Notice: We have migrated to GitLab launching 2024-05-01 see here: https://gitlab.rtems.org/
source: rtems/cpukit
Revision Log Mode:
Legend:
Added
Modified
Copied or renamed
(edit) @3fe615ba   11/18/06 02:28:35 Ralf Corsepius Replace AM_CONDITIONAL(HAS_NETWORKING) with AM_CONDITIONAL(LIBNETWORKING). 4.104.114.84.95
(edit) @7f3d6fe9   11/17/06 22:59:41 Joel Sherrill 2006-11-17 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @28c55e4   11/17/06 22:58:33 Joel Sherrill 2006-11-17 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @d056acd0   11/17/06 22:57:48 Joel Sherrill 2006-11-17 Joel Sherrill <joel@…> * score/src/heapwalk.c: … 4.104.114.84.95
(edit) @bf89c76   11/17/06 22:55:51 Joel Sherrill 2006-11-17 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @336227d   11/17/06 22:55:05 Joel Sherrill 2006-11-17 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @8441e5e   11/17/06 22:53:56 Joel Sherrill 2006-11-17 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @44bc19a   11/17/06 22:51:12 Joel Sherrill 2006-11-17 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @4d0bb65   11/17/06 22:49:30 Joel Sherrill 2006-11-17 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @efb1c3f5   11/17/06 09:58:59 Ralf Corsepius Regenerate. 4.104.114.84.95
(edit) @59f16322   11/17/06 09:51:34 Ralf Corsepius 2006-11-17 Ralf Corsépius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @91fadb3   11/17/06 09:50:45 Ralf Corsepius Suppress itron if int8/int16_t are not provided. Introduce … 4.104.114.84.95
(edit) @5669334   11/17/06 09:49:29 Ralf Corsepius Introduce AM_CONDITIONAL(LIBITRON). Remove AM_CONDITIONAL(HAS_ITRON). 4.104.114.84.95
(edit) @9f62936   11/17/06 09:42:56 Ralf Corsepius Introduce AM_CONDITIONAL(LIBDOSFS). 4.104.114.84.95
(edit) @5069a89   11/17/06 08:55:16 Ralf Corsepius 2006-11-17 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @10bf8e69   11/17/06 08:46:45 Ralf Corsepius 2006-11-17 Ralf Corsépius <ralf.corsepius@…> * configure.ac, … 4.104.114.84.95
(edit) @795da078   11/17/06 05:58:06 Ralf Corsepius 2006-11-17 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @e252c38   11/16/06 16:38:15 Ralf Corsepius 2006-11-16 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @3a0d61e9   11/16/06 16:37:49 Ralf Corsepius Cosmetic updates from FreeBSD. Eliminate bcopy in favor of memcpy. 4.104.114.84.95
(edit) @c9478cd   11/16/06 14:55:42 Ralf Corsepius Fix typo. 4.104.114.84.95
(edit) @c3ed74e   11/16/06 14:53:10 Ralf Corsepius 2006-11-16 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @d808d8b   11/16/06 14:43:40 Ralf Corsepius 2006-11-16 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @bd1c2368   11/16/06 14:41:32 Ralf Corsepius 2006-11-16 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @eafa35e7   11/15/06 16:54:01 Joel Sherrill 2006-11-15 Joel Sherrill <joel@…> * sapi/src/io.c: Fix spacing. 4.104.114.84.95
(edit) @4741fcb7   11/15/06 15:45:48 Joel Sherrill * sapi/include/confdefs.h: Enable includes needed for new objects. 4.104.114.84.95
(edit) @cdda98fa   11/15/06 15:43:42 Joel Sherrill 2006-11-15 Joel Sherrill <joel.sherrill@…> * … 4.104.114.84.95
(edit) @ba16717   11/15/06 15:34:45 Joel Sherrill 2006-11-15 Joel Sherrill <joel.sherrill@…> * … 4.104.114.84.95
(edit) @8c47f1c1   11/15/06 14:28:05 Ralf Corsepius Regenerate. 4.104.114.84.95
(edit) @dd5be89   11/15/06 14:23:52 Ralf Corsepius 2006-11-15 Ralf Corsépius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @728c3167   11/15/06 14:19:47 Ralf Corsepius Add RTEMS_AMPOLISH3. 4.104.114.84.95
(edit) @21ca03c3   11/15/06 14:19:19 Ralf Corsepius Remove. 4.104.114.84.95
(edit) @28c4602   11/15/06 14:18:27 Ralf Corsepius Pick up ampolish3 from ac_aux_dir. 4.104.114.84.95
(edit) @bfe2fd3   11/15/06 14:17:57 Ralf Corsepius Remove RTEMS_AMPOLISH3. Add checks for uint8_t, int8_t, uint16_t, … 4.104.114.84.95
(edit) @5fdca8a   11/15/06 14:15:24 Joel Sherrill 2006-11-15 Joel Sherrill <joel.sherrill@…> * … 4.104.114.84.95
(edit) @047d67a   11/15/06 14:08:49 Joel Sherrill 2006-11-15 Joel Sherrill <joel.sherrill@…> * … 4.104.114.84.95
(edit) @64d01b9   11/15/06 11:03:09 Ralf Corsepius Regenerate. 4.104.114.84.95
(edit) @fe3037df   11/14/06 21:44:25 Joel Sherrill 2006-11-14 Jiri Gaisler <jiri@…> * cpu_asm.S: Properly … 4.104.114.84.95
(edit) @d62a2e0   11/14/06 09:14:58 Ralf Corsepius 2006-11-14 Ralf Corsépius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @d826ef2b   11/12/06 11:19:08 Ralf Corsepius 2006-11-12 Ralf Corsépius <ralf.corsepius@…> * Makefile.am, … 4.104.114.84.95
(edit) @89434bf   11/12/06 11:18:45 Ralf Corsepius Regenerate. 4.104.114.84.95
(edit) @d8f6534   11/12/06 11:18:21 Ralf Corsepius Remove RTEMS_PROVIDES_STDINT_H, RTEMS_PROVIDES_INTTYPES_H. 4.104.114.84.95
(edit) @43912af   11/12/06 11:12:53 Ralf Corsepius 2006-11-12 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @0fefba6   11/12/06 11:03:48 Ralf Corsepius 2006-11-12 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @4df1b2e   11/09/06 11:11:03 Ralf Corsepius 2006-11-09 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @a6c5a6d1   11/09/06 11:10:50 Ralf Corsepius Remove stray whitespaces. 4.104.114.84.95
(edit) @1cb0a9b4   11/09/06 11:10:29 Ralf Corsepius Use BFIN instead of BFIN. 4.104.114.84.95
(edit) @65bee786   11/09/06 10:29:45 Ralf Corsepius changes 4.104.114.84.95
(edit) @e4fec90   11/09/06 10:28:59 Ralf Corsepius Add bfin. 4.104.114.84.95
(edit) @e306f333   11/09/06 07:49:21 Ralf Corsepius 2006-11-09 Ralf Corsépius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @fbf8301   11/08/06 08:42:45 Ralf Corsepius 2006-11-08 Ralf Corsépius <ralf.corsepius@…> * cpu_asm.S: … 4.104.114.84.95
(edit) @3faa99f2   11/08/06 08:23:35 Ralf Corsepius 2006-11-08 Ralf Corsépius <ralf.corsepius@…> * irq.c: Add … 4.104.114.84.95
(edit) @da959610   11/08/06 08:23:19 Ralf Corsepius Eliminate hidden backspaces. 4.104.114.84.95
(edit) @918b7a9   11/08/06 08:21:20 Ralf Corsepius Add missing newline 4.104.114.84.95
(edit) @068c3ee1   11/02/06 21:48:41 Joel Sherrill 2006-11-02 Steven Johnson <sjohnson@…> * … 4.104.114.84.95
(edit) @0c2ec7f   10/30/06 22:21:23 Joel Sherrill 2006-10-30 Joel Sherrill <joel@…> PR 841/rtems * … 4.104.114.84.95
(edit) @5112ff5a   10/25/06 11:28:08 Joel Sherrill 2006-10-25 Jennifer Averett <jennifer@…> * … 4.104.114.84.95
(edit) @e996604   10/24/06 20:24:29 Joel Sherrill 2006-10-24 Joel Sherrill <joel@…> * rtems/bfin/bfin.h: … 4.104.114.84.95
(edit) @9dfd75e   10/24/06 20:20:36 Joel Sherrill 2006-10-24 Alain Schaefer <alani@…> * Makefile.am, cpu.c, … 4.104.114.84.95
(edit) @b78d94d   10/23/06 19:39:51 Joel Sherrill 2006-10-23 Joel Sherrill <joel@…> * configure.ac, … 4.104.114.84.95
(edit) @5b8b467   10/23/06 17:19:52 Joel Sherrill 2006-10-23 Joel Sherrill <joel@…> * cpu.c, … 4.104.114.84.95
(edit) @d9a6ab3   10/23/06 17:17:50 Joel Sherrill 2006-10-23 Joel Sherrill <joel@…> * .cvsignore, ChangeLog?, … 4.104.114.84.95
(edit) @be8dd107   10/21/06 05:56:42 Ralf Corsepius 2006-10-21 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @80886bd   10/21/06 05:56:10 Ralf Corsepius Remove. 4.104.114.84.95
(edit) @cbeebc0   10/19/06 20:30:47 Joel Sherrill 2006-10-19 Joel Sherrill <joel@…> * score/Makefile.am, … 4.104.114.84.95
(edit) @04dba49   10/19/06 19:20:10 Joel Sherrill 2006-10-19 Joel Sherrill <joel@…> * configure.ac, … 4.104.114.84.95
(edit) @c461430   10/18/06 10:43:41 Ralf Corsepius 2006-10-18 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @9b5e72b   10/18/06 03:37:19 Ralf Corsepius 2006-10-18 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @0ec8e35   10/17/06 17:49:59 Ralf Corsepius 2006-10-17 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @4a6fd180   10/17/06 17:21:18 Ralf Corsepius 2006-10-17 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @2e28876   10/17/06 15:49:31 Ralf Corsepius 2006-10-17 Ralf Corsépius <ralf.corsepius@…> * … 4.104.114.84.95
(edit) @ba2c04f   10/17/06 07:38:02 Ralf Corsepius 2006-10-17 Ralf Corsépius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @ce1bdb08   10/17/06 07:29:40 Ralf Corsepius 2006-10-17 Ralf Corsépius <ralf.corsepius@…> * configure.ac: … 4.104.114.84.95
(edit) @879f1e4   10/16/06 16:04:48 Ralf Corsepius Fix broken file 4.104.114.84.95
(edit) @1133a80   10/16/06 15:59:25 Ralf Corsepius 2006-10-16 Ralf Corsépius <ralf.corsepius@…> * configure.ac, … 4.104.114.84.95
(edit) @ed908735   10/16/06 15:58:13 Ralf Corsepius Adaptations to automake-1.10. 4.104.114.84.95
(edit) @343408c   10/14/06 16:45:47 Ralf Corsepius This commit was generated by cvs2svn to compensate for changes in … 4.104.114.84.95
(edit) @db55493   10/14/06 16:45:47 Ralf Corsepius Import from zlib-1.2.4 4.104.114.84.95
(edit) @8462ac8a   09/28/06 14:57:07 Chris Johns 2006-09-29 Chris Johns <chrisj@…> * … 4.104.114.84.95
(edit) @8dec181   09/28/06 14:44:50 Chris Johns Flush stdout after updating the command line. 4.104.114.84.95
(edit) @7fb2bb2   09/25/06 14:19:45 Joel Sherrill 2006-09-14 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @7fa1ce86   09/25/06 14:03:51 Joel Sherrill 2006-09-25 Joel Sherrill <joel.sherrill@…> * … 4.104.114.84.95
(edit) @8042961d   09/25/06 13:38:24 Joel Sherrill 2006-09-25 Joel Sherrill <joel.sherrill@…> * … 4.104.114.84.95
(edit) @161f25b5   09/25/06 13:37:55 Joel Sherrill Add name. 4.104.114.84.95
(edit) @9c191ee   09/25/06 13:36:58 Joel Sherrill * score/Makefile.am, score/preinstall.am, … 4.104.114.84.95
(edit) @90d2585a   09/14/06 19:09:06 Joel Sherrill 2006-09-14 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @bc11ec2   09/14/06 15:07:19 Joel Sherrill 2006-09-14 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @5c1023a0   09/13/06 16:54:54 Joel Sherrill 2006-09-13 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @7ac4ae9   09/13/06 16:22:24 Joel Sherrill 2006-09-13 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @957d886   09/11/06 21:42:23 Joel Sherrill 2006-09-11 Joel Sherrill <joel@…> * libmisc/mw-fb/mw_fb.c, … 4.104.114.84.95
(edit) @ea1d598f   09/11/06 21:41:36 Joel Sherrill 2006-09-11 Joel Sherrill <joel@…> * cpu.c: Remove warning. 4.104.114.84.95
(edit) @ea7fd1ec   09/11/06 17:34:10 Joel Sherrill 2006-09-11 Jerry Needell <jerry.needell@…> * … 4.104.114.84.95
(edit) @bc69c485   09/08/06 20:28:56 Joel Sherrill 2006-09-08 Ken Peters <ken.peters@…> PR 1170/rtems * … 4.104.114.84.95
(edit) @c2f22829   09/06/06 12:55:52 Chris Johns 2006-09-06 Chris Johns <chrisj@…> * pppd/pppd.h: … 4.104.114.84.95
(edit) @b59eff1   09/06/06 05:13:42 Chris Johns Fix the bug in name change. The UNTIMEOUT macro did not use the ppp … 4.104.114.84.95
(edit) @d2efdeb1   09/01/06 21:21:43 Joel Sherrill 2006-09-01 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @d8f86d9   09/01/06 21:16:19 strauman * pppd/rtems.main.c, pppd/pppd.h: renamed 'untimeout' to … 4.104.114.84.95
(edit) @cf04e8ac   09/01/06 19:10:01 Joel Sherrill * empty log message * 4.104.114.84.95
(edit) @300c914c   09/01/06 18:15:01 Joel Sherrill * empty log message * 4.104.114.84.95
(edit) @b3ee778e   09/01/06 15:37:47 Joel Sherrill 2006-09-01 Joel Sherrill <joel@…> * … 4.104.114.84.95
(edit) @ddee935   08/31/06 01:53:35 Joel Sherrill 2006-08-30 Joel Sherrill <joel@…> * rtems/score/cpu.h: … 4.104.114.84.95
