@825cb1f
03/04/14 12:02:18 |
Sebastian Huber |
score: Delete _Thread_Dispatch_set_disable_level()
This function was …
4.115
@718124e
03/03/14 09:18:01 |
Sebastian Huber |
rtems: Add RTEMS_INTERRUPT_REPLACE
A new option …
4.115
@8b50a55
03/03/14 08:09:24 |
Sebastian Huber |
score: Add _Atomic_Fence()
4.115
@a418b2f
03/03/14 07:38:10 |
Sebastian Huber |
libnetworking: Typo
4.115
@ba25cc2
02/19/14 10:21:34 |
Sebastian Huber |
score: Add and use _Giant_Drop()
New test smptests/smpfatal03.
4.115
@7336be9d
02/18/14 12:40:39 |
Sebastian Huber |
score: SMP initialization and shutdown changes
Rename …
4.115
@6b998fee
02/23/14 22:04:31 |
Joel Sherrill |
taskmode: Formatting correction
4.115
@e1d7bf0
02/26/14 10:08:31 |
Sebastian Huber |
rtems: Add cache size functions
Add rtems_cache_get_data_cache_size() …
4.115
@e7549ff4
02/26/14 10:00:17 |
Sebastian Huber |
rtems: Use size_t for cache line size
A cache line cannot have a …
4.115
@5e8301d
02/26/14 09:35:48 |
Sebastian Huber |
rtems: Cache manager documentation
Move useful functions to the top …
4.115
@a4bc90af
02/24/14 11:45:00 |
Sebastian Huber |
sparc: Fix CPU counter support
The SPARC processors supported by …
4.115
@95d0c98
02/24/14 09:13:32 |
Sebastian Huber |
score: Fix thread TLS area initialization
Do not use _TLS_Size here …
4.115
@47d60134
02/19/14 12:52:41 |
Sebastian Huber |
score: _CPU_SMP_Get_current_processor()
Remove …
4.115
@7ee4e72
02/20/14 16:05:44 |
Sebastian Huber |
score: _Thread_Start_multitasking()
Fix serious race-condition. Read …
4.115
@83bf105
02/19/14 09:57:46 |
Sebastian Huber |
score: Rename _Internal_error_Occurred()
Rename …
4.115
@52eecba
02/19/14 16:36:01 |
Jennifer Averett |
posix: Set pthread attribute values in detach and setschedparm methods.
4.115
@8a65a960
02/18/14 12:36:35 |
Sebastian Huber |
score: _SMP_Inter_processor_interrupt_handler()
Inline …
4.115
@c4ff027
02/18/14 12:30:28 |
Sebastian Huber |
score: Wait for per-CPU state changes later
Wait for per-CPU changes …
4.115
@b1d08a58
02/18/14 12:20:08 |
Sebastian Huber |
score: Initialize per-CPU locks
4.115
@282bfd3
02/18/14 12:03:27 |
Sebastian Huber |
score: Move _SMP_Handler_initialize()
4.115
@4d9bd56
02/17/14 14:12:43 |
Sebastian Huber |
score: Rename rtems_smp_process_interrupt()
Rename …
4.115
@911b1d2
02/17/14 14:02:54 |
Sebastian Huber |
score: Rename rtems_smp_secondary_cpu_initialize()
Rename …
4.115
@6ca4f6a
02/17/14 13:56:51 |
Sebastian Huber |
score: Add and use <rtems/score/smpimpl.h>
Collect SMP implementation …
4.115
@f8ff2a0
02/17/14 13:31:32 |
Sebastian Huber |
score: Delete bsp_smp_broadcast_interrupt()
Since the per-CPU SMP …
4.115
@4627fcd
02/17/14 13:25:29 |
Sebastian Huber |
score: Rename bsp_smp_initialize()
Rename bsp_smp_initialize() into …
4.115
@2afe065
02/17/14 13:12:21 |
Sebastian Huber |
score: Remove ASM guard
4.115
@2cb95b5f
02/17/14 12:58:01 |
Sebastian Huber |
score: Rename RTEMS_BSP_SMP_SHUTDOWN
Rename RTEMS_BSP_SMP_SHUTDOWN in …
4.115
@9eec2f3
02/17/14 12:46:11 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_SMP
Use rtems_fatal() instead of …
4.115
@33cb8bf
02/17/14 10:40:18 |
Sebastian Huber |
score: Add RTEMS_FATAL_SOURCE_BSP
Merge …
4.115
@b39e055
02/17/14 09:17:20 |
Sebastian Huber |
score: Delete INTERNAL_ERROR_SHUTDOWN_WHEN_NOT_UP
This error case is …
4.115
@8a6de83
02/17/14 09:10:27 |
Sebastian Huber |
score: Move _SMP_Request_other_cores_to_shutdown()
Move …
4.115
@38ee758
02/17/14 08:58:43 |
Sebastian Huber |
score: Disable ISR in _Internal_error_Occurred()
Disable interrupts …
4.115
@514705d
02/12/14 15:05:35 |
Sebastian Huber |
score: Delete _Thread_BSP_context
Do not return to BSP context in the …
4.115
@92f50c3
02/17/14 08:47:12 |
Sebastian Huber |
score: Add SYSTEM_STATE_TERMINATED
Merge systems states …
4.115
@801b5d8
02/17/14 08:23:59 |
Sebastian Huber |
powerpc: Change interrupt disable implemetation
Instead of SPRG0 (= …
4.115
@c2934b96
02/17/14 12:24:55 |
Sebastian Huber |
score: Move SMP interrupt stack initialization
Move SMP interrupt …
4.115
@57997d8
02/17/14 18:15:19 |
Jennifer Averett |
cpukit: Correct bug in check of affinity support in newlib.
4.115
@ad7292f
02/14/14 11:57:53 |
Sebastian Huber |
score: Add SMP barrier
4.115
@0344ce03
02/13/14 14:43:03 |
Sebastian Huber |
score: Use atomic API for SMP lock
Use a ticket lock implementation …
4.115
@8a9568d2
02/14/14 10:18:13 |
Sebastian Huber |
Require presence of <stdatomic.h> for SMP support
4.115
@dcd97c7
02/14/14 11:48:49 |
Sebastian Huber |
sparc: Add atomic support for SPARC V8
Use SWAP instruction with one …
4.115
@ad56361
02/13/14 12:00:00 |
Sebastian Huber |
sparc: Add LEON3_ASR17_PROCESSOR_INDEX_SHIFT
Add …
4.115
@945853b7
02/13/14 14:38:52 |
Sebastian Huber |
score: Add Atomic_Uint
4.115
@cd2c655
02/13/14 13:28:50 |
Sebastian Huber |
score: Fix warnings, C++ compatibility, fix typos
4.115
@6f90ef7
02/13/14 12:08:46 |
Sebastian Huber |
score: Remove volatile from asm statements
The instructions to get …
4.115
@24bf11e
02/12/14 09:31:38 |
Sebastian Huber |
score: Add CPU counter support
Add a CPU counter interface to allow …
4.115
@ece9754
02/11/14 13:48:35 |
Sebastian Huber |
sparc: Increase CPU_STRUCTURE_ALIGNMENT to 32
Recent LEON4 systems …
4.115
@bab16de2
02/07/14 08:53:47 |
Sebastian Huber |
score: Change debug helper functions
Rename …
4.115
@97cf623d
02/05/14 10:36:05 |
Sebastian Huber |
sparc: Save/restore only non-volatile context
The …
4.115
@01794eb
02/07/14 07:55:02 |
Sebastian Huber |
score: Format _Thread_Get_maximum_internal_threads
4.115
@920a43e
02/05/14 16:00:09 |
Sebastian Huber |
rtems: Add rtems_status_code_description()
4.115
@558cc8d
02/05/14 14:41:00 |
Sebastian Huber |
score: _CPU_Context_switch_to_first_task_smp()
Delete …
4.115
@022851a
01/28/14 11:10:08 |
Sebastian Huber |
Add thread-local storage (TLS) support
Tested and implemented on ARM, …
4.115
@16a41cc
01/29/14 08:29:39 |
Sebastian Huber |
score: Add _Thread_Get_maximum_internal_threads()
4.115
@a49bc35
01/28/14 10:49:57 |
Sebastian Huber |
score: Add _Heap_Size_with_overhead()
4.115
@a850d04
01/28/14 10:32:35 |
Sebastian Huber |
score: Add _Workspace_Allocate_aligned()
4.115
@ba386a6
01/31/14 18:28:47 |
Joel Sherrill |
dosfs/fat.c: Remove use of register keyword
4.115
@cfbeaf6
01/31/14 18:28:02 |
Joel Sherrill |
calloc.c: Remove use of register keyword
4.115
@e633f3b
01/31/14 17:03:24 |
Joel Sherrill |
posix/*.c: Remove use of register keyword
4.115
@3a638ce
01/31/14 16:55:17 |
Joel Sherrill |
rtems/*.c: Remove use of register keyword
4.115
@5b34e7a
01/16/14 12:05:13 |
Sebastian Huber |
IMFS: Improved support for generic nodes
The …
4.115
@45e82bb8
01/16/14 12:02:50 |
Sebastian Huber |
IMFS: Allow sockets as generic nodes
4.115
@a32f996b
01/20/14 02:00:35 |
Nick Withers |
Don't use unsafe buffer operations
Don't use unsafe buffer …
4.115
@805ef2f2
11/30/13 19:53:41 |
Sebastian Huber |
arm: Add ARMv7-M SHCSR register bits
4.115
@8d7c3ca
01/09/14 21:59:21 |
Joel Sherrill |
tasksetpriority.c: Remove obsolete comment
4.115
@a19a7077
12/18/13 00:01:11 |
strauman |
posix: fix race condition between pthread_create and capture engine
4.115
@66bf2cc9
12/19/13 00:54:53 |
allanh |
mw_uid: corrects uid_read_message short timeouts
4.115
@2b03a62
11/01/13 13:59:41 |
Jim Panetta |
NTP: Sync time correctly when receiving broadcast updates
1) The …
4.115
@35b8f48a
12/06/13 18:21:20 |
Daniel Ramirez |
libcsupport: Refactor rtems_deviceio_errno
Renames …
4.115
@564ce0f
12/06/13 02:21:05 |
Daniel Ramirez |
libcsupport: implemented termios functions cfsetspeed and cfmakeraw
4.115
@6a26e9b
12/24/13 07:08:29 |
Chris Johns |
cpukit/capture: Print the uptime and diff in ctrace.
Print the uptime …
4.115
@9f9c0bb
12/24/13 05:42:23 |
Chris Johns |
cpukit/capture: Use the new RTEMS API to get the uptime in …
4.115
@2d1bdc8
12/24/13 05:38:42 |
Chris Johns |
cpukit/rtems: Add rtems_clock_get_uptime_nanoseconds to the RTEMS API. …
4.115
@2bafb960
12/21/13 03:44:12 |
Daniel Ramirez |
rtems: classic api to/from core priority conversions
4.115
@c1d8ee4
12/17/13 09:59:13 |
Sebastian Huber |
libcsupport: Accept NULL for zero-length entries
4.115
@56bea43
12/16/13 13:26:29 |
Sebastian Huber |
Filesystem: Use default kqfilter and poll handler
4.115
@2f68778
12/16/13 12:44:13 |
Sebastian Huber |
Filesystem: Add readv/writev handlers
The readv() and writev() …
4.115
@95a57280
12/16/13 12:12:22 |
Sebastian Huber |
libcsupport: Add and use rtems_libio_iovec_eval()
4.115
@db8a89e
12/19/13 08:01:23 |
Chris Johns |
cpukit/capture: Update the capture engine.
The capture did not work …
4.115
@a9619f3c
12/18/13 17:00:42 |
alan.cudmore |
For PR 2164 - RFS File System - fix bitmap_create_search loop bug
4.115
@9b48dc6
12/18/13 17:37:47 |
alan.cudmore |
For PR 2162 - RFS File System - statvfs reports 1 block free
This is …
4.115
@e60b7b1
12/18/13 16:39:19 |
alan.cudmore |
For PR 2163 - RFS File System - fix group search algorithm bug
This …
4.115
@f859d20
12/16/13 13:45:26 |
Sebastian Huber |
arm: Fix set by but not used warning
4.115
@fb664a2
12/16/13 09:55:27 |
Sebastian Huber |
nfsclient: Move defines to cover all header files
4.115
@99c2323
12/13/13 12:57:06 |
Sebastian Huber |
JFFS2: Do not re-define struct iovec
4.115
@259328a7
12/16/13 00:59:51 |
Chris Johns |
cpukit/shell: Control help break with SHELL_LINES env variable.
4.115
@4402308b
12/14/13 17:56:33 |
Joel Sherrill |
no_cpu/cpusmplock.h: Clean up to be compilable
4.115
@801a1fc6
12/09/13 20:22:33 |
Joel Sherrill |
cpukit/configure.ac: Probe for SMP affinity methods
4.115
@98e5c95
12/11/13 08:39:09 |
Sebastian Huber |
PR2160: imfs: Use ENOSYS for unsupported nodes
Return an error status …
4.115
@0f01de2b
12/10/13 15:08:16 |
Joel Sherrill |
alarm.c: Use _Assert() not assert()
4.115
@c59f668
12/10/13 04:00:27 |
Chris Johns |
PR2138: rtems_rfs_rtems_initialize() can erroneously set errno.
Patch …
4.115
@798b8da
12/10/13 01:53:13 |
Joel Sherrill |
Merge branch 'master' into am
4.115
@967c1438
12/09/13 21:36:38 |
Joel Sherrill |
alarm.c: Per comment add debug code for kill() failing
This is highly …
4.115
@8ae999c3
12/09/13 21:28:55 |
Joel Sherrill |
pthread.c: Use UINT32_MAX rather than constant value
4.115
@327fbd6
12/09/13 21:25:16 |
Joel Sherrill |
condwaitsupp.c: Return EPERM if waiting and mutex is not locked
This …
4.115
@96281908
12/09/13 21:12:36 |
Joel Sherrill |
psignalimpl.h: Remove dead comment
4.115
@fa820b9
12/09/13 21:10:55 |
Joel Sherrill |
pthread.c: Remove XXX and use SIGNAL_ constants
4.115
@01d43180
12/09/13 21:04:40 |
Joel Sherrill |
posix/config.h: Comment clean up
4.115
@2b3a648
12/09/13 20:37:03 |
Joel Sherrill |
signalcatch.c: Remove junk comment
4.115
@16b1c350
12/09/13 19:46:50 |
Joel Sherrill |
timerimpl.h: Comment clean up
4.115
