Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/cpukit
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @77b1020a   03/18/07 07:34:25 Ralf Corsepius 2007-03-18 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @0d88a77   03/17/07 07:41:45 Ralf Corsepius Fix oversights. 4.104.114.84.95
(edit) @8976329   03/17/07 07:30:22 Ralf Corsepius 2007-03-17 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @d7664246   03/17/07 07:30:08 Ralf Corsepius Remove P(). 4.104.114.84.95
(edit) @23f5cc5c   03/17/07 07:05:04 Ralf Corsepius 2007-03-17 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @508cd3a1   03/17/07 07:04:49 Ralf Corsepius Remove P(). 4.104.114.84.95
(edit) @30ceeaa   03/17/07 06:46:45 Ralf Corsepius 2007-03-17 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @d7c655d   03/17/07 06:41:11 Ralf Corsepius 2007-03-17 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @34140dbe   03/16/07 07:19:35 Ralf Corsepius 2007-03-16 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @37c7bfcb   03/16/07 07:19:24 Ralf Corsepius Change _Workspace_Handler_initialization and … 4.104.114.84.95
(edit) @c294e8d   03/16/07 03:39:04 Ralf Corsepius 2007-03-16 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @d89360c   03/16/07 03:38:31 Ralf Corsepius Remove (Unused). 4.104.114.84.95
(edit) @a6679ac   03/16/07 03:38:11 Ralf Corsepius Regenerate. 4.104.114.84.95
(edit) @9d155ac0   03/16/07 03:37:23 Ralf Corsepius Remove sys/rtprio.h. 4.104.114.84.95
(edit) @32dbe39   03/14/07 11:47:00 Ralf Corsepius 2007-03-14 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @e67a778   03/14/07 11:46:48 Ralf Corsepius Remove P(). 4.104.114.84.95
(edit) @307c7af1   03/13/07 19:45:55 Joel Sherrill Upgrade to 4.7.99.1 4.104.114.84.95
(edit) @26b8262   03/13/07 05:39:27 Ralf Corsepius 2007-03-13 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @83d01d5   03/13/07 05:38:21 Ralf Corsepius 2007-03-13 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @d38ac0e   03/13/07 05:17:12 Ralf Corsepius 2007-03-13 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @dfb3c2b   03/12/07 20:23:58 Joel Sherrill 2007-03-12 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @1fb90ec7   03/12/07 11:16:02 Joel Sherrill 2007-03-12 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @e2a8b99   03/10/07 16:16:10 Joel Sherrill 2007-03-10 Joel Sherrill <joel@…> PR 1226/cpukit * … 4.104.114.84.95
(edit) @6c7928b   03/08/07 21:44:02 Joel Sherrill 2007-03-08 Joel Sherrill <joel@…> * libfs/src/imfs/imfs.h: … 4.104.114.84.95
(edit) @6b7d3a31   03/08/07 21:43:31 Joel Sherrill 2007-03-08 Joel Sherrill <joel@…> * libfs/src/imfs/imfs.h: … 4.104.114.84.95
(edit) @8583f82   03/08/07 21:43:05 Joel Sherrill 2007-03-08 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @3d1e8ba   03/08/07 21:41:46 Joel Sherrill 2007-03-08 Joel Sherrill <joel@…> * rtems/Makefile.am, … 4.104.114.84.95
(edit) @96d0b64   03/05/07 21:01:40 Joel Sherrill 2007-03-05 Joel Sherrill <joel@…> PR 1222/cpukit * … 4.104.114.84.95
(edit) @471998ec   03/05/07 20:55:18 Joel Sherrill 2007-03-05 Joel Sherrill <joel@…> * sapi/src/exinit.c: Fix … 4.104.114.84.95
(edit) @7f5fc4e   03/05/07 20:53:05 Joel Sherrill 2007-03-05 Joel Sherrill <joel@…> PR 1221/cpukit * … 4.104.114.84.95
(edit) @5d750c70   02/22/07 15:24:19 Ralf Corsepius 2007-02-22 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @1fa64f9   02/22/07 09:12:51 Ralf Corsepius Revert to version 4.7.99-0 4.104.114.84.95
(edit) @5e854044   02/22/07 07:42:53 Ralf Corsepius Testing: Upgrade to 4.7.99.1 4.104.114.84.95
(edit) @c943413   02/21/07 17:03:25 Ralf Corsepius 2007-02-21 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @4768a274   02/16/07 01:55:47 Ralf Corsepius 2007-02-16 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @a297369c   02/11/07 08:37:48 Ralf Corsepius 2007-02-11 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @59c44c6   02/11/07 08:35:15 Ralf Corsepius More size_t for heap-sizes. 4.104.114.84.95
(edit) @3672dd97   02/11/07 04:52:48 Ralf Corsepius 2007-02-11 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @8022a68   02/11/07 04:52:37 Ralf Corsepius Use size_t for heap-sizes. 4.104.114.84.95
(edit) @f692e004   02/11/07 04:47:54 Ralf Corsepius 2007-02-11 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @c1f3bf3c   02/09/07 15:06:49 Ralf Corsepius 2007-02-09 Ralf Corsepius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @fb24f698   02/09/07 15:06:37 Ralf Corsepius Use size_t for stack-sizes. 4.104.114.84.95
(edit) @ba2f913   02/07/07 04:34:46 Ralf Corsepius 2007-02-07 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @9a673dba   02/07/07 03:36:52 Ralf Corsepius 2007-02-07 Ralf Corsépius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @64e442a   02/06/07 22:57:35 strauman 2007-02-06 Till Straumann <strauman@…> * … 4.104.114.84.95
(edit) @b3b82e7a   02/06/07 14:46:24 Ralf Corsepius 2007-02-06 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @cddd2d0   02/06/07 14:45:54 Ralf Corsepius Remove getpagesize.c. 4.104.114.84.95
(edit) @f350dcf8   02/06/07 14:45:34 Ralf Corsepius Add getpagesize.c. 4.104.114.84.95
(edit) @bee19fe   02/06/07 14:45:10 Ralf Corsepius Removed (moved to libcsupport/src). 4.104.114.84.95
(edit) @6fb68a5   02/06/07 14:44:34 Ralf Corsepius New (moved from posix/src). 4.104.114.84.95
(edit) @70261d1   02/06/07 14:36:02 Ralf Corsepius 2007-02-06 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @f629a8b   02/06/07 13:51:30 Ralf Corsepius 2007-02-06 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @f0bc3835   02/06/07 13:40:57 Ralf Corsepius 2007-02-06 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @a33a6e43   02/06/07 11:27:54 Ralf Corsepius 2007-02-06 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @2e22795   02/06/07 11:27:42 Ralf Corsepius Use size_t for sizes. 4.104.114.84.95
(edit) @8ae331d8   02/06/07 10:23:05 Ralf Corsepius Use size_t for sizes. 4.104.114.84.95
(edit) @8f99833b   02/06/07 08:57:56 Ralf Corsepius 2007-02-06 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @6703e491   02/06/07 08:57:40 Ralf Corsepius Use size_t for sizes. 4.104.114.84.95
(edit) @638aaba1   02/06/07 05:57:20 Ralf Corsepius 2007-02-06 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @c8b0f1cb   02/06/07 05:57:07 Ralf Corsepius Use size_t for sizes. 4.104.114.84.95
(edit) @85c03ce3   02/06/07 05:18:03 Ralf Corsepius 2007-02-06 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @d9b3141   02/06/07 05:17:48 Ralf Corsepius Use size_t for sizes. 4.104.114.84.95
(edit) @e26913b0   02/06/07 04:47:52 Ralf Corsepius 2007-02-06 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @f4e0118   02/06/07 04:46:56 Ralf Corsepius Use size_t for sizes. 4.104.114.84.95
(edit) @2af864d   02/06/07 03:50:47 Ralf Corsepius Use size_t for sizes. 4.104.114.84.95
(edit) @4b0971d4   02/06/07 03:50:32 Ralf Corsepius 2007-02-06 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @11f2f0cd   02/05/07 18:05:37 Ralf Corsepius 2007-02-05 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @df095da   02/05/07 18:05:21 Ralf Corsepius Use size_t for sizes. 4.104.114.84.95
(edit) @8eacfb52   02/05/07 15:35:49 Ralf Corsepius 2007-02-05 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @32e101b   02/05/07 15:35:36 Ralf Corsepius Use size_t for sizes. 4.104.114.84.95
(edit) @1cf2581b   01/30/07 09:11:10 Ralf Corsepius 2007-01-30 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @53cd606   01/30/07 07:55:58 Ralf Corsepius 2007-01-30 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @7c7aabd   01/29/07 04:27:26 Ralf Corsepius 2007-01-29 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @07d0ce8   01/28/07 03:57:09 Ralf Corsepius 2007-01-28 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @460175ef   01/27/07 18:18:05 Ralf Corsepius 2007-01-27 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @7364df6   01/27/07 07:26:37 Ralf Corsepius 2007-01-27 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @ea35fdc6   01/27/07 07:21:27 Ralf Corsepius Dynamically derive RTEMS_MAJOR, RTEMS_MINOR, … 4.104.114.84.95
(edit) @8db96e5   01/27/07 07:21:05 Ralf Corsepius Remove RTEMS_MAJOR, RTEMS_MINOR, RTEMS_REVISION (moved to … 4.104.114.84.95
(edit) @0454464   01/26/07 05:52:43 Ralf Corsepius 2007-01-26 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @6200dc9   01/22/07 23:02:02 Joel Sherrill Formatting. 4.104.114.84.95
(edit) @3d14a45   01/21/07 18:25:31 Thomas.Doerfler mproved gen5200 MSCAN driver fixed synchronization bug between ata.c … 4.104.114.84.95
(edit) @6a03edd5   01/17/07 06:19:38 strauman 2007-01-16 Till Straumann <strauman@…> * … 4.104.114.84.95
(edit) @05cdf2a8   01/17/07 06:15:19 strauman 2007-01-16 Till Straumann <strauman@…> * … 4.104.114.84.95
(edit) @e411dda   01/09/07 21:54:52 Joel Sherrill 2007-01-09 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @63a88eb   01/08/07 08:43:28 Ralf Corsepius Regenerate. 4.104.114.84.95
(edit) @e9c1b5f   01/02/07 06:34:57 Ralf Corsepius 2007-01-02 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @d07cb3a   12/13/06 07:27:42 Ralf Corsepius 2006-12-13 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @ff32049b   12/13/06 07:27:06 Ralf Corsepius Abandon. 4.104.114.84.95
(edit) @c50c6bf   12/13/06 07:24:32 Ralf Corsepius 2006-12-13 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @f065e42   12/13/06 07:24:10 Ralf Corsepius Abandon backward compatibility types. 4.104.114.84.95
(edit) @8373c318   12/13/06 07:22:54 Ralf Corsepius Regenerate. 4.104.114.84.95
(edit) @7ecaafa   12/13/06 07:21:53 Ralf Corsepius Abandon DEPRECATED_TYPES. 4.104.114.84.95
(edit) @d547ff9f   12/13/06 07:21:38 Ralf Corsepius Abandon DEPRECATED_TYPES/--enable-deprecated. 4.104.114.84.95
(edit) @294de470   12/13/06 05:39:19 Ralf Corsepius 2006-12-13 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @b25d6119   12/13/06 05:37:07 Ralf Corsepius Use am_aux_dir/ampolish3. 4.104.114.84.95
(edit) @f4cf0ea   12/13/06 03:23:44 Ralf Corsepius Fix ugly typos. 4.104.114.84.95
(edit) @48415d1e   12/12/06 16:42:16 Ralf Corsepius 2006-12-12 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @a208413   12/12/06 16:41:22 Ralf Corsepius Remove RTEMS_AMPOLISH. 4.104.114.84.95
(edit) @e00746b3   12/12/06 16:37:22 Ralf Corsepius 2006-12-12 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @ada8d531   12/12/06 16:36:38 Ralf Corsepius Add RTEMS_AMPOLISH. 4.104.114.84.95
