@59a0541c
07/12/18 07:15:55 |
cederman |
sparc: Restore npc when returning from the syscall_lazy_fp_switch trap …
5
@6695d02
08/23/18 12:39:33 |
Sebastian Huber |
Update FreeBSD kernel timespec support
This change is based on the …
5
@ba0e9631
08/10/18 05:34:03 |
Sebastian Huber |
score: Do not inline _Thread_Dispatch_enable()
This function is …
5
@a36aa86
08/23/18 12:32:07 |
Sebastian Huber |
Add dummy PI_SOFT to <sys/priority.h>
Update #3472.
5
@d14f934
08/10/18 05:22:43 |
Sebastian Huber |
score: Fix ISR enable in _Thread_Dispatch_enable()
This bug had …
5
@dcaea71
08/15/18 10:26:13 |
christian.mauderer |
dev/sc16is752: Add name space for field names.
The field names for …
5
@bc731313
08/13/18 10:55:34 |
amaan.cheval |
bsps/x86_64: Add APIC timer based clock driver
The APIC timer is …
5
@6869321
08/13/18 10:50:38 |
amaan.cheval |
bsps/x86_64: Add support for RTEMS interrupts
Updates #2898.
5
@4544749e
08/13/18 10:33:12 |
amaan.cheval |
bsps/x86_64: Add paging support with 1GiB super pages
Updates #2898.
5
@ab971bf5
08/13/18 10:21:47 |
amaan.cheval |
bsps/x86_64: Reorganize header files and compile-options
Updates #2898.
5
@b2de426
08/06/18 09:53:42 |
Sebastian Huber |
score: Fix _Addresses_Subtract()
Use architecture-specific integer …
5
@66cb142
08/06/18 08:51:00 |
Sebastian Huber |
rtems: Parameter types in rtems_partition_create()
Use uintptr_t to …
5
@b8eae140
08/10/18 05:11:56 |
Sebastian Huber |
Add dummy PRI_MIN_KERN to <sys/priority.h>
Update #3472.
5
@aac36d15
08/08/18 09:17:36 |
Sebastian Huber |
posix: Add configure check for mprotect()
Update #3491.
5
@71948f76
08/08/18 05:52:18 |
Sebastian Huber |
sys/event.h: Update version FreeBSD tag
Update #3472.
5
@ac824ff
07/18/18 13:04:03 |
dab |
Make the definition of struct kevent in event.h match what the man …
5
@96b32773
07/11/18 02:09:11 |
dab |
Address some (although not all) style(9) issues in event.h after …
5
@1d00acb1
06/28/18 20:37:17 |
dab |
Fix compilation error in r335765 under gcc 4.2.1.
The anonymous …
5
@b37ef68
06/28/18 17:01:04 |
dab |
Remove potential identifier conflict in the EV_SET macro.
PR43905 …
5
@bf026dd4
11/27/17 15:01:59 |
pfg |
sys/sys: further adoption of SPDX licensing ID tags.
Mainly focus on …
5
@57c03363
11/25/17 04:49:12 |
jhb |
Decode kevent structures logged via ktrace(2) in kdump.
- Add a new …
5
@e9b708a
06/17/17 00:57:26 |
kib |
Add abstime kqueue(2) timers and expand struct kevent members.
This …
5
@f51aec8
04/08/17 04:34:18 |
pkelsey |
Fix typo.
hist -> hint
MFC after: 3 days
5
@fd27bae
08/07/18 04:25:47 |
Sebastian Huber |
CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
Make …
5
@0b038bd4
08/04/18 08:38:48 |
Sebastian Huber |
libblock: Add RTEMS_DEPRECATED
Close #3358.
5
@ab96aec
08/04/18 08:56:46 |
Sebastian Huber |
dosfs: Avoid deprecated routine
Update #3358.
5
@698093d
08/03/18 20:39:42 |
Sebastian Huber |
libblock: Use rtems_blkdev_create_partition()
Update #3358.
5
@0fe7133
07/31/18 14:01:17 |
Sebastian Huber |
flashdisk: Use rtems_blkdev_create()
Update #3358.
5
@16f3f10
07/31/18 13:54:29 |
Sebastian Huber |
nvdisk: Use rtems_blkdev_create()
Update #3358.
5
@24b94c4
07/30/18 04:39:09 |
Sebastian Huber |
ramdisk: Use rtems_blkdev_create()
Update #3358.
5
@d56e68b
08/04/18 12:27:38 |
Sebastian Huber |
rfs: Remove erroneous call of rtems_disk_release()
The function …
5
@42f9963d
08/03/18 05:58:07 |
Sebastian Huber |
score: Remove superfluous semicolon
This avoids warnings like this:
5
@83ca9f0a
08/02/18 12:52:12 |
Sebastian Huber |
rtems: Relax partition buffer area alignment
The partition buffer …
5
@27bbc05
08/02/18 12:49:01 |
Sebastian Huber |
score: Remove CPU_PARTITION_ALIGNMENT
Use the CPU_SIZEOF_POINTER …
5
@28b8cf9b
08/02/18 07:41:08 |
Sebastian Huber |
riscv: Fix CPU_ALIGNMENT
Update #3433.
5
@334e1d2
07/30/18 05:35:26 |
Sebastian Huber |
confdefs: Fix uniprocessor configuration
Introduce a new internal …
5
@cfc9573
07/27/18 12:47:17 |
Sebastian Huber |
riscv: Rework CPU counter support
Update #3433.
5
@6b9ef09
07/20/18 08:57:59 |
Sebastian Huber |
riscv: Add CLINT and PLIC support
The CLINT and PLIC need some …
5
@c2670de
07/20/18 07:07:40 |
Sebastian Huber |
riscv: Use wfi instruction for idle task
Update #3433.
5
@8db3f0e
07/19/18 10:11:19 |
Sebastian Huber |
riscv: Rework exception handling
Remove …
5
@5694b0c
07/19/18 08:15:53 |
Sebastian Huber |
riscv: New CPU_Exception_frame
Use the CPU_Interrupt_frame for the …
5
@d779a1e2
07/19/18 07:35:54 |
Sebastian Huber |
riscv: Add exception codes
Update #3433.
5
@5677883
07/24/18 07:09:06 |
Sebastian Huber |
score: _SMP_Inter_processor_interrupt_handler()
Optimize …
5
@a1f7d7d
07/24/18 07:00:18 |
Sebastian Huber |
score: RTEMS_PREDICT_TRUE(), RTEMS_PREDICT_FALSE()
Add …
5
@406dd62
07/24/18 09:18:27 |
Sebastian Huber |
_SMP_Start_multitasking_on_secondary_processor()
Pass current …
5
@0d362ff3
07/23/18 12:54:51 |
Sebastian Huber |
Pass current …
5
@f8d00a3
07/25/18 06:00:22 |
Sebastian Huber |
tm27: Fix prototype warnings
5
@05259de1
07/25/18 07:54:56 |
Sebastian Huber |
powerpc: Fix _CPU_Instruction_illegal()
Apparently the .word …
5
@3a646426
07/19/18 10:53:34 |
Sebastian Huber |
score: Add _CPU_Instruction_illegal()
On some …
5
@b74353e
07/20/18 06:06:46 |
Sebastian Huber |
score: Add _CPU_Instruction_no_operation()
This helps to reduce the …
5
@42f2fdfd
07/20/18 05:56:43 |
Sebastian Huber |
score: Move context validation declarations
The context validation …
5
@248ca7a
07/20/18 07:10:29 |
Sebastian Huber |
score: Remove obsolete CPU port defines
5
@1554a8c5
07/20/18 06:47:25 |
Sebastian Huber |
dtc: Update VERSION
5
@ec2de39
07/19/18 06:19:43 |
Sebastian Huber |
libfdt: fdt_address_cells() and fdt_size_cells()
Add internal …
5
@513daa3
07/19/18 11:06:49 |
Sebastian Huber |
capture: Include missing header file
5
@b4f15d8
07/19/18 05:10:26 |
Sebastian Huber |
jffs2: Rename README to VERSION
This makes it easer to find files …
5
@2af004e
07/18/18 07:32:28 |
Sebastian Huber |
dtc: Add VERSION file
Close #3471.
5
@80eaf45
07/09/18 04:50:38 |
david |
libfdt: Add necessary header padding in fdt_create()
At present …
5
@4fd05d3
07/07/18 19:57:19 |
sjg |
libfdt: Copy the struct region in fdt_resize()
At present this …
5
@78ad048
06/21/18 05:32:40 |
david |
libfdt: Add helpers for accessing unaligned words
This adds some …
5
@3848f14b
06/06/18 21:37:05 |
sjg |
pylibfdt: Add functions to update properties
Allow updating and …
5
@0d851d4
03/17/18 13:12:12 |
david |
libfdt: Add fdt_check_full() function
This new function implements a …
5
@9a7de8e
03/16/18 11:40:26 |
david |
libfdt: Add fdt_header_size()
We have a couple of places within …
5
@c81f432
03/09/18 12:28:56 |
david |
libfdt: Safer access to memory reservations
fdt_num_mem_rsv() and …
5
@6bc883b
03/25/18 11:54:22 |
david |
libfdt: Propagate name errors in fdt_getprop_by_offset()
5
@72273b6
11/14/17 11:45:56 |
david |
libfdt: Safer access to strings section
fdt_string() is used to …
5
@8073f95e
10/23/17 03:45:56 |
david |
libfdt: Make fdt_check_header() more thorough
Currently …
5
@c4267b1
04/10/18 07:06:18 |
david |
libfdt: Improve sequential write state checking
When creating a tree …
5
@85d1769
10/22/17 05:32:15 |
david |
libfdt: Clean up header checking functions
Many of the libfdt entry …
5
@c13e400
01/25/18 05:13:40 |
nwhitehorn |
Add limited read-only support for older (V2 and V3) device tree to …
5
@4e5f848
10/26/17 01:13:46 |
programmingkidx |
implement strnlen for systems that need it
Prior the Mac OS 10.7, the …
5
@42f1b37
10/18/17 06:22:40 |
david |
libfdt: Remove leading underscores from identifiers
In a lot of …
5
@f5e879f
10/18/17 05:45:52 |
david |
Fix some errors in comments
A comment in tests/stringlist.c refers to …
5
@a1c3b41a
07/27/17 16:33:11 |
pantelis.antoniou |
Introduce fdt_setprop_placeholder() method
In some cases you need to …
5
@903d2ec
04/08/17 16:14:42 |
sjg |
Fix a few whitespace and style nits
These were noticed when synching …
5
@f984d8f
04/01/17 15:31:41 |
sjg |
Add a libfdt function to write a property placeholder
The existing …
5
@67f49b98
03/17/17 22:14:33 |
sjg |
Adjust libfdt.h to work with swig
There are a few places where …
5
@d0a1fc8
03/06/17 01:16:56 |
david |
libfdt: Change names of sparse helper macros
The default libfdt_env.h …
5
@90f54b0e
02/24/17 00:12:50 |
david |
libfdt: Add fdt_setprop_empty()
Device trees can contain empty (zero …
5
@6dbbd277
02/23/17 23:51:05 |
david |
libfdt: Remove undefined behaviour setting empty properties
The …
5
@8cd96f47
11/03/16 15:47:42 |
b-fair |
libfdt: add missing errors to fdt_strerror()
Some error values were …
5
@d8c856b
10/17/16 06:08:24 |
yamada.masahiro |
libfdt: fix fdt_stringlist_search()
If fdt_getprop() fails, negative …
5
@aa9389f
10/17/16 06:08:23 |
yamada.masahiro |
libfdt: fix fdt_stringlist_count()
5
@c753d9d
10/11/16 08:10:31 |
maxime.ripard |
fdt: strerr: Remove spurious BADOVERLAY
There's one …
5
@4f7c3ac9
10/06/16 11:39:56 |
maxime.ripard |
libfdt: Add BADPHANDLE error string
The BADPHANDLE error was missing …
5
@e879a98d
09/30/16 13:57:16 |
maxime.ripard |
libfdt: Add overlay application function
The device tree overlays are …
5
@b0ceda54
09/30/16 13:57:15 |
maxime.ripard |
libfdt: Extend the reach of FDT_ERR_BADPHANDLE
So far, the BADPHANDLE …
5
@2679534b
09/30/16 13:57:14 |
maxime.ripard |
libfdt: Add new errors for the overlay code
Add a few new error codes …
5
@f670acbf
09/26/16 16:12:26 |
thuth |
Fix some typing errors in libfdt.h and livetree.c
Correct some typos …
5
@607b70f
08/22/16 09:55:49 |
yamada.masahiro |
libfdt: simplify fdt_del_mem_rsv()
The variable "err" is unneeded.
5
@6112fb0b
07/29/16 09:55:48 |
maxime.ripard |
libfdt: Add fdt_setprop_inplace_namelen_partial
Add a function to …
5
@2086bbc8
07/27/16 12:55:56 |
maxime.ripard |
libfdt: Add fdt_getprop_namelen_w
Add a function to retrieve a …
5
@220cde8
07/27/16 12:55:55 |
maxime.ripard |
libfdt: Add max phandle retrieval function
Add a function to retrieve …
5
@eda76d4
07/27/16 12:55:54 |
maxime.ripard |
libfdt: Add iterator over properties
Implement a macro based on …
5
@da8eff99
07/27/16 12:55:53 |
treding |
libfdt: Add a subnodes iterator macro
The fdt_for_each_subnode() …
5
@8bbd8c7
03/07/16 03:12:48 |
sjg |
Correct a missing space in a fdt_header cast
The code style here is …
5
@8f6fb28c
03/07/16 03:12:47 |
sjg |
Correct line lengths in libfdt.h
There are a few lines that are over …
5
@34e6ae62
03/07/16 03:12:46 |
sjg |
Correct space-after-tab in libfdt.h
There are a few places with a …
5
@0ddfe029
02/12/16 05:45:12 |
yamada.masahiro |
libfdt: simplify fdt_node_check_compatible()
Because …
5
@87acb61e
12/17/15 06:19:11 |
david |
libfdt: Fix undefined behaviour in fdt_offset_ptr()
Using pointer …
5
