@28b8cf9b
08/02/18 07:41:08 |
Sebastian Huber |
riscv: Fix CPU_ALIGNMENT
Update #3433.
5
@334e1d2
07/30/18 05:35:26 |
Sebastian Huber |
confdefs: Fix uniprocessor configuration
Introduce a new internal …
5
@cfc9573
07/27/18 12:47:17 |
Sebastian Huber |
riscv: Rework CPU counter support
Update #3433.
5
@6b9ef09
07/20/18 08:57:59 |
Sebastian Huber |
riscv: Add CLINT and PLIC support
The CLINT and PLIC need some …
5
@c2670de
07/20/18 07:07:40 |
Sebastian Huber |
riscv: Use wfi instruction for idle task
Update #3433.
5
@8db3f0e
07/19/18 10:11:19 |
Sebastian Huber |
riscv: Rework exception handling
Remove …
5
@5694b0c
07/19/18 08:15:53 |
Sebastian Huber |
riscv: New CPU_Exception_frame
Use the CPU_Interrupt_frame for the …
5
@d779a1e2
07/19/18 07:35:54 |
Sebastian Huber |
riscv: Add exception codes
Update #3433.
5
@5677883
07/24/18 07:09:06 |
Sebastian Huber |
score: _SMP_Inter_processor_interrupt_handler()
Optimize …
5
@a1f7d7d
07/24/18 07:00:18 |
Sebastian Huber |
score: RTEMS_PREDICT_TRUE(), RTEMS_PREDICT_FALSE()
Add …
5
@406dd62
07/24/18 09:18:27 |
Sebastian Huber |
_SMP_Start_multitasking_on_secondary_processor()
Pass current …
5
@0d362ff3
07/23/18 12:54:51 |
Sebastian Huber |
Pass current …
5
@f8d00a3
07/25/18 06:00:22 |
Sebastian Huber |
tm27: Fix prototype warnings
5
@05259de1
07/25/18 07:54:56 |
Sebastian Huber |
powerpc: Fix _CPU_Instruction_illegal()
Apparently the .word …
5
@3a646426
07/19/18 10:53:34 |
Sebastian Huber |
score: Add _CPU_Instruction_illegal()
On some …
5
@b74353e
07/20/18 06:06:46 |
Sebastian Huber |
score: Add _CPU_Instruction_no_operation()
This helps to reduce the …
5
@42f2fdfd
07/20/18 05:56:43 |
Sebastian Huber |
score: Move context validation declarations
The context validation …
5
@248ca7a
07/20/18 07:10:29 |
Sebastian Huber |
score: Remove obsolete CPU port defines
5
@1554a8c5
07/20/18 06:47:25 |
Sebastian Huber |
dtc: Update VERSION
5
@ec2de39
07/19/18 06:19:43 |
Sebastian Huber |
libfdt: fdt_address_cells() and fdt_size_cells()
Add internal …
5
@513daa3
07/19/18 11:06:49 |
Sebastian Huber |
capture: Include missing header file
5
@b4f15d8
07/19/18 05:10:26 |
Sebastian Huber |
jffs2: Rename README to VERSION
This makes it easer to find files …
5
@2af004e
07/18/18 07:32:28 |
Sebastian Huber |
dtc: Add VERSION file
Close #3471.
5
@80eaf45
07/09/18 04:50:38 |
david |
libfdt: Add necessary header padding in fdt_create()
At present …
5
@4fd05d3
07/07/18 19:57:19 |
sjg |
libfdt: Copy the struct region in fdt_resize()
At present this …
5
@78ad048
06/21/18 05:32:40 |
david |
libfdt: Add helpers for accessing unaligned words
This adds some …
5
@3848f14b
06/06/18 21:37:05 |
sjg |
pylibfdt: Add functions to update properties
Allow updating and …
5
@0d851d4
03/17/18 13:12:12 |
david |
libfdt: Add fdt_check_full() function
This new function implements a …
5
@9a7de8e
03/16/18 11:40:26 |
david |
libfdt: Add fdt_header_size()
We have a couple of places within …
5
@c81f432
03/09/18 12:28:56 |
david |
libfdt: Safer access to memory reservations
fdt_num_mem_rsv() and …
5
@6bc883b
03/25/18 11:54:22 |
david |
libfdt: Propagate name errors in fdt_getprop_by_offset()
5
@72273b6
11/14/17 11:45:56 |
david |
libfdt: Safer access to strings section
fdt_string() is used to …
5
@8073f95e
10/23/17 03:45:56 |
david |
libfdt: Make fdt_check_header() more thorough
Currently …
5
@c4267b1
04/10/18 07:06:18 |
david |
libfdt: Improve sequential write state checking
When creating a tree …
5
@85d1769
10/22/17 05:32:15 |
david |
libfdt: Clean up header checking functions
Many of the libfdt entry …
5
@c13e400
01/25/18 05:13:40 |
nwhitehorn |
Add limited read-only support for older (V2 and V3) device tree to …
5
@4e5f848
10/26/17 01:13:46 |
programmingkidx |
implement strnlen for systems that need it
Prior the Mac OS 10.7, the …
5
@42f1b37
10/18/17 06:22:40 |
david |
libfdt: Remove leading underscores from identifiers
In a lot of …
5
@f5e879f
10/18/17 05:45:52 |
david |
Fix some errors in comments
A comment in tests/stringlist.c refers to …
5
@a1c3b41a
07/27/17 16:33:11 |
pantelis.antoniou |
Introduce fdt_setprop_placeholder() method
In some cases you need to …
5
@903d2ec
04/08/17 16:14:42 |
sjg |
Fix a few whitespace and style nits
These were noticed when synching …
5
@f984d8f
04/01/17 15:31:41 |
sjg |
Add a libfdt function to write a property placeholder
The existing …
5
@67f49b98
03/17/17 22:14:33 |
sjg |
Adjust libfdt.h to work with swig
There are a few places where …
5
@d0a1fc8
03/06/17 01:16:56 |
david |
libfdt: Change names of sparse helper macros
The default libfdt_env.h …
5
@90f54b0e
02/24/17 00:12:50 |
david |
libfdt: Add fdt_setprop_empty()
Device trees can contain empty (zero …
5
@6dbbd277
02/23/17 23:51:05 |
david |
libfdt: Remove undefined behaviour setting empty properties
The …
5
@8cd96f47
11/03/16 15:47:42 |
b-fair |
libfdt: add missing errors to fdt_strerror()
Some error values were …
5
@d8c856b
10/17/16 06:08:24 |
yamada.masahiro |
libfdt: fix fdt_stringlist_search()
If fdt_getprop() fails, negative …
5
@aa9389f
10/17/16 06:08:23 |
yamada.masahiro |
libfdt: fix fdt_stringlist_count()
5
@c753d9d
10/11/16 08:10:31 |
maxime.ripard |
fdt: strerr: Remove spurious BADOVERLAY
There's one …
5
@4f7c3ac9
10/06/16 11:39:56 |
maxime.ripard |
libfdt: Add BADPHANDLE error string
The BADPHANDLE error was missing …
5
@e879a98d
09/30/16 13:57:16 |
maxime.ripard |
libfdt: Add overlay application function
The device tree overlays are …
5
@b0ceda54
09/30/16 13:57:15 |
maxime.ripard |
libfdt: Extend the reach of FDT_ERR_BADPHANDLE
So far, the BADPHANDLE …
5
@2679534b
09/30/16 13:57:14 |
maxime.ripard |
libfdt: Add new errors for the overlay code
Add a few new error codes …
5
@f670acbf
09/26/16 16:12:26 |
thuth |
Fix some typing errors in libfdt.h and livetree.c
Correct some typos …
5
@607b70f
08/22/16 09:55:49 |
yamada.masahiro |
libfdt: simplify fdt_del_mem_rsv()
The variable "err" is unneeded.
5
@6112fb0b
07/29/16 09:55:48 |
maxime.ripard |
libfdt: Add fdt_setprop_inplace_namelen_partial
Add a function to …
5
@2086bbc8
07/27/16 12:55:56 |
maxime.ripard |
libfdt: Add fdt_getprop_namelen_w
Add a function to retrieve a …
5
@220cde8
07/27/16 12:55:55 |
maxime.ripard |
libfdt: Add max phandle retrieval function
Add a function to retrieve …
5
@eda76d4
07/27/16 12:55:54 |
maxime.ripard |
libfdt: Add iterator over properties
Implement a macro based on …
5
@da8eff99
07/27/16 12:55:53 |
treding |
libfdt: Add a subnodes iterator macro
The fdt_for_each_subnode() …
5
@8bbd8c7
03/07/16 03:12:48 |
sjg |
Correct a missing space in a fdt_header cast
The code style here is …
5
@8f6fb28c
03/07/16 03:12:47 |
sjg |
Correct line lengths in libfdt.h
There are a few lines that are over …
5
@34e6ae62
03/07/16 03:12:46 |
sjg |
Correct space-after-tab in libfdt.h
There are a few places with a …
5
@0ddfe029
02/12/16 05:45:12 |
yamada.masahiro |
libfdt: simplify fdt_node_check_compatible()
Because …
5
@87acb61e
12/17/15 06:19:11 |
david |
libfdt: Fix undefined behaviour in fdt_offset_ptr()
Using pointer …
5
@b41cd6c
12/02/15 00:43:10 |
courtney.cavin |
libfdt: check for potential overrun in _fdt_splice()
This patch …
5
@bda8f80
07/18/18 06:54:57 |
Sebastian Huber |
score: Add a FALLTHROUGH comment to kvprintf()
This change was added …
5
@ffd4617
07/17/18 13:33:49 |
Sebastian Huber |
score: Fix _Scheduler_EDF_SMP_Set_affinity()
Commit …
5
@da0cbef2
07/16/18 06:22:57 |
Sebastian Huber |
score: Avoid structurally dead code
This was spotted by Coverity Scan.
5
@6ec7f21
07/16/18 06:31:05 |
Sebastian Huber |
posix: Fix rwlock auto initialization
Add more test cases.
5
@00a19d6
07/05/18 07:06:56 |
Sebastian Huber |
jffs2: Add README
Add README to document the corrspending Linux …
5
@682ecda
02/12/18 21:03:10 |
boris.brezillon |
mtd: Unconditionally update ->fail_addr and ->addr in part_erase()
5
@808c092
02/12/18 21:03:09 |
boris.brezillon |
mtd: Stop assuming mtd_erase() is asynchronous
None of the …
5
@638948c
02/23/17 00:34:00 |
colin.king |
jffs2: fix spelling mistake: "requestied" -> "requested"
trivial fix …
5
@63c5c53e
02/02/17 18:15:33 |
mingo |
sched/headers: Prepare to move signal wakeup & sigpending methods from …
5
@976af92
09/29/16 15:48:31 |
agruenba |
jffs2: Remove jffs2_{get,set,remove}xattr macros
When …
5
@0ec9bbc
06/10/16 14:51:30 |
torvalds |
vfs: make the string hashes salt the hash
We always mixed in the …
5
@fb5bc64d
04/01/16 12:29:47 |
kirill.shutemov |
mm, fs: get rid of PAGE_CACHE_* and page_cache_{get,release} macros
5
@0f5030d
02/01/16 12:00:25 |
David.Woodhouse |
jffs2: Improve post-mount CRC scan efficiency
We need to finish doing …
5
@e4fa3ad
02/01/16 14:04:46 |
David.Woodhouse |
Fix directory hardlinks from deleted directories
When a directory is …
5
@1e6d56e
02/01/16 12:37:20 |
David.Woodhouse |
jffs2: Fix page lock / f->sem deadlock
With this fix, all code paths …
5
@c9670dd1
01/22/16 23:11:02 |
penguin-kernel |
tree wide: use kvfree() than conditional kfree()/vfree()
There are …
5
@410dd26
09/29/15 03:23:55 |
fangwei1 |
jffs2: fix a memleak in read_direntry()
Need to free the memory …
5
@4dc16ea
02/26/14 02:27:40 |
computersforpeace |
jffs2: fix unbalanced locking
Li Zefan reported an unbalanced locking …
5
@8e55f0d
02/10/15 20:49:48 |
chenjie6 |
jffs2: fix handling of corrupted summary length
sm->offset maybe …
5
@8bcd5a22
01/11/15 16:36:48 |
rickard_strandqvist |
jffs2: compr_rubin: Remove unused function
Remove the function …
5
@2c5980f
11/27/14 11:05:46 |
geert+renesas |
jffs2: Drop bogus if in comment
Signed-off-by: Geert Uytterhoeven …
5
@e315b460
08/01/14 19:13:40 |
viro |
kill wbuf_queued/wbuf_dwork_lock
schedule_delayed_work() happening …
5
@9da567b2
08/08/14 21:23:14 |
yinghai |
initramfs: support initramfs that is bigger than 2GiB
Now with 64bit …
5
@a60ac5ca
01/06/14 13:36:55 |
ajesh |
jffs2: Fix crash due to truncation of csize
mounting JFFS2 partition …
5
@03cba49d
01/06/14 13:36:54 |
kamlakant.patel |
jffs2: Fix segmentation fault found in stress test
Creating a large …
5
@d60c1665
02/12/14 20:44:56 |
lizefan |
jffs2: avoid soft-lockup in jffs2_reserve_space_gc()
We triggered …
5
@52c50c78
02/12/14 20:44:57 |
lizefan |
jffs2: remove from wait queue after schedule()
@wait is a local …
5
@e650f4fc
12/20/13 13:16:47 |
hch |
jffs2: use generic posix ACL infrastructure
Also don't bother to set …
5
@1465e70c
01/23/14 23:56:11 |
cody |
fs/jffs2: use rbtree postorder iteration helper instead of opencoding
5
@22d9575
07/04/18 14:12:14 |
Sebastian Huber |
linux: Add rbtree_postorder_for_each_entry_safe()
Update #3465.
5
@0cb4257
07/03/18 18:32:31 |
Sebastian Huber |
linux: Simplify <linux/rbtree.h>
Remove the placeholder struct …
5
@877aeab
07/04/18 14:14:35 |
Sebastian Huber |
linux: Install <linux/rbtree.h>
This makes it possible to test this …
5
@6539bea
06/29/18 18:00:28 |
Sebastian Huber |
score: Add postorder tree iteration support
Update #3465.
5
