@5d614fd
08/13/20 05:44:25 |
Sebastian Huber |
libtest: Add T_puts()
Update #3199.
@a7af34d0
08/13/20 05:45:29 |
Sebastian Huber |
libtest: Add T_do_is_runner()
Update #3199.
@e67eff2
08/13/20 05:33:17 |
Sebastian Huber |
libtest: Add output buffer drain and fill
Update #3199.
@5a8114c6
08/12/20 14:57:39 |
Sebastian Huber |
libtest: Change fixture scope method
Return the produced character …
@5869c647
08/11/20 08:41:26 |
aschref.ben-thabet |
rtems/printer.h Fix build warnings -Wclass-memaccess
@14749c45
06/28/20 00:21:45 |
kinsey.moore |
posix: Only check shm_unlink obj_err if necessary
In the nominal case …
@c1354f0
08/07/20 18:30:39 |
Sebastian Huber |
libtest: Add T_thread_switch_record()
Add support to record thread …
@20c79bf
08/07/20 18:30:09 |
Sebastian Huber |
libtest: Constify
Update #3199.
@20b1bdb
08/08/20 08:07:32 |
Chris Johns |
shell: Only clear std handles when the shell task exits
Clearing the …
@f933b65
08/07/20 16:07:52 |
Sebastian Huber |
libtest: Improve T_check_task_context
Update #3199.
@e812f81
08/06/20 12:30:51 |
Sebastian Huber |
Document application configuration options
Add a new directory for …
@6894e2f4
08/06/20 17:44:39 |
Sebastian Huber |
Remove accidentally committed file
@32f1f747
08/06/20 17:12:55 |
Sebastian Huber |
libtest: Fix T_interrupt_test() in SMP configs
Update #3199.
@d2c98c1
08/05/20 07:18:27 |
Sebastian Huber |
dev/sc16is752: Fix declaration
@9566538
08/03/20 09:46:48 |
Sebastian Huber |
termios: Make rtems_termios_ttyMutex private
This mutex is used to …
@2ae557eb
08/03/20 08:25:53 |
Sebastian Huber |
score: Use flexible-array member for C99 and later
This addresses …
@87fdb20
08/03/20 12:18:33 |
christian.mauderer |
dosfs: Fix memory leak on failed mounts.
Currently if mount fails, a …
@c60942ea
07/30/20 08:30:15 |
Sebastian Huber |
rtems: Add rtems_interrupt_server_create()
Add …
@21c7e3a
07/22/20 12:41:51 |
jan.sommer |
i386: Fix possible race condition on first context restore
Make sure …
@7746b0de
04/08/20 08:28:47 |
Sebastian Huber |
malloc: Make deferred free support optional
Only include the deferred …
@6f94a83
04/08/20 08:20:51 |
Sebastian Huber |
score: Add RTEMS_WEAK
Update #4032.
@cc3fd8fc
07/17/20 17:42:32 |
Sebastian Huber |
libtest: Add T_interrupt_test()
Update #3199.
@c9d2405
07/18/20 18:09:11 |
Sebastian Huber |
libtest: Add rtems_test_run()
Update #3199.
@dddc9a58
07/20/20 05:28:07 |
Sebastian Huber |
libtest: Add quiet assert NULL pointer checks
Update #3199.
@467ef5b4
07/17/20 19:24:56 |
Sebastian Huber |
libtest: Add T_unreachable()
Update #3199.
@d702c9f4
07/18/20 12:41:36 |
Sebastian Huber |
libtest: Make check message optional
This macro magic is in line with …
@35d9af69
07/18/20 14:05:42 |
Sebastian Huber |
libtest: Add T_CHECK_FMT
Rename internal function T_check_true() to …
@7781404
07/17/20 19:21:16 |
Sebastian Huber |
libtest: Add T_stop()
Update #3199.
@34e4df55
04/16/20 10:22:06 |
Sebastian Huber |
libtest: Split POSIX Keys support
Update #3199.
@63e4278
06/26/20 05:44:55 |
Sebastian Huber |
libtest: Add T_get_scope()
Update #3199.
@cb3c6bdc
06/09/20 13:55:22 |
Sebastian Huber |
libtest: Add push/pop fixture support
Update #3199.
@6b27e32
06/08/20 08:04:55 |
Sebastian Huber |
libtest: Support custom scope messages via fixture
Update #3199.
@c081c68
04/16/20 14:06:59 |
Sebastian Huber |
libtest: Add T_make_runner()
Update #3199.
@af92665
07/17/20 12:49:42 |
Sebastian Huber |
libtest: Add T_get_one_clock_tick_busy()
Update #3199.
@e3e3b871
07/17/20 12:40:36 |
Sebastian Huber |
libtest: Add T_busy()
Update #3199.
@361404e8
07/17/20 11:46:24 |
Sebastian Huber |
libtest: Move <t.h> to <rtems/test.h>
Update #3199.
@9de8d61
07/17/20 11:36:49 |
Sebastian Huber |
libtest: <rtems/test.h> to <rtems/test-info.h>
Rename this header …
@1fab972
07/21/20 13:22:55 |
Sebastian Huber |
score: Improve _Thread_Start() description
@3a95a07d
07/09/20 08:21:29 |
media-server: Add ability for retry.
This adds the possibility to …
@a3ed4219
05/28/20 13:48:35 |
Sebastian Huber |
score: Remove deprecated Thread
This type was deprecated in RTEMS …
@53a5af2
05/11/20 13:10:19 |
Sebastian Huber |
rtems: Remove deprecated proc_ptr definition
Close #3586.
@2adf328
05/11/20 13:08:55 |
Sebastian Huber |
rtems: Remove support for RTEMS_DEPRECATED_TYPES
Close #3584.
@312fcf2
05/28/20 13:36:23 |
Sebastian Huber |
rtems: Remove rtems_thread_cpu_usage_t
This type was deprecated in …
@1546b1c0
05/28/20 13:35:41 |
Sebastian Huber |
rtems: Remove region_information_block
@f8998f1
05/28/20 13:35:09 |
Sebastian Huber |
rtems: Remove rtems_context_fp
This type was deprecated in RTEMS 5.1. …
@df2dac3
05/28/20 13:34:23 |
Sebastian Huber |
@65dc040
05/28/20 13:32:44 |
Sebastian Huber |
rtems: Remove rtems_rate_monotonic_period_time_t
This type was …
@6a3fcd4
05/28/20 13:31:40 |
Sebastian Huber |
rtems: Remove deprecated rtems_extension
@13a4b880
05/28/20 13:30:33 |
Sebastian Huber |
rtems: Remove rtems_get_processor_count()
This function was …
@e4215e43
05/28/20 13:29:43 |
Sebastian Huber |
rtems: Remove rtems_get_current_processor()
This function was …
@dc4879b
05/28/20 13:24:19 |
Sebastian Huber |
rtems: Remove deprecated rtems_io_lookup_name()
Close #3420.
@39c2e28
05/11/20 06:27:45 |
Sebastian Huber |
rtems: Remove deprecated <rtems/system.h>
Close #3980.
@479b2bf
05/11/20 06:25:32 |
Sebastian Huber |
rtems: Remove _Copyright_Notice from API header
Close #3981.
@b3686d7
05/11/20 06:22:35 |
Sebastian Huber |
rtems: Remove RTEMS_MAXIMUM_NAME_LENGTH
Close #3979.
@9039011
05/11/20 06:20:48 |
Sebastian Huber |
rtems: Move declartion of _RTEMS_version
Close #3978.
@401b237
07/03/20 05:46:24 |
Sebastian Huber |
epiphany: Remove support for this target
Due to an unmaintained …
@d0c1ce6
04/21/20 08:17:00 |
Sebastian Huber |
i386: Replace fpcr clobber with memory clobber
Update #3943.
@3c78e93
06/30/20 07:51:13 |
Sebastian Huber |
score: Clarify CPU_USE_LIBC_INIT_FINI_ARRAY option
Update #4018.
@48dd7b8c
06/29/20 19:35:08 |
kinsey.moore |
score: Add CPU_USE_LIBC_INIT_FINI_ARRAY
This introduces the …
@37c36de
06/30/20 07:19:08 |
Sebastian Huber |
Change version to RTEMS 6
Update #4020.
@46c23871
06/16/20 05:28:58 |
Sebastian Huber |
rtems: Remove RTEMS_MP_NOT_CONFIGURED error
Some objects can be …
5
@5d4a1edc
05/31/20 14:22:55 |
jan.sommer |
bsp/pc386: Define interrupt stack frame for smp
- Defines …
5
@8937f12
05/31/20 14:22:54 |
jan.sommer |
bsp/pc386: Update context switch and restore
Uses similar flow in …
5
@85d6a760
05/31/20 14:22:53 |
jan.sommer |
bsp/pc386: Update GDT to work for SMP
Create a GS segment in the GDT …
5
@bd750c9e
05/27/20 07:24:54 |
Sebastian Huber |
arm: Fix ARMv7-M exception handler
Store the stack pointer of the …
5
@934cbe7
05/12/20 05:06:37 |
Sebastian Huber |
posix: Get real priority in pthread_getattr_np()
This is in line with …
5
@153b2669
05/07/20 06:45:29 |
Sebastian Huber |
termios: Replace rtems_termios_isig_status_code
Merge the …
5
@e9762d7
05/05/20 23:53:45 |
Chris Johns |
libdl: Add allocator check script
Use with the trace outout to check …
5
@3ce3cdf
05/05/20 14:16:54 |
Sebastian Huber |
score: Update _Copyright_Notice
Add the _Copyright_Notice to a …
5
@d30a352
05/05/20 14:12:05 |
Sebastian Huber |
rtems: Deprecate _Copyright_Notice
Close #3973.
5
@1af8e45b
05/05/20 14:11:39 |
Sebastian Huber |
rtems: Add rtems_get_copyright_notice()
Update #3973.
5
@63274da
05/05/20 12:53:42 |
Sebastian Huber |
rtems: Deprecate <rtems/system.h>
Close #3972.
5
@3d86d83
05/05/20 12:49:54 |
Sebastian Huber |
rtems: Deprecate RTEMS_MAXIMUM_NAME_LENGTH
This define is
* not …
5
@34b098e
05/05/20 12:37:30 |
Sebastian Huber |
rtems: Deprecate use of _RTEMS_version
Close #3970.
5
@4b9b6dd
05/05/20 12:34:32 |
Sebastian Huber |
Use rtems_get_version_string()
Update #3970.
5
@b7702c54
05/05/20 04:58:27 |
Chris Johns |
libdl/rap: Correctly check the return enum from rela calls
- The …
5
@3635d6a
05/05/20 04:57:34 |
Chris Johns |
libdl/obj-comp: Add trace prints when decompressing
Updates #3969
5
@d5fc2a6a
05/05/20 04:55:34 |
Chris Johns |
libdl/obj-cache: Fail if the read offset is past the file length
5
@b77670fd
05/05/20 04:54:39 |
Chris Johns |
libdl/obj: Fix RAP format call table.
Updates #3969
5
@fe77587
05/05/20 04:53:53 |
Chris Johns |
libdl/sparc: Print trace message of reloc failture path
Updates #3969
5
@285cda3
05/05/20 04:53:14 |
Chris Johns |
libdl: Fix comment.
Updates #3969
5
@cfe8f7a
04/27/20 14:14:06 |
Sebastian Huber |
doxygen: Switch @brief and @ingroup
This order change fixes the Latex …
5
@0b416759
04/28/20 03:58:20 |
Chris Johns |
libdl/mips: Fix MIPS16hi/lo relocation support.
This patch is an …
5
@3d73642
04/17/20 08:00:15 |
Sebastian Huber |
sapi: Add param check to rtems_extension_create()
Check that the …
5
@80cf60e
04/15/20 07:48:32 |
Sebastian Huber |
Canonicalize config.h include
Use the following variant which was …
5
@8f808c1
04/15/20 07:45:32 |
Sebastian Huber |
libnetworking: Remove config.h include in header
5
@d007cc2
04/14/20 05:26:27 |
Chris Johns |
libmisc/shell: Fix the handling of joel scripts in telnet
- Fix the …
5
@4f32722
04/14/20 14:29:52 |
Sebastian Huber |
config: Fix typo
Update #3875.
5
@ea227af
04/13/20 17:41:21 |
Sebastian Huber |
score: Check time of day in _TOD_Set()
Close #3949.
5
@fb07f730
04/13/20 17:29:35 |
Sebastian Huber |
score: Return status in _TOD_Set()
Update #3949.
5
@840f21d
04/07/20 05:13:58 |
Sebastian Huber |
score: Delete RTEMS_DECLARE_GLOBAL_SYMBOL()
Delete unused …
5
@099ab00
04/05/20 08:31:24 |
Sebastian Huber |
config: Fix _ISR_Stack_area_end
In the previous implementation, the …
5
@3a882e5
04/05/20 08:30:43 |
Sebastian Huber |
score: Add and use RTEMS_SYMBOL_NAME()
Update #3799.
5
@d582d0e
04/05/20 07:58:24 |
Sebastian Huber |
Revert "score: Fix _ISR_Stack_area_end"
This reverts commit …
5
@50782bc5
04/03/20 15:31:35 |
Gedare Bloom |
cpukit/rfs: fix typo in header guard
5
@8e80876
04/03/20 07:47:21 |
Sebastian Huber |
The _ISR_Stack_area_begin and …
5
@51307919
03/20/20 08:12:26 |
Sebastian Huber |
arm: ARMv7-M statically initialized vector table
Statically …
5
@7e33a80
03/31/20 08:31:20 |
Sebastian Huber |
config: Remove filesystem entry config options
Remove the following …
5
@86f006be
04/01/20 07:07:09 |
Sebastian Huber |
libio: Remove RTEMS_FILESYSTEM_TYPE_MINIIMFS
This type is unused. Do …
5
@18f5bcb
03/26/20 14:06:57 |
Sebastian Huber |
rtems: Fix Doxygen comment
5
