@c48cf0bd
09/11/14 07:10:16 |
Sebastian Huber |
score: Rename _BSP_Exception_frame_print()
Rename …
4.115
@6e0000c
09/11/14 07:07:36 |
Sebastian Huber |
powerpc: Delete PPC_BSP_HAS_FIXED_PR288
4.115
@0facefc
09/10/14 13:08:52 |
Hesham Almatary |
or1k: Let CPU/BSP Fatal handler have access to source
This patchs …
4.115
@f82752a4
06/04/14 09:23:34 |
Daniel Hellstrom |
Without the source …
4.115
@80ad7090
09/08/14 12:13:31 |
pisa |
score: More strict RTEMS_DEQUALIFY implementation.
This …
4.115
@05ac47d
09/05/14 07:13:46 |
Sebastian Huber |
posix: Use RTEMS_DECONST()
4.115
@4d5250c
09/05/14 07:13:23 |
Sebastian Huber |
posix: Fix warning
4.115
@8dab980
09/05/14 07:12:59 |
Sebastian Huber |
libcsupport: Use RTEMS_DECONST()
4.115
@a72f16e
09/05/14 06:32:28 |
Sebastian Huber |
score: Add RTEMS_DECONST|DEVOLATILE|DEQUALIFY()
4.115
@2a86615
08/05/14 20:48:01 |
Jennifer Averett |
capture: Add support for variable length records.
4.115
@133962b
07/22/14 14:40:54 |
Jennifer Averett |
capture: Split user extension methods out.
4.115
@bc35eeca
09/04/14 17:55:39 |
Hesham Almatary |
Regenerate preinstall.am for score/cpu/or1k
This patch regenerates …
4.115
@06ac8b71
09/03/14 14:59:37 |
Joel Sherrill |
shell.c: Add cast to match printf() expectations for width specifier
4.115
@2dd1e75e
09/03/14 14:59:10 |
Joel Sherrill |
rtems-rfs-buffer.c: Correct printf() format specifiers to eliminate …
4.115
@3bff410
09/02/14 23:07:36 |
Joel Sherrill |
rtems/score/assert.h: Rework to allow use of NDEBUG
4.115
@9d95ef9
09/02/14 23:07:15 |
Joel Sherrill |
mprotect.c: Remove warning for no prototype
4.115
@5f9c208
09/03/14 03:15:24 |
Chris Johns |
libfs: Fix the warning in the RFS.
Return the first error if one or …
4.115
@305357e
08/31/14 23:29:41 |
Hesham Almatary |
or1k: Implement context validate and context volatile clobber …
4.115
@23e8f3d
08/31/14 23:28:49 |
Hesham Almatary |
Add missing r31 load instruction _ISR_Handler
_ISR_Handler: r31 was …
4.115
@fe826e2
09/02/14 12:10:19 |
Sebastian Huber |
sapi: Add profiling report begin/end message
4.115
@fecaeca1
08/25/14 10:59:34 |
cederman |
score: Define _CPU_Start_multitasking only for LEON SPARC, not SPARC …
4.115
@59990cc
08/29/14 02:48:01 |
Chris Johns |
Regenerate all preinstall.am files.
With this patch the preinstall.am …
4.115
@b597c0d
08/28/14 13:44:52 |
Joel Sherrill |
Apparently, at some point …
4.115
@34db8ec
08/27/14 12:06:10 |
Sebastian Huber |
rtems: SMP fix for timer server
4.115
@96ec8ee8
08/22/14 15:09:36 |
Sebastian Huber |
rtems: Add more clock tick functions
Add rtems_clock_tick_later(), …
4.115
@e5f6ca8
08/22/14 20:22:04 |
Hesham Almatary |
Add or1k to the list of targets that use IEEE 754 in xdr_float.c
4.115
@f553c6e
08/22/14 14:39:47 |
Sebastian Huber |
rtems: Inline rtems_clock_get_ticks_since_boot()
Update documentation.
4.115
@ddbc3f8d
07/11/14 14:37:56 |
cederman |
score: Add SMP support to the cache manager
Adds functions that …
4.115
@bba83e5
07/11/14 14:09:41 |
cederman |
score/sparc: Add comment on icache flush after trap table update
4.115
@54f3476e
07/03/14 09:18:55 |
cederman |
bsp/sparc: Flush icache before first time enabling interrupts
A …
4.115
@aed38189
07/08/14 09:35:14 |
cederman |
score: Rename SMP broadcast message function
Change message type to …
4.115
@a68cc1b
07/08/14 09:33:55 |
cederman |
score: Add function to send a SMP message to a set of CPUs
4.115
@5787188
08/20/14 23:47:02 |
Joel Sherrill |
Add configuration to detect toolset has sigaltstack() prototype
4.115
@bba3507
08/19/14 15:43:36 |
Sebastian Huber |
score: PR2179: Fix initially locked PI mutex
4.115
@3654667f
08/14/14 15:02:29 |
Kolja Waschk |
rtems_termios_puts: Copy and write more than one char at once
Renamed …
4.115
@de62e5d8
08/18/14 21:06:46 |
Hesham Almatary |
Add or1k tick timer register definitions
4.115
@1a2d3497
08/14/14 12:27:40 |
Sebastian Huber |
arm: PR2186: Fix compile error
4.115
@700f97e
08/12/14 18:46:49 |
Joel Sherrill |
or1k/.../preinstall.am: Add missing file
4.115
@94d45f6
08/12/14 15:57:42 |
Hesham Almatary |
Add support for OpenRISC - Fixed issues
This work is based on the old …
4.115
@8ae37323
08/10/14 16:36:30 |
Sebastian Huber |
arm: Add support for FPv4-SP floating point unit
This floating point …
4.115
@0ef6e3bf
07/24/14 15:50:58 |
Sebastian Huber |
rbtree: Simplify _RBTree_Extract()
4.115
@993f5ac
07/23/14 11:03:54 |
Sebastian Huber |
rbtree: Simplify insert and extract
Simplify _RBTree_Insert() and …
4.115
@4752550f
07/23/14 11:19:09 |
Sebastian Huber |
rbtree: Simplify _RBTree_Rotate()
Add and use _RBTree_Direction().
4.115
@390cfcd
08/02/14 13:49:26 |
Sebastian Huber |
posix: Simplify key implementation
4.115
@60fe374
08/03/14 11:02:58 |
Sebastian Huber |
rbtree: Add and use RBTree_Compare_result
4.115
@40dcafa
08/02/14 14:22:31 |
Sebastian Huber |
Add and use RTEMS_CONTAINER_OF()
4.115
@b767683a
07/22/14 20:49:09 |
Sebastian Huber |
rbtree: Rename find header in find control
Simplify …
4.115
@6e93c836
07/22/14 17:42:54 |
Sebastian Huber |
rbtree: Simplify off-tree handling
Only use the parent pointer, since …
4.115
@4cd55724
07/26/14 10:52:22 |
Sebastian Huber |
Delete unused *_Is_null() functions
4.115
@639117f
07/22/14 12:50:07 |
Sebastian Huber |
rbtree: Update maximum node in LIFO order
The test sptests/sp35 …
4.115
@9113798c
07/23/14 20:39:17 |
Joel Sherrill |
todimpl.h: Add missing Doxygen
4.115
@0a84c298
07/23/14 20:37:03 |
Joel Sherrill |
coretod*.c: Fix Doxygen group and comment formatting
4.115
@875fff0a
07/23/14 20:35:35 |
Joel Sherrill |
Add _TOD_Adjust to SCORE TOD Handler.
This lays the proper structure …
4.115
@3b6352d
07/19/14 00:46:59 |
Joel Sherrill |
adjtime.c: Use timestamp math and simplify
4.115
@8abbbdde
07/21/14 16:29:00 |
Sebastian Huber |
rbtree: Do not set node off-tree in extract
4.115
@d7a94693
07/21/14 16:16:47 |
Sebastian Huber |
rbtree: Remove superfluous NULL pointer checks
4.115
@6b0a7efc
07/21/14 16:08:07 |
Sebastian Huber |
rbtree: Format
4.115
@0ea6d07
07/09/14 18:22:28 |
Joel Sherrill |
Use Shared Method for Thread Unblock Cleanup
When a thread is removed …
4.115
@3250664
07/15/14 17:37:36 |
Joel Sherrill |
Thread Queue: Merge discipline subroutines into main methods
There …
4.115
@ed7a028
07/07/14 19:26:13 |
Joel Sherrill |
Thread Queue Priority Discipline Reimplemented with RBTree
4.115
@64939bc
07/12/14 19:22:22 |
Sebastian Huber |
rbtree: Reduce RBTree_Control size
Remove compare function and is …
4.115
@7e119990
07/12/14 19:22:21 |
Sebastian Huber |
rbtree: Delete unused functions
4.115
@764e8b11
07/07/14 19:23:24 |
Joel Sherrill |
scheduleredfunblock.c: Correct spacing
4.115
@3a01e8b
07/07/14 19:22:57 |
Joel Sherrill |
semdelete.c: Correct spacing
4.115
@463de59
04/16/14 14:42:37 |
Jennifer Averett |
capture: Fix capture engine to handle new extensions.
4.115
@1af8634a
04/11/14 15:18:20 |
Jennifer Averett |
capture: Update comment block style in capture engine.
Doxygen added …
4.115
@f0c8501
07/11/14 07:47:05 |
Sebastian Huber |
score: Scheduler helping proto for affinity sched
The priority …
4.115
@27783f6
07/10/14 12:27:42 |
Sebastian Huber |
score: Fix scheduler helping implementation
Do not extract the idle …
4.115
@333f9426
07/10/14 10:49:43 |
Sebastian Huber |
score: Fix assertions
4.115
@93726e5
07/09/14 13:44:13 |
Sebastian Huber |
termios: Add rtems_termios_set_best_baud()
4.115
@8074342c
07/03/14 10:55:42 |
Christian.Mauderer |
termios: Add rtems_termios_get_termios()
4.115
@a0fb29f
07/09/14 09:52:56 |
Sebastian Huber |
termios: PR1279: Use first open status
4.115
@32fc6a3
07/09/14 09:15:53 |
Sebastian Huber |
termios: PR1279: Use set attributes status
4.115
@ef8c00bc
06/27/14 11:10:15 |
Sebastian Huber |
termios: PR2153: New low-level device API
Add a new low-level device …
4.115
@c6048ee
07/09/14 09:20:23 |
Sebastian Huber |
score: _Scheduler_Thread_get_own_node()
Provide this function also …
4.115
@5c3d250
07/04/14 12:34:23 |
Sebastian Huber |
score: Implement scheduler helping protocol
The following scheduler …
4.115
@52f8e90d
07/08/14 16:42:05 |
Joel Sherrill |
schedulerpriorityaffinitysmp.c: Add period at end of sentence
4.115
@8568341
06/11/14 12:31:03 |
Sebastian Huber |
score: Need for help indicator for scheduler ops
Return a thread in …
4.115
@ac532f3
07/04/14 11:40:10 |
Sebastian Huber |
score: Add _Scheduler_Help()
Manage the help state of threads with …
4.115
@08d9760
07/08/14 12:25:55 |
Sebastian Huber |
score: Rename *_Node_get() to *_Thread_get_node()
This emphasizes …
4.115
@19e41767
07/08/14 08:38:19 |
Sebastian Huber |
score: Simplify SMP processor allocation
Avoid copy and paste and set …
4.115
@835b88b
07/07/14 14:41:03 |
Sebastian Huber |
score: Rename _Scheduler_SMP_Update_heir()
Rename and move …
4.115
@5c632c4
07/07/14 11:31:07 |
Sebastian Huber |
score: Fix warning
4.115
@46cd17a
07/04/14 12:32:35 |
Sebastian Huber |
score: Fix MrsP resource root change
Use the root of the owner for …
4.115
@fbda4a8
07/01/14 08:48:28 |
Sebastian Huber |
score: PR2183: Fix context switch on SMP
Fix context switch on SMP …
4.115
@f28f5c4
06/30/14 14:47:06 |
Sebastian Huber |
arm: Use local label in _CPU_Context_restore()
4.115
@bec4730
06/30/14 10:55:50 |
Sebastian Huber |
score: Add PER_CPU_OFFSET_EXECUTING
Add PER_CPU_OFFSET_HEIR. Move …
4.115
@f6b1e063
06/27/14 11:08:28 |
Sebastian Huber |
termios: Make tty list static
4.115
@dd510a0
06/26/14 11:30:59 |
Sebastian Huber |
rtems: Delete unused <rtems/rtems/atomic.h>
4.115
@89f8eab5
05/07/14 12:55:37 |
Sebastian Huber |
score: Workaround for GCC 4.9 for atomic ops
The GCC 4.9 ships its …
4.115
@152ad7d1
06/24/14 07:31:14 |
Sebastian Huber |
score: Fix _Thread_Start_multitasking() on SMP
The …
4.115
@a92989a
06/18/14 13:16:02 |
Sebastian Huber |
score: Fix thread deletion on SMP
Close the thread object in …
4.115
@8f0c7a46
06/10/14 14:13:37 |
Sebastian Huber |
score: Decouple thread and scheduler nodes on SMP
Add a chain node to …
4.115
@647b95d
06/10/14 14:32:12 |
Sebastian Huber |
score: Use chain nodes for ready queue support
This reduces the API …
4.115
@2d36931
06/11/14 09:03:25 |
Sebastian Huber |
score: Collect scheduler related fields in TCB
Add …
4.115
@92635cb
06/03/14 14:27:53 |
Sebastian Huber |
score: Remove scheduler parameter from most ops
Remove the scheduler …
4.115
@bd1431a
06/20/14 10:05:23 |
Sebastian Huber |
score: Use default get/set affinity operation
Add and use …
4.115
@2803c8ce
06/20/14 07:59:05 |
Sebastian Huber |
score: Fix statement with no effect
4.115
@f6b7b7ba
06/18/14 10:11:04 |
Sebastian Huber |
score: Fix _Thread_Delay_ended() on SMP
Suppose we have two tasks A …
4.115
@73bf499
06/10/14 08:56:55 |
Sebastian Huber |
JFFS2: Add device identifier for the flash device
It is used in …
4.115
