Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/cpukit
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @8dec181   09/28/06 14:44:50 Chris Johns Flush stdout after updating the command line. 4.104.114.84.95
(edit) @7fb2bb2   09/25/06 14:19:45 Joel Sherrill 2006-09-14 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @7fa1ce86   09/25/06 14:03:51 Joel Sherrill 2006-09-25 Joel Sherrill <joel.sherrill@…> * … 4.104.114.84.95
(edit) @8042961d   09/25/06 13:38:24 Joel Sherrill 2006-09-25 Joel Sherrill <joel.sherrill@…> * … 4.104.114.84.95
(edit) @161f25b5   09/25/06 13:37:55 Joel Sherrill Add name. 4.104.114.84.95
(edit) @9c191ee   09/25/06 13:36:58 Joel Sherrill * score/Makefile.am, score/preinstall.am, … 4.104.114.84.95
(edit) @90d2585a   09/14/06 19:09:06 Joel Sherrill 2006-09-14 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @bc11ec2   09/14/06 15:07:19 Joel Sherrill 2006-09-14 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @5c1023a0   09/13/06 16:54:54 Joel Sherrill 2006-09-13 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @7ac4ae9   09/13/06 16:22:24 Joel Sherrill 2006-09-13 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @957d886   09/11/06 21:42:23 Joel Sherrill 2006-09-11 Joel Sherrill <joel@…> * libmisc/mw-fb/mw_fb.c, … 4.104.114.84.95
(edit) @ea1d598f   09/11/06 21:41:36 Joel Sherrill 2006-09-11 Joel Sherrill <joel@…> * cpu.c: Remove warning. 4.104.114.84.95
(edit) @ea7fd1ec   09/11/06 17:34:10 Joel Sherrill 2006-09-11 Jerry Needell <jerry.needell@…> * … 4.104.114.84.95
(edit) @bc69c485   09/08/06 20:28:56 Joel Sherrill 2006-09-08 Ken Peters <ken.peters@…> PR 1170/rtems * … 4.104.114.84.95
(edit) @c2f22829   09/06/06 12:55:52 Chris Johns 2006-09-06 Chris Johns <chrisj@…> * pppd/pppd.h: … 4.104.114.84.95
(edit) @b59eff1   09/06/06 05:13:42 Chris Johns Fix the bug in name change. The UNTIMEOUT macro did not use the ppp … 4.104.114.84.95
(edit) @d2efdeb1   09/01/06 21:21:43 Joel Sherrill 2006-09-01 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @d8f86d9   09/01/06 21:16:19 strauman * pppd/rtems.main.c, pppd/pppd.h: renamed 'untimeout' to … 4.104.114.84.95
(edit) @cf04e8ac   09/01/06 19:10:01 Joel Sherrill * empty log message * 4.104.114.84.95
(edit) @300c914c   09/01/06 18:15:01 Joel Sherrill * empty log message * 4.104.114.84.95
(edit) @b3ee778e   09/01/06 15:37:47 Joel Sherrill 2006-09-01 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @ddee935   08/31/06 01:53:35 Joel Sherrill 2006-08-30 Joel Sherrill <joel@…> * rtems/score/cpu.h: … 4.104.114.84.95
(edit) @a009d94   08/31/06 01:10:02 Joel Sherrill 2006-08-30 Joel Sherrill <joel@…> * ftpd/ftpd.c, … 4.104.114.84.95
(edit) @ae5a79c3   08/30/06 17:20:33 Joel Sherrill 2006-08-30 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @eba52fd3   08/30/06 17:16:50 Joel Sherrill 2006-08-30 Joel Sherrill <joel@…> * rtems/score/cpu.h: 4.104.114.84.95
(edit) @3523321   08/30/06 13:53:02 Joel Sherrill 2006-08-30 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @48b1e29   08/30/06 13:18:40 Joel Sherrill 2006-08-30 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @8a1ae87   08/29/06 21:55:30 Joel Sherrill 2006-08-29 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @0337a9c5   08/29/06 21:54:36 Joel Sherrill 2006-08-29 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @cd12590b   08/29/06 21:53:25 Joel Sherrill 2006-08-29 Joel Sherrill <joel@…> * rtems/score/cpu.h: … 4.104.114.84.95
(edit) @e197621   08/29/06 19:38:08 Joel Sherrill 2006-08-29 Joel Sherrill <joel@…> * libfs/src/dosfs/fat.h, … 4.104.114.84.95
(edit) @d5423d83   08/22/06 02:11:32 strauman * libnetworking/net/if_ethersubr.c: (ether_ioctl) Return error for … 4.104.114.84.95
(edit) @5f88544   08/15/06 11:08:14 Joel Sherrill 2006-08-15 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @7db4805e   08/12/06 19:41:01 Ralf Corsepius This commit was generated by cvs2svn to compensate for changes in … 4.104.114.84.95
(edit) @548599ee   08/12/06 19:41:01 Ralf Corsepius Import from zlib-1.2.5 4.104.114.84.95
(edit) @8e5ed77   08/12/06 19:41:00 Ralf Corsepius Import from zlib-1.2.4 4.104.114.84.95
(edit) @8f6c409e   08/10/06 22:04:07 strauman * libnetworking/rtems/rtems_mii_ioctl_kern.c: fixed wrong calculation … 4.104.114.84.95
(edit) @9469043   08/10/06 21:56:54 Joel Sherrill 2006-08-10 Joel Sherrill <joel@…> * cpu.c, … 4.104.114.84.95
(edit) @f77424ea   08/10/06 11:18:44 Joel Sherrill 2006-08-10 Joel Sherrill <joel@…> * .cvsignore: New file. 4.104.114.84.95
(edit) @a19034d   08/09/06 23:04:47 Joel Sherrill 2006-08-09 Joel Sherrill <joel@…> * rtems/score/cpu.h: … 4.104.114.84.95
(edit) @f4786d8   08/09/06 21:28:40 Joel Sherrill 2006-08-09 Kolja Waschk <waschk@…> * rtems/score/cpu.h, … 4.104.114.84.95
(edit) @60eae27d   08/09/06 21:03:27 Joel Sherrill 2006-08-09 Kolja Waschk <waschk@…> * configure.ac, … 4.104.114.84.95
(edit) @50f4487   08/09/06 20:58:11 Joel Sherrill 2006-08-09 Kolja Waschk <waschk@…> * ChangeLog?, Makefile.am, … 4.104.114.84.95
(edit) @a912777c   08/09/06 00:01:55 strauman * libnetworking/rtems/rtems_mii_ioctl_kern.c: read ANER and include … 4.104.114.84.95
(edit) @8eb78a20   07/14/06 09:52:00 Thomas.Doerfler added ChangeLog? entries for PR1117/1118/1119/1120 4.104.114.84.95
(edit) @47854a0d   07/13/06 01:27:30 strauman PR 1110/networking * libnetworking/machine/in_cksum.h: Replaced PPC … 4.104.114.84.95
(edit) @a031fc22   07/13/06 00:36:15 strauman * rtems/old-exceptions/cpu.h, rtems/powerpc/registers.h: Checked … 4.104.114.84.95
(edit) @60426fed   07/13/06 00:32:41 strauman * pppd/sys-rtems.c: fixed error message so that the correct ioctl is … 4.104.114.84.95
(edit) @83df49f   07/11/06 21:05:12 Joel Sherrill 2006-07-11 Joel Sherrill <joel@…> PR 1124/rtems * … 4.104.114.84.95
(edit) @c9b005a9   07/09/06 10:05:27 Thomas.Doerfler applied patches for PR1117/1118/1119/1120 4.104.114.84.95
(edit) @fc08203   07/06/06 11:09:46 Ralf Corsepius convert to utf-8 4.104.114.84.95
(edit) @bf1cade   06/29/06 09:08:07 Ralf Corsepius 2006-06-28 Ralf Corsépius <ralf.corsepius@…> * Makefile.am: … 4.104.114.84.95
(edit) @e0554ce   06/29/06 07:15:28 Ralf Corsepius 2006-06-28 Ralf Corsépius <ralf.corsepius@…> * ampolish3: … 4.104.114.84.95
(edit) @1de34b8   06/24/06 02:57:36 Ralf Corsepius 2006-06-24 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @b7176bd   06/23/06 15:33:19 Ralf Corsepius 2006-06-23 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @f3333d1   06/22/06 22:27:24 Joel Sherrill PR 1101/rtems * libcsupport/src/base_fs.c: Remove extra endif. 4.104.114.84.95
(edit) @1d63ebb   06/22/06 21:56:13 Joel Sherrill 2006-06-22 Joel Sherrill <joel@…> PR 1101/rtems * … 4.104.114.84.95
(edit) @e5f55a1   06/21/06 13:52:18 Joel Sherrill Fix formatting. 4.104.114.84.95
(edit) @412da6df   06/19/06 23:22:04 strauman PR1091/patch * cpu_asm.S: Reduce mask from 0xffc to 0x3fc so only the … 4.104.114.84.95
(edit) @80c2966   06/18/06 06:28:22 Ralf Corsepius 2006-06-18 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @a2eb2f0   06/18/06 05:49:03 Ralf Corsepius 2006-06-18 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @8a02d0af   06/18/06 05:48:20 Ralf Corsepius PR 1088/rtems Add missing #include <limits.h>. 4.104.114.84.95
(edit) @e1baed0   06/18/06 05:47:54 Ralf Corsepius Remove duplicate #include <limits.h>. 4.104.114.84.95
(edit) @cf5f68d   06/10/06 12:33:12 Joel Sherrill 2006-06-02 Greg Menke <gregory.menke@…> * cpu.c: Added … 4.104.114.84.95
(edit) @25571ae   06/10/06 10:42:07 gregory.menke Added mips==32 to fix build problems on those targets caused by the … 4.104.114.84.95
(edit) @0243b0d   06/08/06 20:47:48 Joel Sherrill 2006-06-08 Joel Sherrill <joel@…> * posix/Makefile.am, … 4.104.114.84.95
(edit) @7c99007   06/08/06 18:03:55 gregory.menke B.Robinson MIPS patch 4.104.114.84.95
(edit) @3a06b20   06/03/06 00:34:08 Joel Sherrill Formatting. 4.104.114.84.95
(edit) @a761495b   06/03/06 00:33:10 Joel Sherrill 2006-06-02 Joel Sherrill <joel@…> * itron/src/trcv_mbf.c, … 4.104.114.84.95
(edit) @aed1db6c   06/02/06 21:49:36 Jay Monkman 2006-06-02 Jay Monkman <jtm@…> * cpu.c, cpu_asm.S: Fixed … 4.104.114.84.95
(edit) @7a4b5cb4   06/02/06 21:48:05 Jay Monkman Fixed ARM Data Abort handling. 4.104.114.84.95
(edit) @491d882   05/31/06 14:52:05 WENorum Update icps_allecho counter. 4.104.114.84.95
(edit) @261e743   05/30/06 15:12:54 WENorum Add flag to inhibit ICMP replies. 4.104.114.84.95
(edit) @cf9af2f   05/28/06 16:54:00 Ralf Corsepius Import from zlib-1.2.4 4.104.114.84.95
(edit) @ebbe2af2   05/28/06 16:54:00 Ralf Corsepius This commit was generated by cvs2svn to compensate for changes in … 4.104.114.84.95
(edit) @be31de7   05/25/06 17:36:31 WENorum Provide customisable mbuf allocation. Patch from Steven Johnson … 4.104.114.84.95
(edit) @068cf700   05/16/06 14:26:57 Ralf Corsepius 2006-05-16 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @2861df2   04/27/06 18:40:30 WENorum telnetd and capture changes. 4.104.114.84.95
(edit) @b84fbbe8   04/27/06 18:18:49 WENorum Accept <CR><NUL> as equivalent to <CR><LF>. 4.104.114.84.95
(edit) @32293d69   04/27/06 18:17:20 WENorum Add ability to free information on task delete. 4.104.114.84.95
(edit) @84c86f2   04/19/06 02:55:03 Joel Sherrill 2006-04-18 Joel Sherrill <joel@…> * aclocal/version.m4: … 4.104.114.84.95
(edit) @c5a67176   04/18/06 21:47:28 Joel Sherrill 2006-04-18 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @dace6142   04/13/06 13:05:16 Joel Sherrill Fixed comment. 4.104.114.84.95
(edit) @f18ebd2   04/13/06 13:03:29 Joel Sherrill 2006-04-13 Joel Sherrill <joel@…> PR 949/networking * … 4.104.114.84.95
(edit) @6654e25e   04/13/06 13:03:28 Joel Sherrill 2006-04-13 Joel Sherrill <joel@…> PR 949/networking * … 4.104.114.84.95
(edit) @0637bb3   04/12/06 20:59:21 Joel Sherrill 2006-04-12 Lars Munch <lars@…> PR 949/networking * … 4.104.114.84.95
(edit) @5287d3e   04/07/06 01:16:55 Joel Sherrill 2006-04-06 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @5fbb9097   04/07/06 01:16:32 Joel Sherrill * score/inline/rtems/score/threadmp.inl, … 4.104.114.84.95
(edit) @52502994   04/05/06 20:08:59 Joel Sherrill 2006-04-05 Joel Sherrill <joel@…> Victor V. Vengerov … 4.104.114.84.95
(edit) @03f246fb   03/27/06 15:14:07 WENorum Eliminate undesired sign-extension. 4.104.114.84.95
(edit) @267ecf0   03/23/06 20:33:33 Ralf Corsepius Import from zlib-1.2.4 4.104.114.84.95
(edit) @23d2518   03/23/06 20:33:33 Ralf Corsepius This commit was generated by cvs2svn to compensate for changes in … 4.104.114.84.95
(edit) @a3de1b48   03/17/06 08:38:26 Ralf Corsepius 2006-03-17 Ralf Corsepius <ralf.corsepius@…> * cpu.c … 4.104.114.84.95
(edit) @01a76a6   03/17/06 05:24:30 Ralf Corsepius 2006-03-17 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @1ff385c   03/08/06 18:55:45 Joel Sherrill 2006-03-08 Joel Sherrill <joel@…> PR 761/rtems * … 4.104.114.84.95
(edit) @15096905   03/08/06 18:53:44 Joel Sherrill 2006-03-08 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @27207213   03/07/06 22:26:53 Joel Sherrill Added PR825 reference. 4.104.114.84.95
(edit) @360d9da   03/07/06 22:23:15 Joel Sherrill 2006-03-07 Till Strauman <strauman@…> PR … 4.104.114.84.95
(edit) @77b0a73   03/07/06 22:10:35 Joel Sherrill 2006-03-07 Steven Johnson <sjohnson@…> PR … 4.104.114.84.95
(edit) @0ebfac19   03/07/06 21:26:23 Joel Sherrill 2006-03-07 Thomas Doerfler <Thomas.Doerfler@…> PR … 4.104.114.84.95
