# # ChangeLog for cpukit in rtems # # Generated by Trac 1.2.1.dev0 # 05/31/24 17:13:41 Fri, 20 May 2016 13:10:27 GMT Sebastian Huber [e266d13] * cpukit/posix/include/rtems/posix/muteximpl.h (modified) * cpukit/posix/src/cancel.c (modified) * cpukit/posix/src/mutexdestroy.c (modified) * cpukit/posix/src/mutexget.c (modified) * cpukit/posix/src/mutexgetprioceiling.c (modified) * cpukit/posix/src/mutexlocksupp.c (modified) * cpukit/posix/src/mutexsetprioceiling.c (modified) * cpukit/posix/src/mutexunlock.c (modified) * cpukit/posix/src/pthreaddetach.c (modified) * cpukit/posix/src/pthreadequal.c (modified) * cpukit/posix/src/pthreadgetaffinitynp.c (modified) * cpukit/posix/src/pthreadgetattrnp.c (modified) * cpukit/posix/src/pthreadgetschedparam.c (modified) * cpukit/posix/src/pthreadjoin.c (modified) * cpukit/posix/src/pthreadkill.c (modified) * cpukit/posix/src/pthreadsetaffinitynp.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) * cpukit/rtems/include/rtems/rtems/messageimpl.h (modified) * cpukit/rtems/include/rtems/rtems/semimpl.h (modified) * cpukit/rtems/src/eventsend.c (modified) * cpukit/rtems/src/msgqbroadcast.c (modified) * cpukit/rtems/src/msgqdelete.c (modified) * cpukit/rtems/src/msgqflush.c (modified) * cpukit/rtems/src/msgqgetnumberpending.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/rtems/src/msgqsend.c (modified) * cpukit/rtems/src/msgqurgent.c (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/rtems/src/semsetpriority.c (modified) * cpukit/rtems/src/signalsend.c (modified) * cpukit/rtems/src/systemeventsend.c (modified) * cpukit/rtems/src/taskdelete.c (modified) * cpukit/rtems/src/taskgetaffinity.c (modified) * cpukit/rtems/src/taskgetscheduler.c (modified) * cpukit/rtems/src/taskissuspended.c (modified) * cpukit/rtems/src/taskrestart.c (modified) * cpukit/rtems/src/taskresume.c (modified) * cpukit/rtems/src/tasksetaffinity.c (modified) * cpukit/rtems/src/tasksetpriority.c (modified) * cpukit/rtems/src/tasksetscheduler.c (modified) * cpukit/rtems/src/taskstart.c (modified) * cpukit/rtems/src/tasksuspend.c (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/schedulercbsattachthread.c (modified) * cpukit/score/src/schedulercbsdetachthread.c (modified) * cpukit/score/src/schedulercbsgetexecutiontime.c (modified) * cpukit/score/src/schedulercbsgetremainingbudget.c (modified) * cpukit/score/src/threadget.c (modified) * testsuites/smptests/smpmigration02/init.c (modified) * testsuites/smptests/smpscheduler03/init.c (modified) * testsuites/sptests/spintrcritical22/init.c (modified) * testsuites/sptests/spintrcritical23/init.c (modified) * testsuites/tmtests/tm26/task1.c (modified) Replace *_Get_interrupt_disable() with *_Get() Uniformly use ... Fri, 20 May 2016 13:04:16 GMT Sebastian Huber [582bb23c] * cpukit/posix/include/rtems/posix/barrierimpl.h (modified) * cpukit/posix/include/rtems/posix/mqueueimpl.h (modified) * cpukit/posix/include/rtems/posix/posixapi.h (modified) * cpukit/posix/include/rtems/posix/semaphoreimpl.h (modified) * cpukit/posix/include/rtems/posix/spinlockimpl.h (modified) * cpukit/posix/include/rtems/posix/timerimpl.h (modified) * cpukit/rtems/include/rtems/rtems/barrierimpl.h (modified) * cpukit/rtems/include/rtems/rtems/dpmemimpl.h (modified) * cpukit/rtems/include/rtems/rtems/messageimpl.h (modified) * cpukit/rtems/include/rtems/rtems/partimpl.h (modified) * cpukit/rtems/include/rtems/rtems/ratemonimpl.h (modified) * cpukit/rtems/include/rtems/rtems/semimpl.h (modified) * cpukit/rtems/include/rtems/rtems/timerimpl.h (modified) * cpukit/score/include/rtems/score/objectimpl.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/objectgetlocal.c (modified) * cpukit/score/src/objectgetnameasstring.c (modified) * cpukit/score/src/objectidtoname.c (modified) * cpukit/score/src/threadget.c (modified) score: Rename _Objects_Get_local() Rename _Objects_Get_local() into ... Fri, 20 May 2016 13:01:46 GMT Sebastian Huber [4bae341d] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/objectimpl.h (modified) * cpukit/score/src/objectgetisr.c (deleted) score: Delete unused _Objects_Get_isr_disable() Delete now unused ... Fri, 20 May 2016 12:59:30 GMT Sebastian Huber [62c528e6] * cpukit/rtems/include/rtems/rtems/semimpl.h (modified) * cpukit/rtems/include/rtems/rtems/semmp.h (modified) * cpukit/rtems/src/semdelete.c (modified) * cpukit/rtems/src/semflush.c (modified) * cpukit/rtems/src/semmp.c (modified) * cpukit/rtems/src/semobtain.c (modified) * cpukit/rtems/src/semrelease.c (modified) * cpukit/rtems/src/semsetpriority.c (modified) * testsuites/sptests/spintrcritical22/init.c (modified) * testsuites/tmtests/tm26/task1.c (modified) rtems: _Semaphore_Get_interrupt_disable() Use _Objects_Get_local() ... Fri, 20 May 2016 12:21:12 GMT Sebastian Huber [641b44c2] * cpukit/rtems/include/rtems/rtems/messageimpl.h (modified) * cpukit/rtems/include/rtems/rtems/msgmp.h (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/rtems/src/msgqbroadcast.c (modified) * cpukit/rtems/src/msgqdelete.c (modified) * cpukit/rtems/src/msgqflush.c (modified) * cpukit/rtems/src/msgqgetnumberpending.c (modified) * cpukit/rtems/src/msgqreceive.c (modified) * cpukit/rtems/src/msgqsend.c (modified) * cpukit/rtems/src/msgqurgent.c (modified) rtems: _Message_queue_Get_interrupt_disable() Use ... Fri, 20 May 2016 11:24:11 GMT Sebastian Huber [0a00b2b] * cpukit/rtems/include/rtems/rtems/partimpl.h (modified) * cpukit/rtems/include/rtems/rtems/partmp.h (modified) * cpukit/rtems/src/partdelete.c (modified) * cpukit/rtems/src/partgetbuffer.c (modified) * cpukit/rtems/src/partmp.c (modified) * cpukit/rtems/src/partreturnbuffer.c (modified) rtems: Remove location from _Partition_Get() Use ... Fri, 20 May 2016 12:23:56 GMT Sebastian Huber [516ee75] * cpukit/rtems/src/region.c (modified) mpci: Delete unused region support Fri, 20 May 2016 09:53:41 GMT Sebastian Huber [956b8e5] * cpukit/score/include/rtems/score/objectmp.h (modified) * cpukit/score/include/rtems/score/threadmp.h (modified) * cpukit/score/src/objectgetisr.c (modified) * cpukit/score/src/objectmp.c (modified) mpci: Simplify _Objects_MP_Is_remote() Fri, 20 May 2016 09:42:30 GMT Sebastian Huber [0cc6071] * cpukit/posix/include/rtems/posix/keyimpl.h (modified) posix: Add const to _POSIX_Keys_Key_value_find() Fri, 20 May 2016 09:38:23 GMT Sebastian Huber [61340d1] * cpukit/score/include/rtems/score/rbtree.h (modified) score: Add const to _RBTree_Find_inline() Fri, 20 May 2016 09:04:04 GMT Sebastian Huber [0cc91daa] * cpukit/score/include/rtems/score/objectimpl.h (modified) score: Delete unused _Objects_Get_local_object() Fri, 20 May 2016 07:38:56 GMT Sebastian Huber [28ba7e2] * cpukit/posix/src/mutexinit.c (modified) posix: Remove dead code and shrink comment Fri, 20 May 2016 05:01:03 GMT Sebastian Huber [05f9b02e] * cpukit/posix/include/rtems/posix/posixapi.h (modified) * cpukit/posix/src/condget.c (modified) * cpukit/posix/src/mutexget.c (modified) * cpukit/posix/src/prwlockinit.c (modified) posix: Add and use _POSIX_Get_object_body() Thu, 19 May 2016 15:03:31 GMT Sebastian Huber [8a040fe4] * cpukit/score/include/rtems/score/threadqimpl.h (modified) * cpukit/score/src/threadq.c (modified) * cpukit/score/src/threadqops.c (modified) score: Use _RBTree_Insert_inline() Use _RBTree_Insert_inline() for ... Thu, 19 May 2016 09:20:58 GMT Sebastian Huber [7dfb4b9] * cpukit/posix/include/rtems/posix/priorityimpl.h (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/scheduler.h (modified) * cpukit/score/include/rtems/score/priority.h (modified) * cpukit/score/include/rtems/score/scheduler.h (modified) * cpukit/score/include/rtems/score/schedulercbs.h (modified) * cpukit/score/include/rtems/score/scheduleredf.h (modified) * cpukit/score/include/rtems/score/schedulersimple.h (modified) * cpukit/score/include/rtems/score/schedulersimplesmp.h (modified) score: Add per scheduler instance maximum priority The priority ... Wed, 18 May 2016 07:17:09 GMT Sebastian Huber [452b7f8] * cpukit/libfs/src/dosfs/fat.c (modified) fat: Fix for invalid cluster sizes A cluster size > 32KiB resulted ... Tue, 17 May 2016 14:03:46 GMT Sebastian Huber [ceb0f659] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/include/rtems/score/threaddispatch.h (modified) * cpukit/score/src/smp.c (modified) * cpukit/score/src/threaddisabledispatch.c (deleted) * cpukit/score/src/threaddispatchdisablelevel.c (deleted) * cpukit/score/src/threadenabledispatch.c (deleted) * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpfatal03/Makefile.am (deleted) * testsuites/smptests/smpfatal03/init.c (deleted) * testsuites/smptests/smpfatal03/smpfatal03.doc (deleted) * testsuites/smptests/smpfatal03/smpfatal03.scn (deleted) score: Remove the Giant lock Update #2555. Wed, 18 May 2016 06:08:38 GMT Sebastian Huber [c2f301b5] * cpukit/rtems/include/rtems/rtems/intr.h (modified) * cpukit/rtems/src/intrbody.c (modified) * cpukit/score/include/rtems/score/isrlevel.h (modified) * cpukit/score/include/rtems/score/isrlock.h (modified) * testsuites/tmtests/tm26/task1.c (modified) score: Rename _ISR_Flash() into _ISR_Local_flash() This is a ... Wed, 18 May 2016 06:06:54 GMT Sebastian Huber [24713163] * c/src/lib/libbsp/m68k/gen68360/startup/alloc360.c (modified) * c/src/lib/libbsp/m68k/mvme167/network/network.c (modified) * c/src/lib/libcpu/or1k/shared/cache/cache.c (modified) * c/src/lib/libcpu/powerpc/mpc8260/cpm/dpram.c (modified) * c/src/lib/libcpu/powerpc/mpc8xx/cpm/dpram.c (modified) * c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7045/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7750/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c (modified) * c/src/libchip/ide/ata.c (modified) * cpukit/rtems/include/rtems/rtems/intr.h (modified) * cpukit/rtems/src/intrbody.c (modified) * cpukit/score/cpu/arm/armv7m-isr-vector-install.c (modified) * cpukit/score/cpu/nios2/nios2-mpu-disable-protected.c (modified) * cpukit/score/cpu/or1k/cpu.c (modified) * cpukit/score/include/rtems/score/assert.h (modified) * cpukit/score/include/rtems/score/cpustdatomic.h (modified) * cpukit/score/include/rtems/score/isrlevel.h (modified) * cpukit/score/include/rtems/score/isrlock.h (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/include/rtems/score/threaddispatch.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threaddispatchdisablelevel.c (modified) * testsuites/tmtests/tm26/task1.c (modified) score: Rename _ISR_Disable() and _ISR_Enable() Rename ... Wed, 18 May 2016 06:03:05 GMT Sebastian Huber [4b04cb61] * c/src/lib/libcpu/powerpc/shared/include/powerpc-utility.h (modified) * cpukit/rtems/include/rtems/rtems/intr.h (modified) * cpukit/score/cpu/sparc/sparcv8-atomic.c (modified) * cpukit/score/include/rtems/score/isrlevel.h (modified) * cpukit/score/include/rtems/score/isrlock.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/include/rtems/score/smplock.h (modified) * cpukit/score/include/rtems/score/threaddispatch.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/debugisthreaddispatchingallowed.c (modified) * cpukit/score/src/interr.c (modified) * cpukit/score/src/isrisinprogress.c (modified) * cpukit/score/src/smplock.c (modified) * cpukit/score/src/smpmulticastaction.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threaddispatchdisablelevel.c (modified) * cpukit/score/src/threadhandler.c (modified) * testsuites/smptests/smpcache01/init.c (modified) * testsuites/smptests/smpload01/init.c (modified) * testsuites/smptests/smpthreadlife01/init.c (modified) * testsuites/tmtests/tm26/task1.c (modified) * testsuites/tmtests/tm27/task1.c (modified) score: Rename _ISR_Disable_without_giant() Rename ... Tue, 17 May 2016 13:57:48 GMT Sebastian Huber [d2bacb6c] * c/src/lib/libcpu/sh/sh7032/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7045/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/sh7750/score/cpu_asm.c (modified) * c/src/lib/libcpu/sh/shgdb/score/cpu_asm.c (modified) * cpukit/score/cpu/lm32/irq.c (modified) * cpukit/score/cpu/nios2/nios2-iic-irq.c (modified) * cpukit/score/include/rtems/score/threaddispatch.h (modified) score: _Thread_Dispatch_increment_disable_level() Avoid ... Tue, 17 May 2016 13:15:17 GMT Sebastian Huber [b80156c] * cpukit/score/src/objectextendinformation.c (modified) score: Avoid Giant _Objects_Extend_information() Avoid Giant lock ... Tue, 17 May 2016 13:11:16 GMT Sebastian Huber [ee710ef] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/object.h (modified) * cpukit/score/include/rtems/score/objectimpl.h (modified) * cpukit/score/src/objectget.c (deleted) score: Delete unused _Objects_Get() Update #2555. Tue, 17 May 2016 14:07:11 GMT Sebastian Huber [23294fd2] * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadget.c (modified) score: Delete unused _Thread_Get() Update #2555. Tue, 17 May 2016 12:38:57 GMT Sebastian Huber [f36ada32] * cpukit/rtems/src/taskdelete.c (modified) * cpukit/rtems/src/tasks.c (modified) rtems: Avoid Giant lock for rtems_task_delete() Update #2555. Tue, 17 May 2016 11:56:02 GMT Sebastian Huber [64fe1663] * cpukit/posix/src/pthreadkill.c (modified) posix: Avoid Giant lock for pthread_kill() Update #2555. Fri, 13 May 2016 08:28:14 GMT Sebastian Huber [da826560] * cpukit/posix/Makefile.am (modified) * cpukit/posix/include/rtems/posix/cancel.h (deleted) * cpukit/posix/include/rtems/posix/threadsup.h (modified) * cpukit/posix/preinstall.am (modified) * cpukit/posix/src/cancel.c (modified) * cpukit/posix/src/canceleval.c (deleted) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/pthreadexit.c (modified) * cpukit/posix/src/pthreadinitthreads.c (modified) * cpukit/posix/src/setcancelstate.c (modified) * cpukit/posix/src/setcanceltype.c (modified) * cpukit/posix/src/testcancel.c (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadrestart.c (modified) posix: Rework thread cancellation Add ... Fri, 13 May 2016 12:07:23 GMT Sebastian Huber [33829ce] * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/rtems/src/taskstart.c (modified) * cpukit/score/include/rtems/score/statesimpl.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/mpci.c (modified) * cpukit/score/src/threadstart.c (modified) * testsuites/tmtests/tm26/task1.c (modified) score: Avoid Giant lock for _Thread_Start() Update #2555. Fri, 13 May 2016 06:16:30 GMT Sebastian Huber [54550e04] * cpukit/posix/include/rtems/posix/pthreadimpl.h (modified) * cpukit/posix/include/rtems/posix/threadsup.h (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/pthreaddetach.c (modified) * cpukit/posix/src/pthreadexit.c (modified) * cpukit/posix/src/pthreadgetattrnp.c (modified) * cpukit/posix/src/pthreadjoin.c (modified) * cpukit/rtems/src/taskdelete.c (modified) * cpukit/score/include/rtems/score/statesimpl.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadrestart.c (modified) posix: Rework pthread_join() Rework pthread_join() to use ... Fri, 13 May 2016 11:42:18 GMT Sebastian Huber [29e1ecab] * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadrestart.c (modified) score: Simplify _Thread_Life_action_handler() Use ... Fri, 13 May 2016 11:08:54 GMT Sebastian Huber [ef09017] * cpukit/score/src/threadrestart.c (modified) score: Rework _Thread_Cancel() Rework _Thread_Cancel() to use ... Fri, 13 May 2016 09:22:39 GMT Sebastian Huber [862a0ee] * cpukit/libmisc/monitor/mon-prmisc.c (modified) * cpukit/score/include/rtems/score/statesimpl.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/threadrestart.c (modified) score: Rework _Thread_Restart_other() Rework ... Fri, 13 May 2016 05:04:43 GMT Sebastian Huber [9388390] * cpukit/rtems/src/taskrestart.c (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadglobalconstruction.c (modified) * cpukit/score/src/threadrestart.c (modified) score: Split _Thread_Restart() Split _Thread_Restart() into ... Fri, 13 May 2016 08:16:32 GMT Sebastian Huber [0475cca] * cpukit/score/include/rtems/score/threaddispatch.h (modified) score: Add _Thread_Dispatch_disable_with_CPU() Update #2555. ... Fri, 13 May 2016 05:12:38 GMT Sebastian Huber [f410ea82] * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadclearstate.c (modified) score: Add _Thread_Clear_state_locked() This makes it possible to ... Fri, 13 May 2016 05:12:10 GMT Sebastian Huber [9a99ce15] * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadsetstate.c (modified) score: Add _Thread_Set_state_locked() This makes it possible to do ... Fri, 13 May 2016 05:04:13 GMT Sebastian Huber [232147dd] * cpukit/libmisc/monitor/mon-prmisc.c (modified) * cpukit/score/include/rtems/score/statesimpl.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadrestart.c (modified) score: Add _Thread_Join() and _Thread_Cancel() Split ... Thu, 12 May 2016 15:39:22 GMT Sebastian Huber [c99eb50b] * cpukit/score/src/threadrestart.c (modified) score: Rework _Thread_Exit() Rework _Thread_Exit() to use ... Fri, 13 May 2016 11:20:07 GMT Sebastian Huber [7023d82c] * cpukit/score/src/threadrestart.c (modified) score: Add _Thread_Raise_real_priority() Update #2555. Update #2626. Thu, 12 May 2016 14:32:27 GMT Sebastian Huber [9949d8a7] * cpukit/libcsupport/src/privateenv.c (modified) * cpukit/score/include/rtems/score/apimutex.h (modified) * cpukit/score/include/rtems/score/mrspimpl.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/apimutexlock.c (modified) * cpukit/score/src/apimutexunlock.c (modified) * cpukit/score/src/threadrestart.c (modified) * testsuites/smptests/smpthreadlife01/init.c (modified) * testsuites/sptests/spthreadlife01/init.c (modified) score: Add Thread_Change_life() Add _Thread_Change_life_locked() as ... Thu, 12 May 2016 13:14:06 GMT Sebastian Huber [69c722f] * cpukit/score/src/threadrestart.c (modified) score: Delete unused variable Update #2555. Update #2626. Thu, 12 May 2016 12:25:50 GMT Sebastian Huber [270394e] * cpukit/posix/src/pthreadexit.c (modified) * cpukit/rtems/src/taskdelete.c (modified) * cpukit/score/src/threadrestart.c (modified) score: Avoid superfluous life protection Disable thread dispatching ... Thu, 12 May 2016 04:12:06 GMT Sebastian Huber [b7f5e391] * cpukit/posix/src/pthreadexit.c (modified) * cpukit/rtems/src/taskdelete.c (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadrestart.c (modified) score: Add _Thread_Exit() The goal is to make _Thread_Exit() a ... Fri, 13 May 2016 08:21:37 GMT Sebastian Huber [e753748] * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) score: Delete redundant thread life enums This makes it easier to ... Wed, 18 May 2016 12:34:26 GMT Sebastian Huber [41ce30a] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/smplockmcs.h (added) * cpukit/score/preinstall.am (modified) * testsuites/smptests/smplock01/init.c (modified) SMP: Add Mellor-Crummey and Scott (MCS) lock Added only for ... Wed, 18 May 2016 14:54:12 GMT Sebastian Huber [26fafd5] * cpukit/score/include/rtems/score/smplockstats.h (modified) * cpukit/score/include/rtems/score/smplockticket.h (modified) SMP: Add and use lock statistics helper Wed, 18 May 2016 11:44:02 GMT Sebastian Huber [a7668b2] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/smplock.h (modified) * cpukit/score/include/rtems/score/smplockticket.h (added) * cpukit/score/preinstall.am (modified) SMP: Move ticket lock to separate header file Wed, 18 May 2016 11:28:52 GMT Sebastian Huber [2aae3a7] * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/smplock.h (modified) * cpukit/score/include/rtems/score/smplockstats.h (added) * cpukit/score/preinstall.am (modified) * cpukit/score/src/profilingsmplock.c (modified) SMP: Move lock stats to separate header file Tue, 17 May 2016 11:39:15 GMT Sebastian Huber [3c20d28] * cpukit/posix/src/pthreadkill.c (modified) * testsuites/psxtests/psx04/init.c (modified) posix: Fix return states of pthread_kill() POSIX mandates that an ... Fri, 13 May 2016 12:59:31 GMT Sebastian Huber [9fd7271] * cpukit/posix/src/cancel.c (modified) * testsuites/psxtests/psxcancel/init.c (modified) posix: Fix return status of pthread_cancel() POSIX recommends ESRCH ... Thu, 12 May 2016 11:08:49 GMT Sebastian Huber [df23f464] * cpukit/libmisc/capture/capture.c (modified) * cpukit/libmisc/capture/captureimpl.h (modified) capture: Fix use of per-processor data Get the current processor ... Thu, 12 May 2016 11:08:29 GMT Sebastian Huber [d449c12] * cpukit/libmisc/capture/capture.c (modified) capture: Remove superfluous includes Thu, 12 May 2016 09:14:38 GMT Sebastian Huber [7bd1869] * cpukit/libmisc/capture/capture.h (modified) capture: Compact rtems_capture_record_t Order fields according to ... Thu, 12 May 2016 09:12:27 GMT Sebastian Huber [2f11d4a] * cpukit/libmisc/capture/capture_buffer.c (modified) * cpukit/libmisc/capture/capture_buffer.h (modified) capture: Fix buffer allocation and free Do not use function static ... Thu, 12 May 2016 09:22:33 GMT Sebastian Huber [0727760] * cpukit/rtems/include/rtems/rtems/intr.h (modified) rtems: Add rtems_interrupt_lock_interrupt_disable Update #2707. Wed, 11 May 2016 12:03:23 GMT Sebastian Huber [ef6f8a83] * cpukit/rtems/src/taskgetscheduler.c (modified) * cpukit/rtems/src/tasksetscheduler.c (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) score: Avoid Giant lock for scheduler set/get Update #2555. Wed, 11 May 2016 11:42:58 GMT Sebastian Huber [8bc6bf28] * cpukit/posix/include/rtems/posix/pthreadimpl.h (modified) * cpukit/posix/include/rtems/posix/threadsup.h (modified) * cpukit/posix/src/pthread.c (modified) * cpukit/posix/src/pthreadgetattrnp.c (modified) * cpukit/posix/src/pthreadgetschedparam.c (modified) * cpukit/posix/src/pthreadsetschedparam.c (modified) * cpukit/score/include/rtems/score/thread.h (modified) posix: Avoid Giant lock for some pthread functions Avoid Giant lock ... Wed, 11 May 2016 09:06:51 GMT Sebastian Huber [d9952999] * cpukit/posix/src/pthreadgetaffinitynp.c (modified) * cpukit/rtems/src/taskgetaffinity.c (modified) * cpukit/score/src/schedulergetaffinity.c (modified) score: Avoid Giant lock _Scheduler_Get_affinity() Update #2555. Wed, 11 May 2016 08:58:59 GMT Sebastian Huber [e135271] * cpukit/libmisc/monitor/mon-prmisc.c (modified) * cpukit/posix/src/pthreadcreate.c (modified) * cpukit/posix/src/pthreadsetaffinitynp.c (modified) * cpukit/rtems/src/tasksetaffinity.c (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/statesimpl.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/schedulerpriorityaffinitysmp.c (modified) * cpukit/score/src/schedulersetaffinity.c (modified) score: Avoid Giant lock _Scheduler_Set_affinity() Update #2555. Wed, 11 May 2016 09:54:49 GMT Sebastian Huber [bd12dda] * cpukit/libmisc/cpuuse/cpuusagereset.c (modified) * cpukit/rtems/src/taskmode.c (modified) * cpukit/score/include/rtems/score/schedulerimpl.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/schedulercbsunblock.c (modified) * cpukit/score/src/threadchangepriority.c (modified) * cpukit/score/src/threadclearstate.c (modified) * cpukit/score/src/threadgetcputimeused.c (modified) * cpukit/score/src/threadsetstate.c (modified) * cpukit/score/src/threadyield.c (modified) * testsuites/smptests/smpscheduler03/init.c (modified) * testsuites/tmtests/tm27/task1.c (modified) score: Use thread state lock for current state In addition protect ... Wed, 11 May 2016 08:27:37 GMT Sebastian Huber [11c66437] * cpukit/rtems/src/taskissuspended.c (modified) rtems: Avoid Giant lock rtems_task_is_suspended() Update #2555. Wed, 11 May 2016 08:21:57 GMT Sebastian Huber [4d76300a] * cpukit/rtems/include/rtems/rtems/taskmp.h (modified) * cpukit/rtems/src/taskmp.c (modified) * cpukit/rtems/src/taskresume.c (modified) * cpukit/rtems/src/tasksetpriority.c (modified) * cpukit/rtems/src/tasksuspend.c (modified) rtems: Avoid Giant lock for some task operations Avoid Giant lock ... Tue, 10 May 2016 04:47:19 GMT Sebastian Huber [105b4e6] * cpukit/rtems/include/rtems/rtems/asr.h (modified) * cpukit/rtems/include/rtems/rtems/asrimpl.h (modified) * cpukit/rtems/src/signalcatch.c (modified) * cpukit/rtems/src/signalsend.c (modified) * cpukit/rtems/src/taskmode.c (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/score/include/rtems/score/thread.h (modified) rtems: Use thread state lock for signals Fri, 06 May 2016 04:44:41 GMT Sebastian Huber [6e4f929] * cpukit/posix/src/psignalunblockthread.c (modified) * cpukit/rtems/include/rtems/rtems/signalimpl.h (modified) * cpukit/rtems/src/signalcatch.c (modified) * cpukit/rtems/src/signalsend.c (modified) * cpukit/rtems/src/taskmode.c (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/thread.c (modified) * cpukit/score/src/threaddispatch.c (modified) * cpukit/score/src/threadinitialize.c (modified) * cpukit/score/src/threadrestart.c (modified) score: Introduce thread state lock Update #2556. Tue, 10 May 2016 05:52:19 GMT Sebastian Huber [af20467e] * cpukit/score/include/rtems/score/threadq.h (modified) * cpukit/score/include/rtems/score/threadqimpl.h (modified) score: Add _Thread_queue_Is_lock_owner() Add ... Fri, 06 May 2016 04:58:37 GMT Sebastian Huber [d9bb9eb] * cpukit/posix/include/rtems/posix/psignalimpl.h (modified) * cpukit/posix/src/psignal.c (modified) * cpukit/posix/src/psignalunblockthread.c (modified) posix: Make _POSIX_signals_Action_handler() static Wed, 04 May 2016 14:02:39 GMT Sebastian Huber [a0162bf] * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/regionimpl.h (modified) * cpukit/rtems/include/rtems/rtems/regionmp.h (deleted) * cpukit/rtems/preinstall.am (modified) * cpukit/rtems/src/regionmp.c (deleted) mpci: Delete unused region support Mon, 09 May 2016 05:29:52 GMT Sebastian Huber [3e0bb67] * cpukit/score/include/rtems/score/smplock.h (modified) * cpukit/score/src/smplock.c (modified) score: Ensure matching lock acquire and release Ensure matching ... Mon, 09 May 2016 04:49:53 GMT Sebastian Huber [1a9d36b] * cpukit/score/include/rtems/score/isrlock.h (modified) * cpukit/score/include/rtems/score/percpu.h (modified) * cpukit/score/include/rtems/score/smplock.h (modified) * cpukit/score/src/smplock.c (modified) score: Add _ISR_lock_Is_owner() Wed, 11 May 2016 15:52:13 GMT Sebastian Huber [9276fde] * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/src/coremutex.c (modified) * testsuites/sptests/Makefile.am (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/spmutex01/Makefile.am (added) * testsuites/sptests/spmutex01/init.c (added) * testsuites/sptests/spmutex01/spmutex01.doc (added) * testsuites/sptests/spmutex01/spmutex01.scn (added) score: Fix CORE mutex initialization The priority inheritance and ... Wed, 11 May 2016 14:42:29 GMT Sebastian Huber [2b71210] * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) Revert "score: Avoid use of uninitialized variable" Sorry, I should ... Wed, 11 May 2016 14:00:16 GMT Sebastian Huber [35c8efc] * cpukit/score/include/rtems/score/schedulersmpimpl.h (modified) score: Avoid use of uninitialized variable Properly set the ... Wed, 04 May 2016 09:28:12 GMT Sebastian Huber [f65f803] * cpukit/score/src/schedulercbsattachthread.c (modified) * cpukit/score/src/schedulercbsdetachthread.c (modified) * cpukit/score/src/schedulercbsgetexecutiontime.c (modified) * cpukit/score/src/schedulercbsgetremainingbudget.c (modified) score: Avoid Giant lock for CBS scheduler Update #2555. Wed, 04 May 2016 09:10:32 GMT Sebastian Huber [64051ec] * cpukit/posix/src/pthreadequal.c (modified) posix: Avoid Giant lock in pthread_equal() Update #2555. Wed, 04 May 2016 08:09:45 GMT Sebastian Huber [bb2ad039] * cpukit/rtems/include/rtems/rtems/asr.h (modified) * cpukit/rtems/include/rtems/rtems/asrimpl.h (modified) * cpukit/rtems/include/rtems/rtems/signalmp.h (modified) * cpukit/rtems/src/signalcatch.c (modified) * cpukit/rtems/src/signalmp.c (modified) * cpukit/rtems/src/signalsend.c (modified) * cpukit/rtems/src/taskmode.c (modified) rtems: Avoid Giant lock for signals Update #2555. Tue, 03 May 2016 14:16:08 GMT Sebastian Huber [b30ab25] * cpukit/score/src/mpci.c (modified) mpci: Avoid Giant lock in _MPCI_Process_response() Update #2555. ... Tue, 03 May 2016 07:59:50 GMT Sebastian Huber [a0dee7c7] * cpukit/rtems/include/rtems/rtems/eventmp.h (modified) * cpukit/rtems/src/eventmp.c (modified) * cpukit/rtems/src/eventsend.c (modified) * cpukit/rtems/src/systemeventsend.c (modified) * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/src/threadget.c (modified) score: Simplify _Thread_Get_interrupt_disable() Remove the object ... Tue, 03 May 2016 07:59:06 GMT Sebastian Huber [49a134dd] * cpukit/rtems/include/rtems/rtems/eventimpl.h (modified) * cpukit/rtems/src/eventsend.c (modified) * cpukit/rtems/src/eventsurrender.c (modified) * cpukit/rtems/src/systemeventsend.c (modified) rtems: Return status in _Event_Surrender() Tue, 03 May 2016 07:57:38 GMT Sebastian Huber [822ec589] * cpukit/score/include/rtems/score/threadimpl.h (modified) * cpukit/score/include/rtems/score/threadmp.h (modified) * cpukit/score/src/threadget.c (modified) score: Add _Thread_MP_Is_remote() Tue, 03 May 2016 07:24:32 GMT Sebastian Huber [8c77150] * cpukit/score/src/threadget.c (modified) score: Simplify _Thread_Get_objects_information() Tue, 03 May 2016 07:19:59 GMT Sebastian Huber [876dde7a] * cpukit/sapi/src/exinit.c (modified) * cpukit/score/include/rtems/score/objectimpl.h (modified) * cpukit/score/src/threadget.c (modified) * testsuites/sptests/sp43/init.c (modified) score: Make _Objects_Information_table const The ... Tue, 03 May 2016 07:17:45 GMT Sebastian Huber [469dc47] * cpukit/score/src/objectidtoname.c (modified) score: Simplify _Objects_Id_to_name() Tue, 03 May 2016 07:12:51 GMT Sebastian Huber [0ab4fb7] * cpukit/score/src/objectidtoname.c (modified) score: Fix _Objects_Id_to_name() Avoid out-of-bounds array access ... Tue, 03 May 2016 05:38:19 GMT Sebastian Huber [1d40d81b] * c/src/ada/rtems-tasks.adb (modified) * c/src/ada/rtems-tasks.ads (modified) * cpukit/rtems/Makefile.am (modified) * cpukit/rtems/include/rtems/rtems/tasks.h (modified) * cpukit/rtems/include/rtems/rtems/tasksimpl.h (modified) * cpukit/rtems/mainpage.h (modified) * cpukit/rtems/src/tasks.c (modified) * cpukit/rtems/src/taskvariable_invoke_dtor.c (deleted) * cpukit/rtems/src/taskvariableadd.c (deleted) * cpukit/rtems/src/taskvariabledelete.c (deleted) * cpukit/rtems/src/taskvariableget.c (deleted) * cpukit/sapi/include/confdefs.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * testsuites/psxtests/psxconfig01/init.c (modified) * testsuites/sptests/configure.ac (modified) * testsuites/sptests/sp28/Makefile.am (deleted) * testsuites/sptests/sp28/init.c (deleted) * testsuites/sptests/sp28/sp28.doc (deleted) * testsuites/sptests/sp28/sp28.scn (deleted) rtems: Remove task variables Update #2494. Update #2555. Tue, 03 May 2016 10:57:16 GMT Sebastian Huber [b1b6f3b0] * cpukit/sapi/include/confdefs.h (modified) * cpukit/score/src/coremsg.c (modified) confdefs.h: Fix message queue size estimate Account for maximum ... Tue, 03 May 2016 10:55:00 GMT Sebastian Huber [e4fd35d] * cpukit/sapi/include/confdefs.h (modified) * testsuites/psxtests/psxconfig01/init.c (modified) confdefs.h: Fix named object size estimate Account for the ... Sun, 01 May 2016 14:11:30 GMT Sebastian Huber [0a68d8e] * cpukit/posix/include/rtems/posix/barrierimpl.h (modified) * cpukit/posix/include/rtems/posix/mqueueimpl.h (modified) * cpukit/posix/include/rtems/posix/semaphoreimpl.h (modified) * cpukit/posix/include/rtems/posix/spinlockimpl.h (modified) * cpukit/posix/include/rtems/posix/timerimpl.h (modified) * cpukit/posix/src/condget.c (modified) * cpukit/posix/src/prwlockinit.c (modified) * cpukit/rtems/include/rtems/rtems/barrierimpl.h (modified) * cpukit/rtems/include/rtems/rtems/dpmemimpl.h (modified) * cpukit/rtems/include/rtems/rtems/ratemonimpl.h (modified) * cpukit/rtems/include/rtems/rtems/timerimpl.h (modified) * cpukit/score/include/rtems/score/objectimpl.h (modified) * cpukit/score/src/objectgetlocal.c (modified) * cpukit/score/src/objectgetnameasstring.c (modified) score: Optimize _Objects_Get_local() Make the interrupt lock ... Mon, 02 May 2016 04:30:49 GMT Sebastian Huber [e38a92b] * cpukit/rtems/include/rtems/rtems/barriermp.h (modified) * cpukit/rtems/include/rtems/rtems/eventmp.h (modified) * cpukit/rtems/include/rtems/rtems/msgmp.h (modified) * cpukit/rtems/include/rtems/rtems/partmp.h (modified) * cpukit/rtems/include/rtems/rtems/regionmp.h (modified) * cpukit/rtems/include/rtems/rtems/semmp.h (modified) * cpukit/rtems/include/rtems/rtems/signalmp.h (modified) * cpukit/rtems/include/rtems/rtems/taskmp.h (modified) * cpukit/rtems/src/eventmp.c (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/rtems/src/partmp.c (modified) * cpukit/rtems/src/regionmp.c (modified) * cpukit/rtems/src/semmp.c (modified) * cpukit/rtems/src/signalmp.c (modified) * cpukit/rtems/src/taskmp.c (modified) mpci: Make _*_MP_Get_packet() static Mon, 02 May 2016 04:17:07 GMT Sebastian Huber [c506158c] * cpukit/rtems/include/rtems/rtems/barriermp.h (modified) * cpukit/rtems/include/rtems/rtems/eventmp.h (modified) * cpukit/rtems/include/rtems/rtems/msgmp.h (modified) * cpukit/rtems/include/rtems/rtems/partmp.h (modified) * cpukit/rtems/include/rtems/rtems/regionmp.h (modified) * cpukit/rtems/include/rtems/rtems/semmp.h (modified) * cpukit/rtems/include/rtems/rtems/signalmp.h (modified) * cpukit/rtems/include/rtems/rtems/taskmp.h (modified) * cpukit/rtems/src/eventmp.c (modified) * cpukit/rtems/src/msgmp.c (modified) * cpukit/rtems/src/partmp.c (modified) * cpukit/rtems/src/regionmp.c (modified) * cpukit/rtems/src/semmp.c (modified) * cpukit/rtems/src/signalmp.c (modified) * cpukit/rtems/src/taskmp.c (modified) mpci: Make _*_MP_Send_response_packet() static Mon, 02 May 2016 11:11:18 GMT Sebastian Huber [b1b8bd2] * cpukit/score/include/rtems/score/corebarrierimpl.h (modified) mpci: Fix _CORE_barrier_Surrender() Bug introduced by ... Fri, 29 Apr 2016 10:09:32 GMT Sebastian Huber [981eed2] * cpukit/sapi/include/confdefs.h (modified) * cpukit/sapi/include/rtems/scheduler.h (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/schedulerstrongapa.h (added) * cpukit/score/preinstall.am (modified) * cpukit/score/src/schedulerstrongapa.c (added) * testsuites/smptests/Makefile.am (modified) * testsuites/smptests/configure.ac (modified) * testsuites/smptests/smpstrongapa01/Makefile.am (added) * testsuites/smptests/smpstrongapa01/init.c (added) * testsuites/smptests/smpstrongapa01/smpstrongapa01.doc (added) * testsuites/smptests/smpstrongapa01/smpstrongapa01.scn (added) score: Add dummy Strong APA scheduler Start with a copy of the ... Fri, 29 Apr 2016 07:27:11 GMT Sebastian Huber [66374df] * cpukit/posix/src/killinfo.c (modified) posix: Avoid Giant lock in _POSIX_signals_Send() Update #2555. ... Thu, 28 Apr 2016 04:55:16 GMT Sebastian Huber [259d885] * cpukit/posix/src/sigtimedwait.c (modified) posix: Remove superfluous thread dispatch disable The ... Thu, 28 Apr 2016 04:51:25 GMT Sebastian Huber [d5cc9fd6] * cpukit/configure.ac (modified) * cpukit/score/Makefile.am (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/src/coremutexseize.c (modified) * cpukit/score/src/coremutexseizeintr.c (deleted) score: __RTEMS_DO_NOT_INLINE_CORE_MUTEX_SEIZE__ Delete ... Thu, 28 Apr 2016 04:26:01 GMT Sebastian Huber [500a8e9c] * cpukit/configure.ac (modified) * cpukit/posix/src/mutextranslatereturncode.c (modified) * cpukit/rtems/src/semtranslatereturncode.c (modified) * cpukit/score/include/rtems/score/coremutex.h (modified) * cpukit/score/include/rtems/score/coremuteximpl.h (modified) * cpukit/score/include/rtems/score/thread.h (modified) * cpukit/score/src/coremutex.c (modified) * cpukit/score/src/coremutexsurrender.c (modified) * cpukit/score/src/threadinitialize.c (modified) * testsuites/sptests/sp36/strict_order_mut.c (modified) score: Delete __RTEMS_STRICT_ORDER_MUTEX__ Remove support for ... Wed, 27 Apr 2016 20:07:56 GMT Sebastian Huber [1ef8e4a8] * cpukit/posix/src/adjtime.c (modified) * cpukit/posix/src/clocksettime.c (modified) * cpukit/rtems/src/clockset.c (modified) * cpukit/score/include/rtems/score/timecounterimpl.h (modified) * cpukit/score/include/rtems/score/todimpl.h (modified) * cpukit/score/src/coretodadjust.c (modified) * cpukit/score/src/coretodset.c (modified) * cpukit/score/src/kern_tc.c (modified) score: Avoid Giant lock for set time of day Update #2555. Update #2630. Wed, 27 Apr 2016 19:32:23 GMT Sebastian Huber [3888771] * cpukit/posix/src/clocksettime.c (modified) * cpukit/rtems/src/clockset.c (modified) * cpukit/score/include/rtems/score/todimpl.h (modified) * cpukit/score/src/coretodadjust.c (modified) * cpukit/score/src/coretodset.c (modified) score: Streamline set time of day functions Rename _TOD_Set() into ... Wed, 27 Apr 2016 14:52:48 GMT Sebastian Huber [7772640] * cpukit/score/src/objectgetnameasstring.c (modified) score: _Objects_Get_name_as_string() Avoid Giant lock in ... Wed, 27 Apr 2016 14:46:57 GMT Sebastian Huber [f4d541cc] * cpukit/rtems/src/rtemsobjectsetname.c (modified) rtems: Avoid Giant lock in rtems_object_set_name() Update #2555. Wed, 27 Apr 2016 14:36:04 GMT Sebastian Huber [f009ed0] * cpukit/libnetworking/rtems/rtems_glue.c (modified) * cpukit/rtems/include/rtems/rtems/semimpl.h (modified) * cpukit/rtems/src/semsetpriority.c (modified) * testsuites/tmtests/tm26/task1.c (modified) rtems: Avoid Giant lock for semaphores Update #2555.
