@a75a7d3
09/21/18 05:30:44 |
Sebastian Huber |
stackchk: Remove heap hack
It is now guranteed that threads do not …
5
@56e61e24
09/20/18 05:57:08 |
Sebastian Huber |
Remove INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL
The configured …
5
@227b145
08/31/18 06:56:08 |
Daniel Hellstrom |
sparc: clang AS does no accept UNIMP without argument
5
@1c34a9b
12/19/17 12:36:33 |
cederman |
sparc: Remove sequence that could trigger B2BST errata
5
@e20da8b
12/12/17 10:19:46 |
cederman |
sparc: Return to previous section type when done with .data._SPARC_Counter
5
@776464a
09/19/18 09:52:47 |
Sebastian Huber |
score: Allocate per-CPU data only if necessary
The …
5
@68f339b6
09/17/18 09:53:10 |
Sebastian Huber |
Remove CONFIGURE_HAS_OWN_CONFIGURATION_TABLE
The RTEMS configuration …
5
@5fa0a1f6
09/17/18 08:35:45 |
Sebastian Huber |
config: Remove CONFIGURE_HAS_OWN_MOUNT_TABLE
RTEMS had the …
5
@bd5cec41
09/17/18 08:31:29 |
Sebastian Huber |
config: Remove CONFIGURE_HAS_OWN_FILESYSTEM_TABLE
This configuration …
5
@fe283f6c
09/14/18 11:20:05 |
Sebastian Huber |
powerpc: Fix _CPU_Counter_read() for MPC860
The mpc860 is a …
5
@aaa6653
09/13/18 09:33:11 |
Sebastian Huber |
score: Fix PER_CPU_DATA_ITEM_DECLARE()
Fix …
5
@1fe1b820
09/10/18 09:47:24 |
Sebastian Huber |
score: Fix PER_CPU_DATA_GET_BY_OFFSET()
Add uniprocessor version for …
5
@e58f1cd3
09/05/18 05:27:24 |
Sebastian Huber |
Add more dummy values to <sys/priority.h>
Update #3472.
5
@7097962
08/29/18 07:43:44 |
Sebastian Huber |
score: Add thread pin/unpin support
Add support to temporarily pin a …
5
@d8bc0730
09/07/18 09:27:45 |
Sebastian Huber |
score: Modify _Scheduler_Unblock()
In SMP configurations, obtain the …
5
@cfc4231d
08/27/18 08:36:35 |
Sebastian Huber |
score: Add flexible per-CPU data
Update #3507.
5
@77d374f5
09/07/18 05:12:06 |
Sebastian Huber |
cpukit/Makefile.am: Cleanup
5
@cb68253
09/07/18 04:19:02 |
Sebastian Huber |
network: Use kernel/user space header files
Add and use …
5
@43fb904e
09/07/18 05:06:05 |
Sebastian Huber |
network: Remove man page installation
The man page installation is …
5
@eae4d147
09/07/18 04:24:00 |
Sebastian Huber |
network: Remove unused files
5
@d9296d24
09/07/18 04:39:50 |
Sebastian Huber |
Move <poll.h> to set of default header files
The <poll.h> is a POSIX …
5
@ea0a680
09/10/18 08:36:41 |
Sebastian Huber |
score: Debug aid for _Chain_Extract_unprotected()
Ensure that a chain …
5
@2d1c3dff
09/07/18 05:33:47 |
Sebastian Huber |
nfsclient: Fix unused variable warning
5
@e0a9336b
09/03/18 06:12:35 |
Sebastian Huber |
score: Fix EDF SMP scheduler
Fix a special case: block a one-to-one …
5
@3aad9d9b
09/03/18 07:31:19 |
Sebastian Huber |
score: Generalize SMP scheduler block support
Add extract from …
5
@9b5b864
08/29/18 17:42:10 |
joel |
rtems/score/epiphany-utility.h: Fix not a prototype warning
5
@bc696482
08/29/18 17:41:35 |
joel |
score/cpu/bfin/cpu.c: Fix _CPU_Thread_Idle_body() prototype
5
@14a218f
08/21/18 15:32:48 |
joel |
cpukit/telnetd/pty.c: Fix format overflow warning on sprintf()
5
@9e8bba5
08/29/18 05:53:02 |
Sebastian Huber |
score: Remove redundant #ifdef RTEMS_SMP
5
@6d70a11
08/27/18 05:33:29 |
Sebastian Huber |
Include <stdbool.h> in <machine/_kernel_types.h>
The FreeBSD kernel …
5
@27c89d7
08/08/18 09:52:09 |
Sebastian Huber |
Add FreeBSD kernel space header files
Move the kernel space content …
5
@0d51b6d8
06/28/18 12:39:37 |
Daniel Hellstrom |
capture: prevent unaligned access when reading time
LLVM warns about …
5
@59a0541c
07/12/18 07:15:55 |
cederman |
sparc: Restore npc when returning from the syscall_lazy_fp_switch trap …
5
@6695d02
08/23/18 12:39:33 |
Sebastian Huber |
Update FreeBSD kernel timespec support
This change is based on the …
5
@ba0e9631
08/10/18 05:34:03 |
Sebastian Huber |
score: Do not inline _Thread_Dispatch_enable()
This function is …
5
@a36aa86
08/23/18 12:32:07 |
Sebastian Huber |
Add dummy PI_SOFT to <sys/priority.h>
Update #3472.
5
@d14f934
08/10/18 05:22:43 |
Sebastian Huber |
score: Fix ISR enable in _Thread_Dispatch_enable()
This bug had …
5
@dcaea71
08/15/18 10:26:13 |
christian.mauderer |
dev/sc16is752: Add name space for field names.
The field names for …
5
@bc731313
08/13/18 10:55:34 |
amaan.cheval |
bsps/x86_64: Add APIC timer based clock driver
The APIC timer is …
5
@6869321
08/13/18 10:50:38 |
amaan.cheval |
bsps/x86_64: Add support for RTEMS interrupts
Updates #2898.
5
@4544749e
08/13/18 10:33:12 |
amaan.cheval |
bsps/x86_64: Add paging support with 1GiB super pages
Updates #2898.
5
@ab971bf5
08/13/18 10:21:47 |
amaan.cheval |
bsps/x86_64: Reorganize header files and compile-options
Updates #2898.
5
@b2de426
08/06/18 09:53:42 |
Sebastian Huber |
score: Fix _Addresses_Subtract()
Use architecture-specific integer …
5
@66cb142
08/06/18 08:51:00 |
Sebastian Huber |
rtems: Parameter types in rtems_partition_create()
Use uintptr_t to …
5
@b8eae140
08/10/18 05:11:56 |
Sebastian Huber |
Add dummy PRI_MIN_KERN to <sys/priority.h>
Update #3472.
5
@aac36d15
08/08/18 09:17:36 |
Sebastian Huber |
posix: Add configure check for mprotect()
Update #3491.
5
@71948f76
08/08/18 05:52:18 |
Sebastian Huber |
sys/event.h: Update version FreeBSD tag
Update #3472.
5
@ac824ff
07/18/18 13:04:03 |
dab |
Make the definition of struct kevent in event.h match what the man …
5
@96b32773
07/11/18 02:09:11 |
dab |
Address some (although not all) style(9) issues in event.h after …
5
@1d00acb1
06/28/18 20:37:17 |
dab |
Fix compilation error in r335765 under gcc 4.2.1.
The anonymous …
5
@b37ef68
06/28/18 17:01:04 |
dab |
Remove potential identifier conflict in the EV_SET macro.
PR43905 …
5
@bf026dd4
11/27/17 15:01:59 |
pfg |
sys/sys: further adoption of SPDX licensing ID tags.
Mainly focus on …
5
@57c03363
11/25/17 04:49:12 |
jhb |
Decode kevent structures logged via ktrace(2) in kdump.
- Add a new …
5
@e9b708a
06/17/17 00:57:26 |
kib |
Add abstime kqueue(2) timers and expand struct kevent members.
This …
5
@f51aec8
04/08/17 04:34:18 |
pkelsey |
Fix typo.
hist -> hint
MFC after: 3 days
5
@fd27bae
08/07/18 04:25:47 |
Sebastian Huber |
CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
Make …
5
@0b038bd4
08/04/18 08:38:48 |
Sebastian Huber |
libblock: Add RTEMS_DEPRECATED
Close #3358.
5
@ab96aec
08/04/18 08:56:46 |
Sebastian Huber |
dosfs: Avoid deprecated routine
Update #3358.
5
@698093d
08/03/18 20:39:42 |
Sebastian Huber |
libblock: Use rtems_blkdev_create_partition()
Update #3358.
5
@0fe7133
07/31/18 14:01:17 |
Sebastian Huber |
flashdisk: Use rtems_blkdev_create()
Update #3358.
5
@16f3f10
07/31/18 13:54:29 |
Sebastian Huber |
nvdisk: Use rtems_blkdev_create()
Update #3358.
5
@24b94c4
07/30/18 04:39:09 |
Sebastian Huber |
ramdisk: Use rtems_blkdev_create()
Update #3358.
5
@d56e68b
08/04/18 12:27:38 |
Sebastian Huber |
rfs: Remove erroneous call of rtems_disk_release()
The function …
5
@42f9963d
08/03/18 05:58:07 |
Sebastian Huber |
score: Remove superfluous semicolon
This avoids warnings like this:
5
@83ca9f0a
08/02/18 12:52:12 |
Sebastian Huber |
rtems: Relax partition buffer area alignment
The partition buffer …
5
@27bbc05
08/02/18 12:49:01 |
Sebastian Huber |
score: Remove CPU_PARTITION_ALIGNMENT
Use the CPU_SIZEOF_POINTER …
5
@28b8cf9b
08/02/18 07:41:08 |
Sebastian Huber |
riscv: Fix CPU_ALIGNMENT
Update #3433.
5
@334e1d2
07/30/18 05:35:26 |
Sebastian Huber |
confdefs: Fix uniprocessor configuration
Introduce a new internal …
5
@cfc9573
07/27/18 12:47:17 |
Sebastian Huber |
riscv: Rework CPU counter support
Update #3433.
5
@6b9ef09
07/20/18 08:57:59 |
Sebastian Huber |
riscv: Add CLINT and PLIC support
The CLINT and PLIC need some …
5
@c2670de
07/20/18 07:07:40 |
Sebastian Huber |
riscv: Use wfi instruction for idle task
Update #3433.
5
@8db3f0e
07/19/18 10:11:19 |
Sebastian Huber |
riscv: Rework exception handling
Remove …
5
@5694b0c
07/19/18 08:15:53 |
Sebastian Huber |
riscv: New CPU_Exception_frame
Use the CPU_Interrupt_frame for the …
5
@d779a1e2
07/19/18 07:35:54 |
Sebastian Huber |
riscv: Add exception codes
Update #3433.
5
@5677883
07/24/18 07:09:06 |
Sebastian Huber |
score: _SMP_Inter_processor_interrupt_handler()
Optimize …
5
@a1f7d7d
07/24/18 07:00:18 |
Sebastian Huber |
score: RTEMS_PREDICT_TRUE(), RTEMS_PREDICT_FALSE()
Add …
5
@406dd62
07/24/18 09:18:27 |
Sebastian Huber |
_SMP_Start_multitasking_on_secondary_processor()
Pass current …
5
@0d362ff3
07/23/18 12:54:51 |
Sebastian Huber |
Pass current …
5
@f8d00a3
07/25/18 06:00:22 |
Sebastian Huber |
tm27: Fix prototype warnings
5
@05259de1
07/25/18 07:54:56 |
Sebastian Huber |
powerpc: Fix _CPU_Instruction_illegal()
Apparently the .word …
5
@3a646426
07/19/18 10:53:34 |
Sebastian Huber |
score: Add _CPU_Instruction_illegal()
On some …
5
@b74353e
07/20/18 06:06:46 |
Sebastian Huber |
score: Add _CPU_Instruction_no_operation()
This helps to reduce the …
5
@42f2fdfd
07/20/18 05:56:43 |
Sebastian Huber |
score: Move context validation declarations
The context validation …
5
@248ca7a
07/20/18 07:10:29 |
Sebastian Huber |
score: Remove obsolete CPU port defines
5
@1554a8c5
07/20/18 06:47:25 |
Sebastian Huber |
dtc: Update VERSION
5
@ec2de39
07/19/18 06:19:43 |
Sebastian Huber |
libfdt: fdt_address_cells() and fdt_size_cells()
Add internal …
5
@513daa3
07/19/18 11:06:49 |
Sebastian Huber |
capture: Include missing header file
5
@b4f15d8
07/19/18 05:10:26 |
Sebastian Huber |
jffs2: Rename README to VERSION
This makes it easer to find files …
5
@2af004e
07/18/18 07:32:28 |
Sebastian Huber |
dtc: Add VERSION file
Close #3471.
5
@80eaf45
07/09/18 04:50:38 |
david |
libfdt: Add necessary header padding in fdt_create()
At present …
5
@4fd05d3
07/07/18 19:57:19 |
sjg |
libfdt: Copy the struct region in fdt_resize()
At present this …
5
@78ad048
06/21/18 05:32:40 |
david |
libfdt: Add helpers for accessing unaligned words
This adds some …
5
@3848f14b
06/06/18 21:37:05 |
sjg |
pylibfdt: Add functions to update properties
Allow updating and …
5
@0d851d4
03/17/18 13:12:12 |
david |
libfdt: Add fdt_check_full() function
This new function implements a …
5
@9a7de8e
03/16/18 11:40:26 |
david |
libfdt: Add fdt_header_size()
We have a couple of places within …
5
@c81f432
03/09/18 12:28:56 |
david |
libfdt: Safer access to memory reservations
fdt_num_mem_rsv() and …
5
@6bc883b
03/25/18 11:54:22 |
david |
libfdt: Propagate name errors in fdt_getprop_by_offset()
5
@72273b6
11/14/17 11:45:56 |
david |
libfdt: Safer access to strings section
fdt_string() is used to …
5
@8073f95e
10/23/17 03:45:56 |
david |
libfdt: Make fdt_check_header() more thorough
Currently …
5
@c4267b1
04/10/18 07:06:18 |
david |
libfdt: Improve sequential write state checking
When creating a tree …
5
