# # ChangeLog for cpukit in rtems # # Generated by Trac 1.2.1.dev0 # 05/12/24 11:32:37 Tue, 13 Oct 2020 12:35:18 GMT Sebastian Huber [f1d932d5] * cpukit/doxygen.h (modified) * cpukit/doxygen/top-level-groups.h (modified) * cpukit/include/rtems/confdefs.h (modified) * cpukit/include/rtems/extensionimpl.h (modified) * cpukit/include/rtems/libcsupport.h (modified) * cpukit/include/rtems/posix/posixapi.h (modified) * cpukit/include/rtems/rtems/asrimpl.h (modified) * cpukit/include/rtems/rtems/attrimpl.h (modified) * cpukit/include/rtems/rtems/barrierimpl.h (modified) * cpukit/include/rtems/rtems/dpmemimpl.h (modified) * cpukit/include/rtems/rtems/eventimpl.h (modified) * cpukit/include/rtems/rtems/messageimpl.h (modified) * cpukit/include/rtems/rtems/modesimpl.h (modified) * cpukit/include/rtems/rtems/objectimpl.h (modified) * cpukit/include/rtems/rtems/optionsimpl.h (modified) * cpukit/include/rtems/rtems/partimpl.h (modified) * cpukit/include/rtems/rtems/ratemonimpl.h (modified) * cpukit/include/rtems/rtems/regionimpl.h (modified) * cpukit/include/rtems/rtems/semimpl.h (modified) * cpukit/include/rtems/rtems/signalimpl.h (modified) * cpukit/include/rtems/rtems/statusimpl.h (modified) * cpukit/include/rtems/rtems/tasksimpl.h (modified) * cpukit/include/rtems/rtems/timerimpl.h (modified) * cpukit/include/rtems/score/object.h (modified) doxygen: Rename Internal to Implementation Use a top-level ... Tue, 17 Nov 2020 08:38:50 GMT Christian Mauderer [b169095c] * bsps/arm/stm32h7/include/stm32h7/mpu-config.h (added) * bsps/arm/stm32h7/start/bspstarthooks.c (modified) * bsps/arm/stm32h7/start/mpu-config.c (added) * cpukit/score/cpu/arm/include/rtems/score/armv7m.h (modified) * spec/build/bsps/arm/stm32h7/bspstm32h7.yml (modified) cpu/armv7m: Add table based init for ARMV7M_MPU Modify the MPU ... Fri, 20 Nov 2020 07:10:06 GMT Sebastian Huber [c13fd2d] * cpukit/include/rtems/score/basedefs.h (modified) score: Restore RTEMS_COMPILER_UNUSED_ATTRIBUTE Commit ... Thu, 19 Nov 2020 07:40:25 GMT Sebastian Huber [298b5ef1] * cpukit/include/rtems/confdefs/wkspace.h (modified) * cpukit/score/src/stackallocatorinit.c (modified) config: Initialize task stack allocator on demand Register a custom ... Thu, 19 Nov 2020 07:40:13 GMT Sebastian Huber [c5af8aa0] * cpukit/include/rtems/confdefs/wkspace.h (modified) * cpukit/include/rtems/score/interr.h (modified) * cpukit/score/src/stackallocatorinit.c (modified) * spec/build/testsuites/sptests/grp.yml (modified) * spec/build/testsuites/sptests/spfatal06.yml (deleted) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spfatal06/init.c (deleted) * testsuites/sptests/spfatal06/spfatal06.doc (deleted) * testsuites/sptests/spfatal06/spfatal06.scn (deleted) * testsuites/sptests/spinternalerror01/init.c (modified) * testsuites/sptests/sptimecounter01/init.c (modified) config: Simplify task stack allocator init Replace runtime checks ... Thu, 12 Nov 2020 10:05:19 GMT Sebastian Huber [c542345] * cpukit/libtest/t-test-rtems-measure.c (modified) libtest: Simplify "Load" environment reporting Report all runtime ... Wed, 11 Nov 2020 16:09:58 GMT Sebastian Huber [78baeb7] * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test.c (modified) libtest: Allow assert checks during test begin Allow assert checks ... Wed, 11 Nov 2020 10:27:50 GMT Sebastian Huber [d2bc5945] * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test-rtems-measure.c (modified) libtest: Rename ValidCache in FullCache This name better reflects ... Tue, 10 Nov 2020 11:02:34 GMT Sebastian Huber [8882635] * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test-rtems-memory.c (added) * spec/build/cpukit/librtemstest.yml (modified) libtest: Add primitive test case memory allocator This primitive ... Tue, 10 Nov 2020 09:40:51 GMT Sebastian Huber [33cd037b] * cpukit/libtest/t-test-rtems-measure.c (modified) libtest: Simplify runtime measurement support Use the test case ... Tue, 10 Nov 2020 09:23:10 GMT Sebastian Huber [eae22cc0] * cpukit/Makefile.am (modified) * cpukit/include/rtems/test.h (modified) * cpukit/libtest/t-test-malloc.c (deleted) * cpukit/libtest/t-test.c (modified) * cpukit/libtest/testrun.c (modified) * spec/build/cpukit/librtemstest.yml (modified) * testsuites/libtests/ttest01/init.c (modified) libtest: Make test case allocator configurable Thu, 22 Oct 2020 17:58:44 GMT Kinsey Moore [eb3d7fb] * cpukit/score/cpu/aarch64/include/rtems/score/cpu.h (modified) score/aarch64: Size saved SP register for ABI This ensures that the ... Mon, 11 May 2020 12:49:08 GMT Sebastian Huber [21af871] * cpukit/include/rtems/score/basedefs.h (modified) rtems: Generate Change license to ... Wed, 24 Jun 2020 04:35:57 GMT Sebastian Huber [ecc6b2f] * cpukit/include/rtems/rtems/part.h (modified) rtems: Generate Change license to BSD-2-Clause ... Mon, 22 Jun 2020 08:27:29 GMT Sebastian Huber [007ee13] * cpukit/include/rtems/rtems/event.h (modified) rtems: Generate Change license to ... Fri, 05 Jun 2020 12:40:10 GMT Sebastian Huber [f75e240] * cpukit/include/rtems/rtems/attr.h (modified) rtems: Generate Change license to BSD-2-Clause ... Thu, 04 Jun 2020 18:41:12 GMT Sebastian Huber [9b4458e7] * cpukit/include/rtems/rtems/types.h (modified) rtems: Generate Change license to ... Thu, 04 Jun 2020 17:50:25 GMT Sebastian Huber [8de874b] * cpukit/include/rtems/rtems/options.h (modified) rtems: Generate Change license to ... Thu, 04 Jun 2020 14:54:15 GMT Sebastian Huber [e05b100] * cpukit/include/rtems/rtems/modes.h (modified) rtems: Generate Change license to ... Thu, 28 May 2020 11:48:28 GMT Sebastian Huber [c0327d8] * cpukit/include/rtems/rtems/status.h (modified) rtems: Generate Change license to ... Thu, 28 May 2020 11:48:17 GMT Sebastian Huber [da44df3] * cpukit/include/rtems/rtems/config.h (modified) rtems: Generate Change license to ... Thu, 28 May 2020 11:47:15 GMT Sebastian Huber [1af94608] * cpukit/include/rtems/config.h (modified) rtems: Generate Change license to BSD-2-Clause ... Thu, 04 Jun 2020 14:54:36 GMT Sebastian Huber [96559b3] * cpukit/include/rtems/rtems/region.h (modified) * cpukit/include/rtems/rtems/support.h (modified) rtems: Include missing header file Wed, 11 Nov 2020 07:15:02 GMT Sebastian Huber [ced13022] * cpukit/doxygen/appl-config.h (modified) * cpukit/include/rtems.h (modified) * cpukit/include/rtems/io.h (modified) * testsuites/validation/tc-message-construct-errors.c (modified) * testsuites/validation/tc-task-construct-errors.c (modified) * testsuites/validation/ts-validation-0.c (modified) Improve automatically generated warning Mon, 09 Nov 2020 07:09:27 GMT Sebastian Huber [7f0379c] * cpukit/Makefile.am (modified) * cpukit/libtrace/record/record-server.c (modified) * cpukit/libtrace/record/record-stream-header.c (added) * spec/build/cpukit/librtemscpu.yml (modified) libtrace: Move _Record_Stream_header_initialize() This fixes the ... Thu, 05 Nov 2020 08:56:16 GMT Sebastian Huber [350bba7a] * bsps/sparc/erc32/include/erc32.h (modified) * bsps/sparc/leon2/include/leon.h (modified) * bsps/sparc/leon3/include/leon.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/sparc.h (modified) sparc: Add SPARC_INTERRUPT_SOURCE_TO_TRAP() Update #4171. Thu, 05 Nov 2020 08:50:36 GMT Sebastian Huber [82811477] * bsps/sparc/erc32/include/erc32.h (modified) * bsps/sparc/erc32/start/setvec.c (modified) * bsps/sparc/leon2/include/leon.h (modified) * bsps/sparc/leon2/start/setvec.c (modified) * bsps/sparc/leon3/include/leon.h (modified) * bsps/sparc/leon3/start/setvec.c (modified) * cpukit/score/cpu/sparc/include/rtems/score/sparc.h (modified) sparc: Add SPARC_INTERRUPT_TRAP_TO_SOURCE() Update #4171. Thu, 05 Nov 2020 08:32:09 GMT Sebastian Huber [b7271f8] * bsps/sparc/erc32/include/erc32.h (modified) * bsps/sparc/erc32/start/setvec.c (modified) * bsps/sparc/leon2/include/leon.h (modified) * bsps/sparc/leon2/start/setvec.c (modified) * bsps/sparc/leon3/include/leon.h (modified) * bsps/sparc/leon3/start/setvec.c (modified) * cpukit/score/cpu/sparc/include/rtems/score/sparc.h (modified) sparc: Add SPARC_IS_INTERRUPT_TRAP() Update #4171. Thu, 05 Nov 2020 08:23:52 GMT Sebastian Huber [2c467ec] * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/sparc.h (modified) sparc: Move SPARC-specific macros to sparc.h Clarify Doxygen ... Thu, 29 Oct 2020 13:11:32 GMT Jan Sommer [da9cc0b] * cpukit/include/rtems/confdefs/libpci.h (modified) confdefs: Add extern C guards to libpci.h Wed, 28 Oct 2020 12:25:45 GMT Sebastian Huber [6823943] * cpukit/include/rtems/score/smplock.h (modified) score: Fix unused parameter 'lock' warning Mon, 19 Oct 2020 12:54:39 GMT Frank Kühndel [daeb0a1] * cpukit/libmisc/rtems-fdt/rtems-fdt.c (modified) rtems-fdt / shell - Fix string truncation warning The compiler ... Mon, 19 Oct 2020 14:31:51 GMT Sebastian Huber [2b9fb314] * cpukit/posix/src/pspinunlock.c (modified) posix: Fix pthread_spin_unlock() Prevent a call to ... Thu, 15 Oct 2020 06:14:22 GMT Chris Johns [f514092] * cpukit/libfs/src/rfs/rtems-rfs-bitmaps.c (modified) libfs/rfs: Check search bit map end on last bit - Do not write past ... Fri, 02 Oct 2020 09:36:20 GMT Sebastian Huber [e7b878e] * bsps/arm/include/bsp/arm-a9mpcore-start.h (modified) * cpukit/score/cpu/arm/include/libcpu/arm-cp15.h (modified) bsps/arm: Workaround for Errata 845369 Add a workaround for ... Fri, 16 Oct 2020 04:22:45 GMT Sebastian Huber [e2250eeb] * cpukit/libmisc/rtems-fdt/rtems-fdt.c (modified) Revert "rtems-fdt / shell - Fix string truncation warning" This ... Thu, 15 Oct 2020 09:33:13 GMT Frank Kühndel [355bc37a] * cpukit/libmisc/rtems-fdt/rtems-fdt.c (modified) rtems-fdt / shell - Fix string truncation warning The compiler ... Mon, 12 Oct 2020 16:50:24 GMT Frank Kühndel [1dbd1079] * cpukit/libmisc/shell/main_edit.c (modified) shell/main_edit.c: Fix string truncation warning Using strlcpy() ... Mon, 12 Oct 2020 16:06:30 GMT Frank Kühndel [b03c103] * cpukit/libmisc/shell/main_edit.c (modified) shell/main_edit.c: Fix use of wrong constant realpath() requires a ... Mon, 12 Oct 2020 16:01:45 GMT Frank Kühndel [529402f5] * cpukit/libmisc/shell/shell.c (modified) shell/shell.c: Fix illegal string copy This is an illegal use of ... Mon, 12 Oct 2020 15:11:18 GMT Frank Kühndel [2361b2c] * cpukit/libmisc/shell/shell.c (modified) shell/shell.c: Fix an implicit type cast With some compiler ... Tue, 13 Oct 2020 11:47:06 GMT Sebastian Huber [3972085] * cpukit/include/rtems/chain.h (modified) * cpukit/include/rtems/rtems/asrimpl.h (modified) * cpukit/include/rtems/score/chainimpl.h (modified) * cpukit/include/rtems/score/objectmp.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/rtems/src/partmp.c (modified) * cpukit/rtems/src/semmp.c (modified) * cpukit/rtems/src/signalcatch.c (modified) * cpukit/rtems/src/signalsend.c (modified) * cpukit/rtems/src/taskconstruct.c (modified) * cpukit/score/src/objectmp.c (modified) Remove *_Is_null() inline functions Simply compare the values ... Wed, 14 Oct 2020 07:16:20 GMT Sebastian Huber [df9cc1ae] * cpukit/rtems/src/partcreate.c (modified) rtems: Remove superfluous include Fri, 09 Oct 2020 13:40:13 GMT Frank Kühndel [a479686] * cpukit/Makefile.am (modified) * cpukit/include/rtems/bdpart.h (modified) * cpukit/libblock/src/bdpart-mount.c (deleted) * cpukit/libmisc/shell/fdisk.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) shell: Remove not functioning fdisk mount/unmount The shell has an ... Mon, 05 Oct 2020 14:49:14 GMT Frank Kühndel [f3df25b6] * cpukit/libmisc/monitor/mon-editor.c (modified) cpukit/libmisc/monitor: Fix an illegal string copy This is actually ... Mon, 12 Oct 2020 06:09:13 GMT Sebastian Huber [b434dc1] * cpukit/libblock/src/sparse-disk.c (modified) libblock: Fix sparse disk The qsort() in ... Thu, 28 May 2020 13:52:11 GMT Sebastian Huber [8111a6ba] * cpukit/include/rtems/io.h (modified) rtems: Generate The manager documentation is a ... Sun, 11 Oct 2020 13:50:28 GMT Sebastian Huber [243d3ed5] * cpukit/libblock/src/bdpart-register.c (modified) libblock: Add comment Tue, 06 Oct 2020 13:01:31 GMT Frank Kühndel [c8c1426c] * cpukit/mghttpd/mongoose.c (modified) mghttpd/mongoose: Fix string truncation warning This fixes the ... Mon, 05 Oct 2020 14:37:23 GMT Frank Kühndel [bc7ac71] * cpukit/libblock/src/bdpart-register.c (modified) libblock: Fix string truncation warning This patch does not only ... Mon, 05 Oct 2020 14:20:44 GMT Frank Kühndel [59d0e6a] * cpukit/libmisc/capture/capture_support.c (modified) capture: Fix unaligned pointer value warning rtems_name is a four ... Tue, 06 Oct 2020 05:39:44 GMT Sebastian Huber [d7a48e1] * bsps/include/bsp/bootcard.h (modified) * bsps/powerpc/qoriq/include/bsp.h (modified) * bsps/sparc/leon3/include/leon.h (modified) * cpukit/include/rtems/fatal.h (modified) * cpukit/include/rtems/init.h (modified) * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/include/rtems/score/assert.h (modified) * cpukit/include/rtems/score/basedefs.h (modified) * cpukit/include/rtems/score/interr.h (modified) * cpukit/include/rtems/score/smpimpl.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/include/rtems/test-info.h (modified) * cpukit/score/cpu/aarch64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/arm/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/bfin/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/i386/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/lm32/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/m68k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/mips/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/moxie/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/nios2/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/powerpc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/riscv/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sh/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/sparc/include/rtems/score/sparc.h (modified) * cpukit/score/cpu/sparc64/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/v850/include/rtems/score/cpu.h (modified) * cpukit/score/cpu/x86_64/include/rtems/score/cpu.h (modified) rtems: Improve RTEMS_NO_RETURN attribute Provide RTEMS_NO_RETURN ... Thu, 08 Oct 2020 23:44:36 GMT Chris Johns [89a22be] * cpukit/include/rtems/error.hpp (modified) * cpukit/include/rtems/thread.hpp (modified) * cpukit/librtemscxx/error.cpp (modified) * cpukit/librtemscxx/thread.cpp (modified) librtemscxx: Fix white space to match the coding standard Thu, 08 Oct 2020 08:12:20 GMT Chris Johns [6f2a219f] * cpukit/include/rtems/thread.hpp (modified) * cpukit/librtemscxx/error.cpp (modified) * cpukit/librtemscxx/thread.cpp (modified) librtemscxx: Add join() and detach() to the thread - Do not start ... Wed, 07 Oct 2020 10:13:42 GMT Sebastian Huber [e697baf] * cpukit/doxygen/appl-config.h (modified) doxygen: Add "Generated from ..." comments Improve file header ... Wed, 07 Oct 2020 10:12:17 GMT Sebastian Huber [f815d04] * cpukit/include/rtems.h (modified) rtems: Add "Generated from ..." comments Improve file header ... Sat, 03 Oct 2020 06:13:24 GMT Chris Johns [cf95826] * cpukit/include/rtems/error.hpp (added) * cpukit/include/rtems/thread.hpp (added) * cpukit/librtemscxx/error.cpp (added) * cpukit/librtemscxx/thread.cpp (added) * spec/build/cpukit/grp.yml (modified) * spec/build/cpukit/librtemscxx.yml (added) * spec/build/testsuites/libtests/grp.yml (modified) * spec/build/testsuites/libtests/rcxx01.yml (added) * testsuites/libtests/rcxx01/init.c (added) * testsuites/libtests/rcxx01/rcxx01.doc (added) * testsuites/libtests/rcxx01/rcxx01.scn (added) * testsuites/libtests/rcxx01/thread.cpp (added) cpukit/librcxx: Add a C++ thread interface with attributes Wed, 30 Sep 2020 12:21:32 GMT Sebastian Huber [97e9728] * cpukit/include/rtems/rtems/part.h (modified) * testsuites/psxtests/psxconfig01/init.c (modified) * testsuites/sptests/sppartition_err01/init.c (modified) rtems: Add RTEMS_PARTITION_ALIGNMENT Update #4105. Tue, 22 Sep 2020 13:31:34 GMT Kinsey Moore [8387c52] * cpukit/include/rtems/score/tls.h (modified) * cpukit/score/cpu/aarch64/aarch64-context-validate.S (added) * cpukit/score/cpu/aarch64/aarch64-context-volatile-clobber.S (added) * cpukit/score/cpu/aarch64/aarch64-exception-default.S (added) * cpukit/score/cpu/aarch64/aarch64-exception-default.c (added) * cpukit/score/cpu/aarch64/aarch64-exception-frame-print.c (added) * cpukit/score/cpu/aarch64/aarch64-exception-interrupt.S (added) * cpukit/score/cpu/aarch64/aarch64-thread-idle.c (added) * cpukit/score/cpu/aarch64/cpu.c (added) * cpukit/score/cpu/aarch64/cpu_asm.S (added) * cpukit/score/cpu/aarch64/include/libcpu/vectors.h (added) * cpukit/score/cpu/aarch64/include/rtems/asm.h (added) * cpukit/score/cpu/aarch64/include/rtems/score/aarch64.h (added) * cpukit/score/cpu/aarch64/include/rtems/score/cpu.h (added) * cpukit/score/cpu/aarch64/include/rtems/score/cpu_irq.h (added) * cpukit/score/cpu/aarch64/include/rtems/score/cpuatomic.h (added) * cpukit/score/cpu/aarch64/include/rtems/score/cpuimpl.h (added) * spec/build/cpukit/cpuaarch64.yml (added) * spec/build/cpukit/librtemscpu.yml (modified) score: Add AArch64 port This adds a CPU port for AArch64(ARMv8) ... Mon, 05 Oct 2020 09:58:11 GMT Sebastian Huber [2c367617] * cpukit/acinclude.m4 (modified) * cpukit/configure.ac (modified) build: Add testopts.h to configure script Close #4120. Wed, 30 Sep 2020 09:31:58 GMT Sebastian Huber [f2185d10] * cpukit/Makefile.am (modified) * cpukit/include/rtems/confdefs/wkspace.h (modified) * cpukit/include/rtems/malloc.h (modified) * cpukit/include/rtems/score/wkspacedata.h (modified) * cpukit/libcsupport/src/malloc_initialize.c (modified) * cpukit/libcsupport/src/mallocheap.c (added) * cpukit/score/src/wkspacemallocinitdefault.c (added) * cpukit/score/src/wkspacemallocinitunified.c (added) * spec/build/cpukit/librtemscpu.yml (modified) Decouple the C Program Heap initialization Before this patch ... Wed, 30 Sep 2020 14:22:04 GMT Sebastian Huber [71689a07] * cpukit/rtems/src/msgqconstruct.c (modified) * cpukit/rtems/src/partcreate.c (modified) * cpukit/rtems/src/regioncreate.c (modified) * cpukit/rtems/src/taskconstruct.c (modified) * testsuites/validation/tc-message-construct-errors.c (modified) * testsuites/validation/tc-task-construct-errors.c (modified) rtems: Canonicalize name and id checks Check the name followed by ... Sat, 26 Sep 2020 13:18:45 GMT Sebastian Huber [5ff5ce6] * cpukit/include/rtems/io.h (modified) rtems: Remove rtems_io_driver_io_error() The implementation was ... Thu, 24 Sep 2020 13:31:41 GMT Frank Kühndel [ffc928b] * cpukit/libmisc/shell/shell.c (modified) Fixing bug in line editing of the shell with CTRL-U. This patch ... Mon, 28 Sep 2020 07:08:57 GMT Sebastian Huber [f48d7834] * cpukit/doxygen/appl-config.h (modified) doxygen: Fix use of getchark() and rtems_putc() Wed, 23 Sep 2020 14:47:58 GMT Sebastian Huber [4a4f41e] * cpukit/Makefile.am (modified) * cpukit/include/rtems/rtems/message.h (modified) * cpukit/include/rtems/rtems/messageimpl.h (modified) * cpukit/include/rtems/score/coremsg.h (modified) * cpukit/include/rtems/score/coremsgimpl.h (modified) * cpukit/posix/src/mqueueopen.c (modified) * cpukit/rtems/src/msgqconstruct.c (added) * cpukit/rtems/src/msgqcreate.c (modified) * cpukit/score/src/coremsg.c (modified) * cpukit/score/src/coremsgclose.c (modified) * cpukit/score/src/coremsgwkspace.c (added) * spec/build/cpukit/librtemscpu.yml (modified) * testsuites/mptests/mp09/initimpl.h (modified) * testsuites/mptests/mp09/system.h (modified) * testsuites/mptests/mp09/task1.c (modified) * testsuites/sptests/sp13/init.c (modified) * testsuites/sptests/sp13/system.h (modified) rtems: Add rtems_message_queue_construct() In contrast to message ... Thu, 24 Sep 2020 07:05:36 GMT Sebastian Huber [24ea1ce] * cpukit/include/rtems/rtems/messagedata.h (modified) * cpukit/libmisc/monitor/mon-queue.c (modified) * cpukit/rtems/src/msgqcreate.c (modified) * cpukit/rtems/src/msgqdelete.c (modified) rtems: Remove Message_queue_Control::attribute_set Add ... Wed, 23 Sep 2020 11:46:38 GMT Sebastian Huber [2c09f54f] * cpukit/headers.am (modified) * cpukit/include/rtems/score/coremsg.h (modified) * cpukit/include/rtems/score/coremsgbuffer.h (added) * spec/build/cpukit/librtemscpu.yml (modified) score: Add Move the ... Wed, 23 Sep 2020 08:33:51 GMT Sebastian Huber [69b4fe59] * cpukit/include/rtems/confdefs/wkspace.h (modified) * cpukit/include/rtems/rtems/msgmp.h (modified) * cpukit/include/rtems/score/coremsg.h (modified) * cpukit/include/rtems/score/coremsgimpl.h (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/score/src/coremsg.c (modified) * cpukit/score/src/coremsginsert.c (modified) * cpukit/score/src/coremsgseize.c (modified) * cpukit/score/src/coremsgsubmit.c (modified) * testsuites/sptests/spmsgq_err01/init.c (modified) score: Simplify CORE_message_queue_Buffer Merge ... Wed, 23 Sep 2020 08:09:37 GMT Sebastian Huber [5bc7c37] * cpukit/include/rtems/score/coremsgimpl.h (modified) * cpukit/include/rtems/score/status.h (modified) * cpukit/posix/src/mqueueopen.c (modified) * cpukit/rtems/src/msgqcreate.c (modified) * cpukit/score/src/coremsg.c (modified) * testsuites/sptests/sp77/init.c (modified) * testsuites/sptests/spmsgq_err01/init.c (modified) score: Improve _CORE_message_queue_Initialize() Return a status ... Mon, 21 Sep 2020 06:15:27 GMT Sebastian Huber [34dd90a5] * cpukit/score/src/coremsg.c (modified) score: Gather message queue control initialization Initialize the ... Mon, 21 Sep 2020 06:14:05 GMT Sebastian Huber [fe2cb7c4] * cpukit/score/src/coremsg.c (modified) score: Fix allocation size calculation The previous multiplication ... Mon, 21 Sep 2020 06:10:06 GMT Sebastian Huber [3c025576] * cpukit/score/src/coremsg.c (modified) score: Use RTEMS_ALIGN_UP() Update #4007. Thu, 24 Sep 2020 14:18:33 GMT Sebastian Huber [a72419b] * cpukit/libtest/t-test-busy-tick.c (modified) libtest: Remove superfluous assignment Issue found by Coverity (CID ... Wed, 23 Sep 2020 05:33:27 GMT Sebastian Huber [18fe650a] * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) or1k: Do not use printk() for _CPU_Fatal_halt() Debug output can be ... Wed, 23 Sep 2020 05:32:42 GMT Sebastian Huber [2248b37] * cpukit/score/cpu/or1k/include/rtems/score/cpu.h (modified) or1k: Remove superfluous includes Including in ... Wed, 23 Sep 2020 03:59:31 GMT Chris Johns [5ebba2c] * cpukit/Makefile.am (modified) libmisc/capture: Add rtems-trace-buffer-default.c to the autotools build Wed, 23 Sep 2020 03:46:48 GMT Chris Johns [de58eb2f] * cpukit/Makefile.am (modified) cpukit/rtems: Add taskconstruct.c to the autotools build Sun, 20 Sep 2020 13:09:48 GMT Sebastian Huber [9f2a207] * cpukit/include/rtems/trace/rtems-trace-buffer-vars.h (modified) * cpukit/libmisc/capture/rtems-trace-buffer-default.c (added) * cpukit/libmisc/capture/rtems-trace-buffer-vars.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) capture: Move default trace data Provide the default trace data in ... Wed, 05 Aug 2020 07:19:20 GMT Sebastian Huber [da27e96] * cpukit/include/rtems/score/schedulerimpl.h (modified) score: Document _Scheduler_Try_to_schedule_node() Wed, 24 Jun 2020 09:23:40 GMT Sebastian Huber [0b410b8a] * cpukit/include/rtems.h (modified) rtems: Generate Change license to BSD-2-Clause according ... Fri, 18 Sep 2020 07:07:46 GMT Sebastian Huber [7892ac0] * cpukit/include/rtems.h (modified) * cpukit/include/rtems/rtems/mp.h (modified) rtems: From to Move multiprocessing ... Wed, 24 Jun 2020 08:43:22 GMT Sebastian Huber [c161216d] * cpukit/include/rtems.h (modified) * cpukit/include/rtems/rtems/types.h (modified) rtems: From to Move type related ... Wed, 24 Jun 2020 08:40:42 GMT Sebastian Huber [d433b724] * cpukit/include/rtems.h (modified) * cpukit/include/rtems/rtems/tasks.h (modified) rtems: From to Move task related ... Wed, 24 Jun 2020 08:39:44 GMT Sebastian Huber [1615b5ff] * cpukit/include/rtems.h (modified) * cpukit/include/rtems/rtems/object.h (modified) rtems: From to Move object related ... Wed, 24 Jun 2020 08:36:16 GMT Sebastian Huber [5353ea89] * cpukit/include/rtems.h (modified) * cpukit/include/rtems/config.h (modified) * cpukit/sapi/src/getcopyrightnotice.c (modified) * cpukit/sapi/src/getversionstring.c (modified) rtems: Move from to Move configuration ... Fri, 03 Jul 2020 10:41:47 GMT Sebastian Huber [96ea30f0] * cpukit/include/rtems/score/scheduler.h (modified) * cpukit/include/rtems/score/schedulerimpl.h (modified) score: Improve Scheduler Handler documentation Fri, 18 Sep 2020 06:19:37 GMT Sebastian Huber [4e5327ff] * cpukit/doxygen/appl-config.h (modified) doxygen: Wrap long lines Thu, 17 Sep 2020 18:07:08 GMT Sebastian Huber [2f65e13] * cpukit/include/rtems/rtems/tasks.h (modified) rtems: Fix typo Update #3959. Fri, 11 Sep 2020 08:33:19 GMT Sebastian Huber [139ffa2] * Doxyfile (modified) * cpukit/doxygen/top-level-groups.h (modified) * spec/build/bsps/tstsmallmem.yml (modified) * spec/build/testsuites/grp.yml (modified) * spec/build/testsuites/optvalidation.yml (added) * spec/build/testsuites/validation/grp.yml (added) * spec/build/testsuites/validation/validation-0.yml (added) * testsuites/validation/ts-validation-0.c (added) validation: Add general purpose test suite Add a general purpose ... Fri, 11 Sep 2020 09:01:42 GMT Sebastian Huber [ad22c65] * cpukit/doxygen.h (modified) * cpukit/doxygen/top-level-groups.h (added) doxygen: Move top-level group definitions Update #3959. Thu, 09 Apr 2020 10:12:13 GMT Sebastian Huber [6942e5f] * cpukit/doxygen/appl-config.h (modified) * cpukit/include/rtems/confdefs/threads.h (modified) * cpukit/include/rtems/confdefs/wkspace.h (modified) * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/include/rtems/rtems/tasksimpl.h (modified) * cpukit/rtems/src/taskconstruct.c (added) * cpukit/rtems/src/taskcreate.c (modified) * spec/build/cpukit/librtemscpu.yml (modified) * testsuites/sptests/sp01/init.c (modified) * testsuites/sptests/sp01/sp01.doc (modified) * testsuites/sptests/sp01/system.h (modified) rtems: Add rtems_task_construct() In contrast to ... Thu, 10 Sep 2020 14:35:09 GMT Sebastian Huber [c312f31] * cpukit/doxygen/appl-config.h (modified) * cpukit/include/rtems/confdefs/threads.h (modified) * cpukit/include/rtems/rtems/tasks.h (modified) * cpukit/include/rtems/score/interr.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/sapi/src/interrtext.c (modified) * cpukit/score/src/tlsallocsize.c (modified) * spec/build/testsuites/sptests/grp.yml (modified) * spec/build/testsuites/sptests/spfatal33.yml (added) * testsuites/sptests/spfatal33/init.c (added) * testsuites/sptests/spfatal33/spfatal33.doc (added) * testsuites/sptests/spfatal33/spfatal33.scn (added) * testsuites/sptests/spinternalerror02/init.c (modified) CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE Add this application ... Wed, 16 Sep 2020 08:34:12 GMT Sebastian Huber [dce1cdf1] * cpukit/include/rtems/score/basedefs.h (modified) rtems: Add RTEMS_ALIGN_UP() Update #3959. Update #4074. Wed, 16 Sep 2020 08:33:52 GMT Sebastian Huber [641b31a4] * cpukit/include/rtems/score/basedefs.h (modified) rtems: Add RTEMS_ALIGN_DOWN() Update #3959. Update #4074. Thu, 17 Sep 2020 15:40:52 GMT Sebastian Huber [98d2adb] * cpukit/libtest/t-test-thread-switch.c (modified) libtest: Fix T_thread_switch_record() If RTEMS_DEBUG is not ... Fri, 04 Sep 2020 18:10:57 GMT Sebastian Huber [20d8237] * bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c (modified) * cpukit/score/cpu/arm/include/libcpu/arm-cp15.h (modified) arm: Fix arm_cp15_set_translation_table_entries() In a ... Sat, 12 Sep 2020 15:11:28 GMT Gedare Bloom [9f096f4] * cpukit/score/cpu/i386/include/rtems/asm.h (modified) i386/score: fix assembly mnemonic Closes #4076. Fri, 11 Sep 2020 13:43:23 GMT Sebastian Huber [dd734d46] * cpukit/score/src/threadinitialize.c (modified) score: Fix _Thread_Initialize() Fix an error cleanup path in SMP ... Thu, 09 Apr 2020 10:11:19 GMT Sebastian Huber [aedd92d] * cpukit/Makefile.am (modified) * cpukit/include/rtems/score/stackimpl.h (modified) * cpukit/include/rtems/score/thread.h (modified) * cpukit/include/rtems/score/threadimpl.h (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/rtems/src/taskcreate.c (modified) * cpukit/score/src/stackallocatorfreenothing.c (added) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadrestart.c (modified) score: Add stack free handler to TCB This avoids a dependency to ...
