source: rtems/cpukit
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @60c4ba1   Sep 13, 2018, 4:30:08 AM Sebastian Huber build: Merge dev/Makefile.am
(edit) @54c0b57   Sep 12, 2018, 2:03:42 PM Sebastian Huber build: Move sapi/Makefile.am
(edit) @68e1ccc   Sep 11, 2018, 4:30:20 AM Sebastian Huber build: Remove specialized CPPFLAGS
(edit) @6cdaa85   Oct 4, 2018, 6:16:45 PM Sebastian Huber shell: Use #include "..." for local header files Update #3375.
(edit) @2806e10   Oct 9, 2018, 6:38:11 AM Sebastian Huber telnetd: Ignore setsockopt() return status Update #3529.
(edit) @84a5921d   Oct 9, 2018, 6:12:46 AM Sebastian Huber ftpd: Restructure chroot() handling. Remove superfluous setting of …
(edit) @6dc0b5f   Jul 21, 2017, 12:18:50 PM javier.jalle leon, spwtdp: Initial driver commit
(edit) @acb53d5   Oct 9, 2018, 6:43:08 AM Sebastian Huber posix: Remove static assertion Standard C does not allow pointer …
(edit) @5bd75823   Oct 8, 2018, 8:02:07 AM Sebastian Huber ftpd: Remove superfluous temporary buffer Update #3530.
(edit) @2f784d7   Oct 8, 2018, 6:14:40 AM Sebastian Huber ftpd: Check return status of getsockname() Update #3530.
(edit) @be8de0ff   Oct 5, 2018, 1:16:46 PM Sebastian Huber ftpd: Fix insecure chroot() handling Ensure that the …
(edit) @df97c4d2   Oct 5, 2018, 12:56:10 PM Sebastian Huber ftpd: Avoid resource leak Update #3530.
(edit) @479a28e0   Oct 5, 2018, 12:54:49 PM Sebastian Huber ftpd: Avoid use of uninitialized memory Update #3530.
(edit) @51da629   Oct 5, 2018, 12:47:21 PM Sebastian Huber ftpd: Avoid malloc() and sscanf() Move the user name to the session …
(edit) @dcf42bb2   Oct 5, 2018, 12:39:46 PM Sebastian Huber ftpd: Remove FTPD_SessionInfo_t::pass member There is no need to keep …
(edit) @e761fb4   Oct 5, 2018, 12:05:22 PM Sebastian Huber ftpd: Avoid NULL pointer checks before free() They are superfluous …
(edit) @05b5f9c0   Oct 5, 2018, 11:56:59 AM Sebastian Huber jffs2: Avoid use of constant register variable Avoid the use of a …
(edit) @4a7c6867   Oct 5, 2018, 7:37:44 AM Sebastian Huber Fix rbtree_postorder_for_each_entry_safe() Use the non-standard …
(edit) @1d39e96   Oct 5, 2018, 6:11:09 AM Sebastian Huber score: Fix legacy RTEMS_STATIC_ASSERT() In standard C pointer …
(edit) @8776bb9   Sep 26, 2018, 4:34:54 AM Sebastian Huber score: Remove CPU_PROVIDES_IDLE_THREAD_BODY Remove the …
(edit) @b38887a   Oct 5, 2018, 11:39:49 AM Sebastian Huber dev/sc16is752: Deal with a baud of zero Avoid division by zero and …
(edit) @8777d4c   Oct 4, 2018, 9:29:03 AM Sebastian Huber Add rtems_interrupt_server_request_set_vector() By default, the …
(edit) @313f897   Sep 13, 2018, 12:50:08 PM Sebastian Huber Optimize calloc() Use return value of memset() to enable tail call …
(edit) @1ad43f8   Sep 13, 2018, 12:49:16 PM Sebastian Huber Avoid need for -fno-builtin for calloc() Use …
(edit) @5418890   Sep 13, 2018, 4:22:21 AM Sebastian Huber Remove superfluous pipe_create()
(edit) @242887bc   Sep 13, 2018, 4:19:05 AM Sebastian Huber Rename files to make them unique within cpukit This allows to build …
(edit) @f373bdc0   Sep 10, 2018, 3:46:19 PM Sebastian Huber libdl: Avoid command line defines Update #3375.
(edit) @2e77151   Sep 10, 2018, 4:31:53 AM Sebastian Huber mghttpd: Add configuration to source file Update #3375.
(edit) @06060da   Sep 10, 2018, 4:29:11 AM Sebastian Huber pppd: Simplify Makefile.am Update #3375.
(edit) @e069f7fe   Sep 10, 2018, 4:27:10 AM Sebastian Huber rpc: Use configuration header file Update #3375.
(edit) @f004b2b8   Oct 2, 2018, 8:22:15 AM Sebastian Huber Use rtems_task_exit() Update #3530. Update #3533.
(edit) @e50e3f70   Oct 1, 2018, 7:25:06 AM Sebastian Huber rtems: Add rtems_task_exit() Update #3533.
(edit) @57a7ecde   Oct 1, 2018, 6:20:11 AM Sebastian Huber telnetd: Remove CEXP convenience routines Close #3535.
(edit) @a346ebba   Sep 26, 2018, 7:04:43 AM Sebastian Huber telnetd: Remove CONFIGURE_MAXIMUM_PTYS Add a …
(edit) @2da93bcb   Sep 26, 2018, 7:18:12 AM Sebastian Huber telnetd: Regroup includes
(edit) @8e075540   Sep 26, 2018, 7:17:55 AM Sebastian Huber telnetd: Remove dead code
(edit) @0413b14   Sep 26, 2018, 7:06:43 AM Sebastian Huber telnetd: Remove superfluous global variable Update #3528.
(edit) @b980f363   Sep 25, 2018, 1:07:35 PM Sebastian Huber telnetd: Convert pty driver to new Termios API Update #3526.
(edit) @ac9f808   Sep 25, 2018, 1:19:08 PM Sebastian Huber pppd: Remove unused get_pty() function Update #3526.
(edit) @c56721c   Sep 27, 2018, 5:21:27 AM Sebastian Huber printer: Fix Doxygen comments
(edit) @7d1acc03   Sep 24, 2018, 7:15:10 AM Sebastian Huber stackchk: Fix interrupt stack preparation We have to prepare the …
(edit) @4221d93   Sep 20, 2018, 6:47:44 AM Sebastian Huber stackchk: Improve support for interrupt stacks Prepare the interrupt …
(edit) @a75a7d3   Sep 21, 2018, 5:30:44 AM Sebastian Huber stackchk: Remove heap hack It is now guranteed that threads do not …
(edit) @56e61e24   Sep 20, 2018, 5:57:08 AM Sebastian Huber Remove INTERNAL_ERROR_INTERRUPT_STACK_TOO_SMALL The configured …
(edit) @227b145   Aug 31, 2018, 6:56:08 AM Daniel Hellstrom sparc: clang AS does no accept UNIMP without argument
(edit) @1c34a9b   Dec 19, 2017, 12:36:33 PM cederman sparc: Remove sequence that could trigger B2BST errata
(edit) @e20da8b   Dec 12, 2017, 10:19:46 AM cederman sparc: Return to previous section type when done with .data._SPARC_Counter
(edit) @776464a   Sep 19, 2018, 9:52:47 AM Sebastian Huber score: Allocate per-CPU data only if necessary The …
(edit) @68f339b6   Sep 17, 2018, 9:53:10 AM Sebastian Huber Remove CONFIGURE_HAS_OWN_CONFIGURATION_TABLE The RTEMS configuration …
(edit) @5fa0a1f6   Sep 17, 2018, 8:35:45 AM Sebastian Huber config: Remove CONFIGURE_HAS_OWN_MOUNT_TABLE RTEMS had the …
(edit) @bd5cec41   Sep 17, 2018, 8:31:29 AM Sebastian Huber config: Remove CONFIGURE_HAS_OWN_FILESYSTEM_TABLE This configuration …
(edit) @fe283f6c   Sep 14, 2018, 11:20:05 AM Sebastian Huber powerpc: Fix _CPU_Counter_read() for MPC860 The mpc860 is a …
(edit) @aaa6653   Sep 13, 2018, 9:33:11 AM Sebastian Huber score: Fix PER_CPU_DATA_ITEM_DECLARE() Fix …
(edit) @1fe1b820   Sep 10, 2018, 9:47:24 AM Sebastian Huber score: Fix PER_CPU_DATA_GET_BY_OFFSET() Add uniprocessor version for …
(edit) @e58f1cd3   Sep 5, 2018, 5:27:24 AM Sebastian Huber Add more dummy values to <sys/priority.h> Update #3472.
(edit) @7097962   Aug 29, 2018, 7:43:44 AM Sebastian Huber score: Add thread pin/unpin support Add support to temporarily pin a …
(edit) @d8bc0730   Sep 7, 2018, 9:27:45 AM Sebastian Huber score: Modify _Scheduler_Unblock() In SMP configurations, obtain the …
(edit) @cfc4231d   Aug 27, 2018, 8:36:35 AM Sebastian Huber score: Add flexible per-CPU data Update #3507.
(edit) @77d374f5   Sep 7, 2018, 5:12:06 AM Sebastian Huber cpukit/Makefile.am: Cleanup
(edit) @cb68253   Sep 7, 2018, 4:19:02 AM Sebastian Huber network: Use kernel/user space header files Add and use …
(edit) @43fb904e   Sep 7, 2018, 5:06:05 AM Sebastian Huber network: Remove man page installation The man page installation is …
(edit) @eae4d147   Sep 7, 2018, 4:24:00 AM Sebastian Huber network: Remove unused files
(edit) @d9296d24   Sep 7, 2018, 4:39:50 AM Sebastian Huber Move <poll.h> to set of default header files The <poll.h> is a POSIX …
(edit) @ea0a680   Sep 10, 2018, 8:36:41 AM Sebastian Huber score: Debug aid for _Chain_Extract_unprotected() Ensure that a chain …
(edit) @2d1c3df   Sep 7, 2018, 5:33:47 AM Sebastian Huber nfsclient: Fix unused variable warning
(edit) @e0a9336b   Sep 3, 2018, 6:12:35 AM Sebastian Huber score: Fix EDF SMP scheduler Fix a special case: block a one-to-one …
(edit) @3aad9d9b   Sep 3, 2018, 7:31:19 AM Sebastian Huber score: Generalize SMP scheduler block support Add extract from …
(edit) @9b5b864   Aug 29, 2018, 5:42:10 PM joel rtems/score/epiphany-utility.h: Fix not a prototype warning
(edit) @bc696482   Aug 29, 2018, 5:41:35 PM joel score/cpu/bfin/cpu.c: Fix _CPU_Thread_Idle_body() prototype
(edit) @14a218f   Aug 21, 2018, 3:32:48 PM joel cpukit/telnetd/pty.c: Fix format overflow warning on sprintf() …
(edit) @9e8bba5   Aug 29, 2018, 5:53:02 AM Sebastian Huber score: Remove redundant #ifdef RTEMS_SMP
(edit) @6d70a11   Aug 27, 2018, 5:33:29 AM Sebastian Huber Include <stdbool.h> in <machine/_kernel_types.h> The FreeBSD kernel …
(edit) @27c89d7   Aug 8, 2018, 9:52:09 AM Sebastian Huber Add FreeBSD kernel space header files Move the kernel space content …
(edit) @0d51b6d8   Jun 28, 2018, 12:39:37 PM Daniel Hellstrom capture: prevent unaligned access when reading time LLVM warns about …
(edit) @59a0541c   Jul 12, 2018, 7:15:55 AM cederman sparc: Restore npc when returning from the syscall_lazy_fp_switch trap …
(edit) @6695d02   Aug 23, 2018, 12:39:33 PM Sebastian Huber Update FreeBSD kernel timespec support This change is based on the …
(edit) @ba0e9631   Aug 10, 2018, 5:34:03 AM Sebastian Huber score: Do not inline _Thread_Dispatch_enable() This function is …
(edit) @a36aa86   Aug 23, 2018, 12:32:07 PM Sebastian Huber Add dummy PI_SOFT to <sys/priority.h> Update #3472.
(edit) @d14f934   Aug 10, 2018, 5:22:43 AM Sebastian Huber score: Fix ISR enable in _Thread_Dispatch_enable() This bug had …
(edit) @dcaea71   Aug 15, 2018, 10:26:13 AM christian.mauderer dev/sc16is752: Add name space for field names. The field names for …
(edit) @bc731313   Aug 13, 2018, 10:55:34 AM amaan.cheval bsps/x86_64: Add APIC timer based clock driver The APIC timer is …
(edit) @6869321   Aug 13, 2018, 10:50:38 AM amaan.cheval bsps/x86_64: Add support for RTEMS interrupts Updates #2898.
(edit) @4544749e   Aug 13, 2018, 10:33:12 AM amaan.cheval bsps/x86_64: Add paging support with 1GiB super pages Updates #2898.
(edit) @ab971bf5   Aug 13, 2018, 10:21:47 AM amaan.cheval bsps/x86_64: Reorganize header files and compile-options Updates #2898.
(edit) @b2de426   Aug 6, 2018, 9:53:42 AM Sebastian Huber score: Fix _Addresses_Subtract() Use architecture-specific integer …
(edit) @66cb142   Aug 6, 2018, 8:51:00 AM Sebastian Huber rtems: Parameter types in rtems_partition_create() Use uintptr_t to …
(edit) @b8eae140   Aug 10, 2018, 5:11:56 AM Sebastian Huber Add dummy PRI_MIN_KERN to <sys/priority.h> Update #3472.
(edit) @aac36d15   Aug 8, 2018, 9:17:36 AM Sebastian Huber posix: Add configure check for mprotect() Update #3491.
(edit) @71948f76   Aug 8, 2018, 5:52:18 AM Sebastian Huber sys/event.h: Update version FreeBSD tag Update #3472.
(edit) @ac824ff   Jul 18, 2018, 1:04:03 PM dab Make the definition of struct kevent in event.h match what the man …
(edit) @96b32773   Jul 11, 2018, 2:09:11 AM dab Address some (although not all) style(9) issues in event.h after …
(edit) @1d00acb1   Jun 28, 2018, 8:37:17 PM dab Fix compilation error in r335765 under gcc 4.2.1. The anonymous …
(edit) @b37ef68   Jun 28, 2018, 5:01:04 PM dab Remove potential identifier conflict in the EV_SET macro. PR43905 …
(edit) @bf026dd4   Nov 27, 2017, 3:01:59 PM pfg sys/sys: further adoption of SPDX licensing ID tags. Mainly focus on …
(edit) @57c03363   Nov 25, 2017, 4:49:12 AM jhb Decode kevent structures logged via ktrace(2) in kdump. - Add a new …
(edit) @e9b708a   Jun 17, 2017, 12:57:26 AM kib Add abstime kqueue(2) timers and expand struct kevent members. This …
(edit) @f51aec8   Apr 8, 2017, 4:34:18 AM pkelsey Fix typo. hist -> hint MFC after: 3 days
(edit) @fd27bae   Aug 7, 2018, 4:25:47 AM Sebastian Huber CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE Make …
(edit) @0b038bd4   Aug 4, 2018, 8:38:48 AM Sebastian Huber libblock: Add RTEMS_DEPRECATED Close #3358.
(edit) @ab96aec   Aug 4, 2018, 8:56:46 AM Sebastian Huber dosfs: Avoid deprecated routine Update #3358.
