to configuration
Close #3543.
5
@0dc303f
10/10/18 08:40:21 |
Sebastian Huber |
telnetd: Create sessions at start
Update #3543.
5
@0f0e130
10/10/18 07:11:47 |
Sebastian Huber |
telnetd: Allocate the server context
Update #3543.
5
@bf4c7ff6
10/10/18 07:04:47 |
Sebastian Huber |
telnetd: Create server socket at start
Update #3543.
5
@1c567c5
10/09/18 13:42:42 |
Sebastian Huber |
telnetd: Rename shell_args to telnetd_session
Update #3543.
5
@6d3ec58a
10/09/18 13:31:46 |
Sebastian Huber |
telnetd: Simplify task spawn function
Use the minimum task size for …
5
@2548d14
09/10/18 15:38:14 |
Sebastian Huber |
build: Include header.am in cpukit/Makefile.am
Include all …
5
@629faf9
10/09/18 12:47:02 |
Sebastian Huber |
telnetd: Remove keep stdio feature
The Telnet service started via …
5
@477bca2
10/06/18 08:59:10 |
Sebastian Huber |
build: Remove local.am
5
@9da5d5fd
10/06/18 08:12:21 |
Sebastian Huber |
build: Directly reference libraries in tests
Remove use of …
5
@637546a
10/05/18 18:12:40 |
Sebastian Huber |
build: Merge score/cpu/*/Makefile.am
5
@96ad2b2
10/04/18 18:32:12 |
Sebastian Huber |
build: Merge libmisc/Makefile.am
5
@19b7db50
10/04/18 18:07:16 |
Sebastian Huber |
build: Merge libnetworking/Makefile.am
5
@a40bb03
10/04/18 15:58:48 |
Sebastian Huber |
build: Merge zlib/Makefile.am
5
@7f0eac30
10/04/18 15:48:23 |
Sebastian Huber |
build: Merge telnetd/Makefile.am
5
@1d93843
09/14/18 18:02:02 |
Sebastian Huber |
build: Merge score/Makefile.am
5
@640271f
09/14/18 17:55:00 |
Sebastian Huber |
build: Merge rtems/Makefile.am
5
@24312f34
09/14/18 17:51:38 |
Sebastian Huber |
build: Merge pppd/Makefile.am
5
@b3ef89f9
09/14/18 17:46:58 |
Sebastian Huber |
build: Merge posix/Makefile.am
5
@028b0ce
09/14/18 14:12:19 |
Sebastian Huber |
build: Merge mghttpd/Makefile.am
5
@a2a71b5
09/14/18 14:00:45 |
Sebastian Huber |
build: Merge libstdthreads/Makefile.am
5
@5079524
09/14/18 13:56:26 |
Sebastian Huber |
build: Merge librpc/Makefile.am
5
@c38d517
09/14/18 04:43:35 |
Sebastian Huber |
build: Merge libpci/Makefile.am
5
@e39642a4
09/14/18 04:41:27 |
Sebastian Huber |
build: Merge libmd/Makefile.am
5
@0c56264
09/14/18 04:38:50 |
Sebastian Huber |
build: Merge libi2c/Makefile.am
5
@8d677cf
09/14/18 04:35:59 |
Sebastian Huber |
build: Merge libgnat/Makefile.am
5
@b45a853
09/14/18 04:34:02 |
Sebastian Huber |
build: Merge libfs/Makefile.am
5
@d3d1243
09/14/18 04:22:19 |
Sebastian Huber |
build: Merge libdrvmgr/Makefile.am
5
@551f473
09/14/18 04:19:15 |
Sebastian Huber |
build: Merge libdl/Makefile.am
5
@bab7a68
09/14/18 04:16:36 |
Sebastian Huber |
build: Merge libdebugger/Makefile.am
5
@2532817
09/13/18 12:46:30 |
Sebastian Huber |
build: Merge libcsupport/Makefile.am
5
@94acbbf
09/13/18 12:22:17 |
Sebastian Huber |
build: Merge libcrypt/Makefile.am
5
@9c058287
09/13/18 04:42:32 |
Sebastian Huber |
build: Merge libblock/Makefile.am
5
@8fb3443
09/13/18 04:37:56 |
Sebastian Huber |
build: Merge libfdt/Makefile.am
5
@690718ab
09/13/18 04:35:03 |
Sebastian Huber |
build: Merge ftpd/Makefile.am
5
@60c4ba1
09/13/18 04:30:08 |
Sebastian Huber |
build: Merge dev/Makefile.am
5
@54c0b57
09/12/18 14:03:42 |
Sebastian Huber |
build: Move sapi/Makefile.am
5
@68e1ccc4
09/11/18 04:30:20 |
Sebastian Huber |
build: Remove specialized CPPFLAGS
5
@6cdaa85
10/04/18 18:16:45 |
Sebastian Huber |
shell: Use #include "..." for local header files
Update #3375.
5
@2806e10
10/09/18 06:38:11 |
Sebastian Huber |
telnetd: Ignore setsockopt() return status
Update #3529.
5
@84a5921d
10/09/18 06:12:46 |
Sebastian Huber |
ftpd: Restructure chroot() handling.
Remove superfluous setting of …
5
@6dc0b5f
07/21/17 12:18:50 |
javier.jalle |
leon, spwtdp: Initial driver commit
5
@acb53d5
10/09/18 06:43:08 |
Sebastian Huber |
posix: Remove static assertion
Standard C does not allow pointer …
5
@5bd75823
10/08/18 08:02:07 |
Sebastian Huber |
ftpd: Remove superfluous temporary buffer
Update #3530.
5
@2f784d7
10/08/18 06:14:40 |
Sebastian Huber |
ftpd: Check return status of getsockname()
Update #3530.
5
@be8de0ff
10/05/18 13:16:46 |
Sebastian Huber |
ftpd: Fix insecure chroot() handling
Ensure that the …
5
@df97c4d2
10/05/18 12:56:10 |
Sebastian Huber |
ftpd: Avoid resource leak
Update #3530.
5
@479a28e0
10/05/18 12:54:49 |
Sebastian Huber |
ftpd: Avoid use of uninitialized memory
Update #3530.
5
@51da629
10/05/18 12:47:21 |
Sebastian Huber |
ftpd: Avoid malloc() and sscanf()
Move the user name to the session …
5
@dcf42bb2
10/05/18 12:39:46 |
Sebastian Huber |
ftpd: Remove FTPD_SessionInfo_t::pass member
There is no need to keep …
5
@e761fb4
10/05/18 12:05:22 |
Sebastian Huber |
ftpd: Avoid NULL pointer checks before free()
They are superfluous …
5
@05b5f9c0
10/05/18 11:56:59 |
Sebastian Huber |
jffs2: Avoid use of constant register variable
Avoid the use of a …
5
@4a7c6867
10/05/18 07:37:44 |
Sebastian Huber |
Fix rbtree_postorder_for_each_entry_safe()
Use the non-standard …
5
@1d39e96
10/05/18 06:11:09 |
Sebastian Huber |
score: Fix legacy RTEMS_STATIC_ASSERT()
In standard C pointer …
5
@8776bb9
09/26/18 04:34:54 |
Sebastian Huber |
score: Remove CPU_PROVIDES_IDLE_THREAD_BODY
Remove the …
5
@b38887a
10/05/18 11:39:49 |
Sebastian Huber |
dev/sc16is752: Deal with a baud of zero
Avoid division by zero and …
5
@8777d4c
10/04/18 09:29:03 |
Sebastian Huber |
Add rtems_interrupt_server_request_set_vector()
By default, the …
5
@313f897
09/13/18 12:50:08 |
Sebastian Huber |
Optimize calloc()
Use return value of memset() to enable tail call …
5
@1ad43f8
09/13/18 12:49:16 |
Sebastian Huber |
Avoid need for -fno-builtin for calloc()
Use …
5
@5418890
09/13/18 04:22:21 |
Sebastian Huber |
Remove superfluous pipe_create()
5
@242887bc
09/13/18 04:19:05 |
Sebastian Huber |
Rename files to make them unique within cpukit
This allows to build …
5
@f373bdc0
09/10/18 15:46:19 |
Sebastian Huber |
libdl: Avoid command line defines
Update #3375.
5
@2e77151
09/10/18 04:31:53 |
Sebastian Huber |
mghttpd: Add configuration to source file
Update #3375.
5
@06060da
09/10/18 04:29:11 |
Sebastian Huber |
pppd: Simplify Makefile.am
Update #3375.
5
@e069f7fe
09/10/18 04:27:10 |
Sebastian Huber |
rpc: Use configuration header file
Update #3375.
5
@f004b2b8
10/02/18 08:22:15 |
Sebastian Huber |
Use rtems_task_exit()
Update #3530.
Update #3533.
5
@e50e3f70
10/01/18 07:25:06 |
Sebastian Huber |
rtems: Add rtems_task_exit()
Update #3533.
5
@57a7ecde
10/01/18 06:20:11 |
Sebastian Huber |
telnetd: Remove CEXP convenience routines
Close #3535.
5
@a346ebba
09/26/18 07:04:43 |
Sebastian Huber |
telnetd: Remove CONFIGURE_MAXIMUM_PTYS
Add a …
5
@2da93bcb
09/26/18 07:18:12 |
Sebastian Huber |
telnetd: Regroup includes
5
@8e075540
09/26/18 07:17:55 |
Sebastian Huber |
telnetd: Remove dead code
5
@0413b14
09/26/18 07:06:43 |
Sebastian Huber |
telnetd: Remove superfluous global variable
Update #3528.
5
@b980f363
09/25/18 13:07:35 |
Sebastian Huber |
telnetd: Convert pty driver to new Termios API
Update #3526.
5
@ac9f8087
09/25/18 13:19:08 |
Sebastian Huber |
pppd: Remove unused get_pty() function
Update #3526.
5
@c56721c
09/27/18 05:21:27 |
Sebastian Huber |
printer: Fix Doxygen comments
5
@7d1acc03
09/24/18 07:15:10 |
Sebastian Huber |
stackchk: Fix interrupt stack preparation
We have to prepare the …
5
@4221d93
09/20/18 06:47:44 |
Sebastian Huber |
stackchk: Improve support for interrupt stacks
Prepare the interrupt …
5
@a75a7d3
09/21/18 05:30:44 |
Sebastian Huber |
stackchk: Remove heap hack
It is now guranteed that threads do not …
5
@56e61e24
09/20/18 05:57:08 |
Sebastian Huber |
Remove INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL
The configured …
5
@227b145
08/31/18 06:56:08 |
Daniel Hellstrom |
sparc: clang AS does no accept UNIMP without argument
5
@1c34a9b
12/19/17 12:36:33 |
cederman |
sparc: Remove sequence that could trigger B2BST errata
5
@e20da8b
12/12/17 10:19:46 |
cederman |
sparc: Return to previous section type when done with .data._SPARC_Counter
5
@776464a
09/19/18 09:52:47 |
Sebastian Huber |
score: Allocate per-CPU data only if necessary
The …
5
@68f339b6
09/17/18 09:53:10 |
Sebastian Huber |
Remove CONFIGURE_HAS_OWN_CONFIGURATION_TABLE
The RTEMS configuration …
5
@5fa0a1f6
09/17/18 08:35:45 |
Sebastian Huber |
config: Remove CONFIGURE_HAS_OWN_MOUNT_TABLE
RTEMS had the …
5
@bd5cec41
09/17/18 08:31:29 |
Sebastian Huber |
config: Remove CONFIGURE_HAS_OWN_FILESYSTEM_TABLE
This configuration …
5
@fe283f6c
09/14/18 11:20:05 |
Sebastian Huber |
powerpc: Fix _CPU_Counter_read() for MPC860
The mpc860 is a …
5
@aaa6653
09/13/18 09:33:11 |
Sebastian Huber |
score: Fix PER_CPU_DATA_ITEM_DECLARE()
Fix …
5
@1fe1b820
09/10/18 09:47:24 |
Sebastian Huber |
score: Fix PER_CPU_DATA_GET_BY_OFFSET()
Add uniprocessor version for …
5
@e58f1cd3
09/05/18 05:27:24 |
Sebastian Huber |
Add more dummy values to <sys/priority.h>
Update #3472.
5
@7097962
08/29/18 07:43:44 |
Sebastian Huber |
score: Add thread pin/unpin support
Add support to temporarily pin a …
5
@d8bc0730
09/07/18 09:27:45 |
Sebastian Huber |
score: Modify _Scheduler_Unblock()
In SMP configurations, obtain the …
5
@cfc4231d
08/27/18 08:36:35 |
Sebastian Huber |
score: Add flexible per-CPU data
Update #3507.
5
@77d374f5
09/07/18 05:12:06 |
Sebastian Huber |
cpukit/Makefile.am: Cleanup
5
@cb68253
09/07/18 04:19:02 |
Sebastian Huber |
network: Use kernel/user space header files
Add and use …
5
@43fb904e
09/07/18 05:06:05 |
Sebastian Huber |
network: Remove man page installation
The man page installation is …
5
@eae4d147
09/07/18 04:24:00 |
Sebastian Huber |
network: Remove unused files
5
