@3f0c0bfe
05/05/21 11:26:44 |
Sebastian Huber |
rtems: rtems_scheduler_ident_by_processor_set()
Check for a NULL …
@cd5fd85
03/18/21 17:01:27 |
stephen.clark |
stackchk: Fixed 32bit pointers
Using 32bit types like uint32_t for …
@ca02143
03/18/21 16:54:03 |
stephen.clark |
rtems-fdt: Fixed 32bit pointers
@3e16f1a6
05/04/21 07:36:00 |
Sebastian Huber |
score: Make _Once_Lock() and _Once_Unlock() static
These two …
@024d4ea
04/09/21 17:53:22 |
Sebastian Huber |
rtems: Use allocator mutex for timer server
The allocator mutex is …
@d692c62d
05/03/21 07:17:33 |
Sebastian Huber |
Make zero size allocation result consistent
The zero size allocations …
@5b97821
04/08/21 05:51:38 |
Sebastian Huber |
libtest: Fix use of flexible array member
Flexible array members must …
@1eb6cdde
04/30/21 14:58:50 |
Sebastian Huber |
score: Add _Thread_Dispatch_direct_no_return()
The …
@a84bf96
04/30/21 13:07:14 |
Sebastian Huber |
basedefs: Add RTEMS_NOINIT
Update #3866.
@8b15a324
04/26/21 08:15:05 |
Sebastian Huber |
Use alias for rtems_task_self() and pthread_self()
This may reduce …
@0906321
04/30/21 05:08:19 |
Sebastian Huber |
appl-config: Add missing "the"
@901136e
04/30/21 05:07:30 |
Sebastian Huber |
appl-config: CONFIGURE_BSP_PREREQUISITE_DRIVERS
Replace copy and …
@eefe7009
04/29/21 08:02:56 |
Sebastian Huber |
appl-config: Reformat option constraints
If only one constraint is …
@8e4f578
04/28/21 17:51:07 |
vijay |
cpukit/Makefile.am: Remove remaining LIBNETWORKING files
@8cf30c4
03/10/21 18:51:20 |
ryan.long |
main_rtrace.c: Add error return when malloc fails
CID 1399709: …
@cdf66529
03/10/21 15:05:21 |
ryan.long |
objectextendinformation.c: Ensure information->object_blocks is not …
@a70d60a
04/28/21 20:24:54 |
ryan.long |
pwdgrp.c: Removed unused variable
The 'sc' variable was originally …
@a1679af3
06/15/20 09:10:02 |
Sebastian Huber |
rtems: Generate <rtems/rtems/tasks.h>
Change license to BSD-2-Clause …
@b3d3186d
06/24/20 05:10:06 |
Sebastian Huber |
rtems: Generate <rtems/rtems/region.h>
@0b9e307
06/22/20 12:20:19 |
Sebastian Huber |
rtems: Generate <rtems/rtems/intr.h>
@278c7daa
04/28/21 05:38:29 |
Sebastian Huber |
rtems: Fix typo "cod" -> "code"
@55c6cb1d
04/22/21 13:57:19 |
Sebastian Huber |
rtems: Clarify constraints in documentation
@bbc93c11
04/26/21 11:36:46 |
Sebastian Huber |
Return status code for _Thread_Start()
This avoids having conditional …
@9d82150
04/26/21 09:22:39 |
Sebastian Huber |
Return status code for _Scheduler_Set_affinity()
This avoids having …
@4b7c77b
04/26/21 09:00:24 |
Sebastian Huber |
rtems: Change rtems_task_get_affinity() status
In case the processor …
@127a812
04/26/21 08:39:08 |
Sebastian Huber |
Simplify get affinitiy directives
There is no need to disable thread …
@1452699
04/26/21 08:34:11 |
Sebastian Huber |
Return status code for _Scheduler_Get_affinity()
@2684f2a3
04/27/21 08:54:04 |
Sebastian Huber |
rtems: Constify timer fire when directives
Close #4392.
@e29d5cd
04/25/21 04:26:45 |
vijay |
Makefile.am: Remove legacy networking files
@de6e515
06/24/20 04:58:53 |
Sebastian Huber |
rtems: Generate <rtems/rtems/ratemon.h>
Change license to …
@73a0175
06/24/20 04:34:49 |
Sebastian Huber |
rtems: Generate <rtems/rtems/message.h>
Change license to …
@f14cf0c
04/23/21 06:21:48 |
Sebastian Huber |
rtems: Check for NULL config in task construct
Since there are …
@03747b50
04/23/21 06:19:43 |
Sebastian Huber |
rtems: Check for NULL config in msgq construct
Since there are …
@8854aec1
04/22/21 13:57:19 |
Sebastian Huber |
rtems: Mention timer server fire directives
A timer may be also …
@b229b4c
06/24/20 06:09:03 |
Sebastian Huber |
rtems: Generate <rtems/rtems/support.h>
Change license to …
@e8be0047
06/24/20 06:43:13 |
Sebastian Huber |
rtems: Generate <rtems/rtems/mp.h>
@0be4b882
06/22/20 07:51:06 |
Sebastian Huber |
rtems: Generate <rtems/rtems/dpmem.h>
@71a2e7e
05/28/20 11:47:28 |
Sebastian Huber |
rtems: Generate <rtems/init.h>
@97ba94b
06/22/20 09:41:37 |
Sebastian Huber |
rtems: Generate <rtems/fatal.h>
@7bbbe42
04/08/21 13:41:15 |
frank.kuehndel |
clock:_TOD_To_seconds(): Fix year 2514 overflow
This patch fixes …
@51defd92
04/20/21 17:30:35 |
Sebastian Huber |
Fix calloc() behaviour in case of overflow
The multiplication to …
@6c66bbb
04/20/21 07:58:06 |
Sebastian Huber |
malloc: Hide RTEMS_Malloc_Sbrk_amount
Move RTEMS_Malloc_Sbrk_amount …
@d8a5e14
04/20/21 06:41:00 |
Sebastian Huber |
libcsupport: Move rtems_calloc()
Move rtems_calloc() since it only …
@2b32146
04/20/21 07:33:52 |
Sebastian Huber |
Remove superfluous <rtems/score/wkspace.h> includes
@0e49372a
04/19/21 18:06:27 |
Sebastian Huber |
score: Remove unused _Thread_queue_Dequeue()
Last use was removed by: …
@69bde47
04/05/21 21:28:10 |
kinsey.moore |
cpukit/aarch64: Restore ISR cookie bit mask
The _CPU_ISR_Is_enabled() …
@00f9faf2
04/16/21 13:22:04 |
Sebastian Huber |
rtems: Document rtems_semaphore_obtain() errors
@0cbbcef
04/13/21 17:58:48 |
vijay |
Revert "cpukit/include: Remove telnetd.h"
This reverts commit …
@650ac700
04/13/21 17:57:21 |
vijay |
Revert "cpukit: Remove telnetd"
@09d811b
03/12/21 20:56:03 |
ryan.long |
fastlz.c: Unused value (CID #1399751)
CID 1399751: Unused value in …
@0b23660
03/12/21 20:25:40 |
ryan.long |
print-ls.c: Unused value (CID #1255346)
CID 1255346: Unused value in …
@fbc76440
03/12/21 17:14:47 |
ryan.long |
main_cp.c: Unused value (CID #1255344)
CID 1255344: Unused value in …
@83835729
03/03/21 19:53:27 |
vijay |
Update #3850
@3299dda2
02/26/21 22:51:07 |
vijay |
Update #3850
@6692e03
02/25/21 02:08:51 |
vijay |
cpukit/libfs: Remove nfsclient
Update #3850
@369e6c5b
02/25/21 02:08:09 |
vijay |
cpukit: remove pppd
Update #3850
@2a13ad3
02/25/21 02:06:38 |
vijay |
cpukit: Remove libnetworking
Update #3850
@a28eafb
02/24/21 19:27:29 |
vijay |
cpukit: Move ftpfs from libnetworking to libfs
Update #3850
@809b76ec
04/07/21 05:08:43 |
Sebastian Huber |
rtems: Fix rtems_semaphore_release() documentation
The directive …
@089e6818
04/06/21 14:00:35 |
Sebastian Huber |
score: Replace Objects_Name_or_id_lookup_errors
Replace …
@d1c038c7
03/24/21 19:13:34 |
Sebastian Huber |
score: Fix internal error status number
The value of …
@1af1c19
03/22/21 17:52:00 |
alex.white |
cpukit/aarch64: Add ESR register decoding
@1e62e15f
03/27/21 17:08:13 |
Sebastian Huber |
score: Add an assert to _Workspace_Free()
@e0aba8cb
03/27/21 10:15:43 |
Sebastian Huber |
score: Fix task stack initialization
Do not adjust the stack area …
@d4d2f648
03/27/21 14:55:49 |
joel |
pwdgrp.c: Change to simply ignore return value from mkdir(/etc)
At …
@fd639b8
01/21/21 15:53:55 |
christian.mauderer |
dosfs: Use peek support
This speeds up reading fragmented files.
Fix …
@6ae79e6
01/19/21 14:33:35 |
libblock: Add rtems_bdbuf_peek()
Adds a peek function that allows …
@62bbb0c
03/24/21 12:57:43 |
joel |
gen_uuid.c: Revert previous patch …
@37fc651
03/23/21 16:25:15 |
ryan.long |
pwdgrp.c: Remove _Assert. /etc may already exist
Removed the …
@bd9e45d9
03/18/21 02:50:56 |
niteesh.gs |
rtems-fdt/rtems-fdt.c: Fix bug in loop termination
The while loop, …
@53bd5e32
03/17/21 07:09:49 |
Sebastian Huber |
rtems: Relax mode checks in rtems_signal_catch()
Check only for …
@50abce31
03/18/21 09:37:23 |
Sebastian Huber |
rtems: Fix rtems_task_mode()
Do the ASR and preemption mode change …
@b4eb937
03/12/21 14:13:27 |
Sebastian Huber |
rtems: Improve semaphore create error checks
Do not mix checks for …
@4ebdbee
03/12/21 13:37:10 |
Sebastian Huber |
rtems: Allow initially locked MrsP semaphores
Rejecting initially …
@0965b7c8
03/12/21 13:16:30 |
Sebastian Huber |
rtems: Require RTEMS_PRIORITY for MrsP semaphores
MrsP semaphores are …
@c9a41b00
03/12/21 07:31:35 |
Sebastian Huber |
score: Add Thread_Configuration::cpu_time_budget
Move the CPU time …
@b2da982
04/21/20 09:57:50 |
Daniel Hellstrom |
leon,tn-0018: work around GRLIB-TN-0018 errata
Overview
The …
@89d90c0
11/25/19 08:45:26 |
Daniel Hellstrom |
sparc,leon: avoid triggering LEON3FT errata TN-0009
Close #4336.
@acad761
11/20/19 12:19:35 |
Daniel Hellstrom |
sparc,leon: avoid triggering TN-0009 bad sequence
Update #4336.
@1d804cb
11/14/19 09:26:21 |
Daniel Hellstrom |
sparc: fix bad register alignment for 64 bit store
@0cae482a
12/19/17 12:37:08 |
cederman |
sparc: Remove sequences that the B2BST scan script warns about
Update …
@14bb077
03/09/21 12:01:11 |
frank.kuehndel |
basedefs: Clarify RTEMS_STRING(), RTEMS_XSTRING()
@fbab832
03/02/21 18:51:46 |
ryan.long |
main_help.c: Unchecked return value from library (CID #1437650)
CID …
@55ba229
03/02/21 16:46:02 |
ryan.long |
pwdgrp.c: Fix Unchecked return value from library (CID #1255518)
CID …
@8e34aa3
03/02/21 16:34:36 |
ryan.long |
main_chmod.c: Fix Unchecked return value from library (CID #1063856)
@597e4f4
03/02/21 16:08:28 |
ryan.long |
gen_uuid.c: Fix two Unchecked return value from library errors
CID …
@3246fa42
03/01/21 16:07:42 |
ryan.long |
main_edit.c: Fix Unchecked return value (CID #1255318)
CID 1255318: …
@0d33d10
03/01/21 21:33:10 |
ryan.long |
pci_cfg_read.c: Fix Missing break in switch (CID #1399723)
CID …
@c7eb89f8
03/01/21 21:06:41 |
ryan.long |
cpuusagetop.c: Fix three Missing break in switch Coverity errors
CID …
@9951cee
02/15/21 15:05:10 |
kinsey.moore |
bsps/aarch64: RTEMS_DEBUG stack alignment faults
Run with stack …
@9aff7e56
01/11/21 16:23:16 |
alex.white |
score/aarch64: Fix interrupt level reads
@bbc9974a
02/15/21 16:51:37 |
kinsey.moore |
cpukit: Explicitly enforce alignment requirements
According to …
@61d688bf
03/04/21 07:12:47 |
Sebastian Huber |
aarch64: Fix context switch
The Per_CPU_Control::isr_dispatch_disable …
@5248395
03/03/21 08:23:20 |
Sebastian Huber |
score: Ensure stack alignment requirement
Make sure that a …
@1de00d6
03/03/21 08:36:45 |
Sebastian Huber |
CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE
Ensure that …
@30f6fd5b
03/03/21 07:04:55 |
Sebastian Huber |
rtems: Fix RTEMS_TASK_STORAGE_ALIGNMENT
Make sure we meet the stack …
@4a765b47
03/03/21 07:39:33 |
Sebastian Huber |
score: Enforce CPU_STACK_ALIGNMENT requirements
Clarify …
@83b1b25d
03/02/21 11:31:45 |
Sebastian Huber |
rtems: Simplify rtems_signal_catch()
In uniprocessor configurations, …
@9a13f37
03/02/21 09:55:10 |
Sebastian Huber |
rtems: Simplify _Signal_Action_handler()
Use the invariant that an …
@441824a
03/01/21 07:12:54 |
Sebastian Huber |
score: Simplify _Objects_Name_to_id_u32()
Remove superfluous check …
