source: rtems/cpukit
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @54f35888   Oct 25, 2018, 8:54:12 AM Sebastian Huber posix: Provide threads by default Update #2514.
(edit) @033f31c8   Oct 25, 2018, 8:26:40 AM Sebastian Huber posix: Hide POSIX_API_Control by default Update #2514.
(edit) @fe7aefd5   Oct 25, 2018, 8:12:39 AM Sebastian Huber posix: Provide message queues by default Update #2514.
(edit) @701057e0   Oct 25, 2018, 8:07:46 AM Sebastian Huber posix: Provide shared memory objects by default Update #2514.
(edit) @9318cfb0   Oct 14, 2018, 10:43:13 AM Sebastian Huber posix: Provide named semaphores by default Update #2514.
(edit) @e97806a   Oct 14, 2018, 5:20:05 PM Sebastian Huber posix: Split posix_api_configuration_table Use separate configuration …
(edit) @55b69ed   Oct 15, 2018, 6:33:45 AM Sebastian Huber Move default config to librtemsdefaultconfig.a An RTEMS application …
(edit) @7038271   Oct 25, 2018, 10:05:53 AM Sebastian Huber Remove RTEMS_SCORE_OBJECT_ENABLE_STRING_NAMES Enable support for …
(edit) @5090a71b   Oct 25, 2018, 9:32:01 AM Sebastian Huber score: Remove bogus thread object name support Update #2514.
(edit) @0dbf67b   Oct 25, 2018, 12:37:08 PM Sebastian Huber posix: Provide aio_suspend() by default Update #2514.
(edit) @135cb10   Oct 25, 2018, 7:56:02 AM Sebastian Huber posix: Provide more functions by default Update #2514.
(edit) @4a7be22   Oct 25, 2018, 8:03:46 AM Sebastian Huber posix: Fix build with POSIX API disabled Update #2514.
(edit) @24b5807   Oct 24, 2018, 5:35:51 AM Sebastian Huber config: Modify CONFIGURE_INTERRUPT_STACK_SIZE Use …
(edit) @4b801ac   Oct 24, 2018, 5:54:27 AM Sebastian Huber posix: Provide simple thread functions by default Update #2514.
(edit) @c1ce9a2   Oct 24, 2018, 5:40:23 AM Sebastian Huber posix: Provide get thread attributes by default Update #2514.
(edit) @8d81622   Oct 14, 2018, 3:10:32 PM Sebastian Huber posix: Provide non-thread functions by default Update #2514.
(edit) @0b2808ce   Oct 14, 2018, 10:41:22 AM Sebastian Huber posix: Provide scheduler support by default Update #2514.
(edit) @dd804bb   Oct 14, 2018, 10:36:22 AM Sebastian Huber posix: Provide cancel state/type by default Sort POSIX sources …
(edit) @6da1bb0   Oct 18, 2018, 12:58:31 PM Sebastian Huber Remove superfluous configure checks The results of these checks are …
(edit) @167654e   Oct 18, 2018, 12:45:24 PM Sebastian Huber Remove checks for flockfile(), etc. declarations Declarations …
(edit) @f59edebf   Oct 18, 2018, 12:39:09 PM Sebastian Huber Remove getcwd() This function is provided by Newlib since 2000. …
(edit) @79d145a7   Oct 18, 2018, 12:36:44 PM Sebastian Huber Remove optional getrusage() declaration Declaration provided by …
(edit) @e161767e   Oct 18, 2018, 12:33:58 PM Sebastian Huber Remove ttyname() This function is provided by Newlib since 2000. …
(edit) @658ec75   Oct 18, 2018, 12:28:17 PM Sebastian Huber Remove assert() This function is provided by Newlib since 2000. …
(edit) @87a9900f   Oct 18, 2018, 12:22:46 PM Sebastian Huber Remove isatty() These functions are provided by Newlib since 2000. …
(edit) @3cf12c9   Oct 18, 2018, 12:11:10 PM Sebastian Huber Remove strlcat(), strlcpy(), strsep(), readdir_r() These functions …
(edit) @1ad26cd   Oct 18, 2018, 10:38:58 AM Sebastian Huber Support O_NOFOLLOW open() flag Close #3546.
(edit) @b4043ea   Sep 24, 2018, 2:32:49 PM joel check-networking.m4: Disable legacy stack for x86_64 and epiphany …
(edit) @4af18b3   Oct 11, 2018, 8:51:21 AM Sebastian Huber Support O_DIRECTORY open() flag Close #3545.
(edit) @c980eaf   Oct 16, 2018, 12:35:12 PM Sebastian Huber console: Be fair in simple console read Wait for one tick in case no …
(edit) @c6023b7   Oct 12, 2018, 12:40:52 PM Sebastian Huber posix: Fix unused result warning
(edit) @9d1f17a9   Oct 11, 2018, 5:34:35 PM Sebastian Huber build: Fix build on Windows Avoid a long argument list while creating …
(edit) @26b58b7e   Oct 10, 2018, 11:12:50 AM Sebastian Huber telnetd: Add server port to configuration Close #3543.
(edit) @0dc303f   Oct 10, 2018, 8:40:21 AM Sebastian Huber telnetd: Create sessions at start Update #3543.
(edit) @0f0e130   Oct 10, 2018, 7:11:47 AM Sebastian Huber telnetd: Allocate the server context Update #3543.
(edit) @bf4c7ff6   Oct 10, 2018, 7:04:47 AM Sebastian Huber telnetd: Create server socket at start Update #3543.
(edit) @1c567c5   Oct 9, 2018, 1:42:42 PM Sebastian Huber telnetd: Rename shell_args to telnetd_session Update #3543.
(edit) @6d3ec58a   Oct 9, 2018, 1:31:46 PM Sebastian Huber telnetd: Simplify task spawn function Use the minimum task size for …
(edit) @2548d14   Sep 10, 2018, 3:38:14 PM Sebastian Huber build: Include header.am in cpukit/Makefile.am Include all …
(edit) @629faf9   Oct 9, 2018, 12:47:02 PM Sebastian Huber telnetd: Remove keep stdio feature The Telnet service started via …
(edit) @477bca2   Oct 6, 2018, 8:59:10 AM Sebastian Huber build: Remove local.am
(edit) @9da5d5fd   Oct 6, 2018, 8:12:21 AM Sebastian Huber build: Directly reference libraries in tests Remove use of …
(edit) @637546a   Oct 5, 2018, 6:12:40 PM Sebastian Huber build: Merge score/cpu/*/Makefile.am
(edit) @96ad2b2   Oct 4, 2018, 6:32:12 PM Sebastian Huber build: Merge libmisc/Makefile.am
(edit) @19b7db50   Oct 4, 2018, 6:07:16 PM Sebastian Huber build: Merge libnetworking/Makefile.am
(edit) @a40bb03   Oct 4, 2018, 3:58:48 PM Sebastian Huber build: Merge zlib/Makefile.am
(edit) @7f0eac30   Oct 4, 2018, 3:48:23 PM Sebastian Huber build: Merge telnetd/Makefile.am
(edit) @1d93843   Sep 14, 2018, 6:02:02 PM Sebastian Huber build: Merge score/Makefile.am
(edit) @640271f   Sep 14, 2018, 5:55:00 PM Sebastian Huber build: Merge rtems/Makefile.am
(edit) @24312f34   Sep 14, 2018, 5:51:38 PM Sebastian Huber build: Merge pppd/Makefile.am
(edit) @b3ef89f9   Sep 14, 2018, 5:46:58 PM Sebastian Huber build: Merge posix/Makefile.am
(edit) @028b0ce   Sep 14, 2018, 2:12:19 PM Sebastian Huber build: Merge mghttpd/Makefile.am
(edit) @a2a71b5   Sep 14, 2018, 2:00:45 PM Sebastian Huber build: Merge libstdthreads/Makefile.am
(edit) @5079524   Sep 14, 2018, 1:56:26 PM Sebastian Huber build: Merge librpc/Makefile.am
(edit) @c38d517   Sep 14, 2018, 4:43:35 AM Sebastian Huber build: Merge libpci/Makefile.am
(edit) @e39642a4   Sep 14, 2018, 4:41:27 AM Sebastian Huber build: Merge libmd/Makefile.am
(edit) @0c56264   Sep 14, 2018, 4:38:50 AM Sebastian Huber build: Merge libi2c/Makefile.am
(edit) @8d677cf   Sep 14, 2018, 4:35:59 AM Sebastian Huber build: Merge libgnat/Makefile.am
(edit) @b45a853   Sep 14, 2018, 4:34:02 AM Sebastian Huber build: Merge libfs/Makefile.am
(edit) @d3d1243   Sep 14, 2018, 4:22:19 AM Sebastian Huber build: Merge libdrvmgr/Makefile.am
(edit) @551f473   Sep 14, 2018, 4:19:15 AM Sebastian Huber build: Merge libdl/Makefile.am
(edit) @bab7a68   Sep 14, 2018, 4:16:36 AM Sebastian Huber build: Merge libdebugger/Makefile.am
(edit) @2532817   Sep 13, 2018, 12:46:30 PM Sebastian Huber build: Merge libcsupport/Makefile.am
(edit) @94acbbf   Sep 13, 2018, 12:22:17 PM Sebastian Huber build: Merge libcrypt/Makefile.am
(edit) @9c058287   Sep 13, 2018, 4:42:32 AM Sebastian Huber build: Merge libblock/Makefile.am
(edit) @8fb3443   Sep 13, 2018, 4:37:56 AM Sebastian Huber build: Merge libfdt/Makefile.am
(edit) @690718ab   Sep 13, 2018, 4:35:03 AM Sebastian Huber build: Merge ftpd/Makefile.am
(edit) @60c4ba1   Sep 13, 2018, 4:30:08 AM Sebastian Huber build: Merge dev/Makefile.am
(edit) @54c0b57   Sep 12, 2018, 2:03:42 PM Sebastian Huber build: Move sapi/Makefile.am
(edit) @68e1ccc   Sep 11, 2018, 4:30:20 AM Sebastian Huber build: Remove specialized CPPFLAGS
(edit) @6cdaa85   Oct 4, 2018, 6:16:45 PM Sebastian Huber shell: Use #include "..." for local header files Update #3375.
(edit) @2806e10   Oct 9, 2018, 6:38:11 AM Sebastian Huber telnetd: Ignore setsockopt() return status Update #3529.
(edit) @84a5921d   Oct 9, 2018, 6:12:46 AM Sebastian Huber ftpd: Restructure chroot() handling. Remove superfluous setting of …
(edit) @6dc0b5f   Jul 21, 2017, 12:18:50 PM javier.jalle leon, spwtdp: Initial driver commit
(edit) @acb53d5   Oct 9, 2018, 6:43:08 AM Sebastian Huber posix: Remove static assertion Standard C does not allow pointer …
(edit) @5bd75823   Oct 8, 2018, 8:02:07 AM Sebastian Huber ftpd: Remove superfluous temporary buffer Update #3530.
(edit) @2f784d7   Oct 8, 2018, 6:14:40 AM Sebastian Huber ftpd: Check return status of getsockname() Update #3530.
(edit) @be8de0ff   Oct 5, 2018, 1:16:46 PM Sebastian Huber ftpd: Fix insecure chroot() handling Ensure that the …
(edit) @df97c4d2   Oct 5, 2018, 12:56:10 PM Sebastian Huber ftpd: Avoid resource leak Update #3530.
(edit) @479a28e0   Oct 5, 2018, 12:54:49 PM Sebastian Huber ftpd: Avoid use of uninitialized memory Update #3530.
(edit) @51da629   Oct 5, 2018, 12:47:21 PM Sebastian Huber ftpd: Avoid malloc() and sscanf() Move the user name to the session …
(edit) @dcf42bb2   Oct 5, 2018, 12:39:46 PM Sebastian Huber ftpd: Remove FTPD_SessionInfo_t::pass member There is no need to keep …
(edit) @e761fb4   Oct 5, 2018, 12:05:22 PM Sebastian Huber ftpd: Avoid NULL pointer checks before free() They are superfluous …
(edit) @05b5f9c0   Oct 5, 2018, 11:56:59 AM Sebastian Huber jffs2: Avoid use of constant register variable Avoid the use of a …
(edit) @4a7c6867   Oct 5, 2018, 7:37:44 AM Sebastian Huber Fix rbtree_postorder_for_each_entry_safe() Use the non-standard …
(edit) @1d39e96   Oct 5, 2018, 6:11:09 AM Sebastian Huber score: Fix legacy RTEMS_STATIC_ASSERT() In standard C pointer …
(edit) @8776bb9   Sep 26, 2018, 4:34:54 AM Sebastian Huber score: Remove CPU_PROVIDES_IDLE_THREAD_BODY Remove the …
(edit) @b38887a   Oct 5, 2018, 11:39:49 AM Sebastian Huber dev/sc16is752: Deal with a baud of zero Avoid division by zero and …
(edit) @8777d4c   Oct 4, 2018, 9:29:03 AM Sebastian Huber Add rtems_interrupt_server_request_set_vector() By default, the …
(edit) @313f897   Sep 13, 2018, 12:50:08 PM Sebastian Huber Optimize calloc() Use return value of memset() to enable tail call …
(edit) @1ad43f8   Sep 13, 2018, 12:49:16 PM Sebastian Huber Avoid need for -fno-builtin for calloc() Use …
(edit) @5418890   Sep 13, 2018, 4:22:21 AM Sebastian Huber Remove superfluous pipe_create()
(edit) @242887bc   Sep 13, 2018, 4:19:05 AM Sebastian Huber Rename files to make them unique within cpukit This allows to build …
(edit) @f373bdc0   Sep 10, 2018, 3:46:19 PM Sebastian Huber libdl: Avoid command line defines Update #3375.
(edit) @2e77151   Sep 10, 2018, 4:31:53 AM Sebastian Huber mghttpd: Add configuration to source file Update #3375.
(edit) @06060da   Sep 10, 2018, 4:29:11 AM Sebastian Huber pppd: Simplify Makefile.am Update #3375.
(edit) @e069f7fe   Sep 10, 2018, 4:27:10 AM Sebastian Huber rpc: Use configuration header file Update #3375.
(edit) @f004b2b8   Oct 2, 2018, 8:22:15 AM Sebastian Huber Use rtems_task_exit() Update #3530. Update #3533.
(edit) @e50e3f70   Oct 1, 2018, 7:25:06 AM Sebastian Huber rtems: Add rtems_task_exit() Update #3533.
(edit) @57a7ecde   Oct 1, 2018, 6:20:11 AM Sebastian Huber telnetd: Remove CEXP convenience routines Close #3535.
