@2e0ebd11
06/12/96 22:49:33 |
Joel Sherrill |
added initialization of posix signal manager.
4.104.114.84.95
@281ad52
06/12/96 22:49:14 |
Joel Sherrill |
basic kill() which send a signal to pthread_self() appears to work.
4.104.114.84.95
@4a1bc34b
06/12/96 17:45:34 |
Joel Sherrill |
added waiting for signal state.
4.104.114.84.95
@2291b71
06/12/96 17:45:01 |
Joel Sherrill |
initial implementation of blocking signal routines -- sigwait, …
4.104.114.84.95
@937808f5
06/11/96 22:55:39 |
Joel Sherrill |
added comment to make sure we add unblock of thread
4.104.114.84.95
@ea1a5bef
06/11/96 22:52:42 |
Joel Sherrill |
first attempt at adding algorithm to select the thread which will …
4.104.114.84.95
@20d099e
06/11/96 22:51:59 |
Joel Sherrill |
deleted field for signals_global_pending.
4.104.114.84.95
@c8f5ab5
06/11/96 20:43:55 |
Joel Sherrill |
tested blocking a signal, sending it to self, then unblocking it.
4.104.114.84.95
@12aeff91
06/11/96 16:03:15 |
Joel Sherrill |
Interruptible by signals state was added to the STATES_BLOCKED set. …
4.104.114.84.95
@98ed15e
06/11/96 16:01:37 |
Joel Sherrill |
Basic signal functionality appears to work. pthread_kill() can …
4.104.114.84.95
@d0baf81
06/11/96 16:00:06 |
Joel Sherrill |
new file.
4.104.114.84.95
@494740c
06/10/96 21:04:14 |
Joel Sherrill |
added psignal.h
4.104.114.84.95
@0f63c86
06/10/96 20:47:56 |
Joel Sherrill |
added code to _Thread_Clear_state to check if the state was not …
4.104.114.84.95
@fdec30b
06/10/96 20:47:23 |
Joel Sherrill |
first attempt at the routine which vectors signals.
4.104.114.84.95
@d03f192
06/10/96 20:46:36 |
Joel Sherrill |
* empty log message *
4.104.114.84.95
@81daab3
06/07/96 15:22:19 |
Joel Sherrill |
added states for "join at exit" and "interruptible by signal"
4.104.114.84.95
@05ce4e09
06/07/96 15:21:27 |
Joel Sherrill |
changed code which set errno and then returned -1 to use the macro …
4.104.114.84.95
@895efd9
06/07/96 13:54:23 |
Joel Sherrill |
key destructor is now run at correct point in pthread_exit() sequence …
4.104.114.84.95
@fce2e9d
06/06/96 21:27:33 |
Joel Sherrill |
in newlib now
4.104.114.84.95
@782bdfd
06/06/96 19:09:27 |
Joel Sherrill |
Removed assert's from routines which return the error ENOSYS.
4.104.114.84.95
@09b1f1a
06/06/96 17:57:39 |
Joel Sherrill |
patch from Tony Bennett on the ifdef for O_NDELAY
4.104.114.84.95
@e754dd1d
06/06/96 17:54:37 |
Joel Sherrill |
process oriented scheduler routines now return ENOSYS
4.104.114.84.95
@5d9cb7e
06/06/96 17:24:44 |
Joel Sherrill |
removed timer_getoverrun() since it was also in ptimer.c
4.104.114.84.95
@0207c55
06/06/96 15:36:18 |
Joel Sherrill |
Made the implementation of pthread_equal conditional on RTEMS_DEBUG. …
4.104.114.84.95
@65a5c1b
06/06/96 15:32:49 |
Joel Sherrill |
completed pthread_setschedparam.
4.104.114.84.95
@ebd40c0
06/06/96 14:55:08 |
Joel Sherrill |
Added Sporadic Server support to posix threads which required changes …
4.104.114.84.95
@2f200c7
06/06/96 14:55:01 |
Joel Sherrill |
4.104.114.84.95
@624133c
06/06/96 14:53:12 |
Joel Sherrill |
added Sporadic Server support
4.104.114.84.95
@ed10d76
06/06/96 14:52:53 |
Joel Sherrill |
added Sporadic_timer field to support sporadic server
4.104.114.84.95
@7aa4671
06/05/96 21:12:06 |
Joel Sherrill |
added cpu_time_budget field to Thread_Control and removed the global …
4.104.114.84.95
@7169852
06/05/96 18:34:48 |
Joel Sherrill |
fixed spacing
4.104.114.84.95
@23305a25
06/05/96 14:46:04 |
Joel Sherrill |
added support for the api providing the thread stack area
4.104.114.84.95
@98162c35
06/05/96 14:45:45 |
Joel Sherrill |
added boolean to indicate whether or not the stack area was provided …
4.104.114.84.95
@9b4e549
06/05/96 14:45:05 |
Joel Sherrill |
renamed Schedule to schedparam in the posix api control information.
4.104.114.84.95
@7189a40
06/05/96 14:44:03 |
Joel Sherrill |
added comments to to document the definition of posix priority
and how …
4.104.114.84.95
@09c1e31d
06/05/96 14:43:52 |
Joel Sherrill |
added comments to priority.h to document the definition of posix …
4.104.114.84.95
@2c207d1f
06/04/96 20:36:37 |
Joel Sherrill |
make PTHREAD_SCOPE_SYSTEM an unsupported value for contentionscope.
4.104.114.84.95
@65911c32
06/04/96 19:50:15 |
Joel Sherrill |
made sure _Thread_Enable_dispatch is not invoked in cases
where …
4.104.114.84.95
@56bd4a36
06/04/96 19:48:08 |
Joel Sherrill |
made sure routines which called _Objects_Get also called …
4.104.114.84.95
@230a0dcb
06/04/96 19:44:16 |
Joel Sherrill |
added some of the required functionality to pthread_setschedparam and …
4.104.114.84.95
@3ff4688
06/04/96 19:20:53 |
Joel Sherrill |
clean up pass
4.104.114.84.95
@6b067c4
06/04/96 19:15:28 |
Joel Sherrill |
renamed the local variable attrp to the_attr in pthread_create
4.104.114.84.95
@24adc5b
06/04/96 19:05:16 |
Joel Sherrill |
changed sched_rr_get_interval to use the interval to timespec routine.
4.104.114.84.95
@c48e0ee
06/04/96 16:15:59 |
Joel Sherrill |
added interpretation of scheduling policy and parameter information to …
4.104.114.84.95
@12c77ab
06/04/96 16:14:55 |
Joel Sherrill |
added scheduling policy and parameter information
4.104.114.84.95
@8f857992
06/03/96 22:08:18 |
Joel Sherrill |
added thread queue for list of threads waiting to join.
thread is …
4.104.114.84.95
@552a345d
06/03/96 22:07:14 |
Joel Sherrill |
4.104.114.84.95
@742b399
06/03/96 21:08:26 |
Joel Sherrill |
added priority ceiling support
4.104.114.84.95
@f39b01e
06/03/96 21:08:16 |
Joel Sherrill |
added an assert if a pthread_t is not the same size as an Objects_Id
4.104.114.84.95
@e811d68
06/03/96 21:06:51 |
Joel Sherrill |
deleted POSIX threads typedef masking Thread_Control
added initial …
4.104.114.84.95
@4427a64
06/03/96 21:06:12 |
Joel Sherrill |
4.104.114.84.95
@685f4d65
06/03/96 18:59:24 |
Joel Sherrill |
sleep moved into newlibc.c so the sleep.o object would not be in the …
4.104.114.84.95
@a26ee01c
06/03/96 18:27:48 |
Joel Sherrill |
nanosleep now fills in the time remaining structure.
4.104.114.84.95
@5b748a1
06/03/96 17:32:19 |
Joel Sherrill |
renamed _POSIX_Time_Spec_to_interval to _POSIX_Timespec_to_interval
4.104.114.84.95
@5ff991e8
06/03/96 16:29:59 |
Joel Sherrill |
created ptimer.c and moved the timer_* routines out of time.c into ptimer.c
4.104.114.84.95
@a3828359
06/03/96 16:29:35 |
Joel Sherrill |
added constant for seconds between posix epoch (1970) and rtems epoch …
4.104.114.84.95
@f6e6ed8
06/03/96 15:49:22 |
Joel Sherrill |
changed so this file is usable from assembly files.
no longer uses …
4.104.114.84.95
@5e7b6272
05/31/96 23:27:45 |
Joel Sherrill |
renamed _TOD_Ticks_since_boot as _Watchdog_Ticks_since_boot so the …
4.104.114.84.95
@c238a218
05/31/96 21:40:48 |
Joel Sherrill |
added checks to validate values passed to set attribute routines
4.104.114.84.95
@c832429
05/31/96 19:02:13 |
Joel Sherrill |
added nanoseconds per second constant
4.104.114.84.95
@e72d995a
05/31/96 19:01:26 |
Joel Sherrill |
moved sleep() from psignal.c to unistd.c
implemented sigemptyset() …
4.104.114.84.95
@b927fba
05/31/96 18:59:57 |
Joel Sherrill |
commented out cancel handlers related items.
4.104.114.84.95
@7c55e06
05/30/96 20:48:33 |
Joel Sherrill |
Added nanoseconds constant
4.104.114.84.95
@5600661
05/30/96 20:48:10 |
Joel Sherrill |
First cut at implementing time, clock_gettime, clock_settime, …
4.104.114.84.95
@b169590e
05/30/96 20:34:46 |
Joel Sherrill |
added dummy versions of kill and getpid which assert(0) so that …
4.104.114.84.95
@be1c11ed
05/29/96 22:48:26 |
Joel Sherrill |
tests now specify whether using posix initialization threads table
or …
4.104.114.84.95
@dd32d883
05/29/96 22:46:05 |
Joel Sherrill |
posix initialization threads table was misnamed "posix initialization …
4.104.114.84.95
@7f72217e
05/29/96 21:27:26 |
Joel Sherrill |
comment clean up
4.104.114.84.95
@2a98af84
05/29/96 21:02:20 |
Joel Sherrill |
types.c: spacing
psignal.c: kill recognizes SIGABRT and exits to …
4.104.114.84.95
@5240c71c
05/29/96 20:58:45 |
Joel Sherrill |
fixed support for posix initialization threads table
4.104.114.84.95
@cfcfdf0
05/29/96 20:55:05 |
Joel Sherrill |
added pthread_exit
first posix thread ran
4.104.114.84.95
@5e0efa2b
05/29/96 20:50:52 |
Joel Sherrill |
cleaned up spacing and parentheses
4.104.114.84.95
@d835a35
05/29/96 19:28:15 |
Joel Sherrill |
spacing
4.104.114.84.95
@ece8c9a
05/29/96 19:28:01 |
Joel Sherrill |
first cut at pthread_create
4.104.114.84.95
@9c877c0d
05/29/96 18:46:46 |
Joel Sherrill |
addressed minimum stack size attribute.
There is a potential problem …
4.104.114.84.95
@98849f44
05/29/96 16:55:05 |
Joel Sherrill |
4.104.114.84.95
@613cff6
05/29/96 16:54:52 |
Joel Sherrill |
removed all ifdef's on NOT_IMPLEMENTED.
4.104.114.84.95
@e941ea13
05/29/96 16:54:24 |
Joel Sherrill |
added entry point for posix initialization threads to the posix …
4.104.114.84.95
@d9a0689e
05/29/96 16:07:21 |
Joel Sherrill |
Addressed RTEMS API initialization tasks table in a system without …
4.104.114.84.95
@99f9dffa
05/29/96 16:05:28 |
Joel Sherrill |
Added default POSIX API configuration table.
4.104.114.84.95
@019bce7
05/29/96 16:05:06 |
Joel Sherrill |
It is now not an error to have 0 RTEMS initialization tasks since you …
4.104.114.84.95
@974ff40
05/29/96 16:04:31 |
Joel Sherrill |
renamed signal.c to psignal.c to avoid naming problems.
added mp …
4.104.114.84.95
@c627b2a3
05/28/96 21:40:52 |
Joel Sherrill |
split the inclusion of "EXTERN" data based on whether it was sapi, …
4.104.114.84.95
@c6fa38c0
05/28/96 19:29:51 |
Joel Sherrill |
added maximum keys
4.104.114.84.95
@7640525
05/28/96 19:29:02 |
Joel Sherrill |
added enumerated constant for the POSIX API as an error source
4.104.114.84.95
@5a18e04
05/28/96 19:28:32 |
Joel Sherrill |
added initial set of api extension callouts
4.104.114.84.95
@2b4683a
05/28/96 17:13:29 |
Ralf Corsepius |
This commit was generated by cvs2svn to compensate for changes in …
4.104.114.84.95
@bc69a859
05/28/96 17:13:29 |
Ralf Corsepius |
Import from zlib-1.2.4
4.104.114.84.95
@962c9b65
05/28/96 16:33:11 |
Joel Sherrill |
new file
4.104.114.84.95
@47d6b140
05/28/96 16:32:55 |
Joel Sherrill |
commented out interrupt support
4.104.114.84.95
@da33d26
05/28/96 16:18:34 |
Joel Sherrill |
added ifndef's for the POSIX maximum field in the POSIX api …
4.104.114.84.95
@d4b44877
05/28/96 16:17:01 |
Joel Sherrill |
added posix api initialization call to init.c
deleted a blank line in …
4.104.114.84.95
@8165b48f
05/28/96 16:16:28 |
Joel Sherrill |
comment cleanup
4.104.114.84.95
@52d9e4d1
05/28/96 16:16:11 |
Joel Sherrill |
added maximum keys
4.104.114.84.95
@2eba45d
05/28/96 14:16:45 |
Joel Sherrill |
made posix configuration information conditional so configurations …
4.104.114.84.95
@cb96372
05/28/96 13:24:58 |
Joel Sherrill |
changed call to _ISR_Enable() to _ISR_Set_level() in _Thread_Handler. …
4.104.114.84.95
@e6d4b1d
05/28/96 13:13:34 |
Joel Sherrill |
added initial posix configuration support
4.104.114.84.95
@568ebf3
05/24/96 19:32:37 |
Joel Sherrill |
updates to fix typos
4.104.114.84.95
@8b2ecf85
05/23/96 15:37:38 |
Joel Sherrill |
updates from Tony Bennett
4.104.114.84.95
@859f17ce
05/23/96 15:35:26 |
Joel Sherrill |
invoke thread stack free routine instead of Workspace free.
4.104.114.84.95
